Building collabora version of Rock 5A
Go to solution Solved by Endian,
I tried hackning the rock-5A.wip file to allow me to build the collabora version, and it worked quite nicely! The board boots into linux and the ethernet port and usb seem to work!
so should i try to send up a pull request to the armbian GitHub to include this change, an if so How should i do this?
otherwise someone else with experience is wecome to do it too!
/ Kenneth
Hmm.. So I assume since my question relates to a board that is not maintained, the question is now moved to a different board? Formally correct.
However, my fear is that a side-effect of this might be that I will not get any answers, since there seem to be very little traffic in this board?
But hopefully I am wrong... @Werner can hopefully enlighten me?
Maybe I should have sent a direct message to the maintainer instead?
Edited by Endian
