@Nick AThank you for your suggestion. I can boot up normally using this img, but the wired network cannot be recognized. There is no network.  Armbian-unofficial_25.05.0-trunk_Vontar-h618_bookworm_edge_6.12.11_server.img
1. I want to know how to extract the DTS file from the Android .img file and use it in my existing ARMbian system.
2. What should I do if the wired network connection is not recognized?
Posted (edited)
03.10.2025 в 15:33, Nick A сказал:
You can build your own Debian 13 Trixie version.
I tried to build image for my vontar h618 box (PCB FX-H618-D4-V10, 4GB Samsung memory, 32GB eMMC). I've compiled it with KERNEL_BTF=no because I have limited RAM in Linux VM - 4+GB wasn't enough for BTF building. Board starts, LAN works OK, but WIFI wasn't present in device list.
then I tried to update system - update is fetched but it seems like .dts is replaced, and HDMI and LAN didn't work at all. /proc/device-tree/name is empty.
I tried to add "fdtfile=sun50i-h618-transpeed-8k618-t.dtb" in /boot/armbianEnv.txt - after reboot all remains same.
how to specify right device tree at boot?
UPD:
I've changed line to "fdtfile=allwinner/sun50i-h618-transpeed-8k618-t.dtb", dtb file seems to be loaded, but nothing happened:
systemd-shutdown[1]: Failed to set watchdog hardware timeout to 10min: Invalid argument
reboot: Restarting system
U-Boot SPL 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300)
DRAM:testing 32-bit width, rank = 2
read calibration failed!
testing 32-bit width, rank = 1
DRAM:Store cfg
DRAM:1st writing pattern
DRAM:detecting column address bits
detected 11 columns
DRAM:restore cfg
DRAM:reconfigure for all active rows
DRAM:store cfg
DRAM:2nd writing pattern
DRAM:detecting row address bits
detected 16 rows
DRAM:restoring cfg
DRAM:end of auto detect dram size
MBUS port 0 cfg0 0100000d cfg1 00640080
MBUS port 1 cfg0 06000009 cfg1 01000578
MBUS port 2 cfg0 0200000d cfg1 00600100
MBUS port 3 cfg0 01000009 cfg1 00500064
MBUS port 4 cfg0 20000209 cfg1 1388157c
MBUS port 5 cfg0 00640209 cfg1 00200040
MBUS port 6 cfg0 00640209 cfg1 00200040
MBUS port 8 cfg0 01000009 cfg1 00400080
MBUS port 11 cfg0 01000009 cfg1 00640080
MBUS port 14 cfg0 04000009 cfg1 00400100
MBUS port 16 cfg0 2000060d cfg1 09600af0
MBUS port 21 cfg0 0800060d cfg1 02000300
MBUS port 22 cfg0 01000009 cfg1 00640080
MBUS port 25 cfg0 0064000f cfg1 00200040
MBUS port 26 cfg0 20000209 cfg1 1388157c
MBUS port 37 cfg0 01000009 cfg1 00400080
MBUS port 38 cfg0 00640209 cfg1 00200040
MBUS port 39 cfg0 20000209 cfg1 1388157c
MBUS port 40 cfg0 00640209 cfg1 00200040
 4096 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.10.14(debug):armbian
NOTICE:  BL31: Built : 13:42:51, Oct  8 2025
NOTICE:  BL31: Detected Allwinner H616 SoC (1823)
NOTICE:  BL31: Found U-Boot DTB at 0x4a0a3760, model: Transpeed 8K618-T
INFO:    ARM GICv2 driver initialized
INFO:    Configuring SPC Controller
INFO:    PMIC: Probing AXP305 on RSB
ERROR:   RSB: set run-time address: 0x10003
INFO:    Could not init RSB: -65539
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for erratum 855873 was applied
INFO:    BL31: cortex_a53: CPU workaround for erratum 1530924 was applied
INFO:    PSCI: Suspend is unavailable
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
INFO:    Changed devicetree.
ns16550_serial serial@5000000: pinctrl_select_state_full: uclass_get_device_by_phandle_id: err=-19
U-Boot 2025.01-armbian-2025.01-S6d41-P65b3-H8869-Va3a9-Bb703-R448a-dirty (Oct 08 2025 - 13:44:47 +0300) Allwinner Technology
CPU:   Allwinner H616 (SUN50I)
Model: Transpeed 8K618-T
DRAM:  4 GiB
Core:  68 devices, 22 uclasses, devicetree: separate
WDT:   Not starting watchdog@30090a0
MMC:   mmc@4020000: 0, mmc@4021000: 2, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   apply fix for AC300 ephy bb version bug ...
using AC300 emac1 ephy default config ...
eth0: ethernet@5030000
starting USB...
Bus usb@5101000: sun4i_usb_phy phy@5100400: External vbus detected, not enabling our own vbus
USB EHCI 1.00
Bus usb@5101400: USB OHCI 1.0
Bus usb@5200000: USB EHCI 1.00
Bus usb@5200400: USB OHCI 1.0
scanning bus usb@5101000 for devices... 1 USB Device(s) found
scanning bus usb@5101400 for devices... 1 USB Device(s) found
scanning bus usb@5200000 for devices... 1 USB Device(s) found
scanning bus usb@5200400 for devices... 2 USB Device(s) found
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
4641 bytes read in 9 ms (502.9 KiB/s)
U-boot loaded from SD
Boot script loaded from mmc
267 bytes read in 5 ms (51.8 KiB/s)
Load fdt: /boot/dtb/allwinner/sun50i-h618-transpeed-8k618-t.dtb
41706 bytes read in 18 ms (2.2 MiB/s)
Working FDT set to 4fa00000
4203 bytes read in 17 ms (241.2 KiB/s)
Applying kernel provided DT fixup script (sun50i-h616-fixup.scr)
## Executing script at 45000000
22434042 bytes read in 1151 ms (18.6 MiB/s)
32059904 bytes read in 1642 ms (18.6 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42170000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
   Data Size:    22433978 Bytes = 21.4 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 48a9a000, end 49fff0ba ... OK
   Loading Device Tree to 0000000048a27000, end 0000000048a99fff ... OK
Working FDT set to 48a27000
Starting kernel ...
done.
Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done.
Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems
done.
Begin: Will now check root file system ... fsck from util-linux 2.41
[/sbin/fsck.ext4 (1) -- /dev/mmcblk1p1] fsck.ext4 -a -C0 /dev/mmcblk1p1
armbi_root: clean, 43618/460672 files, 738631/1903616 blocks
done.
done.
Begin: Running /scripts/local-bottom ... done.
Begin: Running /scripts/init-bottom ... done.
SELinux:  Could not open policy file <= /etc/selinux/default/policy/policy.34:  No such file or directory
Welcome to Armbian 25.11.0-trunk.38 trixie!
<daemons startup>
UPD2:
devicetree seems to be loaded, strange that it isn't work:
# cat /proc/device-tree/model
Transpeed 8K618-T
it seems like it's kernel-related thing?
Here's full dmesg:
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 6.15.4-edge-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP PREEMPT Fri Jun 27 10:13:43 UTC 2025
[    0.000000] KASLR disabled due to lack of seed
[    0.000000] Machine model: Transpeed 8K618-T
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: 0x0000000040000000..0x000000004007ffff (512 KiB) nomap non-reusable secmon@40000000
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000013fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000004007ffff]
[    0.000000]   node   0: [mem 0x0000000040080000-0x000000013fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000013fffffff]
[    0.000000] cma: Reserved 64 MiB at 0x00000000fc000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.4
[    0.000000] percpu: Embedded 24 pages/cpu s58840 r8192 d31272 u98304
[    0.000000] pcpu-alloc: s58840 r8192 d31272 u98304 alloc=24*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] alternatives: applying boot alternatives
[    0.000000] Kernel command line: root=UUID=19261dfd-7753-43cf-91f1-a7dbdbdd0887 rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 console=tty1 consoleblank=0 loglevel=1 ubootpart=0ab155bb-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=memory
[    0.000000] Unknown kernel command line parameters "splash=verbose ubootpart=0ab155bb-01 cgroup_enable=memory", will be passed to user space.
[    0.000000] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] software IO TLB: area num 4.
[    0.000000] software IO TLB: mapped [mem 0x00000000f8000000-0x00000000fc000000] (64MB)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 1048576
[    0.000000] mem auto-init: stack:all(zero), heap alloc:off, heap free:off
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000713] Console: colour dummy device 80x25
[    0.000725] printk: legacy console [tty1] enabled
[    0.000821] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000835] pid_max: default: 32768 minimum: 301
[    0.000943] LSM: initializing lsm=capability,yama,selinux,tomoyo
[    0.001011] Yama: becoming mindful.
[    0.001034] SELinux:  Initializing.
[    0.001539] TOMOYO Linux initialized
[    0.001642] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001668] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003667] rcu: Hierarchical SRCU implementation.
[    0.003674] rcu:     Max phase no-delay instances is 1000.
[    0.003880] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.004075] EFI services will not be available.
[    0.004252] smp: Bringing up secondary CPUs ...
[    0.004678] Detected VIPT I-cache on CPU1
[    0.004766] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.005273] Detected VIPT I-cache on CPU2
[    0.005328] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.005786] Detected VIPT I-cache on CPU3
[    0.005839] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.005913] smp: Brought up 1 node, 4 CPUs
[    0.005926] SMP: Total of 4 processors activated.
[    0.005931] CPU: All CPU(s) started at EL2
[    0.005963] CPU features: detected: 32-bit EL0 Support
[    0.005968] CPU features: detected: 32-bit EL1 Support
[    0.005975] CPU features: detected: CRC32 instructions
[    0.005985] CPU features: detected: PMUv3
[    0.006020] alternatives: applying system-wide alternatives
[    0.007221] Memory: 3923712K/4194304K available (15424K kernel code, 1548K rwdata, 10612K rodata, 3584K init, 805K bss, 201468K reserved, 65536K cma-reserved)
[    0.008193] devtmpfs: initialized
[    0.015645] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.015664] posixtimers hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.015708] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.016980] 24720 pages in range for non-PLT usage
[    0.017001] 516240 pages in range for PLT usage
[    0.017271] pinctrl core: initialized pinctrl subsystem
[    0.017917] DMI not present or invalid.
[    0.020332] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.021506] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.021634] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.021826] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.021867] audit: initializing netlink subsys (disabled)
[    0.022046] audit: type=2000 audit(0.020:1): state=initialized audit_enabled=0 res=1
[    0.022522] thermal_sys: Registered thermal governor 'fair_share'
[    0.022529] thermal_sys: Registered thermal governor 'bang_bang'
[    0.022534] thermal_sys: Registered thermal governor 'step_wise'
[    0.022539] thermal_sys: Registered thermal governor 'user_space'
[    0.022583] cpuidle: using governor ladder
[    0.022612] cpuidle: using governor menu
[    0.022727] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.022811] ASID allocator initialised with 65536 entries
[    0.027793] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.027851] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000
[    0.027938] /soc/interrupt-controller@3021000: Fixed dependency cycle(s) with /soc/interrupt-controller@3021000
[    0.028154] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.028176] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000
[    0.028215] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.028241] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@3001000
[    0.028258] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000
[    0.028276] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/clock@3001000
[    0.028293] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/rtc@7000000
[    0.028495] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.029164] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000
[    0.033583] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.033657] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.033680] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000
[    0.033876] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.033953] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.034248] /soc/clock@3001000: Fixed dependency cycle(s) with /soc/rtc@7000000
[    0.034369] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@3001000
[    0.034436] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000
[    0.034560] /soc/rtc@7000000: Fixed dependency cycle(s) with /soc/clock@7010000
[    0.034627] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/clock@3001000
[    0.034691] /soc/clock@7010000: Fixed dependency cycle(s) with /soc/rtc@7000000
[    0.037836] cryptd: max_cpu_qlen set to 1000
[    0.104143] raid6: neonx8   gen()  1898 MB/s
[    0.172223] raid6: neonx4   gen()  1858 MB/s
[    0.240321] raid6: neonx2   gen()  1785 MB/s
[    0.308399] raid6: neonx1   gen()  1532 MB/s
[    0.376485] raid6: int64x8  gen()  1187 MB/s
[    0.444573] raid6: int64x4  gen()  1315 MB/s
[    0.512672] raid6: int64x2  gen()  1178 MB/s
[    0.580758] raid6: int64x1  gen()   872 MB/s
[    0.580765] raid6: using algorithm neonx8 gen() 1898 MB/s
[    0.648826] raid6: .... xor() 1393 MB/s, rmw enabled
[    0.648832] raid6: using neon recovery algorithm
[    0.649276] iommu: Default domain type: Translated
[    0.649282] iommu: DMA domain TLB invalidation policy: strict mode
[    0.650112] SCSI subsystem initialized
[    0.650236] libata version 3.00 loaded.
[    0.650421] usbcore: registered new interface driver usbfs
[    0.650461] usbcore: registered new interface driver hub
[    0.650492] usbcore: registered new device driver usb
[    0.650653] mc: Linux media interface: v0.10
[    0.650699] videodev: Linux video capture interface: v2.00
[    0.650780] pps_core: LinuxPPS API ver. 1 registered
[    0.650786] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.650802] PTP clock support registered
[    0.651229] Advanced Linux Sound Architecture Driver Initialized.
[    0.652054] NetLabel: Initializing
[    0.652060] NetLabel:  domain hash size = 128
[    0.652065] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.652127] NetLabel:  unlabeled traffic allowed by default
[    0.652133] mctp: management component transport protocol core
[    0.652138] NET: Registered PF_MCTP protocol family
[    0.652386] vgaarb: loaded
[    0.652679] clocksource: Switched to clocksource arch_sys_counter
[    0.653008] VFS: Disk quotas dquot_6.6.0
[    0.653029] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.653188] netfs: FS-Cache loaded
[    0.653315] CacheFiles: Loaded
[    0.661482] NET: Registered PF_INET protocol family
[    0.661724] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.721134] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.721244] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.721262] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.721513] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.722481] TCP: Hash tables configured (established 32768 bind 32768)
[    0.722600] UDP hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.722762] UDP-Lite hash table entries: 2048 (order: 5, 131072 bytes, linear)
[    0.723108] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.723143] NET: Registered PF_XDP protocol family
[    0.723161] PCI: CLS 0 bytes, default 64
[    0.723475] Unpacking initramfs...
[    0.727996] kvm [1]: nv: 566 coarse grained trap handlers
[    0.728564] kvm [1]: IPA Size Limit: 40 bits
[    0.730865] kvm [1]: vgic interrupt IRQ9
[    0.730911] kvm [1]: Hyp nVHE mode initialized successfully
[    0.732725] Initialise system trusted keyrings
[    0.732928] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[    0.733453] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.734205] SGI XFS with ACLs, security attributes, no debug enabled
[    0.797521] NET: Registered PF_ALG protocol family
[    0.797565] xor: automatically using best checksumming function   32regs
[    0.797577] Key type asymmetric registered
[    0.797583] Asymmetric key parser 'x509' registered
[    0.797590] Asymmetric key parser 'pkcs8' registered
[    0.797717] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.797966] io scheduler mq-deadline registered
[    0.798012] io scheduler bfq registered
[    0.804592] ledtrig-cpu: registered to indicate activity on CPUs
[    0.816616] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.820486] misc dump reg init
[    0.830701] loop: module loaded
[    0.831903] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[    0.831912] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld <Jason@zx2c4.com>. All Rights Reserved.
[    0.833446] tun: Universal TUN/TAP device driver, 1.6
[    0.834090] PPP generic driver version 2.4.2
[    0.834237] PPP BSD Compression module registered
[    0.834244] PPP Deflate Compression module registered
[    0.834289] PPP MPPE Compression module registered
[    0.834296] NET: Registered PF_PPPOX protocol family
[    0.835684] usbcore: registered new interface driver usblp
[    0.835734] usbcore: registered new interface driver usb-storage
[    0.835991] mousedev: PS/2 mouse device common for all mice
[    0.837250] sun6i-rtc 7000000.rtc: registered as rtc0
[    0.837272] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T02:49:37 UTC (96577)
[    0.837691] i2c_dev: i2c /dev entries driver
[    0.838464] usbcore: registered new interface driver uvcvideo
[    0.838474] Driver for 1-wire Dallas network protocol.
[    0.839693] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.841140] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000002
[    0.841189] hid: raw HID events driver (C) Jiri Kosina
[    0.841354] usbcore: registered new interface driver usbhid
[    0.841360] usbhid: USB HID core driver
[    0.842211] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[    0.843540] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.852148] gnss: GNSS driver registered with major 239
[    0.852507] usbcore: registered new interface driver snd-usb-audio
[    0.857235] NET: Registered PF_INET6 protocol family
[    1.809114] Freeing initrd memory: 21908K
[    1.852299] Segment Routing with IPv6
[    1.852400] In-situ OAM (IOAM) with IPv6
[    1.852559] NET: Registered PF_PACKET protocol family
[    1.852603] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    1.852761] 8021q: 802.1Q VLAN Support v1.8
[    1.852833] 9pnet: Installing 9P2000 support
[    1.852934] Key type dns_resolver registered
[    1.866864] registered taskstats version 1
[    1.867272] Loading compiled-in X.509 certificates
[    1.879248] zswap: loaded using pool lzo/zsmalloc
[    1.879519] Key type .fscrypt registered
[    1.879526] Key type fscrypt-provisioning registered
[    1.881026] Btrfs loaded, zoned=no, fsverity=no
[    1.881240] Key type encrypted registered
[    1.894341] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.894719] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    1.896199] ehci-platform 5101000.usb: EHCI Host Controller
[    1.896223] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    1.896561] ehci-platform 5200000.usb: EHCI Host Controller
[    1.896580] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 2
[    1.897000] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[    1.897028] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    1.897047] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 3
[    1.897049] ehci-platform 5200000.usb: irq 24, io mem 0x05200000
[    1.897157] ohci-platform 5101400.usb: irq 25, io mem 0x05101400
[    1.897300] ehci-platform 5101000.usb: irq 23, io mem 0x05101000
[    1.897634] ohci-platform 5200400.usb: Generic Platform OHCI controller
[    1.897652] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 4
[    1.897721] ohci-platform 5200400.usb: irq 27, io mem 0x05200400
[    1.897795] axp20x-i2c 0-0036: AXP20x variant AXP313a found
[    1.897982] axp20x-i2c 0-0036: AXP20X driver loaded
[    1.900578] sun50i_cpufreq_nvmem: sun50i-cpufreq-nvmem: unknown speed bin 0x2100, using default bin 0
[    1.900594] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[    1.904300] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    1.908708] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
[    1.908863] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15
[    1.908872] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.908879] usb usb2: Product: EHCI Host Controller
[    1.908884] usb usb2: Manufacturer: Linux 6.15.4-edge-sunxi64 ehci_hcd
[    1.908890] usb usb2: SerialNumber: 5200000.usb
[    1.909336] hub 2-0:1.0: USB hub found
[    1.909359] hub 2-0:1.0: 1 port detected
[    1.910551] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    1.911538] printk: legacy console [ttyS0] disabled
[    1.924687] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    1.924799] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15
[    1.924806] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.924811] usb usb1: Product: EHCI Host Controller
[    1.924815] usb usb1: Manufacturer: Linux 6.15.4-edge-sunxi64 ehci_hcd
[    1.924819] usb usb1: SerialNumber: 5101000.usb
[    1.925150] hub 1-0:1.0: USB hub found
[    1.925169] hub 1-0:1.0: 1 port detected
[    1.932133] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 293, base_baud = 1500000) is a 16550A
[    1.932186] printk: legacy console [ttyS0] enabled
[    1.953845] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 294, base_baud = 1500000) is a 16550A
[    1.954482] Registered IR keymap rc-empty
[    1.954540] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[    1.954633] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[    1.954733] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input0
[    1.955041] sunxi-ir 7040000.ir: initialized sunXi IR driver
[    1.956585] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    1.956816] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15
[    1.956828] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.956836] usb usb3: Product: Generic Platform OHCI controller
[    1.956843] usb usb3: Manufacturer: Linux 6.15.4-edge-sunxi64 ohci_hcd
[    1.956850] usb usb3: SerialNumber: 5101400.usb
[    1.957325] hub 3-0:1.0: USB hub found
[    1.957352] hub 3-0:1.0: 1 port detected
[    1.957850] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.15
[    1.957863] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.957871] usb usb4: Product: Generic Platform OHCI controller
[    1.957878] usb usb4: Manufacturer: Linux 6.15.4-edge-sunxi64 ohci_hcd
[    1.957885] usb usb4: SerialNumber: 5200400.usb
[    1.958321] sunxi-mmc 4020000.mmc: Got CD GPIO
[    1.958395] hub 4-0:1.0: USB hub found
[    1.958424] hub 4-0:1.0: 1 port detected
[    1.958473] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    1.980751] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    1.981082] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    1.981600] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.026689] mmc1: new high speed SDHC card at address 1234
[    2.027500] mmcblk1: mmc1:1234 SA08G 7.41 GiB
[    2.029537]  mmcblk1: p1
[    2.054946] clk: Disabling unused clocks
[    2.055089] PM: genpd: Disabling unused power domains
[    2.055101] ALSA device list:
[    2.055106]   #0: h616-audio-codec
[    2.056849] Freeing unused kernel memory: 3584K
[    2.056979] Run /init as init process
[    2.056983]   with arguments:
[    2.056987]     /init
[    2.056990]   with environment:
[    2.056993]     HOME=/
[    2.056997]     TERM=linux
[    2.057001]     splash=verbose
[    2.057004]     ubootpart=0ab155bb-01
[    2.057008]     cgroup_enable=memory
[    2.064266] fbcon: Taking over console
[    2.075723] mmc0: new high speed SDIO card at address 0001
[    2.235558] mmc2: new HS200 MMC card at address 0001
[    2.236406] mmcblk2: mmc2:0001 HBG4e\x05 29.1 GiB
[    2.245344]  mmcblk2: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25
[    2.252029] mmcblk2boot0: mmc2:0001 HBG4e\x05 4.00 MiB
[    2.255191] mmcblk2boot1: mmc2:0001 HBG4e\x05 4.00 MiB
[    2.412744] usb 4-1: new low-speed USB device number 2 using ohci-platform
[    2.582940] usb_phy_generic usb_phy_generic.1.auto: dummy supplies not allowed for exclusive requests (id=vbus)
[    2.583479] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[    2.583504] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 5
[    2.583975] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.15
[    2.583988] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.583995] usb usb5: Product: MUSB HDRC host driver
[    2.584001] usb usb5: Manufacturer: Linux 6.15.4-edge-sunxi64 musb-hcd
[    2.584007] usb usb5: SerialNumber: musb-hdrc.2.auto
[    2.589640] hub 5-0:1.0: USB hub found
[    2.589679] hub 5-0:1.0: 1 port detected
[    2.651852] usb 4-1: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10
[    2.651879] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.651886] usb 4-1: Product: USB Keyboard
[    2.651892] usb 4-1: Manufacturer:
[    2.669092] input:   USB Keyboard as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.0/0003:04D9:1603.0001/input/input1
[    2.813424] hid-generic 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [  USB Keyboard] on usb-5200400.usb-1/input0
[    2.831654] input:   USB Keyboard System Control as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.1/0003:04D9:1603.0002/input/input2
[    2.885250] input:   USB Keyboard Consumer Control as /devices/platform/soc/5200400.usb/usb4/4-1/4-1:1.1/0003:04D9:1603.0002/input/input3
[    2.885744] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [  USB Keyboard] on usb-5200400.usb-1/input1
[    3.431403] EXT4-fs (mmcblk1p1): mounted filesystem 19261dfd-7753-43cf-91f1-a7dbdbdd0887 ro with writeback data mode. Quota mode: none.
[    3.698271] Not activating Mandatory Access Control as /sbin/tomoyo-init does not exist.
[    4.711748] systemd[1]: System time advanced to built-in epoch: Tue 2025-09-09 11:38:33 EEST
[    4.996658] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[    4.996764] systemd[1]: Detected architecture arm64.
[    5.038431] systemd[1]: Hostname set to <transpeed-8k618-t>.
[    5.387846] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[    6.905977] systemd[1]: Queued start job for default target graphical.target.
[    6.954803] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    6.957116] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    6.958937] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    6.960152] systemd[1]: Created slice user.slice - User and Session Slice.
[    6.960510] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    6.961364] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    6.961507] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[    6.961776] systemd[1]: Reached target slices.target - Slice Units.
[    6.961909] systemd[1]: Reached target swap.target - Swaps.
[    6.977468] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[    6.978394] systemd[1]: Listening on syslog.socket - Syslog Socket.
[    6.986417] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    6.986963] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    6.987389] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    6.987943] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[    6.988169] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.988261] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    6.988615] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    6.988977] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    6.989585] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[    6.996152] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    7.000167] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[    7.003876] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    7.004522] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[    7.005072] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    7.010397] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[    7.021814] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    7.033445] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    7.042251] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    7.063844] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    7.073767] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    7.086154] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    7.087084] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    7.104248] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    7.104489] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.104853] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.122632] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[    7.127539] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    7.137029] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    7.137757] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[    7.139856] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    7.161570] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    7.163388] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[    7.164166] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[    7.165895] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.166617] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    7.167703] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.168380] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    7.169817] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    7.173367] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    7.177503] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[    7.179095] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.179933] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    7.184039] fuse: init (API version 7.43)
[    7.186468] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    7.190703] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.191663] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    7.205225] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    7.234008] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    7.244798] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    7.248975] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[    7.253665] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[    7.299369] EXT4-fs (mmcblk1p1): re-mounted 19261dfd-7753-43cf-91f1-a7dbdbdd0887 r/w.
[    7.310754] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[    7.312796] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[    7.331358] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    7.331611] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[    7.335370] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[    7.335602] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.392937] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[    7.526733] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[    7.718931] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[    8.157121] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[    8.159637] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[    8.165560] systemd[1]: Starting systemd-resolved.service - Network Name Resolution...
[    8.170151] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[    8.248470] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[    8.250750] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[    8.257187] systemd[1]: Mounting tmp.mount - /tmp...
[    8.262377] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[    8.318886] systemd[1]: Mounted tmp.mount - /tmp.
[    8.319484] systemd[1]: Reached target local-fs.target - Local File Systems.
[    8.326726] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management.
[    8.330796] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[    8.339093] systemd[1]: Starting console-setup.service - Set console font and keymap...
[    8.347485] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[    8.401908] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[    8.475602] systemd[1]: Finished console-setup.service - Set console font and keymap.
[    8.501895] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 266 (systemd-binfmt)
[    8.522813] systemd[1]: Received SIGRTMIN+20 from PID 161 (plymouthd).
[    8.562744] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[    9.135553] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[    9.200463] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[    9.213023] zram: Added device: zram0
[    9.214516] zram: Added device: zram1
[    9.217055] zram: Added device: zram2
[    9.218426] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[    9.228325] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[    9.246450] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[    9.433695] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
[    9.456729] random: crng init done
[   11.847701] zram0: detected capacity change from 0 to 4018328
[   11.916645] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   11.916865] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   11.916988] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   11.917101] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[   11.917179] sun8i-ce 1904000.crypto: Register cbc(aes)
[   11.917252] sun8i-ce 1904000.crypto: Register ecb(aes)
[   11.917273] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[   11.917293] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[   11.917313] sun8i-ce 1904000.crypto: Register md5
[   11.917334] sun8i-ce 1904000.crypto: Register sha1
[   11.917356] sun8i-ce 1904000.crypto: Register sha224
[   11.917377] sun8i-ce 1904000.crypto: Register sha256
[   11.917398] sun8i-ce 1904000.crypto: Register sha384
[   11.917418] sun8i-ce 1904000.crypto: Register sha512
[   11.917439] sun8i-ce 1904000.crypto: Register stdrng
[   11.917561] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[   12.118689] Adding 2009160k swap on /dev/zram0.  Priority:5 extents:1 across:2009160k SS
[   12.185804] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   12.186497] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   12.186656] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   12.259708] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   12.260592] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   12.261327] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   12.261532] systemd[1]: Reached target paths.target - Path Units.
[   12.347893] zram1: detected capacity change from 0 to 102400
[   12.407256] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.417358] systemd[1]: Started systemd-resolved.service - Network Name Resolution.
[   12.426064] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.426728] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   12.441526] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   12.441679] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups.
[   12.442398] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   12.442888] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[   12.443204] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
[   12.446693] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   12.451454] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   12.451767] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[   12.452202] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   12.452456] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   12.452516] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.452810] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   12.452899] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.452949] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   12.523888] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   12.524664] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   12.525669] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   12.528169] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   12.529066] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   12.548237] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
[   12.554293] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin failed with error -2
[   12.560120] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   12.564924] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   12.580014] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
[   13.275775] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   13.283666] systemd[1]: Starting systemd-journald.service - Journal Service...
[   13.438057] systemd-journald[425]: Collecting audit messages is disabled.
[   13.532888] systemd[1]: Started systemd-journald.service - Journal Service.
[   13.580761] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   13.630339] systemd-journald[425]: Received client request to flush runtime journal.
[   15.061746] systemd-journald[425]: /var/log/journal/86d178a1f5114188b9ed8fe9a41fe517/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
[   15.061790] systemd-journald[425]: Rotating system journal.
[   21.976349] RPC: Registered named UNIX socket transport module.
[   21.976376] RPC: Registered udp transport module.
[   21.976383] RPC: Registered tcp transport module.
[   21.976389] RPC: Registered tcp-with-tls transport module.
[   21.976394] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   37.296144] systemd-journald[425]: Received client request to relinquish /var/log/journal/86d178a1f5114188b9ed8fe9a41fe517 access.
Edited by NiTr0
@emor acid This was discussed before in this thread. Here are the links. Hope they help.
1) https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/4/#findComment-187672
2) https://forum.armbian.com/topic/29794-how-to-install-armbian-in-h618/page/21/#findComment-218004
@NiTr0 You need to freeze kernel updates in the armbian-config tool.  The images I released use kernel version 6.12.
54 минуты назад, Nick A сказал:
thanks.
also, did you test orange pi 2w armbian release with h618 dtb? and how to specify dtb in proper way? how it's specified in armbian images? I didn't see "fdtfile=<something>" in images.
Posted (edited)
@NiTr0 Armbian doesn't use $fdtfile because U-Boot carries the same DT already, in memory. If you want to use a different DT, add
fdtfile=yourdt to the /boot/armbianEnv.txt. I haven't tried this method.
I don’t remember if I tested orange pi 2w. It’s been awhile since I released the image. I think someone has. I have a board laying around somewhere. I'll try it when I'm not busy.
Edited by Nick A
@Nick A I've played with my box - it seems like trouble was actually in .dtb file.
armbian has .dtb named sun50i-h618-transpeed-8k618-t.dtb  - but it's for different box revision, or even just wrong .dtb
when I rolled back to right .dtb with fresh edge kernel file network starts to work OK.
also, on your image I've got network interface flapping once per some seconds; on 6.15.4 all is OK.
I've reinstalled armbian on flash, switched to -current kernel branch and replaced .dtb with valid one - device boots OK, except wifi (it's still unavailable), btw I don't need wifi on it.
so I have a question: how to copy .dtb at each kernel update? Or it'll be easier just to forbid kernel update (how to do this?)
Here's bootlog:
DRAM:Store cfg
detected 11 columns
DRAM:restore cfg
DRAM:store cfg
detected 16 rows
DRAM:restoring cfg
 4096 MiB
INFO:    SPSR = 0x3c9
DRAM:  4 GiB
In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
starting USB...
USB EHCI 1.00
Scanning mmc 0:1...
4641 bytes read in 8 ms (566.4 KiB/s)
205 bytes read in 7 ms (28.3 KiB/s)
The file allwinner/sun50i-h618-transpeed-8k618-t.dtb was not found in the path /boot/dtb/allwinner
37503 bytes read in 18 ms (2 MiB/s)
Failed to load '/boot/dtb/overlay/sun50i-h616-fixup.scr'
25209433 bytes read in 1290 ms (18.6 MiB/s)
38217736 bytes read in 1952 ms (18.7 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=0x42760000
   Image Name:   uInitrd
   Data Size:    25209369 Bytes = 24 MiB
   Loading Ramdisk to 487f5000, end 49fffa19 ... OK
   Loading Device Tree to 0000000048783000, end 00000000487f4fff ... OK
Working FDT set to 48783000
Starting kernel ...
done.
done.
[/sbin/fsck.ext4 (1) -- /dev/mmcblk2p1] fsck.ext4 -a -C0 /dev/mmcblk2p1
armbi_root: clean, 44150/460672 files, 540723/1903616 blocks
done.
done.
and dmesg:
[    0.000000] Linux version 6.12.43-current-sunxi64 (build@armbian) (aarch64-linux-gnu-gcc (Ubuntu 13.3.0-6ubuntu2~24.04) 13.3.0, GNU ld (GNU Binutils for Ubuntu) 2.42) #1 SMP Wed Aug 20 16:30:58 UTC 2025
[    0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000013fffffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x13f7d26c0-0x13f7d477f]
[    0.000000] cma: Reserved 128 MiB at 0x00000000f8000000 on node -1
[    0.000000] percpu: Embedded 31 pages/cpu s89496 r8192 d29288 u126976
[    0.000000] pcpu-alloc: s89496 r8192 d29288 u126976 alloc=31*4096
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] Fallback order for Node 0: 0
[    0.000000] Policy zone: Normal
[    0.000000] software IO TLB: mapped [mem 0x00000000f4000000-0x00000000f8000000] (64MB)
[    0.000000] ftrace: allocating 52395 entries in 205 pages
[    0.000000] ftrace: allocated 205 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[    0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000571] Console: colour dummy device 80x25
[    0.000584] printk: legacy console [tty1] enabled
[    0.000752] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.000767] pid_max: default: 32768 minimum: 301
[    0.000851] LSM: initializing lsm=capability,yama,apparmor,ima,evm
[    0.000926] Yama: becoming mindful.
[    0.001155] AppArmor: AppArmor initialized
[    0.001334] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.001361] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.003884] rcu: Hierarchical SRCU implementation.
[    0.003892] rcu:     Max phase no-delay instances is 1000.
[    0.004186] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[    0.005086] smp: Bringing up secondary CPUs ...
[    0.005666] Detected VIPT I-cache on CPU1
[    0.005768] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.006402] Detected VIPT I-cache on CPU2
[    0.006456] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.007037] Detected VIPT I-cache on CPU3
[    0.007093] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.007177] smp: Brought up 1 node, 4 CPUs
[    0.007192] SMP: Total of 4 processors activated.
[    0.007197] CPU: All CPU(s) started at EL2
[    0.007203] CPU features: detected: 32-bit EL0 Support
[    0.007209] CPU features: detected: CRC32 instructions
[    0.007260] alternatives: applying system-wide alternatives
[    0.008280] Memory: 3847692K/4194304K available (17472K kernel code, 2506K rwdata, 10900K rodata, 6336K init, 865K bss, 210320K reserved, 131072K cma-reserved)
[    0.009745] devtmpfs: initialized
[    0.016132] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.016156] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.019975] 23200 pages in range for non-PLT usage
[    0.020060] 514720 pages in range for PLT usage
[    0.020381] pinctrl core: initialized pinctrl subsystem
[    0.023505] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.024521] DMA: preallocated 512 KiB GFP_KERNEL pool for atomic allocations
[    0.024650] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.024841] DMA: preallocated 512 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.024878] audit: initializing netlink subsys (disabled)
[    0.025331] audit: type=2000 audit(0.024:1): state=initialized audit_enabled=0 res=1
[    0.025717] thermal_sys: Registered thermal governor 'fair_share'
[    0.025724] thermal_sys: Registered thermal governor 'bang_bang'
[    0.025730] thermal_sys: Registered thermal governor 'step_wise'
[    0.025736] thermal_sys: Registered thermal governor 'user_space'
[    0.025783] cpuidle: using governor menu
[    0.026001] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.026108] ASID allocator initialised with 65536 entries
[    0.026282] Serial: AMBA PL011 UART driver
[    0.031457] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.031527] /soc/interrupt-controller@3021000: Fixed dependency cycle(s) with /soc/interrupt-controller@3021000
[    0.031622] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.031658] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000
[    0.031677] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.031695] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000
[    0.031735] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.032150] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.034174] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.034529] /soc/hdmi@6000000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.034601] /soc/bus@1000000/mixer@100000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.034667] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/hdmi@6000000
[    0.034734] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.034754] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/bus@1000000/mixer@100000
[    0.034921] /soc/tcon-top@6510000: Fixed dependency cycle(s) with /soc/lcd-controller@6515000
[    0.034996] /soc/lcd-controller@6515000: Fixed dependency cycle(s) with /soc/tcon-top@6510000
[    0.038774] /soc/hdmi@6000000: Fixed dependency cycle(s) with /connector
[    0.038847] /connector: Fixed dependency cycle(s) with /soc/hdmi@6000000
[    0.040501] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[    0.040512] HugeTLB: 0 KiB vmemmap can be freed for a 1.00 GiB page
[    0.040521] HugeTLB: registered 32.0 MiB page size, pre-allocated 0 pages
[    0.040526] HugeTLB: 0 KiB vmemmap can be freed for a 32.0 MiB page
[    0.040533] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[    0.040539] HugeTLB: 0 KiB vmemmap can be freed for a 2.00 MiB page
[    0.040546] HugeTLB: registered 64.0 KiB page size, pre-allocated 0 pages
[    0.040551] HugeTLB: 0 KiB vmemmap can be freed for a 64.0 KiB page
[    0.041613] cryptd: max_cpu_qlen set to 1000
[    0.108174] raid6: neonx8   gen()  1901 MB/s
[    0.176236] raid6: neonx4   gen()  1864 MB/s
[    0.244301] raid6: neonx2   gen()  1786 MB/s
[    0.312373] raid6: neonx1   gen()  1526 MB/s
[    0.380450] raid6: int64x8  gen()  1186 MB/s
[    0.448503] raid6: int64x4  gen()  1319 MB/s
[    0.516579] raid6: int64x2  gen()  1175 MB/s
[    0.584638] raid6: int64x1  gen()   869 MB/s
[    0.584645] raid6: using algorithm neonx8 gen() 1901 MB/s
[    0.652698] raid6: .... xor() 1389 MB/s, rmw enabled
[    0.652705] raid6: using neon recovery algorithm
[    0.653326] iommu: Default domain type: Translated
[    0.653335] iommu: DMA domain TLB invalidation policy: strict mode
[    0.653921] SCSI subsystem initialized
[    0.654105] usbcore: registered new interface driver usbfs
[    0.654142] usbcore: registered new interface driver hub
[    0.654178] usbcore: registered new device driver usb
[    0.654483] pps_core: LinuxPPS API ver. 1 registered
[    0.654490] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.654510] PTP clock support registered
[    0.654890] scmi_core: SCMI protocol bus registered
[    0.655129] Advanced Linux Sound Architecture Driver Initialized.
[    0.656018] NetLabel: Initializing
[    0.656024] NetLabel:  domain hash size = 128
[    0.656030] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.656105] NetLabel:  unlabeled traffic allowed by default
[    0.656112] mctp: management component transport protocol core
[    0.656118] NET: Registered PF_MCTP protocol family
[    0.656566] clocksource: Switched to clocksource arch_sys_counter
[    0.660223] VFS: Disk quotas dquot_6.6.0
[    0.660261] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.660469] netfs: FS-Cache loaded
[    0.661006] AppArmor: AppArmor Filesystem Enabled
[    0.669081] NET: Registered PF_INET protocol family
[    0.669341] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.734561] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[    0.734631] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.734650] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.734904] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[    0.735859] TCP: Hash tables configured (established 32768 bind 32768)
[    0.735988] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.736084] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[    0.736352] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.736415] ARM FF-A: FFA_VERSION returned not supported
[    0.736748] Trying to unpack rootfs image as initramfs...
[    0.742067] Initialise system trusted keyrings
[    0.742138] Key type blacklist registered
[    0.742339] workingset: timestamp_bits=44 max_order=20 bucket_order=0
[    0.742391] zbud: loaded
[    0.742909] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.744360] integrity: Platform Keyring initialized
[    0.811001] xor: automatically using best checksumming function   32regs
[    0.811028] async_tx: api initialized (async)
[    0.811041] Key type asymmetric registered
[    0.811048] Asymmetric key parser 'x509' registered
[    0.811197] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    0.811471] io scheduler mq-deadline registered
[    0.811480] io scheduler kyber registered
[    0.811532] io scheduler bfq registered
[    0.815466] ledtrig-cpu: registered to indicate activity on CPUs
[    0.825407] Serial: 8250/16550 driver, 6 ports, IRQ sharing disabled
[    0.836527] loop: module loaded
[    0.839915] usbcore: registered new interface driver usb-storage
[    0.840446] mousedev: PS/2 mouse device common for all mice
[    0.841503] sun6i-rtc 7000000.rtc: registered as rtc0
[    0.841531] sun6i-rtc 7000000.rtc: setting system clock to 1970-01-02T01:10:45 UTC (90645)
[    0.841810] i2c_dev: i2c /dev entries driver
[    0.842064] mv64xxx_i2c 5002c00.i2c: can't get pinctrl, bus recovery not supported
[    0.843082] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.844483] sdhci: Secure Digital Host Controller Interface driver
[    0.844491] sdhci: Copyright(c) Pierre Ossman
[    0.844520] Synopsys Designware Multimedia Card Interface Driver
[    0.845277] sdhci-pltfm: SDHCI platform and OF driver helper
[    0.845630] SMCCC: SOC_ID: ID = jep106:091e:1823 Revision = 0x00000002
[    0.846043] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    0.846205] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    0.846313] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    0.846418] sun8i-ce 1904000.crypto: will run requests pump with realtime priority
[    0.846497] sun8i-ce 1904000.crypto: Register cbc(aes)
[    0.846562] sun8i-ce 1904000.crypto: Register ecb(aes)
[    0.846581] sun8i-ce 1904000.crypto: Register cbc(des3_ede)
[    0.846598] sun8i-ce 1904000.crypto: Register ecb(des3_ede)
[    0.846615] sun8i-ce 1904000.crypto: Register md5
[    0.846633] sun8i-ce 1904000.crypto: Register sha1
[    0.846651] sun8i-ce 1904000.crypto: Register sha224
[    0.846669] sun8i-ce 1904000.crypto: Register sha256
[    0.846686] sun8i-ce 1904000.crypto: Register sha384
[    0.846704] sun8i-ce 1904000.crypto: Register sha512
[    0.846722] sun8i-ce 1904000.crypto: Register stdrng
[    0.846847] sun8i-ce 1904000.crypto: CryptoEngine Die ID 0
[    0.847238] hid: raw HID events driver (C) Jiri Kosina
[    0.847358] usbcore: registered new interface driver usbhid
[    0.847365] usbhid: USB HID core driver
[    0.848241] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 (0,8000003f) counters available
[    0.848362] random: crng init done
[    0.859469] NET: Registered PF_INET6 protocol family
[    1.972242] Freeing initrd memory: 24616K
[    2.016072] Segment Routing with IPv6
[    2.016163] In-situ OAM (IOAM) with IPv6
[    2.016338] NET: Registered PF_PACKET protocol family
[    2.016373] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.016500] 8021q: 802.1Q VLAN Support v1.8
[    2.016583] 9pnet: Installing 9P2000 support
[    2.016677] Key type dns_resolver registered
[    2.024253] registered taskstats version 1
[    2.024661] Loading compiled-in X.509 certificates
[    2.036982] zswap: loaded using pool zstd/zbud
[    2.037212] Demotion targets for Node 0: null
[    2.037452] Key type .fscrypt registered
[    2.037459] Key type fscrypt-provisioning registered
[    2.038854] Btrfs loaded, zoned=yes, fsverity=no
[    2.038993] Key type encrypted registered
[    2.039006] AppArmor: AppArmor sha256 policy hashing enabled
[    2.039032] ima: No TPM chip found, activating TPM-bypass!
[    2.039050] ima: Allocated hash algorithm: sha1
[    2.039084] ima: No architecture policies found
[    2.039161] evm: Initialising EVM extended attributes:
[    2.039167] evm: security.selinux
[    2.039173] evm: security.SMACK64
[    2.039178] evm: security.SMACK64EXEC
[    2.039183] evm: security.SMACK64TRANSMUTE
[    2.039189] evm: security.SMACK64MMAP
[    2.039193] evm: security.apparmor
[    2.039198] evm: security.ima
[    2.039203] evm: security.capability
[    2.039208] evm: HMAC attrs: 0x1
[    2.049816] sun8i-mixer 1100000.mixer: Adding to iommu group 0
[    2.052467] sun4i-drm display-engine: Adding to iommu group 0
[    2.068388] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff80008122b9c8)
[    2.068553] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800081230798)
[    2.068920] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff8000812285e8)
[    2.068981] sun8i-dw-hdmi 6000000.hdmi: supply hvcc not found, using dummy regulator
[    2.069195] sun8i-dw-hdmi 6000000.hdmi: Detected HDMI TX controller v2.12a with HDCP (DWC HDMI 2.0 TX PHY)
[    2.069766] sun8i-dw-hdmi 6000000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.070027] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff80008122aa90)
[    2.070531] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0
[    2.070600] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    2.071984] ehci-platform 5101000.usb: EHCI Host Controller
[    2.072009] ehci-platform 5101000.usb: new USB bus registered, assigned bus number 1
[    2.072107] ehci-platform 5200000.usb: EHCI Host Controller
[    2.072127] ehci-platform 5200000.usb: new USB bus registered, assigned bus number 2
[    2.072403] ehci-platform 5101000.usb: irq 26, io mem 0x05101000
[    2.072630] sun4i-drm display-engine: [drm] Cannot find any crtc or sizes
[    2.072852] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests (id=vbus)
[    2.073052] ohci-platform 5200400.usb: Generic Platform OHCI controller
[    2.073073] ohci-platform 5200400.usb: new USB bus registered, assigned bus number 3
[    2.073126] ehci-platform 5200000.usb: irq 27, io mem 0x05200000
[    2.073181] ohci-platform 5200400.usb: irq 29, io mem 0x05200400
[    2.080578] ehci-platform 5101000.usb: USB 2.0 started, EHCI 1.00
[    2.080830] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    2.080843] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.080853] usb usb1: Product: EHCI Host Controller
[    2.080861] usb usb1: Manufacturer: Linux 6.12.43-current-sunxi64 ehci_hcd
[    2.080869] usb usb1: SerialNumber: 5101000.usb
[    2.081350] hub 1-0:1.0: USB hub found
[    2.081390] hub 1-0:1.0: 1 port detected
[    2.092568] ehci-platform 5200000.usb: USB 2.0 started, EHCI 1.00
[    2.092781] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    2.092794] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.092803] usb usb2: Product: EHCI Host Controller
[    2.092811] usb usb2: Manufacturer: Linux 6.12.43-current-sunxi64 ehci_hcd
[    2.092819] usb usb2: SerialNumber: 5200000.usb
[    2.093199] hub 2-0:1.0: USB hub found
[    2.093234] hub 2-0:1.0: 1 port detected
[    2.132741] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12
[    2.132754] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.132764] usb usb3: Product: Generic Platform OHCI controller
[    2.132772] usb usb3: Manufacturer: Linux 6.12.43-current-sunxi64 ohci_hcd
[    2.132780] usb usb3: SerialNumber: 5200400.usb
[    2.133154] hub 3-0:1.0: USB hub found
[    2.133191] hub 3-0:1.0: 1 port detected
[    2.272604] ohci-platform 5101400.usb: Generic Platform OHCI controller
[    2.272627] ohci-platform 5101400.usb: new USB bus registered, assigned bus number 4
[    2.272712] ohci-platform 5101400.usb: irq 28, io mem 0x05101400
[    2.272781] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[    2.272800] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 5
[    2.272974] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.12
[    2.272987] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.272997] usb usb5: Product: MUSB HDRC host driver
[    2.273004] usb usb5: Manufacturer: Linux 6.12.43-current-sunxi64 musb-hcd
[    2.273012] usb usb5: SerialNumber: musb-hdrc.4.auto
[    2.273372] hub 5-0:1.0: USB hub found
[    2.273409] hub 5-0:1.0: 1 port detected
[    2.276208] sun50i_cpufreq_nvmem: sun50i-cpufreq-nvmem: unknown speed bin 0x2100, using default bin 0
[    2.276225] sun50i_cpufreq_nvmem: Using CPU speed bin speed0
[    2.278224] gpio gpiochip0: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    2.278503] sun50i-h616-r-pinctrl 7022000.pinctrl: initialized sunXi PIO driver
[    2.279071] sun50i-h616-r-pinctrl 7022000.pinctrl: supply vcc-pl not found, using dummy regulator
[    2.279740] axp20x-i2c 2-0036: AXP20x variant AXP313a found
[    2.279899] axp20x-i2c 2-0036: AXP20X driver loaded
[    2.282150] gpio gpiochip1: Static allocation of GPIO base is deprecated, use dynamic allocation.
[    2.290430] sun50i-h616-pinctrl 300b000.pinctrl: initialized sunXi PIO driver
[    2.292140] printk: legacy console [ttyS0] disabled
[    2.292536] 5000000.serial: ttyS0 at MMIO 0x5000000 (irq = 297, base_baud = 1500000) is a 16550A
[    2.292614] printk: legacy console [ttyS0] enabled
[    2.294231] 5000400.serial: ttyS1 at MMIO 0x5000400 (irq = 299, base_baud = 1500000) is a 16550A
[    2.294518] serial serial0: tty port ttyS1 registered
[    2.296119] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pf not found, using dummy regulator
[    2.296270] of_cfs_init
[    2.296364] of_cfs_init: OK
[    2.297020] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    2.297096] sunxi-mmc 4020000.mmc: Got CD GPIO
[    2.316651] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    2.320604] sunxi-mmc 4021000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.320895] sunxi-mmc 4020000.mmc: initialized, max. request size: 16384 KB, uses new timings mode
[    2.336895] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 6.12
[    2.336928] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.336939] usb usb4: Product: Generic Platform OHCI controller
[    2.336948] usb usb4: Manufacturer: Linux 6.12.43-current-sunxi64 ohci_hcd
[    2.336957] usb usb4: SerialNumber: 5101400.usb
[    2.337575] hub 4-0:1.0: USB hub found
[    2.337617] hub 4-0:1.0: 1 port detected
[    2.360515] mmc2: host does not support reading read-only switch, assuming write-enable
[    2.362583] mmc2: new high speed SDHC card at address 1234
[    2.363535] mmcblk2: mmc2:1234 SA08G 7.41 GiB
[    2.365608] clk: Disabling unused clocks
[    2.365758] PM: genpd: Disabling unused power domains
[    2.365773] ALSA device list:
[    2.365782]   No soundcards found.
[    2.365860]  mmcblk2: p1
[    2.370525] Freeing unused kernel memory: 6336K
[    2.370724] Run /init as init process
[    2.370732]   with arguments:
[    2.370739]     /init
[    2.370747]   with environment:
[    2.370753]     HOME=/
[    2.370759]     TERM=linux
[    2.370766]     splash=verbose
[    2.370772]     ubootpart=0ab155bb-01
[    2.370779]     cgroup_enable=memory
[    2.413424] mmc1: new high speed SDIO card at address 0001
[    2.560879] usb 3-1: new low-speed USB device number 2 using ohci-platform
[    2.575142] mmc0: new HS200 MMC card at address 0001
[    2.576081] mmcblk0: mmc0:0001 HBG4e\x05 29.1 GiB
[    2.583030]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25
[    2.591132] mmcblk0boot0: mmc0:0001 HBG4e\x05 4.00 MiB
[    2.592422] mmcblk0boot1: mmc0:0001 HBG4e\x05 4.00 MiB
[    2.790700] usb 3-1: New USB device found, idVendor=04d9, idProduct=1603, bcdDevice= 3.10
[    2.790736] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.790747] usb 3-1: Product: USB Keyboard
[    2.790756] usb 3-1: Manufacturer:
[    2.815134] input:   USB Keyboard as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.0/0003:04D9:1603.0001/input/input0
[    2.951388] hid-generic 0003:04D9:1603.0001: input,hidraw0: USB HID v1.10 Keyboard [  USB Keyboard] on usb-5200400.usb-1/input0
[    2.977742] input:   USB Keyboard System Control as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.1/0003:04D9:1603.0002/input/input1
[    3.033105] input:   USB Keyboard Consumer Control as /devices/platform/soc/5200400.usb/usb3/3-1/3-1:1.1/0003:04D9:1603.0002/input/input2
[    3.033450] hid-generic 0003:04D9:1603.0002: input,hidraw1: USB HID v1.10 Device [  USB Keyboard] on usb-5200400.usb-1/input1
[    3.120639] sun50i-h616-pinctrl 300b000.pinctrl: supply vcc-pa not found, using dummy regulator
[    3.120977] dwmac-sun8i 5030000.ethernet: IRQ eth_wake_irq not found
[    3.120990] dwmac-sun8i 5030000.ethernet: IRQ eth_lpi not found
[    3.121000] dwmac-sun8i 5030000.ethernet: IRQ sfty not found
[    3.121239] dwmac-sun8i 5030000.ethernet: supply phy-io not found, using dummy regulator
[    3.121428] dwmac-sun8i 5030000.ethernet: PTP uses main clock
[    3.121460] dwmac-sun8i 5030000.ethernet: Current syscon value is not the default 53fe1 (expect 0)
[    3.124354] dwmac-sun8i 5030000.ethernet: No HW DMA feature register supported
[    3.124381] dwmac-sun8i 5030000.ethernet: RX Checksum Offload Engine supported
[    3.124390] dwmac-sun8i 5030000.ethernet: COE Type 2
[    3.124401] dwmac-sun8i 5030000.ethernet: TX Checksum insertion supported
[    3.124410] dwmac-sun8i 5030000.ethernet: Normal descriptors
[    3.124418] dwmac-sun8i 5030000.ethernet: Chain mode enabled
[    3.248941] dwmac-sun8i 5030000.ethernet end0: renamed from eth0
[    3.942773] EXT4-fs (mmcblk2p1): mounted filesystem 19261dfd-7753-43cf-91f1-a7dbdbdd0887 ro with writeback data mode. Quota mode: none.
[    5.323298] systemd[1]: System time advanced to built-in epoch: Tue 2025-09-09 11:38:33 EEST
[    5.447285] systemd[1]: systemd 257.8-1~deb13u2 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +IPE +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF -XKBCOMMON -UTMP +SYSVINIT +LIBARCHIVE)
[    5.447354] systemd[1]: Detected architecture arm64.
[    5.486384] systemd[1]: Hostname set to <transpeed-8k618-t>.
[    5.916241] systemd[1]: bpf-restrict-fs: BPF LSM hook not enabled in the kernel, BPF LSM not supported.
[    7.399541] systemd[1]: Queued start job for default target graphical.target.
[    7.434799] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[    7.437298] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[    7.439229] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
[    7.440504] systemd[1]: Created slice user.slice - User and Session Slice.
[    7.440929] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[    7.441840] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[    7.442011] systemd[1]: Expecting device dev-ttyS0.device - /dev/ttyS0...
[    7.442379] systemd[1]: Reached target slices.target - Slice Units.
[    7.442551] systemd[1]: Reached target swap.target - Swaps.
[    7.461296] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
[    7.462146] systemd[1]: Listening on syslog.socket - Syslog Socket.
[    7.469728] systemd[1]: Listening on systemd-creds.socket - Credential Encryption/Decryption.
[    7.470205] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[    7.470599] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[    7.471157] systemd[1]: Listening on systemd-journald.socket - Journal Sockets.
[    7.471409] systemd[1]: systemd-pcrextend.socket - TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.471526] systemd[1]: systemd-pcrlock.socket - Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.471908] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[    7.472225] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[    7.479158] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
[    7.482972] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[    7.487531] systemd[1]: Mounting run-lock.mount - Legacy Locks Directory /run/lock...
[    7.497139] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[    7.505102] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[    7.505865] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
[    7.520536] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[    7.532501] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[    7.581928] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[    7.589504] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
[    7.605653] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[    7.611595] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[    7.621857] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
[    7.622855] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[    7.640485] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[    7.640848] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.641293] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    7.653299] systemd[1]: Starting systemd-udev-load-credentials.service - Load udev Rules from Credentials...
[    7.669360] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[    7.710166] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
[    7.711040] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[    7.711725] systemd[1]: Mounted run-lock.mount - Legacy Locks Directory /run/lock.
[    7.712465] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[    7.713611] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[    7.715233] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[    7.716229] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[    7.718802] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[    7.720701] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[    7.721717] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
[    7.723473] systemd[1]: modprobe@drm.service: Deactivated successfully.
[    7.724441] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[    7.726393] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[    7.727344] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[    7.733566] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[    7.733828] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
[    7.738599] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
[    7.749308] systemd[1]: Starting systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully...
[    7.798847] fuse: init (API version 7.41)
[    7.806571] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
[    7.808955] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[    7.809998] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
[    7.818016] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[    7.823699] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
[    7.828257] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[    7.865394] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[    7.900042] systemd[1]: Finished systemd-udev-load-credentials.service - Load udev Rules from Credentials.
[    7.929219] EXT4-fs (mmcblk2p1): re-mounted 19261dfd-7753-43cf-91f1-a7dbdbdd0887 r/w.
[    7.929754] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
[    7.935589] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
[    7.948451] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[    7.949557] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[    7.954454] systemd[1]: Starting systemd-random-seed.service - Load/Save OS Random Seed...
[    7.954775] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[    8.017402] systemd[1]: Finished systemd-tmpfiles-setup-dev-early.service - Create Static Device Nodes in /dev gracefully.
[    8.018427] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[    8.026443] systemd[1]: Starting systemd-resolved.service - Network Name Resolution...
[    8.037198] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
[    8.149007] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
[    8.155953] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
[    8.190439] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
[    8.191125] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
[    8.414770] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
[    8.779701] systemd[1]: Mounting tmp.mount - /tmp...
[    8.839867] systemd[1]: Mounted tmp.mount - /tmp.
[    8.840639] systemd[1]: Reached target local-fs.target - Local File Systems.
[    9.494067] systemd[1]: Listening on systemd-sysext.socket - System Extension Image Management.
[    9.498723] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
[    9.503545] systemd[1]: Starting console-setup.service - Set console font and keymap...
[    9.508838] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
[   10.225378] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
[   10.285135] systemd[1]: Finished systemd-random-seed.service - Load/Save OS Random Seed.
[   10.287173] systemd[1]: Finished console-setup.service - Set console font and keymap.
[   10.287798] systemd[1]: first-boot-complete.target - First Boot Complete was skipped because of an unmet condition check (ConditionFirstBoot=yes).
[   10.287974] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   10.327725] systemd[1]: Received SIGRTMIN+20 from PID 175 (plymouthd).
[   10.357503] systemd[1]: proc-sys-fs-binfmt_misc.automount: Got automount request for /proc/sys/fs/binfmt_misc, triggered by 285 (systemd-binfmt)
[   10.361790] systemd[1]: Mounting proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System...
[   10.421113] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
[   10.470159] systemd[1]: Mounted proc-sys-fs-binfmt_misc.mount - Arbitrary Executable File Formats File System.
[   10.493729] systemd[1]: Finished systemd-binfmt.service - Set Up Additional Binary Formats.
[   11.092158] zram: Added device: zram0
[   11.092646] zram: Added device: zram1
[   11.093079] zram: Added device: zram2
[   11.166044] systemd[1]: Started systemd-resolved.service - Network Name Resolution.
[   11.166613] systemd[1]: Reached target nss-lookup.target - Host and Network Name Lookups.
[   11.168895] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
[   11.174146] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
[   11.353382] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
[   12.387841]  ahub_dam-snd-soc-dummy-dai: substream ahub_dam-snd-soc-dummy-dai has no playback, no capture
[   12.387871] sunxi-snd-mach soc:ahub_dam_mach: ASoC: can't create pcm ahub_dam-snd-soc-dummy-dai :-22
[   12.388125] sunxi-snd-mach soc:ahub_dam_mach: probe with driver sunxi-snd-mach failed with error -22
[   12.410074] Registered IR keymap rc-empty
[   12.410228] rc rc0: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0
[   12.410426] rc rc0: lirc_dev: driver sunxi-ir registered at minor = 0, raw IR receiver, no transmitter
[   12.410536] input: sunxi-ir as /devices/platform/soc/7040000.ir/rc/rc0/input3
[   12.411120] sunxi-ir 7040000.ir: initialized sunXi IR driver
[   12.457259] zram0: detected capacity change from 0 to 4014936
[   12.564822] mc: Linux media interface: v0.10
[   12.802723] panfrost 1800000.gpu: clock rate = 432000000
[   12.802763] panfrost 1800000.gpu: bus_clock rate = 200000000
[   12.803496] core: _opp_supported_by_regulators: OPP minuV: 1080000 maxuV: 1080000, not supported by regulator
[   12.803513] panfrost 1800000.gpu: _opp_add: OPP not supported by regulators (800000000)
[   12.805159] Adding 2007464k swap on /dev/zram0.  Priority:5 extents:1 across:2007464k SS
[   12.805339] Bluetooth: Core ver 2.22
[   12.805452] NET: Registered PF_BLUETOOTH protocol family
[   12.805459] Bluetooth: HCI device and connection manager initialized
[   12.805478] Bluetooth: HCI socket layer initialized
[   12.805488] Bluetooth: L2CAP socket layer initialized
[   12.805504] Bluetooth: SCO socket layer initialized
[   12.807411] panfrost 1800000.gpu: mali-g31 id 0x7093 major 0x0 minor 0x0 status 0x0
[   12.807432] panfrost 1800000.gpu: features: 00000000,000027f7, issues: 00000000,00000400
[   12.807442] panfrost 1800000.gpu: Features: L2:0x07100206 Shader:0x00000000 Tiler:0x00000209 Mem:0x1 MMU:0x00002821 AS:0xff JS:0x7
[   12.807452] panfrost 1800000.gpu: shader_present=0x1 l2_present=0x1
[   12.825143] [drm] Initialized panfrost 1.2.0 for 1800000.gpu on minor 1
[   12.890218] videodev: Linux video capture interface: v2.00
[   14.008422] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
[   14.078341] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
[   14.079001] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   14.079516] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
[   14.079695] systemd[1]: Reached target paths.target - Path Units.
[   14.202513] zram1: detected capacity change from 0 to 102400
[   14.216373] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   14.217483] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   14.218219] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   14.232945] Bluetooth: HCI UART driver ver 2.3
[   14.232981] Bluetooth: HCI UART protocol H4 registered
[   14.232991] Bluetooth: HCI UART protocol BCSP registered
[   14.233115] Bluetooth: HCI UART protocol LL registered
[   14.233127] Bluetooth: HCI UART protocol ATH3K registered
[   14.233184] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   14.233400] Bluetooth: HCI UART protocol Intel registered
[   14.233575] Bluetooth: HCI UART protocol Broadcom registered
[   14.233639] Bluetooth: HCI UART protocol QCA registered
[   14.233651] Bluetooth: HCI UART protocol AG6XX registered
[   14.233705] Bluetooth: HCI UART protocol Marvell registered
[   14.276639] sunxi_cedrus: module is from the staging directory, the quality is unknown, you have been warned.
[   14.280614] cedrus 1c0e000.video-codec: Adding to iommu group 0
[   14.281908] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[   14.396474] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
[   14.400639] systemd[1]: Starting fake-hwclock-load.service - Restore the current clock...
[   14.405126] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[   14.405424] systemd[1]: systemd-hibernate-clear.service - Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[   14.405865] systemd[1]: systemd-hwdb-update.service - Rebuild Hardware Database was skipped because of an unmet condition check (ConditionNeedsUpdate=/etc).
[   14.406125] systemd[1]: systemd-machine-id-commit.service - Save Transient machine-id to Disk was skipped because of an unmet condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   14.406184] systemd[1]: systemd-pcrmachine.service - TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   14.406400] systemd[1]: systemd-sysusers.service - Create System Users was skipped because no trigger condition checks were met.
[   14.406483] systemd[1]: systemd-tpm2-setup-early.service - Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   14.406533] systemd[1]: systemd-tpm2-setup.service - TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[   14.408041] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
[   14.412941] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
[   14.467898] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
[   14.483092] systemd[1]: fake-hwclock-load.service: Deactivated successfully.
[   14.483860] systemd[1]: Finished fake-hwclock-load.service - Restore the current clock.
[   14.485428] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[   14.486139] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[   14.511995] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
[   14.523865] systemd[1]: Reached target bluetooth.target - Bluetooth Support.
[   14.524164] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
[   14.536326] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.transpeed,8k618-t.bin failed with error -2
[   14.566286] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.txt failed with error -2
[   14.572933] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
[   14.581364] Bluetooth: hci0: BCM: chip id 68
[   14.583869] Bluetooth: hci0: BCM: features 0x0f
[   14.607309] Bluetooth: hci0: BCM4334B0
[   14.607341] Bluetooth: hci0: BCM4334B0 (002.001.013) build 0000
[   14.613262] Bluetooth: hci0: BCM4334B0 'brcm/BCM4334B0.hcd' Patch
[   15.568597] brcmfmac: brcmf_sdio_htclk: HT Avail timeout (1000000): clkctl 0x50
[   15.646511] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
[   15.655285] systemd[1]: Starting systemd-journald.service - Journal Service...
[   17.765734] systemd-journald[449]: Collecting audit messages is disabled.
[   17.886448] systemd[1]: Started systemd-journald.service - Journal Service.
[   17.996517] systemd-journald[449]: Received client request to flush runtime journal.
[   19.097863] Bluetooth: hci0: BCM: features 0x0f
[   19.121506] Bluetooth: hci0: BCM4334B1 37.4 MHz ExtLNA Murata VM
[   19.121529] Bluetooth: hci0: BCM4334B0 (002.001.013) build 1852
[   25.444154] systemd-journald[449]: /var/log/journal/799574e4576441e8a38a6aa7819880e3/system.journal: Realtime clock jumped backwards relative to last journal entry, rotating.
[   25.444216] systemd-journald[449]: Rotating system journal.
[   51.316081] RPC: Registered named UNIX socket transport module.
[   51.316105] RPC: Registered udp transport module.
[   51.316110] RPC: Registered tcp transport module.
[   51.316114] RPC: Registered tcp-with-tls transport module.
[   51.316118] RPC: Registered tcp NFSv4.1 backchannel transport module.
[   66.481569] systemd-journald[449]: Received client request to relinquish /var/log/journal/799574e4576441e8a38a6aa7819880e3 access.
[  110.706220] dwmac-sun8i 5030000.ethernet end0: Register MEM_TYPE_PAGE_POOL RxQ-0
[  110.768166] dwmac-sun8i 5030000.ethernet end0: PHY [stmmac-0:00] driver [Allwinner AC200 EPHY] (irq=POLL)
[  110.768209] dwmac-sun8i 5030000.ethernet end0: No Safety Features support found
[  110.768219] dwmac-sun8i 5030000.ethernet end0: No MAC Management Counters available
[  110.768228] dwmac-sun8i 5030000.ethernet end0: PTP not supported by HW
[  110.768647] dwmac-sun8i 5030000.ethernet end0: configuring for phy/rmii link mode
[  112.806629] dwmac-sun8i 5030000.ethernet end0: Link is Up - 100Mbps/Full - flow control off
Posted (edited)
@emor acid Here's some information on H616/H618 ethernet phy. This is the 100Mbit ethernet built inside the H618 SOC.
https://lore.kernel.org/linux-sunxi/20250526002924.2567843-1-james.hilliard1@gmail.com/T/#t
In your dmesg log it shows your box is loading a generic phy.
Quote
dwmac-sun8i 5030000.ethernet eth0: PHY [stmmac-0:00] driver [Generic PHY] (irq=POLL)
It should be loading the Allwinner phy. For example @NiTr0 logs above.
Quote
Your box might be using a 1000Mbit external ethernet chip. If that's the case your dts settings will be very different. You'll need check if your box supports Gigabit Ethernet and find the Ethernet chip on your board.
@NiTr0 Just freeze the kernel updates using armbian-config. My armbian build is unofficial so you can't use the official armbian kernels. I'm using patches created by warpme and my own custom patches. So the kernel update feature will not work.
https://www.google.com/search?q=armbian+config+freeze+kernel&oq=armbian+config+freeze+kernel&gs_lcrp=EgZjaHJvbWUyBggAEEUYOdIBCDY4MDJqMGo3qAIAsAIA&sourceid=chrome&ie=UTF-8
For wifi your box is looking for
Quote
You need find the brcmfmac4334 bin file and rename it to brcmfmac4334-sdio.transpeed,8k618-t.bin. Also, the brcmfmac4334 txt to brcmfmac4334-sdio.txt. I think it's already in /lib/firmware/brcm under a different name.
Edited by Nick A
4 часа назад, Nick A сказал:
kernel update actually works, I'm now on -current mainline kernel (-edge works OK too); trouble is only in .dtb in mainline package
# uname -a
Linux transpeed-8k618-t 6.12.43-current-sunxi64 #1 SMP Wed Aug 20 16:30:58 UTC 2025 aarch64 GNU/Linux
5 часов назад, Nick A сказал:
thanks; there are brcmfmac4334-sdio.bin and brcmfmac4334-sdio.rockchip,rk3318-box.txt; I've renamed them to brcmfmac4334-sdio.transpeed,8k618-t.bin and brcmfmac4334-sdio.txt - wifi appears in device list, there are some strange messages in dmesg but I think it'll work ok
[23108.014126] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac4334-sdio for chip BCM4334/3
[23108.023494] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac4334-sdio.clm_blob failed with error -2
[23108.214552] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
[23108.214581] brcmfmac: brcmf_c_process_txcap_blob: no txcap_blob available (err=-2)
[23108.214910] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4334/3 wl0: Jul 24 2019 12:58:36 version 6.10.191 (TOB) (r) FWID 01-b049404e
Posted (edited)
@NiTr0 I guess transferring the dtb to official armbian kernel 6.12.43 will work. Most of warpme’s collection of patches are already in the official armbian build. There might be some differences.
Don’t worry about those wifi errors it will work fine.
Edited by Nick A
