orange pi zero 2 doesn't reconnect to wifi after router connection lost
Go to solution Solved by Gunjan Gupta,
Hi everyone. FIrst of all, i need to thank this community, you need to be congratulated for the effort you all make to this project.
When i restart my router, the wlan0 of my opi zero 2  stops, no network with "nmcli dev wifi" appears. I've already tried restarting the service with "sudo systemctl restart NetworkManager", disable IPv6 and also installing latest armbian-firmware-full.deb, but it still the same. I'm only able to resolve it with a reboot. Previously I used Debian and this did not happen. I'm using this linux version (4.9.318-legacy-sun50iw9)  because of compatibility with the SPI LCD TFT display that I'm using. From what I researched here on the forum, this seems to be related to drivers, but I didn't find the solution (if it exists for the version I'm using).  Normally I would try another version, but I am unable to remove the SD card from the opi at the moment (the LCD is glued to the front of it), I would like to solve this just through the terminal. I will leave the armbianmonitor log below. thanks.
Network/firewall problem detected.
Trying fallback...
Network/firewall problem detected. Not able to upload debug info.
     1
     2	### Activated 1 lzo zram swap devices with 482MB each.
     3	### Activated Armbian ramlog partition with lz4 compression
     4
     5	Mon Sep 25 10:14:12 AM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
     6
     7	### dmesg:
     8
     9	[    0.000000] Booting Linux on physical CPU 0x0
    10	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
    11	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
    12	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
    13	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
    14	[    0.000000] On node 0 totalpages: 262144
    15	[    0.000000]   DMA zone: 4096 pages used for memmap
    16	[    0.000000]   DMA zone: 0 pages reserved
    17	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
    18	[    0.000000] psci: probing for conduit method from DT.
    19	[    0.000000] psci: PSCIv1.0 detected in firmware.
    20	[    0.000000] psci: Using standard PSCI v0.2 function IDs
    21	[    0.000000] psci: Trusted OS migration not required
    22	[    0.000000] psci: SMC Calling Convention v1.0
    23	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
    24	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
    25	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
    26	[    0.000000] Detected VIPT I-cache on CPU0
    27	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
    28	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
    29	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
    30	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
    31	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
    32	[    0.000000] log_buf_len min size: 131072 bytes
    33	[    0.000000] log_buf_len: 524288 bytes
    34	[    0.000000] early log buf free: 129352(98%)
    35	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
    36	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
    37	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
    38	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
    39	[    0.000000] Virtual kernel memory layout:
    40	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
    41	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
    42	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
    43	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
    44	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
    45	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
    46	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
    47	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
    48	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
    49	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
    50	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
    51	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
    52	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    53	[    0.000000] Preemptible hierarchical RCU implementation.
    54	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
    55	[    0.000000] NR_IRQS:64 nr_irqs:64 0
    56	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    57	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
    58	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    59	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    60	[    0.000225] Console: colour dummy device 80x25
    61	[    0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
    62	[    0.000249] pid_max: default: 32768 minimum: 301
    63	[    0.000446] Security Framework initialized
    64	[    0.000454] AppArmor: AppArmor disabled by boot time parameter
    65	[    0.000568] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
    66	[    0.000573] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
    67	[    0.001841] sched-energy: CPU device node has no sched-energy-costs
    68	[    0.001855] Invalid sched_group_energy for CPU0
    69	[    0.001863] CPU0: update cpu_capacity 1024
    70	[    0.008981] ASID allocator initialised with 32768 entries
    71	[    0.027980] BOOTEVENT:        27.964624: ON
    72	[    0.055930] Detected VIPT I-cache on CPU1
    73	[    0.055983] Invalid sched_group_energy for CPU1
    74	[    0.055987] CPU1: update cpu_capacity 1024
    75	[    0.055990] CPU1: Booted secondary processor [410fd034]
    76	[    0.079320] Detected VIPT I-cache on CPU2
    77	[    0.079359] Invalid sched_group_energy for CPU2
    78	[    0.079363] CPU2: update cpu_capacity 1024
    79	[    0.079366] CPU2: Booted secondary processor [410fd034]
    80	[    0.102723] Detected VIPT I-cache on CPU3
    81	[    0.102756] Invalid sched_group_energy for CPU3
    82	[    0.102759] CPU3: update cpu_capacity 1024
    83	[    0.102762] CPU3: Booted secondary processor [410fd034]
    84	[    0.102849] Brought up 4 CPUs
    85	[    0.102857] SMP: Total of 4 processors activated.
    86	[    0.102865] CPU features: detected feature: 32-bit EL0 Support
    87	[    0.102871] CPU features: detected feature: Kernel page table isolation (KPTI)
    88	[    0.106635] CPU: All CPU(s) started at EL1
    89	[    0.106656] alternatives: patching kernel code
    90	[    0.106835] Invalid sched_group_energy for CPU3
    91	[    0.106844] CPU3: update max cpu_capacity 1024
    92	[    0.106850] Invalid sched_group_energy for Cluster3
    93	[    0.106855] Invalid sched_group_energy for CPU2
    94	[    0.106860] Invalid sched_group_energy for Cluster2
    95	[    0.106865] Invalid sched_group_energy for CPU1
    96	[    0.106871] Invalid sched_group_energy for Cluster1
    97	[    0.106876] Invalid sched_group_energy for CPU0
    98	[    0.106881] Invalid sched_group_energy for Cluster0
    99	[    0.108304] devtmpfs: initialized
   100	[    0.112733] CPU1: update max cpu_capacity 1024
   101	[    0.143456] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
   102	[    0.143481] futex hash table entries: 1024 (order: 5, 131072 bytes)
   103	[    0.144142] xor: measuring software checksum speed
   104	[    0.176262]    8regs     :  1933.200 MB/sec
   105	[    0.209641]    8regs_prefetch:  1720.800 MB/sec
   106	[    0.243028]    32regs    :  2287.200 MB/sec
   107	[    0.276415]    32regs_prefetch:  1996.800 MB/sec
   108	[    0.276421] xor: using function: 32regs (2287.200 MB/sec)
   109	[    0.276480] atomic64_test: passed
   110	[    0.276486] pinctrl core: initialized pinctrl subsystem
   111	[    0.277668] NET: Registered protocol family 16
   112	[    0.278918] dump_class_init,861, success
   113	[    0.293134] cpuidle: using governor menu
   114	[    0.294564] sunxi iommu: irq = 8
   115	[    0.294891] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
   116	[    0.294909] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   117	[    0.296309] DMA: preallocated 256 KiB pool for atomic allocations
   118	[    0.297693] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
   119	[    0.312065] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
   120	[    0.316111] iommu: Adding device 1c0e000.ve to group 0
   121	[    0.316665] iommu: Adding device 1c00000.vp9 to group 0
   122	[    0.328265] iommu: Adding device 1000000.disp to group 0
   123	[    0.329691] iommu: Adding device 1480000.g2d to group 0
   124	[    0.332912] iommu: Adding device csi0 to group 0
   125	[    0.333397] iommu: Adding device csi1 to group 0
   126	[    0.334620] iommu: Adding device 6600800.vind:scaler@0 to group 0
   127	[    0.334913] iommu: Adding device 6600800.vind:scaler@1 to group 0
   128	[    0.335223] iommu: Adding device 6600800.vind:scaler@2 to group 0
   129	[    0.335532] iommu: Adding device 6600800.vind:scaler@3 to group 0
   130	[    0.335833] iommu: Adding device 6600800.vind:scaler@4 to group 0
   131	[    0.336129] iommu: Adding device 6600800.vind:scaler@5 to group 0
   132	[    0.337214] iommu: Adding device vinc0 to group 0
   133	[    0.337719] iommu: Adding device vinc1 to group 0
   134	[    0.339189] iommu: Adding device 1420000.deinterlace to group 0
   135	[    0.381216] HugeTLB registered 2 MB page size, pre-allocated 0 pages
   136	[    0.437337] raid6: int64x1  gen()   391 MB/s
   137	[    0.494101] raid6: int64x1  xor()   362 MB/s
   138	[    0.550863] raid6: int64x2  gen()   591 MB/s
   139	[    0.607537] raid6: int64x2  xor()   513 MB/s
   140	[    0.664318] raid6: int64x4  gen()   840 MB/s
   141	[    0.721054] raid6: int64x4  xor()   629 MB/s
   142	[    0.777759] raid6: int64x8  gen()   964 MB/s
   143	[    0.834536] raid6: int64x8  xor()   655 MB/s
   144	[    0.891292] raid6: neonx1   gen()   648 MB/s
   145	[    0.948026] raid6: neonx1   xor()   641 MB/s
   146	[    1.004736] raid6: neonx2   gen()   975 MB/s
   147	[    1.061478] raid6: neonx2   xor()   819 MB/s
   148	[    1.118260] raid6: neonx4   gen()  1287 MB/s
   149	[    1.174969] raid6: neonx4   xor()   965 MB/s
   150	[    1.231719] raid6: neonx8   gen()  1323 MB/s
   151	[    1.288451] raid6: neonx8   xor()   991 MB/s
   152	[    1.288456] raid6: using algorithm neonx8 gen() 1323 MB/s
   153	[    1.288461] raid6: .... xor() 991 MB/s, rmw enabled
   154	[    1.288467] raid6: using intx1 recovery algorithm
   155	[    1.288648] pwm module init!
   156	[    1.292943] sunxi-pm debug v3.10
   157	[    1.294038] SCSI subsystem initialized
   158	[    1.294659] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
   159	[    1.294743] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
   160	[    1.294863] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
   161	[    1.295349] spi spi0: master is unqueued, this is deprecated
   162	[    1.295659] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
   163	[    1.296234] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
   164	[    1.296315] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
   165	[    1.296427] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
   166	[    1.296879] spi spi1: master is unqueued, this is deprecated
   167	[    1.297185] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
   168	[    1.297961] usbcore: registered new interface driver usbfs
   169	[    1.298051] usbcore: registered new interface driver hub
   170	[    1.298124] usbcore: registered new device driver usb
   171	[    1.298366] sunxi_i2c_adap_init()2522 - init
   172	[    1.298955] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
   173	[    1.299050] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
   174	[    1.299057] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
   175	[    1.299073] twi3 supply twi not found, using dummy regulator
   176	[    1.299150] twi_request_gpio()451 - [i2c3] init name: twi3
   177	[    1.299897] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
   178	[    1.299975] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
   179	[    1.299983] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
   180	[    1.299996] twi5 supply twi not found, using dummy regulator
   181	[    1.300097] twi_request_gpio()451 - [i2c5] init name: twi5
   182	[    1.300584] axp20x-i2c 5-0036: AXP20x variant AXP806 found
   183	[    1.319272] random: fast init done
   184	[    1.330453] axp20x-i2c 5-0036: AXP20X driver loaded
   185	[    1.330939] media: Linux media interface: v0.10
   186	[    1.331023] Linux video capture interface: v2.00
   187	[    1.331851] Advanced Linux Sound Architecture Driver Initialized.
   188	[    1.332584] Bluetooth: Core ver 2.22
   189	[    1.332657] NET: Registered protocol family 31
   190	[    1.332663] Bluetooth: HCI device and connection manager initialized
   191	[    1.332681] Bluetooth: HCI socket layer initialized
   192	[    1.332694] Bluetooth: L2CAP socket layer initialized
   193	[    1.332733] Bluetooth: SCO socket layer initialized
   194	[    1.333495] [DISP]disp_module_init
   195	[    1.334685] [DISP] parser_disp_init_para,line:1403:
   196	[    1.334694] of_property_read fb0_width fail
   197	[    1.334707] [DISP] disp_init,line:2215:
   198	[    1.334713] smooth display screen:0 type:4 mode:10
   199	[    1.352233] [DISP]disp_module_init finish
   200	[    1.353103] clocksource: Switched to clocksource arch_sys_counter
   201	[    1.353356] VFS: Disk quotas dquot_6.6.0
   202	[    1.353442] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   203	[    1.354182] Console: switching to colour frame buffer device 240x67
   204	[    1.397407] NET: Registered protocol family 2
   205	[    1.397529] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
   206	[    1.416697] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
   207	[    1.416772] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
   208	[    1.416896] TCP: Hash tables configured (established 8192 bind 8192)
   209	[    1.416987] UDP hash table entries: 512 (order: 2, 16384 bytes)
   210	[    1.417016] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
   211	[    1.417337] NET: Registered protocol family 1
   212	[    1.417940] RPC: Registered named UNIX socket transport module.
   213	[    1.417945] RPC: Registered udp transport module.
   214	[    1.417948] RPC: Registered tcp transport module.
   215	[    1.417951] RPC: Registered tcp NFSv4.1 backchannel transport module.
   216	[    1.418220] Trying to unpack rootfs image as initramfs...
   217	[    2.172617] Freeing initrd memory: 17256K
   218	[    2.173741] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
   219	[    2.177671] audit: initializing netlink subsys (disabled)
   220	[    2.177758] audit: type=2000 audit(2.173:1): initialized
   221	[    2.178699] workingset: timestamp_bits=45 max_order=18 bucket_order=0
   222	[    2.189823] DLM installed
   223	[    2.191628] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   224	[    2.191964] Registering sdcardfs 0.1
   225	[    2.192434] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
   226	[    2.194120] ntfs: driver 2.1.32 [Flags: R/W].
   227	[    2.200780] NET: Registered protocol family 38
   228	[    2.201137] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
   229	[    2.201276] io scheduler noop registered
   230	[    2.201285] io scheduler deadline registered
   231	[    2.201454] io scheduler cfq registered (default)
   232	[    2.203658] failed to get easy_light_used assign
   233	[    2.203667] failed to get normal led pin assign
   234	[    2.203673] failed to get standby led pin assign
   235	[    2.203678] failed to get standby led pin assign
   236	[    2.203683] these is zero number for gpio
   237	[    2.203688] gpio_init finish with uesd
   238	[    2.206901] uart uart0: get regulator failed
   239	[    2.207102] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
   240	[    2.207125] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
   241	[    2.207219] console [ttyS0] enabled
   242	[    2.208029] uart uart1: get regulator failed
   243	[    2.208216] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
   244	[    2.208918] uart uart5: get regulator failed
   245	[    2.209103] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
   246	[    2.210433] misc dump reg init
   247	[    2.211574] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
   248	[    2.211910] Unable to detect cache hierarchy for CPU 0
   249	[    2.225936] brd: module loaded
   250	[    2.234300] loop: module loaded
   251	[    2.234492] [NAND][NE] Not found valid nand node on dts
   252	[    2.235082] Get boot type cmd line fail
   253	[    2.235668] sunxi-bt soc@03000000:bt: Missing bt_power.
   254	[    2.235679] sunxi-bt soc@03000000:bt: bt_power_name ((null))
   255	[    2.235686] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
   256	[    2.235693] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
   257	[    2.235748] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
   258	[    2.235825] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
   259	[    2.236724] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
   260	[    2.236736] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
   261	[    2.236743] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
   262	[    2.236751] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
   263	[    2.236758] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
   264	[    2.236790] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
   265	[    2.236824] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
   266	[    2.236832] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
   267	[    2.236850] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
   268	[    2.237822] [ADDR_MGT] addr_mgt_probe: success.
   269	[    2.244731] tun: Universal TUN/TAP device driver, 1.6
   270	[    2.244743] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
   271	[    2.246912] gmac-power0: NULL
   272	[    2.246922] gmac-power1: NULL
   273	[    2.246928] gmac-power2: NULL
   274	[    2.247873] PPP generic driver version 2.4.2
   275	[    2.248154] PPP BSD Compression module registered
   276	[    2.248165] PPP Deflate Compression module registered
   277	[    2.248191] PPP MPPE Compression module registered
   278	[    2.248199] NET: Registered protocol family 24
   279	[    2.248232] PPTP driver version 0.8.5
   280	[    2.248602] usbcore: registered new interface driver r8152
   281	[    2.248676] usbcore: registered new interface driver asix
   282	[    2.248773] usbcore: registered new interface driver ax88179_178a
   283	[    2.248840] usbcore: registered new interface driver cdc_ether
   284	[    2.248903] usbcore: registered new interface driver net1080
   285	[    2.248970] usbcore: registered new interface driver cdc_subset
   286	[    2.249034] usbcore: registered new interface driver zaurus
   287	[    2.249123] usbcore: registered new interface driver cdc_ncm
   288	[    2.249130] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   289	[    2.249487] get drv_vbus is fail, 84
   290	[    2.249497] get ehci0-controller, regulator_io is no nocare
   291	[    2.249813] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
   292	[    2.249819] [sunxi-ehci0]: Not init ehci0
   293	[    2.249954] get ehci1-controller, regulator_io is no nocare
   294	[    2.250171] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
   295	[    2.250230] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   296	[    2.250258] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
   297	[    2.250976] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
   298	[    2.266480] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
   299	[    2.266873] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
   300	[    2.266883] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   301	[    2.266890] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   302	[    2.266898] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
   303	[    2.266904] usb usb1: SerialNumber: sunxi-ehci
   304	[    2.267826] hub 1-0:1.0: USB hub found
   305	[    2.267882] hub 1-0:1.0: 1 port detected
   306	[    2.268635] get drv_vbus is fail, 84
   307	[    2.268642] get ehci2-controller, regulator_io is no nocare
   308	[    2.268884] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
   309	[    2.268936] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   310	[    2.268962] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
   311	[    2.269313] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
   312	[    2.279797] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
   313	[    2.280032] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
   314	[    2.280041] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   315	[    2.280049] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   316	[    2.280056] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
   317	[    2.280062] usb usb2: SerialNumber: sunxi-ehci
   318	[    2.280928] hub 2-0:1.0: USB hub found
   319	[    2.280977] hub 2-0:1.0: 1 port detected
   320	[    2.281647] get drv_vbus is fail, 84
   321	[    2.281655] get ehci3-controller, regulator_io is no nocare
   322	[    2.281903] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
   323	[    2.281955] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   324	[    2.281979] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
   325	[    2.282294] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
   326	[    2.296448] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
   327	[    2.296651] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
   328	[    2.296659] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   329	[    2.296667] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
   330	[    2.296674] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
   331	[    2.296681] usb usb3: SerialNumber: sunxi-ehci
   332	[    2.297536] hub 3-0:1.0: USB hub found
   333	[    2.297581] hub 3-0:1.0: 1 port detected
   334	[    2.298516] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   335	[    2.298886] get drv_vbus is fail, 84
   336	[    2.298894] get ohci0-controller, regulator_io is no nocare
   337	[    2.299227] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
   338	[    2.299232] [sunxi-ohci0]: Not init ohci0
   339	[    2.299350] get ohci1-controller, regulator_io is no nocare
   340	[    2.299509] hci: request ohci1-controller gpio:80
   341	[    2.299586] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
   342	[    2.299637] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
   343	[    2.299662] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
   344	[    2.299740] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
   345	[    2.360641] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
   346	[    2.360652] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   347	[    2.360659] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
   348	[    2.360666] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
   349	[    2.360673] usb usb4: SerialNumber: sunxi-ohci
   350	[    2.361541] hub 4-0:1.0: USB hub found
   351	[    2.361587] hub 4-0:1.0: 1 port detected
   352	[    2.362260] get drv_vbus is fail, 84
   353	[    2.362267] get ohci2-controller, regulator_io is no nocare
   354	[    2.362601] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
   355	[    2.362650] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
   356	[    2.362676] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
   357	[    2.362753] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
   358	[    2.420614] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
   359	[    2.420625] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   360	[    2.420632] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
   361	[    2.420640] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
   362	[    2.420646] usb usb5: SerialNumber: sunxi-ohci
   363	[    2.421525] hub 5-0:1.0: USB hub found
   364	[    2.421575] hub 5-0:1.0: 1 port detected
   365	[    2.422259] get drv_vbus is fail, 84
   366	[    2.422267] get ohci3-controller, regulator_io is no nocare
   367	[    2.422597] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
   368	[    2.422646] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
   369	[    2.422671] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
   370	[    2.422754] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
   371	[    2.480615] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
   372	[    2.480625] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   373	[    2.480632] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
   374	[    2.480640] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
   375	[    2.480646] usb usb6: SerialNumber: sunxi-ohci
   376	[    2.481502] hub 6-0:1.0: USB hub found
   377	[    2.481548] hub 6-0:1.0: 1 port detected
   378	[    2.482475] ohci-platform: OHCI generic platform driver
   379	[    2.483238] usbcore: registered new interface driver uas
   380	[    2.483411] usbcore: registered new interface driver usb-storage
   381	[    2.483521] usbcore: registered new interface driver ums-alauda
   382	[    2.483597] usbcore: registered new interface driver ums-cypress
   383	[    2.483666] usbcore: registered new interface driver ums-datafab
   384	[    2.483735] usbcore: registered new interface driver ums_eneub6250
   385	[    2.483806] usbcore: registered new interface driver ums-freecom
   386	[    2.483879] usbcore: registered new interface driver ums-isd200
   387	[    2.483950] usbcore: registered new interface driver ums-jumpshot
   388	[    2.484023] usbcore: registered new interface driver ums-karma
   389	[    2.484101] usbcore: registered new interface driver ums-onetouch
   390	[    2.484197] usbcore: registered new interface driver ums-realtek
   391	[    2.484276] usbcore: registered new interface driver ums-sddr09
   392	[    2.484349] usbcore: registered new interface driver ums-sddr55
   393	[    2.484422] usbcore: registered new interface driver ums-usbat
   394	[    2.484569] usb_serial_number:20080411
   395	[    2.485793] input: sunxi-keyboard as /devices/virtual/input/input0
   396	[    2.486377] usbcore: registered new interface driver xpad
   397	[    2.486522] usbcore: registered new interface driver usb_acecad
   398	[    2.486622] usbcore: registered new interface driver aiptek
   399	[    2.486706] usbcore: registered new interface driver gtco
   400	[    2.486783] usbcore: registered new interface driver hanwang
   401	[    2.486864] usbcore: registered new interface driver kbtab
   402	[    2.487331] axp2101_pek: axp2101-pek can not register without irq
   403	[    2.487354] axp2101-pek: probe of axp2101-pek.0 failed with error -22
   404	[    2.488835] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
   405	[    2.488902] sunxi-rtc rtc: RTC enabled
   406	[    2.489377] i2c /dev entries driver
   407	[    2.490183] lirc_dev: IR Remote Control driver registered, major 244
   408	[    2.490195] IR NEC protocol handler initialized
   409	[    2.490202] IR RC5(x/sz) protocol handler initialized
   410	[    2.490207] IR RC6 protocol handler initialized
   411	[    2.490213] IR JVC protocol handler initialized
   412	[    2.490218] IR Sony protocol handler initialized
   413	[    2.490224] IR SANYO protocol handler initialized
   414	[    2.490230] IR Sharp protocol handler initialized
   415	[    2.490236] IR MCE Keyboard/mouse protocol handler initialized
   416	[    2.490242] IR LIRC bridge handler initialized
   417	[    2.490247] IR XMP protocol handler initialized
   418	[    2.490771] sunxi_ir_startup: get ir protocol failed
   419	[    2.490814] 7040000.s_cir supply ir0 not found, using dummy regulator
   420	[    2.491018] Registered IR keymap rc_map_sunxi
   421	[    2.491417] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
   422	[    2.491650] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
   423	[    2.492626] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
   424	[    2.493253] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
   425	[    2.493950] sunxi cedar version 0.1
   426	[    2.494148] VE: install start!!!
   427
   428	[    2.494344] cedar_ve: cedar-ve the get irq is 278
   429	[    2.494969] VE: get debugfs_mpp_root is NULL, please check mpp
   430
   431	[    2.494982] VE: sunxi ve debug register driver failed!
   432
   433	[    2.498225] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
   434	[    2.499513] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
   435	[    2.499874] Bluetooth: HCI UART driver ver 2.3
   436	[    2.499886] Bluetooth: HCI UART protocol H4 registered
   437	[    2.499892] Bluetooth: HCI UART protocol LL registered
   438	[    2.499897] Bluetooth: HCI UART protocol Three-wire (H5) registered
   439	[    2.504082] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
   440	[    2.504098] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
   441	[    2.504111] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
   442	[    2.504123] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
   443	[    2.504135] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
   444	[    2.504147] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
   445	[    2.504554] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
   446	[    2.504670] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
   447	[    2.504870] sunxi-mmc sdc0: No vmmc regulator found
   448	[    2.504877] sunxi-mmc sdc0: No vqmmc regulator found
   449	[    2.504884] sunxi-mmc sdc0: No vdmmc regulator found
   450	[    2.504890] sunxi-mmc sdc0: No vd33sw regulator found
   451	[    2.504898] sunxi-mmc sdc0: No vd18sw regulator found
   452	[    2.504904] sunxi-mmc sdc0: No vq33sw regulator found
   453	[    2.504910] sunxi-mmc sdc0: No vq18sw regulator found
   454	[    2.505647] sunxi-mmc sdc0: set host busy
   455	[    2.505745] sunxi-mmc sdc0: Got CD GPIO
   456	[    2.506111] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
   457	[    2.506147] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
   458	[    2.519790] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   459	[    2.536685] sunxi-mmc sdc0: detmode:gpio irq
   460	[    2.536715] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   461	[    2.539215] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   462	[    2.540562] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
   463	[    2.540680] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
   464	[    2.540821] sunxi-mmc sdc1: No vmmc regulator found
   465	[    2.540828] sunxi-mmc sdc1: No vqmmc regulator found
   466	[    2.540834] sunxi-mmc sdc1: No vdmmc regulator found
   467	[    2.540840] sunxi-mmc sdc1: No vd33sw regulator found
   468	[    2.540846] sunxi-mmc sdc1: No vd18sw regulator found
   469	[    2.540852] sunxi-mmc sdc1: No vq33sw regulator found
   470	[    2.540859] sunxi-mmc sdc1: No vq18sw regulator found
   471	[    2.541310] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   472	[    2.542581] sunxi-mmc sdc1: set host busy
   473	[    2.542659] mmc:failed to get gpios
   474	[    2.543780] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   475	[    2.545044] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
   476	[    2.559846] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   477	[    2.568166] mmc0: host does not support reading read-only switch, assuming write-enable
   478	[    2.570079] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
   479	[    2.570163] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
   480	[    2.570517] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
   481	[    2.570613] mmc0: new high speed SDXC card at address 0001
   482	[    2.571691] mmcblk0: mmc0:0001 SD16G 59.5 GiB
   483	[    2.573317]  mmcblk0: p1
   484	[    2.576495] sunxi-mmc sdc1: detmode:manually by software
   485	[    2.578689] ledtrig-cpu: registered to indicate activity on CPUs
   486	[    2.579410] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   487	[    2.580261] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   488	[    2.580294] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   489	[    2.582800] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   490	[    2.584727] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
   491	[    2.585563] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
   492	[    2.586402] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
   493	[    2.586714] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
   494	[    2.586722] sunxi_emce_probe()590emce hw init failed!
   495	[    2.586749] emce: probe of emce failed with error -2
   496	[    2.587041] hidraw: raw HID events driver (C) Jiri Kosina
   497	[    2.587291] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
   498	[    2.587328] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
   499	[    2.591817] usbcore: registered new interface driver usbhid
   500	[    2.591824] usbhid: USB HID core driver
   501	[    2.593303] optee: probing for conduit method from DT.
   502	[    2.593319] optee: api uid mismatch
   503	[    2.593917] usbcore: registered new interface driver snd-usb-audio
   504	[    2.595507] [sunxi_hdmi_codec_init] driver and deivce register finished.
   505	[    2.597254] [sunxi_internal_codec_probe]:get audio avcc failed
   506	[    2.597292] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
   507	[    2.597527] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
   508	[    2.600081] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
   509	[    2.602045] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
   510	[    2.602059] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
   511	[    2.604441] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
   512	[    2.604466] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
   513	[    2.608609] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
   514	[    2.610037] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
   515	[    2.611906] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
   516	[    2.615014] pktgen: Packet Generator for packet performance testing. Version: 2.75
   517	[    2.615450] u32 classifier
   518	[    2.615456]     Actions configured
   519	[    2.615469] Netfilter messages via NETLINK v0.30.
   520	[    2.615497] nfnl_acct: registering with nfnetlink.
   521	[    2.615834] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
   522	[    2.616081] ctnetlink v0.93: registering with nfnetlink.
   523	[    2.616896] xt_time: kernel timezone is -0000
   524	[    2.616922] IPVS: Registered protocols (TCP, UDP)
   525	[    2.617030] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
   526	[    2.617156] IPVS: Creating netns size=1928 id=0
   527	[    2.617288] IPVS: ipvs loaded.
   528	[    2.617296] IPVS: [rr] scheduler registered.
   529	[    2.617394] ipip: IPv4 and MPLS over IPv4 tunneling driver
   530	[    2.618098] gre: GRE over IPv4 demultiplexor driver
   531	[    2.618107] ip_gre: GRE over IPv4 tunneling driver
   532	[    2.619384] IPv4 over IPsec tunneling driver
   533	[    2.620321] ip_tables: (C) 2000-2006 Netfilter Core Team
   534	[    2.620601] arp_tables: arp_tables: (C) 2002 David S. Miller
   535	[    2.620666] Initializing XFRM netlink socket
   536	[    2.620699] IPsec XFRM device driver
   537	[    2.621546] NET: Registered protocol family 10
   538	[    2.623459] mip6: Mobile IPv6
   539	[    2.623498] ip6_tables: (C) 2000-2006 Netfilter Core Team
   540	[    2.624821] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
   541	[    2.626490] NET: Registered protocol family 17
   542	[    2.626534] NET: Registered protocol family 15
   543	[    2.626691] Bridge firewalling registered
   544	[    2.626840] Bluetooth: RFCOMM TTY layer initialized
   545	[    2.626857] Bluetooth: RFCOMM socket layer initialized
   546	[    2.626892] Bluetooth: RFCOMM ver 1.11
   547	[    2.626906] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
   548	[    2.626911] Bluetooth: BNEP filters: protocol multicast
   549	[    2.626925] Bluetooth: BNEP socket layer initialized
   550	[    2.626930] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
   551	[    2.626942] Bluetooth: HIDP socket layer initialized
   552	[    2.627033] l2tp_core: L2TP core driver, V2.0
   553	[    2.627049] l2tp_ppp: PPPoL2TP kernel driver, V2.0
   554	[    2.627055] 8021q: 802.1Q VLAN Support v1.8
   555	[    2.627255] sctp: Hash tables configured (bind 256/256)
   556	[    2.627867] Key type dns_resolver registered
   557	[    2.628009] Registered cp15_barrier emulation handler
   558	[    2.628022] Registered setend emulation handler
   559	[    2.628972] registered taskstats version 1
   560	[    2.640511] zswap: default zpool zbud not available
   561	[    2.640519] zswap: pool creation failed
   562	[    2.643399] Btrfs loaded, crc32c=crc32c-arm64-hw
   563	[    2.644156] HDMI 2.0 driver init start!
   564	[    2.644170] boot_hdmi=true
   565	[    2.644969] Can not find the node of esm
   566	[    2.644987] ERROR: pinctrl_get for HDMI2.0 DDC fail
   567	[    2.645072] Get hdmi_power0:vcc-hdmi
   568	[    2.645111] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
   569	[    2.645293] Get hdmi_power1:vdd-hdmi
   570	[    2.645315] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
   571	[    2.646873] hdmi_cec_init
   572	[    2.647368] [DISP] disp_device_attached,line:146:
   573	[    2.647377] attached ok, mgr0<-->device0, type=4
   574	[    2.647387] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
   575	[    2.647400] [DISP] disp_hdmi_set_mode,line:648:
   576	[    2.647404] hdmi_set_mode is null!
   577	[    2.650107] HDMI2.0 module init end
   578	[    2.661230] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
   579	[    2.664683] cpu cpu1: opp_list_debug_create_link: Failed to create link
   580	[    2.664695] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
   581	[    2.664726] cpu cpu2: opp_list_debug_create_link: Failed to create link
   582	[    2.664734] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
   583	[    2.664765] cpu cpu3: opp_list_debug_create_link: Failed to create link
   584	[    2.664772] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
   585	[    2.667109] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
   586	[    2.668077] get det_vbus is fail, 84
   587	[    2.668085] get id is fail, 84
   588	[    2.668561] sunxi-rtc rtc: setting system clock to 2023-09-25 13:13:54 UTC (1695647634)
   589	[    2.672307] ALSA device list:
   590	[    2.672316]   #0: audiocodec
   591	[    2.672320]   #1: sndahub
   592	[    2.672323]   #2: sndhdmi
   593	[    2.674011] Freeing unused kernel memory: 3008K
   594	[    2.719116] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   595	[    2.721130] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   596	[    2.724240] random: systemd-udevd: uninitialized urandom read (16 bytes read)
   597	[    2.782715] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
   598	[    2.943236] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
   599	[    3.053189] HDMI cable is connected
   600	[    3.293196] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
   601	[    3.513560] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
   602	[    3.513569] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   603	[    3.513574] usb 4-1: Product: Rapoo 2.4G Wireless Device
   604	[    3.513579] usb 4-1: Manufacturer: RAPOO
   605	[    3.521487] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
   606	[    3.522059] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
   607	[    3.528252] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
   608	[    3.583846] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
   609	[    3.587814] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
   610	[    3.645175] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
   611	[    4.175658] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
   612	[    5.121341] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
   613	[    5.121897] cgroup: cgroup2: unknown option "nsdelegate"
   614	[    5.142231] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
   615	[    5.142255] systemd[1]: Detected architecture arm64.
   616	[    5.143380] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
   617	[    5.160788] systemd[1]: Hostname set to <opi>.
   618	[    5.187977] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
   619	[    6.664171] (sd-execut[1456]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
   620	[    6.826549]
   621	               insmod_device_driver
   622
   623	[    6.826799] device_chose finished 124!
   624	[    7.152531] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
   625	[    7.390712] systemd[1]: Queued start job for default target graphical.target.
   626	[    7.398290] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
   627	[    7.400498] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
   628	[    7.402728] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
   629	[    7.404079] systemd[1]: Created slice user.slice - User and Session Slice.
   630	[    7.404752] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
   631	[    7.405299] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
   632	[    7.405628] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
   633	[    7.406181] systemd[1]: Reached target slices.target - Slice Units.
   634	[    7.406565] systemd[1]: Reached target swap.target - Swaps.
   635	[    7.406884] systemd[1]: Reached target time-set.target - System Time Set.
   636	[    7.407367] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
   637	[    7.424824] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
   638	[    7.425902] systemd[1]: Listening on syslog.socket - Syslog Socket.
   639	[    7.426952] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
   640	[    7.427666] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
   641	[    7.429270] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
   642	[    7.430281] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
   643	[    7.431365] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
   644	[    7.433565] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
   645	[    7.434470] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
   646	[    7.438424] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
   647	[    7.442972] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
   648	[    7.447838] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
   649	[    7.449095] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
   650	[    7.450145] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
   651	[    7.458224] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
   652	[    7.463640] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
   653	[    7.469588] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
   654	[    7.476065] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
   655	[    7.483720] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
   656	[    7.493753] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
   657	[    7.505609] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
   658	[    7.513699] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
   659	[    7.521780] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
   660	[    7.523557] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
   661	[    7.533427] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
   662	[    7.539615] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
   663	[    7.545233] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
   664	[    7.555354] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
   665	[    7.557708] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
   666	[    7.560723] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
   667	[    7.563680] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
   668	[    7.567220] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
   669	[    7.570740] systemd[1]: modprobe@configfs.service: Deactivated successfully.
   670	[    7.571596] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
   671	[    7.574513] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
   672	[    7.575328] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
   673	[    7.575934] fuse init (API version 7.26)
   674	[    7.578913] systemd[1]: modprobe@drm.service: Deactivated successfully.
   675	[    7.579585] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
   676	[    7.584245] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   677	[    7.603909] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
   678	[    7.607255] systemd[1]: modprobe@fuse.service: Deactivated successfully.
   679	[    7.608402] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
   680	[    7.609083] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
   681	[    7.627682] systemd[1]: modprobe@loop.service: Deactivated successfully.
   682	[    7.632223] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
   683	[    7.643261] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
   684	[    7.644042] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
   685	[    7.644053] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
   686	[    7.644258] spidev spi1.1: Deleting spi1.1
   687	[    7.644866] fbtft_device: GPIOS used by 'fb_st7735r':
   688	[    7.644872] fbtft_device: 'reset' = GPIO73
   689	[    7.644876] fbtft_device: 'dc' = GPIO70
   690	[    7.644887] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
   691	[    7.644893] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
   692	[    7.677124] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
   693	[    7.692328] WCN: marlin_init entry!
   694	[    7.693743] WCN: marlin_parse_dt reset gpio=211
   695	[    7.693754] WCN_ERR: gpio reset request err: 211
   696	[    7.693760] WCN: wcn config bt wake host
   697	[    7.694287] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
   698	[    7.694462] WCN: wcn config wifi wake host
   699	[    7.694483] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
   700	[    7.697753] sdiohal:sdiohal_init ok
   701	[    7.698681] WCN: marlin_probe ok!
   702	[    7.707661] mtty_probe init device addr: 0xffffffc009743700
   703	[    7.707871] -->rfkill_bluetooth_init
   704	[    7.708097] <--rfkill_bluetooth_init
   705	[    7.737223] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
   706	[    7.745823] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
   707	[    7.754294] WCN: start_marlin [MARLIN_WIFI]
   708	[    7.754310] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
   709	[    7.754313] WCN: the first power on start
   710	[    7.767251] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
   711	[    7.767919] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
   712	[    7.779068] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
   713	[    7.780247] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
   714	[    7.787054] systemd[1]: Starting systemd-sysusers.service - Create System Users...
   715	[    7.803925] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
   716	[    7.806506] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
   717	[    7.808844] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
   718	[    7.857375] systemd[1]: Finished systemd-sysusers.service - Create System Users.
   719	[    7.863816] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
   720	[    7.869863] WCN: marlin chip en pull up
   721	[    7.896530] sdiohal:sdiohal_scan_card
   722	[    7.896550] sunxi-wlan soc@03000000:wlan: bus_index: 1
   723	[    7.896603] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
   724	[    7.913180] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   725	[    7.933965] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   726	[    7.934818] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
   727	[    7.934866] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   728	[    7.937397] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   729	[    7.940513] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   730	[    7.956522] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
   731	[    7.962872] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
   732	[    7.964962] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
   733	[    7.967564] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
   734	[    7.968346] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
   735	[    7.968438] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
   736	[    7.969151] mmc1: new ultra high speed SDR104 SDIO card at address 8800
   737	[    7.969623] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
   738	[    7.969916] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
   739	[    7.969939] WCN: marlin_scan_finish!
   740	[    7.969944] sdiohal:probe ok
   741	[    7.970002] sdiohal:scan end!
   742	[    7.970010] WCN: then marlin start to download
   743	[    7.970035] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
   744	[    7.970722] systemd[1]: Mounting tmp.mount - /tmp...
   745	[    7.976973] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
   746	[    7.996649] systemd[1]: Mounted tmp.mount - /tmp.
   747	[    7.998972] systemd[1]: Reached target local-fs.target - Local File Systems.
   748	[    8.004304] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
   749	[    8.010521] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
   750	[    8.016247] systemd[1]: Starting console-setup.service - Set console font and keymap...
   751	[    8.022617] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
   752	[    8.035416] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
   753	[    8.041679] systemd[1]: Starting ufw.service - Uncomplicated firewall...
   754	[    8.044570] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
   755	[    8.079969] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
   756	[    8.089589] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
   757	[    8.094069] systemd[1]: Finished console-setup.service - Set console font and keymap.
   758	[    8.099049] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
   759	[    8.102140] systemd[1]: Received SIGRTMIN+20 from PID 1419 (plymouthd).
   760	[    8.106775] systemd[1]: Finished ufw.service - Uncomplicated firewall.
   761	[    8.109875] systemd[1]: Reached target network-pre.target - Preparation for Network.
   762	[    8.120853] WCN: combin_img 0 marlin_firmware_write finish and successful
   763	[    8.121037] WCN: marlin_start_run read reset reg val:0x1
   764	[    8.121041] WCN: after do marlin_start_run reset reg val:0x0
   765	[    8.121252] WCN: s_marlin_bootup_time=8121247426
   766	[    8.126767] WCN: clock mode: TSX
   767	[    8.126963] WCN: marlin_write_cali_data sync init_state:0x1a0f50
   768	[    8.153464] WCN: marlin_write_cali_data sync init_state:0x1a0f50
   769	[    8.180042] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
   770	[    8.180049] WCN: sdio_config bt_wake_host trigger:[high]
   771	[    8.180053] WCN: sdio_config irq:[inband]
   772	[    8.180056] WCN: sdio_config wl_wake_host trigger:[high]
   773	[    8.180060] WCN: sdio_config wake_host_level_duration_time:[20ms]
   774	[    8.180063] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
   775	[    8.180068] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
   776	[    8.180420] WCN: marlin_write_cali_data finish
   777	[    8.180599] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   778	[    8.184298] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
   779	[    8.186570] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
   780	[    8.187145] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
   781	[    8.187683] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
   782	[    8.206808] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   783	[    8.230273] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
   784	[    8.233417] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   785	[    8.260159] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   786	[    8.286681] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
   787	[    8.313421] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
   788	[    8.313431] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
   789	[    8.313451] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
   790	[    8.313993] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
   791	[    8.340033] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
   792	[    8.340041] sdiohal:sdiohal_runtime_get entry
   793	[    8.340206] WCN: get_cp2_version entry!
   794	[    8.342041] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
   795	[    8.342164] WCN: switch_cp2_log - close entry!
   796	[    8.343330] WCN: WCND at cmd read:OK
   797	[    8.343500] WCN: then marlin download finished and run ok
   798	[    8.343507] WCN: start_loopcheck
   799	[    8.358103] WCN: get_board_ant_num [one_ant]
   800	[    8.358115] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
   801	[    8.419895] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
   802	[    8.425761] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
   803	[    8.432774] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
   804	[    8.478091] zram: Added device: zram0
   805	[    8.479072] zram: Added device: zram1
   806	[    8.480095] zram: Added device: zram2
   807	[    8.515448] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
   808	[    8.516740] zswap: can't enable, initialization failed
   809	[    8.523294] systemd[1]: Starting networking.service - Raise network interfaces...
   810	[    8.550425] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
   811	[    8.575402] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
   812	[    8.583681] zram0: detected capacity change from 0 to 506396672
   813	[    8.643939] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
   814	[    8.684828] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
   815	[    8.687032] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
   816	[    8.688075] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
   817	[    8.690095] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
   818	[    9.171003] systemd[1]: Finished networking.service - Raise network interfaces.
   819	[    9.972783] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
   820	[   10.065081] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
   821	[   10.280879] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
   822	[   10.699203] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
   823	[   10.709665] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
   824	[   10.771758] sunxi-bt soc@03000000:bt: set block: 0
   825	[   10.791280] bluetooth_set_power: start_block=0
   826	[   10.791289] WCN: start_marlin [MARLIN_BLUETOOTH]
   827	[   10.791298] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
   828	[   10.791302] WCN: marlin have open, GNSS is closed
   829	[   10.791308] bluetooth_set_power: end_block=0
   830	[   10.801157] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
   831	[   11.015993] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
   832	[   11.035604] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
   833	[   11.035729] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
   834	[   11.036178] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
   835	[   11.052983] systemd[1]: Starting brltty.service - Braille Device Support...
   836	[   11.058965] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
   837	[   11.065165] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
   838	[   11.071992] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
   839	[   11.078964] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
   840	[   11.088671] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
   841	[   11.089344] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
   842	[   11.092894] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
   843	[   11.093819] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
   844	[   11.096164] systemd[1]: modprobe@loop.service: Deactivated successfully.
   845	[   11.096864] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
   846	[   11.098548] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
   847	[   11.098734] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
   848	[   11.150318] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
   849	[   11.150966] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
   850	[   11.151697] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
   851	[   11.624444] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
   852	[   11.768801] zram1: detected capacity change from 0 to 52428800
   853	[   11.824933] systemd[1]: Started brltty.service - Braille Device Support.
   854	[   11.844101] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
   855	[   15.812101] systemd[1]: systemd-rfkill.service: Deactivated successfully.
   856	[   15.870180] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
   857	[   15.876418] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
   858	[   15.938006] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
   859	[   19.478345] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
   860	[   19.484761] systemd[1]: Starting systemd-journald.service - Journal Service...
   861	[   19.754529] systemd-journald[1924]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
   862	[   19.754550] systemd-journald[1924]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
   863	[   19.761899] systemd[1]: Started systemd-journald.service - Journal Service.
   864	[   19.808239] systemd-journald[1924]: Received client request to flush runtime journal.
   865	[   20.043035] IPVS: Creating netns size=1928 id=1
   866
   867	### armbian-release:
   868
   869	# PLEASE DO NOT EDIT THIS FILE
   870	BOARD=orangepizero2
   871	BOARD_NAME="Orange Pi Zero2"
   872	BOARDFAMILY=sun50iw9
   873	BUILD_REPOSITORY_URL=https://github.com/armbian/build
   874	BUILD_REPOSITORY_COMMIT=ac829eb6
   875	LINUXFAMILY=sun50iw9
   876	ARCH=arm64
   877	IMAGE_TYPE=stable
   878	BOARD_TYPE=conf
   879	INITRD_ARCH=arm
   880	KERNEL_IMAGE_TYPE=Image
   881	FORCE_BOOTSCRIPT_UPDATE=yes
   882	VENDOR=Armbian
   883	BOOTSCRIPT_FORCE_UPDATE="yes"
   884	BOOTSCRIPT_DST="boot.cmd"
   885	VERSION=23.8.1
   886	REVISION=23.8.1
   887	BRANCH=legacy
   888
   889	### boot environment:
   890
   891	verbosity=1
   892	console=serial
   893	#disp_mode=1080p60
   894	#fb0_width=1280
   895	#fb0_height=720
   896	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
   897	rootfstype=ext4
   898	overlays=spi-spidev
   899	param_spidev_spi_bus=1
   900	param_spidev_spi_cs=1
   901	extraargs=fbcon=map:1
   902	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
   903
   904	### lsusb:
   905
   906	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   907	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   908	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   909	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   910	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
   911	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   912	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   913
   914	### lscpu:
   915
   916	Architecture:        aarch64
   917	CPU op-mode(s):      32-bit, 64-bit
   918	Byte Order:          Little Endian
   919	CPU(s):              4
   920	On-line CPU(s) list: 0-3
   921	Vendor ID:           ARM
   922	Model name:          Cortex-A53
   923	Model:               4
   924	Thread(s) per core:  1
   925	Core(s) per cluster: 4
   926	Socket(s):           -
   927	Cluster(s):          1
   928	Stepping:            r0p4
   929	CPU(s) scaling MHz:  100%
   930	CPU max MHz:         1512.0000
   931	CPU min MHz:         480.0000
   932	BogoMIPS:            48.00
   933	Flags:               fp asimd aes pmull sha1 sha2 crc32
   934
   935	### cpuinfo:
   936
   937	processor	: 0
   938	BogoMIPS	: 48.00
   939	Features	: fp asimd aes pmull sha1 sha2 crc32
   940	CPU implementer	: 0x41
   941	CPU architecture: 8
   942	CPU variant	: 0x0
   943	CPU part	: 0xd03
   944	CPU revision	: 4
   945
   946	processor	: 1
   947	BogoMIPS	: 48.00
   948	Features	: fp asimd aes pmull sha1 sha2 crc32
   949	CPU implementer	: 0x41
   950	CPU architecture: 8
   951	CPU variant	: 0x0
   952	CPU part	: 0xd03
   953	CPU revision	: 4
   954
   955	processor	: 2
   956	BogoMIPS	: 48.00
   957	Features	: fp asimd aes pmull sha1 sha2 crc32
   958	CPU implementer	: 0x41
   959	CPU architecture: 8
   960	CPU variant	: 0x0
   961	CPU part	: 0xd03
   962	CPU revision	: 4
   963
   964	processor	: 3
   965	BogoMIPS	: 48.00
   966	Features	: fp asimd aes pmull sha1 sha2 crc32
   967	CPU implementer	: 0x41
   968	CPU architecture: 8
   969	CPU variant	: 0x0
   970	CPU part	: 0xd03
   971	CPU revision	: 4
   972
   973
   974	### meminfo:
   975
   976	MemTotal:         989056 kB
   977	MemFree:          798616 kB
   978	MemAvailable:     885636 kB
   979	Buffers:           15588 kB
   980	Cached:            78536 kB
   981	SwapCached:            0 kB
   982	Active:            65408 kB
   983	Inactive:          49780 kB
   984	Active(anon):      21248 kB
   985	Inactive(anon):      656 kB
   986	Active(file):      44160 kB
   987	Inactive(file):    49124 kB
   988	Unevictable:           0 kB
   989	Mlocked:               0 kB
   990	SwapTotal:        494524 kB
   991	SwapFree:         494524 kB
   992	Dirty:              2748 kB
   993	Writeback:             0 kB
   994	AnonPages:         21120 kB
   995	Mapped:            24344 kB
   996	Shmem:               828 kB
   997	Slab:              32928 kB
   998	SReclaimable:       9116 kB
   999	SUnreclaim:        23812 kB
  1000	KernelStack:        2560 kB
  1001	PageTables:         1056 kB
  1002	NFS_Unstable:          0 kB
  1003	Bounce:                0 kB
  1004	WritebackTmp:          0 kB
  1005	CommitLimit:      989052 kB
  1006	Committed_AS:      79260 kB
  1007	VmallocTotal:   263061440 kB
  1008	VmallocUsed:           0 kB
  1009	VmallocChunk:          0 kB
  1010	CmaTotal:          16384 kB
  1011	CmaFree:            7468 kB
  1012	HugePages_Total:       0
  1013	HugePages_Free:        0
  1014	HugePages_Rsvd:        0
  1015	HugePages_Surp:        0
  1016	Hugepagesize:       2048 kB
  1017
  1018	### virtual memory:
  1019
  1020	vm.admin_reserve_kbytes = 8192
  1021	vm.block_dump = 0
  1022	vm.compact_unevictable_allowed = 1
  1023	vm.dirty_background_bytes = 0
  1024	vm.dirty_background_ratio = 10
  1025	vm.dirty_bytes = 0
  1026	vm.dirty_expire_centisecs = 3000
  1027	vm.dirty_ratio = 20
  1028	vm.dirtytime_expire_seconds = 43200
  1029	vm.dirty_writeback_centisecs = 500
  1030	vm.extfrag_threshold = 500
  1031	vm.extra_free_kbytes = 0
  1032	vm.hugepages_treat_as_movable = 0
  1033	vm.hugetlb_shm_group = 0
  1034	vm.laptop_mode = 0
  1035	vm.legacy_va_layout = 0
  1036	vm.lowmem_reserve_ratio = 256	32
  1037	vm.max_map_count = 65530
  1038	vm.min_free_kbytes = 3937
  1039	vm.mmap_min_addr = 4096
  1040	vm.mmap_rnd_bits = 18
  1041	vm.mmap_rnd_compat_bits = 11
  1042	vm.nr_hugepages = 0
  1043	vm.nr_overcommit_hugepages = 0
  1044	vm.nr_pdflush_threads = 0
  1045	vm.oom_dump_tasks = 1
  1046	vm.oom_kill_allocating_task = 0
  1047	vm.overcommit_kbytes = 0
  1048	vm.overcommit_memory = 0
  1049	vm.overcommit_ratio = 50
  1050	vm.page-cluster = 0
  1051	vm.panic_on_oom = 0
  1052	vm.percpu_pagelist_fraction = 0
  1053	vm.stat_interval = 1
  1054	vm.swappiness = 100
  1055	vm.user_reserve_kbytes = 30004
  1056	vm.vfs_cache_pressure = 100
  1057	vm.watermark_scale_factor = 10
  1058
  1059	### ip addr:
  1060
  1061	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  1062	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  1063	    inet XXX.XXX.0.1/8 scope host lo
  1064	       valid_lft forever preferred_lft forever
  1065	    inet6 ::1/128 scope host noprefixroute
  1066	       valid_lft forever preferred_lft forever
  1067	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1068	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  1069	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1070	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  1071	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  1072	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  1073	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  1074	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  1075	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  1076	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  1077	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  1078	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  1079	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  1080	    link/tunnel6 :: brd ::
  1081	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  1082	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  1083	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  1084	    link/tunnel6 :: brd ::
  1085	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  1086	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  1087
  1088	### partitions:
  1089
  1090	major minor  #blocks  name
  1091
  1092	 179        0   62410752 mmcblk0
  1093	 179        1   61763584 mmcblk0p1
  1094	 253        0     494528 zram0
  1095	 253        1      51200 zram1
  1096
  1097	### df:
  1098
  1099	udev            466M     0  466M   0% /dev
  1100	tmpfs            97M  2.1M   95M   3% /run
  1101	/dev/mmcblk0p1   58G  5.7G   52G  10% /
  1102	tmpfs           483M     0  483M   0% /dev/shm
  1103	tmpfs           5.0M     0  5.0M   0% /run/lock
  1104	tmpfs           483M  4.0K  483M   1% /tmp
  1105	/dev/zram1       47M  2.4M   41M   6% /var/log
  1106
  1107	### lsblk:
  1108
  1109	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  1110	mmcblk0             59.5G
  1111	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  1112	zram1                 50M /var/log
  1113	zram2                  0B
  1114
  1115	### zramctl:
  1116
  1117	NAME       ALGORITHM DISKSIZE  DATA  COMPR TOTAL STREAMS MOUNTPOINT
  1118	/dev/zram1 lz4            50M  2.4M 565.1K  932K       4 /var/log
  1119	/dev/zram0 lzo         482.9M    4K    76B   12K       4 [SWAP]
  1120
  1121	### mtab:
  1122
  1123	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1124	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  1125	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  1126
  1127	### mmc0:0001 info:
  1128
  1129	              manfid: 0x0000fe
  1130	                 cid: fe3432534431364720000000690091f5
  1131	               fwrev: 0x0
  1132	                 csd: 400e00325b590001dc277f800a40008b
  1133	                 ocr: 0x00200000
  1134	                type: SD
  1135	                date: 01/2009
  1136	               hwrev: 0x2
  1137	                 dsr: 0x404
  1138	              serial: 0x00000069
  1139	          erase_size: 512
  1140	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  1141	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1142	                 scr: 0285808300000000
  1143	               oemid: 0x3432
  1144	preferred_erase_size: 4194304
  1145	                name: SD16G
  1146
  1147	### Boot system health:
  1148
  1149	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  1150	10:14:14  1512 MHz  1.17  39%  19%  13%   0%   6%   0%  50.0 °C  0/5
  1151	10:14:14  1512 MHz  1.17  94%  31%  28%   0%  34%   0%  47.9 °C  0/5
  1152	10:14:15  1512 MHz  1.17 100%  29%  55%   1%  14%   0%  47.9 °C  0/5
  1153	10:14:15  1512 MHz  1.17  99%  32%  59%   1%   6%   0%  50.0 °C  0/5
  1154	10:14:15  1512 MHz  1.17  96%  31%  34%   1%  29%   0%  50.0 °C  0/5
  1155
  1156	### Activated 1 lzo zram swap devices with 482MB each.
  1157	### Activated Armbian ramlog partition with lz4 compression
  1158
  1159	Mon Sep 25 11:53:07 AM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  1160
  1161	### dmesg:
  1162
  1163	[    0.000000] Booting Linux on physical CPU 0x0
  1164	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  1165	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  1166	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  1167	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  1168	[    0.000000] On node 0 totalpages: 262144
  1169	[    0.000000]   DMA zone: 4096 pages used for memmap
  1170	[    0.000000]   DMA zone: 0 pages reserved
  1171	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  1172	[    0.000000] psci: probing for conduit method from DT.
  1173	[    0.000000] psci: PSCIv1.0 detected in firmware.
  1174	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  1175	[    0.000000] psci: Trusted OS migration not required
  1176	[    0.000000] psci: SMC Calling Convention v1.0
  1177	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  1178	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  1179	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  1180	[    0.000000] Detected VIPT I-cache on CPU0
  1181	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  1182	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  1183	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  1184	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  1185	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  1186	[    0.000000] log_buf_len min size: 131072 bytes
  1187	[    0.000000] log_buf_len: 524288 bytes
  1188	[    0.000000] early log buf free: 129352(98%)
  1189	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  1190	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  1191	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  1192	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  1193	[    0.000000] Virtual kernel memory layout:
  1194	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  1195	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  1196	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  1197	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  1198	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  1199	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  1200	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  1201	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  1202	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  1203	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  1204	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  1205	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  1206	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  1207	[    0.000000] Preemptible hierarchical RCU implementation.
  1208	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  1209	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  1210	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  1211	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  1212	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  1213	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  1214	[    0.000213] Console: colour dummy device 80x25
  1215	[    0.000228] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  1216	[    0.000237] pid_max: default: 32768 minimum: 301
  1217	[    0.000434] Security Framework initialized
  1218	[    0.000442] AppArmor: AppArmor disabled by boot time parameter
  1219	[    0.000561] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  1220	[    0.000567] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  1221	[    0.001842] sched-energy: CPU device node has no sched-energy-costs
  1222	[    0.001857] Invalid sched_group_energy for CPU0
  1223	[    0.001864] CPU0: update cpu_capacity 1024
  1224	[    0.008938] ASID allocator initialised with 32768 entries
  1225	[    0.027948] BOOTEVENT:        27.933457: ON
  1226	[    0.055888] Detected VIPT I-cache on CPU1
  1227	[    0.055944] Invalid sched_group_energy for CPU1
  1228	[    0.055947] CPU1: update cpu_capacity 1024
  1229	[    0.055951] CPU1: Booted secondary processor [410fd034]
  1230	[    0.079275] Detected VIPT I-cache on CPU2
  1231	[    0.079313] Invalid sched_group_energy for CPU2
  1232	[    0.079316] CPU2: update cpu_capacity 1024
  1233	[    0.079319] CPU2: Booted secondary processor [410fd034]
  1234	[    0.102675] Detected VIPT I-cache on CPU3
  1235	[    0.102708] Invalid sched_group_energy for CPU3
  1236	[    0.102711] CPU3: update cpu_capacity 1024
  1237	[    0.102714] CPU3: Booted secondary processor [410fd034]
  1238	[    0.102794] Brought up 4 CPUs
  1239	[    0.102802] SMP: Total of 4 processors activated.
  1240	[    0.102810] CPU features: detected feature: 32-bit EL0 Support
  1241	[    0.102816] CPU features: detected feature: Kernel page table isolation (KPTI)
  1242	[    0.106583] CPU: All CPU(s) started at EL1
  1243	[    0.106605] alternatives: patching kernel code
  1244	[    0.106777] Invalid sched_group_energy for CPU3
  1245	[    0.106787] CPU3: update max cpu_capacity 1024
  1246	[    0.106792] Invalid sched_group_energy for Cluster3
  1247	[    0.106797] Invalid sched_group_energy for CPU2
  1248	[    0.106803] Invalid sched_group_energy for Cluster2
  1249	[    0.106807] Invalid sched_group_energy for CPU1
  1250	[    0.106813] Invalid sched_group_energy for Cluster1
  1251	[    0.106818] Invalid sched_group_energy for CPU0
  1252	[    0.106823] Invalid sched_group_energy for Cluster0
  1253	[    0.108245] devtmpfs: initialized
  1254	[    0.112692] CPU1: update max cpu_capacity 1024
  1255	[    0.143351] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  1256	[    0.143380] futex hash table entries: 1024 (order: 5, 131072 bytes)
  1257	[    0.144036] xor: measuring software checksum speed
  1258	[    0.176245]    8regs     :  1933.200 MB/sec
  1259	[    0.209624]    8regs_prefetch:  1720.800 MB/sec
  1260	[    0.243010]    32regs    :  2287.200 MB/sec
  1261	[    0.276398]    32regs_prefetch:  1935.600 MB/sec
  1262	[    0.276403] xor: using function: 32regs (2287.200 MB/sec)
  1263	[    0.276463] atomic64_test: passed
  1264	[    0.276469] pinctrl core: initialized pinctrl subsystem
  1265	[    0.277635] NET: Registered protocol family 16
  1266	[    0.278886] dump_class_init,861, success
  1267	[    0.296463] cpuidle: using governor menu
  1268	[    0.297922] sunxi iommu: irq = 8
  1269	[    0.298242] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  1270	[    0.298259] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  1271	[    0.299679] DMA: preallocated 256 KiB pool for atomic allocations
  1272	[    0.301067] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  1273	[    0.315448] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  1274	[    0.319394] iommu: Adding device 1c0e000.ve to group 0
  1275	[    0.319896] iommu: Adding device 1c00000.vp9 to group 0
  1276	[    0.331325] iommu: Adding device 1000000.disp to group 0
  1277	[    0.332744] iommu: Adding device 1480000.g2d to group 0
  1278	[    0.335961] iommu: Adding device csi0 to group 0
  1279	[    0.336420] iommu: Adding device csi1 to group 0
  1280	[    0.337642] iommu: Adding device 6600800.vind:scaler@0 to group 0
  1281	[    0.337941] iommu: Adding device 6600800.vind:scaler@1 to group 0
  1282	[    0.338242] iommu: Adding device 6600800.vind:scaler@2 to group 0
  1283	[    0.338532] iommu: Adding device 6600800.vind:scaler@3 to group 0
  1284	[    0.338818] iommu: Adding device 6600800.vind:scaler@4 to group 0
  1285	[    0.339122] iommu: Adding device 6600800.vind:scaler@5 to group 0
  1286	[    0.340053] iommu: Adding device vinc0 to group 0
  1287	[    0.340603] iommu: Adding device vinc1 to group 0
  1288	[    0.342058] iommu: Adding device 1420000.deinterlace to group 0
  1289	[    0.384529] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  1290	[    0.440807] raid6: int64x1  gen()   392 MB/s
  1291	[    0.497436] raid6: int64x1  xor()   362 MB/s
  1292	[    0.554273] raid6: int64x2  gen()   591 MB/s
  1293	[    0.611040] raid6: int64x2  xor()   512 MB/s
  1294	[    0.667771] raid6: int64x4  gen()   840 MB/s
  1295	[    0.724552] raid6: int64x4  xor()   629 MB/s
  1296	[    0.781384] raid6: int64x8  gen()   965 MB/s
  1297	[    0.838120] raid6: int64x8  xor()   655 MB/s
  1298	[    0.894922] raid6: neonx1   gen()   648 MB/s
  1299	[    0.951679] raid6: neonx1   xor()   641 MB/s
  1300	[    1.008469] raid6: neonx2   gen()   976 MB/s
  1301	[    1.065251] raid6: neonx2   xor()   819 MB/s
  1302	[    1.122039] raid6: neonx4   gen()  1287 MB/s
  1303	[    1.178809] raid6: neonx4   xor()   966 MB/s
  1304	[    1.235591] raid6: neonx8   gen()  1324 MB/s
  1305	[    1.292359] raid6: neonx8   xor()   991 MB/s
  1306	[    1.292365] raid6: using algorithm neonx8 gen() 1324 MB/s
  1307	[    1.292370] raid6: .... xor() 991 MB/s, rmw enabled
  1308	[    1.292375] raid6: using intx1 recovery algorithm
  1309	[    1.292510] pwm module init!
  1310	[    1.296809] sunxi-pm debug v3.10
  1311	[    1.297909] SCSI subsystem initialized
  1312	[    1.298536] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  1313	[    1.298618] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  1314	[    1.298739] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  1315	[    1.299257] spi spi0: master is unqueued, this is deprecated
  1316	[    1.299566] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  1317	[    1.300133] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  1318	[    1.300213] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  1319	[    1.300329] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  1320	[    1.300793] spi spi1: master is unqueued, this is deprecated
  1321	[    1.301098] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  1322	[    1.301944] usbcore: registered new interface driver usbfs
  1323	[    1.302032] usbcore: registered new interface driver hub
  1324	[    1.302103] usbcore: registered new device driver usb
  1325	[    1.302262] sunxi_i2c_adap_init()2522 - init
  1326	[    1.302818] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  1327	[    1.302909] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  1328	[    1.302917] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  1329	[    1.302932] twi3 supply twi not found, using dummy regulator
  1330	[    1.303008] twi_request_gpio()451 - [i2c3] init name: twi3
  1331	[    1.303783] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  1332	[    1.303866] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  1333	[    1.303873] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  1334	[    1.303887] twi5 supply twi not found, using dummy regulator
  1335	[    1.303965] twi_request_gpio()451 - [i2c5] init name: twi5
  1336	[    1.304443] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  1337	[    1.323141] random: fast init done
  1338	[    1.334361] axp20x-i2c 5-0036: AXP20X driver loaded
  1339	[    1.334857] media: Linux media interface: v0.10
  1340	[    1.334941] Linux video capture interface: v2.00
  1341	[    1.335668] Advanced Linux Sound Architecture Driver Initialized.
  1342	[    1.336426] Bluetooth: Core ver 2.22
  1343	[    1.336493] NET: Registered protocol family 31
  1344	[    1.336499] Bluetooth: HCI device and connection manager initialized
  1345	[    1.336516] Bluetooth: HCI socket layer initialized
  1346	[    1.336528] Bluetooth: L2CAP socket layer initialized
  1347	[    1.336566] Bluetooth: SCO socket layer initialized
  1348	[    1.337339] [DISP]disp_module_init
  1349	[    1.338520] [DISP] parser_disp_init_para,line:1403:
  1350	[    1.338529] of_property_read fb0_width fail
  1351	[    1.338541] [DISP] disp_init,line:2215:
  1352	[    1.338546] smooth display screen:0 type:4 mode:10
  1353	[    1.355947] [DISP]disp_module_init finish
  1354	[    1.356888] clocksource: Switched to clocksource arch_sys_counter
  1355	[    1.357129] VFS: Disk quotas dquot_6.6.0
  1356	[    1.357217] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  1357	[    1.357965] Console: switching to colour frame buffer device 240x67
  1358	[    1.401241] NET: Registered protocol family 2
  1359	[    1.401365] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  1360	[    1.417139] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  1361	[    1.417212] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  1362	[    1.417336] TCP: Hash tables configured (established 8192 bind 8192)
  1363	[    1.417423] UDP hash table entries: 512 (order: 2, 16384 bytes)
  1364	[    1.417451] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  1365	[    1.417772] NET: Registered protocol family 1
  1366	[    1.418326] RPC: Registered named UNIX socket transport module.
  1367	[    1.418331] RPC: Registered udp transport module.
  1368	[    1.418336] RPC: Registered tcp transport module.
  1369	[    1.418339] RPC: Registered tcp NFSv4.1 backchannel transport module.
  1370	[    1.418579] Trying to unpack rootfs image as initramfs...
  1371	[    2.172813] Freeing initrd memory: 17256K
  1372	[    2.173902] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  1373	[    2.177824] audit: initializing netlink subsys (disabled)
  1374	[    2.177911] audit: type=2000 audit(2.173:1): initialized
  1375	[    2.178866] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  1376	[    2.190066] DLM installed
  1377	[    2.191956] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  1378	[    2.192295] Registering sdcardfs 0.1
  1379	[    2.192766] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  1380	[    2.194332] ntfs: driver 2.1.32 [Flags: R/W].
  1381	[    2.201080] NET: Registered protocol family 38
  1382	[    2.201448] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  1383	[    2.201597] io scheduler noop registered
  1384	[    2.201605] io scheduler deadline registered
  1385	[    2.201769] io scheduler cfq registered (default)
  1386	[    2.203715] failed to get easy_light_used assign
  1387	[    2.203726] failed to get normal led pin assign
  1388	[    2.203731] failed to get standby led pin assign
  1389	[    2.203736] failed to get standby led pin assign
  1390	[    2.203742] these is zero number for gpio
  1391	[    2.203746] gpio_init finish with uesd
  1392	[    2.206782] uart uart0: get regulator failed
  1393	[    2.207027] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  1394	[    2.207051] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  1395	[    2.207127] console [ttyS0] enabled
  1396	[    2.207945] uart uart1: get regulator failed
  1397	[    2.208135] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  1398	[    2.208892] uart uart5: get regulator failed
  1399	[    2.209082] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  1400	[    2.210652] misc dump reg init
  1401	[    2.211842] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  1402	[    2.212179] Unable to detect cache hierarchy for CPU 0
  1403	[    2.226192] brd: module loaded
  1404	[    2.234375] loop: module loaded
  1405	[    2.234564] [NAND][NE] Not found valid nand node on dts
  1406	[    2.235154] Get boot type cmd line fail
  1407	[    2.235732] sunxi-bt soc@03000000:bt: Missing bt_power.
  1408	[    2.235742] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  1409	[    2.235749] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  1410	[    2.235756] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  1411	[    2.235812] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  1412	[    2.235884] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  1413	[    2.236710] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  1414	[    2.236721] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  1415	[    2.236728] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  1416	[    2.236736] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  1417	[    2.236743] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  1418	[    2.236772] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  1419	[    2.236806] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  1420	[    2.236814] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  1421	[    2.236832] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  1422	[    2.237851] [ADDR_MGT] addr_mgt_probe: success.
  1423	[    2.244289] tun: Universal TUN/TAP device driver, 1.6
  1424	[    2.244298] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  1425	[    2.246294] gmac-power0: NULL
  1426	[    2.246303] gmac-power1: NULL
  1427	[    2.246310] gmac-power2: NULL
  1428	[    2.247346] PPP generic driver version 2.4.2
  1429	[    2.247633] PPP BSD Compression module registered
  1430	[    2.247643] PPP Deflate Compression module registered
  1431	[    2.247670] PPP MPPE Compression module registered
  1432	[    2.247679] NET: Registered protocol family 24
  1433	[    2.247712] PPTP driver version 0.8.5
  1434	[    2.248074] usbcore: registered new interface driver r8152
  1435	[    2.248149] usbcore: registered new interface driver asix
  1436	[    2.248259] usbcore: registered new interface driver ax88179_178a
  1437	[    2.248326] usbcore: registered new interface driver cdc_ether
  1438	[    2.248388] usbcore: registered new interface driver net1080
  1439	[    2.248447] usbcore: registered new interface driver cdc_subset
  1440	[    2.248510] usbcore: registered new interface driver zaurus
  1441	[    2.248604] usbcore: registered new interface driver cdc_ncm
  1442	[    2.248611] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  1443	[    2.248973] get drv_vbus is fail, 84
  1444	[    2.248982] get ehci0-controller, regulator_io is no nocare
  1445	[    2.249246] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  1446	[    2.249252] [sunxi-ehci0]: Not init ehci0
  1447	[    2.249365] get ehci1-controller, regulator_io is no nocare
  1448	[    2.249538] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  1449	[    2.249595] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1450	[    2.249622] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  1451	[    2.250274] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  1452	[    2.263582] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  1453	[    2.263843] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  1454	[    2.263852] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1455	[    2.263860] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1456	[    2.263867] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  1457	[    2.263874] usb usb1: SerialNumber: sunxi-ehci
  1458	[    2.264739] hub 1-0:1.0: USB hub found
  1459	[    2.264787] hub 1-0:1.0: 1 port detected
  1460	[    2.265472] get drv_vbus is fail, 84
  1461	[    2.265480] get ehci2-controller, regulator_io is no nocare
  1462	[    2.265725] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  1463	[    2.265777] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1464	[    2.265802] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  1465	[    2.266086] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  1466	[    2.276904] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  1467	[    2.277135] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  1468	[    2.277144] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1469	[    2.277152] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1470	[    2.277159] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  1471	[    2.277165] usb usb2: SerialNumber: sunxi-ehci
  1472	[    2.278004] hub 2-0:1.0: USB hub found
  1473	[    2.278047] hub 2-0:1.0: 1 port detected
  1474	[    2.278715] get drv_vbus is fail, 84
  1475	[    2.278723] get ehci3-controller, regulator_io is no nocare
  1476	[    2.278968] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  1477	[    2.279019] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1478	[    2.279044] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  1479	[    2.279340] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  1480	[    2.290234] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  1481	[    2.290420] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  1482	[    2.290429] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1483	[    2.290436] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  1484	[    2.290444] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  1485	[    2.290450] usb usb3: SerialNumber: sunxi-ehci
  1486	[    2.291318] hub 3-0:1.0: USB hub found
  1487	[    2.291367] hub 3-0:1.0: 1 port detected
  1488	[    2.292292] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  1489	[    2.292658] get drv_vbus is fail, 84
  1490	[    2.292666] get ohci0-controller, regulator_io is no nocare
  1491	[    2.293007] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  1492	[    2.293013] [sunxi-ohci0]: Not init ohci0
  1493	[    2.293128] get ohci1-controller, regulator_io is no nocare
  1494	[    2.293289] hci: request ohci1-controller gpio:80
  1495	[    2.293363] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  1496	[    2.293413] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1497	[    2.293439] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  1498	[    2.293518] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  1499	[    2.354426] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  1500	[    2.354438] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1501	[    2.354445] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1502	[    2.354452] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  1503	[    2.354459] usb usb4: SerialNumber: sunxi-ohci
  1504	[    2.355317] hub 4-0:1.0: USB hub found
  1505	[    2.355364] hub 4-0:1.0: 1 port detected
  1506	[    2.356047] get drv_vbus is fail, 84
  1507	[    2.356055] get ohci2-controller, regulator_io is no nocare
  1508	[    2.356390] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  1509	[    2.356438] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1510	[    2.356464] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  1511	[    2.356541] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  1512	[    2.414401] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  1513	[    2.414412] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1514	[    2.414420] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1515	[    2.414427] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  1516	[    2.414434] usb usb5: SerialNumber: sunxi-ohci
  1517	[    2.415308] hub 5-0:1.0: USB hub found
  1518	[    2.415355] hub 5-0:1.0: 1 port detected
  1519	[    2.416037] get drv_vbus is fail, 84
  1520	[    2.416046] get ohci3-controller, regulator_io is no nocare
  1521	[    2.416372] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  1522	[    2.416422] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1523	[    2.416452] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  1524	[    2.416529] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  1525	[    2.474400] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  1526	[    2.474410] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  1527	[    2.474418] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  1528	[    2.474425] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  1529	[    2.474432] usb usb6: SerialNumber: sunxi-ohci
  1530	[    2.475298] hub 6-0:1.0: USB hub found
  1531	[    2.475343] hub 6-0:1.0: 1 port detected
  1532	[    2.476263] ohci-platform: OHCI generic platform driver
  1533	[    2.477022] usbcore: registered new interface driver uas
  1534	[    2.477190] usbcore: registered new interface driver usb-storage
  1535	[    2.477275] usbcore: registered new interface driver ums-alauda
  1536	[    2.477351] usbcore: registered new interface driver ums-cypress
  1537	[    2.477424] usbcore: registered new interface driver ums-datafab
  1538	[    2.477496] usbcore: registered new interface driver ums_eneub6250
  1539	[    2.477573] usbcore: registered new interface driver ums-freecom
  1540	[    2.477650] usbcore: registered new interface driver ums-isd200
  1541	[    2.477721] usbcore: registered new interface driver ums-jumpshot
  1542	[    2.477792] usbcore: registered new interface driver ums-karma
  1543	[    2.477869] usbcore: registered new interface driver ums-onetouch
  1544	[    2.477958] usbcore: registered new interface driver ums-realtek
  1545	[    2.478037] usbcore: registered new interface driver ums-sddr09
  1546	[    2.478108] usbcore: registered new interface driver ums-sddr55
  1547	[    2.478191] usbcore: registered new interface driver ums-usbat
  1548	[    2.478340] usb_serial_number:20080411
  1549	[    2.479564] input: sunxi-keyboard as /devices/virtual/input/input0
  1550	[    2.480203] usbcore: registered new interface driver xpad
  1551	[    2.480364] usbcore: registered new interface driver usb_acecad
  1552	[    2.480452] usbcore: registered new interface driver aiptek
  1553	[    2.480528] usbcore: registered new interface driver gtco
  1554	[    2.480605] usbcore: registered new interface driver hanwang
  1555	[    2.480693] usbcore: registered new interface driver kbtab
  1556	[    2.481153] axp2101_pek: axp2101-pek can not register without irq
  1557	[    2.481176] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  1558	[    2.482643] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  1559	[    2.482710] sunxi-rtc rtc: RTC enabled
  1560	[    2.483183] i2c /dev entries driver
  1561	[    2.484007] lirc_dev: IR Remote Control driver registered, major 244
  1562	[    2.484018] IR NEC protocol handler initialized
  1563	[    2.484025] IR RC5(x/sz) protocol handler initialized
  1564	[    2.484030] IR RC6 protocol handler initialized
  1565	[    2.484036] IR JVC protocol handler initialized
  1566	[    2.484041] IR Sony protocol handler initialized
  1567	[    2.484047] IR SANYO protocol handler initialized
  1568	[    2.484053] IR Sharp protocol handler initialized
  1569	[    2.484059] IR MCE Keyboard/mouse protocol handler initialized
  1570	[    2.484064] IR LIRC bridge handler initialized
  1571	[    2.484070] IR XMP protocol handler initialized
  1572	[    2.484595] sunxi_ir_startup: get ir protocol failed
  1573	[    2.484637] 7040000.s_cir supply ir0 not found, using dummy regulator
  1574	[    2.484818] Registered IR keymap rc_map_sunxi
  1575	[    2.485206] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  1576	[    2.485444] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  1577	[    2.486430] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  1578	[    2.487074] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  1579	[    2.487772] sunxi cedar version 0.1
  1580	[    2.487968] VE: install start!!!
  1581
  1582	[    2.488154] cedar_ve: cedar-ve the get irq is 278
  1583	[    2.488790] VE: get debugfs_mpp_root is NULL, please check mpp
  1584
  1585	[    2.488807] VE: sunxi ve debug register driver failed!
  1586
  1587	[    2.492026] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  1588	[    2.493331] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  1589	[    2.493695] Bluetooth: HCI UART driver ver 2.3
  1590	[    2.493706] Bluetooth: HCI UART protocol H4 registered
  1591	[    2.493712] Bluetooth: HCI UART protocol LL registered
  1592	[    2.493718] Bluetooth: HCI UART protocol Three-wire (H5) registered
  1593	[    2.498055] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  1594	[    2.498079] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  1595	[    2.498099] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  1596	[    2.498122] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  1597	[    2.498140] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  1598	[    2.498152] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  1599	[    2.498522] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  1600	[    2.498625] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  1601	[    2.498822] sunxi-mmc sdc0: No vmmc regulator found
  1602	[    2.498829] sunxi-mmc sdc0: No vqmmc regulator found
  1603	[    2.498836] sunxi-mmc sdc0: No vdmmc regulator found
  1604	[    2.498842] sunxi-mmc sdc0: No vd33sw regulator found
  1605	[    2.498848] sunxi-mmc sdc0: No vd18sw regulator found
  1606	[    2.498855] sunxi-mmc sdc0: No vq33sw regulator found
  1607	[    2.498861] sunxi-mmc sdc0: No vq18sw regulator found
  1608	[    2.499542] sunxi-mmc sdc0: set host busy
  1609	[    2.499650] sunxi-mmc sdc0: Got CD GPIO
  1610	[    2.500017] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  1611	[    2.500052] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  1612	[    2.513611] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1613	[    2.530461] sunxi-mmc sdc0: detmode:gpio irq
  1614	[    2.530595] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1615	[    2.533100] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1616	[    2.533807] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  1617	[    2.533916] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  1618	[    2.534055] sunxi-mmc sdc1: No vmmc regulator found
  1619	[    2.534062] sunxi-mmc sdc1: No vqmmc regulator found
  1620	[    2.534069] sunxi-mmc sdc1: No vdmmc regulator found
  1621	[    2.534075] sunxi-mmc sdc1: No vd33sw regulator found
  1622	[    2.534081] sunxi-mmc sdc1: No vd18sw regulator found
  1623	[    2.534088] sunxi-mmc sdc1: No vq33sw regulator found
  1624	[    2.534094] sunxi-mmc sdc1: No vq18sw regulator found
  1625	[    2.534875] sunxi-mmc sdc1: set host busy
  1626	[    2.534959] mmc:failed to get gpios
  1627	[    2.535163] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1628	[    2.535258] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  1629	[    2.537725] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1630	[    2.550295] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1631	[    2.561346] mmc0: host does not support reading read-only switch, assuming write-enable
  1632	[    2.563205] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  1633	[    2.563280] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  1634	[    2.563558] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  1635	[    2.563650] mmc0: new high speed SDXC card at address 0001
  1636	[    2.564765] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  1637	[    2.566296]  mmcblk0: p1
  1638	[    2.566959] sunxi-mmc sdc1: detmode:manually by software
  1639	[    2.569167] ledtrig-cpu: registered to indicate activity on CPUs
  1640	[    2.569901] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  1641	[    2.570752] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  1642	[    2.570783] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1643	[    2.573287] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1644	[    2.575096] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  1645	[    2.575106] sunxi_emce_probe()590emce hw init failed!
  1646	[    2.575133] emce: probe of emce failed with error -2
  1647	[    2.575228] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  1648	[    2.575408] hidraw: raw HID events driver (C) Jiri Kosina
  1649	[    2.576075] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  1650	[    2.576936] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  1651	[    2.577793] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  1652	[    2.577841] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  1653	[    2.579927] usbcore: registered new interface driver usbhid
  1654	[    2.579937] usbhid: USB HID core driver
  1655	[    2.581469] optee: probing for conduit method from DT.
  1656	[    2.581482] optee: api uid mismatch
  1657	[    2.582016] usbcore: registered new interface driver snd-usb-audio
  1658	[    2.583647] [sunxi_hdmi_codec_init] driver and deivce register finished.
  1659	[    2.585342] [sunxi_internal_codec_probe]:get audio avcc failed
  1660	[    2.585381] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  1661	[    2.585630] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  1662	[    2.588135] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  1663	[    2.590112] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  1664	[    2.590125] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  1665	[    2.592459] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  1666	[    2.592485] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  1667	[    2.596456] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  1668	[    2.598249] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  1669	[    2.600150] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  1670	[    2.603089] pktgen: Packet Generator for packet performance testing. Version: 2.75
  1671	[    2.603526] u32 classifier
  1672	[    2.603533]     Actions configured
  1673	[    2.603592] Netfilter messages via NETLINK v0.30.
  1674	[    2.603647] nfnl_acct: registering with nfnetlink.
  1675	[    2.603996] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  1676	[    2.604247] ctnetlink v0.93: registering with nfnetlink.
  1677	[    2.605014] xt_time: kernel timezone is -0000
  1678	[    2.605038] IPVS: Registered protocols (TCP, UDP)
  1679	[    2.605147] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  1680	[    2.605271] IPVS: Creating netns size=1928 id=0
  1681	[    2.605401] IPVS: ipvs loaded.
  1682	[    2.605409] IPVS: [rr] scheduler registered.
  1683	[    2.605506] ipip: IPv4 and MPLS over IPv4 tunneling driver
  1684	[    2.606212] gre: GRE over IPv4 demultiplexor driver
  1685	[    2.606220] ip_gre: GRE over IPv4 tunneling driver
  1686	[    2.607609] IPv4 over IPsec tunneling driver
  1687	[    2.608486] ip_tables: (C) 2000-2006 Netfilter Core Team
  1688	[    2.608765] arp_tables: arp_tables: (C) 2002 David S. Miller
  1689	[    2.608830] Initializing XFRM netlink socket
  1690	[    2.608865] IPsec XFRM device driver
  1691	[    2.609703] NET: Registered protocol family 10
  1692	[    2.611651] mip6: Mobile IPv6
  1693	[    2.611691] ip6_tables: (C) 2000-2006 Netfilter Core Team
  1694	[    2.613001] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  1695	[    2.614688] NET: Registered protocol family 17
  1696	[    2.614730] NET: Registered protocol family 15
  1697	[    2.614888] Bridge firewalling registered
  1698	[    2.615022] Bluetooth: RFCOMM TTY layer initialized
  1699	[    2.615040] Bluetooth: RFCOMM socket layer initialized
  1700	[    2.615072] Bluetooth: RFCOMM ver 1.11
  1701	[    2.615087] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  1702	[    2.615092] Bluetooth: BNEP filters: protocol multicast
  1703	[    2.615105] Bluetooth: BNEP socket layer initialized
  1704	[    2.615111] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  1705	[    2.615123] Bluetooth: HIDP socket layer initialized
  1706	[    2.615216] l2tp_core: L2TP core driver, V2.0
  1707	[    2.615230] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  1708	[    2.615236] 8021q: 802.1Q VLAN Support v1.8
  1709	[    2.615435] sctp: Hash tables configured (bind 256/256)
  1710	[    2.616036] Key type dns_resolver registered
  1711	[    2.616177] Registered cp15_barrier emulation handler
  1712	[    2.616190] Registered setend emulation handler
  1713	[    2.617224] registered taskstats version 1
  1714	[    2.628757] zswap: default zpool zbud not available
  1715	[    2.628764] zswap: pool creation failed
  1716	[    2.631550] Btrfs loaded, crc32c=crc32c-arm64-hw
  1717	[    2.632312] HDMI 2.0 driver init start!
  1718	[    2.632327] boot_hdmi=true
  1719	[    2.633141] Can not find the node of esm
  1720	[    2.633159] ERROR: pinctrl_get for HDMI2.0 DDC fail
  1721	[    2.633247] Get hdmi_power0:vcc-hdmi
  1722	[    2.633286] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  1723	[    2.633458] Get hdmi_power1:vdd-hdmi
  1724	[    2.633480] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  1725	[    2.635080] hdmi_cec_init
  1726	[    2.635565] [DISP] disp_device_attached,line:146:
  1727	[    2.635574] attached ok, mgr0<-->device0, type=4
  1728	[    2.635585] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  1729	[    2.635598] [DISP] disp_hdmi_set_mode,line:648:
  1730	[    2.635602] hdmi_set_mode is null!
  1731	[    2.637248] HDMI2.0 module init end
  1732	[    2.648351] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  1733	[    2.651812] cpu cpu1: opp_list_debug_create_link: Failed to create link
  1734	[    2.651824] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  1735	[    2.651859] cpu cpu2: opp_list_debug_create_link: Failed to create link
  1736	[    2.651867] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  1737	[    2.651897] cpu cpu3: opp_list_debug_create_link: Failed to create link
  1738	[    2.651904] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  1739	[    2.654207] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  1740	[    2.655096] get det_vbus is fail, 84
  1741	[    2.655103] get id is fail, 84
  1742	[    2.655576] sunxi-rtc rtc: setting system clock to 2023-09-25 14:52:49 UTC (1695653569)
  1743	[    2.659337] ALSA device list:
  1744	[    2.659345]   #0: audiocodec
  1745	[    2.659349]   #1: sndahub
  1746	[    2.659352]   #2: sndhdmi
  1747	[    2.661025] Freeing unused kernel memory: 3008K
  1748	[    2.706769] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  1749	[    2.708870] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  1750	[    2.711780] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  1751	[    2.783214] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  1752	[    2.943730] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  1753	[    3.040328] HDMI cable is connected
  1754	[    3.293593] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  1755	[    3.514094] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  1756	[    3.514104] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  1757	[    3.514109] usb 4-1: Product: Rapoo 2.4G Wireless Device
  1758	[    3.514113] usb 4-1: Manufacturer: RAPOO
  1759	[    3.521911] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  1760	[    3.522440] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  1761	[    3.528055] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  1762	[    3.584346] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  1763	[    3.588361] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  1764	[    3.644493] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  1765	[    4.173433] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  1766	[    5.101534] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  1767	[    5.102087] cgroup: cgroup2: unknown option "nsdelegate"
  1768	[    5.122256] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  1769	[    5.122280] systemd[1]: Detected architecture arm64.
  1770	[    5.123378] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  1771	[    5.140746] systemd[1]: Hostname set to <opi>.
  1772	[    5.168066] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  1773	[    6.722904] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  1774	[    6.826941]
  1775	               insmod_device_driver
  1776
  1777	[    6.827189] device_chose finished 124!
  1778	[    7.129729] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  1779	[    7.369172] systemd[1]: Queued start job for default target graphical.target.
  1780	[    7.376823] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  1781	[    7.379020] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  1782	[    7.381318] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  1783	[    7.382600] systemd[1]: Created slice user.slice - User and Session Slice.
  1784	[    7.383253] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  1785	[    7.383868] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  1786	[    7.384202] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  1787	[    7.384756] systemd[1]: Reached target slices.target - Slice Units.
  1788	[    7.385090] systemd[1]: Reached target swap.target - Swaps.
  1789	[    7.385389] systemd[1]: Reached target time-set.target - System Time Set.
  1790	[    7.385902] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  1791	[    7.403268] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  1792	[    7.404433] systemd[1]: Listening on syslog.socket - Syslog Socket.
  1793	[    7.405388] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  1794	[    7.406056] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  1795	[    7.407727] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  1796	[    7.408673] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  1797	[    7.409695] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  1798	[    7.411938] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  1799	[    7.412834] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  1800	[    7.416821] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  1801	[    7.421468] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  1802	[    7.426487] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  1803	[    7.427699] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  1804	[    7.428681] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  1805	[    7.436271] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  1806	[    7.441910] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  1807	[    7.447703] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  1808	[    7.454201] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  1809	[    7.461600] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  1810	[    7.470060] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  1811	[    7.478698] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  1812	[    7.486727] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  1813	[    7.496520] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  1814	[    7.498007] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  1815	[    7.511229] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  1816	[    7.517677] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  1817	[    7.523815] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  1818	[    7.525336] fuse init (API version 7.26)
  1819	[    7.536260] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  1820	[    7.538668] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  1821	[    7.541222] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  1822	[    7.544423] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  1823	[    7.549066] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  1824	[    7.553679] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  1825	[    7.554461] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  1826	[    7.557916] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  1827	[    7.558773] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  1828	[    7.603516] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  1829	[    7.612080] systemd[1]: modprobe@drm.service: Deactivated successfully.
  1830	[    7.627612] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  1831	[    7.632507] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  1832	[    7.640673] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  1833	[    7.641758] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  1834	[    7.641769] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  1835	[    7.641965] spidev spi1.1: Deleting spi1.1
  1836	[    7.642784] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1837	[    7.643217] fbtft_device: GPIOS used by 'fb_st7735r':
  1838	[    7.643224] fbtft_device: 'reset' = GPIO73
  1839	[    7.643228] fbtft_device: 'dc' = GPIO70
  1840	[    7.643242] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  1841	[    7.643247] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  1842	[    7.644283] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  1843	[    7.665419] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  1844	[    7.680927] WCN: marlin_init entry!
  1845	[    7.682109] WCN: marlin_parse_dt reset gpio=211
  1846	[    7.682120] WCN_ERR: gpio reset request err: 211
  1847	[    7.682125] WCN: wcn config bt wake host
  1848	[    7.682626] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  1849	[    7.682867] WCN: wcn config wifi wake host
  1850	[    7.682900] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  1851	[    7.686401] sdiohal:sdiohal_init ok
  1852	[    7.687690] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  1853	[    7.690160] WCN: marlin_probe ok!
  1854	[    7.692178] systemd[1]: modprobe@loop.service: Deactivated successfully.
  1855	[    7.693023] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  1856	[    7.696210] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  1857	[    7.699361] mtty_probe init device addr: 0xffffffc009a62f00
  1858	[    7.702980] -->rfkill_bluetooth_init
  1859	[    7.703219] <--rfkill_bluetooth_init
  1860	[    7.746330] WCN: start_marlin [MARLIN_WIFI]
  1861	[    7.746344] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  1862	[    7.746348] WCN: the first power on start
  1863	[    7.753319] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  1864	[    7.759541] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  1865	[    7.760731] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  1866	[    7.767285] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  1867	[    7.768094] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  1868	[    7.774614] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  1869	[    7.790586] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  1870	[    7.793206] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  1871	[    7.808935] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  1872	[    7.844542] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  1873	[    7.851045] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  1874	[    7.863660] WCN: marlin chip en pull up
  1875	[    7.893670] sdiohal:sdiohal_scan_card
  1876	[    7.893692] sunxi-wlan soc@03000000:wlan: bus_index: 1
  1877	[    7.893746] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  1878	[    7.910290] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1879	[    7.931090] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  1880	[    7.932031] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  1881	[    7.932076] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1882	[    7.934615] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1883	[    7.937717] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1884	[    7.953107] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  1885	[    7.953636] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  1886	[    7.955164] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  1887	[    7.961258] systemd[1]: Mounting tmp.mount - /tmp...
  1888	[    7.967862] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  1889	[    7.973982] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  1890	[    7.974741] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  1891	[    7.974807] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  1892	[    7.975417] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  1893	[    7.975947] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  1894	[    7.976137] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  1895	[    7.976159] WCN: marlin_scan_finish!
  1896	[    7.976164] sdiohal:probe ok
  1897	[    7.976179] sdiohal:scan end!
  1898	[    7.976185] WCN: then marlin start to download
  1899	[    7.976214] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  1900	[    7.991119] systemd[1]: Mounted tmp.mount - /tmp.
  1901	[    7.993310] systemd[1]: Reached target local-fs.target - Local File Systems.
  1902	[    7.998567] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  1903	[    8.004446] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  1904	[    8.010353] systemd[1]: Starting console-setup.service - Set console font and keymap...
  1905	[    8.015562] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  1906	[    8.041808] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  1907	[    8.051646] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  1908	[    8.056330] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  1909	[    8.061917] systemd[1]: Finished console-setup.service - Set console font and keymap.
  1910	[    8.107595] WCN: combin_img 0 marlin_firmware_write finish and successful
  1911	[    8.107769] WCN: marlin_start_run read reset reg val:0x1
  1912	[    8.107773] WCN: after do marlin_start_run reset reg val:0x0
  1913	[    8.107983] WCN: s_marlin_bootup_time=8107975260
  1914	[    8.111812] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  1915	[    8.113960] WCN: clock mode: TSX
  1916	[    8.114174] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  1917	[    8.119656] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  1918	[    8.123269] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  1919	[    8.126534] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  1920	[    8.128442] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  1921	[    8.129410] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  1922	[    8.134094] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  1923	[    8.137291] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
  1924	[    8.137872] systemd[1]: Reached target network-pre.target - Preparation for Network.
  1925	[    8.140733] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  1926	[    8.167217] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
  1927	[    8.167226] WCN: sdio_config bt_wake_host trigger:[high]
  1928	[    8.167229] WCN: sdio_config irq:[inband]
  1929	[    8.167233] WCN: sdio_config wl_wake_host trigger:[high]
  1930	[    8.167241] WCN: sdio_config wake_host_level_duration_time:[20ms]
  1931	[    8.167244] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
  1932	[    8.167249] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
  1933	[    8.167615] WCN: marlin_write_cali_data finish
  1934	[    8.167904] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  1935	[    8.193884] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  1936	[    8.207431] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  1937	[    8.210652] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  1938	[    8.220528] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  1939	[    8.247169] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  1940	[    8.273851] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  1941	[    8.300524] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
  1942	[    8.300534] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
  1943	[    8.300550] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
  1944	[    8.301247] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
  1945	[    8.327207] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
  1946	[    8.327216] sdiohal:sdiohal_runtime_get entry
  1947	[    8.327429] WCN: get_cp2_version entry!
  1948	[    8.329113] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
  1949	[    8.329144] WCN: switch_cp2_log - close entry!
  1950	[    8.330472] WCN: WCND at cmd read:OK
  1951	[    8.330551] WCN: then marlin download finished and run ok
  1952	[    8.330557] WCN: start_loopcheck
  1953	[    8.344877] WCN: get_board_ant_num [one_ant]
  1954	[    8.344888] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
  1955	[    8.405967] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
  1956	[    8.411352] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  1957	[    8.419183] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  1958	[    8.486413] zram: Added device: zram0
  1959	[    8.487193] zram: Added device: zram1
  1960	[    8.488112] zram: Added device: zram2
  1961	[    8.496220] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  1962	[    8.504088] systemd[1]: Starting networking.service - Raise network interfaces...
  1963	[    8.521937] zswap: can't enable, initialization failed
  1964	[    8.580851] zram0: detected capacity change from 0 to 506396672
  1965	[    8.586326] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  1966	[    8.603653] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  1967	[    8.668634] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  1968	[    8.685418] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  1969	[    8.687924] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  1970	[    8.688982] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  1971	[    8.689622] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  1972	[    9.128629] systemd[1]: Finished networking.service - Raise network interfaces.
  1973	[    9.763740] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  1974	[    9.890189] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  1975	[   10.028067] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  1976	[   10.654680] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  1977	[   10.654923] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  1978	[   10.655554] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  1979	[   10.667241] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  1980	[   10.677764] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  1981	[   10.684938] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  1982	[   10.698026] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  1983	[   10.702064] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  1984	[   10.702944] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  1985	[   10.707530] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  1986	[   10.708623] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  1987	[   10.711708] systemd[1]: modprobe@loop.service: Deactivated successfully.
  1988	[   10.712834] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  1989	[   10.714975] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  1990	[   10.715235] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  1991	[   10.774342] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  1992	[   10.779309] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  1993	[   10.780190] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  1994	[   10.792320] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  1995	[   10.811076] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  1996	[   10.857080] sunxi-bt soc@03000000:bt: set block: 0
  1997	[   10.873938] bluetooth_set_power: start_block=0
  1998	[   10.873950] WCN: start_marlin [MARLIN_BLUETOOTH]
  1999	[   10.873960] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
  2000	[   10.873965] WCN: marlin have open, GNSS is closed
  2001	[   10.873970] bluetooth_set_power: end_block=0
  2002	[   10.922196] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  2003	[   11.094722] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  2004	[   11.100559] systemd[1]: Starting brltty.service - Braille Device Support...
  2005	[   11.626231] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  2006	[   11.768144] zram1: detected capacity change from 0 to 52428800
  2007	[   11.859100] systemd[1]: Started brltty.service - Braille Device Support.
  2008	[   11.873324] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  2009	[   15.857495] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  2010	[   15.863476] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  2011	[   15.925725] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  2012	[   15.937064] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  2013	[   19.597599] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  2014	[   19.604154] systemd[1]: Starting systemd-journald.service - Journal Service...
  2015	[   19.884029] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
  2016	[   19.884051] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  2017	[   19.891164] systemd[1]: Started systemd-journald.service - Journal Service.
  2018	[   19.938167] systemd-journald[1921]: Received client request to flush runtime journal.
  2019	[   20.306857] IPVS: Creating netns size=1928 id=1
  2020
  2021	### armbian-release:
  2022
  2023	# PLEASE DO NOT EDIT THIS FILE
  2024	BOARD=orangepizero2
  2025	BOARD_NAME="Orange Pi Zero2"
  2026	BOARDFAMILY=sun50iw9
  2027	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  2028	BUILD_REPOSITORY_COMMIT=ac829eb6
  2029	LINUXFAMILY=sun50iw9
  2030	ARCH=arm64
  2031	IMAGE_TYPE=stable
  2032	BOARD_TYPE=conf
  2033	INITRD_ARCH=arm
  2034	KERNEL_IMAGE_TYPE=Image
  2035	FORCE_BOOTSCRIPT_UPDATE=yes
  2036	VENDOR=Armbian
  2037	BOOTSCRIPT_FORCE_UPDATE="yes"
  2038	BOOTSCRIPT_DST="boot.cmd"
  2039	VERSION=23.8.1
  2040	REVISION=23.8.1
  2041	BRANCH=legacy
  2042
  2043	### boot environment:
  2044
  2045	verbosity=1
  2046	console=serial
  2047	#disp_mode=1080p60
  2048	#fb0_width=1280
  2049	#fb0_height=720
  2050	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  2051	rootfstype=ext4
  2052	overlays=spi-spidev
  2053	param_spidev_spi_bus=1
  2054	param_spidev_spi_cs=1
  2055	extraargs=fbcon=map:1
  2056	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  2057
  2058	### lsusb:
  2059
  2060	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2061	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2062	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2063	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2064	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  2065	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  2066	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  2067
  2068	### lscpu:
  2069
  2070	Architecture:        aarch64
  2071	CPU op-mode(s):      32-bit, 64-bit
  2072	Byte Order:          Little Endian
  2073	CPU(s):              4
  2074	On-line CPU(s) list: 0-3
  2075	Vendor ID:           ARM
  2076	Model name:          Cortex-A53
  2077	Model:               4
  2078	Thread(s) per core:  1
  2079	Core(s) per cluster: 4
  2080	Socket(s):           -
  2081	Cluster(s):          1
  2082	Stepping:            r0p4
  2083	CPU(s) scaling MHz:  100%
  2084	CPU max MHz:         1512.0000
  2085	CPU min MHz:         480.0000
  2086	BogoMIPS:            48.00
  2087	Flags:               fp asimd aes pmull sha1 sha2 crc32
  2088
  2089	### cpuinfo:
  2090
  2091	processor	: 0
  2092	BogoMIPS	: 48.00
  2093	Features	: fp asimd aes pmull sha1 sha2 crc32
  2094	CPU implementer	: 0x41
  2095	CPU architecture: 8
  2096	CPU variant	: 0x0
  2097	CPU part	: 0xd03
  2098	CPU revision	: 4
  2099
  2100	processor	: 1
  2101	BogoMIPS	: 48.00
  2102	Features	: fp asimd aes pmull sha1 sha2 crc32
  2103	CPU implementer	: 0x41
  2104	CPU architecture: 8
  2105	CPU variant	: 0x0
  2106	CPU part	: 0xd03
  2107	CPU revision	: 4
  2108
  2109	processor	: 2
  2110	BogoMIPS	: 48.00
  2111	Features	: fp asimd aes pmull sha1 sha2 crc32
  2112	CPU implementer	: 0x41
  2113	CPU architecture: 8
  2114	CPU variant	: 0x0
  2115	CPU part	: 0xd03
  2116	CPU revision	: 4
  2117
  2118	processor	: 3
  2119	BogoMIPS	: 48.00
  2120	Features	: fp asimd aes pmull sha1 sha2 crc32
  2121	CPU implementer	: 0x41
  2122	CPU architecture: 8
  2123	CPU variant	: 0x0
  2124	CPU part	: 0xd03
  2125	CPU revision	: 4
  2126
  2127
  2128	### meminfo:
  2129
  2130	MemTotal:         989056 kB
  2131	MemFree:          795972 kB
  2132	MemAvailable:     885620 kB
  2133	Buffers:           15732 kB
  2134	Cached:            81084 kB
  2135	SwapCached:            0 kB
  2136	Active:            65604 kB
  2137	Inactive:          52188 kB
  2138	Active(anon):      21192 kB
  2139	Inactive(anon):      652 kB
  2140	Active(file):      44412 kB
  2141	Inactive(file):    51536 kB
  2142	Unevictable:           0 kB
  2143	Mlocked:               0 kB
  2144	SwapTotal:        494524 kB
  2145	SwapFree:         494524 kB
  2146	Dirty:              5340 kB
  2147	Writeback:             0 kB
  2148	AnonPages:         21100 kB
  2149	Mapped:            24592 kB
  2150	Shmem:               824 kB
  2151	Slab:              33012 kB
  2152	SReclaimable:       9044 kB
  2153	SUnreclaim:        23968 kB
  2154	KernelStack:        2528 kB
  2155	PageTables:         1060 kB
  2156	NFS_Unstable:          0 kB
  2157	Bounce:                0 kB
  2158	WritebackTmp:          0 kB
  2159	CommitLimit:      989052 kB
  2160	Committed_AS:      80292 kB
  2161	VmallocTotal:   263061440 kB
  2162	VmallocUsed:           0 kB
  2163	VmallocChunk:          0 kB
  2164	CmaTotal:          16384 kB
  2165	CmaFree:            7468 kB
  2166	HugePages_Total:       0
  2167	HugePages_Free:        0
  2168	HugePages_Rsvd:        0
  2169	HugePages_Surp:        0
  2170	Hugepagesize:       2048 kB
  2171
  2172	### virtual memory:
  2173
  2174	vm.admin_reserve_kbytes = 8192
  2175	vm.block_dump = 0
  2176	vm.compact_unevictable_allowed = 1
  2177	vm.dirty_background_bytes = 0
  2178	vm.dirty_background_ratio = 10
  2179	vm.dirty_bytes = 0
  2180	vm.dirty_expire_centisecs = 3000
  2181	vm.dirty_ratio = 20
  2182	vm.dirtytime_expire_seconds = 43200
  2183	vm.dirty_writeback_centisecs = 500
  2184	vm.extfrag_threshold = 500
  2185	vm.extra_free_kbytes = 0
  2186	vm.hugepages_treat_as_movable = 0
  2187	vm.hugetlb_shm_group = 0
  2188	vm.laptop_mode = 0
  2189	vm.legacy_va_layout = 0
  2190	vm.lowmem_reserve_ratio = 256	32
  2191	vm.max_map_count = 65530
  2192	vm.min_free_kbytes = 3937
  2193	vm.mmap_min_addr = 4096
  2194	vm.mmap_rnd_bits = 18
  2195	vm.mmap_rnd_compat_bits = 11
  2196	vm.nr_hugepages = 0
  2197	vm.nr_overcommit_hugepages = 0
  2198	vm.nr_pdflush_threads = 0
  2199	vm.oom_dump_tasks = 1
  2200	vm.oom_kill_allocating_task = 0
  2201	vm.overcommit_kbytes = 0
  2202	vm.overcommit_memory = 0
  2203	vm.overcommit_ratio = 50
  2204	vm.page-cluster = 0
  2205	vm.panic_on_oom = 0
  2206	vm.percpu_pagelist_fraction = 0
  2207	vm.stat_interval = 1
  2208	vm.swappiness = 100
  2209	vm.user_reserve_kbytes = 30004
  2210	vm.vfs_cache_pressure = 100
  2211	vm.watermark_scale_factor = 10
  2212
  2213	### ip addr:
  2214
  2215	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  2216	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  2217	    inet XXX.XXX.0.1/8 scope host lo
  2218	       valid_lft forever preferred_lft forever
  2219	    inet6 ::1/128 scope host noprefixroute
  2220	       valid_lft forever preferred_lft forever
  2221	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2222	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  2223	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2224	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  2225	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  2226	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  2227	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  2228	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  2229	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  2230	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  2231	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  2232	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  2233	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  2234	    link/tunnel6 :: brd ::
  2235	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  2236	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  2237	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  2238	    link/tunnel6 :: brd ::
  2239	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  2240	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  2241
  2242	### partitions:
  2243
  2244	major minor  #blocks  name
  2245
  2246	 179        0   62410752 mmcblk0
  2247	 179        1   61763584 mmcblk0p1
  2248	 253        0     494528 zram0
  2249	 253        1      51200 zram1
  2250
  2251	### df:
  2252
  2253	udev            466M     0  466M   0% /dev
  2254	tmpfs            97M  900K   96M   1% /run
  2255	/dev/mmcblk0p1   58G  5.7G   52G  10% /
  2256	tmpfs           483M     0  483M   0% /dev/shm
  2257	tmpfs           5.0M     0  5.0M   0% /run/lock
  2258	tmpfs           483M  4.0K  483M   1% /tmp
  2259	/dev/zram1       47M  4.8M   39M  11% /var/log
  2260
  2261	### lsblk:
  2262
  2263	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  2264	mmcblk0             59.5G
  2265	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  2266	zram1                 50M /var/log
  2267	zram2                  0B
  2268
  2269	### zramctl:
  2270
  2271	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  2272	/dev/zram1 lz4            50M  4.8M  1.4M  1.8M       4 /var/log
  2273	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  2274
  2275	### mtab:
  2276
  2277	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2278	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  2279	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  2280
  2281	### mmc0:0001 info:
  2282
  2283	              manfid: 0x0000fe
  2284	                 cid: fe3432534431364720000000690091f5
  2285	               fwrev: 0x0
  2286	                 csd: 400e00325b590001dc277f800a40008b
  2287	                 ocr: 0x00200000
  2288	                type: SD
  2289	                date: 01/2009
  2290	               hwrev: 0x2
  2291	                 dsr: 0x404
  2292	              serial: 0x00000069
  2293	          erase_size: 512
  2294	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  2295	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  2296	                 scr: 0285808300000000
  2297	               oemid: 0x3432
  2298	preferred_erase_size: 4194304
  2299	                name: SD16G
  2300
  2301	### Boot system health:
  2302
  2303	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  2304	11:53:09  1512 MHz  1.25  39%  19%  13%   0%   7%   0%  48.2 °C  0/5
  2305	11:53:10  1512 MHz  1.25  97%  21%  45%   2%  28%   0%  48.2 °C  0/5
  2306	11:53:10  1512 MHz  1.25 100%  29%  50%   0%  19%   0%  48.9 °C  0/5
  2307	11:53:11  1512 MHz  1.25  96%  20%  23%   0%  50%   0%  48.9 °C  0/5
  2308	11:53:11  1512 MHz  1.25  99%  27%  40%   1%  30%   0%  48.9 °C  0/5
  2309
  2310	### Activated 1 lzo zram swap devices with 482MB each.
  2311	### Activated Armbian ramlog partition with lz4 compression
  2312
  2313	Mon Sep 25 12:17:53 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  2314
  2315	### dmesg:
  2316
  2317	[    0.000000] Booting Linux on physical CPU 0x0
  2318	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  2319	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  2320	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  2321	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  2322	[    0.000000] On node 0 totalpages: 262144
  2323	[    0.000000]   DMA zone: 4096 pages used for memmap
  2324	[    0.000000]   DMA zone: 0 pages reserved
  2325	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  2326	[    0.000000] psci: probing for conduit method from DT.
  2327	[    0.000000] psci: PSCIv1.0 detected in firmware.
  2328	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  2329	[    0.000000] psci: Trusted OS migration not required
  2330	[    0.000000] psci: SMC Calling Convention v1.0
  2331	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  2332	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  2333	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  2334	[    0.000000] Detected VIPT I-cache on CPU0
  2335	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  2336	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  2337	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  2338	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  2339	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  2340	[    0.000000] log_buf_len min size: 131072 bytes
  2341	[    0.000000] log_buf_len: 524288 bytes
  2342	[    0.000000] early log buf free: 129352(98%)
  2343	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  2344	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  2345	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  2346	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  2347	[    0.000000] Virtual kernel memory layout:
  2348	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  2349	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  2350	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  2351	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  2352	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  2353	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  2354	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  2355	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  2356	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  2357	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  2358	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  2359	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  2360	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  2361	[    0.000000] Preemptible hierarchical RCU implementation.
  2362	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  2363	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  2364	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  2365	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  2366	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  2367	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  2368	[    0.000211] Console: colour dummy device 80x25
  2369	[    0.000227] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  2370	[    0.000235] pid_max: default: 32768 minimum: 301
  2371	[    0.000433] Security Framework initialized
  2372	[    0.000442] AppArmor: AppArmor disabled by boot time parameter
  2373	[    0.000560] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  2374	[    0.000567] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  2375	[    0.001839] sched-energy: CPU device node has no sched-energy-costs
  2376	[    0.001854] Invalid sched_group_energy for CPU0
  2377	[    0.001861] CPU0: update cpu_capacity 1024
  2378	[    0.008953] ASID allocator initialised with 32768 entries
  2379	[    0.027923] BOOTEVENT:        27.909457: ON
  2380	[    0.055902] Detected VIPT I-cache on CPU1
  2381	[    0.055955] Invalid sched_group_energy for CPU1
  2382	[    0.055959] CPU1: update cpu_capacity 1024
  2383	[    0.055962] CPU1: Booted secondary processor [410fd034]
  2384	[    0.079289] Detected VIPT I-cache on CPU2
  2385	[    0.079327] Invalid sched_group_energy for CPU2
  2386	[    0.079330] CPU2: update cpu_capacity 1024
  2387	[    0.079333] CPU2: Booted secondary processor [410fd034]
  2388	[    0.102692] Detected VIPT I-cache on CPU3
  2389	[    0.102726] Invalid sched_group_energy for CPU3
  2390	[    0.102729] CPU3: update cpu_capacity 1024
  2391	[    0.102732] CPU3: Booted secondary processor [410fd034]
  2392	[    0.102813] Brought up 4 CPUs
  2393	[    0.102820] SMP: Total of 4 processors activated.
  2394	[    0.102829] CPU features: detected feature: 32-bit EL0 Support
  2395	[    0.102835] CPU features: detected feature: Kernel page table isolation (KPTI)
  2396	[    0.106595] CPU: All CPU(s) started at EL1
  2397	[    0.106617] alternatives: patching kernel code
  2398	[    0.106790] Invalid sched_group_energy for CPU3
  2399	[    0.106800] CPU3: update max cpu_capacity 1024
  2400	[    0.106806] Invalid sched_group_energy for Cluster3
  2401	[    0.106811] Invalid sched_group_energy for CPU2
  2402	[    0.106816] Invalid sched_group_energy for Cluster2
  2403	[    0.106821] Invalid sched_group_energy for CPU1
  2404	[    0.106827] Invalid sched_group_energy for Cluster1
  2405	[    0.106831] Invalid sched_group_energy for CPU0
  2406	[    0.106837] Invalid sched_group_energy for Cluster0
  2407	[    0.108257] devtmpfs: initialized
  2408	[    0.112702] CPU1: update max cpu_capacity 1024
  2409	[    0.143397] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  2410	[    0.143418] futex hash table entries: 1024 (order: 5, 131072 bytes)
  2411	[    0.144078] xor: measuring software checksum speed
  2412	[    0.176236]    8regs     :  1933.200 MB/sec
  2413	[    0.209615]    8regs_prefetch:  1720.800 MB/sec
  2414	[    0.243003]    32regs    :  2287.200 MB/sec
  2415	[    0.276391]    32regs_prefetch:  1935.600 MB/sec
  2416	[    0.276396] xor: using function: 32regs (2287.200 MB/sec)
  2417	[    0.276457] atomic64_test: passed
  2418	[    0.276463] pinctrl core: initialized pinctrl subsystem
  2419	[    0.277631] NET: Registered protocol family 16
  2420	[    0.278774] dump_class_init,861, success
  2421	[    0.293110] cpuidle: using governor menu
  2422	[    0.294521] sunxi iommu: irq = 8
  2423	[    0.294837] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  2424	[    0.294855] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  2425	[    0.296242] DMA: preallocated 256 KiB pool for atomic allocations
  2426	[    0.297632] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  2427	[    0.311994] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  2428	[    0.316021] iommu: Adding device 1c0e000.ve to group 0
  2429	[    0.316543] iommu: Adding device 1c00000.vp9 to group 0
  2430	[    0.328258] iommu: Adding device 1000000.disp to group 0
  2431	[    0.329710] iommu: Adding device 1480000.g2d to group 0
  2432	[    0.332989] iommu: Adding device csi0 to group 0
  2433	[    0.333518] iommu: Adding device csi1 to group 0
  2434	[    0.334714] iommu: Adding device 6600800.vind:scaler@0 to group 0
  2435	[    0.335018] iommu: Adding device 6600800.vind:scaler@1 to group 0
  2436	[    0.335334] iommu: Adding device 6600800.vind:scaler@2 to group 0
  2437	[    0.335638] iommu: Adding device 6600800.vind:scaler@3 to group 0
  2438	[    0.335948] iommu: Adding device 6600800.vind:scaler@4 to group 0
  2439	[    0.336250] iommu: Adding device 6600800.vind:scaler@5 to group 0
  2440	[    0.337321] iommu: Adding device vinc0 to group 0
  2441	[    0.337809] iommu: Adding device vinc1 to group 0
  2442	[    0.339300] iommu: Adding device 1420000.deinterlace to group 0
  2443	[    0.381178] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  2444	[    0.437369] raid6: int64x1  gen()   391 MB/s
  2445	[    0.494025] raid6: int64x1  xor()   362 MB/s
  2446	[    0.550749] raid6: int64x2  gen()   590 MB/s
  2447	[    0.607545] raid6: int64x2  xor()   512 MB/s
  2448	[    0.664291] raid6: int64x4  gen()   840 MB/s
  2449	[    0.721006] raid6: int64x4  xor()   629 MB/s
  2450	[    0.777779] raid6: int64x8  gen()   964 MB/s
  2451	[    0.834480] raid6: int64x8  xor()   655 MB/s
  2452	[    0.891289] raid6: neonx1   gen()   648 MB/s
  2453	[    0.947984] raid6: neonx1   xor()   641 MB/s
  2454	[    1.004732] raid6: neonx2   gen()   976 MB/s
  2455	[    1.061457] raid6: neonx2   xor()   819 MB/s
  2456	[    1.118189] raid6: neonx4   gen()  1286 MB/s
  2457	[    1.174947] raid6: neonx4   xor()   965 MB/s
  2458	[    1.231666] raid6: neonx8   gen()  1323 MB/s
  2459	[    1.288431] raid6: neonx8   xor()   984 MB/s
  2460	[    1.288437] raid6: using algorithm neonx8 gen() 1323 MB/s
  2461	[    1.288442] raid6: .... xor() 984 MB/s, rmw enabled
  2462	[    1.288447] raid6: using intx1 recovery algorithm
  2463	[    1.288624] pwm module init!
  2464	[    1.292929] sunxi-pm debug v3.10
  2465	[    1.294013] SCSI subsystem initialized
  2466	[    1.294627] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  2467	[    1.294705] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  2468	[    1.294822] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  2469	[    1.295322] spi spi0: master is unqueued, this is deprecated
  2470	[    1.295630] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  2471	[    1.296201] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  2472	[    1.296283] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  2473	[    1.296400] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  2474	[    1.296844] spi spi1: master is unqueued, this is deprecated
  2475	[    1.297148] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  2476	[    1.297931] usbcore: registered new interface driver usbfs
  2477	[    1.298022] usbcore: registered new interface driver hub
  2478	[    1.298095] usbcore: registered new device driver usb
  2479	[    1.298376] sunxi_i2c_adap_init()2522 - init
  2480	[    1.298937] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  2481	[    1.299028] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  2482	[    1.299036] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  2483	[    1.299051] twi3 supply twi not found, using dummy regulator
  2484	[    1.299127] twi_request_gpio()451 - [i2c3] init name: twi3
  2485	[    1.299888] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  2486	[    1.299967] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  2487	[    1.299974] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  2488	[    1.299990] twi5 supply twi not found, using dummy regulator
  2489	[    1.300065] twi_request_gpio()451 - [i2c5] init name: twi5
  2490	[    1.300552] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  2491	[    1.319041] random: fast init done
  2492	[    1.330217] axp20x-i2c 5-0036: AXP20X driver loaded
  2493	[    1.330704] media: Linux media interface: v0.10
  2494	[    1.330790] Linux video capture interface: v2.00
  2495	[    1.331581] Advanced Linux Sound Architecture Driver Initialized.
  2496	[    1.332328] Bluetooth: Core ver 2.22
  2497	[    1.332427] NET: Registered protocol family 31
  2498	[    1.332433] Bluetooth: HCI device and connection manager initialized
  2499	[    1.332451] Bluetooth: HCI socket layer initialized
  2500	[    1.332463] Bluetooth: L2CAP socket layer initialized
  2501	[    1.332502] Bluetooth: SCO socket layer initialized
  2502	[    1.338283] [DISP]disp_module_init
  2503	[    1.339468] [DISP] parser_disp_init_para,line:1403:
  2504	[    1.339477] of_property_read fb0_width fail
  2505	[    1.339488] [DISP] disp_init,line:2215:
  2506	[    1.339494] smooth display screen:0 type:4 mode:10
  2507	[    1.356890] [DISP]disp_module_init finish
  2508	[    1.357753] clocksource: Switched to clocksource arch_sys_counter
  2509	[    1.357992] VFS: Disk quotas dquot_6.6.0
  2510	[    1.358136] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  2511	[    1.358889] Console: switching to colour frame buffer device 240x67
  2512	[    1.402311] NET: Registered protocol family 2
  2513	[    1.402441] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  2514	[    1.414671] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  2515	[    1.414744] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  2516	[    1.414866] TCP: Hash tables configured (established 8192 bind 8192)
  2517	[    1.414952] UDP hash table entries: 512 (order: 2, 16384 bytes)
  2518	[    1.414982] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  2519	[    1.415288] NET: Registered protocol family 1
  2520	[    1.415831] RPC: Registered named UNIX socket transport module.
  2521	[    1.415836] RPC: Registered udp transport module.
  2522	[    1.415839] RPC: Registered tcp transport module.
  2523	[    1.415842] RPC: Registered tcp NFSv4.1 backchannel transport module.
  2524	[    1.416090] Trying to unpack rootfs image as initramfs...
  2525	[    2.170062] Freeing initrd memory: 17256K
  2526	[    2.171184] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  2527	[    2.175097] audit: initializing netlink subsys (disabled)
  2528	[    2.175153] audit: type=2000 audit(2.170:1): initialized
  2529	[    2.176062] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  2530	[    2.187177] DLM installed
  2531	[    2.189044] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  2532	[    2.189384] Registering sdcardfs 0.1
  2533	[    2.189856] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  2534	[    2.191393] ntfs: driver 2.1.32 [Flags: R/W].
  2535	[    2.197821] NET: Registered protocol family 38
  2536	[    2.198201] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  2537	[    2.198330] io scheduler noop registered
  2538	[    2.198338] io scheduler deadline registered
  2539	[    2.198506] io scheduler cfq registered (default)
  2540	[    2.200317] failed to get easy_light_used assign
  2541	[    2.200328] failed to get normal led pin assign
  2542	[    2.200333] failed to get standby led pin assign
  2543	[    2.200338] failed to get standby led pin assign
  2544	[    2.200343] these is zero number for gpio
  2545	[    2.200347] gpio_init finish with uesd
  2546	[    2.203754] uart uart0: get regulator failed
  2547	[    2.203954] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  2548	[    2.203975] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  2549	[    2.204067] console [ttyS0] enabled
  2550	[    2.204950] uart uart1: get regulator failed
  2551	[    2.205145] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  2552	[    2.205881] uart uart5: get regulator failed
  2553	[    2.206067] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  2554	[    2.207328] misc dump reg init
  2555	[    2.208772] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  2556	[    2.209114] Unable to detect cache hierarchy for CPU 0
  2557	[    2.223698] brd: module loaded
  2558	[    2.231879] loop: module loaded
  2559	[    2.232069] [NAND][NE] Not found valid nand node on dts
  2560	[    2.232664] Get boot type cmd line fail
  2561	[    2.233251] sunxi-bt soc@03000000:bt: Missing bt_power.
  2562	[    2.233261] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  2563	[    2.233268] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  2564	[    2.233275] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  2565	[    2.233333] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  2566	[    2.233404] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  2567	[    2.234235] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  2568	[    2.234247] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  2569	[    2.234255] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  2570	[    2.234262] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  2571	[    2.234269] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  2572	[    2.234300] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  2573	[    2.234341] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  2574	[    2.234349] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  2575	[    2.234367] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  2576	[    2.235492] [ADDR_MGT] addr_mgt_probe: success.
  2577	[    2.242110] tun: Universal TUN/TAP device driver, 1.6
  2578	[    2.242120] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  2579	[    2.244105] gmac-power0: NULL
  2580	[    2.244115] gmac-power1: NULL
  2581	[    2.244121] gmac-power2: NULL
  2582	[    2.245221] PPP generic driver version 2.4.2
  2583	[    2.245504] PPP BSD Compression module registered
  2584	[    2.245515] PPP Deflate Compression module registered
  2585	[    2.245540] PPP MPPE Compression module registered
  2586	[    2.245550] NET: Registered protocol family 24
  2587	[    2.245582] PPTP driver version 0.8.5
  2588	[    2.245943] usbcore: registered new interface driver r8152
  2589	[    2.246022] usbcore: registered new interface driver asix
  2590	[    2.246115] usbcore: registered new interface driver ax88179_178a
  2591	[    2.246187] usbcore: registered new interface driver cdc_ether
  2592	[    2.246250] usbcore: registered new interface driver net1080
  2593	[    2.246314] usbcore: registered new interface driver cdc_subset
  2594	[    2.246385] usbcore: registered new interface driver zaurus
  2595	[    2.246477] usbcore: registered new interface driver cdc_ncm
  2596	[    2.246484] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  2597	[    2.246843] get drv_vbus is fail, 84
  2598	[    2.246852] get ehci0-controller, regulator_io is no nocare
  2599	[    2.247115] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  2600	[    2.247121] [sunxi-ehci0]: Not init ehci0
  2601	[    2.247248] get ehci1-controller, regulator_io is no nocare
  2602	[    2.247431] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  2603	[    2.247488] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2604	[    2.247515] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  2605	[    2.248121] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  2606	[    2.261108] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  2607	[    2.261394] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  2608	[    2.261403] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2609	[    2.261411] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2610	[    2.261418] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  2611	[    2.261425] usb usb1: SerialNumber: sunxi-ehci
  2612	[    2.262279] hub 1-0:1.0: USB hub found
  2613	[    2.262325] hub 1-0:1.0: 1 port detected
  2614	[    2.263019] get drv_vbus is fail, 84
  2615	[    2.263027] get ehci2-controller, regulator_io is no nocare
  2616	[    2.263264] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  2617	[    2.263314] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2618	[    2.263339] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  2619	[    2.263631] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  2620	[    2.274444] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  2621	[    2.274652] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  2622	[    2.274661] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2623	[    2.274668] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2624	[    2.274675] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  2625	[    2.274682] usb usb2: SerialNumber: sunxi-ehci
  2626	[    2.275540] hub 2-0:1.0: USB hub found
  2627	[    2.275583] hub 2-0:1.0: 1 port detected
  2628	[    2.276255] get drv_vbus is fail, 84
  2629	[    2.276263] get ehci3-controller, regulator_io is no nocare
  2630	[    2.276507] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  2631	[    2.276558] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2632	[    2.276586] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  2633	[    2.276883] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  2634	[    2.287763] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  2635	[    2.287950] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  2636	[    2.287959] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2637	[    2.287966] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  2638	[    2.287974] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  2639	[    2.287980] usb usb3: SerialNumber: sunxi-ehci
  2640	[    2.288840] hub 3-0:1.0: USB hub found
  2641	[    2.288883] hub 3-0:1.0: 1 port detected
  2642	[    2.289803] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  2643	[    2.290200] get drv_vbus is fail, 84
  2644	[    2.290208] get ohci0-controller, regulator_io is no nocare
  2645	[    2.290541] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  2646	[    2.290546] [sunxi-ohci0]: Not init ohci0
  2647	[    2.290664] get ohci1-controller, regulator_io is no nocare
  2648	[    2.290836] hci: request ohci1-controller gpio:80
  2649	[    2.290912] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  2650	[    2.290964] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2651	[    2.290989] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  2652	[    2.291111] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  2653	[    2.351931] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  2654	[    2.351941] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2655	[    2.351948] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2656	[    2.351956] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  2657	[    2.351963] usb usb4: SerialNumber: sunxi-ohci
  2658	[    2.352841] hub 4-0:1.0: USB hub found
  2659	[    2.352886] hub 4-0:1.0: 1 port detected
  2660	[    2.353559] get drv_vbus is fail, 84
  2661	[    2.353568] get ohci2-controller, regulator_io is no nocare
  2662	[    2.353898] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  2663	[    2.353953] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2664	[    2.353978] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  2665	[    2.354069] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  2666	[    2.411931] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  2667	[    2.411941] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2668	[    2.411948] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2669	[    2.411956] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  2670	[    2.411963] usb usb5: SerialNumber: sunxi-ohci
  2671	[    2.412833] hub 5-0:1.0: USB hub found
  2672	[    2.412878] hub 5-0:1.0: 1 port detected
  2673	[    2.413565] get drv_vbus is fail, 84
  2674	[    2.413573] get ohci3-controller, regulator_io is no nocare
  2675	[    2.413910] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  2676	[    2.413960] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2677	[    2.413986] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  2678	[    2.414065] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  2679	[    2.471929] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  2680	[    2.471939] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  2681	[    2.471947] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  2682	[    2.471954] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  2683	[    2.471961] usb usb6: SerialNumber: sunxi-ohci
  2684	[    2.472806] hub 6-0:1.0: USB hub found
  2685	[    2.472849] hub 6-0:1.0: 1 port detected
  2686	[    2.473771] ohci-platform: OHCI generic platform driver
  2687	[    2.474527] usbcore: registered new interface driver uas
  2688	[    2.474694] usbcore: registered new interface driver usb-storage
  2689	[    2.474789] usbcore: registered new interface driver ums-alauda
  2690	[    2.474870] usbcore: registered new interface driver ums-cypress
  2691	[    2.474939] usbcore: registered new interface driver ums-datafab
  2692	[    2.475007] usbcore: registered new interface driver ums_eneub6250
  2693	[    2.475076] usbcore: registered new interface driver ums-freecom
  2694	[    2.475158] usbcore: registered new interface driver ums-isd200
  2695	[    2.475234] usbcore: registered new interface driver ums-jumpshot
  2696	[    2.475307] usbcore: registered new interface driver ums-karma
  2697	[    2.475380] usbcore: registered new interface driver ums-onetouch
  2698	[    2.475481] usbcore: registered new interface driver ums-realtek
  2699	[    2.475559] usbcore: registered new interface driver ums-sddr09
  2700	[    2.475631] usbcore: registered new interface driver ums-sddr55
  2701	[    2.475702] usbcore: registered new interface driver ums-usbat
  2702	[    2.475853] usb_serial_number:20080411
  2703	[    2.477083] input: sunxi-keyboard as /devices/virtual/input/input0
  2704	[    2.477700] usbcore: registered new interface driver xpad
  2705	[    2.477853] usbcore: registered new interface driver usb_acecad
  2706	[    2.477944] usbcore: registered new interface driver aiptek
  2707	[    2.478024] usbcore: registered new interface driver gtco
  2708	[    2.478124] usbcore: registered new interface driver hanwang
  2709	[    2.478201] usbcore: registered new interface driver kbtab
  2710	[    2.478668] axp2101_pek: axp2101-pek can not register without irq
  2711	[    2.478691] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  2712	[    2.480181] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  2713	[    2.480245] sunxi-rtc rtc: RTC enabled
  2714	[    2.480724] i2c /dev entries driver
  2715	[    2.481555] lirc_dev: IR Remote Control driver registered, major 244
  2716	[    2.481567] IR NEC protocol handler initialized
  2717	[    2.481573] IR RC5(x/sz) protocol handler initialized
  2718	[    2.481579] IR RC6 protocol handler initialized
  2719	[    2.481585] IR JVC protocol handler initialized
  2720	[    2.481590] IR Sony protocol handler initialized
  2721	[    2.481596] IR SANYO protocol handler initialized
  2722	[    2.481602] IR Sharp protocol handler initialized
  2723	[    2.481608] IR MCE Keyboard/mouse protocol handler initialized
  2724	[    2.481614] IR LIRC bridge handler initialized
  2725	[    2.481619] IR XMP protocol handler initialized
  2726	[    2.482153] sunxi_ir_startup: get ir protocol failed
  2727	[    2.482194] 7040000.s_cir supply ir0 not found, using dummy regulator
  2728	[    2.482379] Registered IR keymap rc_map_sunxi
  2729	[    2.482775] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  2730	[    2.483007] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  2731	[    2.483989] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  2732	[    2.484611] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  2733	[    2.485311] sunxi cedar version 0.1
  2734	[    2.485516] VE: install start!!!
  2735
  2736	[    2.485702] cedar_ve: cedar-ve the get irq is 278
  2737	[    2.486319] VE: get debugfs_mpp_root is NULL, please check mpp
  2738
  2739	[    2.486334] VE: sunxi ve debug register driver failed!
  2740
  2741	[    2.489573] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  2742	[    2.490885] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  2743	[    2.491279] Bluetooth: HCI UART driver ver 2.3
  2744	[    2.491291] Bluetooth: HCI UART protocol H4 registered
  2745	[    2.491297] Bluetooth: HCI UART protocol LL registered
  2746	[    2.491302] Bluetooth: HCI UART protocol Three-wire (H5) registered
  2747	[    2.495501] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  2748	[    2.495517] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  2749	[    2.495530] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  2750	[    2.495542] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  2751	[    2.495555] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  2752	[    2.495572] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  2753	[    2.495970] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  2754	[    2.496084] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  2755	[    2.496282] sunxi-mmc sdc0: No vmmc regulator found
  2756	[    2.496289] sunxi-mmc sdc0: No vqmmc regulator found
  2757	[    2.496295] sunxi-mmc sdc0: No vdmmc regulator found
  2758	[    2.496301] sunxi-mmc sdc0: No vd33sw regulator found
  2759	[    2.496308] sunxi-mmc sdc0: No vd18sw regulator found
  2760	[    2.496314] sunxi-mmc sdc0: No vq33sw regulator found
  2761	[    2.496320] sunxi-mmc sdc0: No vq18sw regulator found
  2762	[    2.497017] sunxi-mmc sdc0: set host busy
  2763	[    2.497119] sunxi-mmc sdc0: Got CD GPIO
  2764	[    2.497501] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  2765	[    2.497535] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  2766	[    2.511099] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2767	[    2.528131] sunxi-mmc sdc0: detmode:gpio irq
  2768	[    2.528165] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2769	[    2.530678] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2770	[    2.532042] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  2771	[    2.532176] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  2772	[    2.532317] sunxi-mmc sdc1: No vmmc regulator found
  2773	[    2.532324] sunxi-mmc sdc1: No vqmmc regulator found
  2774	[    2.532330] sunxi-mmc sdc1: No vdmmc regulator found
  2775	[    2.532336] sunxi-mmc sdc1: No vd33sw regulator found
  2776	[    2.532342] sunxi-mmc sdc1: No vd18sw regulator found
  2777	[    2.532349] sunxi-mmc sdc1: No vq33sw regulator found
  2778	[    2.532355] sunxi-mmc sdc1: No vq18sw regulator found
  2779	[    2.532736] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2780	[    2.533061] sunxi-mmc sdc1: set host busy
  2781	[    2.533143] mmc:failed to get gpios
  2782	[    2.533427] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  2783	[    2.535221] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2784	[    2.547830] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2785	[    2.558892] mmc0: host does not support reading read-only switch, assuming write-enable
  2786	[    2.560754] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  2787	[    2.560830] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  2788	[    2.560973] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  2789	[    2.561064] mmc0: new high speed SDXC card at address 0001
  2790	[    2.562158] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  2791	[    2.563656]  mmcblk0: p1
  2792	[    2.564494] sunxi-mmc sdc1: detmode:manually by software
  2793	[    2.566675] ledtrig-cpu: registered to indicate activity on CPUs
  2794	[    2.567419] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  2795	[    2.568269] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  2796	[    2.568310] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2797	[    2.570817] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  2798	[    2.572739] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  2799	[    2.573579] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  2800	[    2.574441] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  2801	[    2.574713] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  2802	[    2.574720] sunxi_emce_probe()590emce hw init failed!
  2803	[    2.574746] emce: probe of emce failed with error -2
  2804	[    2.575045] hidraw: raw HID events driver (C) Jiri Kosina
  2805	[    2.575289] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  2806	[    2.575327] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  2807	[    2.580189] usbcore: registered new interface driver usbhid
  2808	[    2.580198] usbhid: USB HID core driver
  2809	[    2.581715] optee: probing for conduit method from DT.
  2810	[    2.581728] optee: api uid mismatch
  2811	[    2.582253] usbcore: registered new interface driver snd-usb-audio
  2812	[    2.583847] [sunxi_hdmi_codec_init] driver and deivce register finished.
  2813	[    2.585637] [sunxi_internal_codec_probe]:get audio avcc failed
  2814	[    2.585677] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  2815	[    2.585942] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  2816	[    2.588500] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  2817	[    2.590538] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  2818	[    2.590551] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  2819	[    2.592790] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  2820	[    2.592813] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  2821	[    2.596752] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  2822	[    2.598160] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  2823	[    2.600018] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  2824	[    2.603083] pktgen: Packet Generator for packet performance testing. Version: 2.75
  2825	[    2.603504] u32 classifier
  2826	[    2.603511]     Actions configured
  2827	[    2.603523] Netfilter messages via NETLINK v0.30.
  2828	[    2.603549] nfnl_acct: registering with nfnetlink.
  2829	[    2.603885] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  2830	[    2.604138] ctnetlink v0.93: registering with nfnetlink.
  2831	[    2.604987] xt_time: kernel timezone is -0000
  2832	[    2.605012] IPVS: Registered protocols (TCP, UDP)
  2833	[    2.605123] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  2834	[    2.605253] IPVS: Creating netns size=1928 id=0
  2835	[    2.605383] IPVS: ipvs loaded.
  2836	[    2.605391] IPVS: [rr] scheduler registered.
  2837	[    2.605488] ipip: IPv4 and MPLS over IPv4 tunneling driver
  2838	[    2.606202] gre: GRE over IPv4 demultiplexor driver
  2839	[    2.606212] ip_gre: GRE over IPv4 tunneling driver
  2840	[    2.607545] IPv4 over IPsec tunneling driver
  2841	[    2.608494] ip_tables: (C) 2000-2006 Netfilter Core Team
  2842	[    2.608770] arp_tables: arp_tables: (C) 2002 David S. Miller
  2843	[    2.608838] Initializing XFRM netlink socket
  2844	[    2.608870] IPsec XFRM device driver
  2845	[    2.609700] NET: Registered protocol family 10
  2846	[    2.611853] mip6: Mobile IPv6
  2847	[    2.611892] ip6_tables: (C) 2000-2006 Netfilter Core Team
  2848	[    2.613162] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  2849	[    2.615363] NET: Registered protocol family 17
  2850	[    2.615406] NET: Registered protocol family 15
  2851	[    2.615566] Bridge firewalling registered
  2852	[    2.615697] Bluetooth: RFCOMM TTY layer initialized
  2853	[    2.615713] Bluetooth: RFCOMM socket layer initialized
  2854	[    2.615745] Bluetooth: RFCOMM ver 1.11
  2855	[    2.615759] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  2856	[    2.615764] Bluetooth: BNEP filters: protocol multicast
  2857	[    2.615778] Bluetooth: BNEP socket layer initialized
  2858	[    2.615784] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  2859	[    2.615797] Bluetooth: HIDP socket layer initialized
  2860	[    2.615884] l2tp_core: L2TP core driver, V2.0
  2861	[    2.615900] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  2862	[    2.615906] 8021q: 802.1Q VLAN Support v1.8
  2863	[    2.616104] sctp: Hash tables configured (bind 256/256)
  2864	[    2.616687] Key type dns_resolver registered
  2865	[    2.616828] Registered cp15_barrier emulation handler
  2866	[    2.616841] Registered setend emulation handler
  2867	[    2.617802] registered taskstats version 1
  2868	[    2.629196] zswap: default zpool zbud not available
  2869	[    2.629204] zswap: pool creation failed
  2870	[    2.632039] Btrfs loaded, crc32c=crc32c-arm64-hw
  2871	[    2.632775] HDMI 2.0 driver init start!
  2872	[    2.632791] boot_hdmi=true
  2873	[    2.633610] Can not find the node of esm
  2874	[    2.633629] ERROR: pinctrl_get for HDMI2.0 DDC fail
  2875	[    2.633715] Get hdmi_power0:vcc-hdmi
  2876	[    2.633754] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  2877	[    2.633931] Get hdmi_power1:vdd-hdmi
  2878	[    2.633956] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  2879	[    2.635580] hdmi_cec_init
  2880	[    2.636048] [DISP] disp_device_attached,line:146:
  2881	[    2.636057] attached ok, mgr0<-->device0, type=4
  2882	[    2.636067] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  2883	[    2.636080] [DISP] disp_hdmi_set_mode,line:648:
  2884	[    2.636084] hdmi_set_mode is null!
  2885	[    2.638146] HDMI2.0 module init end
  2886	[    2.649346] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  2887	[    2.652771] cpu cpu1: opp_list_debug_create_link: Failed to create link
  2888	[    2.652782] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  2889	[    2.652814] cpu cpu2: opp_list_debug_create_link: Failed to create link
  2890	[    2.652822] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  2891	[    2.652852] cpu cpu3: opp_list_debug_create_link: Failed to create link
  2892	[    2.652859] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  2893	[    2.655207] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  2894	[    2.656131] get det_vbus is fail, 84
  2895	[    2.656139] get id is fail, 84
  2896	[    2.656631] sunxi-rtc rtc: setting system clock to 2023-09-25 15:17:35 UTC (1695655055)
  2897	[    2.660427] ALSA device list:
  2898	[    2.660434]   #0: audiocodec
  2899	[    2.660438]   #1: sndahub
  2900	[    2.660441]   #2: sndhdmi
  2901	[    2.662096] Freeing unused kernel memory: 3008K
  2902	[    2.708138] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  2903	[    2.710072] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  2904	[    2.713113] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  2905	[    2.782119] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  2906	[    2.944603] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  2907	[    3.044494] HDMI cable is connected
  2908	[    3.294463] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  2909	[    3.514909] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  2910	[    3.514918] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  2911	[    3.514923] usb 4-1: Product: Rapoo 2.4G Wireless Device
  2912	[    3.514928] usb 4-1: Manufacturer: RAPOO
  2913	[    3.522735] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  2914	[    3.523135] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  2915	[    3.528604] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  2916	[    3.585698] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  2917	[    3.590146] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  2918	[    3.646478] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  2919	[    4.191576] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  2920	[    5.116950] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  2921	[    5.117505] cgroup: cgroup2: unknown option "nsdelegate"
  2922	[    5.137834] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  2923	[    5.137866] systemd[1]: Detected architecture arm64.
  2924	[    5.139125] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  2925	[    5.156504] systemd[1]: Hostname set to <opi>.
  2926	[    5.183760] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  2927	[    6.640306] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  2928	[    6.827825]
  2929	               insmod_device_driver
  2930
  2931	[    6.828068] device_chose finished 124!
  2932	[    7.127061] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  2933	[    7.365547] systemd[1]: Queued start job for default target graphical.target.
  2934	[    7.372711] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  2935	[    7.374948] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  2936	[    7.377204] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  2937	[    7.378599] systemd[1]: Created slice user.slice - User and Session Slice.
  2938	[    7.379271] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  2939	[    7.379830] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  2940	[    7.380160] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  2941	[    7.380639] systemd[1]: Reached target slices.target - Slice Units.
  2942	[    7.380944] systemd[1]: Reached target swap.target - Swaps.
  2943	[    7.381324] systemd[1]: Reached target time-set.target - System Time Set.
  2944	[    7.381840] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  2945	[    7.398961] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  2946	[    7.400065] systemd[1]: Listening on syslog.socket - Syslog Socket.
  2947	[    7.400994] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  2948	[    7.401758] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  2949	[    7.403353] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  2950	[    7.404341] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  2951	[    7.405470] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  2952	[    7.407607] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  2953	[    7.408607] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  2954	[    7.412518] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  2955	[    7.417120] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  2956	[    7.422120] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  2957	[    7.423287] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  2958	[    7.424224] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  2959	[    7.432188] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  2960	[    7.437584] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  2961	[    7.443303] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  2962	[    7.449716] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  2963	[    7.457266] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  2964	[    7.465871] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  2965	[    7.475426] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  2966	[    7.488350] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  2967	[    7.495482] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  2968	[    7.496895] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  2969	[    7.507167] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  2970	[    7.513093] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  2971	[    7.518779] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  2972	[    7.523221] fuse init (API version 7.26)
  2973	[    7.530103] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  2974	[    7.532552] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  2975	[    7.534813] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  2976	[    7.537693] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  2977	[    7.541476] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  2978	[    7.545846] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  2979	[    7.547023] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  2980	[    7.549690] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  2981	[    7.550392] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  2982	[    7.552720] systemd[1]: modprobe@drm.service: Deactivated successfully.
  2983	[    7.553388] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  2984	[    7.562554] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  2985	[    7.577023] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  2986	[    7.578523] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  2987	[    7.602460] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  2988	[    7.624772] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  2989	[    7.632528] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  2990	[    7.633381] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  2991	[    7.633393] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  2992	[    7.633582] spidev spi1.1: Deleting spi1.1
  2993	[    7.634599] fbtft_device: GPIOS used by 'fb_st7735r':
  2994	[    7.634607] fbtft_device: 'reset' = GPIO73
  2995	[    7.634611] fbtft_device: 'dc' = GPIO70
  2996	[    7.634623] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  2997	[    7.634629] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  2998	[    7.638405] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  2999	[    7.656012] systemd[1]: modprobe@loop.service: Deactivated successfully.
  3000	[    7.656785] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  3001	[    7.659107] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  3002	[    7.673950] WCN: marlin_init entry!
  3003	[    7.675259] WCN: marlin_parse_dt reset gpio=211
  3004	[    7.675269] WCN_ERR: gpio reset request err: 211
  3005	[    7.675274] WCN: wcn config bt wake host
  3006	[    7.675777] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  3007	[    7.675923] WCN: wcn config wifi wake host
  3008	[    7.675946] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  3009	[    7.679404] sdiohal:sdiohal_init ok
  3010	[    7.680423] WCN: marlin_probe ok!
  3011	[    7.689223] mtty_probe init device addr: 0xffffffc03b686f00
  3012	[    7.689416] -->rfkill_bluetooth_init
  3013	[    7.689618] <--rfkill_bluetooth_init
  3014	[    7.714683] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  3015	[    7.720905] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  3016	[    7.721982] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  3017	[    7.732239] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  3018	[    7.733223] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  3019	[    7.741392] WCN: start_marlin [MARLIN_WIFI]
  3020	[    7.741412] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  3021	[    7.741416] WCN: the first power on start
  3022	[    7.747227] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  3023	[    7.768939] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  3024	[    7.772395] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  3025	[    7.802956] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  3026	[    7.816492] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  3027	[    7.845127] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  3028	[    7.857896] WCN: marlin chip en pull up
  3029	[    7.884532] sdiohal:sdiohal_scan_card
  3030	[    7.884553] sunxi-wlan soc@03000000:wlan: bus_index: 1
  3031	[    7.884614] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  3032	[    7.904468] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3033	[    7.921956] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  3034	[    7.922803] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  3035	[    7.922920] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3036	[    7.925453] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3037	[    7.928540] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3038	[    7.940265] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  3039	[    7.942334] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  3040	[    7.944519] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3041	[    7.948376] systemd[1]: Mounting tmp.mount - /tmp...
  3042	[    7.957194] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  3043	[    7.957973] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  3044	[    7.958056] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  3045	[    7.958670] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  3046	[    7.959237] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  3047	[    7.959428] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  3048	[    7.959447] WCN: marlin_scan_finish!
  3049	[    7.959450] sdiohal:probe ok
  3050	[    7.959497] sdiohal:scan end!
  3051	[    7.959503] WCN: then marlin start to download
  3052	[    7.959525] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  3053	[    7.980615] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  3054	[    7.985643] systemd[1]: Mounted tmp.mount - /tmp.
  3055	[    7.988355] systemd[1]: Reached target local-fs.target - Local File Systems.
  3056	[    7.993461] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  3057	[    7.998743] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  3058	[    8.004337] systemd[1]: Starting console-setup.service - Set console font and keymap...
  3059	[    8.009607] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  3060	[    8.020955] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  3061	[    8.028067] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  3062	[    8.031494] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  3063	[    8.065241] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  3064	[    8.077433] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  3065	[    8.084326] systemd[1]: Finished console-setup.service - Set console font and keymap.
  3066	[    8.091032] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  3067	[    8.097665] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  3068	[    8.109390] WCN: combin_img 0 marlin_firmware_write finish and successful
  3069	[    8.109562] WCN: marlin_start_run read reset reg val:0x1
  3070	[    8.109566] WCN: after do marlin_start_run reset reg val:0x0
  3071	[    8.109773] WCN: s_marlin_bootup_time=8109768635
  3072	[    8.114785] WCN: clock mode: TSX
  3073	[    8.115021] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  3074	[    8.141405] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  3075	[    8.155222] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  3076	[    8.157585] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  3077	[    8.158802] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  3078	[    8.162103] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  3079	[    8.164954] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
  3080	[    8.165457] systemd[1]: Reached target network-pre.target - Preparation for Network.
  3081	[    8.168116] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
  3082	[    8.168126] WCN: sdio_config bt_wake_host trigger:[high]
  3083	[    8.168129] WCN: sdio_config irq:[inband]
  3084	[    8.168132] WCN: sdio_config wl_wake_host trigger:[high]
  3085	[    8.168138] WCN: sdio_config wake_host_level_duration_time:[20ms]
  3086	[    8.168142] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
  3087	[    8.168148] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
  3088	[    8.168533] WCN: marlin_write_cali_data finish
  3089	[    8.168740] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  3090	[    8.194691] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  3091	[    8.212239] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  3092	[    8.221342] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  3093	[    8.247979] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  3094	[    8.274697] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  3095	[    8.301395] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
  3096	[    8.301405] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
  3097	[    8.301421] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
  3098	[    8.301957] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
  3099	[    8.328091] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
  3100	[    8.328099] sdiohal:sdiohal_runtime_get entry
  3101	[    8.328272] WCN: get_cp2_version entry!
  3102	[    8.330032] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
  3103	[    8.330069] WCN: switch_cp2_log - close entry!
  3104	[    8.331459] WCN: WCND at cmd read:OK
  3105	[    8.331968] WCN: then marlin download finished and run ok
  3106	[    8.331979] WCN: start_loopcheck
  3107	[    8.345667] WCN: get_board_ant_num [one_ant]
  3108	[    8.345678] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
  3109	[    8.406865] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
  3110	[    8.412188] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  3111	[    8.422605] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  3112	[    8.473090] zram: Added device: zram0
  3113	[    8.474165] zram: Added device: zram1
  3114	[    8.475510] zram: Added device: zram2
  3115	[    8.511484] zswap: can't enable, initialization failed
  3116	[    8.512812] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  3117	[    8.521326] systemd[1]: Starting networking.service - Raise network interfaces...
  3118	[    8.560988] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  3119	[    8.574225] zram0: detected capacity change from 0 to 506396672
  3120	[    8.576780] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  3121	[    8.650334] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  3122	[    8.663742] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  3123	[    8.666032] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  3124	[    8.667282] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  3125	[    8.667702] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  3126	[    9.139019] systemd[1]: Finished networking.service - Raise network interfaces.
  3127	[    9.974376] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  3128	[   10.034288] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  3129	[   10.270974] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  3130	[   10.719968] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  3131	[   10.731951] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  3132	[   10.797388] sunxi-bt soc@03000000:bt: set block: 0
  3133	[   10.820915] bluetooth_set_power: start_block=0
  3134	[   10.820927] WCN: start_marlin [MARLIN_BLUETOOTH]
  3135	[   10.820936] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
  3136	[   10.820941] WCN: marlin have open, GNSS is closed
  3137	[   10.820947] bluetooth_set_power: end_block=0
  3138	[   10.843784] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  3139	[   10.959171] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  3140	[   10.959468] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  3141	[   10.960277] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  3142	[   10.966890] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  3143	[   10.974768] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  3144	[   10.983934] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  3145	[   10.992794] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  3146	[   10.997628] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  3147	[   10.998777] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  3148	[   11.003515] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  3149	[   11.004860] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  3150	[   11.009415] systemd[1]: modprobe@loop.service: Deactivated successfully.
  3151	[   11.010418] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  3152	[   11.013885] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  3153	[   11.014193] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  3154	[   11.051694] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  3155	[   11.052227] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  3156	[   11.068227] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  3157	[   11.070263] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  3158	[   11.076378] systemd[1]: Starting brltty.service - Braille Device Support...
  3159	[   11.622057] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  3160	[   11.766120] zram1: detected capacity change from 0 to 52428800
  3161	[   11.821739] systemd[1]: Started brltty.service - Braille Device Support.
  3162	[   11.840742] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  3163	[   15.854019] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  3164	[   15.869877] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  3165	[   15.898811] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  3166	[   15.959002] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  3167	[   19.658844] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  3168	[   19.665165] systemd[1]: Starting systemd-journald.service - Journal Service...
  3169	[   19.940069] systemd-journald[1922]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
  3170	[   19.940091] systemd-journald[1922]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  3171	[   19.947202] systemd[1]: Started systemd-journald.service - Journal Service.
  3172	[   19.993653] systemd-journald[1922]: Received client request to flush runtime journal.
  3173	[   20.245138] IPVS: Creating netns size=1928 id=1
  3174
  3175	### armbian-release:
  3176
  3177	# PLEASE DO NOT EDIT THIS FILE
  3178	BOARD=orangepizero2
  3179	BOARD_NAME="Orange Pi Zero2"
  3180	BOARDFAMILY=sun50iw9
  3181	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  3182	BUILD_REPOSITORY_COMMIT=ac829eb6
  3183	LINUXFAMILY=sun50iw9
  3184	ARCH=arm64
  3185	IMAGE_TYPE=stable
  3186	BOARD_TYPE=conf
  3187	INITRD_ARCH=arm
  3188	KERNEL_IMAGE_TYPE=Image
  3189	FORCE_BOOTSCRIPT_UPDATE=yes
  3190	VENDOR=Armbian
  3191	BOOTSCRIPT_FORCE_UPDATE="yes"
  3192	BOOTSCRIPT_DST="boot.cmd"
  3193	VERSION=23.8.1
  3194	REVISION=23.8.1
  3195	BRANCH=legacy
  3196
  3197	### boot environment:
  3198
  3199	verbosity=1
  3200	console=serial
  3201	#disp_mode=1080p60
  3202	#fb0_width=1280
  3203	#fb0_height=720
  3204	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  3205	rootfstype=ext4
  3206	overlays=spi-spidev
  3207	param_spidev_spi_bus=1
  3208	param_spidev_spi_cs=1
  3209	extraargs=fbcon=map:1
  3210	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  3211
  3212	### lsusb:
  3213
  3214	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3215	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3216	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3217	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3218	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  3219	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  3220	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  3221
  3222	### lscpu:
  3223
  3224	Architecture:        aarch64
  3225	CPU op-mode(s):      32-bit, 64-bit
  3226	Byte Order:          Little Endian
  3227	CPU(s):              4
  3228	On-line CPU(s) list: 0-3
  3229	Vendor ID:           ARM
  3230	Model name:          Cortex-A53
  3231	Model:               4
  3232	Thread(s) per core:  1
  3233	Core(s) per cluster: 4
  3234	Socket(s):           -
  3235	Cluster(s):          1
  3236	Stepping:            r0p4
  3237	CPU(s) scaling MHz:  100%
  3238	CPU max MHz:         1512.0000
  3239	CPU min MHz:         480.0000
  3240	BogoMIPS:            48.00
  3241	Flags:               fp asimd aes pmull sha1 sha2 crc32
  3242
  3243	### cpuinfo:
  3244
  3245	processor	: 0
  3246	BogoMIPS	: 48.00
  3247	Features	: fp asimd aes pmull sha1 sha2 crc32
  3248	CPU implementer	: 0x41
  3249	CPU architecture: 8
  3250	CPU variant	: 0x0
  3251	CPU part	: 0xd03
  3252	CPU revision	: 4
  3253
  3254	processor	: 1
  3255	BogoMIPS	: 48.00
  3256	Features	: fp asimd aes pmull sha1 sha2 crc32
  3257	CPU implementer	: 0x41
  3258	CPU architecture: 8
  3259	CPU variant	: 0x0
  3260	CPU part	: 0xd03
  3261	CPU revision	: 4
  3262
  3263	processor	: 2
  3264	BogoMIPS	: 48.00
  3265	Features	: fp asimd aes pmull sha1 sha2 crc32
  3266	CPU implementer	: 0x41
  3267	CPU architecture: 8
  3268	CPU variant	: 0x0
  3269	CPU part	: 0xd03
  3270	CPU revision	: 4
  3271
  3272	processor	: 3
  3273	BogoMIPS	: 48.00
  3274	Features	: fp asimd aes pmull sha1 sha2 crc32
  3275	CPU implementer	: 0x41
  3276	CPU architecture: 8
  3277	CPU variant	: 0x0
  3278	CPU part	: 0xd03
  3279	CPU revision	: 4
  3280
  3281
  3282	### meminfo:
  3283
  3284	MemTotal:         989056 kB
  3285	MemFree:          794528 kB
  3286	MemAvailable:     885284 kB
  3287	Buffers:           15604 kB
  3288	Cached:            82092 kB
  3289	SwapCached:            0 kB
  3290	Active:            66392 kB
  3291	Inactive:          53084 kB
  3292	Active(anon):      21848 kB
  3293	Inactive(anon):      656 kB
  3294	Active(file):      44544 kB
  3295	Inactive(file):    52428 kB
  3296	Unevictable:           0 kB
  3297	Mlocked:               0 kB
  3298	SwapTotal:        494524 kB
  3299	SwapFree:         494524 kB
  3300	Dirty:              6072 kB
  3301	Writeback:             0 kB
  3302	AnonPages:         21644 kB
  3303	Mapped:            24364 kB
  3304	Shmem:               824 kB
  3305	Slab:              33156 kB
  3306	SReclaimable:       9216 kB
  3307	SUnreclaim:        23940 kB
  3308	KernelStack:        2560 kB
  3309	PageTables:         1032 kB
  3310	NFS_Unstable:          0 kB
  3311	Bounce:                0 kB
  3312	WritebackTmp:          0 kB
  3313	CommitLimit:      989052 kB
  3314	Committed_AS:      77888 kB
  3315	VmallocTotal:   263061440 kB
  3316	VmallocUsed:           0 kB
  3317	VmallocChunk:          0 kB
  3318	CmaTotal:          16384 kB
  3319	CmaFree:            7468 kB
  3320	HugePages_Total:       0
  3321	HugePages_Free:        0
  3322	HugePages_Rsvd:        0
  3323	HugePages_Surp:        0
  3324	Hugepagesize:       2048 kB
  3325
  3326	### virtual memory:
  3327
  3328	vm.admin_reserve_kbytes = 8192
  3329	vm.block_dump = 0
  3330	vm.compact_unevictable_allowed = 1
  3331	vm.dirty_background_bytes = 0
  3332	vm.dirty_background_ratio = 10
  3333	vm.dirty_bytes = 0
  3334	vm.dirty_expire_centisecs = 3000
  3335	vm.dirty_ratio = 20
  3336	vm.dirtytime_expire_seconds = 43200
  3337	vm.dirty_writeback_centisecs = 500
  3338	vm.extfrag_threshold = 500
  3339	vm.extra_free_kbytes = 0
  3340	vm.hugepages_treat_as_movable = 0
  3341	vm.hugetlb_shm_group = 0
  3342	vm.laptop_mode = 0
  3343	vm.legacy_va_layout = 0
  3344	vm.lowmem_reserve_ratio = 256	32
  3345	vm.max_map_count = 65530
  3346	vm.min_free_kbytes = 3937
  3347	vm.mmap_min_addr = 4096
  3348	vm.mmap_rnd_bits = 18
  3349	vm.mmap_rnd_compat_bits = 11
  3350	vm.nr_hugepages = 0
  3351	vm.nr_overcommit_hugepages = 0
  3352	vm.nr_pdflush_threads = 0
  3353	vm.oom_dump_tasks = 1
  3354	vm.oom_kill_allocating_task = 0
  3355	vm.overcommit_kbytes = 0
  3356	vm.overcommit_memory = 0
  3357	vm.overcommit_ratio = 50
  3358	vm.page-cluster = 0
  3359	vm.panic_on_oom = 0
  3360	vm.percpu_pagelist_fraction = 0
  3361	vm.stat_interval = 1
  3362	vm.swappiness = 100
  3363	vm.user_reserve_kbytes = 29999
  3364	vm.vfs_cache_pressure = 100
  3365	vm.watermark_scale_factor = 10
  3366
  3367	### ip addr:
  3368
  3369	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  3370	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  3371	    inet XXX.XXX.0.1/8 scope host lo
  3372	       valid_lft forever preferred_lft forever
  3373	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3374	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  3375	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3376	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  3377	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  3378	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  3379	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  3380	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  3381	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  3382	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  3383	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  3384	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  3385	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  3386	    link/tunnel6 :: brd ::
  3387	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  3388	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  3389	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  3390	    link/tunnel6 :: brd ::
  3391	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  3392	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  3393
  3394	### partitions:
  3395
  3396	major minor  #blocks  name
  3397
  3398	 179        0   62410752 mmcblk0
  3399	 179        1   61763584 mmcblk0p1
  3400	 253        0     494528 zram0
  3401	 253        1      51200 zram1
  3402
  3403	### df:
  3404
  3405	udev            466M     0  466M   0% /dev
  3406	tmpfs            97M  884K   96M   1% /run
  3407	/dev/mmcblk0p1   58G  5.7G   52G  10% /
  3408	tmpfs           483M     0  483M   0% /dev/shm
  3409	tmpfs           5.0M     0  5.0M   0% /run/lock
  3410	tmpfs           483M  4.0K  483M   1% /tmp
  3411	/dev/zram1       47M  5.8M   38M  14% /var/log
  3412
  3413	### lsblk:
  3414
  3415	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  3416	mmcblk0             59.5G
  3417	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  3418	zram1                 50M /var/log
  3419	zram2                  0B
  3420
  3421	### zramctl:
  3422
  3423	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  3424	/dev/zram1 lz4            50M  5.6M  1.6M    2M       4 /var/log
  3425	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  3426
  3427	### mtab:
  3428
  3429	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3430	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  3431	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  3432
  3433	### mmc0:0001 info:
  3434
  3435	              manfid: 0x0000fe
  3436	                 cid: fe3432534431364720000000690091f5
  3437	               fwrev: 0x0
  3438	                 csd: 400e00325b590001dc277f800a40008b
  3439	                 ocr: 0x00200000
  3440	                type: SD
  3441	                date: 01/2009
  3442	               hwrev: 0x2
  3443	                 dsr: 0x404
  3444	              serial: 0x00000069
  3445	          erase_size: 512
  3446	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  3447	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  3448	                 scr: 0285808300000000
  3449	               oemid: 0x3432
  3450	preferred_erase_size: 4194304
  3451	                name: SD16G
  3452
  3453	### Boot system health:
  3454
  3455	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  3456	12:17:55  1512 MHz  1.17  39%  19%  13%   0%   6%   0%  50.2 °C  0/5
  3457	12:17:55  1512 MHz  1.17  92%  22%  22%   2%  45%   0%  50.2 °C  0/5
  3458	12:17:56  1512 MHz  1.17  99%  40%  53%   1%   3%   0%  50.2 °C  0/5
  3459	12:17:56  1512 MHz  1.17 100%  33%  59%   1%   5%   0%  49.4 °C  0/5
  3460	12:17:57  1512 MHz  1.17  92%  23%  28%   0%  38%   0%  49.4 °C  0/5
  3461
  3462	### Activated 1 lzo zram swap devices with 482MB each.
  3463	### Activated Armbian ramlog partition with lz4 compression
  3464
  3465	### Activated 1 lzo zram swap devices with 482MB each.
  3466	### Activated Armbian ramlog partition with lz4 compression
  3467
  3468	Mon Sep 25 02:17:34 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  3469
  3470	### dmesg:
  3471
  3472	[    0.000000] Booting Linux on physical CPU 0x0
  3473	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  3474	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  3475	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  3476	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  3477	[    0.000000] On node 0 totalpages: 262144
  3478	[    0.000000]   DMA zone: 4096 pages used for memmap
  3479	[    0.000000]   DMA zone: 0 pages reserved
  3480	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  3481	[    0.000000] psci: probing for conduit method from DT.
  3482	[    0.000000] psci: PSCIv1.0 detected in firmware.
  3483	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  3484	[    0.000000] psci: Trusted OS migration not required
  3485	[    0.000000] psci: SMC Calling Convention v1.0
  3486	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  3487	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  3488	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  3489	[    0.000000] Detected VIPT I-cache on CPU0
  3490	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  3491	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  3492	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  3493	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  3494	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  3495	[    0.000000] log_buf_len min size: 131072 bytes
  3496	[    0.000000] log_buf_len: 524288 bytes
  3497	[    0.000000] early log buf free: 129352(98%)
  3498	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  3499	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  3500	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  3501	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  3502	[    0.000000] Virtual kernel memory layout:
  3503	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  3504	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  3505	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  3506	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  3507	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  3508	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  3509	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  3510	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  3511	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  3512	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  3513	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  3514	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  3515	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  3516	[    0.000000] Preemptible hierarchical RCU implementation.
  3517	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  3518	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  3519	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  3520	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  3521	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  3522	[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  3523	[    0.000223] Console: colour dummy device 80x25
  3524	[    0.000237] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  3525	[    0.000245] pid_max: default: 32768 minimum: 301
  3526	[    0.000441] Security Framework initialized
  3527	[    0.000449] AppArmor: AppArmor disabled by boot time parameter
  3528	[    0.000563] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  3529	[    0.000569] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  3530	[    0.001849] sched-energy: CPU device node has no sched-energy-costs
  3531	[    0.001863] Invalid sched_group_energy for CPU0
  3532	[    0.001871] CPU0: update cpu_capacity 1024
  3533	[    0.008959] ASID allocator initialised with 32768 entries
  3534	[    0.027939] BOOTEVENT:        27.924665: ON
  3535	[    0.055908] Detected VIPT I-cache on CPU1
  3536	[    0.055961] Invalid sched_group_energy for CPU1
  3537	[    0.055964] CPU1: update cpu_capacity 1024
  3538	[    0.055967] CPU1: Booted secondary processor [410fd034]
  3539	[    0.079292] Detected VIPT I-cache on CPU2
  3540	[    0.079328] Invalid sched_group_energy for CPU2
  3541	[    0.079331] CPU2: update cpu_capacity 1024
  3542	[    0.079334] CPU2: Booted secondary processor [410fd034]
  3543	[    0.102694] Detected VIPT I-cache on CPU3
  3544	[    0.102727] Invalid sched_group_energy for CPU3
  3545	[    0.102731] CPU3: update cpu_capacity 1024
  3546	[    0.102733] CPU3: Booted secondary processor [410fd034]
  3547	[    0.102813] Brought up 4 CPUs
  3548	[    0.102821] SMP: Total of 4 processors activated.
  3549	[    0.102829] CPU features: detected feature: 32-bit EL0 Support
  3550	[    0.102835] CPU features: detected feature: Kernel page table isolation (KPTI)
  3551	[    0.106604] CPU: All CPU(s) started at EL1
  3552	[    0.106626] alternatives: patching kernel code
  3553	[    0.106803] Invalid sched_group_energy for CPU3
  3554	[    0.106813] CPU3: update max cpu_capacity 1024
  3555	[    0.106818] Invalid sched_group_energy for Cluster3
  3556	[    0.106823] Invalid sched_group_energy for CPU2
  3557	[    0.106829] Invalid sched_group_energy for Cluster2
  3558	[    0.106834] Invalid sched_group_energy for CPU1
  3559	[    0.106840] Invalid sched_group_energy for Cluster1
  3560	[    0.106845] Invalid sched_group_energy for CPU0
  3561	[    0.106850] Invalid sched_group_energy for Cluster0
  3562	[    0.108277] devtmpfs: initialized
  3563	[    0.112711] CPU1: update max cpu_capacity 1024
  3564	[    0.143411] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  3565	[    0.143432] futex hash table entries: 1024 (order: 5, 131072 bytes)
  3566	[    0.144088] xor: measuring software checksum speed
  3567	[    0.176249]    8regs     :  1933.200 MB/sec
  3568	[    0.209628]    8regs_prefetch:  1720.800 MB/sec
  3569	[    0.243016]    32regs    :  2287.200 MB/sec
  3570	[    0.276403]    32regs_prefetch:  1935.600 MB/sec
  3571	[    0.276409] xor: using function: 32regs (2287.200 MB/sec)
  3572	[    0.276469] atomic64_test: passed
  3573	[    0.276476] pinctrl core: initialized pinctrl subsystem
  3574	[    0.277649] NET: Registered protocol family 16
  3575	[    0.278817] dump_class_init,861, success
  3576	[    0.293122] cpuidle: using governor menu
  3577	[    0.294524] sunxi iommu: irq = 8
  3578	[    0.294861] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  3579	[    0.294879] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  3580	[    0.296271] DMA: preallocated 256 KiB pool for atomic allocations
  3581	[    0.297666] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  3582	[    0.312044] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  3583	[    0.316075] iommu: Adding device 1c0e000.ve to group 0
  3584	[    0.316634] iommu: Adding device 1c00000.vp9 to group 0
  3585	[    0.328200] iommu: Adding device 1000000.disp to group 0
  3586	[    0.329618] iommu: Adding device 1480000.g2d to group 0
  3587	[    0.332832] iommu: Adding device csi0 to group 0
  3588	[    0.333308] iommu: Adding device csi1 to group 0
  3589	[    0.334535] iommu: Adding device 6600800.vind:scaler@0 to group 0
  3590	[    0.334833] iommu: Adding device 6600800.vind:scaler@1 to group 0
  3591	[    0.335141] iommu: Adding device 6600800.vind:scaler@2 to group 0
  3592	[    0.335436] iommu: Adding device 6600800.vind:scaler@3 to group 0
  3593	[    0.335725] iommu: Adding device 6600800.vind:scaler@4 to group 0
  3594	[    0.336009] iommu: Adding device 6600800.vind:scaler@5 to group 0
  3595	[    0.337039] iommu: Adding device vinc0 to group 0
  3596	[    0.337542] iommu: Adding device vinc1 to group 0
  3597	[    0.338994] iommu: Adding device 1420000.deinterlace to group 0
  3598	[    0.377854] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  3599	[    0.433963] raid6: int64x1  gen()   391 MB/s
  3600	[    0.490701] raid6: int64x1  xor()   365 MB/s
  3601	[    0.547455] raid6: int64x2  gen()   591 MB/s
  3602	[    0.604205] raid6: int64x2  xor()   512 MB/s
  3603	[    0.660963] raid6: int64x4  gen()   840 MB/s
  3604	[    0.717685] raid6: int64x4  xor()   629 MB/s
  3605	[    0.774389] raid6: int64x8  gen()   964 MB/s
  3606	[    0.831166] raid6: int64x8  xor()   655 MB/s
  3607	[    0.887951] raid6: neonx1   gen()   648 MB/s
  3608	[    0.944646] raid6: neonx1   xor()   641 MB/s
  3609	[    1.001423] raid6: neonx2   gen()   976 MB/s
  3610	[    1.058128] raid6: neonx2   xor()   819 MB/s
  3611	[    1.114888] raid6: neonx4   gen()  1287 MB/s
  3612	[    1.171618] raid6: neonx4   xor()   965 MB/s
  3613	[    1.228373] raid6: neonx8   gen()  1323 MB/s
  3614	[    1.285089] raid6: neonx8   xor()   991 MB/s
  3615	[    1.285094] raid6: using algorithm neonx8 gen() 1323 MB/s
  3616	[    1.285099] raid6: .... xor() 991 MB/s, rmw enabled
  3617	[    1.285104] raid6: using intx1 recovery algorithm
  3618	[    1.285271] pwm module init!
  3619	[    1.289618] sunxi-pm debug v3.10
  3620	[    1.290703] SCSI subsystem initialized
  3621	[    1.291325] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  3622	[    1.291408] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  3623	[    1.291528] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  3624	[    1.292011] spi spi0: master is unqueued, this is deprecated
  3625	[    1.292319] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  3626	[    1.292903] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  3627	[    1.292982] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  3628	[    1.293098] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  3629	[    1.293547] spi spi1: master is unqueued, this is deprecated
  3630	[    1.293854] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  3631	[    1.294585] usbcore: registered new interface driver usbfs
  3632	[    1.294684] usbcore: registered new interface driver hub
  3633	[    1.294763] usbcore: registered new device driver usb
  3634	[    1.295046] sunxi_i2c_adap_init()2522 - init
  3635	[    1.295603] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  3636	[    1.295695] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  3637	[    1.295702] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  3638	[    1.295717] twi3 supply twi not found, using dummy regulator
  3639	[    1.295792] twi_request_gpio()451 - [i2c3] init name: twi3
  3640	[    1.296525] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  3641	[    1.296604] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  3642	[    1.296611] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  3643	[    1.296625] twi5 supply twi not found, using dummy regulator
  3644	[    1.296702] twi_request_gpio()451 - [i2c5] init name: twi5
  3645	[    1.297164] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  3646	[    1.310180] axp806-aldo2: Bringing 700000uV into 3300000-3300000uV
  3647	[    1.313858] axp806-aldo3: Bringing 700000uV into 3300000-3300000uV
  3648	[    1.315058] random: fast init done
  3649	[    1.330654] axp20x-i2c 5-0036: AXP20X driver loaded
  3650	[    1.331139] media: Linux media interface: v0.10
  3651	[    1.331217] Linux video capture interface: v2.00
  3652	[    1.332015] Advanced Linux Sound Architecture Driver Initialized.
  3653	[    1.332808] Bluetooth: Core ver 2.22
  3654	[    1.332882] NET: Registered protocol family 31
  3655	[    1.332888] Bluetooth: HCI device and connection manager initialized
  3656	[    1.332906] Bluetooth: HCI socket layer initialized
  3657	[    1.332919] Bluetooth: L2CAP socket layer initialized
  3658	[    1.332958] Bluetooth: SCO socket layer initialized
  3659	[    1.333781] [DISP]disp_module_init
  3660	[    1.335074] [DISP] parser_disp_init_para,line:1403:
  3661	[    1.335083] of_property_read fb0_width fail
  3662	[    1.335094] [DISP] disp_init,line:2215:
  3663	[    1.335100] smooth display screen:0 type:4 mode:10
  3664	[    1.352552] [DISP]disp_module_init finish
  3665	[    1.353418] clocksource: Switched to clocksource arch_sys_counter
  3666	[    1.353675] VFS: Disk quotas dquot_6.6.0
  3667	[    1.353767] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  3668	[    1.354501] Console: switching to colour frame buffer device 240x67
  3669	[    1.397742] NET: Registered protocol family 2
  3670	[    1.397862] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  3671	[    1.417007] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  3672	[    1.417080] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  3673	[    1.417203] TCP: Hash tables configured (established 8192 bind 8192)
  3674	[    1.417289] UDP hash table entries: 512 (order: 2, 16384 bytes)
  3675	[    1.417318] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  3676	[    1.417641] NET: Registered protocol family 1
  3677	[    1.418269] RPC: Registered named UNIX socket transport module.
  3678	[    1.418274] RPC: Registered udp transport module.
  3679	[    1.418277] RPC: Registered tcp transport module.
  3680	[    1.418281] RPC: Registered tcp NFSv4.1 backchannel transport module.
  3681	[    1.418556] Trying to unpack rootfs image as initramfs...
  3682	[    2.173216] Freeing initrd memory: 17256K
  3683	[    2.174337] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  3684	[    2.178251] audit: initializing netlink subsys (disabled)
  3685	[    2.178333] audit: type=2000 audit(2.173:1): initialized
  3686	[    2.179242] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  3687	[    2.190594] DLM installed
  3688	[    2.192418] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  3689	[    2.192757] Registering sdcardfs 0.1
  3690	[    2.193223] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  3691	[    2.194880] ntfs: driver 2.1.32 [Flags: R/W].
  3692	[    2.201328] NET: Registered protocol family 38
  3693	[    2.201686] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  3694	[    2.201804] io scheduler noop registered
  3695	[    2.201811] io scheduler deadline registered
  3696	[    2.201970] io scheduler cfq registered (default)
  3697	[    2.203899] failed to get easy_light_used assign
  3698	[    2.203911] failed to get normal led pin assign
  3699	[    2.203916] failed to get standby led pin assign
  3700	[    2.203921] failed to get standby led pin assign
  3701	[    2.203926] these is zero number for gpio
  3702	[    2.203930] gpio_init finish with uesd
  3703	[    2.207432] uart uart0: get regulator failed
  3704	[    2.207645] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  3705	[    2.207668] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  3706	[    2.207762] console [ttyS0] enabled
  3707	[    2.208572] uart uart1: get regulator failed
  3708	[    2.208760] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  3709	[    2.209477] uart uart5: get regulator failed
  3710	[    2.209658] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  3711	[    2.210972] misc dump reg init
  3712	[    2.212103] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  3713	[    2.212441] Unable to detect cache hierarchy for CPU 0
  3714	[    2.226536] brd: module loaded
  3715	[    2.234698] loop: module loaded
  3716	[    2.234889] [NAND][NE] Not found valid nand node on dts
  3717	[    2.235466] Get boot type cmd line fail
  3718	[    2.236050] sunxi-bt soc@03000000:bt: Missing bt_power.
  3719	[    2.236060] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  3720	[    2.236067] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  3721	[    2.236074] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  3722	[    2.236132] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  3723	[    2.236205] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  3724	[    2.237089] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  3725	[    2.237100] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  3726	[    2.237108] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  3727	[    2.237116] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  3728	[    2.237123] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  3729	[    2.237151] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  3730	[    2.237185] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  3731	[    2.237194] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  3732	[    2.237211] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  3733	[    2.238161] [ADDR_MGT] addr_mgt_probe: success.
  3734	[    2.244758] tun: Universal TUN/TAP device driver, 1.6
  3735	[    2.244768] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  3736	[    2.246839] gmac-power0: NULL
  3737	[    2.246850] gmac-power1: NULL
  3738	[    2.246856] gmac-power2: NULL
  3739	[    2.247778] PPP generic driver version 2.4.2
  3740	[    2.248063] PPP BSD Compression module registered
  3741	[    2.248073] PPP Deflate Compression module registered
  3742	[    2.248100] PPP MPPE Compression module registered
  3743	[    2.248109] NET: Registered protocol family 24
  3744	[    2.248143] PPTP driver version 0.8.5
  3745	[    2.248502] usbcore: registered new interface driver r8152
  3746	[    2.248585] usbcore: registered new interface driver asix
  3747	[    2.248683] usbcore: registered new interface driver ax88179_178a
  3748	[    2.248751] usbcore: registered new interface driver cdc_ether
  3749	[    2.248820] usbcore: registered new interface driver net1080
  3750	[    2.248880] usbcore: registered new interface driver cdc_subset
  3751	[    2.248942] usbcore: registered new interface driver zaurus
  3752	[    2.249035] usbcore: registered new interface driver cdc_ncm
  3753	[    2.249042] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  3754	[    2.249397] get drv_vbus is fail, 84
  3755	[    2.249405] get ehci0-controller, regulator_io is no nocare
  3756	[    2.249677] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  3757	[    2.249682] [sunxi-ehci0]: Not init ehci0
  3758	[    2.249797] get ehci1-controller, regulator_io is no nocare
  3759	[    2.249973] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  3760	[    2.250030] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3761	[    2.250057] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  3762	[    2.250724] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  3763	[    2.263435] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  3764	[    2.263740] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  3765	[    2.263749] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3766	[    2.263756] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3767	[    2.263764] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  3768	[    2.263770] usb usb1: SerialNumber: sunxi-ehci
  3769	[    2.264681] hub 1-0:1.0: USB hub found
  3770	[    2.264732] hub 1-0:1.0: 1 port detected
  3771	[    2.265411] get drv_vbus is fail, 84
  3772	[    2.265419] get ehci2-controller, regulator_io is no nocare
  3773	[    2.265664] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  3774	[    2.265715] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3775	[    2.265740] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  3776	[    2.266053] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  3777	[    2.276778] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  3778	[    2.276987] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  3779	[    2.276996] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3780	[    2.277004] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3781	[    2.277011] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  3782	[    2.277018] usb usb2: SerialNumber: sunxi-ehci
  3783	[    2.277863] hub 2-0:1.0: USB hub found
  3784	[    2.277909] hub 2-0:1.0: 1 port detected
  3785	[    2.278579] get drv_vbus is fail, 84
  3786	[    2.278587] get ehci3-controller, regulator_io is no nocare
  3787	[    2.278830] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  3788	[    2.278881] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3789	[    2.278906] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  3790	[    2.279195] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  3791	[    2.290095] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  3792	[    2.290315] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  3793	[    2.290324] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3794	[    2.290332] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  3795	[    2.290339] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  3796	[    2.290346] usb usb3: SerialNumber: sunxi-ehci
  3797	[    2.291181] hub 3-0:1.0: USB hub found
  3798	[    2.291223] hub 3-0:1.0: 1 port detected
  3799	[    2.292140] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  3800	[    2.292518] get drv_vbus is fail, 84
  3801	[    2.292526] get ohci0-controller, regulator_io is no nocare
  3802	[    2.292859] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  3803	[    2.292865] [sunxi-ohci0]: Not init ohci0
  3804	[    2.292978] get ohci1-controller, regulator_io is no nocare
  3805	[    2.293134] hci: request ohci1-controller gpio:80
  3806	[    2.293209] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  3807	[    2.293258] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3808	[    2.293284] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  3809	[    2.293362] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  3810	[    2.354289] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  3811	[    2.354300] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3812	[    2.354308] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3813	[    2.354315] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  3814	[    2.354322] usb usb4: SerialNumber: sunxi-ohci
  3815	[    2.355199] hub 4-0:1.0: USB hub found
  3816	[    2.355247] hub 4-0:1.0: 1 port detected
  3817	[    2.355924] get drv_vbus is fail, 84
  3818	[    2.355933] get ohci2-controller, regulator_io is no nocare
  3819	[    2.356264] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  3820	[    2.356314] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3821	[    2.356346] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  3822	[    2.356424] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  3823	[    2.414263] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  3824	[    2.414273] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3825	[    2.414281] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3826	[    2.414288] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  3827	[    2.414295] usb usb5: SerialNumber: sunxi-ohci
  3828	[    2.415160] hub 5-0:1.0: USB hub found
  3829	[    2.415205] hub 5-0:1.0: 1 port detected
  3830	[    2.415902] get drv_vbus is fail, 84
  3831	[    2.415911] get ohci3-controller, regulator_io is no nocare
  3832	[    2.416242] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  3833	[    2.416292] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3834	[    2.416319] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  3835	[    2.416395] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  3836	[    2.474264] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  3837	[    2.474275] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  3838	[    2.474283] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  3839	[    2.474290] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  3840	[    2.474297] usb usb6: SerialNumber: sunxi-ohci
  3841	[    2.475152] hub 6-0:1.0: USB hub found
  3842	[    2.475202] hub 6-0:1.0: 1 port detected
  3843	[    2.476122] ohci-platform: OHCI generic platform driver
  3844	[    2.476901] usbcore: registered new interface driver uas
  3845	[    2.477073] usbcore: registered new interface driver usb-storage
  3846	[    2.477158] usbcore: registered new interface driver ums-alauda
  3847	[    2.477252] usbcore: registered new interface driver ums-cypress
  3848	[    2.477331] usbcore: registered new interface driver ums-datafab
  3849	[    2.477404] usbcore: registered new interface driver ums_eneub6250
  3850	[    2.477476] usbcore: registered new interface driver ums-freecom
  3851	[    2.477550] usbcore: registered new interface driver ums-isd200
  3852	[    2.477619] usbcore: registered new interface driver ums-jumpshot
  3853	[    2.477690] usbcore: registered new interface driver ums-karma
  3854	[    2.477764] usbcore: registered new interface driver ums-onetouch
  3855	[    2.477863] usbcore: registered new interface driver ums-realtek
  3856	[    2.477942] usbcore: registered new interface driver ums-sddr09
  3857	[    2.478011] usbcore: registered new interface driver ums-sddr55
  3858	[    2.478083] usbcore: registered new interface driver ums-usbat
  3859	[    2.478230] usb_serial_number:20080411
  3860	[    2.479464] input: sunxi-keyboard as /devices/virtual/input/input0
  3861	[    2.480122] usbcore: registered new interface driver xpad
  3862	[    2.480243] usbcore: registered new interface driver usb_acecad
  3863	[    2.480331] usbcore: registered new interface driver aiptek
  3864	[    2.480421] usbcore: registered new interface driver gtco
  3865	[    2.480501] usbcore: registered new interface driver hanwang
  3866	[    2.480579] usbcore: registered new interface driver kbtab
  3867	[    2.481065] axp2101_pek: axp2101-pek can not register without irq
  3868	[    2.481088] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  3869	[    2.482496] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  3870	[    2.482563] sunxi-rtc rtc: RTC enabled
  3871	[    2.483043] i2c /dev entries driver
  3872	[    2.483871] lirc_dev: IR Remote Control driver registered, major 244
  3873	[    2.483882] IR NEC protocol handler initialized
  3874	[    2.483888] IR RC5(x/sz) protocol handler initialized
  3875	[    2.483894] IR RC6 protocol handler initialized
  3876	[    2.483900] IR JVC protocol handler initialized
  3877	[    2.483905] IR Sony protocol handler initialized
  3878	[    2.483911] IR SANYO protocol handler initialized
  3879	[    2.483917] IR Sharp protocol handler initialized
  3880	[    2.483923] IR MCE Keyboard/mouse protocol handler initialized
  3881	[    2.483928] IR LIRC bridge handler initialized
  3882	[    2.483934] IR XMP protocol handler initialized
  3883	[    2.484454] sunxi_ir_startup: get ir protocol failed
  3884	[    2.484497] 7040000.s_cir supply ir0 not found, using dummy regulator
  3885	[    2.484692] Registered IR keymap rc_map_sunxi
  3886	[    2.485095] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  3887	[    2.485338] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  3888	[    2.486311] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  3889	[    2.486942] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  3890	[    2.487670] sunxi cedar version 0.1
  3891	[    2.487858] VE: install start!!!
  3892
  3893	[    2.488044] cedar_ve: cedar-ve the get irq is 278
  3894	[    2.488650] VE: get debugfs_mpp_root is NULL, please check mpp
  3895
  3896	[    2.488660] VE: sunxi ve debug register driver failed!
  3897
  3898	[    2.491889] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  3899	[    2.493179] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  3900	[    2.493547] Bluetooth: HCI UART driver ver 2.3
  3901	[    2.493558] Bluetooth: HCI UART protocol H4 registered
  3902	[    2.493563] Bluetooth: HCI UART protocol LL registered
  3903	[    2.493569] Bluetooth: HCI UART protocol Three-wire (H5) registered
  3904	[    2.497768] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  3905	[    2.497783] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  3906	[    2.497796] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  3907	[    2.497808] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  3908	[    2.497820] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  3909	[    2.497832] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  3910	[    2.498249] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  3911	[    2.498364] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  3912	[    2.498560] sunxi-mmc sdc0: No vmmc regulator found
  3913	[    2.498567] sunxi-mmc sdc0: No vqmmc regulator found
  3914	[    2.498573] sunxi-mmc sdc0: No vdmmc regulator found
  3915	[    2.498580] sunxi-mmc sdc0: No vd33sw regulator found
  3916	[    2.498586] sunxi-mmc sdc0: No vd18sw regulator found
  3917	[    2.498592] sunxi-mmc sdc0: No vq33sw regulator found
  3918	[    2.498598] sunxi-mmc sdc0: No vq18sw regulator found
  3919	[    2.499326] sunxi-mmc sdc0: set host busy
  3920	[    2.499426] sunxi-mmc sdc0: Got CD GPIO
  3921	[    2.499813] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  3922	[    2.499850] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  3923	[    2.516764] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3924	[    2.533806] sunxi-mmc sdc0: detmode:gpio irq
  3925	[    2.533839] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3926	[    2.536344] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3927	[    2.537075] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  3928	[    2.537176] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  3929	[    2.537314] sunxi-mmc sdc1: No vmmc regulator found
  3930	[    2.537321] sunxi-mmc sdc1: No vqmmc regulator found
  3931	[    2.537327] sunxi-mmc sdc1: No vdmmc regulator found
  3932	[    2.537334] sunxi-mmc sdc1: No vd33sw regulator found
  3933	[    2.537340] sunxi-mmc sdc1: No vd18sw regulator found
  3934	[    2.537346] sunxi-mmc sdc1: No vq33sw regulator found
  3935	[    2.537352] sunxi-mmc sdc1: No vq18sw regulator found
  3936	[    2.537991] sunxi-mmc sdc1: set host busy
  3937	[    2.538076] mmc:failed to get gpios
  3938	[    2.538370] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  3939	[    2.538666] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3940	[    2.541218] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3941	[    2.553490] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3942	[    2.558774] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3943	[    2.558814] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  3944	[    2.570101] sunxi-mmc sdc1: detmode:manually by software
  3945	[    2.570939] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  3946	[    2.571786] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  3947	[    2.571829] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3948	[    2.573470] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3949	[    2.574340] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  3950	[    2.575452] ledtrig-cpu: registered to indicate activity on CPUs
  3951	[    2.576225] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  3952	[    2.577065] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  3953	[    2.577910] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  3954	[    2.578743] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  3955	[    2.578780] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  3956	[    2.581383] mmc0: host does not support reading read-only switch, assuming write-enable
  3957	[    2.581747] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  3958	[    2.581754] sunxi_emce_probe()590emce hw init failed!
  3959	[    2.581781] emce: probe of emce failed with error -2
  3960	[    2.582055] hidraw: raw HID events driver (C) Jiri Kosina
  3961	[    2.582071] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  3962	[    2.583133] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  3963	[    2.583288] sunxi-mmc sdc0: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  3964	[    2.583498] mmc0: new ultra high speed SDR104 SDXC card at address 0001
  3965	[    2.584650] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  3966	[    2.586287]  mmcblk0: p1
  3967	[    2.588546] usbcore: registered new interface driver usbhid
  3968	[    2.588555] usbhid: USB HID core driver
  3969	[    2.589976] optee: probing for conduit method from DT.
  3970	[    2.589990] optee: api uid mismatch
  3971	[    2.590582] usbcore: registered new interface driver snd-usb-audio
  3972	[    2.592188] [sunxi_hdmi_codec_init] driver and deivce register finished.
  3973	[    2.593979] [sunxi_internal_codec_probe]:get audio avcc failed
  3974	[    2.594019] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  3975	[    2.594256] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  3976	[    2.596798] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  3977	[    2.598699] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  3978	[    2.598712] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  3979	[    2.600998] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  3980	[    2.601022] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  3981	[    2.605039] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  3982	[    2.606425] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  3983	[    2.608467] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  3984	[    2.611539] pktgen: Packet Generator for packet performance testing. Version: 2.75
  3985	[    2.611969] u32 classifier
  3986	[    2.611976]     Actions configured
  3987	[    2.611988] Netfilter messages via NETLINK v0.30.
  3988	[    2.612017] nfnl_acct: registering with nfnetlink.
  3989	[    2.612355] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  3990	[    2.612612] ctnetlink v0.93: registering with nfnetlink.
  3991	[    2.613365] xt_time: kernel timezone is -0000
  3992	[    2.613388] IPVS: Registered protocols (TCP, UDP)
  3993	[    2.613601] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  3994	[    2.613739] IPVS: Creating netns size=1928 id=0
  3995	[    2.613881] IPVS: ipvs loaded.
  3996	[    2.613890] IPVS: [rr] scheduler registered.
  3997	[    2.613990] ipip: IPv4 and MPLS over IPv4 tunneling driver
  3998	[    2.614729] gre: GRE over IPv4 demultiplexor driver
  3999	[    2.614738] ip_gre: GRE over IPv4 tunneling driver
  4000	[    2.616062] IPv4 over IPsec tunneling driver
  4001	[    2.616986] ip_tables: (C) 2000-2006 Netfilter Core Team
  4002	[    2.617288] arp_tables: arp_tables: (C) 2002 David S. Miller
  4003	[    2.617354] Initializing XFRM netlink socket
  4004	[    2.617387] IPsec XFRM device driver
  4005	[    2.618249] NET: Registered protocol family 10
  4006	[    2.620158] mip6: Mobile IPv6
  4007	[    2.620199] ip6_tables: (C) 2000-2006 Netfilter Core Team
  4008	[    2.621525] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  4009	[    2.623174] NET: Registered protocol family 17
  4010	[    2.623215] NET: Registered protocol family 15
  4011	[    2.623379] Bridge firewalling registered
  4012	[    2.623597] Bluetooth: RFCOMM TTY layer initialized
  4013	[    2.623616] Bluetooth: RFCOMM socket layer initialized
  4014	[    2.623649] Bluetooth: RFCOMM ver 1.11
  4015	[    2.623663] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  4016	[    2.623669] Bluetooth: BNEP filters: protocol multicast
  4017	[    2.623682] Bluetooth: BNEP socket layer initialized
  4018	[    2.623688] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  4019	[    2.623700] Bluetooth: HIDP socket layer initialized
  4020	[    2.623787] l2tp_core: L2TP core driver, V2.0
  4021	[    2.623803] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  4022	[    2.623809] 8021q: 802.1Q VLAN Support v1.8
  4023	[    2.624029] sctp: Hash tables configured (bind 256/256)
  4024	[    2.624619] Key type dns_resolver registered
  4025	[    2.624759] Registered cp15_barrier emulation handler
  4026	[    2.624775] Registered setend emulation handler
  4027	[    2.625732] registered taskstats version 1
  4028	[    2.637412] zswap: default zpool zbud not available
  4029	[    2.637420] zswap: pool creation failed
  4030	[    2.640238] Btrfs loaded, crc32c=crc32c-arm64-hw
  4031	[    2.640984] HDMI 2.0 driver init start!
  4032	[    2.640999] boot_hdmi=true
  4033	[    2.641888] Can not find the node of esm
  4034	[    2.641910] ERROR: pinctrl_get for HDMI2.0 DDC fail
  4035	[    2.642000] Get hdmi_power0:vcc-hdmi
  4036	[    2.642039] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  4037	[    2.642213] Get hdmi_power1:vdd-hdmi
  4038	[    2.642235] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  4039	[    2.643781] hdmi_cec_init
  4040	[    2.644253] [DISP] disp_device_attached,line:146:
  4041	[    2.644263] attached ok, mgr0<-->device0, type=4
  4042	[    2.644273] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  4043	[    2.644286] [DISP] disp_hdmi_set_mode,line:648:
  4044	[    2.644291] hdmi_set_mode is null!
  4045	[    2.646282] HDMI2.0 module init end
  4046	[    2.657625] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  4047	[    2.661018] cpu cpu1: opp_list_debug_create_link: Failed to create link
  4048	[    2.661029] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  4049	[    2.661062] cpu cpu2: opp_list_debug_create_link: Failed to create link
  4050	[    2.661069] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  4051	[    2.661099] cpu cpu3: opp_list_debug_create_link: Failed to create link
  4052	[    2.661106] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  4053	[    2.663372] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  4054	[    2.664357] get det_vbus is fail, 84
  4055	[    2.664364] get id is fail, 84
  4056	[    2.664853] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:08 UTC (8)
  4057	[    2.666258] axp806-dcdcb: disabling
  4058	[    2.668244] axp806-cldo1: disabling
  4059	[    2.669878] ALSA device list:
  4060	[    2.669883]   #0: audiocodec
  4061	[    2.669887]   #1: sndahub
  4062	[    2.669890]   #2: sndhdmi
  4063	[    2.671549] Freeing unused kernel memory: 3008K
  4064	[    2.716878] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  4065	[    2.718849] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  4066	[    2.721751] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  4067	[    2.787155] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  4068	[    2.950231] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  4069	[    3.050169] HDMI cable is connected
  4070	[    3.300112] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  4071	[    3.520629] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  4072	[    3.520637] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  4073	[    3.520642] usb 4-1: Product: Rapoo 2.4G Wireless Device
  4074	[    3.520647] usb 4-1: Manufacturer: RAPOO
  4075	[    3.528552] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  4076	[    3.529137] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  4077	[    3.535296] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  4078	[    3.590987] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  4079	[    3.594916] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  4080	[    3.652089] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  4081	[    4.648774] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  4082	[    5.149026] systemd[1]: System time before build time, advancing clock.
  4083	[    5.153888] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  4084	[    5.154532] cgroup: cgroup2: unknown option "nsdelegate"
  4085	[    5.167122] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  4086	[    5.167146] systemd[1]: Detected architecture arm64.
  4087	[    5.168243] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  4088	[    5.174347] systemd[1]: Hostname set to <opi>.
  4089	[    5.189012] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  4090	[    6.048114] (sd-execut[1463]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  4091	[    6.404139] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  4092	[    6.630871] systemd[1]: Queued start job for default target graphical.target.
  4093	[    6.638188] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  4094	[    6.640492] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  4095	[    6.642717] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  4096	[    6.644107] systemd[1]: Created slice user.slice - User and Session Slice.
  4097	[    6.644745] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  4098	[    6.645300] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  4099	[    6.645621] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  4100	[    6.646126] systemd[1]: Reached target slices.target - Slice Units.
  4101	[    6.646424] systemd[1]: Reached target swap.target - Swaps.
  4102	[    6.646693] systemd[1]: Reached target time-set.target - System Time Set.
  4103	[    6.647210] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  4104	[    6.664481] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  4105	[    6.665565] systemd[1]: Listening on syslog.socket - Syslog Socket.
  4106	[    6.666493] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  4107	[    6.667249] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  4108	[    6.668873] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  4109	[    6.669806] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  4110	[    6.670921] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  4111	[    6.672981] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  4112	[    6.673962] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  4113	[    6.677940] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  4114	[    6.682530] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  4115	[    6.687914] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  4116	[    6.689005] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  4117	[    6.690001] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  4118	[    6.697394] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  4119	[    6.702802] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  4120	[    6.708936] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  4121	[    6.717640] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  4122	[    6.727773] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  4123	[    6.734831] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  4124	[    6.742802] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  4125	[    6.750866] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  4126	[    6.758016] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  4127	[    6.760255] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  4128	[    6.770670] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  4129	[    6.777606] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  4130	[    6.784370] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  4131	[    6.793365] fuse init (API version 7.26)
  4132	[    6.800338] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  4133	[    6.804451] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  4134	[    6.807719] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  4135	[    6.811750] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  4136	[    6.815623] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  4137	[    6.819314] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  4138	[    6.821122] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  4139	[    6.825927] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  4140	[    6.826881]
  4141	               insmod_device_driver
  4142
  4143	[    6.827201] device_chose finished 124!
  4144	[    6.827936] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  4145	[    6.834941] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  4146	[    6.844869] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  4147	[    6.852000] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  4148	[    6.852967] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  4149	[    6.852977] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  4150	[    6.853169] spidev spi1.1: Deleting spi1.1
  4151	[    6.854092] fbtft_device: GPIOS used by 'fb_st7735r':
  4152	[    6.854099] fbtft_device: 'reset' = GPIO73
  4153	[    6.854103] fbtft_device: 'dc' = GPIO70
  4154	[    6.854114] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  4155	[    6.854120] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  4156	[    6.879009] WCN: marlin_init entry!
  4157	[    6.880228] WCN: marlin_parse_dt reset gpio=211
  4158	[    6.880239] WCN_ERR: gpio reset request err: 211
  4159	[    6.880245] WCN: wcn config bt wake host
  4160	[    6.880795] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  4161	[    6.881011] WCN: wcn config wifi wake host
  4162	[    6.881033] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  4163	[    6.884501] sdiohal:sdiohal_init ok
  4164	[    6.885358] WCN: marlin_probe ok!
  4165	[    6.892654] mtty_probe init device addr: 0xffffffc0097acc00
  4166	[    6.892873] -->rfkill_bluetooth_init
  4167	[    6.893072] <--rfkill_bluetooth_init
  4168	[    6.901683] systemd[1]: modprobe@drm.service: Deactivated successfully.
  4169	[    6.902493] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  4170	[    6.909481] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4171	[    6.910525] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  4172	[    6.913492] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  4173	[    6.914447] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  4174	[    6.918362] systemd[1]: modprobe@loop.service: Deactivated successfully.
  4175	[    6.921887] WCN: start_marlin [MARLIN_WIFI]
  4176	[    6.921901] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  4177	[    6.921904] WCN: the first power on start
  4178	[    6.964092] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  4179	[    6.990704] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  4180	[    6.998780] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  4181	[    7.004536] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  4182	[    7.005551] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  4183	[    7.036842] WCN: marlin chip en pull up
  4184	[    7.041179] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  4185	[    7.042418] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  4186	[    7.049265] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  4187	[    7.063498] sdiohal:sdiohal_scan_card
  4188	[    7.063518] sunxi-wlan soc@03000000:wlan: bus_index: 1
  4189	[    7.063715] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  4190	[    7.065203] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  4191	[    7.067908] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  4192	[    7.070056] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  4193	[    7.080184] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4194	[    7.097638] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  4195	[    7.098517] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  4196	[    7.098557] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4197	[    7.101071] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4198	[    7.104191] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4199	[    7.111988] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  4200	[    7.118800] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  4201	[    7.120218] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4202	[    7.131520] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  4203	[    7.132273] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  4204	[    7.132328] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  4205	[    7.132926] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  4206	[    7.133371] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  4207	[    7.133770] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  4208	[    7.133804] sdiohal:scan end!
  4209	[    7.133815] WCN: marlin_scan_finish!
  4210	[    7.133827] WCN: then marlin start to download
  4211	[    7.133837] sdiohal:probe ok
  4212	[    7.133871] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  4213	[    7.201228] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  4214	[    7.203486] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  4215	[    7.209184] systemd[1]: Mounting tmp.mount - /tmp...
  4216	[    7.214720] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  4217	[    7.217170] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  4218	[    7.222287] systemd[1]: Mounted tmp.mount - /tmp.
  4219	[    7.224625] systemd[1]: Reached target local-fs.target - Local File Systems.
  4220	[    7.253090] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  4221	[    7.258291] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  4222	[    7.263770] systemd[1]: Starting console-setup.service - Set console font and keymap...
  4223	[    7.273395] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  4224	[    7.280051] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  4225	[    7.297697] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  4226	[    7.305671] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  4227	[    7.312960] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  4228	[    7.316886] systemd[1]: Finished console-setup.service - Set console font and keymap.
  4229	[    7.321392] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  4230	[    7.324235] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
  4231	[    7.364894] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  4232	[    7.367838] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  4233	[    7.368732] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  4234	[    7.369688] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  4235	[    7.372600] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  4236	[    7.385284] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  4237	[    7.388680] systemd[1]: Reached target network-pre.target - Preparation for Network.
  4238	[    7.563709] zram: Added device: zram0
  4239	[    7.564594] zram: Added device: zram1
  4240	[    7.565372] zram: Added device: zram2
  4241	[    7.596641] zswap: can't enable, initialization failed
  4242	[    7.631630] zram0: detected capacity change from 0 to 506396672
  4243	[    7.717088] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  4244	[    7.730819] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  4245	[    7.788683] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  4246	[    7.791220] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  4247	[    7.792262] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  4248	[    7.792933] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  4249	[    7.808929] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  4250	[    8.160208] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  4251	[    9.153318] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  4252	[    9.173543] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  4253	[    9.242911] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  4254	[    9.380524] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  4255	[    9.671062] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  4256	[    9.686402] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  4257	[    9.729479] sunxi-bt soc@03000000:bt: set block: 0
  4258	[    9.749704] bluetooth_set_power: start_block=0
  4259	[    9.749717] WCN: start_marlin [MARLIN_BLUETOOTH]
  4260	[    9.873282] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  4261	[    9.873595] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  4262	[    9.874250] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  4263	[    9.880617] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  4264	[    9.891122] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  4265	[    9.902156] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  4266	[    9.910280] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  4267	[    9.914021] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  4268	[    9.914867] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  4269	[    9.917807] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  4270	[    9.921733] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  4271	[    9.926699] systemd[1]: modprobe@loop.service: Deactivated successfully.
  4272	[    9.970866] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  4273	[    9.973118] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  4274	[    9.974600] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  4275	[    9.975497] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  4276	[    9.977899] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  4277	[    9.978199] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  4278	[   10.041010] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  4279	[   10.046987] systemd[1]: Starting brltty.service - Braille Device Support...
  4280	[   10.186775] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  4281	[   10.660377] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  4282	[   10.715393] systemd[1]: Started brltty.service - Braille Device Support.
  4283	[   10.724860] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  4284	[   10.825855] zram1: detected capacity change from 0 to 52428800
  4285	[   11.200171] WCN_ERR: btwifi_download_firmware request firmware error
  4286	[   14.879269] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  4287	[   14.885303] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  4288	[   14.941500] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  4289	[   18.419212] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  4290	[   18.425601] systemd[1]: Starting systemd-journald.service - Journal Service...
  4291	[   18.697120] systemd-journald[1844]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.1 (1655 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
  4292	[   18.697143] systemd-journald[1844]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  4293	[   18.701111] systemd[1]: Started systemd-journald.service - Journal Service.
  4294	[   18.742686] systemd-journald[1844]: Received client request to flush runtime journal.
  4295	[   19.006495] IPVS: Creating netns size=1928 id=1
  4296	[   19.976211] random: crng init done
  4297	[   19.976222] random: 7 urandom warning(s) missed due to ratelimiting
  4298	[   37.173491] WCN_ERR: marlin download timeout
  4299	[   37.173503] sdiohal:sdiohal_runtime_put entry
  4300	[   37.173609] sdiohal:sdiohal_runtime_put wait xmit_cnt end
  4301	[   37.173653] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 1
  4302	[   37.173658] WCN: no module to power on, start to power on
  4303	[   37.184625] sdiohal err:sdiohal_adma_pt_write xmit_cnt:0 xmit_start:0,not have card
  4304	[   37.184647] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
  4305	[   37.184652] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
  4306	[   37.200146] sdiohal:sdiohal_scan_card
  4307	[   37.200158] sdiohal:Already exist card!, xmit_cnt=0x0
  4308	[   37.200172] sunxi-wlan soc@03000000:wlan: bus_index: 1
  4309	[   37.200294] sdiohal:[sdiohal_remove]enter
  4310	[   37.200310] sdiohal:remove card end
  4311	[   37.200462] mmc1: card 8800 removed
  4312	[   37.200559] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  4313	[   37.201660] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  4314	[   37.216764] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4315	[   37.234165] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4316	[   37.236691] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4317	[   37.239806] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4318	[   37.253438] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  4319	[   37.264006] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  4320	[   37.264734] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  4321	[   37.264783] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  4322	[   37.265328] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  4323	[   37.306765] sunxi-wlan soc@03000000:wlan: bus_index: 1
  4324	[   37.307017] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  4325	[   37.307095] WCN: marlin_scan_finish!
  4326	[   37.307100] sdiohal:probe ok
  4327	[   37.307190] sdiohal:scan end!
  4328	[   37.307197] WCN: only marlin start to download
  4329	[   37.307218] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  4330	[   38.320161] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  4331	[   39.333502] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  4332	[   40.346784] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  4333	[   40.379920] unisoc_wifi: probe of unisoc_wifi failed with error -1
  4334
  4335	### armbian-release:
  4336
  4337	# PLEASE DO NOT EDIT THIS FILE
  4338	BOARD=orangepizero2
  4339	BOARD_NAME="Orange Pi Zero2"
  4340	BOARDFAMILY=sun50iw9
  4341	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  4342	BUILD_REPOSITORY_COMMIT=ac829eb6
  4343	LINUXFAMILY=sun50iw9
  4344	ARCH=arm64
  4345	IMAGE_TYPE=stable
  4346	BOARD_TYPE=conf
  4347	INITRD_ARCH=arm
  4348	KERNEL_IMAGE_TYPE=Image
  4349	FORCE_BOOTSCRIPT_UPDATE=yes
  4350	VENDOR=Armbian
  4351	BOOTSCRIPT_FORCE_UPDATE="yes"
  4352	BOOTSCRIPT_DST="boot.cmd"
  4353	VERSION=23.8.1
  4354	REVISION=23.8.1
  4355	BRANCH=legacy
  4356
  4357	### boot environment:
  4358
  4359	verbosity=1
  4360	console=serial
  4361	#disp_mode=1080p60
  4362	#fb0_width=1280
  4363	#fb0_height=720
  4364	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  4365	rootfstype=ext4
  4366	overlays=spi-spidev
  4367	param_spidev_spi_bus=1
  4368	param_spidev_spi_cs=1
  4369	extraargs=fbcon=map:1
  4370	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  4371
  4372	### lsusb:
  4373
  4374	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4375	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4376	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4377	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4378	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  4379	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  4380	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  4381
  4382	### lscpu:
  4383
  4384	Architecture:        aarch64
  4385	CPU op-mode(s):      32-bit, 64-bit
  4386	Byte Order:          Little Endian
  4387	CPU(s):              4
  4388	On-line CPU(s) list: 0-3
  4389	Vendor ID:           ARM
  4390	Model name:          Cortex-A53
  4391	Model:               4
  4392	Thread(s) per core:  1
  4393	Core(s) per cluster: 4
  4394	Socket(s):           -
  4395	Cluster(s):          1
  4396	Stepping:            r0p4
  4397	CPU(s) scaling MHz:  100%
  4398	CPU max MHz:         1512.0000
  4399	CPU min MHz:         480.0000
  4400	BogoMIPS:            48.00
  4401	Flags:               fp asimd aes pmull sha1 sha2 crc32
  4402
  4403	### cpuinfo:
  4404
  4405	processor	: 0
  4406	BogoMIPS	: 48.00
  4407	Features	: fp asimd aes pmull sha1 sha2 crc32
  4408	CPU implementer	: 0x41
  4409	CPU architecture: 8
  4410	CPU variant	: 0x0
  4411	CPU part	: 0xd03
  4412	CPU revision	: 4
  4413
  4414	processor	: 1
  4415	BogoMIPS	: 48.00
  4416	Features	: fp asimd aes pmull sha1 sha2 crc32
  4417	CPU implementer	: 0x41
  4418	CPU architecture: 8
  4419	CPU variant	: 0x0
  4420	CPU part	: 0xd03
  4421	CPU revision	: 4
  4422
  4423	processor	: 2
  4424	BogoMIPS	: 48.00
  4425	Features	: fp asimd aes pmull sha1 sha2 crc32
  4426	CPU implementer	: 0x41
  4427	CPU architecture: 8
  4428	CPU variant	: 0x0
  4429	CPU part	: 0xd03
  4430	CPU revision	: 4
  4431
  4432	processor	: 3
  4433	BogoMIPS	: 48.00
  4434	Features	: fp asimd aes pmull sha1 sha2 crc32
  4435	CPU implementer	: 0x41
  4436	CPU architecture: 8
  4437	CPU variant	: 0x0
  4438	CPU part	: 0xd03
  4439	CPU revision	: 4
  4440
  4441
  4442	### meminfo:
  4443
  4444	MemTotal:         989056 kB
  4445	MemFree:          798200 kB
  4446	MemAvailable:     886428 kB
  4447	Buffers:           15720 kB
  4448	Cached:            79444 kB
  4449	SwapCached:            0 kB
  4450	Active:            68448 kB
  4451	Inactive:          50800 kB
  4452	Active(anon):      24192 kB
  4453	Inactive(anon):      644 kB
  4454	Active(file):      44256 kB
  4455	Inactive(file):    50156 kB
  4456	Unevictable:           0 kB
  4457	Mlocked:               0 kB
  4458	SwapTotal:        494524 kB
  4459	SwapFree:         494524 kB
  4460	Dirty:               712 kB
  4461	Writeback:             0 kB
  4462	AnonPages:         23968 kB
  4463	Mapped:            24876 kB
  4464	Shmem:               812 kB
  4465	Slab:              28268 kB
  4466	SReclaimable:       9280 kB
  4467	SUnreclaim:        18988 kB
  4468	KernelStack:        2560 kB
  4469	PageTables:         1036 kB
  4470	NFS_Unstable:          0 kB
  4471	Bounce:                0 kB
  4472	WritebackTmp:          0 kB
  4473	CommitLimit:      989052 kB
  4474	Committed_AS:      83364 kB
  4475	VmallocTotal:   263061440 kB
  4476	VmallocUsed:           0 kB
  4477	VmallocChunk:          0 kB
  4478	CmaTotal:          16384 kB
  4479	CmaFree:            7468 kB
  4480	HugePages_Total:       0
  4481	HugePages_Free:        0
  4482	HugePages_Rsvd:        0
  4483	HugePages_Surp:        0
  4484	Hugepagesize:       2048 kB
  4485
  4486	### virtual memory:
  4487
  4488	vm.admin_reserve_kbytes = 8192
  4489	vm.block_dump = 0
  4490	vm.compact_unevictable_allowed = 1
  4491	vm.dirty_background_bytes = 0
  4492	vm.dirty_background_ratio = 10
  4493	vm.dirty_bytes = 0
  4494	vm.dirty_expire_centisecs = 3000
  4495	vm.dirty_ratio = 20
  4496	vm.dirtytime_expire_seconds = 43200
  4497	vm.dirty_writeback_centisecs = 500
  4498	vm.extfrag_threshold = 500
  4499	vm.extra_free_kbytes = 0
  4500	vm.hugepages_treat_as_movable = 0
  4501	vm.hugetlb_shm_group = 0
  4502	vm.laptop_mode = 0
  4503	vm.legacy_va_layout = 0
  4504	vm.lowmem_reserve_ratio = 256	32
  4505	vm.max_map_count = 65530
  4506	vm.min_free_kbytes = 3937
  4507	vm.mmap_min_addr = 4096
  4508	vm.mmap_rnd_bits = 18
  4509	vm.mmap_rnd_compat_bits = 11
  4510	vm.nr_hugepages = 0
  4511	vm.nr_overcommit_hugepages = 0
  4512	vm.nr_pdflush_threads = 0
  4513	vm.oom_dump_tasks = 1
  4514	vm.oom_kill_allocating_task = 0
  4515	vm.overcommit_kbytes = 0
  4516	vm.overcommit_memory = 0
  4517	vm.overcommit_ratio = 50
  4518	vm.page-cluster = 0
  4519	vm.panic_on_oom = 0
  4520	vm.percpu_pagelist_fraction = 0
  4521	vm.stat_interval = 1
  4522	vm.swappiness = 100
  4523	vm.user_reserve_kbytes = 30007
  4524	vm.vfs_cache_pressure = 100
  4525	vm.watermark_scale_factor = 10
  4526
  4527	### ip addr:
  4528
  4529	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  4530	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  4531	    inet XXX.XXX.0.1/8 scope host lo
  4532	       valid_lft forever preferred_lft forever
  4533	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4534	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  4535	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  4536	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  4537	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  4538	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  4539	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  4540	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  4541	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  4542	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  4543	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  4544	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  4545	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  4546	    link/tunnel6 :: brd ::
  4547	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  4548	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  4549	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  4550	    link/tunnel6 :: brd ::
  4551
  4552	### partitions:
  4553
  4554	major minor  #blocks  name
  4555
  4556	 179        0   62410752 mmcblk0
  4557	 179        1   61763584 mmcblk0p1
  4558	 253        0     494528 zram0
  4559	 253        1      51200 zram1
  4560
  4561	### df:
  4562
  4563	udev            466M     0  466M   0% /dev
  4564	tmpfs            97M  2.1M   95M   3% /run
  4565	/dev/mmcblk0p1   58G  6.3G   52G  11% /
  4566	tmpfs           483M     0  483M   0% /dev/shm
  4567	tmpfs           5.0M     0  5.0M   0% /run/lock
  4568	tmpfs           483M  4.0K  483M   1% /tmp
  4569	/dev/zram1       47M  6.9M   37M  16% /var/log
  4570
  4571	### lsblk:
  4572
  4573	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  4574	mmcblk0             59.5G
  4575	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  4576	zram1                 50M /var/log
  4577	zram2                  0B
  4578
  4579	### zramctl:
  4580
  4581	NAME       ALGORITHM DISKSIZE DATA COMPR TOTAL STREAMS MOUNTPOINT
  4582	/dev/zram1 lz4            50M   7M    2M  2.4M       4 /var/log
  4583	/dev/zram0 lzo         482.9M   4K   76B   12K       4 [SWAP]
  4584
  4585	### mtab:
  4586
  4587	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4588	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  4589	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  4590
  4591	### mmc0:0001 info:
  4592
  4593	              manfid: 0x0000fe
  4594	                 cid: fe3432534431364720000000690091f5
  4595	               fwrev: 0x0
  4596	                 csd: 400e00325b590001dc277f800a40008b
  4597	                 ocr: 0x00200000
  4598	                type: SD
  4599	                date: 01/2009
  4600	               hwrev: 0x2
  4601	                 dsr: 0x404
  4602	              serial: 0x00000069
  4603	          erase_size: 512
  4604	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  4605	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  4606	                 scr: 0285808300000000
  4607	               oemid: 0x3432
  4608	preferred_erase_size: 4194304
  4609	                name: SD16G
  4610
  4611	### Boot system health:
  4612
  4613	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  4614	14:17:38  1512 MHz  1.54  23%  11%  10%   0%   1%   0%  51.3 °C  0/5
  4615	14:17:39  1512 MHz  1.54  96%  11%  59%   0%  24%   0%  51.3 °C  0/5
  4616	14:17:39  1512 MHz  2.29  93%  13%  54%   1%  24%   0%  51.3 °C  0/5
  4617	14:17:40  1512 MHz  2.29  86%  10%  54%   2%  19%   0%  49.6 °C  0/5
  4618	14:17:40  1512 MHz  2.29  58%   6%  29%   2%  19%   0%  49.6 °C  0/5
  4619
  4620	### Activated 1 lzo zram swap devices with 482MB each.
  4621	### Activated Armbian ramlog partition with lz4 compression
  4622
  4623	Mon Sep 25 02:27:47 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  4624
  4625	### dmesg:
  4626
  4627	[    0.000000] Booting Linux on physical CPU 0x0
  4628	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  4629	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  4630	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  4631	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  4632	[    0.000000] On node 0 totalpages: 262144
  4633	[    0.000000]   DMA zone: 4096 pages used for memmap
  4634	[    0.000000]   DMA zone: 0 pages reserved
  4635	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  4636	[    0.000000] psci: probing for conduit method from DT.
  4637	[    0.000000] psci: PSCIv1.0 detected in firmware.
  4638	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  4639	[    0.000000] psci: Trusted OS migration not required
  4640	[    0.000000] psci: SMC Calling Convention v1.0
  4641	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  4642	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  4643	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  4644	[    0.000000] Detected VIPT I-cache on CPU0
  4645	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  4646	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  4647	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  4648	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  4649	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  4650	[    0.000000] log_buf_len min size: 131072 bytes
  4651	[    0.000000] log_buf_len: 524288 bytes
  4652	[    0.000000] early log buf free: 129352(98%)
  4653	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  4654	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  4655	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  4656	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  4657	[    0.000000] Virtual kernel memory layout:
  4658	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  4659	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  4660	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  4661	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  4662	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  4663	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  4664	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  4665	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  4666	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  4667	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  4668	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  4669	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  4670	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  4671	[    0.000000] Preemptible hierarchical RCU implementation.
  4672	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  4673	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  4674	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  4675	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  4676	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  4677	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  4678	[    0.000232] Console: colour dummy device 80x25
  4679	[    0.000248] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  4680	[    0.000256] pid_max: default: 32768 minimum: 301
  4681	[    0.000453] Security Framework initialized
  4682	[    0.000463] AppArmor: AppArmor disabled by boot time parameter
  4683	[    0.000575] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  4684	[    0.000581] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  4685	[    0.001858] sched-energy: CPU device node has no sched-energy-costs
  4686	[    0.001872] Invalid sched_group_energy for CPU0
  4687	[    0.001880] CPU0: update cpu_capacity 1024
  4688	[    0.008940] ASID allocator initialised with 32768 entries
  4689	[    0.027902] BOOTEVENT:        27.887873: ON
  4690	[    0.055885] Detected VIPT I-cache on CPU1
  4691	[    0.055939] Invalid sched_group_energy for CPU1
  4692	[    0.055943] CPU1: update cpu_capacity 1024
  4693	[    0.055946] CPU1: Booted secondary processor [410fd034]
  4694	[    0.079271] Detected VIPT I-cache on CPU2
  4695	[    0.079310] Invalid sched_group_energy for CPU2
  4696	[    0.079313] CPU2: update cpu_capacity 1024
  4697	[    0.079316] CPU2: Booted secondary processor [410fd034]
  4698	[    0.102675] Detected VIPT I-cache on CPU3
  4699	[    0.102709] Invalid sched_group_energy for CPU3
  4700	[    0.102712] CPU3: update cpu_capacity 1024
  4701	[    0.102715] CPU3: Booted secondary processor [410fd034]
  4702	[    0.102795] Brought up 4 CPUs
  4703	[    0.102802] SMP: Total of 4 processors activated.
  4704	[    0.102810] CPU features: detected feature: 32-bit EL0 Support
  4705	[    0.102816] CPU features: detected feature: Kernel page table isolation (KPTI)
  4706	[    0.106582] CPU: All CPU(s) started at EL1
  4707	[    0.106603] alternatives: patching kernel code
  4708	[    0.106779] Invalid sched_group_energy for CPU3
  4709	[    0.106788] CPU3: update max cpu_capacity 1024
  4710	[    0.106794] Invalid sched_group_energy for Cluster3
  4711	[    0.106799] Invalid sched_group_energy for CPU2
  4712	[    0.106805] Invalid sched_group_energy for Cluster2
  4713	[    0.106810] Invalid sched_group_energy for CPU1
  4714	[    0.106816] Invalid sched_group_energy for Cluster1
  4715	[    0.106820] Invalid sched_group_energy for CPU0
  4716	[    0.106826] Invalid sched_group_energy for Cluster0
  4717	[    0.108252] devtmpfs: initialized
  4718	[    0.112691] CPU1: update max cpu_capacity 1024
  4719	[    0.143391] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  4720	[    0.143418] futex hash table entries: 1024 (order: 5, 131072 bytes)
  4721	[    0.144081] xor: measuring software checksum speed
  4722	[    0.176232]    8regs     :  1933.200 MB/sec
  4723	[    0.209611]    8regs_prefetch:  1720.800 MB/sec
  4724	[    0.242998]    32regs    :  2287.200 MB/sec
  4725	[    0.276385]    32regs_prefetch:  1935.600 MB/sec
  4726	[    0.276391] xor: using function: 32regs (2287.200 MB/sec)
  4727	[    0.276450] atomic64_test: passed
  4728	[    0.276456] pinctrl core: initialized pinctrl subsystem
  4729	[    0.277619] NET: Registered protocol family 16
  4730	[    0.278704] dump_class_init,861, success
  4731	[    0.293114] cpuidle: using governor menu
  4732	[    0.294550] sunxi iommu: irq = 8
  4733	[    0.294876] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  4734	[    0.294894] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  4735	[    0.296301] DMA: preallocated 256 KiB pool for atomic allocations
  4736	[    0.297673] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  4737	[    0.312051] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  4738	[    0.316005] iommu: Adding device 1c0e000.ve to group 0
  4739	[    0.316524] iommu: Adding device 1c00000.vp9 to group 0
  4740	[    0.327918] iommu: Adding device 1000000.disp to group 0
  4741	[    0.329325] iommu: Adding device 1480000.g2d to group 0
  4742	[    0.332536] iommu: Adding device csi0 to group 0
  4743	[    0.332989] iommu: Adding device csi1 to group 0
  4744	[    0.334193] iommu: Adding device 6600800.vind:scaler@0 to group 0
  4745	[    0.334491] iommu: Adding device 6600800.vind:scaler@1 to group 0
  4746	[    0.334795] iommu: Adding device 6600800.vind:scaler@2 to group 0
  4747	[    0.335085] iommu: Adding device 6600800.vind:scaler@3 to group 0
  4748	[    0.335375] iommu: Adding device 6600800.vind:scaler@4 to group 0
  4749	[    0.335667] iommu: Adding device 6600800.vind:scaler@5 to group 0
  4750	[    0.336601] iommu: Adding device vinc0 to group 0
  4751	[    0.337176] iommu: Adding device vinc1 to group 0
  4752	[    0.338627] iommu: Adding device 1420000.deinterlace to group 0
  4753	[    0.381265] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  4754	[    0.437401] raid6: int64x1  gen()   391 MB/s
  4755	[    0.494198] raid6: int64x1  xor()   362 MB/s
  4756	[    0.551001] raid6: int64x2  gen()   591 MB/s
  4757	[    0.607743] raid6: int64x2  xor()   512 MB/s
  4758	[    0.664516] raid6: int64x4  gen()   840 MB/s
  4759	[    0.721310] raid6: int64x4  xor()   629 MB/s
  4760	[    0.778092] raid6: int64x8  gen()   965 MB/s
  4761	[    0.834848] raid6: int64x8  xor()   655 MB/s
  4762	[    0.891626] raid6: neonx1   gen()   648 MB/s
  4763	[    0.948406] raid6: neonx1   xor()   641 MB/s
  4764	[    1.005173] raid6: neonx2   gen()   976 MB/s
  4765	[    1.061984] raid6: neonx2   xor()   820 MB/s
  4766	[    1.118763] raid6: neonx4   gen()  1287 MB/s
  4767	[    1.175509] raid6: neonx4   xor()   965 MB/s
  4768	[    1.232299] raid6: neonx8   gen()  1324 MB/s
  4769	[    1.289082] raid6: neonx8   xor()   991 MB/s
  4770	[    1.289088] raid6: using algorithm neonx8 gen() 1324 MB/s
  4771	[    1.289093] raid6: .... xor() 991 MB/s, rmw enabled
  4772	[    1.289099] raid6: using intx1 recovery algorithm
  4773	[    1.289234] pwm module init!
  4774	[    1.293531] sunxi-pm debug v3.10
  4775	[    1.294638] SCSI subsystem initialized
  4776	[    1.295261] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  4777	[    1.295345] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  4778	[    1.295466] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  4779	[    1.295982] spi spi0: master is unqueued, this is deprecated
  4780	[    1.296291] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  4781	[    1.296861] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  4782	[    1.296943] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  4783	[    1.297058] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  4784	[    1.297525] spi spi1: master is unqueued, this is deprecated
  4785	[    1.297869] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  4786	[    1.298680] usbcore: registered new interface driver usbfs
  4787	[    1.298773] usbcore: registered new interface driver hub
  4788	[    1.298845] usbcore: registered new device driver usb
  4789	[    1.299003] sunxi_i2c_adap_init()2522 - init
  4790	[    1.299574] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  4791	[    1.299662] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  4792	[    1.299670] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  4793	[    1.299685] twi3 supply twi not found, using dummy regulator
  4794	[    1.299761] twi_request_gpio()451 - [i2c3] init name: twi3
  4795	[    1.300506] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  4796	[    1.300585] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  4797	[    1.300592] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  4798	[    1.300606] twi5 supply twi not found, using dummy regulator
  4799	[    1.300685] twi_request_gpio()451 - [i2c5] init name: twi5
  4800	[    1.301170] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  4801	[    1.319867] random: fast init done
  4802	[    1.331019] axp20x-i2c 5-0036: AXP20X driver loaded
  4803	[    1.331548] media: Linux media interface: v0.10
  4804	[    1.331628] Linux video capture interface: v2.00
  4805	[    1.332254] Advanced Linux Sound Architecture Driver Initialized.
  4806	[    1.332978] Bluetooth: Core ver 2.22
  4807	[    1.333045] NET: Registered protocol family 31
  4808	[    1.333051] Bluetooth: HCI device and connection manager initialized
  4809	[    1.333066] Bluetooth: HCI socket layer initialized
  4810	[    1.333078] Bluetooth: L2CAP socket layer initialized
  4811	[    1.333117] Bluetooth: SCO socket layer initialized
  4812	[    1.333961] [DISP]disp_module_init
  4813	[    1.335211] [DISP] parser_disp_init_para,line:1403:
  4814	[    1.335219] of_property_read fb0_width fail
  4815	[    1.335231] [DISP] disp_init,line:2215:
  4816	[    1.335237] smooth display screen:0 type:4 mode:10
  4817	[    1.352707] [DISP]disp_module_init finish
  4818	[    1.353576] clocksource: Switched to clocksource arch_sys_counter
  4819	[    1.353836] VFS: Disk quotas dquot_6.6.0
  4820	[    1.353924] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  4821	[    1.354663] Console: switching to colour frame buffer device 240x67
  4822	[    1.398069] NET: Registered protocol family 2
  4823	[    1.398194] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  4824	[    1.420504] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  4825	[    1.420578] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  4826	[    1.420700] TCP: Hash tables configured (established 8192 bind 8192)
  4827	[    1.420788] UDP hash table entries: 512 (order: 2, 16384 bytes)
  4828	[    1.420816] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  4829	[    1.421140] NET: Registered protocol family 1
  4830	[    1.421730] RPC: Registered named UNIX socket transport module.
  4831	[    1.421735] RPC: Registered udp transport module.
  4832	[    1.421738] RPC: Registered tcp transport module.
  4833	[    1.421741] RPC: Registered tcp NFSv4.1 backchannel transport module.
  4834	[    1.421982] Trying to unpack rootfs image as initramfs...
  4835	[    2.176299] Freeing initrd memory: 17256K
  4836	[    2.177391] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  4837	[    2.181283] audit: initializing netlink subsys (disabled)
  4838	[    2.181341] audit: type=2000 audit(2.176:1): initialized
  4839	[    2.182247] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  4840	[    2.193379] DLM installed
  4841	[    2.195253] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  4842	[    2.195608] Registering sdcardfs 0.1
  4843	[    2.196095] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  4844	[    2.197649] ntfs: driver 2.1.32 [Flags: R/W].
  4845	[    2.204503] NET: Registered protocol family 38
  4846	[    2.204869] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  4847	[    2.205012] io scheduler noop registered
  4848	[    2.205021] io scheduler deadline registered
  4849	[    2.205187] io scheduler cfq registered (default)
  4850	[    2.207065] failed to get easy_light_used assign
  4851	[    2.207077] failed to get normal led pin assign
  4852	[    2.207082] failed to get standby led pin assign
  4853	[    2.207087] failed to get standby led pin assign
  4854	[    2.207093] these is zero number for gpio
  4855	[    2.207097] gpio_init finish with uesd
  4856	[    2.210188] uart uart0: get regulator failed
  4857	[    2.210559] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  4858	[    2.210585] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  4859	[    2.210703] console [ttyS0] enabled
  4860	[    2.211592] uart uart1: get regulator failed
  4861	[    2.211786] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  4862	[    2.212494] uart uart5: get regulator failed
  4863	[    2.212677] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  4864	[    2.213975] misc dump reg init
  4865	[    2.215108] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  4866	[    2.215446] Unable to detect cache hierarchy for CPU 0
  4867	[    2.229903] brd: module loaded
  4868	[    2.238374] loop: module loaded
  4869	[    2.238564] [NAND][NE] Not found valid nand node on dts
  4870	[    2.239152] Get boot type cmd line fail
  4871	[    2.239735] sunxi-bt soc@03000000:bt: Missing bt_power.
  4872	[    2.239746] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  4873	[    2.239753] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  4874	[    2.239760] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  4875	[    2.239815] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  4876	[    2.239885] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  4877	[    2.240792] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  4878	[    2.240804] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  4879	[    2.240812] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  4880	[    2.240819] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  4881	[    2.240826] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  4882	[    2.240858] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  4883	[    2.240891] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  4884	[    2.240899] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  4885	[    2.240916] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  4886	[    2.241850] [ADDR_MGT] addr_mgt_probe: success.
  4887	[    2.248669] tun: Universal TUN/TAP device driver, 1.6
  4888	[    2.248681] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  4889	[    2.250720] gmac-power0: NULL
  4890	[    2.250730] gmac-power1: NULL
  4891	[    2.250736] gmac-power2: NULL
  4892	[    2.251659] PPP generic driver version 2.4.2
  4893	[    2.251945] PPP BSD Compression module registered
  4894	[    2.251954] PPP Deflate Compression module registered
  4895	[    2.251980] PPP MPPE Compression module registered
  4896	[    2.251989] NET: Registered protocol family 24
  4897	[    2.252024] PPTP driver version 0.8.5
  4898	[    2.252376] usbcore: registered new interface driver r8152
  4899	[    2.252452] usbcore: registered new interface driver asix
  4900	[    2.252547] usbcore: registered new interface driver ax88179_178a
  4901	[    2.252621] usbcore: registered new interface driver cdc_ether
  4902	[    2.252683] usbcore: registered new interface driver net1080
  4903	[    2.252751] usbcore: registered new interface driver cdc_subset
  4904	[    2.252812] usbcore: registered new interface driver zaurus
  4905	[    2.252897] usbcore: registered new interface driver cdc_ncm
  4906	[    2.252904] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  4907	[    2.253270] get drv_vbus is fail, 84
  4908	[    2.253279] get ehci0-controller, regulator_io is no nocare
  4909	[    2.253543] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  4910	[    2.253549] [sunxi-ehci0]: Not init ehci0
  4911	[    2.253781] get ehci1-controller, regulator_io is no nocare
  4912	[    2.253992] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  4913	[    2.254050] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4914	[    2.254077] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  4915	[    2.254622] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  4916	[    2.266929] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  4917	[    2.267218] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  4918	[    2.267227] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4919	[    2.267235] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4920	[    2.267242] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  4921	[    2.267249] usb usb1: SerialNumber: sunxi-ehci
  4922	[    2.268117] hub 1-0:1.0: USB hub found
  4923	[    2.268163] hub 1-0:1.0: 1 port detected
  4924	[    2.268836] get drv_vbus is fail, 84
  4925	[    2.268844] get ehci2-controller, regulator_io is no nocare
  4926	[    2.269091] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  4927	[    2.269143] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4928	[    2.269169] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  4929	[    2.269444] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  4930	[    2.280267] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  4931	[    2.280504] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  4932	[    2.280513] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4933	[    2.280520] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4934	[    2.280527] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  4935	[    2.280534] usb usb2: SerialNumber: sunxi-ehci
  4936	[    2.281378] hub 2-0:1.0: USB hub found
  4937	[    2.281421] hub 2-0:1.0: 1 port detected
  4938	[    2.282089] get drv_vbus is fail, 84
  4939	[    2.282097] get ehci3-controller, regulator_io is no nocare
  4940	[    2.282342] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  4941	[    2.282405] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4942	[    2.282431] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  4943	[    2.282717] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  4944	[    2.293595] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  4945	[    2.293782] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  4946	[    2.293791] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4947	[    2.293799] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  4948	[    2.293806] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  4949	[    2.293813] usb usb3: SerialNumber: sunxi-ehci
  4950	[    2.294681] hub 3-0:1.0: USB hub found
  4951	[    2.294727] hub 3-0:1.0: 1 port detected
  4952	[    2.295653] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  4953	[    2.296022] get drv_vbus is fail, 84
  4954	[    2.296030] get ohci0-controller, regulator_io is no nocare
  4955	[    2.296362] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  4956	[    2.296367] [sunxi-ohci0]: Not init ohci0
  4957	[    2.296487] get ohci1-controller, regulator_io is no nocare
  4958	[    2.296652] hci: request ohci1-controller gpio:80
  4959	[    2.296729] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  4960	[    2.296780] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4961	[    2.296806] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  4962	[    2.296885] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  4963	[    2.357785] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  4964	[    2.357797] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4965	[    2.357804] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4966	[    2.357811] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  4967	[    2.357818] usb usb4: SerialNumber: sunxi-ohci
  4968	[    2.358708] hub 4-0:1.0: USB hub found
  4969	[    2.358756] hub 4-0:1.0: 1 port detected
  4970	[    2.359439] get drv_vbus is fail, 84
  4971	[    2.359447] get ohci2-controller, regulator_io is no nocare
  4972	[    2.359782] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  4973	[    2.359832] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4974	[    2.359858] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  4975	[    2.359935] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  4976	[    2.417759] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  4977	[    2.417769] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4978	[    2.417777] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4979	[    2.417784] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  4980	[    2.417791] usb usb5: SerialNumber: sunxi-ohci
  4981	[    2.418665] hub 5-0:1.0: USB hub found
  4982	[    2.418712] hub 5-0:1.0: 1 port detected
  4983	[    2.419383] get drv_vbus is fail, 84
  4984	[    2.419391] get ohci3-controller, regulator_io is no nocare
  4985	[    2.419729] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  4986	[    2.419779] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4987	[    2.419808] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  4988	[    2.419885] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  4989	[    2.477754] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  4990	[    2.477764] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  4991	[    2.477771] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  4992	[    2.477779] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  4993	[    2.477785] usb usb6: SerialNumber: sunxi-ohci
  4994	[    2.478632] hub 6-0:1.0: USB hub found
  4995	[    2.478678] hub 6-0:1.0: 1 port detected
  4996	[    2.479616] ohci-platform: OHCI generic platform driver
  4997	[    2.480358] usbcore: registered new interface driver uas
  4998	[    2.480526] usbcore: registered new interface driver usb-storage
  4999	[    2.480618] usbcore: registered new interface driver ums-alauda
  5000	[    2.480699] usbcore: registered new interface driver ums-cypress
  5001	[    2.480772] usbcore: registered new interface driver ums-datafab
  5002	[    2.480840] usbcore: registered new interface driver ums_eneub6250
  5003	[    2.480914] usbcore: registered new interface driver ums-freecom
  5004	[    2.480988] usbcore: registered new interface driver ums-isd200
  5005	[    2.481057] usbcore: registered new interface driver ums-jumpshot
  5006	[    2.481127] usbcore: registered new interface driver ums-karma
  5007	[    2.481196] usbcore: registered new interface driver ums-onetouch
  5008	[    2.481293] usbcore: registered new interface driver ums-realtek
  5009	[    2.481375] usbcore: registered new interface driver ums-sddr09
  5010	[    2.481456] usbcore: registered new interface driver ums-sddr55
  5011	[    2.481530] usbcore: registered new interface driver ums-usbat
  5012	[    2.481679] usb_serial_number:20080411
  5013	[    2.482917] input: sunxi-keyboard as /devices/virtual/input/input0
  5014	[    2.483538] usbcore: registered new interface driver xpad
  5015	[    2.483708] usbcore: registered new interface driver usb_acecad
  5016	[    2.483807] usbcore: registered new interface driver aiptek
  5017	[    2.483894] usbcore: registered new interface driver gtco
  5018	[    2.483974] usbcore: registered new interface driver hanwang
  5019	[    2.484055] usbcore: registered new interface driver kbtab
  5020	[    2.484523] axp2101_pek: axp2101-pek can not register without irq
  5021	[    2.484545] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  5022	[    2.485934] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  5023	[    2.486005] sunxi-rtc rtc: RTC enabled
  5024	[    2.486472] i2c /dev entries driver
  5025	[    2.487521] lirc_dev: IR Remote Control driver registered, major 244
  5026	[    2.487532] IR NEC protocol handler initialized
  5027	[    2.487538] IR RC5(x/sz) protocol handler initialized
  5028	[    2.487544] IR RC6 protocol handler initialized
  5029	[    2.487550] IR JVC protocol handler initialized
  5030	[    2.487555] IR Sony protocol handler initialized
  5031	[    2.487561] IR SANYO protocol handler initialized
  5032	[    2.487567] IR Sharp protocol handler initialized
  5033	[    2.487573] IR MCE Keyboard/mouse protocol handler initialized
  5034	[    2.487578] IR LIRC bridge handler initialized
  5035	[    2.487584] IR XMP protocol handler initialized
  5036	[    2.488107] sunxi_ir_startup: get ir protocol failed
  5037	[    2.488149] 7040000.s_cir supply ir0 not found, using dummy regulator
  5038	[    2.488335] Registered IR keymap rc_map_sunxi
  5039	[    2.488734] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  5040	[    2.488964] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  5041	[    2.489991] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  5042	[    2.490615] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  5043	[    2.491320] sunxi cedar version 0.1
  5044	[    2.491509] VE: install start!!!
  5045
  5046	[    2.491695] cedar_ve: cedar-ve the get irq is 278
  5047	[    2.492315] VE: get debugfs_mpp_root is NULL, please check mpp
  5048
  5049	[    2.492328] VE: sunxi ve debug register driver failed!
  5050
  5051	[    2.495523] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  5052	[    2.496822] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  5053	[    2.497216] Bluetooth: HCI UART driver ver 2.3
  5054	[    2.497227] Bluetooth: HCI UART protocol H4 registered
  5055	[    2.497233] Bluetooth: HCI UART protocol LL registered
  5056	[    2.497238] Bluetooth: HCI UART protocol Three-wire (H5) registered
  5057	[    2.501443] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  5058	[    2.501460] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  5059	[    2.501473] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  5060	[    2.501485] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  5061	[    2.501497] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  5062	[    2.501509] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  5063	[    2.501919] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  5064	[    2.502028] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  5065	[    2.502231] sunxi-mmc sdc0: No vmmc regulator found
  5066	[    2.502238] sunxi-mmc sdc0: No vqmmc regulator found
  5067	[    2.502244] sunxi-mmc sdc0: No vdmmc regulator found
  5068	[    2.502250] sunxi-mmc sdc0: No vd33sw regulator found
  5069	[    2.502257] sunxi-mmc sdc0: No vd18sw regulator found
  5070	[    2.502263] sunxi-mmc sdc0: No vq33sw regulator found
  5071	[    2.502269] sunxi-mmc sdc0: No vq18sw regulator found
  5072	[    2.502988] sunxi-mmc sdc0: set host busy
  5073	[    2.503089] sunxi-mmc sdc0: Got CD GPIO
  5074	[    2.503446] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  5075	[    2.503481] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  5076	[    2.516936] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5077	[    2.537167] sunxi-mmc sdc0: detmode:gpio irq
  5078	[    2.537198] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5079	[    2.539695] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5080	[    2.541065] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  5081	[    2.541206] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  5082	[    2.541347] sunxi-mmc sdc1: No vmmc regulator found
  5083	[    2.541353] sunxi-mmc sdc1: No vqmmc regulator found
  5084	[    2.541360] sunxi-mmc sdc1: No vdmmc regulator found
  5085	[    2.541366] sunxi-mmc sdc1: No vd33sw regulator found
  5086	[    2.541372] sunxi-mmc sdc1: No vd18sw regulator found
  5087	[    2.541378] sunxi-mmc sdc1: No vq33sw regulator found
  5088	[    2.541384] sunxi-mmc sdc1: No vq18sw regulator found
  5089	[    2.541756] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5090	[    2.542140] sunxi-mmc sdc1: set host busy
  5091	[    2.542223] mmc:failed to get gpios
  5092	[    2.542515] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  5093	[    2.544240] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5094	[    2.556988] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5095	[    2.567590] mmc0: host does not support reading read-only switch, assuming write-enable
  5096	[    2.569443] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  5097	[    2.569513] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  5098	[    2.569656] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  5099	[    2.569747] mmc0: new high speed SDXC card at address 0001
  5100	[    2.570802] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  5101	[    2.572337]  mmcblk0: p1
  5102	[    2.573637] sunxi-mmc sdc1: detmode:manually by software
  5103	[    2.576045] ledtrig-cpu: registered to indicate activity on CPUs
  5104	[    2.576546] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  5105	[    2.577391] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  5106	[    2.577425] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5107	[    2.579918] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5108	[    2.581843] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  5109	[    2.582681] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  5110	[    2.583518] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  5111	[    2.584356] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  5112	[    2.584394] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  5113	[    2.584398] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  5114	[    2.584402] sunxi_emce_probe()590emce hw init failed!
  5115	[    2.584429] emce: probe of emce failed with error -2
  5116	[    2.584698] hidraw: raw HID events driver (C) Jiri Kosina
  5117	[    2.589321] usbcore: registered new interface driver usbhid
  5118	[    2.589329] usbhid: USB HID core driver
  5119	[    2.590831] optee: probing for conduit method from DT.
  5120	[    2.590844] optee: api uid mismatch
  5121	[    2.591387] usbcore: registered new interface driver snd-usb-audio
  5122	[    2.592969] [sunxi_hdmi_codec_init] driver and deivce register finished.
  5123	[    2.594731] [sunxi_internal_codec_probe]:get audio avcc failed
  5124	[    2.594772] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  5125	[    2.595003] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  5126	[    2.597532] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  5127	[    2.599510] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  5128	[    2.599523] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  5129	[    2.601936] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  5130	[    2.601959] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  5131	[    2.606020] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  5132	[    2.607650] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  5133	[    2.609571] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  5134	[    2.612620] pktgen: Packet Generator for packet performance testing. Version: 2.75
  5135	[    2.613063] u32 classifier
  5136	[    2.613070]     Actions configured
  5137	[    2.613084] Netfilter messages via NETLINK v0.30.
  5138	[    2.613112] nfnl_acct: registering with nfnetlink.
  5139	[    2.613436] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  5140	[    2.613748] ctnetlink v0.93: registering with nfnetlink.
  5141	[    2.614517] xt_time: kernel timezone is -0000
  5142	[    2.614541] IPVS: Registered protocols (TCP, UDP)
  5143	[    2.614649] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  5144	[    2.614777] IPVS: Creating netns size=1928 id=0
  5145	[    2.614915] IPVS: ipvs loaded.
  5146	[    2.614923] IPVS: [rr] scheduler registered.
  5147	[    2.615020] ipip: IPv4 and MPLS over IPv4 tunneling driver
  5148	[    2.615732] gre: GRE over IPv4 demultiplexor driver
  5149	[    2.615741] ip_gre: GRE over IPv4 tunneling driver
  5150	[    2.617217] IPv4 over IPsec tunneling driver
  5151	[    2.618081] ip_tables: (C) 2000-2006 Netfilter Core Team
  5152	[    2.618374] arp_tables: arp_tables: (C) 2002 David S. Miller
  5153	[    2.618439] Initializing XFRM netlink socket
  5154	[    2.618473] IPsec XFRM device driver
  5155	[    2.619316] NET: Registered protocol family 10
  5156	[    2.621244] mip6: Mobile IPv6
  5157	[    2.621282] ip6_tables: (C) 2000-2006 Netfilter Core Team
  5158	[    2.622597] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  5159	[    2.624303] NET: Registered protocol family 17
  5160	[    2.624344] NET: Registered protocol family 15
  5161	[    2.624512] Bridge firewalling registered
  5162	[    2.624645] Bluetooth: RFCOMM TTY layer initialized
  5163	[    2.624662] Bluetooth: RFCOMM socket layer initialized
  5164	[    2.624692] Bluetooth: RFCOMM ver 1.11
  5165	[    2.624706] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  5166	[    2.624711] Bluetooth: BNEP filters: protocol multicast
  5167	[    2.624725] Bluetooth: BNEP socket layer initialized
  5168	[    2.624730] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  5169	[    2.624742] Bluetooth: HIDP socket layer initialized
  5170	[    2.624829] l2tp_core: L2TP core driver, V2.0
  5171	[    2.624843] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  5172	[    2.624849] 8021q: 802.1Q VLAN Support v1.8
  5173	[    2.625048] sctp: Hash tables configured (bind 256/256)
  5174	[    2.625633] Key type dns_resolver registered
  5175	[    2.625774] Registered cp15_barrier emulation handler
  5176	[    2.625790] Registered setend emulation handler
  5177	[    2.626760] registered taskstats version 1
  5178	[    2.638328] zswap: default zpool zbud not available
  5179	[    2.638336] zswap: pool creation failed
  5180	[    2.641182] Btrfs loaded, crc32c=crc32c-arm64-hw
  5181	[    2.641924] HDMI 2.0 driver init start!
  5182	[    2.641939] boot_hdmi=true
  5183	[    2.642724] Can not find the node of esm
  5184	[    2.642744] ERROR: pinctrl_get for HDMI2.0 DDC fail
  5185	[    2.642832] Get hdmi_power0:vcc-hdmi
  5186	[    2.642873] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  5187	[    2.643061] Get hdmi_power1:vdd-hdmi
  5188	[    2.643085] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  5189	[    2.644764] hdmi_cec_init
  5190	[    2.645234] [DISP] disp_device_attached,line:146:
  5191	[    2.645243] attached ok, mgr0<-->device0, type=4
  5192	[    2.645254] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  5193	[    2.645265] [DISP] disp_hdmi_set_mode,line:648:
  5194	[    2.645270] hdmi_set_mode is null!
  5195	[    2.647260] HDMI2.0 module init end
  5196	[    2.658460] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  5197	[    2.661895] cpu cpu1: opp_list_debug_create_link: Failed to create link
  5198	[    2.661907] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  5199	[    2.661938] cpu cpu2: opp_list_debug_create_link: Failed to create link
  5200	[    2.661946] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  5201	[    2.661976] cpu cpu3: opp_list_debug_create_link: Failed to create link
  5202	[    2.661983] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  5203	[    2.664324] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  5204	[    2.665265] get det_vbus is fail, 84
  5205	[    2.665272] get id is fail, 84
  5206	[    2.665750] sunxi-rtc rtc: setting system clock to 1970-01-01 00:10:40 UTC (640)
  5207	[    2.669552] ALSA device list:
  5208	[    2.669560]   #0: audiocodec
  5209	[    2.669564]   #1: sndahub
  5210	[    2.669568]   #2: sndhdmi
  5211	[    2.671225] Freeing unused kernel memory: 3008K
  5212	[    2.716495] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  5213	[    2.718640] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  5214	[    2.721557] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  5215	[    2.790590] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  5216	[    2.957015] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  5217	[    3.050291] HDMI cable is connected
  5218	[    3.310321] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  5219	[    3.530364] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  5220	[    3.530373] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  5221	[    3.530378] usb 4-1: Product: Rapoo 2.4G Wireless Device
  5222	[    3.530383] usb 4-1: Manufacturer: RAPOO
  5223	[    3.538164] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  5224	[    3.538556] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  5225	[    3.544172] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  5226	[    3.601540] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  5227	[    3.605612] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  5228	[    3.662259] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  5229	[    4.184305] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  5230	[    5.107278] systemd[1]: System time before build time, advancing clock.
  5231	[    5.111989] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  5232	[    5.112548] cgroup: cgroup2: unknown option "nsdelegate"
  5233	[    5.132864] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  5234	[    5.132888] systemd[1]: Detected architecture arm64.
  5235	[    5.134059] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  5236	[    5.144226] systemd[1]: Hostname set to <opi>.
  5237	[    5.171708] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  5238	[    6.785192] (sd-execut[1457]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  5239	[    6.827008]
  5240	               insmod_device_driver
  5241
  5242	[    6.827282] device_chose finished 124!
  5243	[    7.151137] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  5244	[    7.389532] systemd[1]: Queued start job for default target graphical.target.
  5245	[    7.396979] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  5246	[    7.399185] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  5247	[    7.401496] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  5248	[    7.402807] systemd[1]: Created slice user.slice - User and Session Slice.
  5249	[    7.403444] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  5250	[    7.404067] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  5251	[    7.404407] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  5252	[    7.404970] systemd[1]: Reached target slices.target - Slice Units.
  5253	[    7.405321] systemd[1]: Reached target swap.target - Swaps.
  5254	[    7.405576] systemd[1]: Reached target time-set.target - System Time Set.
  5255	[    7.406053] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  5256	[    7.423447] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  5257	[    7.424620] systemd[1]: Listening on syslog.socket - Syslog Socket.
  5258	[    7.425513] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  5259	[    7.426148] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  5260	[    7.427828] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  5261	[    7.428788] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  5262	[    7.429848] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  5263	[    7.432086] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  5264	[    7.432982] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  5265	[    7.437017] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  5266	[    7.441506] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  5267	[    7.446652] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  5268	[    7.447895] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  5269	[    7.448829] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  5270	[    7.456252] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  5271	[    7.461856] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  5272	[    7.467672] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  5273	[    7.475944] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  5274	[    7.482378] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  5275	[    7.497854] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  5276	[    7.505020] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  5277	[    7.513050] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  5278	[    7.520455] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  5279	[    7.521688] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  5280	[    7.530978] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  5281	[    7.537310] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  5282	[    7.542303] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  5283	[    7.552627] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  5284	[    7.554939] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  5285	[    7.557337] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  5286	[    7.559936] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  5287	[    7.563508] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  5288	[    7.567852] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  5289	[    7.568459] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  5290	[    7.571252] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  5291	[    7.572800] fuse init (API version 7.26)
  5292	[    7.613687] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  5293	[    7.617515] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  5294	[    7.622990] systemd[1]: modprobe@drm.service: Deactivated successfully.
  5295	[    7.623514] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  5296	[    7.625599] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  5297	[    7.626142] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  5298	[    7.628359] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  5299	[    7.628905] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  5300	[    7.631043] systemd[1]: modprobe@loop.service: Deactivated successfully.
  5301	[    7.631176] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  5302	[    7.631706] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  5303	[    7.634441] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  5304	[    7.642017] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  5305	[    7.647591] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  5306	[    7.648414] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  5307	[    7.648423] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  5308	[    7.648613] spidev spi1.1: Deleting spi1.1
  5309	[    7.649260] fbtft_device: GPIOS used by 'fb_st7735r':
  5310	[    7.649268] fbtft_device: 'reset' = GPIO73
  5311	[    7.649272] fbtft_device: 'dc' = GPIO70
  5312	[    7.649284] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  5313	[    7.649290] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  5314	[    7.687336] WCN: marlin_init entry!
  5315	[    7.688479] WCN: marlin_parse_dt reset gpio=211
  5316	[    7.688490] WCN_ERR: gpio reset request err: 211
  5317	[    7.688496] WCN: wcn config bt wake host
  5318	[    7.689006] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  5319	[    7.689225] WCN: wcn config wifi wake host
  5320	[    7.689248] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  5321	[    7.692552] sdiohal:sdiohal_init ok
  5322	[    7.693427] WCN: marlin_probe ok!
  5323	[    7.702198] mtty_probe init device addr: 0xffffffc03b74c000
  5324	[    7.702415] -->rfkill_bluetooth_init
  5325	[    7.702606] <--rfkill_bluetooth_init
  5326	[    7.745836] WCN: start_marlin [MARLIN_WIFI]
  5327	[    7.745849] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  5328	[    7.745853] WCN: the first power on start
  5329	[    7.766598] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  5330	[    7.767360] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  5331	[    7.773105] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  5332	[    7.773959] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  5333	[    7.780312] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  5334	[    7.788980] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  5335	[    7.801249] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  5336	[    7.803813] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  5337	[    7.859166] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  5338	[    7.860302] WCN: marlin chip en pull up
  5339	[    7.865715] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  5340	[    7.886985] sdiohal:sdiohal_scan_card
  5341	[    7.887008] sunxi-wlan soc@03000000:wlan: bus_index: 1
  5342	[    7.887335] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  5343	[    7.903713] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5344	[    7.921174] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  5345	[    7.922022] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  5346	[    7.922042] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5347	[    7.924568] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5348	[    7.927805] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5349	[    7.943663] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  5350	[    7.954915] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  5351	[    7.955678] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  5352	[    7.955761] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  5353	[    7.956446] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  5354	[    7.957308] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  5355	[    7.957495] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  5356	[    7.957518] WCN: marlin_scan_finish!
  5357	[    7.957522] sdiohal:probe ok
  5358	[    7.957533] sdiohal:scan end!
  5359	[    7.957539] WCN: then marlin start to download
  5360	[    7.957569] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  5361	[    7.970097] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  5362	[    7.972015] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  5363	[    7.977767] systemd[1]: Mounting tmp.mount - /tmp...
  5364	[    7.984217] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  5365	[    8.000771] systemd[1]: Mounted tmp.mount - /tmp.
  5366	[    8.003318] systemd[1]: Reached target local-fs.target - Local File Systems.
  5367	[    8.008578] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  5368	[    8.013818] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  5369	[    8.019504] systemd[1]: Starting console-setup.service - Set console font and keymap...
  5370	[    8.024942] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  5371	[    8.040209] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  5372	[    8.047139] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  5373	[    8.051022] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  5374	[    8.084374] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  5375	[    8.092187] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  5376	[    8.100670] systemd[1]: Finished console-setup.service - Set console font and keymap.
  5377	[    8.103043] systemd[1]: Received SIGRTMIN+20 from PID 1420 (plymouthd).
  5378	[    8.147246] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  5379	[    8.153190] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  5380	[    8.154607] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  5381	[    8.155638] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  5382	[    8.160081] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  5383	[    8.177515] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  5384	[    8.180109] systemd[1]: Reached target network-pre.target - Preparation for Network.
  5385	[    8.210840] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  5386	[    8.451940] zram: Added device: zram0
  5387	[    8.452691] zram: Added device: zram1
  5388	[    8.453473] zram: Added device: zram2
  5389	[    8.485148] zswap: can't enable, initialization failed
  5390	[    8.531886] zram0: detected capacity change from 0 to 506396672
  5391	[    8.533302] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  5392	[    8.547536] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  5393	[    8.609483] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  5394	[    8.615789] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  5395	[    8.618153] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  5396	[    8.618996] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  5397	[    8.619587] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  5398	[    8.987033] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  5399	[    9.661041] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  5400	[    9.697069] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  5401	[    9.909975] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  5402	[   10.000388] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  5403	[   10.482601] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  5404	[   10.482810] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  5405	[   10.483353] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  5406	[   10.496267] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  5407	[   10.507236] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  5408	[   10.515133] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  5409	[   10.523273] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  5410	[   10.532717] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  5411	[   10.533541] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  5412	[   10.540494] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  5413	[   10.541319] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  5414	[   10.544077] systemd[1]: modprobe@loop.service: Deactivated successfully.
  5415	[   10.547054] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  5416	[   10.549615] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  5417	[   10.549951] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  5418	[   10.610953] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  5419	[   10.612020] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  5420	[   10.619382] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  5421	[   10.631739] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  5422	[   10.676370] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  5423	[   10.723858] sunxi-bt soc@03000000:bt: block state already is 1
  5424	[   10.729174] bluetooth_set_power: start_block=1
  5425	[   10.866278] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  5426	[   10.872162] systemd[1]: Starting brltty.service - Braille Device Support...
  5427	[   11.013680] WCN: marlin_request_firmware from (null)wcnmodem.bin start!
  5428	[   11.574902] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  5429	[   11.595538] systemd[1]: Started brltty.service - Braille Device Support.
  5430	[   11.611377] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  5431	[   11.742636] zram1: detected capacity change from 0 to 52428800
  5432	[   12.026952] WCN_ERR: btwifi_download_firmware request firmware error
  5433	[   15.819983] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  5434	[   15.826001] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  5435	[   15.888604] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  5436	[   19.668573] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  5437	[   19.674901] systemd[1]: Starting systemd-journald.service - Journal Service...
  5438	[   19.948113] systemd-journald[1838]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.1 (1656 of 2204 items, 1269760 file size, 766 bytes per hash table item), suggesting rotation.
  5439	[   19.948134] systemd-journald[1838]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  5440	[   19.951727] systemd[1]: Started systemd-journald.service - Journal Service.
  5441	[   19.998127] systemd-journald[1838]: Received client request to flush runtime journal.
  5442	[   20.253092] IPVS: Creating netns size=1928 id=1
  5443	[   21.264355] random: crng init done
  5444	[   21.264368] random: 7 urandom warning(s) missed due to ratelimiting
  5445	[   38.880315] WCN_ERR: marlin download timeout
  5446	[   38.880327] sdiohal:sdiohal_runtime_put entry
  5447	[   38.880443] sdiohal:sdiohal_runtime_put wait xmit_cnt end
  5448	[   38.880492] WCN: marlin power state:0, subsys: [MARLIN_BLUETOOTH] power 0
  5449	[   38.880500] bluetooth_set_power: end_block=1
  5450	[   38.891587] sdiohal err:sdiohal_adma_pt_write xmit_cnt:0 xmit_start:0,not have card
  5451	[   38.891609] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
  5452	[   38.891613] sdiohal err:sdiohal_aon_writeb xmit_cnt:0 xmit_start:0,not have card
  5453	[   42.086720] unisoc_wifi: probe of unisoc_wifi failed with error -1
  5454
  5455	### armbian-release:
  5456
  5457	# PLEASE DO NOT EDIT THIS FILE
  5458	BOARD=orangepizero2
  5459	BOARD_NAME="Orange Pi Zero2"
  5460	BOARDFAMILY=sun50iw9
  5461	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  5462	BUILD_REPOSITORY_COMMIT=ac829eb6
  5463	LINUXFAMILY=sun50iw9
  5464	ARCH=arm64
  5465	IMAGE_TYPE=stable
  5466	BOARD_TYPE=conf
  5467	INITRD_ARCH=arm
  5468	KERNEL_IMAGE_TYPE=Image
  5469	FORCE_BOOTSCRIPT_UPDATE=yes
  5470	VENDOR=Armbian
  5471	BOOTSCRIPT_FORCE_UPDATE="yes"
  5472	BOOTSCRIPT_DST="boot.cmd"
  5473	VERSION=23.8.1
  5474	REVISION=23.8.1
  5475	BRANCH=legacy
  5476
  5477	### boot environment:
  5478
  5479	verbosity=1
  5480	console=serial
  5481	#disp_mode=1080p60
  5482	#fb0_width=1280
  5483	#fb0_height=720
  5484	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  5485	rootfstype=ext4
  5486	overlays=spi-spidev
  5487	param_spidev_spi_bus=1
  5488	param_spidev_spi_cs=1
  5489	extraargs=fbcon=map:1
  5490	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  5491
  5492	### lsusb:
  5493
  5494	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5495	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5496	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5497	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5498	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  5499	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  5500	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  5501
  5502	### lscpu:
  5503
  5504	Architecture:        aarch64
  5505	CPU op-mode(s):      32-bit, 64-bit
  5506	Byte Order:          Little Endian
  5507	CPU(s):              4
  5508	On-line CPU(s) list: 0-3
  5509	Vendor ID:           ARM
  5510	Model name:          Cortex-A53
  5511	Model:               4
  5512	Thread(s) per core:  1
  5513	Core(s) per cluster: 4
  5514	Socket(s):           -
  5515	Cluster(s):          1
  5516	Stepping:            r0p4
  5517	CPU(s) scaling MHz:  100%
  5518	CPU max MHz:         1512.0000
  5519	CPU min MHz:         480.0000
  5520	BogoMIPS:            48.00
  5521	Flags:               fp asimd aes pmull sha1 sha2 crc32
  5522
  5523	### cpuinfo:
  5524
  5525	processor	: 0
  5526	BogoMIPS	: 48.00
  5527	Features	: fp asimd aes pmull sha1 sha2 crc32
  5528	CPU implementer	: 0x41
  5529	CPU architecture: 8
  5530	CPU variant	: 0x0
  5531	CPU part	: 0xd03
  5532	CPU revision	: 4
  5533
  5534	processor	: 1
  5535	BogoMIPS	: 48.00
  5536	Features	: fp asimd aes pmull sha1 sha2 crc32
  5537	CPU implementer	: 0x41
  5538	CPU architecture: 8
  5539	CPU variant	: 0x0
  5540	CPU part	: 0xd03
  5541	CPU revision	: 4
  5542
  5543	processor	: 2
  5544	BogoMIPS	: 48.00
  5545	Features	: fp asimd aes pmull sha1 sha2 crc32
  5546	CPU implementer	: 0x41
  5547	CPU architecture: 8
  5548	CPU variant	: 0x0
  5549	CPU part	: 0xd03
  5550	CPU revision	: 4
  5551
  5552	processor	: 3
  5553	BogoMIPS	: 48.00
  5554	Features	: fp asimd aes pmull sha1 sha2 crc32
  5555	CPU implementer	: 0x41
  5556	CPU architecture: 8
  5557	CPU variant	: 0x0
  5558	CPU part	: 0xd03
  5559	CPU revision	: 4
  5560
  5561
  5562	### meminfo:
  5563
  5564	MemTotal:         989056 kB
  5565	MemFree:          798740 kB
  5566	MemAvailable:     887012 kB
  5567	Buffers:           15096 kB
  5568	Cached:            80252 kB
  5569	SwapCached:            0 kB
  5570	Active:            67012 kB
  5571	Inactive:          51664 kB
  5572	Active(anon):      23516 kB
  5573	Inactive(anon):      652 kB
  5574	Active(file):      43496 kB
  5575	Inactive(file):    51012 kB
  5576	Unevictable:           0 kB
  5577	Mlocked:               0 kB
  5578	SwapTotal:        494524 kB
  5579	SwapFree:         494524 kB
  5580	Dirty:               692 kB
  5581	Writeback:             0 kB
  5582	AnonPages:         23400 kB
  5583	Mapped:            23472 kB
  5584	Shmem:               828 kB
  5585	Slab:              27944 kB
  5586	SReclaimable:       9176 kB
  5587	SUnreclaim:        18768 kB
  5588	KernelStack:        2480 kB
  5589	PageTables:         1148 kB
  5590	NFS_Unstable:          0 kB
  5591	Bounce:                0 kB
  5592	WritebackTmp:          0 kB
  5593	CommitLimit:      989052 kB
  5594	Committed_AS:      83468 kB
  5595	VmallocTotal:   263061440 kB
  5596	VmallocUsed:           0 kB
  5597	VmallocChunk:          0 kB
  5598	CmaTotal:          16384 kB
  5599	CmaFree:            7468 kB
  5600	HugePages_Total:       0
  5601	HugePages_Free:        0
  5602	HugePages_Rsvd:        0
  5603	HugePages_Surp:        0
  5604	Hugepagesize:       2048 kB
  5605
  5606	### virtual memory:
  5607
  5608	vm.admin_reserve_kbytes = 8192
  5609	vm.block_dump = 0
  5610	vm.compact_unevictable_allowed = 1
  5611	vm.dirty_background_bytes = 0
  5612	vm.dirty_background_ratio = 10
  5613	vm.dirty_bytes = 0
  5614	vm.dirty_expire_centisecs = 3000
  5615	vm.dirty_ratio = 20
  5616	vm.dirtytime_expire_seconds = 43200
  5617	vm.dirty_writeback_centisecs = 500
  5618	vm.extfrag_threshold = 500
  5619	vm.extra_free_kbytes = 0
  5620	vm.hugepages_treat_as_movable = 0
  5621	vm.hugetlb_shm_group = 0
  5622	vm.laptop_mode = 0
  5623	vm.legacy_va_layout = 0
  5624	vm.lowmem_reserve_ratio = 256	32
  5625	vm.max_map_count = 65530
  5626	vm.min_free_kbytes = 3937
  5627	vm.mmap_min_addr = 4096
  5628	vm.mmap_rnd_bits = 18
  5629	vm.mmap_rnd_compat_bits = 11
  5630	vm.nr_hugepages = 0
  5631	vm.nr_overcommit_hugepages = 0
  5632	vm.nr_pdflush_threads = 0
  5633	vm.oom_dump_tasks = 1
  5634	vm.oom_kill_allocating_task = 0
  5635	vm.overcommit_kbytes = 0
  5636	vm.overcommit_memory = 0
  5637	vm.overcommit_ratio = 50
  5638	vm.page-cluster = 0
  5639	vm.panic_on_oom = 0
  5640	vm.percpu_pagelist_fraction = 0
  5641	vm.stat_interval = 1
  5642	vm.swappiness = 100
  5643	vm.user_reserve_kbytes = 30000
  5644	vm.vfs_cache_pressure = 100
  5645	vm.watermark_scale_factor = 10
  5646
  5647	### ip addr:
  5648
  5649	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  5650	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  5651	    inet XXX.XXX.0.1/8 scope host lo
  5652	       valid_lft forever preferred_lft forever
  5653	    inet6 ::1/128 scope host noprefixroute
  5654	       valid_lft forever preferred_lft forever
  5655	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5656	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  5657	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  5658	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  5659	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  5660	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  5661	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  5662	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  5663	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  5664	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  5665	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  5666	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  5667	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  5668	    link/tunnel6 :: brd ::
  5669	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  5670	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  5671	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  5672	    link/tunnel6 :: brd ::
  5673
  5674	### partitions:
  5675
  5676	major minor  #blocks  name
  5677
  5678	 179        0   62410752 mmcblk0
  5679	 179        1   61763584 mmcblk0p1
  5680	 253        0     494528 zram0
  5681	 253        1      51200 zram1
  5682
  5683	### df:
  5684
  5685	udev            466M     0  466M   0% /dev
  5686	tmpfs            97M  868K   96M   1% /run
  5687	/dev/mmcblk0p1   58G  6.4G   51G  12% /
  5688	tmpfs           483M     0  483M   0% /dev/shm
  5689	tmpfs           5.0M     0  5.0M   0% /run/lock
  5690	tmpfs           483M  4.0K  483M   1% /tmp
  5691	/dev/zram1       47M  7.9M   36M  19% /var/log
  5692
  5693	### lsblk:
  5694
  5695	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  5696	mmcblk0             59.5G
  5697	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  5698	zram1                 50M /var/log
  5699	zram2                  0B
  5700
  5701	### zramctl:
  5702
  5703	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  5704	/dev/zram1 lz4            50M  7.7M  2.1M  2.5M       4 /var/log
  5705	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  5706
  5707	### mtab:
  5708
  5709	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  5710	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  5711	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  5712
  5713	### mmc0:0001 info:
  5714
  5715	              manfid: 0x0000fe
  5716	                 cid: fe3432534431364720000000690091f5
  5717	               fwrev: 0x0
  5718	                 csd: 400e00325b590001dc277f800a40008b
  5719	                 ocr: 0x00200000
  5720	                type: SD
  5721	                date: 01/2009
  5722	               hwrev: 0x2
  5723	                 dsr: 0x404
  5724	              serial: 0x00000069
  5725	          erase_size: 512
  5726	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  5727	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  5728	                 scr: 0285808300000000
  5729	               oemid: 0x3432
  5730	preferred_erase_size: 4194304
  5731	                name: SD16G
  5732
  5733	### Boot system health:
  5734
  5735	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  5736	14:27:49  1512 MHz  1.56  19%   9%   6%   0%   3%   0%  47.8 °C  0/5
  5737	14:27:50  1512 MHz  1.56  89%  17%  17%   1%  53%   0%  47.2 °C  0/5
  5738	14:27:50  1512 MHz  2.56  98%  34%  50%   1%  12%   0%  47.2 °C  0/5
  5739	14:27:51  1512 MHz  2.56 100%  34%  61%   0%   3%   0%  49.4 °C  0/5
  5740	14:27:51  1512 MHz  2.56 100%  39%  51%   1%   7%   0%  49.4 °C  0/5
  5741
  5742	### Activated 1 lzo zram swap devices with 482MB each.
  5743	### Activated Armbian ramlog partition with lz4 compression
  5744
  5745	Mon Sep 25 02:38:27 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  5746
  5747	### dmesg:
  5748
  5749	[    0.000000] Booting Linux on physical CPU 0x0
  5750	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  5751	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  5752	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  5753	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  5754	[    0.000000] On node 0 totalpages: 262144
  5755	[    0.000000]   DMA zone: 4096 pages used for memmap
  5756	[    0.000000]   DMA zone: 0 pages reserved
  5757	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  5758	[    0.000000] psci: probing for conduit method from DT.
  5759	[    0.000000] psci: PSCIv1.0 detected in firmware.
  5760	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  5761	[    0.000000] psci: Trusted OS migration not required
  5762	[    0.000000] psci: SMC Calling Convention v1.0
  5763	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  5764	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  5765	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  5766	[    0.000000] Detected VIPT I-cache on CPU0
  5767	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  5768	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  5769	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  5770	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  5771	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  5772	[    0.000000] log_buf_len min size: 131072 bytes
  5773	[    0.000000] log_buf_len: 524288 bytes
  5774	[    0.000000] early log buf free: 129352(98%)
  5775	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  5776	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  5777	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  5778	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  5779	[    0.000000] Virtual kernel memory layout:
  5780	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  5781	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  5782	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  5783	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  5784	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  5785	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  5786	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  5787	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  5788	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  5789	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  5790	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  5791	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  5792	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  5793	[    0.000000] Preemptible hierarchical RCU implementation.
  5794	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  5795	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  5796	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  5797	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  5798	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  5799	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  5800	[    0.000238] Console: colour dummy device 80x25
  5801	[    0.000253] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  5802	[    0.000262] pid_max: default: 32768 minimum: 301
  5803	[    0.000458] Security Framework initialized
  5804	[    0.000467] AppArmor: AppArmor disabled by boot time parameter
  5805	[    0.000582] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  5806	[    0.000588] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  5807	[    0.001861] sched-energy: CPU device node has no sched-energy-costs
  5808	[    0.001876] Invalid sched_group_energy for CPU0
  5809	[    0.001883] CPU0: update cpu_capacity 1024
  5810	[    0.008972] ASID allocator initialised with 32768 entries
  5811	[    0.027956] BOOTEVENT:        27.942499: ON
  5812	[    0.055924] Detected VIPT I-cache on CPU1
  5813	[    0.055978] Invalid sched_group_energy for CPU1
  5814	[    0.055982] CPU1: update cpu_capacity 1024
  5815	[    0.055985] CPU1: Booted secondary processor [410fd034]
  5816	[    0.079315] Detected VIPT I-cache on CPU2
  5817	[    0.079353] Invalid sched_group_energy for CPU2
  5818	[    0.079357] CPU2: update cpu_capacity 1024
  5819	[    0.079360] CPU2: Booted secondary processor [410fd034]
  5820	[    0.102713] Detected VIPT I-cache on CPU3
  5821	[    0.102747] Invalid sched_group_energy for CPU3
  5822	[    0.102750] CPU3: update cpu_capacity 1024
  5823	[    0.102753] CPU3: Booted secondary processor [410fd034]
  5824	[    0.102832] Brought up 4 CPUs
  5825	[    0.102840] SMP: Total of 4 processors activated.
  5826	[    0.102848] CPU features: detected feature: 32-bit EL0 Support
  5827	[    0.102854] CPU features: detected feature: Kernel page table isolation (KPTI)
  5828	[    0.106614] CPU: All CPU(s) started at EL1
  5829	[    0.106637] alternatives: patching kernel code
  5830	[    0.106815] Invalid sched_group_energy for CPU3
  5831	[    0.106824] CPU3: update max cpu_capacity 1024
  5832	[    0.106830] Invalid sched_group_energy for Cluster3
  5833	[    0.106835] Invalid sched_group_energy for CPU2
  5834	[    0.106840] Invalid sched_group_energy for Cluster2
  5835	[    0.106845] Invalid sched_group_energy for CPU1
  5836	[    0.106851] Invalid sched_group_energy for Cluster1
  5837	[    0.106855] Invalid sched_group_energy for CPU0
  5838	[    0.106861] Invalid sched_group_energy for Cluster0
  5839	[    0.108293] devtmpfs: initialized
  5840	[    0.112726] CPU1: update max cpu_capacity 1024
  5841	[    0.143431] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  5842	[    0.143451] futex hash table entries: 1024 (order: 5, 131072 bytes)
  5843	[    0.144111] xor: measuring software checksum speed
  5844	[    0.176260]    8regs     :  1933.200 MB/sec
  5845	[    0.209639]    8regs_prefetch:  1720.800 MB/sec
  5846	[    0.243027]    32regs    :  2287.200 MB/sec
  5847	[    0.276414]    32regs_prefetch:  1935.600 MB/sec
  5848	[    0.276419] xor: using function: 32regs (2287.200 MB/sec)
  5849	[    0.276479] atomic64_test: passed
  5850	[    0.276485] pinctrl core: initialized pinctrl subsystem
  5851	[    0.277657] NET: Registered protocol family 16
  5852	[    0.278906] dump_class_init,861, success
  5853	[    0.296479] cpuidle: using governor menu
  5854	[    0.297894] sunxi iommu: irq = 8
  5855	[    0.298211] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  5856	[    0.298229] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  5857	[    0.299634] DMA: preallocated 256 KiB pool for atomic allocations
  5858	[    0.301012] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  5859	[    0.315393] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  5860	[    0.319314] iommu: Adding device 1c0e000.ve to group 0
  5861	[    0.319820] iommu: Adding device 1c00000.vp9 to group 0
  5862	[    0.331245] iommu: Adding device 1000000.disp to group 0
  5863	[    0.332650] iommu: Adding device 1480000.g2d to group 0
  5864	[    0.335865] iommu: Adding device csi0 to group 0
  5865	[    0.336319] iommu: Adding device csi1 to group 0
  5866	[    0.337515] iommu: Adding device 6600800.vind:scaler@0 to group 0
  5867	[    0.337814] iommu: Adding device 6600800.vind:scaler@1 to group 0
  5868	[    0.338113] iommu: Adding device 6600800.vind:scaler@2 to group 0
  5869	[    0.338403] iommu: Adding device 6600800.vind:scaler@3 to group 0
  5870	[    0.338693] iommu: Adding device 6600800.vind:scaler@4 to group 0
  5871	[    0.338987] iommu: Adding device 6600800.vind:scaler@5 to group 0
  5872	[    0.339927] iommu: Adding device vinc0 to group 0
  5873	[    0.340536] iommu: Adding device vinc1 to group 0
  5874	[    0.341999] iommu: Adding device 1420000.deinterlace to group 0
  5875	[    0.387969] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  5876	[    0.444207] raid6: int64x1  gen()   393 MB/s
  5877	[    0.500872] raid6: int64x1  xor()   365 MB/s
  5878	[    0.557597] raid6: int64x2  gen()   590 MB/s
  5879	[    0.614378] raid6: int64x2  xor()   512 MB/s
  5880	[    0.671168] raid6: int64x4  gen()   840 MB/s
  5881	[    0.727954] raid6: int64x4  xor()   629 MB/s
  5882	[    0.784771] raid6: int64x8  gen()   965 MB/s
  5883	[    0.841502] raid6: int64x8  xor()   655 MB/s
  5884	[    0.898290] raid6: neonx1   gen()   648 MB/s
  5885	[    0.955061] raid6: neonx1   xor()   641 MB/s
  5886	[    1.011844] raid6: neonx2   gen()   976 MB/s
  5887	[    1.068646] raid6: neonx2   xor()   820 MB/s
  5888	[    1.125400] raid6: neonx4   gen()  1287 MB/s
  5889	[    1.182198] raid6: neonx4   xor()   966 MB/s
  5890	[    1.238981] raid6: neonx8   gen()  1324 MB/s
  5891	[    1.295733] raid6: neonx8   xor()   991 MB/s
  5892	[    1.295738] raid6: using algorithm neonx8 gen() 1324 MB/s
  5893	[    1.295743] raid6: .... xor() 991 MB/s, rmw enabled
  5894	[    1.295749] raid6: using intx1 recovery algorithm
  5895	[    1.295881] pwm module init!
  5896	[    1.300143] sunxi-pm debug v3.10
  5897	[    1.301215] SCSI subsystem initialized
  5898	[    1.301842] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  5899	[    1.301924] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  5900	[    1.302044] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  5901	[    1.302561] spi spi0: master is unqueued, this is deprecated
  5902	[    1.302868] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  5903	[    1.303441] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  5904	[    1.303519] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  5905	[    1.303635] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  5906	[    1.304098] spi spi1: master is unqueued, this is deprecated
  5907	[    1.304403] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  5908	[    1.305208] usbcore: registered new interface driver usbfs
  5909	[    1.305292] usbcore: registered new interface driver hub
  5910	[    1.305365] usbcore: registered new device driver usb
  5911	[    1.305526] sunxi_i2c_adap_init()2522 - init
  5912	[    1.306099] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  5913	[    1.306194] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  5914	[    1.306202] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  5915	[    1.306217] twi3 supply twi not found, using dummy regulator
  5916	[    1.306291] twi_request_gpio()451 - [i2c3] init name: twi3
  5917	[    1.307063] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  5918	[    1.307144] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  5919	[    1.307151] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  5920	[    1.307165] twi5 supply twi not found, using dummy regulator
  5921	[    1.307238] twi_request_gpio()451 - [i2c5] init name: twi5
  5922	[    1.307723] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  5923	[    1.326445] random: fast init done
  5924	[    1.337599] axp20x-i2c 5-0036: AXP20X driver loaded
  5925	[    1.338134] media: Linux media interface: v0.10
  5926	[    1.338214] Linux video capture interface: v2.00
  5927	[    1.338950] Advanced Linux Sound Architecture Driver Initialized.
  5928	[    1.339676] Bluetooth: Core ver 2.22
  5929	[    1.339753] NET: Registered protocol family 31
  5930	[    1.339759] Bluetooth: HCI device and connection manager initialized
  5931	[    1.339775] Bluetooth: HCI socket layer initialized
  5932	[    1.339788] Bluetooth: L2CAP socket layer initialized
  5933	[    1.339825] Bluetooth: SCO socket layer initialized
  5934	[    1.340637] [DISP]disp_module_init
  5935	[    1.341879] [DISP] parser_disp_init_para,line:1403:
  5936	[    1.341888] of_property_read fb0_width fail
  5937	[    1.341898] [DISP] disp_init,line:2215:
  5938	[    1.341904] smooth display screen:0 type:4 mode:10
  5939	[    1.359383] [DISP]disp_module_init finish
  5940	[    1.360268] clocksource: Switched to clocksource arch_sys_counter
  5941	[    1.360527] VFS: Disk quotas dquot_6.6.0
  5942	[    1.360615] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  5943	[    1.361355] Console: switching to colour frame buffer device 240x67
  5944	[    1.404965] NET: Registered protocol family 2
  5945	[    1.405091] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  5946	[    1.420527] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  5947	[    1.420600] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  5948	[    1.420724] TCP: Hash tables configured (established 8192 bind 8192)
  5949	[    1.420812] UDP hash table entries: 512 (order: 2, 16384 bytes)
  5950	[    1.420841] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  5951	[    1.421169] NET: Registered protocol family 1
  5952	[    1.421788] RPC: Registered named UNIX socket transport module.
  5953	[    1.421793] RPC: Registered udp transport module.
  5954	[    1.421796] RPC: Registered tcp transport module.
  5955	[    1.421799] RPC: Registered tcp NFSv4.1 backchannel transport module.
  5956	[    1.422067] Trying to unpack rootfs image as initramfs...
  5957	[    2.176429] Freeing initrd memory: 17256K
  5958	[    2.177558] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  5959	[    2.181455] audit: initializing netlink subsys (disabled)
  5960	[    2.181510] audit: type=2000 audit(2.176:1): initialized
  5961	[    2.182415] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  5962	[    2.193668] DLM installed
  5963	[    2.195511] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  5964	[    2.195852] Registering sdcardfs 0.1
  5965	[    2.196316] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  5966	[    2.197871] ntfs: driver 2.1.32 [Flags: R/W].
  5967	[    2.204515] NET: Registered protocol family 38
  5968	[    2.204881] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  5969	[    2.205015] io scheduler noop registered
  5970	[    2.205022] io scheduler deadline registered
  5971	[    2.205184] io scheduler cfq registered (default)
  5972	[    2.207233] failed to get easy_light_used assign
  5973	[    2.207243] failed to get normal led pin assign
  5974	[    2.207249] failed to get standby led pin assign
  5975	[    2.207254] failed to get standby led pin assign
  5976	[    2.207259] these is zero number for gpio
  5977	[    2.207264] gpio_init finish with uesd
  5978	[    2.210400] uart uart0: get regulator failed
  5979	[    2.210603] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  5980	[    2.210625] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  5981	[    2.210711] console [ttyS0] enabled
  5982	[    2.211510] uart uart1: get regulator failed
  5983	[    2.211708] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  5984	[    2.212410] uart uart5: get regulator failed
  5985	[    2.212594] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  5986	[    2.213915] misc dump reg init
  5987	[    2.215056] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  5988	[    2.215392] Unable to detect cache hierarchy for CPU 0
  5989	[    2.229485] brd: module loaded
  5990	[    2.237791] loop: module loaded
  5991	[    2.237983] [NAND][NE] Not found valid nand node on dts
  5992	[    2.238568] Get boot type cmd line fail
  5993	[    2.239150] sunxi-bt soc@03000000:bt: Missing bt_power.
  5994	[    2.239160] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  5995	[    2.239167] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  5996	[    2.239174] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  5997	[    2.239230] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  5998	[    2.239301] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  5999	[    2.240148] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  6000	[    2.240159] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  6001	[    2.240166] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  6002	[    2.240174] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  6003	[    2.240181] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  6004	[    2.240211] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  6005	[    2.240245] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  6006	[    2.240311] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  6007	[    2.240332] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  6008	[    2.241315] [ADDR_MGT] addr_mgt_probe: success.
  6009	[    2.247933] tun: Universal TUN/TAP device driver, 1.6
  6010	[    2.247945] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  6011	[    2.249924] gmac-power0: NULL
  6012	[    2.249934] gmac-power1: NULL
  6013	[    2.249940] gmac-power2: NULL
  6014	[    2.250894] PPP generic driver version 2.4.2
  6015	[    2.251187] PPP BSD Compression module registered
  6016	[    2.251197] PPP Deflate Compression module registered
  6017	[    2.251225] PPP MPPE Compression module registered
  6018	[    2.251234] NET: Registered protocol family 24
  6019	[    2.251267] PPTP driver version 0.8.5
  6020	[    2.251630] usbcore: registered new interface driver r8152
  6021	[    2.251705] usbcore: registered new interface driver asix
  6022	[    2.251803] usbcore: registered new interface driver ax88179_178a
  6023	[    2.251872] usbcore: registered new interface driver cdc_ether
  6024	[    2.251932] usbcore: registered new interface driver net1080
  6025	[    2.252001] usbcore: registered new interface driver cdc_subset
  6026	[    2.252068] usbcore: registered new interface driver zaurus
  6027	[    2.252156] usbcore: registered new interface driver cdc_ncm
  6028	[    2.252163] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  6029	[    2.252552] get drv_vbus is fail, 84
  6030	[    2.252561] get ehci0-controller, regulator_io is no nocare
  6031	[    2.252825] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  6032	[    2.252831] [sunxi-ehci0]: Not init ehci0
  6033	[    2.252946] get ehci1-controller, regulator_io is no nocare
  6034	[    2.253136] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  6035	[    2.253195] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6036	[    2.253222] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  6037	[    2.253891] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  6038	[    2.270279] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  6039	[    2.270552] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  6040	[    2.270560] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6041	[    2.270568] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6042	[    2.270575] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  6043	[    2.270582] usb usb1: SerialNumber: sunxi-ehci
  6044	[    2.271442] hub 1-0:1.0: USB hub found
  6045	[    2.271486] hub 1-0:1.0: 1 port detected
  6046	[    2.272176] get drv_vbus is fail, 84
  6047	[    2.272184] get ehci2-controller, regulator_io is no nocare
  6048	[    2.272428] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  6049	[    2.272479] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6050	[    2.272503] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  6051	[    2.272783] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  6052	[    2.283632] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  6053	[    2.283861] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  6054	[    2.283870] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6055	[    2.283878] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6056	[    2.283885] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  6057	[    2.283892] usb usb2: SerialNumber: sunxi-ehci
  6058	[    2.284749] hub 2-0:1.0: USB hub found
  6059	[    2.284793] hub 2-0:1.0: 1 port detected
  6060	[    2.285459] get drv_vbus is fail, 84
  6061	[    2.285466] get ehci3-controller, regulator_io is no nocare
  6062	[    2.285708] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  6063	[    2.285758] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6064	[    2.285783] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  6065	[    2.286072] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  6066	[    2.296944] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  6067	[    2.297151] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  6068	[    2.297159] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6069	[    2.297167] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  6070	[    2.297174] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  6071	[    2.297181] usb usb3: SerialNumber: sunxi-ehci
  6072	[    2.298000] hub 3-0:1.0: USB hub found
  6073	[    2.298055] hub 3-0:1.0: 1 port detected
  6074	[    2.298981] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  6075	[    2.299346] get drv_vbus is fail, 84
  6076	[    2.299354] get ohci0-controller, regulator_io is no nocare
  6077	[    2.299693] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  6078	[    2.299700] [sunxi-ohci0]: Not init ohci0
  6079	[    2.299812] get ohci1-controller, regulator_io is no nocare
  6080	[    2.299981] hci: request ohci1-controller gpio:80
  6081	[    2.300057] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  6082	[    2.300109] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6083	[    2.300135] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  6084	[    2.300223] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  6085	[    2.361139] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  6086	[    2.361150] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6087	[    2.361158] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6088	[    2.361165] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  6089	[    2.361172] usb usb4: SerialNumber: sunxi-ohci
  6090	[    2.362029] hub 4-0:1.0: USB hub found
  6091	[    2.362074] hub 4-0:1.0: 1 port detected
  6092	[    2.362745] get drv_vbus is fail, 84
  6093	[    2.362754] get ohci2-controller, regulator_io is no nocare
  6094	[    2.363081] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  6095	[    2.363130] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6096	[    2.363160] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  6097	[    2.363237] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  6098	[    2.421123] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  6099	[    2.421134] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6100	[    2.421142] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6101	[    2.421149] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  6102	[    2.421156] usb usb5: SerialNumber: sunxi-ohci
  6103	[    2.422016] hub 5-0:1.0: USB hub found
  6104	[    2.422065] hub 5-0:1.0: 1 port detected
  6105	[    2.422745] get drv_vbus is fail, 84
  6106	[    2.422753] get ohci3-controller, regulator_io is no nocare
  6107	[    2.423090] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  6108	[    2.423138] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6109	[    2.423165] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  6110	[    2.423241] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  6111	[    2.481119] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  6112	[    2.481129] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  6113	[    2.481137] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  6114	[    2.481144] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  6115	[    2.481151] usb usb6: SerialNumber: sunxi-ohci
  6116	[    2.481999] hub 6-0:1.0: USB hub found
  6117	[    2.482044] hub 6-0:1.0: 1 port detected
  6118	[    2.482968] ohci-platform: OHCI generic platform driver
  6119	[    2.483728] usbcore: registered new interface driver uas
  6120	[    2.483903] usbcore: registered new interface driver usb-storage
  6121	[    2.483998] usbcore: registered new interface driver ums-alauda
  6122	[    2.484075] usbcore: registered new interface driver ums-cypress
  6123	[    2.484150] usbcore: registered new interface driver ums-datafab
  6124	[    2.484223] usbcore: registered new interface driver ums_eneub6250
  6125	[    2.484316] usbcore: registered new interface driver ums-freecom
  6126	[    2.484395] usbcore: registered new interface driver ums-isd200
  6127	[    2.484468] usbcore: registered new interface driver ums-jumpshot
  6128	[    2.484540] usbcore: registered new interface driver ums-karma
  6129	[    2.484613] usbcore: registered new interface driver ums-onetouch
  6130	[    2.484704] usbcore: registered new interface driver ums-realtek
  6131	[    2.484780] usbcore: registered new interface driver ums-sddr09
  6132	[    2.484857] usbcore: registered new interface driver ums-sddr55
  6133	[    2.484941] usbcore: registered new interface driver ums-usbat
  6134	[    2.485089] usb_serial_number:20080411
  6135	[    2.486316] input: sunxi-keyboard as /devices/virtual/input/input0
  6136	[    2.486971] usbcore: registered new interface driver xpad
  6137	[    2.487100] usbcore: registered new interface driver usb_acecad
  6138	[    2.487191] usbcore: registered new interface driver aiptek
  6139	[    2.487279] usbcore: registered new interface driver gtco
  6140	[    2.487364] usbcore: registered new interface driver hanwang
  6141	[    2.487447] usbcore: registered new interface driver kbtab
  6142	[    2.487928] axp2101_pek: axp2101-pek can not register without irq
  6143	[    2.487951] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  6144	[    2.489416] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  6145	[    2.489483] sunxi-rtc rtc: RTC enabled
  6146	[    2.489972] i2c /dev entries driver
  6147	[    2.490942] lirc_dev: IR Remote Control driver registered, major 244
  6148	[    2.490955] IR NEC protocol handler initialized
  6149	[    2.490961] IR RC5(x/sz) protocol handler initialized
  6150	[    2.490967] IR RC6 protocol handler initialized
  6151	[    2.490973] IR JVC protocol handler initialized
  6152	[    2.490978] IR Sony protocol handler initialized
  6153	[    2.490984] IR SANYO protocol handler initialized
  6154	[    2.490990] IR Sharp protocol handler initialized
  6155	[    2.490996] IR MCE Keyboard/mouse protocol handler initialized
  6156	[    2.491002] IR LIRC bridge handler initialized
  6157	[    2.491007] IR XMP protocol handler initialized
  6158	[    2.491532] sunxi_ir_startup: get ir protocol failed
  6159	[    2.491574] 7040000.s_cir supply ir0 not found, using dummy regulator
  6160	[    2.491767] Registered IR keymap rc_map_sunxi
  6161	[    2.492173] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  6162	[    2.492424] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  6163	[    2.493405] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  6164	[    2.494022] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  6165	[    2.494730] sunxi cedar version 0.1
  6166	[    2.494906] VE: install start!!!
  6167
  6168	[    2.495095] cedar_ve: cedar-ve the get irq is 278
  6169	[    2.495719] VE: get debugfs_mpp_root is NULL, please check mpp
  6170
  6171	[    2.495733] VE: sunxi ve debug register driver failed!
  6172
  6173	[    2.498983] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  6174	[    2.500304] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  6175	[    2.504005] Bluetooth: HCI UART driver ver 2.3
  6176	[    2.504017] Bluetooth: HCI UART protocol H4 registered
  6177	[    2.504023] Bluetooth: HCI UART protocol LL registered
  6178	[    2.504029] Bluetooth: HCI UART protocol Three-wire (H5) registered
  6179	[    2.508037] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  6180	[    2.508053] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  6181	[    2.508065] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  6182	[    2.508077] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  6183	[    2.508090] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  6184	[    2.508101] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  6185	[    2.508459] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  6186	[    2.508558] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  6187	[    2.508751] sunxi-mmc sdc0: No vmmc regulator found
  6188	[    2.508758] sunxi-mmc sdc0: No vqmmc regulator found
  6189	[    2.508764] sunxi-mmc sdc0: No vdmmc regulator found
  6190	[    2.508771] sunxi-mmc sdc0: No vd33sw regulator found
  6191	[    2.508777] sunxi-mmc sdc0: No vd18sw regulator found
  6192	[    2.508783] sunxi-mmc sdc0: No vq33sw regulator found
  6193	[    2.508789] sunxi-mmc sdc0: No vq18sw regulator found
  6194	[    2.509499] sunxi-mmc sdc0: set host busy
  6195	[    2.509585] sunxi-mmc sdc0: Got CD GPIO
  6196	[    2.509947] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  6197	[    2.509981] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  6198	[    2.523690] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6199	[    2.540522] sunxi-mmc sdc0: detmode:gpio irq
  6200	[    2.540557] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6201	[    2.543067] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6202	[    2.544448] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  6203	[    2.544584] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  6204	[    2.544724] sunxi-mmc sdc1: No vmmc regulator found
  6205	[    2.544731] sunxi-mmc sdc1: No vqmmc regulator found
  6206	[    2.544737] sunxi-mmc sdc1: No vdmmc regulator found
  6207	[    2.544744] sunxi-mmc sdc1: No vd33sw regulator found
  6208	[    2.544750] sunxi-mmc sdc1: No vd18sw regulator found
  6209	[    2.544756] sunxi-mmc sdc1: No vq33sw regulator found
  6210	[    2.544762] sunxi-mmc sdc1: No vq18sw regulator found
  6211	[    2.545126] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6212	[    2.545596] sunxi-mmc sdc1: set host busy
  6213	[    2.545679] mmc:failed to get gpios
  6214	[    2.545966] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  6215	[    2.547614] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6216	[    2.560348] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6217	[    2.571412] mmc0: host does not support reading read-only switch, assuming write-enable
  6218	[    2.573275] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  6219	[    2.573349] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  6220	[    2.573493] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  6221	[    2.573584] mmc0: new high speed SDXC card at address 0001
  6222	[    2.577048] sunxi-mmc sdc1: detmode:manually by software
  6223	[    2.578128] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  6224	[    2.579024] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  6225	[    2.579653] ledtrig-cpu: registered to indicate activity on CPUs
  6226	[    2.579944]  mmcblk0: p1
  6227	[    2.580248] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  6228	[    2.580338] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6229	[    2.582890] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6230	[    2.584840] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  6231	[    2.585679] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  6232	[    2.586138] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  6233	[    2.586147] sunxi_emce_probe()590emce hw init failed!
  6234	[    2.586174] emce: probe of emce failed with error -2
  6235	[    2.586465] hidraw: raw HID events driver (C) Jiri Kosina
  6236	[    2.586518] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  6237	[    2.587372] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  6238	[    2.587423] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  6239	[    2.591403] usbcore: registered new interface driver usbhid
  6240	[    2.591411] usbhid: USB HID core driver
  6241	[    2.592834] optee: probing for conduit method from DT.
  6242	[    2.592847] optee: api uid mismatch
  6243	[    2.593428] usbcore: registered new interface driver snd-usb-audio
  6244	[    2.595169] [sunxi_hdmi_codec_init] driver and deivce register finished.
  6245	[    2.596779] [sunxi_internal_codec_probe]:get audio avcc failed
  6246	[    2.596820] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  6247	[    2.597237] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  6248	[    2.599761] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  6249	[    2.601723] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  6250	[    2.601737] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  6251	[    2.604011] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  6252	[    2.604036] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  6253	[    2.608032] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  6254	[    2.609428] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  6255	[    2.611366] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  6256	[    2.614415] pktgen: Packet Generator for packet performance testing. Version: 2.75
  6257	[    2.614849] u32 classifier
  6258	[    2.614856]     Actions configured
  6259	[    2.614868] Netfilter messages via NETLINK v0.30.
  6260	[    2.614895] nfnl_acct: registering with nfnetlink.
  6261	[    2.615228] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  6262	[    2.615480] ctnetlink v0.93: registering with nfnetlink.
  6263	[    2.616249] xt_time: kernel timezone is -0000
  6264	[    2.616273] IPVS: Registered protocols (TCP, UDP)
  6265	[    2.616381] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  6266	[    2.616505] IPVS: Creating netns size=1928 id=0
  6267	[    2.616637] IPVS: ipvs loaded.
  6268	[    2.616645] IPVS: [rr] scheduler registered.
  6269	[    2.616742] ipip: IPv4 and MPLS over IPv4 tunneling driver
  6270	[    2.617538] gre: GRE over IPv4 demultiplexor driver
  6271	[    2.617547] ip_gre: GRE over IPv4 tunneling driver
  6272	[    2.618849] IPv4 over IPsec tunneling driver
  6273	[    2.619693] ip_tables: (C) 2000-2006 Netfilter Core Team
  6274	[    2.619971] arp_tables: arp_tables: (C) 2002 David S. Miller
  6275	[    2.620039] Initializing XFRM netlink socket
  6276	[    2.620073] IPsec XFRM device driver
  6277	[    2.620976] NET: Registered protocol family 10
  6278	[    2.622825] mip6: Mobile IPv6
  6279	[    2.622863] ip6_tables: (C) 2000-2006 Netfilter Core Team
  6280	[    2.624413] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  6281	[    2.626030] NET: Registered protocol family 17
  6282	[    2.626072] NET: Registered protocol family 15
  6283	[    2.626229] Bridge firewalling registered
  6284	[    2.626375] Bluetooth: RFCOMM TTY layer initialized
  6285	[    2.626393] Bluetooth: RFCOMM socket layer initialized
  6286	[    2.626423] Bluetooth: RFCOMM ver 1.11
  6287	[    2.626438] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  6288	[    2.626444] Bluetooth: BNEP filters: protocol multicast
  6289	[    2.626458] Bluetooth: BNEP socket layer initialized
  6290	[    2.626463] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  6291	[    2.626475] Bluetooth: HIDP socket layer initialized
  6292	[    2.626579] l2tp_core: L2TP core driver, V2.0
  6293	[    2.626595] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  6294	[    2.626601] 8021q: 802.1Q VLAN Support v1.8
  6295	[    2.626806] sctp: Hash tables configured (bind 256/256)
  6296	[    2.627451] Key type dns_resolver registered
  6297	[    2.627591] Registered cp15_barrier emulation handler
  6298	[    2.627604] Registered setend emulation handler
  6299	[    2.628525] registered taskstats version 1
  6300	[    2.640055] zswap: default zpool zbud not available
  6301	[    2.640063] zswap: pool creation failed
  6302	[    2.642876] Btrfs loaded, crc32c=crc32c-arm64-hw
  6303	[    2.643649] HDMI 2.0 driver init start!
  6304	[    2.643665] boot_hdmi=true
  6305	[    2.644470] Can not find the node of esm
  6306	[    2.644492] ERROR: pinctrl_get for HDMI2.0 DDC fail
  6307	[    2.644582] Get hdmi_power0:vcc-hdmi
  6308	[    2.644623] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  6309	[    2.644796] Get hdmi_power1:vdd-hdmi
  6310	[    2.644817] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  6311	[    2.646384] hdmi_cec_init
  6312	[    2.646837] [DISP] disp_device_attached,line:146:
  6313	[    2.646845] attached ok, mgr0<-->device0, type=4
  6314	[    2.646856] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  6315	[    2.646868] [DISP] disp_hdmi_set_mode,line:648:
  6316	[    2.646873] hdmi_set_mode is null!
  6317	[    2.647942] HDMI2.0 module init end
  6318	[    2.659175] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  6319	[    2.662696] cpu cpu1: opp_list_debug_create_link: Failed to create link
  6320	[    2.662709] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  6321	[    2.662740] cpu cpu2: opp_list_debug_create_link: Failed to create link
  6322	[    2.662748] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  6323	[    2.662778] cpu cpu3: opp_list_debug_create_link: Failed to create link
  6324	[    2.662785] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  6325	[    2.665054] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  6326	[    2.665950] get det_vbus is fail, 84
  6327	[    2.665958] get id is fail, 84
  6328	[    2.666440] sunxi-rtc rtc: setting system clock to 1970-01-01 00:22:04 UTC (1324)
  6329	[    2.670300] ALSA device list:
  6330	[    2.670309]   #0: audiocodec
  6331	[    2.670312]   #1: sndahub
  6332	[    2.670315]   #2: sndhdmi
  6333	[    2.671925] Freeing unused kernel memory: 3008K
  6334	[    2.717256] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  6335	[    2.719187] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  6336	[    2.722174] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  6337	[    2.790881] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  6338	[    2.953709] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  6339	[    3.050362] HDMI cable is connected
  6340	[    3.306956] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  6341	[    3.527153] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  6342	[    3.527162] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  6343	[    3.527168] usb 4-1: Product: Rapoo 2.4G Wireless Device
  6344	[    3.527172] usb 4-1: Manufacturer: RAPOO
  6345	[    3.535130] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  6346	[    3.535857] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  6347	[    3.542018] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  6348	[    3.598482] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  6349	[    3.602405] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  6350	[    3.659004] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  6351	[    4.254527] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  6352	[    5.147597] systemd[1]: System time before build time, advancing clock.
  6353	[    5.152434] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  6354	[    5.152993] cgroup: cgroup2: unknown option "nsdelegate"
  6355	[    5.173411] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  6356	[    5.173436] systemd[1]: Detected architecture arm64.
  6357	[    5.174620] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  6358	[    5.184716] systemd[1]: Hostname set to <opi>.
  6359	[    5.211711] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  6360	[    6.679990] (sd-execut[1459]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  6361	[    6.827012]
  6362	               insmod_device_driver
  6363
  6364	[    6.827268] device_chose finished 124!
  6365	[    7.178621] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  6366	[    7.418011] systemd[1]: Queued start job for default target graphical.target.
  6367	[    7.425278] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  6368	[    7.427470] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  6369	[    7.429662] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  6370	[    7.431043] systemd[1]: Created slice user.slice - User and Session Slice.
  6371	[    7.431679] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  6372	[    7.432218] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  6373	[    7.432550] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  6374	[    7.433083] systemd[1]: Reached target slices.target - Slice Units.
  6375	[    7.433377] systemd[1]: Reached target swap.target - Swaps.
  6376	[    7.433743] systemd[1]: Reached target time-set.target - System Time Set.
  6377	[    7.434281] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  6378	[    7.451639] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  6379	[    7.452724] systemd[1]: Listening on syslog.socket - Syslog Socket.
  6380	[    7.453747] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  6381	[    7.454427] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  6382	[    7.456042] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  6383	[    7.457073] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  6384	[    7.458147] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  6385	[    7.460405] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  6386	[    7.461331] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  6387	[    7.465149] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  6388	[    7.469688] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  6389	[    7.474704] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  6390	[    7.475827] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  6391	[    7.476789] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  6392	[    7.484676] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  6393	[    7.490408] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  6394	[    7.496305] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  6395	[    7.504391] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  6396	[    7.513221] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  6397	[    7.521256] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  6398	[    7.534210] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  6399	[    7.541610] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  6400	[    7.548969] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  6401	[    7.552011] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  6402	[    7.560987] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  6403	[    7.566893] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  6404	[    7.572008] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  6405	[    7.582594] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  6406	[    7.585445] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  6407	[    7.587692] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  6408	[    7.590770] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  6409	[    7.594680] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  6410	[    7.598538] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  6411	[    7.599539] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  6412	[    7.600206] fuse init (API version 7.26)
  6413	[    7.602681] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  6414	[    7.604458] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  6415	[    7.608567] systemd[1]: modprobe@drm.service: Deactivated successfully.
  6416	[    7.624464] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  6417	[    7.647729] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  6418	[    7.671022] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  6419	[    7.678825] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  6420	[    7.679738] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  6421	[    7.679751] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  6422	[    7.679938] spidev spi1.1: Deleting spi1.1
  6423	[    7.681122] fbtft_device: GPIOS used by 'fb_st7735r':
  6424	[    7.681130] fbtft_device: 'reset' = GPIO73
  6425	[    7.681134] fbtft_device: 'dc' = GPIO70
  6426	[    7.681147] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  6427	[    7.681152] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  6428	[    7.682299] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  6429	[    7.694285] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  6430	[    7.700918] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  6431	[    7.701801] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  6432	[    7.704713] systemd[1]: modprobe@loop.service: Deactivated successfully.
  6433	[    7.705487] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  6434	[    7.718320] WCN: marlin_init entry!
  6435	[    7.719543] WCN: marlin_parse_dt reset gpio=211
  6436	[    7.719554] WCN_ERR: gpio reset request err: 211
  6437	[    7.719560] WCN: wcn config bt wake host
  6438	[    7.720070] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  6439	[    7.720400] WCN: wcn config wifi wake host
  6440	[    7.720428] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  6441	[    7.723976] sdiohal:sdiohal_init ok
  6442	[    7.724860] WCN: marlin_probe ok!
  6443	[    7.733508] mtty_probe init device addr: 0xffffffc009756300
  6444	[    7.733750] -->rfkill_bluetooth_init
  6445	[    7.733974] <--rfkill_bluetooth_init
  6446	[    7.751476] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  6447	[    7.760549] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  6448	[    7.777992] WCN: start_marlin [MARLIN_WIFI]
  6449	[    7.778004] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  6450	[    7.778007] WCN: the first power on start
  6451	[    7.784001] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  6452	[    7.785242] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  6453	[    7.791742] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  6454	[    7.792850] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  6455	[    7.799736] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  6456	[    7.816104] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  6457	[    7.818743] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  6458	[    7.824547] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  6459	[    7.880072] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  6460	[    7.893738] WCN: marlin chip en pull up
  6461	[    7.913856] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  6462	[    7.923686] sdiohal:sdiohal_scan_card
  6463	[    7.923702] sunxi-wlan soc@03000000:wlan: bus_index: 1
  6464	[    7.923749] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  6465	[    7.940352] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6466	[    7.957817] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  6467	[    7.958681] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  6468	[    7.958732] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6469	[    7.961342] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6470	[    7.964519] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6471	[    7.980323] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  6472	[    7.991478] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  6473	[    7.992265] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  6474	[    7.992481] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  6475	[    7.993275] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  6476	[    7.994154] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  6477	[    7.994414] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  6478	[    7.994440] WCN: marlin_scan_finish!
  6479	[    7.994444] sdiohal:probe ok
  6480	[    7.994497] sdiohal:scan end!
  6481	[    7.994504] WCN: then marlin start to download
  6482	[    7.994525] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  6483	[    8.028352] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  6484	[    8.064490] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  6485	[    8.070144] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  6486	[    8.072860] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  6487	[    8.075576] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  6488	[    8.083857] systemd[1]: Mounting tmp.mount - /tmp...
  6489	[    8.104791] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  6490	[    8.108173] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  6491	[    8.114375] systemd[1]: Mounted tmp.mount - /tmp.
  6492	[    8.125610] systemd[1]: Reached target local-fs.target - Local File Systems.
  6493	[    8.131996] WCN: combin_img 0 marlin_firmware_write finish and successful
  6494	[    8.132017] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  6495	[    8.132412] WCN: marlin_start_run read reset reg val:0x1
  6496	[    8.132420] WCN: after do marlin_start_run reset reg val:0x0
  6497	[    8.132740] WCN: s_marlin_bootup_time=8132731884
  6498	[    8.139412] WCN: clock mode: TSX
  6499	[    8.139605] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  6500	[    8.158138] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  6501	[    8.165206] systemd[1]: Starting console-setup.service - Set console font and keymap...
  6502	[    8.166614] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  6503	[    8.172428] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  6504	[    8.186760] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  6505	[    8.190913] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
  6506	[    8.190922] WCN: sdio_config bt_wake_host trigger:[high]
  6507	[    8.190926] WCN: sdio_config irq:[inband]
  6508	[    8.190929] WCN: sdio_config wl_wake_host trigger:[high]
  6509	[    8.190934] WCN: sdio_config wake_host_level_duration_time:[20ms]
  6510	[    8.190937] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
  6511	[    8.190941] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
  6512	[    8.191424] WCN: marlin_write_cali_data finish
  6513	[    8.191680] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  6514	[    8.195894] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  6515	[    8.206647] systemd[1]: Finished console-setup.service - Set console font and keymap.
  6516	[    8.217359] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  6517	[    8.243964] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  6518	[    8.248385] systemd[1]: Received SIGRTMIN+20 from PID 1421 (plymouthd).
  6519	[    8.250720] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  6520	[    8.255168] systemd[1]: Reached target network-pre.target - Preparation for Network.
  6521	[    8.261346] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  6522	[    8.270807] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  6523	[    8.290946] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  6524	[    8.291585] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  6525	[    8.297313] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  6526	[    8.307628] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  6527	[    8.318753] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  6528	[    8.324025] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
  6529	[    8.324035] WCN: marlin_bind_verify confuse data: 0x8badefa1b12bbe26aeffa8d1a5c07
  6530	[    8.324052] WCN: marlin_bind_verify verify data: 0xccd7f963c19581907680f88f2044f687
  6531	[    8.324656] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
  6532	[    8.350520] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
  6533	[    8.350528] sdiohal:sdiohal_runtime_get entry
  6534	[    8.350678] WCN: get_cp2_version entry!
  6535	[    8.352067] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
  6536	[    8.352082] WCN: switch_cp2_log - close entry!
  6537	[    8.353466] WCN: WCND at cmd read:OK
  6538	[    8.353509] WCN: then marlin download finished and run ok
  6539	[    8.353515] WCN: start_loopcheck
  6540	[    8.366973] WCN: get_board_ant_num [one_ant]
  6541	[    8.366985] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
  6542	[    8.459917] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
  6543	[    8.464808] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  6544	[    8.471521] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  6545	[    8.538395] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  6546	[    8.548382] systemd[1]: Starting networking.service - Raise network interfaces...
  6547	[    8.612143] zram: Added device: zram0
  6548	[    8.614514] zram: Added device: zram1
  6549	[    8.615542] zram: Added device: zram2
  6550	[    8.651867] zswap: can't enable, initialization failed
  6551	[    8.699500] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  6552	[    8.703442] zram0: detected capacity change from 0 to 506396672
  6553	[    8.720976] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  6554	[    8.786344] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  6555	[    8.792421] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  6556	[    8.794501] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  6557	[    8.795219] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  6558	[    8.805873] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  6559	[    9.145127] systemd[1]: Finished networking.service - Raise network interfaces.
  6560	[   10.030601] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  6561	[   10.148026] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  6562	[   10.292618] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  6563	[   10.937818] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  6564	[   10.938089] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  6565	[   10.938840] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  6566	[   10.939951] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  6567	[   10.953804] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  6568	[   10.966397] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  6569	[   10.976169] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  6570	[   10.983026] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  6571	[   10.988631] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  6572	[   10.989717] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  6573	[   10.994754] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  6574	[   10.995641] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  6575	[   11.002768] systemd[1]: modprobe@loop.service: Deactivated successfully.
  6576	[   11.003539] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  6577	[   11.006299] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  6578	[   11.006531] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  6579	[   11.061551] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  6580	[   11.063576] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  6581	[   11.064633] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  6582	[   11.065824] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  6583	[   11.105893] sunxi-bt soc@03000000:bt: block state already is 1
  6584	[   11.108477] bluetooth_set_power: start_block=1
  6585	[   11.108493] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 0
  6586	[   11.108497] WCN: can not power off, other module is on
  6587	[   11.108505] bluetooth_set_power: end_block=1
  6588	[   11.119009] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  6589	[   11.163270] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  6590	[   11.169077] systemd[1]: Starting brltty.service - Braille Device Support...
  6591	[   11.738965] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  6592	[   11.887401] zram1: detected capacity change from 0 to 52428800
  6593	[   11.901934] systemd[1]: Started brltty.service - Braille Device Support.
  6594	[   11.929997] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  6595	[   15.993123] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  6596	[   15.999188] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  6597	[   16.060586] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  6598	[   16.128164] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  6599	[   19.887335] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  6600	[   19.894062] systemd[1]: Starting systemd-journald.service - Journal Service...
  6601	[   20.169716] systemd-journald[1922]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.0 (1654 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
  6602	[   20.169738] systemd-journald[1922]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  6603	[   20.176762] systemd[1]: Started systemd-journald.service - Journal Service.
  6604	[   20.223448] systemd-journald[1922]: Received client request to flush runtime journal.
  6605	[   20.493386] IPVS: Creating netns size=1928 id=1
  6606
  6607	### armbian-release:
  6608
  6609	# PLEASE DO NOT EDIT THIS FILE
  6610	BOARD=orangepizero2
  6611	BOARD_NAME="Orange Pi Zero2"
  6612	BOARDFAMILY=sun50iw9
  6613	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  6614	BUILD_REPOSITORY_COMMIT=ac829eb6
  6615	LINUXFAMILY=sun50iw9
  6616	ARCH=arm64
  6617	IMAGE_TYPE=stable
  6618	BOARD_TYPE=conf
  6619	INITRD_ARCH=arm
  6620	KERNEL_IMAGE_TYPE=Image
  6621	FORCE_BOOTSCRIPT_UPDATE=yes
  6622	VENDOR=Armbian
  6623	BOOTSCRIPT_FORCE_UPDATE="yes"
  6624	BOOTSCRIPT_DST="boot.cmd"
  6625	VERSION=23.8.1
  6626	REVISION=23.8.1
  6627	BRANCH=legacy
  6628
  6629	### boot environment:
  6630
  6631	verbosity=1
  6632	console=serial
  6633	#disp_mode=1080p60
  6634	#fb0_width=1280
  6635	#fb0_height=720
  6636	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  6637	rootfstype=ext4
  6638	overlays=spi-spidev
  6639	param_spidev_spi_bus=1
  6640	param_spidev_spi_cs=1
  6641	extraargs=fbcon=map:1
  6642	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  6643
  6644	### lsusb:
  6645
  6646	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  6647	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6648	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  6649	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6650	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  6651	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  6652	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  6653
  6654	### lscpu:
  6655
  6656	Architecture:        aarch64
  6657	CPU op-mode(s):      32-bit, 64-bit
  6658	Byte Order:          Little Endian
  6659	CPU(s):              4
  6660	On-line CPU(s) list: 0-3
  6661	Vendor ID:           ARM
  6662	Model name:          Cortex-A53
  6663	Model:               4
  6664	Thread(s) per core:  1
  6665	Core(s) per cluster: 4
  6666	Socket(s):           -
  6667	Cluster(s):          1
  6668	Stepping:            r0p4
  6669	CPU(s) scaling MHz:  100%
  6670	CPU max MHz:         1512.0000
  6671	CPU min MHz:         480.0000
  6672	BogoMIPS:            48.00
  6673	Flags:               fp asimd aes pmull sha1 sha2 crc32
  6674
  6675	### cpuinfo:
  6676
  6677	processor	: 0
  6678	BogoMIPS	: 48.00
  6679	Features	: fp asimd aes pmull sha1 sha2 crc32
  6680	CPU implementer	: 0x41
  6681	CPU architecture: 8
  6682	CPU variant	: 0x0
  6683	CPU part	: 0xd03
  6684	CPU revision	: 4
  6685
  6686	processor	: 1
  6687	BogoMIPS	: 48.00
  6688	Features	: fp asimd aes pmull sha1 sha2 crc32
  6689	CPU implementer	: 0x41
  6690	CPU architecture: 8
  6691	CPU variant	: 0x0
  6692	CPU part	: 0xd03
  6693	CPU revision	: 4
  6694
  6695	processor	: 2
  6696	BogoMIPS	: 48.00
  6697	Features	: fp asimd aes pmull sha1 sha2 crc32
  6698	CPU implementer	: 0x41
  6699	CPU architecture: 8
  6700	CPU variant	: 0x0
  6701	CPU part	: 0xd03
  6702	CPU revision	: 4
  6703
  6704	processor	: 3
  6705	BogoMIPS	: 48.00
  6706	Features	: fp asimd aes pmull sha1 sha2 crc32
  6707	CPU implementer	: 0x41
  6708	CPU architecture: 8
  6709	CPU variant	: 0x0
  6710	CPU part	: 0xd03
  6711	CPU revision	: 4
  6712
  6713
  6714	### meminfo:
  6715
  6716	MemTotal:         989056 kB
  6717	MemFree:          792776 kB
  6718	MemAvailable:     886300 kB
  6719	Buffers:           15368 kB
  6720	Cached:            85348 kB
  6721	SwapCached:            0 kB
  6722	Active:            64416 kB
  6723	Inactive:          56496 kB
  6724	Active(anon):      20552 kB
  6725	Inactive(anon):      644 kB
  6726	Active(file):      43864 kB
  6727	Inactive(file):    55852 kB
  6728	Unevictable:           0 kB
  6729	Mlocked:               0 kB
  6730	SwapTotal:        494524 kB
  6731	SwapFree:         494524 kB
  6732	Dirty:              9360 kB
  6733	Writeback:             0 kB
  6734	AnonPages:         20404 kB
  6735	Mapped:            24492 kB
  6736	Shmem:               828 kB
  6737	Slab:              33092 kB
  6738	SReclaimable:       9260 kB
  6739	SUnreclaim:        23832 kB
  6740	KernelStack:        2544 kB
  6741	PageTables:         1056 kB
  6742	NFS_Unstable:          0 kB
  6743	Bounce:                0 kB
  6744	WritebackTmp:          0 kB
  6745	CommitLimit:      989052 kB
  6746	Committed_AS:      75080 kB
  6747	VmallocTotal:   263061440 kB
  6748	VmallocUsed:           0 kB
  6749	VmallocChunk:          0 kB
  6750	CmaTotal:          16384 kB
  6751	CmaFree:            7468 kB
  6752	HugePages_Total:       0
  6753	HugePages_Free:        0
  6754	HugePages_Rsvd:        0
  6755	HugePages_Surp:        0
  6756	Hugepagesize:       2048 kB
  6757
  6758	### virtual memory:
  6759
  6760	vm.admin_reserve_kbytes = 8192
  6761	vm.block_dump = 0
  6762	vm.compact_unevictable_allowed = 1
  6763	vm.dirty_background_bytes = 0
  6764	vm.dirty_background_ratio = 10
  6765	vm.dirty_bytes = 0
  6766	vm.dirty_expire_centisecs = 3000
  6767	vm.dirty_ratio = 20
  6768	vm.dirtytime_expire_seconds = 43200
  6769	vm.dirty_writeback_centisecs = 500
  6770	vm.extfrag_threshold = 500
  6771	vm.extra_free_kbytes = 0
  6772	vm.hugepages_treat_as_movable = 0
  6773	vm.hugetlb_shm_group = 0
  6774	vm.laptop_mode = 0
  6775	vm.legacy_va_layout = 0
  6776	vm.lowmem_reserve_ratio = 256	32
  6777	vm.max_map_count = 65530
  6778	vm.min_free_kbytes = 3937
  6779	vm.mmap_min_addr = 4096
  6780	vm.mmap_rnd_bits = 18
  6781	vm.mmap_rnd_compat_bits = 11
  6782	vm.nr_hugepages = 0
  6783	vm.nr_overcommit_hugepages = 0
  6784	vm.nr_pdflush_threads = 0
  6785	vm.oom_dump_tasks = 1
  6786	vm.oom_kill_allocating_task = 0
  6787	vm.overcommit_kbytes = 0
  6788	vm.overcommit_memory = 0
  6789	vm.overcommit_ratio = 50
  6790	vm.page-cluster = 0
  6791	vm.panic_on_oom = 0
  6792	vm.percpu_pagelist_fraction = 0
  6793	vm.stat_interval = 1
  6794	vm.swappiness = 100
  6795	vm.user_reserve_kbytes = 30000
  6796	vm.vfs_cache_pressure = 100
  6797	vm.watermark_scale_factor = 10
  6798
  6799	### ip addr:
  6800
  6801	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  6802	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  6803	    inet XXX.XXX.0.1/8 scope host lo
  6804	       valid_lft forever preferred_lft forever
  6805	    inet6 ::1/128 scope host noprefixroute
  6806	       valid_lft forever preferred_lft forever
  6807	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6808	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  6809	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6810	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  6811	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  6812	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  6813	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  6814	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  6815	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  6816	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  6817	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  6818	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  6819	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  6820	    link/tunnel6 :: brd ::
  6821	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  6822	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  6823	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  6824	    link/tunnel6 :: brd ::
  6825	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  6826	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  6827
  6828	### partitions:
  6829
  6830	major minor  #blocks  name
  6831
  6832	 179        0   62410752 mmcblk0
  6833	 179        1   61763584 mmcblk0p1
  6834	 253        0     494528 zram0
  6835	 253        1      51200 zram1
  6836
  6837	### df:
  6838
  6839	udev            466M     0  466M   0% /dev
  6840	tmpfs            97M  2.1M   95M   3% /run
  6841	/dev/mmcblk0p1   58G  7.3G   51G  13% /
  6842	tmpfs           483M     0  483M   0% /dev/shm
  6843	tmpfs           5.0M     0  5.0M   0% /run/lock
  6844	tmpfs           483M  4.0K  483M   1% /tmp
  6845	/dev/zram1       47M  8.8M   35M  21% /var/log
  6846
  6847	### lsblk:
  6848
  6849	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  6850	mmcblk0             59.5G
  6851	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  6852	zram1                 50M /var/log
  6853	zram2                  0B
  6854
  6855	### zramctl:
  6856
  6857	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  6858	/dev/zram1 lz4            50M  8.9M  2.4M  2.9M       4 /var/log
  6859	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  6860
  6861	### mtab:
  6862
  6863	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  6864	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  6865	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  6866
  6867	### mmc0:0001 info:
  6868
  6869	              manfid: 0x0000fe
  6870	                 cid: fe3432534431364720000000690091f5
  6871	               fwrev: 0x0
  6872	                 csd: 400e00325b590001dc277f800a40008b
  6873	                 ocr: 0x00200000
  6874	                type: SD
  6875	                date: 01/2009
  6876	               hwrev: 0x2
  6877	                 dsr: 0x404
  6878	              serial: 0x00000069
  6879	          erase_size: 512
  6880	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  6881	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  6882	                 scr: 0285808300000000
  6883	               oemid: 0x3432
  6884	preferred_erase_size: 4194304
  6885	                name: SD16G
  6886
  6887	### Boot system health:
  6888
  6889	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  6890	14:38:29  1512 MHz  1.17  39%  18%  13%   0%   6%   0%  50.8 °C  0/5
  6891	14:38:29  1512 MHz  1.17  95%  32%  36%   0%  25%   0%  50.8 °C  0/5
  6892	14:38:30  1512 MHz  1.17 100%  34%  57%   1%   7%   0%  49.7 °C  0/5
  6893	14:38:30  1512 MHz  1.17  99%  27%  42%   0%  29%   0%  49.7 °C  0/5
  6894	14:38:31  1512 MHz  1.17  94%  10%  12%   1%  71%   0%  50.2 °C  0/5
  6895
  6896	### Activated 1 lzo zram swap devices with 482MB each.
  6897	### Activated Armbian ramlog partition with lz4 compression
  6898
  6899	Mon Sep 25 03:19:04 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  6900
  6901	### dmesg:
  6902
  6903	[    0.000000] Booting Linux on physical CPU 0x0
  6904	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  6905	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  6906	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  6907	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  6908	[    0.000000] On node 0 totalpages: 262144
  6909	[    0.000000]   DMA zone: 4096 pages used for memmap
  6910	[    0.000000]   DMA zone: 0 pages reserved
  6911	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  6912	[    0.000000] psci: probing for conduit method from DT.
  6913	[    0.000000] psci: PSCIv1.0 detected in firmware.
  6914	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  6915	[    0.000000] psci: Trusted OS migration not required
  6916	[    0.000000] psci: SMC Calling Convention v1.0
  6917	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  6918	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  6919	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  6920	[    0.000000] Detected VIPT I-cache on CPU0
  6921	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  6922	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  6923	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  6924	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  6925	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  6926	[    0.000000] log_buf_len min size: 131072 bytes
  6927	[    0.000000] log_buf_len: 524288 bytes
  6928	[    0.000000] early log buf free: 129352(98%)
  6929	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  6930	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  6931	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  6932	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  6933	[    0.000000] Virtual kernel memory layout:
  6934	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  6935	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  6936	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  6937	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  6938	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  6939	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  6940	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  6941	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  6942	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  6943	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  6944	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  6945	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  6946	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  6947	[    0.000000] Preemptible hierarchical RCU implementation.
  6948	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  6949	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  6950	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  6951	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  6952	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  6953	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  6954	[    0.000233] Console: colour dummy device 80x25
  6955	[    0.000248] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  6956	[    0.000257] pid_max: default: 32768 minimum: 301
  6957	[    0.000453] Security Framework initialized
  6958	[    0.000462] AppArmor: AppArmor disabled by boot time parameter
  6959	[    0.000578] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  6960	[    0.000584] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  6961	[    0.001853] sched-energy: CPU device node has no sched-energy-costs
  6962	[    0.001868] Invalid sched_group_energy for CPU0
  6963	[    0.001875] CPU0: update cpu_capacity 1024
  6964	[    0.008962] ASID allocator initialised with 32768 entries
  6965	[    0.027934] BOOTEVENT:        27.918666: ON
  6966	[    0.055912] Detected VIPT I-cache on CPU1
  6967	[    0.055965] Invalid sched_group_energy for CPU1
  6968	[    0.055970] CPU1: update cpu_capacity 1024
  6969	[    0.055973] CPU1: Booted secondary processor [410fd034]
  6970	[    0.079298] Detected VIPT I-cache on CPU2
  6971	[    0.079335] Invalid sched_group_energy for CPU2
  6972	[    0.079338] CPU2: update cpu_capacity 1024
  6973	[    0.079341] CPU2: Booted secondary processor [410fd034]
  6974	[    0.102698] Detected VIPT I-cache on CPU3
  6975	[    0.102733] Invalid sched_group_energy for CPU3
  6976	[    0.102736] CPU3: update cpu_capacity 1024
  6977	[    0.102739] CPU3: Booted secondary processor [410fd034]
  6978	[    0.102819] Brought up 4 CPUs
  6979	[    0.102827] SMP: Total of 4 processors activated.
  6980	[    0.102835] CPU features: detected feature: 32-bit EL0 Support
  6981	[    0.102841] CPU features: detected feature: Kernel page table isolation (KPTI)
  6982	[    0.106589] CPU: All CPU(s) started at EL1
  6983	[    0.106610] alternatives: patching kernel code
  6984	[    0.106786] Invalid sched_group_energy for CPU3
  6985	[    0.106795] CPU3: update max cpu_capacity 1024
  6986	[    0.106801] Invalid sched_group_energy for Cluster3
  6987	[    0.106806] Invalid sched_group_energy for CPU2
  6988	[    0.106811] Invalid sched_group_energy for Cluster2
  6989	[    0.106816] Invalid sched_group_energy for CPU1
  6990	[    0.106822] Invalid sched_group_energy for Cluster1
  6991	[    0.106826] Invalid sched_group_energy for CPU0
  6992	[    0.106832] Invalid sched_group_energy for Cluster0
  6993	[    0.108261] devtmpfs: initialized
  6994	[    0.112714] CPU1: update max cpu_capacity 1024
  6995	[    0.143376] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  6996	[    0.143397] futex hash table entries: 1024 (order: 5, 131072 bytes)
  6997	[    0.144050] xor: measuring software checksum speed
  6998	[    0.176262]    8regs     :  1933.200 MB/sec
  6999	[    0.209641]    8regs_prefetch:  1720.800 MB/sec
  7000	[    0.243028]    32regs    :  2287.200 MB/sec
  7001	[    0.276414]    32regs_prefetch:  1995.600 MB/sec
  7002	[    0.276420] xor: using function: 32regs (2287.200 MB/sec)
  7003	[    0.276481] atomic64_test: passed
  7004	[    0.276487] pinctrl core: initialized pinctrl subsystem
  7005	[    0.277654] NET: Registered protocol family 16
  7006	[    0.278817] dump_class_init,861, success
  7007	[    0.296479] cpuidle: using governor menu
  7008	[    0.297921] sunxi iommu: irq = 8
  7009	[    0.298250] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  7010	[    0.298267] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  7011	[    0.299690] DMA: preallocated 256 KiB pool for atomic allocations
  7012	[    0.301073] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  7013	[    0.315450] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  7014	[    0.319373] iommu: Adding device 1c0e000.ve to group 0
  7015	[    0.319896] iommu: Adding device 1c00000.vp9 to group 0
  7016	[    0.331336] iommu: Adding device 1000000.disp to group 0
  7017	[    0.332744] iommu: Adding device 1480000.g2d to group 0
  7018	[    0.335938] iommu: Adding device csi0 to group 0
  7019	[    0.336392] iommu: Adding device csi1 to group 0
  7020	[    0.337594] iommu: Adding device 6600800.vind:scaler@0 to group 0
  7021	[    0.337887] iommu: Adding device 6600800.vind:scaler@1 to group 0
  7022	[    0.338197] iommu: Adding device 6600800.vind:scaler@2 to group 0
  7023	[    0.338484] iommu: Adding device 6600800.vind:scaler@3 to group 0
  7024	[    0.338767] iommu: Adding device 6600800.vind:scaler@4 to group 0
  7025	[    0.339049] iommu: Adding device 6600800.vind:scaler@5 to group 0
  7026	[    0.340020] iommu: Adding device vinc0 to group 0
  7027	[    0.340615] iommu: Adding device vinc1 to group 0
  7028	[    0.342081] iommu: Adding device 1420000.deinterlace to group 0
  7029	[    0.387873] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  7030	[    0.444149] raid6: int64x1  gen()   393 MB/s
  7031	[    0.500762] raid6: int64x1  xor()   364 MB/s
  7032	[    0.557586] raid6: int64x2  gen()   591 MB/s
  7033	[    0.614335] raid6: int64x2  xor()   512 MB/s
  7034	[    0.671105] raid6: int64x4  gen()   840 MB/s
  7035	[    0.727900] raid6: int64x4  xor()   629 MB/s
  7036	[    0.784647] raid6: int64x8  gen()   964 MB/s
  7037	[    0.841457] raid6: int64x8  xor()   655 MB/s
  7038	[    0.898234] raid6: neonx1   gen()   648 MB/s
  7039	[    0.954993] raid6: neonx1   xor()   641 MB/s
  7040	[    1.011776] raid6: neonx2   gen()   976 MB/s
  7041	[    1.068564] raid6: neonx2   xor()   819 MB/s
  7042	[    1.125350] raid6: neonx4   gen()  1287 MB/s
  7043	[    1.182100] raid6: neonx4   xor()   965 MB/s
  7044	[    1.238914] raid6: neonx8   gen()  1324 MB/s
  7045	[    1.295675] raid6: neonx8   xor()   991 MB/s
  7046	[    1.295680] raid6: using algorithm neonx8 gen() 1324 MB/s
  7047	[    1.295685] raid6: .... xor() 991 MB/s, rmw enabled
  7048	[    1.295691] raid6: using intx1 recovery algorithm
  7049	[    1.295829] pwm module init!
  7050	[    1.300128] sunxi-pm debug v3.10
  7051	[    1.301208] SCSI subsystem initialized
  7052	[    1.301846] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  7053	[    1.301929] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  7054	[    1.302048] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  7055	[    1.302569] spi spi0: master is unqueued, this is deprecated
  7056	[    1.302881] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  7057	[    1.303458] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  7058	[    1.303540] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  7059	[    1.303657] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  7060	[    1.304121] spi spi1: master is unqueued, this is deprecated
  7061	[    1.304430] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  7062	[    1.305270] usbcore: registered new interface driver usbfs
  7063	[    1.305352] usbcore: registered new interface driver hub
  7064	[    1.305421] usbcore: registered new device driver usb
  7065	[    1.305590] sunxi_i2c_adap_init()2522 - init
  7066	[    1.306154] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  7067	[    1.306248] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  7068	[    1.306255] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  7069	[    1.306271] twi3 supply twi not found, using dummy regulator
  7070	[    1.306354] twi_request_gpio()451 - [i2c3] init name: twi3
  7071	[    1.307109] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  7072	[    1.307190] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  7073	[    1.307197] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  7074	[    1.307211] twi5 supply twi not found, using dummy regulator
  7075	[    1.307285] twi_request_gpio()451 - [i2c5] init name: twi5
  7076	[    1.307766] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  7077	[    1.326358] random: fast init done
  7078	[    1.337543] axp20x-i2c 5-0036: AXP20X driver loaded
  7079	[    1.338038] media: Linux media interface: v0.10
  7080	[    1.338149] Linux video capture interface: v2.00
  7081	[    1.341644] Advanced Linux Sound Architecture Driver Initialized.
  7082	[    1.342376] Bluetooth: Core ver 2.22
  7083	[    1.342475] NET: Registered protocol family 31
  7084	[    1.342481] Bluetooth: HCI device and connection manager initialized
  7085	[    1.342497] Bluetooth: HCI socket layer initialized
  7086	[    1.342510] Bluetooth: L2CAP socket layer initialized
  7087	[    1.342549] Bluetooth: SCO socket layer initialized
  7088	[    1.343348] [DISP]disp_module_init
  7089	[    1.344556] [DISP] parser_disp_init_para,line:1403:
  7090	[    1.344565] of_property_read fb0_width fail
  7091	[    1.344577] [DISP] disp_init,line:2215:
  7092	[    1.344583] smooth display screen:0 type:4 mode:10
  7093	[    1.361858] [DISP]disp_module_init finish
  7094	[    1.362779] clocksource: Switched to clocksource arch_sys_counter
  7095	[    1.363033] VFS: Disk quotas dquot_6.6.0
  7096	[    1.363120] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  7097	[    1.363882] Console: switching to colour frame buffer device 240x67
  7098	[    1.407227] NET: Registered protocol family 2
  7099	[    1.407354] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  7100	[    1.426377] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  7101	[    1.426450] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  7102	[    1.426572] TCP: Hash tables configured (established 8192 bind 8192)
  7103	[    1.426659] UDP hash table entries: 512 (order: 2, 16384 bytes)
  7104	[    1.426686] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  7105	[    1.427011] NET: Registered protocol family 1
  7106	[    1.427623] RPC: Registered named UNIX socket transport module.
  7107	[    1.427628] RPC: Registered udp transport module.
  7108	[    1.427631] RPC: Registered tcp transport module.
  7109	[    1.427634] RPC: Registered tcp NFSv4.1 backchannel transport module.
  7110	[    1.427904] Trying to unpack rootfs image as initramfs...
  7111	[    2.181948] Freeing initrd memory: 17256K
  7112	[    2.183090] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  7113	[    2.186984] audit: initializing netlink subsys (disabled)
  7114	[    2.187040] audit: type=2000 audit(2.183:1): initialized
  7115	[    2.187965] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  7116	[    2.199123] DLM installed
  7117	[    2.200975] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  7118	[    2.201311] Registering sdcardfs 0.1
  7119	[    2.201792] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  7120	[    2.203342] ntfs: driver 2.1.32 [Flags: R/W].
  7121	[    2.209765] NET: Registered protocol family 38
  7122	[    2.210131] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  7123	[    2.210270] io scheduler noop registered
  7124	[    2.210278] io scheduler deadline registered
  7125	[    2.210443] io scheduler cfq registered (default)
  7126	[    2.212267] failed to get easy_light_used assign
  7127	[    2.212277] failed to get normal led pin assign
  7128	[    2.212283] failed to get standby led pin assign
  7129	[    2.212288] failed to get standby led pin assign
  7130	[    2.212293] these is zero number for gpio
  7131	[    2.212298] gpio_init finish with uesd
  7132	[    2.215523] uart uart0: get regulator failed
  7133	[    2.215723] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  7134	[    2.215746] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  7135	[    2.215842] console [ttyS0] enabled
  7136	[    2.216722] uart uart1: get regulator failed
  7137	[    2.216914] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  7138	[    2.217636] uart uart5: get regulator failed
  7139	[    2.217824] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  7140	[    2.219118] misc dump reg init
  7141	[    2.220682] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  7142	[    2.221027] Unable to detect cache hierarchy for CPU 0
  7143	[    2.235199] brd: module loaded
  7144	[    2.243362] loop: module loaded
  7145	[    2.243551] [NAND][NE] Not found valid nand node on dts
  7146	[    2.244133] Get boot type cmd line fail
  7147	[    2.244717] sunxi-bt soc@03000000:bt: Missing bt_power.
  7148	[    2.244727] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  7149	[    2.244735] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  7150	[    2.244741] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  7151	[    2.244798] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  7152	[    2.244869] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  7153	[    2.245712] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  7154	[    2.245723] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  7155	[    2.245730] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  7156	[    2.245737] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  7157	[    2.245744] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  7158	[    2.245774] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  7159	[    2.245806] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  7160	[    2.245814] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  7161	[    2.245831] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  7162	[    2.246834] [ADDR_MGT] addr_mgt_probe: success.
  7163	[    2.253317] tun: Universal TUN/TAP device driver, 1.6
  7164	[    2.253327] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  7165	[    2.255320] gmac-power0: NULL
  7166	[    2.255329] gmac-power1: NULL
  7167	[    2.255335] gmac-power2: NULL
  7168	[    2.256289] PPP generic driver version 2.4.2
  7169	[    2.256610] PPP BSD Compression module registered
  7170	[    2.256620] PPP Deflate Compression module registered
  7171	[    2.256652] PPP MPPE Compression module registered
  7172	[    2.256661] NET: Registered protocol family 24
  7173	[    2.256695] PPTP driver version 0.8.5
  7174	[    2.257063] usbcore: registered new interface driver r8152
  7175	[    2.257140] usbcore: registered new interface driver asix
  7176	[    2.257232] usbcore: registered new interface driver ax88179_178a
  7177	[    2.257297] usbcore: registered new interface driver cdc_ether
  7178	[    2.257357] usbcore: registered new interface driver net1080
  7179	[    2.257416] usbcore: registered new interface driver cdc_subset
  7180	[    2.257474] usbcore: registered new interface driver zaurus
  7181	[    2.257574] usbcore: registered new interface driver cdc_ncm
  7182	[    2.257581] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  7183	[    2.257942] get drv_vbus is fail, 84
  7184	[    2.257950] get ehci0-controller, regulator_io is no nocare
  7185	[    2.258212] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  7186	[    2.258218] [sunxi-ehci0]: Not init ehci0
  7187	[    2.258335] get ehci1-controller, regulator_io is no nocare
  7188	[    2.258519] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  7189	[    2.258578] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7190	[    2.258604] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  7191	[    2.259184] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  7192	[    2.269475] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  7193	[    2.269763] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  7194	[    2.269772] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7195	[    2.269780] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7196	[    2.269787] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  7197	[    2.269794] usb usb1: SerialNumber: sunxi-ehci
  7198	[    2.270655] hub 1-0:1.0: USB hub found
  7199	[    2.270701] hub 1-0:1.0: 1 port detected
  7200	[    2.271370] get drv_vbus is fail, 84
  7201	[    2.271379] get ehci2-controller, regulator_io is no nocare
  7202	[    2.271622] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  7203	[    2.271682] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7204	[    2.271707] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  7205	[    2.271982] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  7206	[    2.282810] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  7207	[    2.283024] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  7208	[    2.283033] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7209	[    2.283040] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7210	[    2.283048] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  7211	[    2.283054] usb usb2: SerialNumber: sunxi-ehci
  7212	[    2.283925] hub 2-0:1.0: USB hub found
  7213	[    2.283969] hub 2-0:1.0: 1 port detected
  7214	[    2.284638] get drv_vbus is fail, 84
  7215	[    2.284646] get ehci3-controller, regulator_io is no nocare
  7216	[    2.284893] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  7217	[    2.284944] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7218	[    2.284969] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  7219	[    2.285283] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  7220	[    2.296127] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  7221	[    2.296319] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  7222	[    2.296328] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7223	[    2.296336] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  7224	[    2.296343] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  7225	[    2.296350] usb usb3: SerialNumber: sunxi-ehci
  7226	[    2.297209] hub 3-0:1.0: USB hub found
  7227	[    2.297254] hub 3-0:1.0: 1 port detected
  7228	[    2.298190] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  7229	[    2.298560] get drv_vbus is fail, 84
  7230	[    2.298568] get ohci0-controller, regulator_io is no nocare
  7231	[    2.298901] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  7232	[    2.298906] [sunxi-ohci0]: Not init ohci0
  7233	[    2.299023] get ohci1-controller, regulator_io is no nocare
  7234	[    2.299189] hci: request ohci1-controller gpio:80
  7235	[    2.299268] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  7236	[    2.299319] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7237	[    2.299345] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  7238	[    2.299423] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  7239	[    2.360295] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  7240	[    2.360306] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7241	[    2.360313] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7242	[    2.360321] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  7243	[    2.360328] usb usb4: SerialNumber: sunxi-ohci
  7244	[    2.361205] hub 4-0:1.0: USB hub found
  7245	[    2.361252] hub 4-0:1.0: 1 port detected
  7246	[    2.361920] get drv_vbus is fail, 84
  7247	[    2.361928] get ohci2-controller, regulator_io is no nocare
  7248	[    2.362257] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  7249	[    2.362308] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7250	[    2.362335] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  7251	[    2.362419] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  7252	[    2.420292] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  7253	[    2.420302] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7254	[    2.420310] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7255	[    2.420317] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  7256	[    2.420324] usb usb5: SerialNumber: sunxi-ohci
  7257	[    2.421182] hub 5-0:1.0: USB hub found
  7258	[    2.421226] hub 5-0:1.0: 1 port detected
  7259	[    2.421906] get drv_vbus is fail, 84
  7260	[    2.421914] get ohci3-controller, regulator_io is no nocare
  7261	[    2.422239] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  7262	[    2.422288] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7263	[    2.422313] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  7264	[    2.422392] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  7265	[    2.480310] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  7266	[    2.480320] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  7267	[    2.480328] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  7268	[    2.480335] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  7269	[    2.480342] usb usb6: SerialNumber: sunxi-ohci
  7270	[    2.481176] hub 6-0:1.0: USB hub found
  7271	[    2.481227] hub 6-0:1.0: 1 port detected
  7272	[    2.482149] ohci-platform: OHCI generic platform driver
  7273	[    2.482889] usbcore: registered new interface driver uas
  7274	[    2.483057] usbcore: registered new interface driver usb-storage
  7275	[    2.483145] usbcore: registered new interface driver ums-alauda
  7276	[    2.483221] usbcore: registered new interface driver ums-cypress
  7277	[    2.483291] usbcore: registered new interface driver ums-datafab
  7278	[    2.483370] usbcore: registered new interface driver ums_eneub6250
  7279	[    2.483440] usbcore: registered new interface driver ums-freecom
  7280	[    2.483511] usbcore: registered new interface driver ums-isd200
  7281	[    2.483579] usbcore: registered new interface driver ums-jumpshot
  7282	[    2.483648] usbcore: registered new interface driver ums-karma
  7283	[    2.483717] usbcore: registered new interface driver ums-onetouch
  7284	[    2.483809] usbcore: registered new interface driver ums-realtek
  7285	[    2.483893] usbcore: registered new interface driver ums-sddr09
  7286	[    2.483964] usbcore: registered new interface driver ums-sddr55
  7287	[    2.484034] usbcore: registered new interface driver ums-usbat
  7288	[    2.484183] usb_serial_number:20080411
  7289	[    2.485425] input: sunxi-keyboard as /devices/virtual/input/input0
  7290	[    2.486025] usbcore: registered new interface driver xpad
  7291	[    2.486169] usbcore: registered new interface driver usb_acecad
  7292	[    2.486264] usbcore: registered new interface driver aiptek
  7293	[    2.486343] usbcore: registered new interface driver gtco
  7294	[    2.486422] usbcore: registered new interface driver hanwang
  7295	[    2.486501] usbcore: registered new interface driver kbtab
  7296	[    2.486984] axp2101_pek: axp2101-pek can not register without irq
  7297	[    2.487007] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  7298	[    2.488438] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  7299	[    2.488502] sunxi-rtc rtc: RTC enabled
  7300	[    2.489001] i2c /dev entries driver
  7301	[    2.489834] lirc_dev: IR Remote Control driver registered, major 244
  7302	[    2.489847] IR NEC protocol handler initialized
  7303	[    2.489853] IR RC5(x/sz) protocol handler initialized
  7304	[    2.489859] IR RC6 protocol handler initialized
  7305	[    2.489865] IR JVC protocol handler initialized
  7306	[    2.489870] IR Sony protocol handler initialized
  7307	[    2.489876] IR SANYO protocol handler initialized
  7308	[    2.489882] IR Sharp protocol handler initialized
  7309	[    2.489888] IR MCE Keyboard/mouse protocol handler initialized
  7310	[    2.489893] IR LIRC bridge handler initialized
  7311	[    2.489898] IR XMP protocol handler initialized
  7312	[    2.490427] sunxi_ir_startup: get ir protocol failed
  7313	[    2.490471] 7040000.s_cir supply ir0 not found, using dummy regulator
  7314	[    2.490653] Registered IR keymap rc_map_sunxi
  7315	[    2.491052] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  7316	[    2.491306] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  7317	[    2.492317] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  7318	[    2.492953] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  7319	[    2.493657] sunxi cedar version 0.1
  7320	[    2.493847] VE: install start!!!
  7321
  7322	[    2.494037] cedar_ve: cedar-ve the get irq is 278
  7323	[    2.494672] VE: get debugfs_mpp_root is NULL, please check mpp
  7324
  7325	[    2.494685] VE: sunxi ve debug register driver failed!
  7326
  7327	[    2.497872] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  7328	[    2.499171] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  7329	[    2.499531] Bluetooth: HCI UART driver ver 2.3
  7330	[    2.499542] Bluetooth: HCI UART protocol H4 registered
  7331	[    2.499547] Bluetooth: HCI UART protocol LL registered
  7332	[    2.499554] Bluetooth: HCI UART protocol Three-wire (H5) registered
  7333	[    2.503735] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  7334	[    2.503751] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  7335	[    2.503764] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  7336	[    2.503776] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  7337	[    2.503788] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  7338	[    2.503800] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  7339	[    2.504220] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  7340	[    2.504336] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  7341	[    2.504533] sunxi-mmc sdc0: No vmmc regulator found
  7342	[    2.504540] sunxi-mmc sdc0: No vqmmc regulator found
  7343	[    2.504546] sunxi-mmc sdc0: No vdmmc regulator found
  7344	[    2.504552] sunxi-mmc sdc0: No vd33sw regulator found
  7345	[    2.504559] sunxi-mmc sdc0: No vd18sw regulator found
  7346	[    2.504565] sunxi-mmc sdc0: No vq33sw regulator found
  7347	[    2.504571] sunxi-mmc sdc0: No vq18sw regulator found
  7348	[    2.505287] sunxi-mmc sdc0: set host busy
  7349	[    2.505383] sunxi-mmc sdc0: Got CD GPIO
  7350	[    2.505768] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  7351	[    2.505807] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  7352	[    2.519473] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7353	[    2.536426] sunxi-mmc sdc0: detmode:gpio irq
  7354	[    2.536459] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7355	[    2.538963] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7356	[    2.540325] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  7357	[    2.540461] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  7358	[    2.540604] sunxi-mmc sdc1: No vmmc regulator found
  7359	[    2.540611] sunxi-mmc sdc1: No vqmmc regulator found
  7360	[    2.540617] sunxi-mmc sdc1: No vdmmc regulator found
  7361	[    2.540624] sunxi-mmc sdc1: No vd33sw regulator found
  7362	[    2.540630] sunxi-mmc sdc1: No vd18sw regulator found
  7363	[    2.540636] sunxi-mmc sdc1: No vq33sw regulator found
  7364	[    2.540642] sunxi-mmc sdc1: No vq18sw regulator found
  7365	[    2.541246] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7366	[    2.542509] sunxi-mmc sdc1: set host busy
  7367	[    2.542591] mmc:failed to get gpios
  7368	[    2.543734] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7369	[    2.545000] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  7370	[    2.559526] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7371	[    2.567486] mmc0: host does not support reading read-only switch, assuming write-enable
  7372	[    2.569393] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  7373	[    2.569483] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  7374	[    2.569629] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  7375	[    2.569719] mmc0: new high speed SDXC card at address 0001
  7376	[    2.574095] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  7377	[    2.575723]  mmcblk0: p1
  7378	[    2.576275] sunxi-mmc sdc1: detmode:manually by software
  7379	[    2.577158] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  7380	[    2.578572] ledtrig-cpu: registered to indicate activity on CPUs
  7381	[    2.579300] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  7382	[    2.579336] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7383	[    2.581911] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7384	[    2.583839] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  7385	[    2.584675] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  7386	[    2.585510] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  7387	[    2.586345] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  7388	[    2.586391] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  7389	[    2.586772] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  7390	[    2.586778] sunxi_emce_probe()590emce hw init failed!
  7391	[    2.586804] emce: probe of emce failed with error -2
  7392	[    2.587070] hidraw: raw HID events driver (C) Jiri Kosina
  7393	[    2.590537] usbcore: registered new interface driver usbhid
  7394	[    2.590545] usbhid: USB HID core driver
  7395	[    2.591815] optee: probing for conduit method from DT.
  7396	[    2.591827] optee: api uid mismatch
  7397	[    2.592469] usbcore: registered new interface driver snd-usb-audio
  7398	[    2.594847] [sunxi_hdmi_codec_init] driver and deivce register finished.
  7399	[    2.597097] [sunxi_internal_codec_probe]:get audio avcc failed
  7400	[    2.597135] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  7401	[    2.597359] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  7402	[    2.599957] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  7403	[    2.601928] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  7404	[    2.601941] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  7405	[    2.604379] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  7406	[    2.604404] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  7407	[    2.608337] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  7408	[    2.609749] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  7409	[    2.611618] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  7410	[    2.614757] pktgen: Packet Generator for packet performance testing. Version: 2.75
  7411	[    2.615204] u32 classifier
  7412	[    2.615211]     Actions configured
  7413	[    2.615223] Netfilter messages via NETLINK v0.30.
  7414	[    2.615251] nfnl_acct: registering with nfnetlink.
  7415	[    2.615593] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  7416	[    2.615842] ctnetlink v0.93: registering with nfnetlink.
  7417	[    2.616662] xt_time: kernel timezone is -0000
  7418	[    2.616686] IPVS: Registered protocols (TCP, UDP)
  7419	[    2.616790] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  7420	[    2.616915] IPVS: Creating netns size=1928 id=0
  7421	[    2.617048] IPVS: ipvs loaded.
  7422	[    2.617056] IPVS: [rr] scheduler registered.
  7423	[    2.617156] ipip: IPv4 and MPLS over IPv4 tunneling driver
  7424	[    2.617859] gre: GRE over IPv4 demultiplexor driver
  7425	[    2.617869] ip_gre: GRE over IPv4 tunneling driver
  7426	[    2.619142] IPv4 over IPsec tunneling driver
  7427	[    2.620078] ip_tables: (C) 2000-2006 Netfilter Core Team
  7428	[    2.620360] arp_tables: arp_tables: (C) 2002 David S. Miller
  7429	[    2.620428] Initializing XFRM netlink socket
  7430	[    2.620461] IPsec XFRM device driver
  7431	[    2.621305] NET: Registered protocol family 10
  7432	[    2.623214] mip6: Mobile IPv6
  7433	[    2.623253] ip6_tables: (C) 2000-2006 Netfilter Core Team
  7434	[    2.624571] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  7435	[    2.626483] NET: Registered protocol family 17
  7436	[    2.626533] NET: Registered protocol family 15
  7437	[    2.626696] Bridge firewalling registered
  7438	[    2.626857] Bluetooth: RFCOMM TTY layer initialized
  7439	[    2.626878] Bluetooth: RFCOMM socket layer initialized
  7440	[    2.626915] Bluetooth: RFCOMM ver 1.11
  7441	[    2.626930] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  7442	[    2.626936] Bluetooth: BNEP filters: protocol multicast
  7443	[    2.626950] Bluetooth: BNEP socket layer initialized
  7444	[    2.626955] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  7445	[    2.626967] Bluetooth: HIDP socket layer initialized
  7446	[    2.627052] l2tp_core: L2TP core driver, V2.0
  7447	[    2.627068] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  7448	[    2.627074] 8021q: 802.1Q VLAN Support v1.8
  7449	[    2.627278] sctp: Hash tables configured (bind 256/256)
  7450	[    2.627866] Key type dns_resolver registered
  7451	[    2.628005] Registered cp15_barrier emulation handler
  7452	[    2.628017] Registered setend emulation handler
  7453	[    2.628922] registered taskstats version 1
  7454	[    2.640553] zswap: default zpool zbud not available
  7455	[    2.640561] zswap: pool creation failed
  7456	[    2.643425] Btrfs loaded, crc32c=crc32c-arm64-hw
  7457	[    2.644174] HDMI 2.0 driver init start!
  7458	[    2.644189] boot_hdmi=true
  7459	[    2.645058] Can not find the node of esm
  7460	[    2.645079] ERROR: pinctrl_get for HDMI2.0 DDC fail
  7461	[    2.645170] Get hdmi_power0:vcc-hdmi
  7462	[    2.645210] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  7463	[    2.645401] Get hdmi_power1:vdd-hdmi
  7464	[    2.645425] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  7465	[    2.647008] hdmi_cec_init
  7466	[    2.647509] [DISP] disp_device_attached,line:146:
  7467	[    2.647519] attached ok, mgr0<-->device0, type=4
  7468	[    2.647529] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  7469	[    2.647541] [DISP] disp_hdmi_set_mode,line:648:
  7470	[    2.647546] hdmi_set_mode is null!
  7471	[    2.649787] HDMI2.0 module init end
  7472	[    2.660885] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  7473	[    2.664523] cpu cpu1: opp_list_debug_create_link: Failed to create link
  7474	[    2.664535] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  7475	[    2.664568] cpu cpu2: opp_list_debug_create_link: Failed to create link
  7476	[    2.664575] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  7477	[    2.664605] cpu cpu3: opp_list_debug_create_link: Failed to create link
  7478	[    2.664613] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  7479	[    2.666916] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  7480	[    2.667820] get det_vbus is fail, 84
  7481	[    2.667827] get id is fail, 84
  7482	[    2.668300] sunxi-rtc rtc: setting system clock to 2023-09-25 18:18:46 UTC (1695665926)
  7483	[    2.672091] ALSA device list:
  7484	[    2.672099]   #0: audiocodec
  7485	[    2.672103]   #1: sndahub
  7486	[    2.672106]   #2: sndhdmi
  7487	[    2.673747] Freeing unused kernel memory: 3008K
  7488	[    2.718922] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  7489	[    2.721056] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  7490	[    2.724330] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  7491	[    2.796516] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  7492	[    2.959558] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  7493	[    3.052820] HDMI cable is connected
  7494	[    3.309468] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  7495	[    3.529904] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  7496	[    3.529914] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  7497	[    3.529919] usb 4-1: Product: Rapoo 2.4G Wireless Device
  7498	[    3.529924] usb 4-1: Manufacturer: RAPOO
  7499	[    3.537841] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  7500	[    3.538427] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  7501	[    3.544586] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  7502	[    3.600307] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  7503	[    3.604165] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  7504	[    3.661441] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  7505	[    4.240626] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  7506	[    5.145795] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  7507	[    5.146414] cgroup: cgroup2: unknown option "nsdelegate"
  7508	[    5.166417] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  7509	[    5.166442] systemd[1]: Detected architecture arm64.
  7510	[    5.167573] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  7511	[    5.177663] systemd[1]: Hostname set to <opi>.
  7512	[    5.204773] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  7513	[    6.811857] (sd-execut[1456]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  7514	[    6.829498]
  7515	               insmod_device_driver
  7516
  7517	[    6.829774] device_chose finished 124!
  7518	[    7.179240] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  7519	[    7.418750] systemd[1]: Queued start job for default target graphical.target.
  7520	[    7.426080] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  7521	[    7.428409] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  7522	[    7.430737] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  7523	[    7.432003] systemd[1]: Created slice user.slice - User and Session Slice.
  7524	[    7.432654] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  7525	[    7.433310] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  7526	[    7.433681] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  7527	[    7.434215] systemd[1]: Reached target slices.target - Slice Units.
  7528	[    7.434632] systemd[1]: Reached target swap.target - Swaps.
  7529	[    7.434911] systemd[1]: Reached target time-set.target - System Time Set.
  7530	[    7.435401] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  7531	[    7.452861] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  7532	[    7.453967] systemd[1]: Listening on syslog.socket - Syslog Socket.
  7533	[    7.454906] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  7534	[    7.455555] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  7535	[    7.457208] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  7536	[    7.458156] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  7537	[    7.459235] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  7538	[    7.461469] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  7539	[    7.462357] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  7540	[    7.466421] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  7541	[    7.471032] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  7542	[    7.475978] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  7543	[    7.477424] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  7544	[    7.478405] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  7545	[    7.486045] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  7546	[    7.491690] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  7547	[    7.497469] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  7548	[    7.506003] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  7549	[    7.515590] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  7550	[    7.527791] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  7551	[    7.535173] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  7552	[    7.543132] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  7553	[    7.551053] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  7554	[    7.552604] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  7555	[    7.562751] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  7556	[    7.569321] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  7557	[    7.574418] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  7558	[    7.584799] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  7559	[    7.587299] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  7560	[    7.589247] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  7561	[    7.592005] fuse init (API version 7.26)
  7562	[    7.593312] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  7563	[    7.599112] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  7564	[    7.603263] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  7565	[    7.603890] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  7566	[    7.608223] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  7567	[    7.644815] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  7568	[    7.656743] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  7569	[    7.662023] systemd[1]: modprobe@drm.service: Deactivated successfully.
  7570	[    7.662567] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  7571	[    7.664769] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  7572	[    7.665330] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  7573	[    7.667531] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  7574	[    7.668055] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  7575	[    7.670976] systemd[1]: modprobe@loop.service: Deactivated successfully.
  7576	[    7.675122] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  7577	[    7.683286] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  7578	[    7.684222] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  7579	[    7.684232] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  7580	[    7.684421] spidev spi1.1: Deleting spi1.1
  7581	[    7.685390] fbtft_device: GPIOS used by 'fb_st7735r':
  7582	[    7.685397] fbtft_device: 'reset' = GPIO73
  7583	[    7.685401] fbtft_device: 'dc' = GPIO70
  7584	[    7.685412] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  7585	[    7.685418] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  7586	[    7.696780] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  7587	[    7.722550] WCN: marlin_init entry!
  7588	[    7.723788] WCN: marlin_parse_dt reset gpio=211
  7589	[    7.723799] WCN_ERR: gpio reset request err: 211
  7590	[    7.723804] WCN: wcn config bt wake host
  7591	[    7.724317] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  7592	[    7.724446] WCN: wcn config wifi wake host
  7593	[    7.724465] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  7594	[    7.728152] sdiohal:sdiohal_init ok
  7595	[    7.729058] WCN: marlin_probe ok!
  7596	[    7.737855] mtty_probe init device addr: 0xffffffc0095b6e00
  7597	[    7.738035] -->rfkill_bluetooth_init
  7598	[    7.738242] <--rfkill_bluetooth_init
  7599	[    7.750168] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  7600	[    7.758288] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  7601	[    7.764967] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  7602	[    7.765975] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  7603	[    7.782030] WCN: start_marlin [MARLIN_WIFI]
  7604	[    7.782044] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  7605	[    7.782048] WCN: the first power on start
  7606	[    7.791125] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  7607	[    7.791851] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  7608	[    7.798448] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  7609	[    7.804260] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  7610	[    7.807510] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  7611	[    7.825607] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  7612	[    7.884017] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  7613	[    7.890545] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  7614	[    7.896198] WCN: marlin chip en pull up
  7615	[    7.922933] sdiohal:sdiohal_scan_card
  7616	[    7.922967] sunxi-wlan soc@03000000:wlan: bus_index: 1
  7617	[    7.923018] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  7618	[    7.939528] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7619	[    7.960381] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  7620	[    7.961290] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  7621	[    7.961331] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7622	[    7.963903] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7623	[    7.967016] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7624	[    7.982832] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  7625	[    7.989419] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  7626	[    7.991496] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  7627	[    7.993907] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  7628	[    7.994700] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  7629	[    7.994798] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  7630	[    7.995529] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  7631	[    7.996246] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  7632	[    7.996461] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  7633	[    7.996490] WCN: marlin_scan_finish!
  7634	[    7.996494] sdiohal:probe ok
  7635	[    7.996505] sdiohal:scan end!
  7636	[    7.996511] WCN: then marlin start to download
  7637	[    7.996551] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  7638	[    7.997527] systemd[1]: Mounting tmp.mount - /tmp...
  7639	[    8.033608] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  7640	[    8.038411] systemd[1]: Mounted tmp.mount - /tmp.
  7641	[    8.041135] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  7642	[    8.043567] systemd[1]: Reached target local-fs.target - Local File Systems.
  7643	[    8.048513] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  7644	[    8.053562] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  7645	[    8.087280] systemd[1]: Starting console-setup.service - Set console font and keymap...
  7646	[    8.102521] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  7647	[    8.112421] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  7648	[    8.130433] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  7649	[    8.133574] WCN: combin_img 0 marlin_firmware_write finish and successful
  7650	[    8.133756] WCN: marlin_start_run read reset reg val:0x1
  7651	[    8.133760] WCN: after do marlin_start_run reset reg val:0x0
  7652	[    8.133966] WCN: s_marlin_bootup_time=8133959468
  7653	[    8.138879] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  7654	[    8.139807] WCN: clock mode: TSX
  7655	[    8.140084] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  7656	[    8.147303] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  7657	[    8.151926] systemd[1]: Finished console-setup.service - Set console font and keymap.
  7658	[    8.164753] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  7659	[    8.167222] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  7660	[    8.182202] systemd[1]: Received SIGRTMIN+20 from PID 1419 (plymouthd).
  7661	[    8.193224] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
  7662	[    8.193235] WCN: sdio_config bt_wake_host trigger:[high]
  7663	[    8.193239] WCN: sdio_config irq:[inband]
  7664	[    8.193244] WCN: sdio_config wl_wake_host trigger:[high]
  7665	[    8.193249] WCN: sdio_config wake_host_level_duration_time:[20ms]
  7666	[    8.193252] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
  7667	[    8.193256] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
  7668	[    8.193618] WCN: marlin_write_cali_data finish
  7669	[    8.193804] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  7670	[    8.210627] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  7671	[    8.217819] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  7672	[    8.219776] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  7673	[    8.222579] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  7674	[    8.223377] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  7675	[    8.224142] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  7676	[    8.227534] systemd[1]: Reached target network-pre.target - Preparation for Network.
  7677	[    8.246350] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  7678	[    8.270355] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  7679	[    8.273053] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  7680	[    8.299706] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  7681	[    8.327502] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
  7682	[    8.327514] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
  7683	[    8.327533] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
  7684	[    8.328066] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
  7685	[    8.353173] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
  7686	[    8.353181] sdiohal:sdiohal_runtime_get entry
  7687	[    8.353343] WCN: get_cp2_version entry!
  7688	[    8.354857] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
  7689	[    8.354887] WCN: switch_cp2_log - close entry!
  7690	[    8.356169] WCN: WCND at cmd read:OK
  7691	[    8.356226] WCN: then marlin download finished and run ok
  7692	[    8.356231] WCN: start_loopcheck
  7693	[    8.374295] WCN: get_board_ant_num [one_ant]
  7694	[    8.374308] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
  7695	[    8.436980] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
  7696	[    8.441339] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  7697	[    8.449680] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  7698	[    8.520727] zram: Added device: zram0
  7699	[    8.521818] zram: Added device: zram1
  7700	[    8.522652] zram: Added device: zram2
  7701	[    8.547016] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  7702	[    8.556837] systemd[1]: Starting networking.service - Raise network interfaces...
  7703	[    8.560976] zswap: can't enable, initialization failed
  7704	[    8.593041] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  7705	[    8.612058] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  7706	[    8.622557] zram0: detected capacity change from 0 to 506396672
  7707	[    8.689130] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  7708	[    8.695579] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  7709	[    8.697665] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  7710	[    8.698424] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  7711	[    8.698850] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  7712	[    9.164249] systemd[1]: Finished networking.service - Raise network interfaces.
  7713	[    9.885868] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  7714	[    9.949826] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  7715	[   10.196492] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  7716	[   10.835602] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  7717	[   10.835936] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  7718	[   10.837595] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  7719	[   10.838464] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  7720	[   10.858823] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  7721	[   10.892384] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  7722	[   10.902749] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  7723	[   10.912628] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  7724	[   10.919820] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  7725	[   10.927187] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  7726	[   10.936512] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  7727	[   10.938331] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  7728	[   10.941050] systemd[1]: modprobe@loop.service: Deactivated successfully.
  7729	[   10.941884] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  7730	[   10.954859] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  7731	[   10.955133] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  7732	[   11.014423] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  7733	[   11.017667] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  7734	[   11.018461] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  7735	[   11.020090] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  7736	[   11.054368] sunxi-bt soc@03000000:bt: set block: 0
  7737	[   11.068226] bluetooth_set_power: start_block=0
  7738	[   11.068238] WCN: start_marlin [MARLIN_BLUETOOTH]
  7739	[   11.068249] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
  7740	[   11.068253] WCN: marlin have open, GNSS is closed
  7741	[   11.068258] bluetooth_set_power: end_block=0
  7742	[   11.082041] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  7743	[   11.101996] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  7744	[   11.107741] systemd[1]: Starting brltty.service - Braille Device Support...
  7745	[   11.665490] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  7746	[   11.811684] zram1: detected capacity change from 0 to 52428800
  7747	[   11.867311] systemd[1]: Started brltty.service - Braille Device Support.
  7748	[   11.887015] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  7749	[   15.912948] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  7750	[   15.918761] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  7751	[   15.980222] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  7752	[   16.099167] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  7753	[   19.866397] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  7754	[   19.872691] systemd[1]: Starting systemd-journald.service - Journal Service...
  7755	[   20.143398] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
  7756	[   20.143420] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  7757	[   20.150867] systemd[1]: Started systemd-journald.service - Journal Service.
  7758	[   20.197915] systemd-journald[1921]: Received client request to flush runtime journal.
  7759	[   20.271279] systemd-journald[1921]: Data hash table of /var/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 77.0 (3505 of 4551 items, 2621440 file size, 747 bytes per hash table item), suggesting rotation.
  7760	[   20.271303] systemd-journald[1921]: /var/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  7761	[   20.676205] IPVS: Creating netns size=1928 id=1
  7762
  7763	### armbian-release:
  7764
  7765	# PLEASE DO NOT EDIT THIS FILE
  7766	BOARD=orangepizero2
  7767	BOARD_NAME="Orange Pi Zero2"
  7768	BOARDFAMILY=sun50iw9
  7769	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  7770	BUILD_REPOSITORY_COMMIT=ac829eb6
  7771	LINUXFAMILY=sun50iw9
  7772	ARCH=arm64
  7773	IMAGE_TYPE=stable
  7774	BOARD_TYPE=conf
  7775	INITRD_ARCH=arm
  7776	KERNEL_IMAGE_TYPE=Image
  7777	FORCE_BOOTSCRIPT_UPDATE=yes
  7778	VENDOR=Armbian
  7779	BOOTSCRIPT_FORCE_UPDATE="yes"
  7780	BOOTSCRIPT_DST="boot.cmd"
  7781	VERSION=23.8.1
  7782	REVISION=23.8.1
  7783	BRANCH=legacy
  7784
  7785	### boot environment:
  7786
  7787	verbosity=1
  7788	console=serial
  7789	#disp_mode=1080p60
  7790	#fb0_width=1280
  7791	#fb0_height=720
  7792	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  7793	rootfstype=ext4
  7794	overlays=spi-spidev
  7795	param_spidev_spi_bus=1
  7796	param_spidev_spi_cs=1
  7797	extraargs=fbcon=map:1
  7798	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  7799
  7800	### lsusb:
  7801
  7802	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  7803	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7804	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  7805	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7806	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  7807	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  7808	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  7809
  7810	### lscpu:
  7811
  7812	Architecture:        aarch64
  7813	CPU op-mode(s):      32-bit, 64-bit
  7814	Byte Order:          Little Endian
  7815	CPU(s):              4
  7816	On-line CPU(s) list: 0-3
  7817	Vendor ID:           ARM
  7818	Model name:          Cortex-A53
  7819	Model:               4
  7820	Thread(s) per core:  1
  7821	Core(s) per cluster: 4
  7822	Socket(s):           -
  7823	Cluster(s):          1
  7824	Stepping:            r0p4
  7825	CPU(s) scaling MHz:  100%
  7826	CPU max MHz:         1512.0000
  7827	CPU min MHz:         480.0000
  7828	BogoMIPS:            48.00
  7829	Flags:               fp asimd aes pmull sha1 sha2 crc32
  7830
  7831	### cpuinfo:
  7832
  7833	processor	: 0
  7834	BogoMIPS	: 48.00
  7835	Features	: fp asimd aes pmull sha1 sha2 crc32
  7836	CPU implementer	: 0x41
  7837	CPU architecture: 8
  7838	CPU variant	: 0x0
  7839	CPU part	: 0xd03
  7840	CPU revision	: 4
  7841
  7842	processor	: 1
  7843	BogoMIPS	: 48.00
  7844	Features	: fp asimd aes pmull sha1 sha2 crc32
  7845	CPU implementer	: 0x41
  7846	CPU architecture: 8
  7847	CPU variant	: 0x0
  7848	CPU part	: 0xd03
  7849	CPU revision	: 4
  7850
  7851	processor	: 2
  7852	BogoMIPS	: 48.00
  7853	Features	: fp asimd aes pmull sha1 sha2 crc32
  7854	CPU implementer	: 0x41
  7855	CPU architecture: 8
  7856	CPU variant	: 0x0
  7857	CPU part	: 0xd03
  7858	CPU revision	: 4
  7859
  7860	processor	: 3
  7861	BogoMIPS	: 48.00
  7862	Features	: fp asimd aes pmull sha1 sha2 crc32
  7863	CPU implementer	: 0x41
  7864	CPU architecture: 8
  7865	CPU variant	: 0x0
  7866	CPU part	: 0xd03
  7867	CPU revision	: 4
  7868
  7869
  7870	### meminfo:
  7871
  7872	MemTotal:         989056 kB
  7873	MemFree:          791132 kB
  7874	MemAvailable:     886204 kB
  7875	Buffers:           15672 kB
  7876	Cached:            86408 kB
  7877	SwapCached:            0 kB
  7878	Active:            66432 kB
  7879	Inactive:          56804 kB
  7880	Active(anon):      21348 kB
  7881	Inactive(anon):      632 kB
  7882	Active(file):      45084 kB
  7883	Inactive(file):    56172 kB
  7884	Unevictable:           0 kB
  7885	Mlocked:               0 kB
  7886	SwapTotal:        494524 kB
  7887	SwapFree:         494524 kB
  7888	Dirty:             10092 kB
  7889	Writeback:             0 kB
  7890	AnonPages:         21068 kB
  7891	Mapped:            24172 kB
  7892	Shmem:               808 kB
  7893	Slab:              33212 kB
  7894	SReclaimable:       9276 kB
  7895	SUnreclaim:        23936 kB
  7896	KernelStack:        2544 kB
  7897	PageTables:         1056 kB
  7898	NFS_Unstable:          0 kB
  7899	Bounce:                0 kB
  7900	WritebackTmp:          0 kB
  7901	CommitLimit:      989052 kB
  7902	Committed_AS:      79860 kB
  7903	VmallocTotal:   263061440 kB
  7904	VmallocUsed:           0 kB
  7905	VmallocChunk:          0 kB
  7906	CmaTotal:          16384 kB
  7907	CmaFree:            7468 kB
  7908	HugePages_Total:       0
  7909	HugePages_Free:        0
  7910	HugePages_Rsvd:        0
  7911	HugePages_Surp:        0
  7912	Hugepagesize:       2048 kB
  7913
  7914	### virtual memory:
  7915
  7916	vm.admin_reserve_kbytes = 8192
  7917	vm.block_dump = 0
  7918	vm.compact_unevictable_allowed = 1
  7919	vm.dirty_background_bytes = 0
  7920	vm.dirty_background_ratio = 10
  7921	vm.dirty_bytes = 0
  7922	vm.dirty_expire_centisecs = 3000
  7923	vm.dirty_ratio = 20
  7924	vm.dirtytime_expire_seconds = 43200
  7925	vm.dirty_writeback_centisecs = 500
  7926	vm.extfrag_threshold = 500
  7927	vm.extra_free_kbytes = 0
  7928	vm.hugepages_treat_as_movable = 0
  7929	vm.hugetlb_shm_group = 0
  7930	vm.laptop_mode = 0
  7931	vm.legacy_va_layout = 0
  7932	vm.lowmem_reserve_ratio = 256	32
  7933	vm.max_map_count = 65530
  7934	vm.min_free_kbytes = 3937
  7935	vm.mmap_min_addr = 4096
  7936	vm.mmap_rnd_bits = 18
  7937	vm.mmap_rnd_compat_bits = 11
  7938	vm.nr_hugepages = 0
  7939	vm.nr_overcommit_hugepages = 0
  7940	vm.nr_pdflush_threads = 0
  7941	vm.oom_dump_tasks = 1
  7942	vm.oom_kill_allocating_task = 0
  7943	vm.overcommit_kbytes = 0
  7944	vm.overcommit_memory = 0
  7945	vm.overcommit_ratio = 50
  7946	vm.page-cluster = 0
  7947	vm.panic_on_oom = 0
  7948	vm.percpu_pagelist_fraction = 0
  7949	vm.stat_interval = 1
  7950	vm.swappiness = 100
  7951	vm.user_reserve_kbytes = 29994
  7952	vm.vfs_cache_pressure = 100
  7953	vm.watermark_scale_factor = 10
  7954
  7955	### ip addr:
  7956
  7957	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  7958	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  7959	    inet XXX.XXX.0.1/8 scope host lo
  7960	       valid_lft forever preferred_lft forever
  7961	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7962	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  7963	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7964	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  7965	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  7966	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  7967	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  7968	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  7969	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  7970	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  7971	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  7972	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  7973	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  7974	    link/tunnel6 :: brd ::
  7975	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  7976	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  7977	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  7978	    link/tunnel6 :: brd ::
  7979	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  7980	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  7981
  7982	### partitions:
  7983
  7984	major minor  #blocks  name
  7985
  7986	 179        0   62410752 mmcblk0
  7987	 179        1   61763584 mmcblk0p1
  7988	 253        0     494528 zram0
  7989	 253        1      51200 zram1
  7990
  7991	### df:
  7992
  7993	udev            466M     0  466M   0% /dev
  7994	tmpfs            97M  2.1M   95M   3% /run
  7995	/dev/mmcblk0p1   58G  7.3G   51G  13% /
  7996	tmpfs           483M     0  483M   0% /dev/shm
  7997	tmpfs           5.0M     0  5.0M   0% /run/lock
  7998	tmpfs           483M  4.0K  483M   1% /tmp
  7999	/dev/zram1       47M  9.8M   34M  23% /var/log
  8000
  8001	### lsblk:
  8002
  8003	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  8004	mmcblk0             59.5G
  8005	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  8006	zram1                 50M /var/log
  8007	zram2                  0B
  8008
  8009	### zramctl:
  8010
  8011	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  8012	/dev/zram1 lz4            50M  9.8M  2.6M  3.1M       4 /var/log
  8013	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  8014
  8015	### mtab:
  8016
  8017	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  8018	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  8019	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  8020
  8021	### mmc0:0001 info:
  8022
  8023	              manfid: 0x0000fe
  8024	                 cid: fe3432534431364720000000690091f5
  8025	               fwrev: 0x0
  8026	                 csd: 400e00325b590001dc277f800a40008b
  8027	                 ocr: 0x00200000
  8028	                type: SD
  8029	                date: 01/2009
  8030	               hwrev: 0x2
  8031	                 dsr: 0x404
  8032	              serial: 0x00000069
  8033	          erase_size: 512
  8034	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  8035	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  8036	                 scr: 0285808300000000
  8037	               oemid: 0x3432
  8038	preferred_erase_size: 4194304
  8039	                name: SD16G
  8040
  8041	### Boot system health:
  8042
  8043	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  8044	15:19:07  1512 MHz  1.10  39%  19%  13%   0%   6%   0%  52.2 °C  0/5
  8045	15:19:07  1512 MHz  1.10  95%  31%  45%   1%  17%   0%  49.6 °C  0/5
  8046	15:19:07  1512 MHz  1.10  99%  29%  48%   0%  20%   0%  49.6 °C  0/5
  8047	15:19:08  1512 MHz  1.10  99%  38%  52%   0%   7%   0%  51.7 °C  0/5
  8048	15:19:08  1512 MHz  1.10  98%  28%  63%   0%   5%   0%  51.7 °C  0/5
  8049
  8050	### Activated 1 lzo zram swap devices with 482MB each.
  8051	### Activated Armbian ramlog partition with lz4 compression
  8052
  8053	Mon Sep 25 03:30:19 PM -03 2023 | Orange Pi Zero2 | 23.8.1 | arm64 | aarch64 | 4.9.318-legacy-sun50iw9
  8054
  8055	### dmesg:
  8056
  8057	[    0.000000] Booting Linux on physical CPU 0x0
  8058	[    0.000000] Linux version 4.9.318-legacy-sun50iw9 (armbian@next) (gcc version 11.4.0 (Ubuntu 11.4.0-1ubuntu1~22.04) ) #1 SMP PREEMPT Tue May 17 02:06:13 UTC 2022
  8059	[    0.000000] Boot CPU: AArch64 Processor [410fd034]
  8060	[    0.000000] disp reserve base 0x7bf4fcc0 ,size 0x384000
  8061	[    0.000000] cma: Reserved 16 MiB at 0x000000007f000000
  8062	[    0.000000] On node 0 totalpages: 262144
  8063	[    0.000000]   DMA zone: 4096 pages used for memmap
  8064	[    0.000000]   DMA zone: 0 pages reserved
  8065	[    0.000000]   DMA zone: 262144 pages, LIFO batch:31
  8066	[    0.000000] psci: probing for conduit method from DT.
  8067	[    0.000000] psci: PSCIv1.0 detected in firmware.
  8068	[    0.000000] psci: Using standard PSCI v0.2 function IDs
  8069	[    0.000000] psci: Trusted OS migration not required
  8070	[    0.000000] psci: SMC Calling Convention v1.0
  8071	[    0.000000] percpu: Embedded 21 pages/cpu s45592 r8192 d32232 u86016
  8072	[    0.000000] pcpu-alloc: s45592 r8192 d32232 u86016 alloc=21*4096
  8073	[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
  8074	[    0.000000] Detected VIPT I-cache on CPU0
  8075	[    0.000000] CPU features: enabling workaround for ARM erratum 845719
  8076	[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 258048
  8077	[    0.000000] Kernel command line: root=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e rootwait rootfstype=ext4 splash=verbose console=ttyS0,115200 consoleblank=0 loglevel=1 ubootpart=68ea14b7-01 disp_reserve=3686400,0x7bf4fcc0 fbcon=map:1
  8078	[    0.000000] log_buf_len individual max cpu contribution: 131072 bytes
  8079	[    0.000000] log_buf_len total cpu_extra contributions: 393216 bytes
  8080	[    0.000000] log_buf_len min size: 131072 bytes
  8081	[    0.000000] log_buf_len: 524288 bytes
  8082	[    0.000000] early log buf free: 129352(98%)
  8083	[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
  8084	[    0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes)
  8085	[    0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes)
  8086	[    0.000000] Memory: 952408K/1048576K available (11902K kernel code, 1476K rwdata, 6668K rodata, 3008K init, 674K bss, 79784K reserved, 16384K cma-reserved)
  8087	[    0.000000] Virtual kernel memory layout:
  8088	[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
  8089	[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
  8090	[    0.000000]       .text : 0xffffff8008208000 - 0xffffff8008da8000   ( 11904 KB)
  8091	[    0.000000]     .rodata : 0xffffff8008da8000 - 0xffffff8009438000   (  6720 KB)
  8092	[    0.000000]       .init : 0xffffff8009438000 - 0xffffff8009728000   (  3008 KB)
  8093	[    0.000000]       .data : 0xffffff8009728000 - 0xffffff8009899008   (  1477 KB)
  8094	[    0.000000]        .bss : 0xffffff8009899008 - 0xffffff8009941b94   (   675 KB)
  8095	[    0.000000]     fixed   : 0xffffffbefe7fb000 - 0xffffffbefec00000   (  4116 KB)
  8096	[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
  8097	[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
  8098	[    0.000000]               0xffffffbf00000000 - 0xffffffbf01000000   (    16 MB actual)
  8099	[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc040000000   (  1024 MB)
  8100	[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
  8101	[    0.000000] Preemptible hierarchical RCU implementation.
  8102	[    0.000000] 	Build-time adjustment of leaf fanout to 64.
  8103	[    0.000000] NR_IRQS:64 nr_irqs:64 0
  8104	[    0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  8105	[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (virt).
  8106	[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
  8107	[    0.000004] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
  8108	[    0.000226] Console: colour dummy device 80x25
  8109	[    0.000240] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=80000)
  8110	[    0.000250] pid_max: default: 32768 minimum: 301
  8111	[    0.000445] Security Framework initialized
  8112	[    0.000453] AppArmor: AppArmor disabled by boot time parameter
  8113	[    0.000570] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes)
  8114	[    0.000576] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes)
  8115	[    0.001838] sched-energy: CPU device node has no sched-energy-costs
  8116	[    0.001854] Invalid sched_group_energy for CPU0
  8117	[    0.001861] CPU0: update cpu_capacity 1024
  8118	[    0.008972] ASID allocator initialised with 32768 entries
  8119	[    0.027949] BOOTEVENT:        27.933623: ON
  8120	[    0.055922] Detected VIPT I-cache on CPU1
  8121	[    0.055976] Invalid sched_group_energy for CPU1
  8122	[    0.055979] CPU1: update cpu_capacity 1024
  8123	[    0.055982] CPU1: Booted secondary processor [410fd034]
  8124	[    0.079312] Detected VIPT I-cache on CPU2
  8125	[    0.079350] Invalid sched_group_energy for CPU2
  8126	[    0.079353] CPU2: update cpu_capacity 1024
  8127	[    0.079356] CPU2: Booted secondary processor [410fd034]
  8128	[    0.102713] Detected VIPT I-cache on CPU3
  8129	[    0.102748] Invalid sched_group_energy for CPU3
  8130	[    0.102752] CPU3: update cpu_capacity 1024
  8131	[    0.102754] CPU3: Booted secondary processor [410fd034]
  8132	[    0.102833] Brought up 4 CPUs
  8133	[    0.102841] SMP: Total of 4 processors activated.
  8134	[    0.102849] CPU features: detected feature: 32-bit EL0 Support
  8135	[    0.102855] CPU features: detected feature: Kernel page table isolation (KPTI)
  8136	[    0.106620] CPU: All CPU(s) started at EL1
  8137	[    0.106643] alternatives: patching kernel code
  8138	[    0.106819] Invalid sched_group_energy for CPU3
  8139	[    0.106829] CPU3: update max cpu_capacity 1024
  8140	[    0.106834] Invalid sched_group_energy for Cluster3
  8141	[    0.106839] Invalid sched_group_energy for CPU2
  8142	[    0.106845] Invalid sched_group_energy for Cluster2
  8143	[    0.106849] Invalid sched_group_energy for CPU1
  8144	[    0.106855] Invalid sched_group_energy for Cluster1
  8145	[    0.106860] Invalid sched_group_energy for CPU0
  8146	[    0.106865] Invalid sched_group_energy for Cluster0
  8147	[    0.108291] devtmpfs: initialized
  8148	[    0.112724] CPU1: update max cpu_capacity 1024
  8149	[    0.143412] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
  8150	[    0.143433] futex hash table entries: 1024 (order: 5, 131072 bytes)
  8151	[    0.144092] xor: measuring software checksum speed
  8152	[    0.176256]    8regs     :  1933.200 MB/sec
  8153	[    0.209635]    8regs_prefetch:  1720.800 MB/sec
  8154	[    0.243021]    32regs    :  2287.200 MB/sec
  8155	[    0.276408]    32regs_prefetch:  1935.600 MB/sec
  8156	[    0.276414] xor: using function: 32regs (2287.200 MB/sec)
  8157	[    0.276474] atomic64_test: passed
  8158	[    0.276480] pinctrl core: initialized pinctrl subsystem
  8159	[    0.277654] NET: Registered protocol family 16
  8160	[    0.278809] dump_class_init,861, success
  8161	[    0.296468] cpuidle: using governor menu
  8162	[    0.297898] sunxi iommu: irq = 8
  8163	[    0.298211] vdso: 2 pages (1 code @ ffffff8008daf000, 1 data @ ffffff800972c000)
  8164	[    0.298228] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
  8165	[    0.299630] DMA: preallocated 256 KiB pool for atomic allocations
  8166	[    0.301010] sun50iw9p1-r-pinctrl r_pio: initialized sunXi PIO driver
  8167	[    0.315366] sun50iw9p1-pinctrl pio: initialized sunXi PIO driver
  8168	[    0.319287] iommu: Adding device 1c0e000.ve to group 0
  8169	[    0.319799] iommu: Adding device 1c00000.vp9 to group 0
  8170	[    0.331254] iommu: Adding device 1000000.disp to group 0
  8171	[    0.332671] iommu: Adding device 1480000.g2d to group 0
  8172	[    0.335875] iommu: Adding device csi0 to group 0
  8173	[    0.336335] iommu: Adding device csi1 to group 0
  8174	[    0.337567] iommu: Adding device 6600800.vind:scaler@0 to group 0
  8175	[    0.337861] iommu: Adding device 6600800.vind:scaler@1 to group 0
  8176	[    0.338173] iommu: Adding device 6600800.vind:scaler@2 to group 0
  8177	[    0.338459] iommu: Adding device 6600800.vind:scaler@3 to group 0
  8178	[    0.338742] iommu: Adding device 6600800.vind:scaler@4 to group 0
  8179	[    0.339026] iommu: Adding device 6600800.vind:scaler@5 to group 0
  8180	[    0.339983] iommu: Adding device vinc0 to group 0
  8181	[    0.340544] iommu: Adding device vinc1 to group 0
  8182	[    0.341998] iommu: Adding device 1420000.deinterlace to group 0
  8183	[    0.391224] HugeTLB registered 2 MB page size, pre-allocated 0 pages
  8184	[    0.447338] raid6: int64x1  gen()   391 MB/s
  8185	[    0.504125] raid6: int64x1  xor()   363 MB/s
  8186	[    0.560790] raid6: int64x2  gen()   590 MB/s
  8187	[    0.617590] raid6: int64x2  xor()   512 MB/s
  8188	[    0.674310] raid6: int64x4  gen()   840 MB/s
  8189	[    0.731025] raid6: int64x4  xor()   628 MB/s
  8190	[    0.787767] raid6: int64x8  gen()   964 MB/s
  8191	[    0.844540] raid6: int64x8  xor()   655 MB/s
  8192	[    0.901328] raid6: neonx1   gen()   648 MB/s
  8193	[    0.958023] raid6: neonx1   xor()   641 MB/s
  8194	[    1.014746] raid6: neonx2   gen()   975 MB/s
  8195	[    1.071510] raid6: neonx2   xor()   819 MB/s
  8196	[    1.128240] raid6: neonx4   gen()  1286 MB/s
  8197	[    1.184979] raid6: neonx4   xor()   965 MB/s
  8198	[    1.241748] raid6: neonx8   gen()  1323 MB/s
  8199	[    1.298459] raid6: neonx8   xor()   991 MB/s
  8200	[    1.298465] raid6: using algorithm neonx8 gen() 1323 MB/s
  8201	[    1.298470] raid6: .... xor() 991 MB/s, rmw enabled
  8202	[    1.298475] raid6: using intx1 recovery algorithm
  8203	[    1.298647] pwm module init!
  8204	[    1.302976] sunxi-pm debug v3.10
  8205	[    1.304067] SCSI subsystem initialized
  8206	[    1.304687] sunxi_spi_probe()2299 - [spi0] SPI MASTER MODE
  8207	[    1.304772] sunxi_spi_request_gpio()1927 - [spi0] Pinctrl init spi0
  8208	[    1.304889] sunxi_spi_clk_init()1977 - [spi0] mclk 100000000
  8209	[    1.305384] spi spi0: master is unqueued, this is deprecated
  8210	[    1.305695] sunxi_spi_probe()2379 - [spi0]: driver probe succeed, base ffffff8008066000, irq 294
  8211	[    1.306284] sunxi_spi_probe()2299 - [spi1] SPI MASTER MODE
  8212	[    1.306365] sunxi_spi_request_gpio()1927 - [spi1] Pinctrl init spi1
  8213	[    1.306483] sunxi_spi_clk_init()1977 - [spi1] mclk 100000000
  8214	[    1.306950] spi spi1: master is unqueued, this is deprecated
  8215	[    1.307263] sunxi_spi_probe()2379 - [spi1]: driver probe succeed, base ffffff8008068000, irq 295
  8216	[    1.308058] usbcore: registered new interface driver usbfs
  8217	[    1.308143] usbcore: registered new interface driver hub
  8218	[    1.308221] usbcore: registered new device driver usb
  8219	[    1.308375] sunxi_i2c_adap_init()2522 - init
  8220	[    1.308951] sunxi_i2c_probe()2208 - [i2c3] warning: failed to get regulator id
  8221	[    1.309047] sunxi_i2c_probe()2270 - [i2c3] twi_drv_used = 0
  8222	[    1.309054] sunxi_i2c_probe()2274 - [i2c3] twi_pkt_interval = 0
  8223	[    1.309070] twi3 supply twi not found, using dummy regulator
  8224	[    1.309146] twi_request_gpio()451 - [i2c3] init name: twi3
  8225	[    1.309915] sunxi_i2c_probe()2208 - [i2c5] warning: failed to get regulator id
  8226	[    1.309994] sunxi_i2c_probe()2270 - [i2c5] twi_drv_used = 0
  8227	[    1.310001] sunxi_i2c_probe()2274 - [i2c5] twi_pkt_interval = 0
  8228	[    1.310015] twi5 supply twi not found, using dummy regulator
  8229	[    1.310090] twi_request_gpio()451 - [i2c5] init name: twi5
  8230	[    1.310571] axp20x-i2c 5-0036: AXP20x variant AXP806 found
  8231	[    1.329304] random: fast init done
  8232	[    1.340490] axp20x-i2c 5-0036: AXP20X driver loaded
  8233	[    1.340973] media: Linux media interface: v0.10
  8234	[    1.341049] Linux video capture interface: v2.00
  8235	[    1.341908] Advanced Linux Sound Architecture Driver Initialized.
  8236	[    1.342633] Bluetooth: Core ver 2.22
  8237	[    1.342705] NET: Registered protocol family 31
  8238	[    1.342711] Bluetooth: HCI device and connection manager initialized
  8239	[    1.342727] Bluetooth: HCI socket layer initialized
  8240	[    1.342739] Bluetooth: L2CAP socket layer initialized
  8241	[    1.342777] Bluetooth: SCO socket layer initialized
  8242	[    1.343552] [DISP]disp_module_init
  8243	[    1.344766] [DISP] parser_disp_init_para,line:1403:
  8244	[    1.344776] of_property_read fb0_width fail
  8245	[    1.344788] [DISP] disp_init,line:2215:
  8246	[    1.344794] smooth display screen:0 type:4 mode:10
  8247	[    1.362118] [DISP]disp_module_init finish
  8248	[    1.362980] clocksource: Switched to clocksource arch_sys_counter
  8249	[    1.363241] VFS: Disk quotas dquot_6.6.0
  8250	[    1.363330] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
  8251	[    1.364068] Console: switching to colour frame buffer device 240x67
  8252	[    1.407307] NET: Registered protocol family 2
  8253	[    1.407432] IP idents hash table entries: 16384 (order: 5, 131072 bytes)
  8254	[    1.419902] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
  8255	[    1.419977] TCP bind hash table entries: 8192 (order: 5, 131072 bytes)
  8256	[    1.420100] TCP: Hash tables configured (established 8192 bind 8192)
  8257	[    1.420192] UDP hash table entries: 512 (order: 2, 16384 bytes)
  8258	[    1.420220] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
  8259	[    1.420538] NET: Registered protocol family 1
  8260	[    1.421159] RPC: Registered named UNIX socket transport module.
  8261	[    1.421164] RPC: Registered udp transport module.
  8262	[    1.421167] RPC: Registered tcp transport module.
  8263	[    1.421170] RPC: Registered tcp NFSv4.1 backchannel transport module.
  8264	[    1.421447] Trying to unpack rootfs image as initramfs...
  8265	[    2.175632] Freeing initrd memory: 17256K
  8266	[    2.176730] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
  8267	[    2.180610] audit: initializing netlink subsys (disabled)
  8268	[    2.180669] audit: type=2000 audit(2.176:1): initialized
  8269	[    2.181586] workingset: timestamp_bits=45 max_order=18 bucket_order=0
  8270	[    2.192665] DLM installed
  8271	[    2.194509] squashfs: version 4.0 (2009/01/31) Phillip Lougher
  8272	[    2.194846] Registering sdcardfs 0.1
  8273	[    2.195314] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
  8274	[    2.196852] ntfs: driver 2.1.32 [Flags: R/W].
  8275	[    2.203364] NET: Registered protocol family 38
  8276	[    2.203725] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
  8277	[    2.203867] io scheduler noop registered
  8278	[    2.203874] io scheduler deadline registered
  8279	[    2.204034] io scheduler cfq registered (default)
  8280	[    2.205837] failed to get easy_light_used assign
  8281	[    2.205848] failed to get normal led pin assign
  8282	[    2.205854] failed to get standby led pin assign
  8283	[    2.205858] failed to get standby led pin assign
  8284	[    2.205864] these is zero number for gpio
  8285	[    2.205868] gpio_init finish with uesd
  8286	[    2.209224] uart uart0: get regulator failed
  8287	[    2.209419] uart0: ttyS0 at MMIO 0x5000000 (irq = 280, base_baud = 1500000) is a SUNXI
  8288	[    2.209441] sw_console_setup()1706 - console setup baud 115200 parity n bits 8, flow n
  8289	[    2.209530] console [ttyS0] enabled
  8290	[    2.210376] uart uart1: get regulator failed
  8291	[    2.210568] uart1: ttyS1 at MMIO 0x5000400 (irq = 281, base_baud = 1500000) is a SUNXI
  8292	[    2.211256] uart uart5: get regulator failed
  8293	[    2.211441] uart5: ttyS5 at MMIO 0x5001400 (irq = 282, base_baud = 1500000) is a SUNXI
  8294	[    2.212650] misc dump reg init
  8295	[    2.214153] deinterlace 1420000.deinterlace: version[1.0.0], ip=0x300100
  8296	[    2.214492] Unable to detect cache hierarchy for CPU 0
  8297	[    2.228621] brd: module loaded
  8298	[    2.236971] loop: module loaded
  8299	[    2.237161] [NAND][NE] Not found valid nand node on dts
  8300	[    2.237751] Get boot type cmd line fail
  8301	[    2.238358] sunxi-bt soc@03000000:bt: Missing bt_power.
  8302	[    2.238368] sunxi-bt soc@03000000:bt: bt_power_name ((null))
  8303	[    2.238376] sunxi-bt soc@03000000:bt: Missing bt_io_regulator.
  8304	[    2.238383] sunxi-bt soc@03000000:bt: io_regulator_name ((null))
  8305	[    2.238438] sunxi-bt soc@03000000:bt: bt_rst gpio=211  mul-sel=1  pull=-1  drv_level=-1  data=0
  8306	[    2.238509] sunxi-bt soc@03000000:bt: devm_pinctrl_get() failed!
  8307	[    2.239340] sunxi-wlan soc@03000000:wlan: wlan_busnum (1)
  8308	[    2.239351] sunxi-wlan soc@03000000:wlan: Missing wlan_power.
  8309	[    2.239358] sunxi-wlan soc@03000000:wlan: wlan_power_name ((null))
  8310	[    2.239365] sunxi-wlan soc@03000000:wlan: Missing wlan_io_regulator.
  8311	[    2.239372] sunxi-wlan soc@03000000:wlan: io_regulator_name ((null))
  8312	[    2.239400] sunxi-wlan soc@03000000:wlan: wlan_regon gpio=210  mul-sel=1  pull=-1  drv_level=-1  data=0
  8313	[    2.239433] sunxi-wlan soc@03000000:wlan: get gpio chip_en failed
  8314	[    2.239441] sunxi-wlan soc@03000000:wlan: get gpio power_en failed
  8315	[    2.239459] sunxi-wlan soc@03000000:wlan: wlan_hostwake gpio=207  mul-sel=6  pull=-1  drv_level=-1  data=0
  8316	[    2.240488] [ADDR_MGT] addr_mgt_probe: success.
  8317	[    2.247040] tun: Universal TUN/TAP device driver, 1.6
  8318	[    2.247049] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
  8319	[    2.249068] gmac-power0: NULL
  8320	[    2.249077] gmac-power1: NULL
  8321	[    2.249083] gmac-power2: NULL
  8322	[    2.250067] PPP generic driver version 2.4.2
  8323	[    2.250358] PPP BSD Compression module registered
  8324	[    2.250367] PPP Deflate Compression module registered
  8325	[    2.250393] PPP MPPE Compression module registered
  8326	[    2.250401] NET: Registered protocol family 24
  8327	[    2.250436] PPTP driver version 0.8.5
  8328	[    2.250796] usbcore: registered new interface driver r8152
  8329	[    2.250879] usbcore: registered new interface driver asix
  8330	[    2.250978] usbcore: registered new interface driver ax88179_178a
  8331	[    2.251047] usbcore: registered new interface driver cdc_ether
  8332	[    2.251115] usbcore: registered new interface driver net1080
  8333	[    2.251177] usbcore: registered new interface driver cdc_subset
  8334	[    2.251244] usbcore: registered new interface driver zaurus
  8335	[    2.251332] usbcore: registered new interface driver cdc_ncm
  8336	[    2.251338] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  8337	[    2.251694] get drv_vbus is fail, 84
  8338	[    2.251702] get ehci0-controller, regulator_io is no nocare
  8339	[    2.251972] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xffffff800992ac30, 0x:ffffff80081c1000, irq_no:11e
  8340	[    2.251978] [sunxi-ehci0]: Not init ehci0
  8341	[    2.252100] get ehci1-controller, regulator_io is no nocare
  8342	[    2.252283] [sunxi-ehci1]: probe, pdev->name: 5200000.ehci1-controller, sunxi_ehci: 0xffffff800992a8e8, 0x:ffffff80081c5000, irq_no:120
  8343	[    2.252343] sunxi-ehci 5200000.ehci1-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8344	[    2.252369] sunxi-ehci 5200000.ehci1-controller: new USB bus registered, assigned bus number 1
  8345	[    2.252940] sunxi-ehci 5200000.ehci1-controller: irq 288, io mem 0xffffff80081c5000
  8346	[    2.266333] sunxi-ehci 5200000.ehci1-controller: USB 0.0 started, EHCI 1.00
  8347	[    2.266621] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
  8348	[    2.266630] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8349	[    2.266638] usb usb1: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8350	[    2.266645] usb usb1: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  8351	[    2.266652] usb usb1: SerialNumber: sunxi-ehci
  8352	[    2.267517] hub 1-0:1.0: USB hub found
  8353	[    2.267564] hub 1-0:1.0: 1 port detected
  8354	[    2.268248] get drv_vbus is fail, 84
  8355	[    2.268255] get ehci2-controller, regulator_io is no nocare
  8356	[    2.268498] [sunxi-ehci2]: probe, pdev->name: 5310000.ehci2-controller, sunxi_ehci: 0xffffff800992a5a0, 0x:ffffff80081cf000, irq_no:122
  8357	[    2.268550] sunxi-ehci 5310000.ehci2-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8358	[    2.268575] sunxi-ehci 5310000.ehci2-controller: new USB bus registered, assigned bus number 2
  8359	[    2.268856] sunxi-ehci 5310000.ehci2-controller: irq 290, io mem 0xffffff80081cf000
  8360	[    2.279667] sunxi-ehci 5310000.ehci2-controller: USB 0.0 started, EHCI 1.00
  8361	[    2.279900] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
  8362	[    2.279908] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8363	[    2.279916] usb usb2: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8364	[    2.279923] usb usb2: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  8365	[    2.279930] usb usb2: SerialNumber: sunxi-ehci
  8366	[    2.280780] hub 2-0:1.0: USB hub found
  8367	[    2.280827] hub 2-0:1.0: 1 port detected
  8368	[    2.281492] get drv_vbus is fail, 84
  8369	[    2.281501] get ehci3-controller, regulator_io is no nocare
  8370	[    2.281752] [sunxi-ehci3]: probe, pdev->name: 5311000.ehci3-controller, sunxi_ehci: 0xffffff800992a258, 0x:ffffff80081d9000, irq_no:124
  8371	[    2.281804] sunxi-ehci 5311000.ehci3-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8372	[    2.281829] sunxi-ehci 5311000.ehci3-controller: new USB bus registered, assigned bus number 3
  8373	[    2.282118] sunxi-ehci 5311000.ehci3-controller: irq 292, io mem 0xffffff80081d9000
  8374	[    2.292996] sunxi-ehci 5311000.ehci3-controller: USB 0.0 started, EHCI 1.00
  8375	[    2.293184] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
  8376	[    2.293193] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8377	[    2.293201] usb usb3: Product: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
  8378	[    2.293208] usb usb3: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ehci_hcd
  8379	[    2.293214] usb usb3: SerialNumber: sunxi-ehci
  8380	[    2.294072] hub 3-0:1.0: USB hub found
  8381	[    2.294127] hub 3-0:1.0: 1 port detected
  8382	[    2.295056] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
  8383	[    2.295424] get drv_vbus is fail, 84
  8384	[    2.295433] get ohci0-controller, regulator_io is no nocare
  8385	[    2.295766] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xffffff800992b950
  8386	[    2.295771] [sunxi-ohci0]: Not init ohci0
  8387	[    2.295894] get ohci1-controller, regulator_io is no nocare
  8388	[    2.296065] hci: request ohci1-controller gpio:80
  8389	[    2.296142] [sunxi-ohci1]: probe, pdev->name: 5200000.ohci1-controller, sunxi_ohci: 0xffffff800992b608
  8390	[    2.296193] sunxi-ohci 5200000.ohci1-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8391	[    2.296221] sunxi-ohci 5200000.ohci1-controller: new USB bus registered, assigned bus number 4
  8392	[    2.296349] sunxi-ohci 5200000.ohci1-controller: irq 289, io mem 0x00000000
  8393	[    2.357161] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
  8394	[    2.357171] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8395	[    2.357179] usb usb4: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8396	[    2.357186] usb usb4: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  8397	[    2.357193] usb usb4: SerialNumber: sunxi-ohci
  8398	[    2.358062] hub 4-0:1.0: USB hub found
  8399	[    2.358111] hub 4-0:1.0: 1 port detected
  8400	[    2.358785] get drv_vbus is fail, 84
  8401	[    2.358793] get ohci2-controller, regulator_io is no nocare
  8402	[    2.359127] [sunxi-ohci2]: probe, pdev->name: 5310000.ohci2-controller, sunxi_ohci: 0xffffff800992b2c0
  8403	[    2.359176] sunxi-ohci 5310000.ohci2-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8404	[    2.359200] sunxi-ohci 5310000.ohci2-controller: new USB bus registered, assigned bus number 5
  8405	[    2.359276] sunxi-ohci 5310000.ohci2-controller: irq 291, io mem 0x00000000
  8406	[    2.417156] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
  8407	[    2.417165] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8408	[    2.417173] usb usb5: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8409	[    2.417180] usb usb5: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  8410	[    2.417187] usb usb5: SerialNumber: sunxi-ohci
  8411	[    2.418050] hub 5-0:1.0: USB hub found
  8412	[    2.418098] hub 5-0:1.0: 1 port detected
  8413	[    2.418769] get drv_vbus is fail, 84
  8414	[    2.418778] get ohci3-controller, regulator_io is no nocare
  8415	[    2.419116] [sunxi-ohci3]: probe, pdev->name: 5311000.ohci3-controller, sunxi_ohci: 0xffffff800992af78
  8416	[    2.419164] sunxi-ohci 5311000.ohci3-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8417	[    2.419189] sunxi-ohci 5311000.ohci3-controller: new USB bus registered, assigned bus number 6
  8418	[    2.419272] sunxi-ohci 5311000.ohci3-controller: irq 293, io mem 0x00000000
  8419	[    2.477167] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
  8420	[    2.477177] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
  8421	[    2.477185] usb usb6: Product: SW USB2.0 'Open' Host Controller (OHCI) Driver
  8422	[    2.477192] usb usb6: Manufacturer: Linux 4.9.318-legacy-sun50iw9 ohci_hcd
  8423	[    2.477199] usb usb6: SerialNumber: sunxi-ohci
  8424	[    2.478053] hub 6-0:1.0: USB hub found
  8425	[    2.478102] hub 6-0:1.0: 1 port detected
  8426	[    2.479025] ohci-platform: OHCI generic platform driver
  8427	[    2.479761] usbcore: registered new interface driver uas
  8428	[    2.479930] usbcore: registered new interface driver usb-storage
  8429	[    2.480022] usbcore: registered new interface driver ums-alauda
  8430	[    2.480105] usbcore: registered new interface driver ums-cypress
  8431	[    2.480180] usbcore: registered new interface driver ums-datafab
  8432	[    2.480252] usbcore: registered new interface driver ums_eneub6250
  8433	[    2.480324] usbcore: registered new interface driver ums-freecom
  8434	[    2.480398] usbcore: registered new interface driver ums-isd200
  8435	[    2.480467] usbcore: registered new interface driver ums-jumpshot
  8436	[    2.480538] usbcore: registered new interface driver ums-karma
  8437	[    2.480610] usbcore: registered new interface driver ums-onetouch
  8438	[    2.480705] usbcore: registered new interface driver ums-realtek
  8439	[    2.480786] usbcore: registered new interface driver ums-sddr09
  8440	[    2.480860] usbcore: registered new interface driver ums-sddr55
  8441	[    2.480930] usbcore: registered new interface driver ums-usbat
  8442	[    2.481078] usb_serial_number:20080411
  8443	[    2.482313] input: sunxi-keyboard as /devices/virtual/input/input0
  8444	[    2.482918] usbcore: registered new interface driver xpad
  8445	[    2.483079] usbcore: registered new interface driver usb_acecad
  8446	[    2.483182] usbcore: registered new interface driver aiptek
  8447	[    2.483274] usbcore: registered new interface driver gtco
  8448	[    2.483354] usbcore: registered new interface driver hanwang
  8449	[    2.483428] usbcore: registered new interface driver kbtab
  8450	[    2.483907] axp2101_pek: axp2101-pek can not register without irq
  8451	[    2.483929] axp2101-pek: probe of axp2101-pek.0 failed with error -22
  8452	[    2.485346] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
  8453	[    2.485413] sunxi-rtc rtc: RTC enabled
  8454	[    2.485898] i2c /dev entries driver
  8455	[    2.486907] lirc_dev: IR Remote Control driver registered, major 244
  8456	[    2.486921] IR NEC protocol handler initialized
  8457	[    2.486927] IR RC5(x/sz) protocol handler initialized
  8458	[    2.486933] IR RC6 protocol handler initialized
  8459	[    2.486938] IR JVC protocol handler initialized
  8460	[    2.486944] IR Sony protocol handler initialized
  8461	[    2.486950] IR SANYO protocol handler initialized
  8462	[    2.486955] IR Sharp protocol handler initialized
  8463	[    2.486961] IR MCE Keyboard/mouse protocol handler initialized
  8464	[    2.486967] IR LIRC bridge handler initialized
  8465	[    2.486973] IR XMP protocol handler initialized
  8466	[    2.487486] sunxi_ir_startup: get ir protocol failed
  8467	[    2.487529] 7040000.s_cir supply ir0 not found, using dummy regulator
  8468	[    2.487721] Registered IR keymap rc_map_sunxi
  8469	[    2.488116] input: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0/input1
  8470	[    2.488357] rc rc0: sunxi_ir_recv as /devices/platform/soc/7040000.s_cir/rc/rc0
  8471	[    2.489366] input: MCE IR Keyboard/Mouse (sunxi-rc-recv) as /devices/virtual/input/input2
  8472	[    2.490022] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-rc-recv) registered at minor = 0
  8473	[    2.490724] sunxi cedar version 0.1
  8474	[    2.490913] VE: install start!!!
  8475
  8476	[    2.491111] cedar_ve: cedar-ve the get irq is 278
  8477	[    2.491723] VE: get debugfs_mpp_root is NULL, please check mpp
  8478
  8479	[    2.491736] VE: sunxi ve debug register driver failed!
  8480
  8481	[    2.494939] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
  8482	[    2.496210] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
  8483	[    2.496595] Bluetooth: HCI UART driver ver 2.3
  8484	[    2.496606] Bluetooth: HCI UART protocol H4 registered
  8485	[    2.496611] Bluetooth: HCI UART protocol LL registered
  8486	[    2.496617] Bluetooth: HCI UART protocol Three-wire (H5) registered
  8487	[    2.500827] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  8488	[    2.500842] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  8489	[    2.500856] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  8490	[    2.500867] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  8491	[    2.500880] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:uart0
  8492	[    2.500892] sun50iw9p1-pinctrl pio: expect_func as:uart0_jtag, but muxsel(3) is func:jtag
  8493	[    2.501309] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  8494	[    2.501428] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
  8495	[    2.501623] sunxi-mmc sdc0: No vmmc regulator found
  8496	[    2.501630] sunxi-mmc sdc0: No vqmmc regulator found
  8497	[    2.501636] sunxi-mmc sdc0: No vdmmc regulator found
  8498	[    2.501643] sunxi-mmc sdc0: No vd33sw regulator found
  8499	[    2.501649] sunxi-mmc sdc0: No vd18sw regulator found
  8500	[    2.501655] sunxi-mmc sdc0: No vq33sw regulator found
  8501	[    2.501661] sunxi-mmc sdc0: No vq18sw regulator found
  8502	[    2.502371] sunxi-mmc sdc0: set host busy
  8503	[    2.502473] sunxi-mmc sdc0: Got CD GPIO
  8504	[    2.502857] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  8505	[    2.502895] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
  8506	[    2.516376] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8507	[    2.533298] sunxi-mmc sdc0: detmode:gpio irq
  8508	[    2.533332] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8509	[    2.535844] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8510	[    2.536714] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.35 2019-12-11 14:29)
  8511	[    2.536825] sunxi-mmc sdc1: ***ctl-spec-caps*** 8
  8512	[    2.536966] sunxi-mmc sdc1: No vmmc regulator found
  8513	[    2.536973] sunxi-mmc sdc1: No vqmmc regulator found
  8514	[    2.536980] sunxi-mmc sdc1: No vdmmc regulator found
  8515	[    2.536986] sunxi-mmc sdc1: No vd33sw regulator found
  8516	[    2.536992] sunxi-mmc sdc1: No vd18sw regulator found
  8517	[    2.536998] sunxi-mmc sdc1: No vq33sw regulator found
  8518	[    2.537004] sunxi-mmc sdc1: No vq18sw regulator found
  8519	[    2.537718] sunxi-mmc sdc1: set host busy
  8520	[    2.537803] mmc:failed to get gpios
  8521	[    2.538013] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8522	[    2.538075] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  8523	[    2.540529] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8524	[    2.553046] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8525	[    2.564072] mmc0: host does not support reading read-only switch, assuming write-enable
  8526	[    2.565936] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  8527	[    2.566012] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
  8528	[    2.566157] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
  8529	[    2.566246] mmc0: new high speed SDXC card at address 0001
  8530	[    2.567310] mmcblk0: mmc0:0001 SD16G 59.5 GiB
  8531	[    2.568929]  mmcblk0: p1
  8532	[    2.569701] sunxi-mmc sdc1: detmode:manually by software
  8533	[    2.572007] ledtrig-cpu: registered to indicate activity on CPUs
  8534	[    2.572640] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  8535	[    2.573501] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  8536	[    2.573535] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8537	[    2.576038] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8538	[    2.577979] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  8539	[    2.578814] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  8540	[    2.579346] sunxi_emce_hw_init()368Unable to get pclk, return fffffffe
  8541	[    2.579356] sunxi_emce_probe()590emce hw init failed!
  8542	[    2.579383] emce: probe of emce failed with error -2
  8543	[    2.579661] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  8544	[    2.579706] hidraw: raw HID events driver (C) Jiri Kosina
  8545	[    2.580515] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
  8546	[    2.580558] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
  8547	[    2.584734] usbcore: registered new interface driver usbhid
  8548	[    2.584742] usbhid: USB HID core driver
  8549	[    2.586156] optee: probing for conduit method from DT.
  8550	[    2.586170] optee: api uid mismatch
  8551	[    2.586791] usbcore: registered new interface driver snd-usb-audio
  8552	[    2.588405] [sunxi_hdmi_codec_init] driver and deivce register finished.
  8553	[    2.590251] [sunxi_internal_codec_probe]:get audio avcc failed
  8554	[    2.590288] [sunxi_internal_codec_probe]:get audio vcc3v3-audio failed
  8555	[    2.590522] lineout_vol:26, linein_gain:3, fmin_gain:3, digital_vol:0, adcdrc_cfg:0, adchpf_cfg:0, dacdrc_cfg:0, dachpf_cfg:0, ramp_func_used:1, pa_msleep_time:100, pa_ctl_level:1, gpio-spk:0
  8556	[    2.593057] sunxi-codec-machine sndcodec: sun50iw9-codec <-> cpudai mapping ok
  8557	[    2.595028] sndhdmi sndhdmi: ASoC: CPU DAI (null) not registered
  8558	[    2.595041] sndhdmi sndhdmi: snd_soc_register_card() failed: -517
  8559	[    2.597331] sunxi-ahub-cpudai 5097000.cpudai3-controller: ahub cpudai id invalid
  8560	[    2.597354] sunxi-ahub-cpudai: probe of 5097000.cpudai3-controller failed with error -22
  8561	[    2.601497] sndahub sndahub: sunxi-ahub-aif1 <-> 5097000.cpudai0-controller mapping ok
  8562	[    2.602879] sndahub sndahub: sunxi-ahub-aif2 <-> 5097000.cpudai1-controller mapping ok
  8563	[    2.604821] sndahub sndahub: sunxi-ahub-aif3 <-> 5097000.cpudai2-controller mapping ok
  8564	[    2.607941] pktgen: Packet Generator for packet performance testing. Version: 2.75
  8565	[    2.608358] u32 classifier
  8566	[    2.608365]     Actions configured
  8567	[    2.608377] Netfilter messages via NETLINK v0.30.
  8568	[    2.608412] nfnl_acct: registering with nfnetlink.
  8569	[    2.608756] nf_conntrack version 0.5.0 (8192 buckets, 32768 max)
  8570	[    2.609006] ctnetlink v0.93: registering with nfnetlink.
  8571	[    2.609825] xt_time: kernel timezone is -0000
  8572	[    2.609850] IPVS: Registered protocols (TCP, UDP)
  8573	[    2.609966] IPVS: Connection hash table configured (size=4096, memory=64Kbytes)
  8574	[    2.610093] IPVS: Creating netns size=1928 id=0
  8575	[    2.610224] IPVS: ipvs loaded.
  8576	[    2.610232] IPVS: [rr] scheduler registered.
  8577	[    2.610330] ipip: IPv4 and MPLS over IPv4 tunneling driver
  8578	[    2.611032] gre: GRE over IPv4 demultiplexor driver
  8579	[    2.611040] ip_gre: GRE over IPv4 tunneling driver
  8580	[    2.612335] IPv4 over IPsec tunneling driver
  8581	[    2.613220] ip_tables: (C) 2000-2006 Netfilter Core Team
  8582	[    2.613513] arp_tables: arp_tables: (C) 2002 David S. Miller
  8583	[    2.613577] Initializing XFRM netlink socket
  8584	[    2.613610] IPsec XFRM device driver
  8585	[    2.614458] NET: Registered protocol family 10
  8586	[    2.616399] mip6: Mobile IPv6
  8587	[    2.616442] ip6_tables: (C) 2000-2006 Netfilter Core Team
  8588	[    2.617778] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
  8589	[    2.619393] NET: Registered protocol family 17
  8590	[    2.619435] NET: Registered protocol family 15
  8591	[    2.619593] Bridge firewalling registered
  8592	[    2.619825] Bluetooth: RFCOMM TTY layer initialized
  8593	[    2.619857] Bluetooth: RFCOMM socket layer initialized
  8594	[    2.619890] Bluetooth: RFCOMM ver 1.11
  8595	[    2.619904] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
  8596	[    2.619910] Bluetooth: BNEP filters: protocol multicast
  8597	[    2.619923] Bluetooth: BNEP socket layer initialized
  8598	[    2.619929] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
  8599	[    2.619940] Bluetooth: HIDP socket layer initialized
  8600	[    2.620040] l2tp_core: L2TP core driver, V2.0
  8601	[    2.620055] l2tp_ppp: PPPoL2TP kernel driver, V2.0
  8602	[    2.620061] 8021q: 802.1Q VLAN Support v1.8
  8603	[    2.620273] sctp: Hash tables configured (bind 256/256)
  8604	[    2.620854] Key type dns_resolver registered
  8605	[    2.620994] Registered cp15_barrier emulation handler
  8606	[    2.621007] Registered setend emulation handler
  8607	[    2.621924] registered taskstats version 1
  8608	[    2.633581] zswap: default zpool zbud not available
  8609	[    2.633589] zswap: pool creation failed
  8610	[    2.636385] Btrfs loaded, crc32c=crc32c-arm64-hw
  8611	[    2.637159] HDMI 2.0 driver init start!
  8612	[    2.637174] boot_hdmi=true
  8613	[    2.637967] Can not find the node of esm
  8614	[    2.637985] ERROR: pinctrl_get for HDMI2.0 DDC fail
  8615	[    2.638077] Get hdmi_power0:vcc-hdmi
  8616	[    2.638116] 6000000.hdmi supply vcc-hdmi not found, using dummy regulator
  8617	[    2.638286] Get hdmi_power1:vdd-hdmi
  8618	[    2.638308] 6000000.hdmi supply vdd-hdmi not found, using dummy regulator
  8619	[    2.639871] hdmi_cec_init
  8620	[    2.640362] [DISP] disp_device_attached,line:146:
  8621	[    2.640372] attached ok, mgr0<-->device0, type=4
  8622	[    2.640382] [HDMI receive params]: tv mode: 0xa format:0x0 data bits:0x0 eotf:0x0 cs:0x0 dvi_hdmi:2 range:2 scan:0 aspect_ratio:8
  8623	[    2.640395] [DISP] disp_hdmi_set_mode,line:648:
  8624	[    2.640399] hdmi_set_mode is null!
  8625	[    2.643344] HDMI2.0 module init end
  8626	[    2.654464] sunxi-thermal 5070400.thermal_sensor: avcc is not calibrated
  8627	[    2.657947] cpu cpu1: opp_list_debug_create_link: Failed to create link
  8628	[    2.657959] cpu cpu1: _add_opp_dev: Failed to register opp debugfs (-12)
  8629	[    2.657991] cpu cpu2: opp_list_debug_create_link: Failed to create link
  8630	[    2.657998] cpu cpu2: _add_opp_dev: Failed to register opp debugfs (-12)
  8631	[    2.658028] cpu cpu3: opp_list_debug_create_link: Failed to create link
  8632	[    2.658035] cpu cpu3: _add_opp_dev: Failed to register opp debugfs (-12)
  8633	[    2.660318] sndhdmi sndhdmi: audiohdmi-dai <-> sunxi-ahub-cpu-aif1 mapping ok
  8634	[    2.661220] get det_vbus is fail, 84
  8635	[    2.661227] get id is fail, 84
  8636	[    2.661721] sunxi-rtc rtc: setting system clock to 2023-09-25 18:30:00 UTC (1695666600)
  8637	[    2.665499] ALSA device list:
  8638	[    2.665507]   #0: audiocodec
  8639	[    2.665510]   #1: sndahub
  8640	[    2.665514]   #2: sndhdmi
  8641	[    2.667177] Freeing unused kernel memory: 3008K
  8642	[    2.712490] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  8643	[    2.714526] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  8644	[    2.717507] random: systemd-udevd: uninitialized urandom read (16 bytes read)
  8645	[    2.790131] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device connect
  8646	[    2.953094] sunxi-ehci 5200000.ehci1-controller: ehci_irq: highspeed device disconnect
  8647	[    3.046476] HDMI cable is connected
  8648	[    3.303019] usb 4-1: new full-speed USB device number 2 using sunxi-ohci
  8649	[    3.523445] usb 4-1: New USB device found, idVendor=24ae, idProduct=2013
  8650	[    3.523453] usb 4-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
  8651	[    3.523458] usb 4-1: Product: Rapoo 2.4G Wireless Device
  8652	[    3.523463] usb 4-1: Manufacturer: RAPOO
  8653	[    3.531450] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.0/0003:24AE:2013.0001/input/input3
  8654	[    3.531851] hid-generic 0003:24AE:2013.0001: input,hidraw0: USB HID v1.10 Mouse [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input0
  8655	[    3.538116] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.1/0003:24AE:2013.0002/input/input4
  8656	[    3.593821] hid-generic 0003:24AE:2013.0002: input,hiddev0,hidraw1: USB HID v1.10 Device [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input1
  8657	[    3.597732] input: RAPOO Rapoo 2.4G Wireless Device as /devices/platform/soc/5200000.ohci1-controller/usb4/4-1/4-1:1.2/0003:24AE:2013.0003/input/input5
  8658	[    3.655013] hid-generic 0003:24AE:2013.0003: input,hidraw2: USB HID v1.10 Keyboard [RAPOO Rapoo 2.4G Wireless Device] on usb-sunxi-ohci-1/input2
  8659	[    4.172009] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null)
  8660	[    5.088174] cgroup: cgroup2: unknown option "nsdelegate,memory_recursiveprot"
  8661	[    5.088729] cgroup: cgroup2: unknown option "nsdelegate"
  8662	[    5.108905] systemd[1]: systemd 252.12-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
  8663	[    5.108928] systemd[1]: Detected architecture arm64.
  8664	[    5.110063] systemd[1]: Warning! Reported kernel version 4.9.318-legacy-sun50iw9 is older than systemd's required baseline kernel version 4.15. Your mileage may vary.
  8665	[    5.120132] systemd[1]: Hostname set to <opi>.
  8666	[    5.147190] cgroup: cgroup: disabling cgroup2 socket matching due to net_prio or net_cls activation
  8667	[    6.751702] (sd-execut[1458]: /usr/lib/systemd/system-generators/netplan failed with exit status 1.
  8668	[    6.826412]
  8669	               insmod_device_driver
  8670
  8671	[    6.826664] device_chose finished 124!
  8672	[    7.115440] systemd[1]: /lib/systemd/system/hdmi-audio.service:10: Support for option SysVStartPriority= has been removed and it is ignored
  8673	[    7.353360] systemd[1]: Queued start job for default target graphical.target.
  8674	[    7.360912] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
  8675	[    7.363078] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
  8676	[    7.365312] systemd[1]: Created slice system-serial\x2dgetty.slice - Slice /system/serial-getty.
  8677	[    7.366692] systemd[1]: Created slice user.slice - User and Session Slice.
  8678	[    7.367364] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
  8679	[    7.367910] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  8680	[    7.368238] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
  8681	[    7.368754] systemd[1]: Reached target slices.target - Slice Units.
  8682	[    7.369075] systemd[1]: Reached target swap.target - Swaps.
  8683	[    7.369356] systemd[1]: Reached target time-set.target - System Time Set.
  8684	[    7.369884] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
  8685	[    7.387168] systemd[1]: Listening on rpcbind.socket - RPCbind Server Activation Socket.
  8686	[    7.388284] systemd[1]: Listening on syslog.socket - Syslog Socket.
  8687	[    7.389250] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
  8688	[    7.389957] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
  8689	[    7.391577] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
  8690	[    7.392533] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
  8691	[    7.393634] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
  8692	[    7.395836] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
  8693	[    7.396804] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
  8694	[    7.400774] systemd[1]: Mounting dev-hugepages.mount - Huge Pages File System...
  8695	[    7.405320] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
  8696	[    7.410389] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
  8697	[    7.411621] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  8698	[    7.412593] systemd[1]: auth-rpcgss-module.service - Kernel Module supporting RPCSEC_GSS was skipped because of an unmet condition check (ConditionPathExists=/etc/krb5.keytab).
  8699	[    7.420265] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
  8700	[    7.425722] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
  8701	[    7.431650] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
  8702	[    7.440500] systemd[1]: Starting modprobe@configfs.service - Load Kernel Module configfs...
  8703	[    7.447331] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  8704	[    7.454548] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
  8705	[    7.462303] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  8706	[    7.473740] systemd[1]: Starting modprobe@fuse.service - Load Kernel Module fuse...
  8707	[    7.481344] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  8708	[    7.482443] systemd[1]: systemd-fsck-root.service - File System Check on Root Device was skipped because of an unmet condition check (ConditionPathExists=!/run/initramfs/fsck-root).
  8709	[    7.493092] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
  8710	[    7.499560] systemd[1]: Starting systemd-remount-fs.service - Remount Root and Kernel File Systems...
  8711	[    7.506195] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
  8712	[    7.516841] systemd[1]: Mounted dev-hugepages.mount - Huge Pages File System.
  8713	[    7.519005] fuse init (API version 7.26)
  8714	[    7.519490] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
  8715	[    7.522235] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
  8716	[    7.526118] systemd[1]: Finished fake-hwclock.service - Restore / save the current clock.
  8717	[    7.529936] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
  8718	[    7.533852] systemd[1]: modprobe@configfs.service: Deactivated successfully.
  8719	[    7.534744] systemd[1]: Finished modprobe@configfs.service - Load Kernel Module configfs.
  8720	[    7.538055] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  8721	[    7.538688] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  8722	[    7.541365] systemd[1]: modprobe@drm.service: Deactivated successfully.
  8723	[    7.542298] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
  8724	[    7.574567] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro
  8725	[    7.591901] fbtft: module is from the staging directory, the quality is unknown, you have been warned.
  8726	[    7.607877] fbtft_device: module is from the staging directory, the quality is unknown, you have been warned.
  8727	[    7.608629] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  8728	[    7.608639] spidev spi1.1: dh2228fv spi1.1 16777kHz 8 bits mode=0x00
  8729	[    7.608821] spidev spi1.1: Deleting spi1.1
  8730	[    7.609454] fbtft_device: GPIOS used by 'fb_st7735r':
  8731	[    7.609461] fbtft_device: 'reset' = GPIO73
  8732	[    7.609465] fbtft_device: 'dc' = GPIO70
  8733	[    7.609475] spidev spi0.0: dh2228fv spi0.0 16777kHz 8 bits mode=0x00
  8734	[    7.609481] spi spi1.1: fb_st7735r spi1.1 16000kHz 8 bits mode=0x00
  8735	[    7.638015] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  8736	[    7.638919] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  8737	[    7.645879] systemd[1]: modprobe@fuse.service: Deactivated successfully.
  8738	[    7.646962] systemd[1]: Finished modprobe@fuse.service - Load Kernel Module fuse.
  8739	[    7.648404] WCN: marlin_init entry!
  8740	[    7.649755] WCN: marlin_parse_dt reset gpio=211
  8741	[    7.649767] WCN_ERR: gpio reset request err: 211
  8742	[    7.649773] WCN: wcn config bt wake host
  8743	[    7.650362] WCN: marlin_registsr_bt_wake bt_hostwake gpio=208 mul-sel=6 pull=-1 drv_level=-1 data=0 intnum=193
  8744	[    7.650505] WCN: wcn config wifi wake host
  8745	[    7.650528] sdiohal:sdiohal_parse_dt adma_tx:1, adma_rx:1, pwrseq:0, irq type:data, gpio_num:0, blksize:840
  8746	[    7.650657] systemd[1]: modprobe@loop.service: Deactivated successfully.
  8747	[    7.651761] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  8748	[    7.654271] sdiohal:sdiohal_init ok
  8749	[    7.655500] WCN: marlin_probe ok!
  8750	[    7.664425] mtty_probe init device addr: 0xffffffc009691300
  8751	[    7.664618] -->rfkill_bluetooth_init
  8752	[    7.664783] <--rfkill_bluetooth_init
  8753	[    7.707577] WCN: start_marlin [MARLIN_WIFI]
  8754	[    7.707591] WCN: marlin power state:0, subsys: [MARLIN_WIFI] power 1
  8755	[    7.707594] WCN: the first power on start
  8756	[    7.734127] systemd[1]: Finished systemd-remount-fs.service - Remount Root and Kernel File Systems.
  8757	[    7.741893] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
  8758	[    7.747724] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
  8759	[    7.748381] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  8760	[    7.754364] systemd[1]: Starting systemd-random-seed.service - Load/Save Random Seed...
  8761	[    7.755073] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  8762	[    7.762283] systemd[1]: Starting systemd-sysusers.service - Create System Users...
  8763	[    7.777941] systemd[1]: Finished keyboard-setup.service - Set the console keyboard layout.
  8764	[    7.789071] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
  8765	[    7.791343] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
  8766	[    7.823067] WCN: marlin chip en pull up
  8767	[    7.846466] systemd[1]: Finished systemd-sysusers.service - Create System Users.
  8768	[    7.849776] sdiohal:sdiohal_scan_card
  8769	[    7.849796] sunxi-wlan soc@03000000:wlan: bus_index: 1
  8770	[    7.849843] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
  8771	[    7.853128] systemd[1]: Starting systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev...
  8772	[    7.869767] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8773	[    7.887224] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  8774	[    7.888126] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
  8775	[    7.888152] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8776	[    7.890713] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8777	[    7.893813] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8778	[    7.909833] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
  8779	[    7.921526] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing LEGACY(SDR12) dt B
  8780	[    7.922310] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  8781	[    7.922399] sunxi-mmc sdc1: sdc set ios:clk 150000000Hz bm PP pm ON vdd 21 width 4 timing UHS-SDR104 dt B
  8782	[    7.923148] mmc1: new ultra high speed SDR104 SDIO card at address 8800
  8783	[    7.923572] sdiohal:sdiohal_probe: func->class=0, vendor=0x0000, device=0x0000, func_num=0x0001, clock=150000000
  8784	[    7.923777] WCN: marlin_get_wcn_chipid: chipid: 0x2355b001
  8785	[    7.923802] WCN: marlin_scan_finish!
  8786	[    7.923806] sdiohal:probe ok
  8787	[    7.923815] sdiohal:scan end!
  8788	[    7.923822] WCN: then marlin start to download
  8789	[    7.923852] WCN: marlin_request_firmware from /lib/firmware/wcnmodem.bin start!
  8790	[    7.975932] systemd[1]: Finished systemd-udev-trigger.service - Coldplug All udev Devices.
  8791	[    8.003941] systemd[1]: Starting ifupdown-pre.service - Helper to synchronize boot up for ifupdown...
  8792	[    8.009254] systemd[1]: Starting systemd-udev-settle.service - Wait for udev To Complete Device Initialization...
  8793	[    8.028187] systemd[1]: Finished systemd-tmpfiles-setup-dev.service - Create Static Device Nodes in /dev.
  8794	[    8.031986] systemd[1]: Finished ifupdown-pre.service - Helper to synchronize boot up for ifupdown.
  8795	[    8.034815] systemd[1]: Reached target local-fs-pre.target - Preparation for Local File Systems.
  8796	[    8.054097] WCN: combin_img 0 marlin_firmware_write finish and successful
  8797	[    8.054258] WCN: marlin_start_run read reset reg val:0x1
  8798	[    8.054262] WCN: after do marlin_start_run reset reg val:0x0
  8799	[    8.054446] WCN: s_marlin_bootup_time=8054442843
  8800	[    8.059830] WCN: clock mode: TSX
  8801	[    8.060008] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  8802	[    8.086581] WCN: marlin_write_cali_data sync init_state:0x1a0f50
  8803	[    8.103931] systemd[1]: Starting systemd-udevd.service - Rule-based Manager for Device Events and Files...
  8804	[    8.113313] WCN: marlin_write_cali_data sync init_state:0xf0f0f0f1
  8805	[    8.113320] WCN: sdio_config bt_wake_host trigger:[high]
  8806	[    8.113324] WCN: sdio_config irq:[inband]
  8807	[    8.113328] WCN: sdio_config wl_wake_host trigger:[high]
  8808	[    8.113333] WCN: sdio_config wake_host_level_duration_time:[20ms]
  8809	[    8.113336] WCN: sdio_config wake_host_data_separation:[bt/wifi reuse]
  8810	[    8.113341] WCN: marlin_send_sdio_config_to_cp sdio_config:0xb8f01 (enable config)
  8811	[    8.113836] WCN: marlin_write_cali_data finish
  8812	[    8.114047] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  8813	[    8.140045] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  8814	[    8.166816] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  8815	[    8.194046] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  8816	[    8.220108] WCN: check_cp_ready sync val:0xf0f0f0f2, prj_type val:0x0
  8817	[    8.246820] WCN: check_cp_ready sync val:0xf0f0f0f6, prj_type val:0x0
  8818	[    8.246830] WCN: marlin_bind_verify confuse data: 0x2e197f4f5a117df30c640a9405a3d69
  8819	[    8.246846] WCN: marlin_bind_verify verify data: 0x16d6ab91e1d71b3ae4604f224021aa
  8820	[    8.247587] WCN: check_cp_ready sync val:0xf0f0f0f7, prj_type val:0x0
  8821	[    8.273306] WCN: check_cp_ready sync val:0xf0f0f0ff, prj_type val:0x0
  8822	[    8.273314] sdiohal:sdiohal_runtime_get entry
  8823	[    8.273538] WCN: get_cp2_version entry!
  8824	[    8.275022] WCN: WCND at cmd read:WCN_VER:Platform Version:MARLIN3_19B_W20.37.4~Project Version:sc2355_marlin3_lite_ott~09-11-2020 21:27:32~
  8825	[    8.276174] WCN: switch_cp2_log - close entry!
  8826	[    8.277357] WCN: WCND at cmd read:OK
  8827	[    8.277407] WCN: then marlin download finished and run ok
  8828	[    8.277413] WCN: start_loopcheck
  8829	[    8.291310] WCN: get_board_ant_num [one_ant]
  8830	[    8.291321] wifi ini path = /lib/firmware/wifi_2355b001_1ant.ini
  8831	[    8.351243] unisoc_wifi unisoc_wifi wlan0: mixed HW and IP checksum settings.
  8832	[    8.355693] systemd[1]: Finished systemd-modules-load.service - Load Kernel Modules.
  8833	[    8.363121] systemd[1]: Starting systemd-sysctl.service - Apply Kernel Variables...
  8834	[    8.426057] systemd[1]: Finished systemd-sysctl.service - Apply Kernel Variables.
  8835	[    8.473186] systemd[1]: Started systemd-udevd.service - Rule-based Manager for Device Events and Files.
  8836	[    8.482704] systemd[1]: Starting plymouth-start.service - Show Plymouth Boot Screen...
  8837	[    8.556898] systemd[1]: Mounting tmp.mount - /tmp...
  8838	[    8.563210] fb_st7735r: module is from the staging directory, the quality is unknown, you have been warned.
  8839	[    8.577168] systemd[1]: Mounted tmp.mount - /tmp.
  8840	[    8.583105] systemd[1]: Reached target local-fs.target - Local File Systems.
  8841	[    8.595141] systemd[1]: Starting armbian-led-state.service - Armbian leds state...
  8842	[    8.603193] systemd[1]: Starting armbian-zram-config.service - Armbian ZRAM config...
  8843	[    8.614005] systemd[1]: Starting console-setup.service - Set console font and keymap...
  8844	[    8.630626] systemd[1]: Starting plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data...
  8845	[    8.657014] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  8846	[    8.667052] systemd[1]: Starting ufw.service - Uncomplicated firewall...
  8847	[    8.672909] systemd[1]: Started plymouth-start.service - Show Plymouth Boot Screen.
  8848	[    8.711853] systemd[1]: Finished console-setup.service - Set console font and keymap.
  8849	[    8.715338] systemd[1]: Finished plymouth-read-write.service - Tell Plymouth To Write Out Runtime Data.
  8850	[    8.718391] systemd[1]: Received SIGRTMIN+20 from PID 1420 (plymouthd).
  8851	[    8.719486] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  8852	[    8.720812] systemd[1]: Started systemd-ask-password-plymouth.path - Forward Password Requests to Plymouth Directory Watch.
  8853	[    8.721402] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
  8854	[    8.722909] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  8855	[    8.729296] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  8856	[    8.730244] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  8857	[    8.733715] systemd[1]: Finished ufw.service - Uncomplicated firewall.
  8858	[    8.735896] systemd[1]: Reached target network-pre.target - Preparation for Network.
  8859	[    8.820062] systemd[1]: Starting networking.service - Raise network interfaces...
  8860	[    8.823212] systemd[1]: Finished armbian-led-state.service - Armbian leds state.
  8861	[    9.134198] zram: Added device: zram0
  8862	[    9.137482] zram: Added device: zram1
  8863	[    9.140693] zram: Added device: zram2
  8864	[    9.213815] zswap: can't enable, initialization failed
  8865	[    9.283892] zram0: detected capacity change from 0 to 506396672
  8866	[    9.468604] systemd[1]: Finished networking.service - Raise network interfaces.
  8867	[   10.026558] graphics fb1: fb_st7735r frame buffer, 160x128, 40 KiB video memory, 4 KiB buffer memory, fps=20, spi1.1 at 16 MHz
  8868	[   10.087472] systemd[1]: Found device dev-ttyS0.device - /dev/ttyS0.
  8869	[   10.255438] systemd[1]: Reached target usb-gadget.target - Hardware activated USB gadget.
  8870	[   10.838127] systemd[1]: systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch was skipped because of an unmet condition check (ConditionPathExists=!/run/plymouth/pid).
  8871	[   10.838386] systemd[1]: proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point was skipped because of an unmet condition check (ConditionPathExists=/proc/sys/fs/binfmt_misc).
  8872	[   10.842784] systemd[1]: Listening on systemd-rfkill.socket - Load/Save RF Kill Switch Status /dev/rfkill Watch.
  8873	[   10.844808] systemd[1]: sys-kernel-tracing.mount - Kernel Trace File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/tracing).
  8874	[   10.862392] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
  8875	[   10.872755] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
  8876	[   10.902803] systemd[1]: Starting modprobe@loop.service - Load Kernel Module loop...
  8877	[   10.923927] systemd[1]: Starting systemd-binfmt.service - Set Up Additional Binary Formats...
  8878	[   10.931494] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
  8879	[   10.932769] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
  8880	[   10.936796] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
  8881	[   10.937756] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
  8882	[   10.945788] systemd[1]: modprobe@loop.service: Deactivated successfully.
  8883	[   10.946873] systemd[1]: Finished modprobe@loop.service - Load Kernel Module loop.
  8884	[   10.963034] systemd[1]: systemd-pstore.service - Platform Persistent Storage Archival was skipped because of an unmet condition check (ConditionDirectoryNotEmpty=/sys/fs/pstore).
  8885	[   10.963434] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
  8886	[   11.010957] systemd[1]: Starting systemd-rfkill.service - Load/Save RF Kill Switch Status...
  8887	[   11.013289] systemd[1]: systemd-binfmt.service: Main process exited, code=exited, status=1/FAILURE
  8888	[   11.014319] systemd[1]: systemd-binfmt.service: Failed with result 'exit-code'.
  8889	[   11.015398] systemd[1]: Failed to start systemd-binfmt.service - Set Up Additional Binary Formats.
  8890	[   11.052518] sunxi-bt soc@03000000:bt: set block: 0
  8891	[   11.064965] bluetooth_set_power: start_block=0
  8892	[   11.064975] WCN: start_marlin [MARLIN_BLUETOOTH]
  8893	[   11.064987] WCN: marlin power state:4, subsys: [MARLIN_BLUETOOTH] power 1
  8894	[   11.064992] WCN: marlin have open, GNSS is closed
  8895	[   11.064998] bluetooth_set_power: end_block=0
  8896	[   11.078425] systemd[1]: Started systemd-rfkill.service - Load/Save RF Kill Switch Status.
  8897	[   11.125453] systemd[1]: Finished systemd-udev-settle.service - Wait for udev To Complete Device Initialization.
  8898	[   11.131316] systemd[1]: Starting brltty.service - Braille Device Support...
  8899	[   11.848745] systemd[1]: Started brltty.service - Braille Device Support.
  8900	[   11.863372] input: BRLTTY 6.5 Linux Screen Driver Keyboard as /devices/virtual/input/input6
  8901	[   12.318625] Adding 494524k swap on /dev/zram0.  Priority:5 extents:1 across:494524k SSFS
  8902	[   12.459276] zram1: detected capacity change from 0 to 52428800
  8903	[   16.088924] systemd[1]: systemd-rfkill.service: Deactivated successfully.
  8904	[   16.536118] systemd[1]: Finished armbian-zram-config.service - Armbian ZRAM config.
  8905	[   16.542493] systemd[1]: Starting armbian-ramlog.service - Armbian memory supported logging...
  8906	[   16.604114] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
  8907	[   20.536223] systemd[1]: Finished armbian-ramlog.service - Armbian memory supported logging.
  8908	[   20.542685] systemd[1]: Starting systemd-journald.service - Journal Service...
  8909	[   20.811168] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.2 (1658 of 2204 items, 1269760 file size, 765 bytes per hash table item), suggesting rotation.
  8910	[   20.811191] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  8911	[   20.818287] systemd[1]: Started systemd-journald.service - Journal Service.
  8912	[   20.865608] systemd-journald[1921]: Received client request to flush runtime journal.
  8913	[   21.145803] IPVS: Creating netns size=1928 id=1
  8914
  8915	### armbian-release:
  8916
  8917	# PLEASE DO NOT EDIT THIS FILE
  8918	BOARD=orangepizero2
  8919	BOARD_NAME="Orange Pi Zero2"
  8920	BOARDFAMILY=sun50iw9
  8921	BUILD_REPOSITORY_URL=https://github.com/armbian/build
  8922	BUILD_REPOSITORY_COMMIT=ac829eb6
  8923	LINUXFAMILY=sun50iw9
  8924	ARCH=arm64
  8925	IMAGE_TYPE=stable
  8926	BOARD_TYPE=conf
  8927	INITRD_ARCH=arm
  8928	KERNEL_IMAGE_TYPE=Image
  8929	FORCE_BOOTSCRIPT_UPDATE=yes
  8930	VENDOR=Armbian
  8931	BOOTSCRIPT_FORCE_UPDATE="yes"
  8932	BOOTSCRIPT_DST="boot.cmd"
  8933	VERSION=23.8.1
  8934	REVISION=23.8.1
  8935	BRANCH=legacy
  8936
  8937	### boot environment:
  8938
  8939	verbosity=1
  8940	console=serial
  8941	#disp_mode=1080p60
  8942	#fb0_width=1280
  8943	#fb0_height=720
  8944	rootdev=UUID=0c85f38a-a16e-49a0-a53c-99d9856e983e
  8945	rootfstype=ext4
  8946	overlays=spi-spidev
  8947	param_spidev_spi_bus=1
  8948	param_spidev_spi_cs=1
  8949	extraargs=fbcon=map:1
  8950	usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
  8951
  8952	### lsusb:
  8953
  8954	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  8955	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  8956	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  8957	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  8958	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  8959	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  8960	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  8961
  8962	### lscpu:
  8963
  8964	Architecture:        aarch64
  8965	CPU op-mode(s):      32-bit, 64-bit
  8966	Byte Order:          Little Endian
  8967	CPU(s):              4
  8968	On-line CPU(s) list: 0-3
  8969	Vendor ID:           ARM
  8970	Model name:          Cortex-A53
  8971	Model:               4
  8972	Thread(s) per core:  1
  8973	Core(s) per cluster: 4
  8974	Socket(s):           -
  8975	Cluster(s):          1
  8976	Stepping:            r0p4
  8977	CPU(s) scaling MHz:  100%
  8978	CPU max MHz:         1512.0000
  8979	CPU min MHz:         480.0000
  8980	BogoMIPS:            48.00
  8981	Flags:               fp asimd aes pmull sha1 sha2 crc32
  8982
  8983	### cpuinfo:
  8984
  8985	processor	: 0
  8986	BogoMIPS	: 48.00
  8987	Features	: fp asimd aes pmull sha1 sha2 crc32
  8988	CPU implementer	: 0x41
  8989	CPU architecture: 8
  8990	CPU variant	: 0x0
  8991	CPU part	: 0xd03
  8992	CPU revision	: 4
  8993
  8994	processor	: 1
  8995	BogoMIPS	: 48.00
  8996	Features	: fp asimd aes pmull sha1 sha2 crc32
  8997	CPU implementer	: 0x41
  8998	CPU architecture: 8
  8999	CPU variant	: 0x0
  9000	CPU part	: 0xd03
  9001	CPU revision	: 4
  9002
  9003	processor	: 2
  9004	BogoMIPS	: 48.00
  9005	Features	: fp asimd aes pmull sha1 sha2 crc32
  9006	CPU implementer	: 0x41
  9007	CPU architecture: 8
  9008	CPU variant	: 0x0
  9009	CPU part	: 0xd03
  9010	CPU revision	: 4
  9011
  9012	processor	: 3
  9013	BogoMIPS	: 48.00
  9014	Features	: fp asimd aes pmull sha1 sha2 crc32
  9015	CPU implementer	: 0x41
  9016	CPU architecture: 8
  9017	CPU variant	: 0x0
  9018	CPU part	: 0xd03
  9019	CPU revision	: 4
  9020
  9021
  9022	### meminfo:
  9023
  9024	MemTotal:         989056 kB
  9025	MemFree:          790420 kB
  9026	MemAvailable:     885996 kB
  9027	Buffers:           15620 kB
  9028	Cached:            86968 kB
  9029	SwapCached:            0 kB
  9030	Active:            65592 kB
  9031	Inactive:          58252 kB
  9032	Active(anon):      21428 kB
  9033	Inactive(anon):      652 kB
  9034	Active(file):      44164 kB
  9035	Inactive(file):    57600 kB
  9036	Unevictable:           0 kB
  9037	Mlocked:               0 kB
  9038	SwapTotal:        494524 kB
  9039	SwapFree:         494524 kB
  9040	Dirty:             11316 kB
  9041	Writeback:             0 kB
  9042	AnonPages:         21292 kB
  9043	Mapped:            24272 kB
  9044	Shmem:               828 kB
  9045	Slab:              33084 kB
  9046	SReclaimable:       9272 kB
  9047	SUnreclaim:        23812 kB
  9048	KernelStack:        2512 kB
  9049	PageTables:         1116 kB
  9050	NFS_Unstable:          0 kB
  9051	Bounce:                0 kB
  9052	WritebackTmp:          0 kB
  9053	CommitLimit:      989052 kB
  9054	Committed_AS:      79636 kB
  9055	VmallocTotal:   263061440 kB
  9056	VmallocUsed:           0 kB
  9057	VmallocChunk:          0 kB
  9058	CmaTotal:          16384 kB
  9059	CmaFree:            7468 kB
  9060	HugePages_Total:       0
  9061	HugePages_Free:        0
  9062	HugePages_Rsvd:        0
  9063	HugePages_Surp:        0
  9064	Hugepagesize:       2048 kB
  9065
  9066	### virtual memory:
  9067
  9068	vm.admin_reserve_kbytes = 8192
  9069	vm.block_dump = 0
  9070	vm.compact_unevictable_allowed = 1
  9071	vm.dirty_background_bytes = 0
  9072	vm.dirty_background_ratio = 10
  9073	vm.dirty_bytes = 0
  9074	vm.dirty_expire_centisecs = 3000
  9075	vm.dirty_ratio = 20
  9076	vm.dirtytime_expire_seconds = 43200
  9077	vm.dirty_writeback_centisecs = 500
  9078	vm.extfrag_threshold = 500
  9079	vm.extra_free_kbytes = 0
  9080	vm.hugepages_treat_as_movable = 0
  9081	vm.hugetlb_shm_group = 0
  9082	vm.laptop_mode = 0
  9083	vm.legacy_va_layout = 0
  9084	vm.lowmem_reserve_ratio = 256	32
  9085	vm.max_map_count = 65530
  9086	vm.min_free_kbytes = 3937
  9087	vm.mmap_min_addr = 4096
  9088	vm.mmap_rnd_bits = 18
  9089	vm.mmap_rnd_compat_bits = 11
  9090	vm.nr_hugepages = 0
  9091	vm.nr_overcommit_hugepages = 0
  9092	vm.nr_pdflush_threads = 0
  9093	vm.oom_dump_tasks = 1
  9094	vm.oom_kill_allocating_task = 0
  9095	vm.overcommit_kbytes = 0
  9096	vm.overcommit_memory = 0
  9097	vm.overcommit_ratio = 50
  9098	vm.page-cluster = 0
  9099	vm.panic_on_oom = 0
  9100	vm.percpu_pagelist_fraction = 0
  9101	vm.stat_interval = 1
  9102	vm.swappiness = 100
  9103	vm.user_reserve_kbytes = 29998
  9104	vm.vfs_cache_pressure = 100
  9105	vm.watermark_scale_factor = 10
  9106
  9107	### ip addr:
  9108
  9109	1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
  9110	    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
  9111	    inet XXX.XXX.0.1/8 scope host lo
  9112	       valid_lft forever preferred_lft forever
  9113	    inet6 ::1/128 scope host noprefixroute
  9114	       valid_lft forever preferred_lft forever
  9115	2: dummy0: <BROADCAST,NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1000
  9116	    link/ether a2:f9:75:52:ad:58 brd ff:ff:ff:ff:ff:ff
  9117	3: eth0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  9118	    link/ether fa:6e:f4:da:68:8c brd ff:ff:ff:ff:ff:ff
  9119	4: tunl0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  9120	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  9121	5: gre0@NONE: <NOARP> mtu 1476 qdisc noop state DOWN group default qlen 1
  9122	    link/gre XXX.XXX.0.0 brd XXX.XXX.0.0
  9123	6: gretap0@NONE: <BROADCAST,MULTICAST> mtu 1462 qdisc noop state DOWN group default qlen 1000
  9124	    link/ether 00:00:00:00:00:00 brd ff:ff:ff:ff:ff:ff
  9125	7: ip_vti0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  9126	    link/ipip XXX.XXX.0.0 brd XXX.XXX.0.0
  9127	8: ip6_vti0@NONE: <NOARP> mtu 1500 qdisc noop state DOWN group default qlen 1
  9128	    link/tunnel6 :: brd ::
  9129	9: sit0@NONE: <NOARP> mtu 1480 qdisc noop state DOWN group default qlen 1
  9130	    link/sit XXX.XXX.0.0 brd XXX.XXX.0.0
  9131	10: ip6tnl0@NONE: <NOARP> mtu 1452 qdisc noop state DOWN group default qlen 1
  9132	    link/tunnel6 :: brd ::
  9133	11: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
  9134	    link/ether 48:c9:27:84:d1:40 brd ff:ff:ff:ff:ff:ff
  9135
  9136	### partitions:
  9137
  9138	major minor  #blocks  name
  9139
  9140	 179        0   62410752 mmcblk0
  9141	 179        1   61763584 mmcblk0p1
  9142	 253        0     494528 zram0
  9143	 253        1      51200 zram1
  9144
  9145	### df:
  9146
  9147	udev            466M     0  466M   0% /dev
  9148	tmpfs            97M  2.1M   95M   3% /run
  9149	/dev/mmcblk0p1   58G  7.3G   51G  13% /
  9150	tmpfs           483M     0  483M   0% /dev/shm
  9151	tmpfs           5.0M     0  5.0M   0% /run/lock
  9152	tmpfs           483M  4.0K  483M   1% /tmp
  9153	/dev/zram1       47M   11M   33M  25% /var/log
  9154
  9155	### lsblk:
  9156
  9157	NAME        FSTYPE   SIZE MOUNTPOINT UUID
  9158	mmcblk0             59.5G
  9159	└─mmcblk0p1 ext4    58.9G /          0c85f38a-a16e-49a0-a53c-99d9856e983e
  9160	zram1                 50M /var/log
  9161	zram2                  0B
  9162
  9163	### zramctl:
  9164
  9165	NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  9166	/dev/zram1 lz4            50M 10.8M  2.9M  3.3M       4 /var/log
  9167	/dev/zram0 lzo         482.9M    4K   76B   12K       4 [SWAP]
  9168
  9169	### mtab:
  9170
  9171	/dev/mmcblk0p1 / ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  9172	/dev/mmcblk0p1 /var/log.hdd ext4 rw,noatime,errors=remount-ro,commit=600 0 0
  9173	/dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  9174
  9175	### mmc0:0001 info:
  9176
  9177	              manfid: 0x0000fe
  9178	                 cid: fe3432534431364720000000690091f5
  9179	               fwrev: 0x0
  9180	                 csd: 400e00325b590001dc277f800a40008b
  9181	                 ocr: 0x00200000
  9182	                type: SD
  9183	                date: 01/2009
  9184	               hwrev: 0x2
  9185	                 dsr: 0x404
  9186	              serial: 0x00000069
  9187	          erase_size: 512
  9188	              uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=SD16G MODALIAS=mmc:block
  9189	                 ssr: 000000000800000004049000080a190a000800000001000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  9190	                 scr: 0285808300000000
  9191	               oemid: 0x3432
  9192	preferred_erase_size: 4194304
  9193	                name: SD16G
  9194
  9195	### Boot system health:
  9196
  9197	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  9198	15:30:21  1512 MHz  1.31  38%  18%  13%   0%   6%   0%  50.1 °C  0/5
  9199	15:30:22  1512 MHz  1.31  99%  38%  49%   0%  11%   0%  50.1 °C  0/5
  9200	15:30:22  1512 MHz  1.31 100%  33%  60%   1%   4%   0%  51.3 °C  0/5
  9201	15:30:22  1512 MHz  1.31 100%  42%  51%   1%   4%   0%  51.3 °C  0/5
  9202	15:30:23  1512 MHz  4.81  98%  29%  56%   1%  10%   0%  51.3 °C  0/5
  9203
  9204	### lsusb:
  9205
  9206	Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  9207	Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  9208	Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  9209	Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  9210	Bus 004 Device 002: ID 24ae:2013 Shenzhen Rapoo Technology Co., Ltd. Rapoo 2.4G Wireless Device
  9211	Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  9212	Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  9213
  9214	/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
  9215	/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
  9216	/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ohci/1p, 12M
  9217	    |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 12M
  9218	    |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 12M
  9219	    |__ Port 1: Dev 2, If 2, Class=Human Interface Device, Driver=usbhid, 12M
  9220	/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
  9221	/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
  9222	/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=sunxi-ehci/1p, 480M
  9223
  9224	### Userland:
  9225
  9226	PRETTY_NAME="Armbian 23.8.3 bookworm"
  9227	ARMBIAN_PRETTY_NAME="Armbian 23.8.3 bookworm"
  9228
  9229	### Installed packages:
  9230
  9231	ii  armbian-bookworm-desktop-xfce         23.8.3                              all          Armbian desktop for Debian bookworm xfce
  9232	ii  armbian-bsp-cli-orangepizero2-legacy  23.8.1                              arm64        Armbian CLI BSP for board 'orangepizero2' branch 'legacy'
  9233	ii  armbian-config                        23.8.3                              all          Armbian configuration utility
  9234	ii  armbian-firmware-full                 23.02.2                             all          Linux firmware-full
  9235	ii  armbian-zsh                           23.8.3                              all          Armbian improved ZShell (oh-my-zsh...)
  9236	ii  linux-base                            4.9                                 all          Linux image base package
  9237	ii  linux-dtb-legacy-sun50iw9             23.8.1                              arm64        Armbian Linux legacy DTBs in /boot/dtb-4.9.318-legacy-sun50iw9
  9238	ii  linux-image-legacy-sun50iw9           23.8.1                              arm64        Armbian Linux legacy kernel image 4.9.318-legacy-sun50iw9
  9239	ii  linux-libc-dev:arm64                  23.02.2                             arm64        Armbian Linux support headers for userspace development
  9240	ii  linux-u-boot-orangepizero2-legacy     23.8.1                              arm64        Das U-Boot for orangepizero2
  9241
  9242	### Loaded modules:
  9243
  9244	Module                  Size  Used by
  9245	zram                   36864  2
  9246	fb_st7735r             16384  1
  9247	sprdwl_ng             442368  0
  9248	sprdbt_tty             40960  2
  9249	uwe5622_bsp_sdio      307200  2 sprdbt_tty,sprdwl_ng
  9250	fbtft_device           61440  0
  9251	fbtft                  57344  2 fbtft_device,fb_st7735r
  9252	fb_sys_fops            16384  1 fbtft
  9253	syscopyarea            16384  1 fbtft
  9254	sysfillrect            16384  1 fbtft
  9255	sysimgblt              16384  1 fbtft
  9256	fuse                  139264  3
  9257
  9258	### Current system health:
  9259
  9260	Time        CPU    load %cpu %sys %usr %nice %io %irq   Tcpu  C.St.
  9261	17:08:45  1512 MHz  2.63  25%   5%  14%   0%   4%   0%  44.2 °C  0/5
  9262	17:08:45  1512 MHz  2.63   5%   2%   0%   1%   0%   0%  44.2 °C  0/5
  9263	17:08:45  1512 MHz  2.63   8%   5%   2%   0%   0%   0%  45.7 °C  0/5
  9264	17:08:46  1512 MHz  2.63   5%   2%   0%   2%   0%   0%  45.7 °C  0/5
  9265	17:08:46  1512 MHz  2.63  10%   5%   5%   0%   0%   0%  45.7 °C  0/5
  9266	17:08:48  1512 MHz  2.63  25%   5%  14%   0%   4%   0%  51.2 °C  0/5
  9267	17:08:49  1512 MHz  2.63 100%   1%  97%   0%   0%   0%  55.9 °C  0/5
  9268	17:08:50  1512 MHz  2.98  74%   1%  72%   0%   0%   0%  56.4 °C  0/5
  9269	17:08:50  1512 MHz  2.98   7%   5%   1%   0%   0%   0%  56.4 °C  0/5
  9270	17:08:51  1512 MHz  2.98   5%   2%   0%   1%   0%   0%  50.3 °C  0/5
  9271
  9272	### resolv.conf
  9273
  9274	-rw-r--r-- 1 root root 30 Sep 25 17:02 /etc/resolv.conf
  9275	# Generated by NetworkManager
  9276
  9277	### Current sysinfo:
  9278
  9279	Linux 4.9.318-legacy-sun50iw9 (opi) 	09/25/2023 	_aarch64_	(4 CPU)
  9280
  9281	avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  9282	          14.58    0.01    5.88    4.60    0.00   74.94
  9283
  9284	Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
  9285	ram0              0.00         0.00         0.00         0.00          0          0          0
  9286	ram1              0.00         0.00         0.00         0.00          0          0          0
  9287	ram2              0.00         0.00         0.00         0.00          0          0          0
  9288	ram3              0.00         0.00         0.00         0.00          0          0          0
  9289	ram4              0.00         0.00         0.00         0.00          0          0          0
  9290	ram5              0.00         0.00         0.00         0.00          0          0          0
  9291	ram6              0.00         0.00         0.00         0.00          0          0          0
  9292	ram7              0.00         0.00         0.00         0.00          0          0          0
  9293	ram8              0.00         0.00         0.00         0.00          0          0          0
  9294	ram9              0.00         0.00         0.00         0.00          0          0          0
  9295	ram10             0.00         0.00         0.00         0.00          0          0          0
  9296	ram11             0.00         0.00         0.00         0.00          0          0          0
  9297	ram12             0.00         0.00         0.00         0.00          0          0          0
  9298	ram13             0.00         0.00         0.00         0.00          0          0          0
  9299	ram14             0.00         0.00         0.00         0.00          0          0          0
  9300	ram15             0.00         0.00         0.00         0.00          0          0          0
  9301	mmcblk0          37.13      1581.19         2.58         0.00    9385503      15340          0
  9302	mmcblk0p1        37.12      1580.84         2.58         0.00    9383399      15340          0
  9303	zram0            47.34        35.42       153.93         0.00     210216     913700          0
  9304	zram1             0.73         0.50         2.40         0.00       2976      14260          0
  9305	zram2             0.00         0.00         0.00         0.00          0          0          0
  9306
  9307	--procs-- -----------------------memory---------------------- ---swap-- -----io---- -system-- ----------cpu----------
  9308	   r    b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st  gu
  9309	   3    0       484508        14440        14888       297328    9   39   402     1  312  458  15   6  75   5   0   0
  9310
  9311	               total        used        free      shared  buff/cache   available
  9312	Mem:           965Mi       702Mi        14Mi        40Mi       304Mi       263Mi
  9313	Swap:          482Mi       473Mi       9.8Mi
  9314
  9315	NAME       ALGORITHM DISKSIZE   DATA  COMPR  TOTAL STREAMS MOUNTPOINT
  9316	/dev/zram1 lz4            50M  11.9M   3.2M   3.7M       4 /var/log
  9317	/dev/zram0 lzo         482.9M 471.2M 134.8M 139.7M       4 [SWAP]
  9318
  9319	 17:08:51 up  1:38,  2 users,  load average: 2.98, 2.40, 2.27
  9320
  9321	[ 5528.824915] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9322	[ 5528.824920] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
  9323	[ 5528.824949] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9324	[ 5528.935756] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9325	[ 5528.935852] sunxi-mmc sdc1: *****retry:start*****
  9326	[ 5528.935890] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9327	[ 5528.935895] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9328	[ 5528.935922] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9329	[ 5529.046729] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9330	[ 5529.046811] sunxi-mmc sdc1: *****retry:start*****
  9331	[ 5529.046847] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9332	[ 5529.046852] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9333	[ 5529.046877] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9334	[ 5529.157645] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9335	[ 5529.157681] sunxi-mmc sdc1: *****retry:start*****
  9336	[ 5529.157716] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9337	[ 5529.157721] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9338	[ 5529.157745] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9339	[ 5529.268510] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9340	[ 5529.268603] sunxi-mmc sdc1: *****retry:start*****
  9341	[ 5529.268638] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9342	[ 5529.268643] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9343	[ 5529.268669] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9344	[ 5529.379488] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9345	[ 5529.379579] sunxi-mmc sdc1: *****retry:start*****
  9346	[ 5529.379614] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9347	[ 5529.379619] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9348	[ 5529.379643] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9349	[ 5529.490458] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9350	[ 5529.490493] sunxi-mmc sdc1: *****retry:start*****
  9351	[ 5529.490528] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9352	[ 5529.490534] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9353	[ 5529.490566] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9354	[ 5529.601328] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9355	[ 5529.601364] sunxi-mmc sdc1: *****retry:start*****
  9356	[ 5529.601396] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9357	[ 5529.601406] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
  9358	[ 5529.601432] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9359	[ 5529.712241] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9360	[ 5529.712332] sunxi-mmc sdc1: *****retry:start*****
  9361	[ 5529.712368] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9362	[ 5529.712373] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
  9363	[ 5529.712398] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9364	[ 5529.823213] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9365	[ 5529.823250] sunxi-mmc sdc1: *****retry:start*****
  9366	[ 5529.823285] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9367	[ 5529.823290] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710110
  9368	[ 5529.823314] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9369	[ 5529.934127] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9370	[ 5529.934218] sunxi-mmc sdc1: *****retry:start*****
  9371	[ 5529.934254] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9372	[ 5529.934259] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9373	[ 5529.934286] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9374	[ 5530.045094] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9375	[ 5530.045184] sunxi-mmc sdc1: *****retry:start*****
  9376	[ 5530.045219] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9377	[ 5530.045224] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9378	[ 5530.045251] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9379	[ 5530.156092] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9380	[ 5530.156224] sunxi-mmc sdc1: *****retry:start*****
  9381	[ 5530.156288] sunxi-mmc sdc1: REG_DRV_DL: 0x00030000
  9382	[ 5530.156301] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9383	[ 5530.156339] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9384	[ 5530.267115] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9385	[ 5530.267170] sunxi-mmc sdc1: *****retry:start*****
  9386	[ 5530.267227] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9387	[ 5530.267239] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9388	[ 5530.267277] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9389	[ 5530.378085] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9390	[ 5530.378170] sunxi-mmc sdc1: *****retry:start*****
  9391	[ 5530.378204] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9392	[ 5530.378209] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9393	[ 5530.378235] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9394	[ 5530.488998] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9395	[ 5530.489081] sunxi-mmc sdc1: *****retry:start*****
  9396	[ 5530.489116] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9397	[ 5530.489121] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710220
  9398	[ 5530.489146] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9399	[ 5530.599954] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9400	[ 5530.599992] sunxi-mmc sdc1: *****retry:start*****
  9401	[ 5530.600031] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9402	[ 5530.600038] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9403	[ 5530.600069] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9404	[ 5530.710876] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9405	[ 5530.710960] sunxi-mmc sdc1: *****retry:start*****
  9406	[ 5530.710995] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9407	[ 5530.711000] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9408	[ 5530.711026] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9409	[ 5530.821834] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9410	[ 5530.821916] sunxi-mmc sdc1: *****retry:start*****
  9411	[ 5530.821950] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9412	[ 5530.821955] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9413	[ 5530.821979] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9414	[ 5530.932792] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9415	[ 5530.932884] sunxi-mmc sdc1: *****retry:start*****
  9416	[ 5530.932919] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9417	[ 5530.932924] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9418	[ 5530.932952] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9419	[ 5531.043761] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9420	[ 5531.043853] sunxi-mmc sdc1: *****retry:start*****
  9421	[ 5531.043887] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9422	[ 5531.043892] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9423	[ 5531.043918] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9424	[ 5531.154729] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9425	[ 5531.154820] sunxi-mmc sdc1: *****retry:start*****
  9426	[ 5531.154854] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9427	[ 5531.154859] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9428	[ 5531.154883] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9429	[ 5531.265646] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9430	[ 5531.265695] sunxi-mmc sdc1: *****retry:start*****
  9431	[ 5531.265729] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9432	[ 5531.265734] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9433	[ 5531.265755] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9434	[ 5531.376573] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9435	[ 5531.376667] sunxi-mmc sdc1: *****retry:start*****
  9436	[ 5531.376703] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9437	[ 5531.376708] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9438	[ 5531.376734] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9439	[ 5531.487542] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9440	[ 5531.487631] sunxi-mmc sdc1: *****retry:start*****
  9441	[ 5531.487666] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9442	[ 5531.487671] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9443	[ 5531.487697] sunxi-mmc sdc1: *****retry:re-send cmd*****
  9444	[ 5531.598507] sunxi-mmc sdc1: smc 1 p1 err, cmd 53, RD DTO !!
  9445	[ 5531.598547] sunxi-mmc sdc1: *****retry:start*****
  9446	[ 5531.598582] sunxi-mmc sdc1: REG_DRV_DL: 0x00000000
  9447	[ 5531.598593] sunxi-mmc sdc1: REG_SD_NTSR: 0x81710000
  9448	[ 5531.598601] sunxi-mmc sdc1: sunxi v4p1x retry give up
  9449	[ 5531.598607] sunxi-mmc sdc1: retry:set phase failed or over retry times
  9450	[ 5531.598624] sunxi-mmc sdc1: retry:give up
  9451	[ 5531.598667] sdiohal err:dt read fail ret:-110, system_addr=0x4024f000
  9452	[ 5531.598672] sdiohal:sdio dump_aon_reg entry
  9453	[ 5531.598707] sdiohal:pmu sdio status:[0x140]:0x6b
  9454	[ 5531.598735] sdiohal:pmu sdio status:[0x141]:0x3c
  9455	[ 5531.598755] sdiohal:pmu sdio status:[0x142]:0xe1
  9456	[ 5531.598775] sdiohal:pmu sdio status:[0x143]:0x0
  9457	[ 5531.598794] sdiohal:pmu sdio status:[0x144]:0x0
  9458	[ 5531.598812] sdiohal:pmu sdio status:[0x145]:0x0
  9459	[ 5531.598831] sdiohal:pmu sdio status:[0x146]:0x0
  9460	[ 5531.598849] sdiohal:pmu sdio status:[0x147]:0x0
  9461	[ 5531.598868] sdiohal:pmu sdio status:[0x148]:0x60
  9462	[ 5531.598887] sdiohal:pmu sdio status:[0x149]:0x0
  9463	[ 5531.598906] sdiohal:pmu sdio status:[0x14a]:0x0
  9464	[ 5531.598925] sdiohal:pmu sdio status:[0x14b]:0x0
  9465	[ 5531.598945] sdiohal:pmu sdio status:[0x14c]:0x0
  9466	[ 5531.598963] sdiohal:pmu sdio status:[0x14d]:0x0
  9467	[ 5531.598982] sdiohal:pmu sdio status:[0x14e]:0x0
  9468	[ 5531.599000] sdiohal:pmu sdio status:[0x14f]:0x0
  9469	[ 5531.599077] sdiohal:cm4d haddr 0:[0x144]:0x0
  9470	[ 5531.599096] sdiohal:cm4d haddr 0:[0x145]:0x20
  9471	[ 5531.599115] sdiohal:cm4d haddr 0:[0x146]:0x12
  9472	[ 5531.599134] sdiohal:cm4d haddr 0:[0x147]:0x0
  9473	[ 5531.599209] sdiohal:cm4i haddr 1:[0x144]:0xe0
  9474	[ 5531.599228] sdiohal:cm4i haddr 1:[0x145]:0x40
  9475	[ 5531.599247] sdiohal:cm4i haddr 1:[0x146]:0x10
  9476	[ 5531.599266] sdiohal:cm4i haddr 1:[0x147]:0x0
  9477	[ 5531.599341] sdiohal:cm4s haddr 2:[0x144]:0x7c
  9478	[ 5531.599360] sdiohal:cm4s haddr 2:[0x145]:0x6
  9479	[ 5531.599379] sdiohal:cm4s haddr 2:[0x146]:0x14
  9480	[ 5531.599398] sdiohal:cm4s haddr 2:[0x147]:0x40
  9481	[ 5531.599474] sdiohal:dmaw haddr 3:[0x144]:0x0
  9482	[ 5531.599493] sdiohal:dmaw haddr 3:[0x145]:0x0
  9483	[ 5531.599512] sdiohal:dmaw haddr 3:[0x146]:0x0
  9484	[ 5531.599531] sdiohal:dmaw haddr 3:[0x147]:0x0
  9485	[ 5531.599645] sdiohal:dmar haddr 4:[0x144]:0x0
  9486	[ 5531.599665] sdiohal:dmar haddr 4:[0x145]:0x0
  9487	[ 5531.599684] sdiohal:dmar haddr 4:[0x146]:0x0
  9488	[ 5531.599703] sdiohal:dmar haddr 4:[0x147]:0x0
  9489	[ 5531.599828] sdiohal:aon_to_ahb haddr 5:[0x144]:0x0
  9490	[ 5531.599859] sdiohal:aon_to_ahb haddr 5:[0x145]:0x0
  9491	[ 5531.599881] sdiohal:aon_to_ahb haddr 5:[0x146]:0x0
  9492	[ 5531.599900] sdiohal:aon_to_ahb haddr 5:[0x147]:0x0
  9493	[ 5531.599977] sdiohal:axi_to_ahb haddr 6:[0x144]:0x4
  9494	[ 5531.599996] sdiohal:axi_to_ahb haddr 6:[0x145]:0xf0
  9495	[ 5531.600015] sdiohal:axi_to_ahb haddr 6:[0x146]:0x24
  9496	[ 5531.600035] sdiohal:axi_to_ahb haddr 6:[0x147]:0x40
  9497	[ 5531.600111] sdiohal:hready_status haddr 7:[0x144]:0xcf
  9498	[ 5531.600130] sdiohal:hready_status haddr 7:[0x145]:0xff
  9499	[ 5531.600149] sdiohal:hready_status haddr 7:[0x146]:0xf9
  9500	[ 5531.600168] sdiohal:hready_status haddr 7:[0x147]:0x70
  9501	[ 5531.600171] sdiohal:val:0xc
  9502	[ 5531.600220] sdiohal:after reset hready status:[0x144]:0xcf
  9503	[ 5531.600238] sdiohal:after reset hready status:[0x145]:0xff
  9504	[ 5531.600256] sdiohal:after reset hready status:[0x146]:0xf9
  9505	[ 5531.600275] sdiohal:after reset hready status:[0x147]:0x70
  9506	[ 5531.600278] sdiohal:sdio dump_aon_reg end
  9507
  9508	[ 5531.600281] sdiohal:sdiohal_abort
  9509	[ 5531.600286] sdiohal:carddump flag set[1]
  9510	[ 5531.600315] sdiohal:disable rx int for dump
  9511	[ 5531.600321] sdiohal:chn8 tx push old, cmdid=25, mstime=5527952, record_time=5527952
  9512	[ 5531.600330] chn8 tx push old: 00 00 00 00 10 19 a5 00 90 59 54 00 00 00 00 00  .........YT.....
  9513	[ 5531.600335] sdiohal:chn8 tx denq old, cmdid=25, mstime=5527952, record_time=5527955
  9514	[ 5531.600339] chn8 tx denq old: 80 52 00 08 10 19 a5 00 90 59 54 00 00 00 00 00  .R.......YT.....
  9515	[ 5531.600344] sdiohal:chn22 rx dispatch old, cmdid=27, mstime=5527848, record_time=5527853
  9516	[ 5531.600348] chn22 rx dispatch old: 3f 06 00 0a 00 1b 0c 00 28 59 54 00 00 38 00 00  ?.......(YT..8..
  9517	[ 5531.600353] sdiohal:chn8 tx push new, cmdid=11, mstime=5527958, record_time=5527958
  9518	[ 5531.600357] chn8 tx push new: 00 00 00 00 10 0b 57 00 96 59 54 00 00 00 00 00  ......W..YT.....
  9519	[ 5531.600361] sdiohal:chn8 tx denq new, cmdid=11, mstime=5527958, record_time=5527958
  9520	[ 5531.600366] chn8 tx denq new: 80 2b 00 08 10 0b 57 00 96 59 54 00 00 00 00 00  .+....W..YT.....
  9521	[ 5531.600370] sdiohal:chn22 rx dispatch new, cmdid=25, mstime=5527952, record_time=5527958
  9522	[ 5531.600375] chn22 rx dispatch new: 3f 06 00 0a 00 19 0c 00 90 59 54 00 00 39 00 00  ?........YT..9..
  9523	[ 5531.600381] WCN_ERR: mdbg_dump_data dump memory error:-110
  9524	[ 5531.600394] WCN: mdbg dump bt modem 0 ok!
  9525	[ 5531.600399] WCN_ERR: read HCI_ARM_WR_RD_MODE reg error:-1
  9526	[ 5531.600413] WCN_ERR: mdbg_dump_data dump memory error:-1
  9527	[ 5531.600418] WCN: mdbg dump bt_cmd buf 0 ok!
  9528	[ 5531.600422] WCN_ERR: mdbg_dump_data dump memory error:-1
  9529	[ 5531.600427] WCN: mdbg dump btevent buf 0 ok!
  9530	[ 5531.600431] WCN_ERR: mdbg_dump_data dump memory error:-1
  9531	[ 5531.600435] WCN: mdbg dump bt_lmp_tx_buf 0 ok!
  9532	[ 5531.600440] WCN_ERR: mdbg_dump_data dump memory error:-1
  9533	[ 5531.600444] WCN: mdbg dump bt_lmp_rx_buf 0 ok!
  9534	[ 5531.600449] WCN_ERR: mdbg_dump_data dump memory error:-1
  9535	[ 5531.600453] WCN: mdbg dump bt_acl_tx_buf0 ok!
  9536	[ 5531.600457] WCN_ERR: mdbg_dump_data dump memory error:-1
  9537	[ 5531.600462] WCN: mdbg dump bt_acl_rx_buf 0 ok!
  9538	[ 5531.600466] WCN_ERR: mdbg_dump_data dump memory error:-1
  9539	[ 5531.600470] WCN: mdbg dump bt_sco_tx_buf 0 ok!
  9540	[ 5531.600475] WCN_ERR: mdbg_dump_data dump memory error:-1
  9541	[ 5531.600479] WCN: mdbg dump bt_sco_rx_buf 0 ok!
  9542	[ 5531.600483] WCN_ERR: mdbg_dump_data dump memory error:-1
  9543	[ 5531.600488] WCN: mdbg dump bt_bb_tx_buf 0 ok!
  9544	[ 5531.600492] WCN_ERR: mdbg_dump_data dump memory error:-1
  9545	[ 5531.600496] WCN: mdbg dump bt_bb_rx_buf 0 ok!
  9546	[ 5531.646525] WCN: dumpmem_rx_callback
  9547	[ 5531.646535] WCN: dump str finish!
  9548	[ 5531.646538] WCN: mdbg dump memory finish
  9549	[ 5531.646564] sdiohal err:sdiohal_adma_pt_read line 510 dump happened
  9550	[ 5531.646568] sdiohal err:adma read fail ret:-19
  9551	[ 5531.876603] WCN: stop_loopcheck
  9552	[ 5537.210058] WCN: mdbg_assert_interface:[CMD] WIFI_CMD_SCAN, [REASON] CMD_RSP_TIMEOUT_ERROR
  9553	[ 5537.210077] sdiohal:carddump flag set[1]
  9554	[ 5537.210150] sdiohal:disable rx int for dump
  9555	[ 5537.210162] sdiohal:chn8 tx push old, cmdid=25, mstime=5527952, record_time=5527952
  9556	[ 5537.210174] chn8 tx push old: 00 00 00 00 10 19 a5 00 90 59 54 00 00 00 00 00  .........YT.....
  9557	[ 5537.210180] sdiohal:chn8 tx denq old, cmdid=25, mstime=5527952, record_time=5527955
  9558	[ 5537.210184] chn8 tx denq old: 80 52 00 08 10 19 a5 00 90 59 54 00 00 00 00 00  .R.......YT.....
  9559	[ 5537.210189] sdiohal:chn22 rx dispatch old, cmdid=27, mstime=5527848, record_time=5527853
  9560	[ 5537.210194] chn22 rx dispatch old: 3f 06 00 0a 00 1b 0c 00 28 59 54 00 00 38 00 00  ?.......(YT..8..
  9561	[ 5537.210198] sdiohal:chn8 tx push new, cmdid=11, mstime=5527958, record_time=5527958
  9562	[ 5537.210203] chn8 tx push new: 00 00 00 00 10 0b 57 00 96 59 54 00 00 00 00 00  ......W..YT.....
  9563	[ 5537.210208] sdiohal:chn8 tx denq new, cmdid=11, mstime=5527958, record_time=5527958
  9564	[ 5537.210213] chn8 tx denq new: 80 2b 00 08 10 0b 57 00 96 59 54 00 00 00 00 00  .+....W..YT.....
  9565	[ 5537.210218] sdiohal:chn22 rx dispatch new, cmdid=25, mstime=5527952, record_time=5527958
  9566	[ 5537.210223] chn22 rx dispatch new: 3f 06 00 0a 00 19 0c 00 90 59 54 00 00 39 00 00  ?........YT..9..
  9567	[ 5537.210227] WCN_ERR: Not dump again!
  9568	[ 5543.137795] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
  9569	[ 5549.247975] systemd-journald[1921]: Data hash table of /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal has a fill level at 75.0 (1654 of 2204 items, 1269760 file size, 767 bytes per hash table item), suggesting rotation.
  9570	[ 5549.248004] systemd-journald[1921]: /run/log/journal/e9c8407423c44a66b4ba6432f86d3639/system.journal: Journal header limits reached or header out-of-date, rotating.
  9571
  9572
  9573
  9574	### interrupts:
  9575	           CPU0       CPU1       CPU2       CPU3
  9576	  3:     199127     209462     208307     179917  wakeupgen  48 Level     sun4i_timer0
  9577	  6:     848063     721119     701849     726177     GIC-0  27 Level     arch_timer
  9578	  8:          0          0          0          0  wakeupgen  61 Level     30f0000.iommu
  9579	151:          0          0          0          0  sunxi_pio_edge 134 Edge      sdc0 cd
  9580	193:          0          0          0          0  sunxi_pio_edge 176 Edge      bt_wake_isr
  9581	273:        483          0          0          0  wakeupgen  42 Level     3002000.dma-controller
  9582	275:          0          0          0          0  wakeupgen 106 Level     RemoteIR_RX
  9583	276:          0          0          0          0  wakeupgen 104 Level     rtc
  9584	278:          0          0          0          0  wakeupgen  93 Level     cedar_dev
  9585	280:        298          0          0          0  wakeupgen   0 Level     uart0
  9586	283:          0          0          0          0  wakeupgen   9 Level     twi3
  9587	284:     138080          0          0          0  wakeupgen 105 Level     twi5
  9588	285:          0          0          0          0  wakeupgen  25 Level     sunxi_usb_udc
  9589	288:          2          0          0          0  wakeupgen  28 Level     ehci_hcd:usb1
  9590	289:      94396          0          0          0  wakeupgen  29 Level     ohci_hcd:usb4
  9591	290:          0          0          0          0  wakeupgen  30 Level     ehci_hcd:usb2
  9592	291:          0          0          0          0  wakeupgen  31 Level     ohci_hcd:usb5
  9593	292:          0          0          0          0  wakeupgen  32 Level     ehci_hcd:usb3
  9594	293:          0          0          0          0  wakeupgen  33 Level     ohci_hcd:usb6
  9595	294:          0          0          0          0  wakeupgen  12 Level     spi0
  9596	295:        504          0          0          0  wakeupgen  13 Level     spi1
  9597	298:       3567          0          0     239620  wakeupgen  35 Level     sunxi-mmc0
  9598	299:     104922          0          0          0  wakeupgen  36 Level     sunxi-mmc1
  9599	300:          9          0          0          0  wakeupgen  88 Level     dispaly
  9600	303:     355994          0          0          0  wakeupgen  66 Level     dispaly
  9601	314:          0          0          0          0  wakeupgen  91 Edge      ss
  9602	316:          0          0          0          0  wakeupgen  89 Level     1420000.deinterlace
  9603	319:          0          0          0          0  wakeupgen  20 Edge      sunxikbd
  9604	320:          0          0          0          0  wakeupgen  14 Level     gmac0
  9605	IPI0:    624833     665809     618948     567108       Rescheduling interrupts
  9606	IPI1:      1658       2105       2104       2033       Function call interrupts
  9607	IPI2:         0          0          0          0       CPU stop interrupts
  9608	IPI3:      5958      12785      18303      20397       Timer broadcast interrupts
  9609	IPI4:      2433       2158       1928       2034       IRQ work interrupts
  9610	IPI5:         0          0          0          0       CPU wake-up interrupts
  9611	Err:          0
Please upload the whole output above to an online pasteboard service
and provide the URL in the forum where you have been asked for this.
Edited by joaopaulo98
@joaopaulo98 Thanks for reporting this. I see you are using quite an old kernel. Could you please try upgrading to current (6.1) or edge(6.5)? We regenerated images for this board few days back to bring back the wifi support. So if you upgrade to 23.8.3 and use 6.1 or 6.5 it should work fine. Let me know if you face any issues with the same.
I see fbtft module driver is present in modern kernel as well, so probably you can give it a try may be on a spare sd card if you don't want to experiment things in your current installation. Whats the model number for your screen?
4 hours ago, joaopaulo98 said:
I don't have another SD card
It is always handy to have a bunch of those when tinkering with SBCs. Thankfully the are rather cheap :)
  • Solution
9 hours ago, joaopaulo98 said:
unfortunately I don't have another SD card
Thats sad. You can still try installing edge kernel to tezt it and then revert back to older kernel if it doesn't work as your liking
I'm using a Chinese display, LCD TFT 1.8" 128x160 - Driver ST7735
I can see the kernel modules for ST7735 is enabled in our kernels
config/kernel/linux-sunxi64-current.config:CONFIG_FB_TFT_ST7735R=m
config/kernel/linux-sunxi64-edge.config:CONFIG_FB_TFT_ST7735R=m
config/kernel/linux-sunxi64-legacy.config:CONFIG_FB_TFT_ST7735R=m
Hi Gunjan, how does one upgrade from the 6.1 to the 6.5 kernel?
Run "sudo armbian-config" then go to System > Other. There should be 23.8.3 6.5 edge kernel in the list
Hello all,
@Gunjan Gupta thank you for your tireless work on all things Armbian.
I know we had brief discussion about 'trying wifi' for zero2, the main issues before were modules not compiling.
Has any device tree specific work been done for the modern kernels? (Not that I last seen).
The latest WIP Sunxi PR might be the time to start testing this, I will try to set some time aside this coming weekend, when going through the PR to test. I do have other pr's in staging for zero2, but cant promise any result.
Best,
Alistair
for uwe5622, when it comes to allwinner, only device tree specific thing needed is to mark the corresponding mmc node status as ok. Other than that, only available option is for configuring bt_wake pin for bluetooth low power mode. But that is optional. So as long as mmc node is present and status is set to ok, wifi should work find once the corresponding drivers are loaded either manually or via kernel commandline.
