Hello everyone,
I recently installed my orangePi 5 to pass workload from my x86 servers over to the orangePi.
My main focus is to reduce my overall energy consumption of my homelab.
TL;DR
Kernel thinks, that while being idle the sweet spot for the frequencies in "ondemand" and "schedutil" is:
  • 1024MHz on the small chips (CPU0-3)
  • 816MHZ  on the big   chips (CPU4+5, CPU6+7)
Reason is an internal cost calculation power vs. frequency gain, which sorts out the lower frequencies.
Long story:
After getting my first orangePi5 in place, I started to play around with the hardware.
I am running:
      █ █ █ █ █ █ █ █ █ █ █      OS: Armbian (23.11.0-trunk.43) aarch64
     ███████████████████████     Host: Orange Pi 5
   ▄▄██                   ██▄▄   Kernel: 6.5.0-rc5-edge-rockchip-rk3588
   ▄▄██    ███████████    ██▄▄   Uptime: 5 days, 17 hours, 24 mins
   ▄▄██   ██         ██   ██▄▄   Packages: 459 (dpkg)
   ▄▄██   ██         ██   ██▄▄   Shell: bash 5.2.15
   ▄▄██   ██         ██   ██▄▄   CPU: (8) @ 1.800GHz
   ▄▄██   █████████████   ██▄▄   Memory: 1439MiB / 7688MiB
# cpufreq-info (cropped for low and high cores)
cpufrequtils 008: cpufreq-info (C) Dominik Brodowski 2004-2009
Report errors and bugs to cpufreq@vger.kernel.org, please.
analyzing CPU 0:
  driver: rockchip-cpufreq
  CPUs which run at the same hardware frequency: 0 1 2 3
  CPUs which need to have their frequency coordinated by software: 0 1 2 3
  maximum transition latency: 72.0 us.
  hardware limits: 408 MHz - 1.80 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz
  available cpufreq governors: conservative, ondemand, userspace, powersave, performance, schedutil
  current policy: frequency should be within 408 MHz and 1.80 GHz.
                  The governor "schedutil" may decide which speed to use
                  within this range.
  current CPU frequency is 1.20 GHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:0.00%, 600 MHz:0.00%, 816 MHz:0.00%, 1.01 GHz:99.91%, 1.20 GHz:0.07%, 1.42 GHz:0.01%, 1.61 GHz:0.00%, 1.80 GHz:0.01%  (38672)
analyzing CPU 7:
  CPUs which run at the same hardware frequency: 6 7
  CPUs which need to have their frequency coordinated by software: 6 7
  maximum transition latency: 356 us.
  hardware limits: 408 MHz - 2.21 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz
  current policy: frequency should be within 408 MHz and 2.21 GHz.
                  within this range.
  current CPU frequency is 816 MHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:0.00%, 600 MHz:0.00%, 816 MHz:99.91%, 1.01 GHz:0.03%, 1.20 GHz:0.01%, 1.42 GHz:0.02%, 1.61 GHz:0.01%, 1.80 GHz:0.00%, 2.02 GHz:0.00%, 2.21 GHz:0.02%  (41580)
So, why are the lowest frequency not reached? Tests with the "powersave" showed, that the kernel is able to set these frequencies.
The "ondemand" scheduler showed no difference.
# uptime
 15:44:20 up 5 days, 17:26,  2 users,  load average: 0.00, 0.00, 0.00
Load average is pretty much like nothing.
So, I started to doubt that everything is working correctly:
  •  Why does the frequency selection work like this? Why are the lowest frequencies not considered in the evaluation?
  •  Are the little/big difference between the cores accounted and used?
  •  What are those error messages on system startup?
I was not able to find anything useful about any limitations, known errors or open bugs. I wasn't able to find a hint, that explained why "ondemand" and "schedutil" won't hit the lowest possible frequency. And yes! I used Google for several days.
So, I started to dig into the following messages from my bootup:
[    1.790851] cpu cpu0: _parse_named_prop: Invalid number of elements in microvolt property (6) with supplies (1)
[    1.790862] cpu cpu0: _of_add_opp_table_v2: Failed to add OPP, -22
[    1.790867] cpu cpu0: OPP table can't be empty
[    1.799837] cpu cpu0: EM: OPP:816000 is inefficient
[    1.799858] cpu cpu0: EM: OPP:600000 is inefficient
[    1.799865] cpu cpu0: EM: OPP:408000 is inefficient
[    1.800170] cpu cpu0: EM: created perf domain
[    1.800981] cpu cpu4: EM: OPP:600000 is inefficient
[    1.800992] cpu cpu4: EM: OPP:408000 is inefficient
[    1.801222] cpu cpu4: EM: created perf domain
[    1.802005] cpu cpu6: EM: OPP:600000 is inefficient
[    1.802014] cpu cpu6: EM: OPP:408000 is inefficient
[    1.802246] cpu cpu6: EM: created perf domain
The first two messages are based of the OPP device drive, reading the tuples from the system(/or predefined structures?) containing power information about the given CPU cores.
The message "OPP table can't be empty" seem to be emitted by cpufreq-dt, which is working side by side with OPP to organize the internal CPU information. From an earlier research I found we are using the driver "rockchip-cpufreq" on rk35xx/rk3588 for doing OPP handing, which is using the cpufreq-dt functions, too. That driver is needed, because we have to handle more then one OPP table.
The next thing was "cpu cpu%d: EM: OPP:%d is inefficient" entry. That message comes from deep inside the kernels common code: "energy management".
After some digging, I found out, that armbian is compiled with debugfs enabled (yeah) so we can peek into a lot of counters.
The energy management is described in details here: https://docs.kernel.org/power/energy-model.html - I read the code first and found out later that documentation is very accurate.
I'm glad, that armbian is build with debugfs enabled, so all counters from energy_management are available under: /sys/kernel/debug/energy_model
Basically these are the counter for my orangePi5 chip and how the kernel evaluates the costs for each frequency level (I marked the frequency from above):
cpu0/ps:408000/cost  230850  |
cpu0/ps:600000/cost  230850  |
cpu0/ps:816000/cost  230850  |
cpu0/ps:1008000/cost 230850  | <---
cpu0/ps:1200000/cost 246496
cpu0/ps:1416000/cost 279327
cpu0/ps:1608000/cost 314211
cpu0/ps:1800000/cost 370386
cpu4/ps:408000/cost 330669 |
cpu4/ps:600000/cost 330670
cpu4/ps:816000/cost 330669 | <---
cpu4/ps:1008000/cost 358800
cpu4/ps:1200000/cost 388078
cpu4/ps:1416000/cost 418503
cpu4/ps:1608000/cost 450077
cpu4/ps:1800000/cost 551690
cpu4/ps:2016000/cost 663635
cpu4/ps:2208000/cost 785915
This is the reason why ondemand, conservative and schedutil choose these frequency as a minimum frequency. The kernel does not seem to have an efficiency gain in terms of power vs energy consumption.
The calculation is cost = max_frequency * power_for_frequency / frequency .
Where does the "power_for_frequency" come from? These are also delivered and available:
cpu0/ps:408000/power   52326
cpu0/ps:600000/power   76950
cpu0/ps:816000/power  104652
cpu0/ps:1008000/power 129276
cpu0/ps:1200000/power 164331
cpu0/ps:1416000/power 219738
cpu0/ps:1608000/power 280696
cpu0/ps:1800000/power 370386
cpu4/ps:408000/power   61102
cpu4/ps:600000/power   89856
cpu4/ps:816000/power  122204
cpu4/ps:1008000/power 163800
cpu4/ps:1200000/power 210912
cpu4/ps:1416000/power 268388
cpu4/ps:1608000/power 327774
cpu4/ps:1800000/power 449748
cpu4/ps:2016000/power 605928
cpu4/ps:2208000/power 785915
This cost value surprised me, that it is the same for the first frequency levels, so I did the math and it is correct. (In fact, I did that to prove my assumption, that I interpreted the cpu-flags correctly, too.)
Basically, I found the reason why we are "locked" at these particular frequencies and are not saving more Watt. Unfortunately there is no official way to adjust the cost values to allow the energy_management to do a different decision.
What bothered me is, that cpufreq-info shows a complete frequency list and maintains all available frequencies. It took me another hour to figure out, that the energy_management source code (em_cpufreq_update_efficiencies) reports the findings via the function cpufreq_table_set_inefficient to the frequency table inside cpufreq. On that way, the frequency table receives flags for the "inefficient" frequencies, which is taken into account by any sophisticated governor (ondemand, schedutil..). These information is not transported by any cpufreq utility to the user.
Bonus question: Does the different power levels of the cores being taken account into the CPU-scheduling?
1. We can see here, that different performance domains are created:
2. Is the energy_aware scheduler active?
# sysctl -a | grep sched_energy_aware
kernel.sched_energy_aware = 1
It is!
Writing this down shortens the path of finding everything out against the real invest into the research 😄 . The Kernel documentation is very helpful, but the debug information need to be found inside the source code (I'm fine with thaT). I recommend reading the https://docs.kernel.org/scheduler/sched-energy.html , which has a very explanation how the energy_management from above works together with the scheduler.
According to the documentation, it works the best with the CPU-governor "schedutil" because it works hand in hand with task scheduling information in opposite to "ondemand" which looks at the core-cpu consumption.
Further reading
Thanks for reading,
I hope this will help someone out there.
Matthias
edit: maybe this is more relevant to the „advanced user/development section“ 🤔
Edited by Matthias Strubel
No, not yet. I usually try to stay as close as upstream as possible.
Next week or the week after another board will arrive, so I can do some tests with that new one.
After that deep dive, I see that issue reasonable and it is ok for me.
As soon as I can, I’ll do a test.
Spelling
I did a test with a second orangePi5 using the legacy kernel.
It seems this kernel identifies different frequencies as "inefficient", but the onemand governor does not take account of this information and scales across the compete frequency range.
# uname -r
5.10.110-rockchip-rk3588
[    7.956842] cpu cpu0: Looking up cpu-supply from device tree
[    7.957323] cpu cpu0: bin=0
[    7.957521] cpu cpu0: leakage=11
[    7.957544] cpu cpu0: Looking up cpu-supply from device tree
[    7.958986] cpu cpu0: pvtm=1459
[    7.959055] cpu cpu0: pvtm-volt-sel=3
[    7.959087] cpu cpu0: Looking up cpu-supply from device tree
[    7.959212] cpu cpu0: Looking up mem-supply from device tree
[    7.959376] cpu cpu4: Looking up cpu-supply from device tree
[    7.961042] cpu cpu4: bin=0
[    7.961213] cpu cpu4: leakage=9
[    7.961231] cpu cpu4: Looking up cpu-supply from device tree
[    7.967741] cpu cpu4: pvtm=1692
[    7.971693] cpu cpu4: pvtm-volt-sel=4
[    7.971725] cpu cpu4: Looking up cpu-supply from device tree
[    7.972223] cpu cpu4: Looking up mem-supply from device tree
[    7.972756] cpu cpu6: Looking up cpu-supply from device tree
[    7.974414] cpu cpu6: bin=0
[    7.974583] cpu cpu6: leakage=9
[    7.974601] cpu cpu6: Looking up cpu-supply from device tree
[    7.981071] cpu cpu6: pvtm=1700
[    7.984995] cpu cpu6: pvtm-volt-sel=4
[    7.985022] cpu cpu6: Looking up cpu-supply from device tree
[    7.985517] cpu cpu6: Looking up mem-supply from device tree
[    7.986626] cpu cpu0: avs=0
[    7.987551] cpu cpu4: avs=0
[    7.988494] cpu cpu6: avs=0
[    7.988652] cpu cpu0: EM: OPP:816000 is inefficient
[    7.988655] cpu cpu0: EM: OPP:600000 is inefficient
[    7.988739] cpu cpu0: EM: created perf domain
[    7.988776] cpu cpu0: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=1608000000 h_table=0
[    7.989471] cpu cpu4: EM: OPP:2304000 is inefficient
[    7.989475] cpu cpu4: EM: OPP:816000 is inefficient
[    7.989478] cpu cpu4: EM: OPP:600000 is inefficient
[    7.989623] cpu cpu4: EM: created perf domain
[    7.989654] cpu cpu4: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
[    7.998280] cpu cpu6: EM: OPP:2304000 is inefficient
[    7.998284] cpu cpu6: EM: OPP:816000 is inefficient
[    7.998287] cpu cpu6: EM: OPP:600000 is inefficient
[    7.998436] cpu cpu6: EM: created perf domain
[    7.998862] cpu cpu6: l=10000 h=85000 hyst=5000 l_limit=0 h_limit=2208000000 h_table=0
# cpufreq-info
analyzing CPU 0:
  driver: cpufreq-dt
  maximum transition latency: 84.0 us.
                  The governor "ondemand" may decide which speed to use
                  within this range.
  current CPU frequency is 408 MHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:96.30%, 600 MHz:0.49%, 816 MHz:0.05%, 1.01 GHz:0.05%, 1.20 GHz:0.13%, 1.42 GHz:0.11%, 1.61 GHz:0.06%, 1.80 GHz:2.82%  (325)
analyzing CPU 1:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 2:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 3:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 4:
  driver: cpufreq-dt
  CPUs which run at the same hardware frequency: 4 5
  CPUs which need to have their frequency coordinated by software: 4 5
  maximum transition latency: 324 us.
  hardware limits: 408 MHz - 2.40 GHz
  available frequency steps: 408 MHz, 600 MHz, 816 MHz, 1.01 GHz, 1.20 GHz, 1.42 GHz, 1.61 GHz, 1.80 GHz, 2.02 GHz, 2.21 GHz, 2.26 GHz, 2.30 GHz, 2.35 GHz, 2.40 GHz
  current policy: frequency should be within 408 MHz and 2.40 GHz.
                  within this range.
  current CPU frequency is 600 MHz (asserted by call to hardware).
  cpufreq stats: 408 MHz:50.53%, 600 MHz:47.79%, 816 MHz:0.26%, 1.01 GHz:0.02%, 1.20 GHz:0.02%, 1.42 GHz:0.01%, 1.61 GHz:0.04%, 1.80 GHz:0.01%, 2.02 GHz:0.01%, 2.21 GHz:0.01%, 2.26 GHz:0.00%, 2.30 GHz:0.00%, 2.35 GHz:0.00%, 2.40 GHz:1.27%  (148)
analyzing CPU 5:
  driver: cpufreq-dt
                  within this range.
analyzing CPU 6:
  driver: cpufreq-dt
                  within this range.
  cpufreq stats: 408 MHz:98.77%, 600 MHz:0.18%, 816 MHz:0.04%, 1.01 GHz:0.03%, 1.20 GHz:0.03%, 1.42 GHz:0.03%, 1.61 GHz:0.03%, 1.80 GHz:0.01%, 2.02 GHz:0.01%, 2.21 GHz:0.01%, 2.26 GHz:0.00%, 2.30 GHz:0.00%, 2.35 GHz:0.01%, 2.40 GHz:0.85%  (156)
analyzing CPU 7:
  driver: cpufreq-dt
                  within this range.
edit: The scheduling seems to make use of the "low" kernels only, the edge kernel across the different kernels (which run on a higher speed on idle).
edit2: more details:
Little cores
sys/kernel/debug/energy_model/cpu0# ls -1  ps\:*/power | xargs -I {} sh -c 'echo -n "{} : ";cat {} '  | sort -t ':' -k3 -n
ps:408000/power : 18
ps:600000/power : 27
ps:816000/power : 37
ps:1008000/power : 45
ps:1200000/power : 56
ps:1416000/power : 74
ps:1608000/power : 106
ps:1800000/power : 149
# ls -1  ps\:*/cost | xargs -I {} sh -c 'echo -n "{} : ";cat {} '  | sort -t ':' -k3 -n
ps:408000/cost : 79411
ps:1008000/cost : 80357
ps:600000/cost : 81000
ps:816000/cost : 81617
ps:1200000/cost : 84000
ps:1416000/cost : 94067
ps:1608000/cost : 118656
ps:1800000/cost : 149000
High cores:
ps:408000/power : 55
ps:600000/power : 82
ps:816000/power : 111
ps:1008000/power : 137
ps:1200000/power : 164
ps:1416000/power : 208
ps:1608000/power : 253
ps:1800000/power : 345
ps:2016000/power : 463
ps:2208000/power : 613
ps:2256000/power : 676
ps:2304000/power : 691
ps:2352000/power : 705
ps:2400000/power : 720
ps:408000/cost : 323529
ps:1008000/cost : 326190
ps:816000/cost : 326470
ps:1200000/cost : 328000
ps:600000/cost : 328000
ps:1416000/cost : 352542
ps:1608000/cost : 377611
ps:1800000/cost : 460000
ps:2016000/cost : 551190
ps:2208000/cost : 666304
ps:2256000/cost : 719148
ps:2352000/cost : 719387
ps:2304000/cost : 719791
ps:2400000/cost : 720000
Added more details
Currently, I am assuming, that the reason for the different behavior is the result of a different cost calculation. (Maybe the flag "inefficient toward ondemand doesn't exists either".)
My hottest candidate are the changes around this patch:
I am still investigating in that area and need to compare a few things.
My assumption is, that there is a kind of change in OPP, energy_management and cpufreq-drivers (-dt), which needs to be adapted to rockchip-cpufreq. Something like the kernel expects unit W but the driver delivers V.
edit: I discarded the assumption about the units, after reviewing the upstream code about the calculation  + patches for rk3588
I did move on with that research. It seems that the OPP readings are different, which should be the same (assumption).
# uname -r
# bash opp_summary.sh
  cpu0
      Frequency  |      u_watt       u_amp  u_volt_max  u_volt_min  u_volt_target
      408000000  |           0           0      950000      750000      750000
      600000000  |           0           0      950000      750000      750000
      816000000  |           0           0      950000      750000      750000
     1008000000  |           0           0      950000      750000      750000
     1200000000  |           0           0      950000      775000      775000
     1416000000  |           0           0      950000      825000      825000
     1608000000  |           0           0      950000      875000      875000
     1800000000  |           0           0      950000      950000      950000
  cpu4
      408000000  |           0           0     1000000      600000      600000
                 |           0           0     1000000      675000      675000
      600000000  |           0           0     1000000      600000      600000
      816000000  |           0           0     1000000      600000      600000
     1008000000  |           0           0     1000000      625000      625000
     1200000000  |           0           0     1000000      650000      650000
     1416000000  |           0           0     1000000      675000      675000
     1608000000  |           0           0     1000000      700000      700000
     1800000000  |           0           0     1000000      775000      775000
     2016000000  |           0           0     1000000      850000      850000
     2208000000  |           0           0     1000000      925000      925000
  cpu6
# uname -r
# bash ./opp_summary.sh
  cpu0
      Frequency  |       u_amp  u_volt_max  u_volt_min  u_volt_target
      408000000  |           0      950000      675000      675000
      600000000  |           0      950000      675000      675000
      816000000  |           0      950000      675000      675000
     1008000000  |           0      950000      675000      675000
     1200000000  |           0      950000      687500      687500
     1416000000  |           0      950000      725000      725000
     1608000000  |           0      950000      812500      812500
     1800000000  |           0      950000      912500      912500
  cpu4
      408000000  |           0     1000000      675000      675000
      600000000  |           0     1000000      675000      675000
      816000000  |           0     1000000      675000      675000
     1008000000  |           0     1000000      675000      675000
     1200000000  |           0     1000000      675000      675000
     1416000000  |           0     1000000      700000      700000
     1608000000  |           0     1000000      725000      725000
     1800000000  |           0     1000000      800000      800000
     2016000000  |           0     1000000      875000      875000
     2208000000  |           0     1000000      962500      962500
     2256000000  |           0     1000000     1000000     1000000
     2304000000  |           0     1000000     1000000     1000000
     2352000000  |           0     1000000     1000000     1000000
     2400000000  |           0     1000000     1000000     1000000
  cpu6
Based off this script opp_summary.sh
