Initramfs can't find /dev/mmcblk1p1
Go to solution Solved by Gunjan Gupta,
Hi all,
I have been using armbian jammy on my potato without issues.
But since the weekend it only boots to initramfs and says can't find mmcblk1p1
I put the sdcard a live gparted and partitions are and verified.
In initramfs I can find in /dev the mmcblk0p1 but not the mmcblk1p1
Now how can I change the boot or the name of the device?
Board: Le Potato
Edited by Roberto Rodrigues
Wring tag
Another info, in initramfs I created a symlink to the missed file
ln /dev/mmcblk0p1 /dev/mmcblk1p1
After having the link created I typed exec init and it started to boot, but off course it fails, because the initramfs gets cleaned. So where the hell is where I change the name is the mmc file to boot?
Best regards
  • Solution
This is interesting one. Kind of like how sd card names are different between different version of RPi.
You haven't mentioned the image you are using. But from the post I am deducing it was working fine for you until you installed an update?
I am not 100% sure as this is not a device I work with. But generally the root device is set in a file called armbianEnv.txt. Here is something for you to try
mount your root partition
mount /dev/mmcblk0p1 /mnt
check if /mnt/boot/armbianEnv.txt exists
ls /mnt/boot/armbianEnv.txt
if it doesn't exists, create it. Replace <Your UUID> with UUID shown in output of blkid command
echo "rootdev=UUID="<Your UUID>" > /mnt/boot/armbianEnv.txt
unmount your root partition
umount /mnt
and reboot
Many Thanks Gunjan Gupta
It really worked the adding of the line echo
Indeed i had done some updates, but i don't remember if i did any to kernel or something like that.
The line echo had to be changed to like
echo rootdev=UUID="<Your UUID>" >> /mnt/boot/armbianEnv.txt
Because the file existed, but had no line to boot the sdcard.
Thanks once again.
Hope this helps others.
