Ducdanh Nguyen Posted August 10 Posted August 10 On 11/27/2023 at 2:53 AM, Victorhtf said: Did anyone made any progress? I also bought a TVBox transpeed with H618 and I would like to install armbian to make my own server based in Linux. Anyone tried with H616 image? By the way, is it possible to backup original ROM before I run some tests? Cause if it not works I would like to keep my TV Box working on. you can install and boot from the sd card, also h616 uses nand flash, which can't write on it (or maybe it uses emmc) 0 Quote
Nick A Posted August 14 Posted August 14 (edited) @dale there’s a new patch to fix boards without external 32k clock. I haven’t tested it yet. https://github.com/warpme/minimyth2/commit/728a14a73924e349fe88fb4def7e5f50a79aed5c Edited August 14 by Nick A 1 Quote
dale Posted August 17 Posted August 17 (edited) On 6/26/2025 at 7:21 PM, c0rnelius said: You apply the patch to the kernel source-tree, In this case we will use meson64 as an example. Add the patch to: patch/kernel/archive/meson64-6.12/ Enable in the defconfig: echo "CONFIG_OPENVFD=m" >> config/kernel/linux-meson64-current.config Build a new IMG or KERNEL as one normally would for your unit. Hi I got error when applying the patch you shared. Can I know how to fix it? Edited August 18 by dale 0 Quote
buzz89 Posted August 19 Posted August 19 I just got an H618 board. It is able to boot using the Vontar image, but the onboard Ethernet is not working. USB Ethernet works fine. The Ethernet chip is RTL8211F, I’m hoping to get some guidance on this issue. Here’s the relevant dmesg output related to Ethernet: dmesg | grep eth [ 0.000000] psci: probing for conduit method from DT. [ 2.422638] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 2.422669] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 2.422678] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 2.422989] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 2.423245] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 2.423316] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 2.426176] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 2.426204] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 2.426211] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 2.426220] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 2.426226] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 2.426232] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 2.469198] dwmac-sun8i 5030000.ethernet end0: renamed from eth0 [ 3.060680] asix 2-1:1.0 eth0: register 'asix' at usb-5200000.usb-1, ASIX AX88772B USB 2.0 Ethernet, 00:0e:c6:c5:f5:e5 [ 3.068667] asix 2-1:1.0 enx000ec6c5f5e5: renamed from eth0 [ 11.377369] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 11.388786] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL) [ 11.388838] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found [ 11.388849] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available [ 11.388859] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW [ 11.393925] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode 0 Quote
buzz89 Posted August 20 Posted August 20 I have build a new image, but no luck, the ethernet is still not working. Here is what I changed. diff --git a/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch b/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch index 747ddca7b..6a88acfcf 100644 --- a/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch +++ b/patch/u-boot/u-boot-h616/160-add-vontar-h618-defconfig.patch @@ -73,9 +73,9 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts +}; + +&mdio1 { -+ rmii_phy: ethernet-phy@16 { ++ rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; -+ reg = <16>; ++ reg = <0>; + }; +}; + dmesg: root@vontar-h618:~# dmesg | grep ether [ 2.850576] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found [ 2.850587] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found [ 2.850597] dwmac-sun8i 5030000.ethernet: IRQ sfty not found [ 2.850841] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator [ 2.851059] dwmac-sun8i 5030000.ethernet: PTP uses main clock [ 2.851089] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0) [ 2.851770] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported [ 2.851780] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported [ 2.851787] dwmac-sun8i 5030000.ethernet: COE Type 2 [ 2.851794] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported [ 2.851801] dwmac-sun8i 5030000.ethernet: Normal descriptors [ 2.851807] dwmac-sun8i 5030000.ethernet: Chain mode enabled [ 2.979923] dwmac-sun8i 5030000.ethernet: EMAC reset timeout [ 2.979966] dwmac-sun8i 5030000.ethernet eth0: stmmac_dvr_remove: removing driver [ 3.004135] dwmac-sun8i 5030000.ethernet: probe with driver dwmac-sun8i failed with error -110 ip link 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN mode DEFAULT group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 3: enx000ec6c5f5e5: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP mode DEFAULT group default qlen 1000 link/ether 00:0e:c6:c5:f5:e5 brd ff:ff:ff:ff:ff:ff 0 Quote
Nick A Posted August 20 Posted August 20 RTL8211F Is an external gigabit chip. Maybe this post will help. 0 Quote
buzz89 Posted August 20 Posted August 20 unable to build. dts/upstream/src/arm64/allwinner/sun50i-h616-vontar-h618.dtb: ERROR (phandle_references): /soc/ethernet@5020000: Reference to non-existent node or label "reg_dcdce" @@ -23,7 +23,7 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts + mmc0 = &mmc0; + mmc1 = &mmc1; + mmc2 = &mmc2; -+ ethernet0 = &emac1; ++ ethernet0 = &emac0; + serial0 = &uart0; + }; + @@ -61,21 +61,21 @@ diff --speed-large-files --no-dereference --minimal -Naur u-boot-2024.01-rc3/dts + status = "okay"; +}; + -+&emac1 { ++&emac0 { + pinctrl-names = "default"; -+ pinctrl-0 = <&rmii_pins>; ++ pinctrl-0 = <&ext_rgmii_pins>; + phy-mode = "rmii"; -+ phy-handle = <&rmii_phy>; -+ phy-supply = <®_aldo1>; ++ phy-handle = <&ext_rgmii_pins>; ++ phy-supply = <®_dcdce>; + allwinner,rx-delay-ps = <3100>; + allwinner,tx-delay-ps = <700>; + status = "okay"; +}; + +&mdio1 { -+ rmii_phy: ethernet-phy@16 { ++ rmii_phy: ethernet-phy@0 { + compatible = "ethernet-phy-ieee802.3-c22"; -+ reg = <16>; ++ reg = <0>; + }; +}; + 0 Quote
Nick A Posted August 20 Posted August 20 (edited) @buzz89In oranges zero2 dts it has a 3.3v regulator defined as reg_dcdce. There’s only 5v defined in the vontar dts. You can add this to your dts reg_dcdce: dcdce { regulator-always-on; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-eth-mmc"; }; https://linux.googlesource.com/linux/kernel/git/bpf/bpf/+/refs/tags/v6.9-rc2/arch/arm64/boot/dts/allwinner/sun50i-h616-orangepi-zero2.dts you can borrow code off these boards as well https://linux-sunxi.org/index.php?search=RTL8211F&title=Special%3ASearch&go=Go if you can extract your android dts for more clues. Edited August 20 by Nick A 0 Quote
buzz89 Posted August 21 Posted August 21 Sorry, I don't have the Android dts, the Android image is erased. I have tried the image from niulinkcloud, The ethernet is working on this image, can we extract dts from this image? 0 Quote
Nick A Posted August 21 Posted August 21 @buzz89 never heard of it. If you have root access you probably can. 0 Quote
buzz89 Posted August 23 Posted August 23 (edited) @Nick AI tried to extract the dts from the working image, cloud you help me find any clues. Thank you. I was able to gain access to the os that works, this is the dmesg: dmesg | grep eth [ 8.550757] libphy: 5020000.eth: probed [ 8.568109] sunxi-gmac 5020000.eth eth0: eth0: Type(8) PHY ID 001cc916 at 0 IRQ poll (5020000.eth-0:00) [ 12.765916] sunxi-gmac 5020000.eth eth0: Link is Up - 1Gbps/Full - flow control off [ 12.775526] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready I also upload the pic of ethernet chip. dts.zip Edited August 23 by buzz89 0 Quote
robertoj Posted August 26 Posted August 26 On 8/16/2025 at 8:25 PM, dale said: Hi I got error when applying the patch you shared. Can I know how to fix it? I don't know anything about this patch, but check this: * Linux version you are using, vs Linux version corneliius has used * Try deleting the hunk in the patch that caused the problem you saw, and see if other hunks cause patch failures * If it is only one hunk causing the problem, look at the file that is affected by the patch drivers/auxdisplay/Makefile: do the lines mentioned in the hunk exist in the Makefile? In the expected line number? 0 Quote
dale Posted August 27 Posted August 27 @robertoj thank you for the answer. I will look at it. @Nick A Hi Nick, for your x98h box, is the wifi working after a reboot command? 0 Quote
Nick A Posted August 27 Posted August 27 @dale I remember wifi stopped working once. You could try this branch and see if it works for you. I haven’t tested it on my x98h yet. On transpeed the a/v audio has issues so I haven’t released images. https://github.com/NickAlilovic/build/tree/v20250407 0 Quote
dale Posted August 28 Posted August 28 (edited) @Nick A it has same issue. I thik it is related to the device tree declaration. Should it be something like this? Quote mmc@4021000 { compatible = "allwinner,sun50i-h616-mmc\0allwinner,sun50i-a100-mmc"; reg = <0x4021000 0x1000>; clocks = <0x02 0x40 0x02 0x3d>; clock-names = "ahb\0mmc"; resets = <0x02 0x0f>; reset-names = "ahb"; interrupts = <0x00 0x24 0x04>; pinctrl-names = "default"; pinctrl-0 = <0x15>; status = "okay"; max-frequency = <50000000>; mmc-ddr-1_8v; no-sd; no-mmc; cap-sdio-irq; #address-cells = <1>; #size-cells = <0>; mmc-pwrseq = <0x16>; phandle = <0x54>; bus-width = <0x04>; non-removable; vmmc-supply = <0x12>; vqmmc-supply = <0x11>; }; rfkill { compatible = "allwinner,sunxi-rfkill"; status = "okay"; chip_en; power_en; pinctrl-0; pinctrl-names; clocks; phandle = <0xd2>; wlan { compatible = "allwinner,sunxi-wlan"; wlan_busnum = <0x01>; wlan_power; wlan_regon = <&pio 0x06 0x12 0>; wlan_hostwake = <&pio 0x06 0x0f 0>; wakeup-source; phandle = <0xd3>; }; bt { compatible = "allwinner,sunxi-bt"; bt_power; bt_rst_n = <&pio 0x06 0x13 1>; phandle = <0xd4>; }; }; btlpm { compatible = "allwinner,sunxi-btlpm"; status = "okay"; uart_index = <0x01>; bt_wake = <&pio 0x06 0x11 0>; bt_hostwake = <&pio 0x06 0x10 0>; wakeup-source; phandle = <0xd6>; }; https://github.com/LYU4662/aic8800-sdio-linux-1.0 Edited August 28 by dale 0 Quote
kazekami_him Posted September 10 Posted September 10 @Rodrigo Campos@Nick A This guy seems to have created a u-boot that can get 4gb ram for M98-8K. https://github.com/nitrolack/M98-8K-Linux/blob/main/U-Boot Screen 20-03-2024 0 Quote
dale Posted September 12 Posted September 12 (edited) @Nick A I fixed the wifi issue after warm reboot for x98h with this patch: Quote + reg_vcc_wifi: reg_vcc_wifi { + compatible = "regulator-fixed"; + regulator-name = "vcc-wifi"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&pio 6 18 GPIO_ACTIVE_HIGH>; /* PG18 = WL_REG_ON */ + enable-active-high; + regulator-always-on; + }; + + wifi_pwrseq: wifi_pwrseq { + compatible = "mmc-pwrseq-simple"; + // No reset-gpios needed here, handled by regulator + // No external clock needed (chip has its own crystal) + }; + +&mmc1 { + vmmc-supply = <®_vcc_wifi>; /* power controlled by PG18 */ + vqmmc-supply = <®_aldo1>; /* IO voltage (1.8V) */ + mmc-pwrseq = <&wifi_pwrseq>; + bus-width = <4>; + non-removable; + no-sd; + no-mmc; + max-frequency = <50000000>; + status = "okay"; + + wlan: wifi@1 { + reg = <1>; + interrupt-parent = <&pio>; + interrupts = <6 15 IRQ_TYPE_EDGE_RISING>; /* PG15 WL_HOSTWAKE */ + interrupt-names = "host-wake"; + // optional: local-mac-address = [00 11 22 33 44 55]; + }; +}; Edited September 12 by dale 0 Quote
Rodrigo Campos Posted September 16 Posted September 16 On 9/10/2025 at 12:47 AM, kazekami_him said: @Rodrigo Campos@Nick A This guy seems to have created a u-boot that can get 4gb ram for M98-8K. https://github.com/nitrolack/M98-8K-Linux/blob/main/U-Boot Screen 20-03-2024 Hi @kazekami_him, Thanks for your information, but I have no idea in how to use this content for test it. Maybe @Nick A Could understand what this guy did and how to bring it to his port and help us to detect the correct ram amount. 0 Quote
Nick A Posted September 16 Posted September 16 (edited) @Rodrigo Campos @kazekami_him I think @nitrolack and @afiftyp had the same Transpeed M98-8k board. It booted fine with my transpeed image. (other than wifi) They didn't have a board that had secure boot. Check if your board is the same. Maybe you could try my older images. It could be the newer u-boot and patches broke the ram detection? Maybe your board is using a different ram? Edited September 16 by Nick A 0 Quote
Rodrigo Campos Posted September 17 Posted September 17 Hi @Nick A, the armbian in afiftyp board just see 2GB to, at least it was this way in 2024 when he sent me his boot log. My board is very similar to afiftyp board, except of a number near the QC sticker, that looks like a version number. afiftyp number is 2336 and the mine is 2333. The amout of memory chips is identical to (8 chips), but tha labels is a litle different, but I cant found the label meaning. I use your image since very old one, so I don't think it is about u-boot update, but I could try an older one. About Secure Boot, A patch that you give me solved it and it isn't a problem any more (thanks again for it). @afiftyp, if I'm wrong and you already solve your rom amount in armbian, please let us know and if you could, explain us what you did to solve it, thanks. 0 Quote
emor acid Posted Monday at 09:29 AM Posted Monday at 09:29 AM (edited) I flashed armbian into my h618, but it won't boot. I have an ubuntu image that boots it, but I don't know the password, so I need to flash armbian again. Can I use this ubuntu image to debug the armbian boot? Edited Monday at 09:32 AM by emor acid 0 Quote
Werner Posted Monday at 01:58 PM Posted Monday at 01:58 PM 4 hours ago, emor acid said: debug the armbian boot? https://debug.armbian.de tl;dr: get an USB uart adapter and debug via serial console. 0 Quote
emor acid Posted 22 hours ago Posted 22 hours ago U-Boot 2024.01-armbian-2024.01-S866c-Pbc32-Ha9af-V80bb-Bda0a-R448a (Nov 25 2024 - 14:01:12 -0500) Allwinner Technology CPU: Allwinner H616 (SUN50I) Model: Transpeed 8K618-T DRAM: 4 GiB Core: 61 devices, 22 uclasses, devicetree: separate WDT: Not starting watchdog@30090a0 MMC: mmc@4020000: 0, mmc@4022000: 1 Loading Environment from FAT... MMC: no card present ** Bad device specification mmc 0 ** In: serial@5000000 Out: serial@5000000 Err: serial@5000000 Net: apply fix for AC300 ephy bb version bug ... using AC300 emac1 ephy default config ... eth0: ethernet@5030000 starting USB... Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus USB EHCI 1.00 Bus usb@5101400: USB OHCI 1.0 Bus usb@5200000: USB EHCI 1.00 Bus usb@5200400: USB OHCI 1.0 scanning bus usb@5101000 for devices... 1 USB Device(s) found scanning bus usb@5101400 for devices... 1 USB Device(s) found scanning bus usb@5200000 for devices... 1 USB Device(s) found scanning bus usb@5200400 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Autoboot in 1 seconds, press <Space> to stop MMC: no card present switch to partitions #0, OK mmc1(part 0) is current device Scanning mmc 1:1... MMC: no card present No EFI system partition No EFI system partition Failed to persist EFI variables BootOrder not defined EFI boot manager: Cannot load any image Device 0: unknown device ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! missing environment variable: pxeuuid Retrieving file: pxelinux.cfg/01-02-00-41-2d-68-a7 ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Retrieving file: pxelinux.cfg/00000000 ethernet@5030000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! Retrieving file: pxelinux.cfg/0000000 what can i do ? and how to do? 3ks 0 Quote
Nick A Posted 4 hours ago Posted 4 hours ago (edited) @emor acid could be your gpio settings for mmc0. Try the x98h image. If that doesn’t work you need to extract your android dts or use the one from the working Ubuntu. Edited 3 hours ago by Nick A 0 Quote
