bp2ija2j Posted September 25, 2023 Share Posted September 25, 2023 $ neofetch ubuntu@orangepi5 ---------------- █ █ █ █ █ █ █ █ █ █ █ OS: Armbian (23.11.0-trunk.145) aarch64 ███████████████████████ Host: Orange Pi 5 ▄▄██ ██▄▄ Kernel: 6.6.0-rc1-edge-rockchip-rk3588 ▄▄██ ███████████ ██▄▄ Uptime: 4 mins ▄▄██ ██ ██ ██▄▄ Packages: 427 (dpkg) ▄▄██ ██ ██ ██▄▄ Shell: bash 5.2.15 ▄▄██ ██ ██ ██▄▄ Terminal: /dev/pts/0 ▄▄██ █████████████ ██▄▄ CPU: (8) @ 1.800GHz ▄▄██ ██ ██ ██▄▄ Memory: 196MiB / 15718MiB ▄▄██ ██ ██ ██▄▄ ▄▄██ ██ ██ ██▄▄ ▄▄██ ██▄▄ ███████████████████████ █ █ █ █ █ █ █ █ █ █ █ Hello, I'm running the edge kernel on a Orange PI 5. I have moved the root partition to an nvme drive with the commands: mount /dev/nvme0n1p# /mnt rsync -aAXHv / --exclude={"/dev/*","/proc/*","/sys/*","/tmp/*","/run/*","/media/*","/boot/*","/mnt/*","/lost+found"} /mnt I left the boot partition on the SD card. I changed the root UUID in the /boot/armbianEnv.txt and in the /mnt/etc/fstab to point to the nvme drive partition. Rebooted and everything seems to work just fine. Is there anything else I need to do before I start using this SBC as a server? Mainly for docker and qemu testing. 0 Quote Link to comment Share on other sites More sharing options...
Jean-Philippe Posted October 1, 2023 Share Posted October 1, 2023 Hi, Did you manage to have USB3 or USB-C working? 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted October 2, 2023 Share Posted October 2, 2023 On 9/25/2023 at 12:14 PM, bp2ija2j said: Is there anything else I need to do before I start using this SBC as a server? Not really. You should keep in mind that mainline support for the RK3588 is under heavy development so issues are to be expected. 0 Quote Link to comment Share on other sites More sharing options...
