Hello all,
maybe I missed that part in the docs or in another thread... In fact, I haven't found a solution.
I'd like to include a custom kernel repository in the build process (maybe in kernel-only mode) and select that in the interface if available. Either include a remote directory (github...) or some local directory. That all for easily trying things out without using the single-patches directory but using the armbian building environment.
I couldn't find the lines in the build scripts, where I easily can "hardcode" such a kernel tree.
Ultimate way would be an additional option for a custom kernel tree, chooseable via the menu.
Can someone point me into the right direction?
Thanks
rellla
Our documentation does not follow the speed of our development :)
Use userpatches/lib.config override as following example:
BOOTBRANCH="branch:2015.10.fslc-qdl"
BOOTSOURCE="https://github.com/UDOOboard/uboot-imx"
BOOTDIR="xxdir"
KERNELSOURCE="https://github.com/UDOOboard/linux_kernel"
KERNELBRANCH="branch:3.14-1.0.x-udoo-ov772x"
KERNELDIR="yydir"
This will be forced for all boards ...
  On 12/16/2016 at 3:24 PM, Igor said:
Use userpatches/lib.config override [...] This will be forced for all boards ...
That's why this commit implemented a 'per $LINUXFAMILY' override, eg. userpatches/sources/sun7i.conf :)
