winfried Posted December 11, 2016 Posted December 11, 2016 On an Olimex Lime2 NAND 4GB I installed Armbian legacy debian jessie server on an sd-card. "lime2 3.4.112-sun7i #10 SMP PREEMPT Sun Oct 23 15:49:51 CEST 2016 armv7l" I followed: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-install-to-emmc-nand-sata-usb and after reboot without card, it did not boot: (from serial console) [...] [ 0.366] flash init finish [ 0.367] mbr magic is not correct [...] Anyhow I didnt understand as prerequisits in description: "pre-installed system on NAND (stock Android or other Linux)" I erased the nand before, since I used it otherwise: dd if=/dev/zero of=/dev/nand bs=512 count=16 Question: Is my NAND broken or must I install some mbr before in the nand ? Any advice ? mfg winfried Appendix: complete boot output: HELLO! BOOT0 is starting! boot0 version : 2.0.0� read dram para. dram driver version: 1.15 dram size =1024MB 0x00018608 super_standby_flag = 0 Succeed in opening nand flash. block from 2 to 6 deal block 2 Succeed in reading Boot1 file head. The size of Boot1 is 0x00068000. The file stored in 0x00000000 of block 2 is perfect. Check is correct. Ready to disable icache. Succeed in loading Boot1. Jump to Boot1. [ 0.159] boot1 version : 2.0.0 [ 0.159] script installed early ok [ 0.160] pmu type = 3 [ 0.265] bat vol = 942 mv [ 0.278] axi:ahb:apb=4:2:2 [ 0.278] set dcdc2=1400mv, clock=912M successed [ 0.281] key [ 0.293] no key found [ 0.293] flash init start [ 0.293] NB1 : enter NFB_Init [ 0.296] NB1 : enter phy init [ 0.299] [NAND] nand driver(A20) version: 0x0x00000002, 0x0x00000012, data: 0x426fff64 1111692733 [ 0.308] set retry default value: [ 0.311] 0x00000020[ 0.314] 0x00000020[ 0.316] 0x00000073[ 0.318] 0x000000c1[ 0.321] [ 0.322] get the good blk ratio from hwscan : 870 [ 0.327] NB1 : nand phy init ok [ 0.366] NB1 : init ok [ 0.366] flash init finish [ 0.367] mbr magic is not correct [ 0.370] fs init fail [ 0.372] fs init fail, jump to fel [ 0.376] set retry default value: [ 0.380] 0x00000020[ 0.382] 0x00000020[ 0.384] 0x00000073[ 0.386] 0x000000c1[ 0.389] [ 0.390] [NAND]dumy read,chip 0x00000000
Igor Posted December 12, 2016 Posted December 12, 2016 NAND install part is a bit dirty since we can't write early boot binaries within Linux. You need to use proprietary Phoenix tools to write some stock Android / Debian and than we can make use of that. That's why we simply write: "pre-installed system on NAND (stock Android or other Linux)" Next problem is u-boot which is also some very old one from Allwinner, which has NAND support. Modern mainline u-boot does not have it and development in this area hasn't come to end user level yet. On the top of that I would need to double check if this could be related to our install tools. I know they were broken at certain point and I am only sure that those self build are working o.k.
winfried Posted December 12, 2016 Author Posted December 12, 2016 Thanks, I tried now flash with orginal Olimex sdcard image (kernel 3.4.103) [1] and used the nandinstall script there and it worked. I will look further in next days maybe to format nand properly for armbian to get the right "mbr magic" und update this comment to this topic [1] https://www.olimex.com/wiki/images/2/20/A20-lime2_mainline_uboot_sunxi_kernel_3.4.103_jessie_emmc_rel_9.torrent
Igor Posted December 13, 2016 Posted December 13, 2016 Steven made most progress on this: https://github.com/phelum/CT_NandBoot (on lime2 is exactly the same) I think the issue here is with our installer which should be fixable with updating to daily build. I will try a test install ASAP.
