rellla Posted December 16, 2016 Posted December 16, 2016 Hello all, maybe I missed that part in the docs or in another thread... In fact, I haven't found a solution. I'd like to include a custom kernel repository in the build process (maybe in kernel-only mode) and select that in the interface if available. Either include a remote directory (github...) or some local directory. That all for easily trying things out without using the single-patches directory but using the armbian building environment. I couldn't find the lines in the build scripts, where I easily can "hardcode" such a kernel tree. Ultimate way would be an additional option for a custom kernel tree, chooseable via the menu. Can someone point me into the right direction? Thanks rellla
Igor Posted December 16, 2016 Posted December 16, 2016 Our documentation does not follow the speed of our development Use userpatches/lib.config override as following example: BOOTBRANCH="branch:2015.10.fslc-qdl" BOOTSOURCE="https://github.com/UDOOboard/uboot-imx" BOOTDIR="xxdir" KERNELSOURCE="https://github.com/UDOOboard/linux_kernel" KERNELBRANCH="branch:3.14-1.0.x-udoo-ov772x" KERNELDIR="yydir" This will be forced for all boards ...
tkaiser Posted December 16, 2016 Posted December 16, 2016 Use userpatches/lib.config override [...] This will be forced for all boards ... That's why this commit implemented a 'per $LINUXFAMILY' override, eg. userpatches/sources/sun7i.conf 2
rellla Posted January 3, 2017 Author Posted January 3, 2017 Thanks guys, this was exactly what i need. rellla 1
rellla Posted January 4, 2017 Author Posted January 4, 2017 One additional thing though: Maybe https://github.com/igorpecovnik/lib/blob/master/configuration.sh#L76should be moved to line 106 or 186 in order to be able to also set $LINUXCONFIG ?! rellla
zador.blood.stained Posted January 4, 2017 Posted January 4, 2017 @rellla You can put your customized kernel config in userpatches too: https://github.com/igorpecovnik/lib/blob/master/common.sh#L214-L216
