Hey there,
I'm running Armbian 23.8.1 Bookworm with Linux 5.10.160-legacy-rk35xx on a Rock 5B and am trying to get zfs via dkms to work, but it won't compile.
configure: error:
       *** None of the expected "file_fallocate" interfaces were detected.
       *** This may be because your kernel version is newer than what is
       *** supported, or you are using a patched custom kernel with
       *** incompatible modifications.
       *** ZFS Version: zfs-2.1.11-1
       *** Compatible Kernels: 3.10 - 6.2
Error! Bad return status for module build on kernel: 5.10.160-legacy-rk35xx (aarch64)
I'm attaching the full build log, perhaps someone has a clue?
dkms-zfs.txt make.log
https://github.com/openzfs/zfs/issues/15081#issuecomment-1647094056 doesn't sound promising though:
See here radxa/kernel#54 (comment)
Rockchip BSP kernel is forked from Android Common Kernel, don't think ZFS would support the Android kernel any time soon.
https://github.com/radxa/kernel/issues/54#issuecomment-1501031920 points out a possibility by patching the zfs sources.
I am not sure if I want to go down that path.
