Hi,
just installed 23.8.1 on my odroid M1, and I get poor network perf when using 1G port speed.
iperf to another machine (iperf -c <server>, M1 sends traffic) gives the following:
[ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.00  sec  8.15 MBytes  6.84 Mbits/sec  631             sender
[  5]   0.00-10.04  sec  7.86 MBytes  6.57 Mbits/sec                  receiver
reverse direction, M1 receives traffic: iperf -R -c <server>
[ ID] Interval           Transfer     Bitrate         Retr
[  5]   0.00-10.04  sec  1.10 GBytes   937 Mbits/sec  587             sender
[  5]   0.00-10.00  sec  1.09 GBytes   938 Mbits/sec                  receiver
same exists with older releases.
also tried with older kernel (6.1.12-rk3568-odroid)
when I set the network port on switch side to 100Mbps / full, then send, receive side is ok, can fill 100Mbps.
Can you please help?
BR,
Tamas
Posted (edited)
I've notice it while moving files via gftp in ssh2 the network speed transfer is really slow (1GB port used)
Edited by j0ta
Hi Bro,
Today after trying a lot of distros and images (uboot part as well) it turned out one specific uboot is working fine stock Debian and Armian image as well.
I followed this how to: https://github.com/inindev/odroid-m1/tree/main/uboot
with the latest loader from this repo: https://github.com/inindev/odroid-m1/releases
Have to be checked what is the difference between this and armbian uboot images.
Posted (edited)
confirmed @Gergő Koszta
U-Boot SPL 2023.07.02-00034-g2717ce87b0 (Aug 18 2023 - 09:35:34 +0000)
U-Boot phase
U-Boot
Just installed it is compatible with armbian bullseye the board boots well, hopefully this u-boot will fix the nvme boot problem I have.
Later I'll comment when I've got some free time to make a new installation of the system
Cheers !
Edited by j0ta
Just out of curiosity, does this firmware build work?
For a test it is sufficient to put it on an otherwise empty microSD card and old the SPI recovery button (RCY) while powering up. No modifications are necessary to the existing system.
hey @usual user tomorrow I'll give a try if nvme boots with the 2023.07.02-00034
if not I'll give a try on your u-boot
the problem I have with nvme is present in this thread (there's video)
I've no idea what's going wrong
Hello,
i have recently installed last recomended version of the armbian into NVME disk ODDROID M1
stybyk@Droiderone:~/MyDocker$ cat /etc/os-release
PRETTY_NAME="Armbian 24.8.4 bookworm"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
stybyk@Droiderone:~/MyDocker$ lsb_release -a
No LSB modules are available.
Distributor ID: Debian
Description:    Armbian 24.8.4 bookworm
Release:        12
Codename:       bookworm
stybyk@Droiderone:~/MyDocker$ hostnamectl
Operating System: Armbian 24.8.4 bookworm
          Kernel: Linux 6.6.51-current-rockchip64
    Architecture: arm64
And i found out that there is still same issue.
Measuring by iperf from M1 > RPI4
[  5]   0.00-10.00  sec  8.73 MBytes  7.32 Mbits/sec  954             sender
[  5]   0.00-10.00  sec  8.47 MBytes  7.11 Mbits/sec                  receiver
Measuring from RP4 to M1
[  5]   0.00-10.00  sec  1.09 GBytes   938 Mbits/sec    0             sender
[  5]   0.00-10.01  sec  1.09 GBytes   935 Mbits/sec                  receiver
Is it the way how to solve it ? Or do i need to re-install completely with different OS from the scratch ?
Quote
Or just wait few weeks for 2024.11 update.
How long is estimated time which should i wait ? Does it have some solid date ? Or anytime in this month ?
I dont remember all my "try actions" with the Oddroid, but last attemts to solve this ruin my disk anyway so now i had to start from begining as my backup was incidentaly too old 🤕
But in this my try, i had selected option in the armbian-install with boot from sd card system on NVMe.  But I dont know how I can identify which type of bootloader I have running.
I think i have t U-boot.
Hi,
my Odroid-M1 is running Armbian 24.11.1 and kernel 6.6.60-current so the fix you mention in the thread above should be in. Nevertheless the network speed is way slower when the M1 sends data. I have tried different client machines for the test as well as network cables on the M1 already, it makes no difference.
iperf3 -c odroidm1
[  5]   0.00-10.00  sec  1.09 GBytes   936 Mbits/sec    0             sender
[  5]   0.00-10.00  sec  1.09 GBytes   934 Mbits/sec                  receiver
iperf3 -R -c odroidm1
[  5]   0.00-10.00  sec   391 MBytes   328 Mbits/sec  5242             sender
[  5]   0.00-10.00  sec   391 MBytes   328 Mbits/sec                  receiver
I played around with ethtool -C tx-usecs and could tune it to ~450 Mbits but still far from the bandwith in the other direction, so is this a different problem?
Hello,
that yours speed is still much more acceptable than mine. I am not abble to backup it due to the slowness.
Last time i tried also to install server image which i keep running now.
Operating System: Armbian 24.11.2 noble
 Kernel: Linux 6.6.63-current-rockchip64
 FROM ODDROID TO RPI
[  5]   0.00-10.00  sec  4.88 MBytes  4.09 Mbits/sec  633             sender
[  5]   0.00-10.00  sec  4.87 MBytes  4.08 Mbits/sec                  receiver
FROM RPI TO ODDOID
I am scared to play with that without backup.
Works for me as for @rmrf.
iperf3 -c ...
[  5]   0.00-10.00  sec  1.10 GBytes   942 Mbits/sec    0             sender
[  5]   0.00-10.01  sec  1.09 GBytes   938 Mbits/sec                  receiver
iperf3 -R -c ...
[  5]   0.00-10.00  sec   412 MBytes   345 Mbits/sec  485             sender
[  5]   0.00-10.00  sec   410 MBytes   344 Mbits/sec                  receiver
Hi,
I have the same issue. Used to run fine on Ubuntu 22.04 with 4.19 kernel but I just upgraded to armbian.
Connecting to host 192.168.2.10, port 5201
[ 5] local 192.168.2.50 port 57993 connected to 192.168.2.10 port 5201
[ 5] 0.00-1.01 sec 80.8 MBytes 668 Mbits/sec
[ 5] 1.01-2.00 sec 95.6 MBytes 813 Mbits/sec
[ 5] 2.00-3.01 sec 39.6 MBytes 330 Mbits/sec
[ 5] 3.01-4.01 sec 107 MBytes 898 Mbits/sec
[ 5] 4.01-5.01 sec 71.4 MBytes 601 Mbits/sec
[ 5] 5.01-6.00 sec 70.6 MBytes 594 Mbits/sec
[ 5] 6.00-7.01 sec 84.2 MBytes 702 Mbits/sec
[ 5] 7.01-8.00 sec 57.8 MBytes 488 Mbits/sec
[ 5] 8.00-9.01 sec 85.2 MBytes 710 Mbits/sec
[ 5] 9.01-10.01 sec 89.6 MBytes 749 Mbits/sec
Reverse mode, remote host 192.168.2.10 is sending
[ 5] local 192.168.2.50 port 58028 connected to 192.168.2.10 port 5201
[ 5] 0.00-1.01 sec 512 KBytes 4.13 Mbits/sec
[ 5] 1.01-2.00 sec 256 KBytes 2.12 Mbits/sec
[ 5] 2.00-3.01 sec 512 KBytes 4.16 Mbits/sec
[ 5] 3.01-4.01 sec 896 KBytes 7.35 Mbits/sec
[ 5] 4.01-5.01 sec 896 KBytes 7.30 Mbits/sec
[ 5] 5.01-6.00 sec 640 KBytes 5.30 Mbits/sec
[ 5] 6.00-7.01 sec 384 KBytes 3.12 Mbits/sec
[ 5] 7.01-8.00 sec 640 KBytes 5.28 Mbits/sec
[ 5] 8.00-9.01 sec 256 KBytes 2.08 Mbits/sec
[ 5] 9.01-10.01 sec 384 KBytes 3.16 Mbits/sec
Posted (edited)
I'm currently at:
# uname -a
Linux micro-015 6.13.0-0.rc1.20241204gitfeffde684ac2.17.fc42.aarch64 #1 SMP PREEMPT_DYNAMIC Sat Dec  7 11:18:10 CET 2024 aarch64 GNU/Linux
And with better wired up in DTB I get:
Spoiler
# iperf3 -c odroid-m1
Connecting to host odroid-m1, port 5201
[  5] local odroid-n2+ port 34366 connected to odroid-m1 port 5201
[ ID] Interval           Transfer     Bitrate         Retr  Cwnd
[  5]   0.00-1.00   sec   112 MBytes   941 Mbits/sec    0    461 KBytes
[  5]   1.00-2.00   sec   112 MBytes   941 Mbits/sec    0    510 KBytes
[  5]   2.00-3.00   sec   113 MBytes   945 Mbits/sec    0    560 KBytes
[  5]   3.00-4.00   sec   111 MBytes   934 Mbits/sec    0    585 KBytes
[  5]   4.00-5.00   sec   112 MBytes   943 Mbits/sec    0    684 KBytes
[  5]   5.00-6.00   sec   111 MBytes   928 Mbits/sec    0    718 KBytes
[  5]   6.00-7.00   sec   112 MBytes   944 Mbits/sec    0    718 KBytes
[  5]   7.00-8.00   sec   112 MBytes   935 Mbits/sec    0    792 KBytes
[  5]   8.00-9.00   sec   111 MBytes   933 Mbits/sec    0    830 KBytes
[  5]   9.00-10.02  sec   113 MBytes   928 Mbits/sec    0    830 KBytes
[  5]   0.00-10.02  sec  1.09 GBytes   938 Mbits/sec    0             sender
[  5]   0.00-10.02  sec  1.09 GBytes   937 Mbits/sec                  receiver
iperf Done.
# iperf3 -R -c odroid-m1
Reverse mode, remote host odroid-m1 is sending
[  5] local odroid-n2+ port 36326 connected to odroid-m1 port 5201
[  5]   0.00-1.00   sec  87.8 MBytes   735 Mbits/sec
[  5]   1.00-2.00   sec  73.6 MBytes   618 Mbits/sec
[  5]   2.00-3.00   sec  94.2 MBytes   791 Mbits/sec
[  5]   3.00-4.00   sec  90.2 MBytes   757 Mbits/sec
[  5]   4.00-5.00   sec  88.5 MBytes   742 Mbits/sec
[  5]   5.00-6.00   sec  86.0 MBytes   721 Mbits/sec
[  5]   6.00-7.00   sec  87.4 MBytes   733 Mbits/sec
[  5]   7.00-8.00   sec  83.2 MBytes   698 Mbits/sec
[  5]   8.00-9.00   sec  86.0 MBytes   721 Mbits/sec
[  5]   9.00-10.00  sec  79.4 MBytes   666 Mbits/sec
[  5]   0.00-10.00  sec   858 MBytes   720 Mbits/sec  196             sender
[  5]   0.00-10.00  sec   856 MBytes   718 Mbits/sec                  receiver
iperf Done.
Edited by usual user
Still the same with armbian 25.2.3
kernel: 6.12.22-current-rockchip64 #1 SMP PREEMPT Mon Apr  7 08:08:37 UTC 2025 aarch64 aarch64 aarch64 GNU/Linux
u-boot-version:
# cat  /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version"
2025.01-armbian-2025.01-S6d41-P41ad-H4cab-V390e-Bb703-R448a
u-boot,version
WARNING: could not set u-boot,version %s.
# iperf3 -R -c odroidm1
Connecting to host odroidm1, port 5201
Reverse mode, remote host odroidm1 is sending
[  5]   0.00-1.00   sec  79.2 KBytes   649 Kbits/sec
[  5]   1.00-2.00   sec  84.8 KBytes   695 Kbits/sec
[  5]   2.00-3.00   sec   206 KBytes  1.69 Mbits/sec
[  5]   3.00-4.00   sec   228 KBytes  1.87 Mbits/sec
[  5]   4.00-5.00   sec   115 KBytes   938 Kbits/sec
[  5]   5.00-6.00   sec   181 KBytes  1.48 Mbits/sec
[  5]   6.00-7.00   sec   163 KBytes  1.33 Mbits/sec
^C[  5]   7.00-7.36   sec  9.90 KBytes   226 Kbits/sec
[  5]   0.00-7.36   sec  0.00 Bytes  0.00 bits/sec                  sender
[  5]   0.00-7.36   sec  1.04 MBytes  1.19 Mbits/sec                  receiver
when changing u-boot back to older u-boot (same kernel), it works as expected
2023.04-00035-g7dd5eb0228
u-boot,version
Connecting to host odrdoidm1, port 5201
[  5]   0.00-1.00   sec   110 MBytes   921 Mbits/sec
[  5]   1.00-2.00   sec   110 MBytes   926 Mbits/sec
[  5]   2.00-3.00   sec   110 MBytes   926 Mbits/sec
[  5]   3.00-4.00   sec   110 MBytes   921 Mbits/sec
[  5]   4.00-5.00   sec   111 MBytes   929 Mbits/sec
[  5]   5.00-6.00   sec   111 MBytes   927 Mbits/sec
[  5]   6.00-7.00   sec   110 MBytes   919 Mbits/sec
^C[  5]   7.00-7.79   sec  87.0 MBytes   925 Mbits/sec
[  5]   0.00-7.79   sec  0.00 Bytes  0.00 bits/sec                  sender
[  5]   0.00-7.79   sec   858 MBytes   924 Mbits/sec                  receiver
iperf3: interrupt - the client has terminated
ethtool output:
~# ethtool end0
Settings for end0:
        Supported ports: [ TP    MII ]
        Supported link modes:   10baseT/Half 10baseT/Full
                                100baseT/Half 100baseT/Full
                                1000baseT/Full
        Supported pause frame use: Symmetric Receive-only
        Supports auto-negotiation: Yes
        Supported FEC modes: Not reported
        Advertised link modes:  10baseT/Half 10baseT/Full
                                1000baseT/Full
        Advertised pause frame use: Symmetric Receive-only
        Advertised auto-negotiation: Yes
        Advertised FEC modes: Not reported
        Link partner advertised link modes:  10baseT/Half 10baseT/Full
                                             1000baseT/Half 1000baseT/Full
        Link partner advertised pause frame use: No
        Link partner advertised auto-negotiation: Yes
        Link partner advertised FEC modes: Not reported
        Speed: 1000Mb/s
        Duplex: Full
        Auto-negotiation: on
        master-slave cfg: preferred slave
        master-slave status: slave
        Port: Twisted Pair
        PHYAD: 0
        Transceiver: external
        MDI-X: Unknown
        Supports Wake-on: ug
        Wake-on: d
        Current message level: 0x0000003f (63)
                               drv probe link timer ifdown ifup
        Link detected: yes
Hi, looks like the issue still persists, but I have a temporary solution in case if your upload speed drops *way* beyond yours (2 Mbps for me). You can force-use a 100 Mbps link speed. `iperf3` results below. Literally 50x speed increase in my case! :)
I've performed these benchmarks connecting to my VPS via wireguard:
$ cat  /dev/mtd/by-name/U-Boot | strings | grep -B1 "u-boot,version"`
U-Boot: 2026.01_armbian-2026.01-S127a-Pc2e6-H706e-Vab81-B2eb2-R448a
Linux 6.18.10-current-rockchip64
Standard operation (1000 Mbps):
```root@odroidm1 ~# ethtool -s eth0 speed 1000 duplex full
root@odroidm1 ~# iperf3 -c 10.0.3.1
Connecting to host 10.0.3.1, port 5201
[  5] local 10.0.3.2 port 42538 connected to 10.0.3.1 port 5201
[  5]   0.00-1.00   sec   384 KBytes  3.14 Mbits/sec    5   14.7 KBytes
[  5]   1.00-2.00   sec   384 KBytes  3.15 Mbits/sec    5   6.68 KBytes
[  5]   2.00-3.00   sec   384 KBytes  3.14 Mbits/sec    2   13.4 KBytes
[  5]   3.00-4.00   sec   256 KBytes  2.10 Mbits/sec    6   9.35 KBytes
[  5]   4.00-4.43   sec   128 KBytes  2.42 Mbits/sec    0   22.7 KBytes
Dirty fix, link capped at 100 Mbps at most:
root@odroidm1 ~# ethtool -s eth0 speed 100 duplex full
[  5] local 10.0.3.2 port 42354 connected to 10.0.3.1 port 5201
[  5]   0.00-1.00   sec  11.4 MBytes  95.3 Mbits/sec    0   1.03 MBytes
[  5]   1.00-2.00   sec  10.5 MBytes  88.1 Mbits/sec    0   1.03 MBytes
[  5]   2.00-3.00   sec  11.4 MBytes  95.4 Mbits/sec    0   1.10 MBytes
[  5]   3.00-4.00   sec  10.2 MBytes  86.0 Mbits/sec    0   1.10 MBytes
[  5]   4.00-4.48   sec  5.00 MBytes  87.4 Mbits/sec    0   1.10 MBytes
So.. yeah.  While using Wireshark I also saw *a lot* of TCP retransmissions too, which usually don't happen that at 100 Mbps link in my configuration.
Posted (edited)
No difference on an installation with `linux-u-boot-odroidm1-edge/sid,now 26.8.0-trunk.12` and `linux-image-edge-rockchip64/sid` (7.0.8-edge-rockchip64 ), 1000 Mbps link is still heavily degraded, especially on packets leaving my gateway router. Could anyone subscribed to this thread confirm that's still the case? Thanks!
1000 Mbps link:
root@odroidm1 ~# ethtool -s eth0 speed 1000 duplex full autoneg on
root@odroidm1 ~ [1]# iperf3 -c 10.0.3.3
Connecting to host 10.0.3.3, port 5201
[  5] local 10.0.3.2 port 51448 connected to 10.0.3.3 port 5201
[  5]   0.00-1.00   sec  1.00 MBytes  8.38 Mbits/sec   12   22.8 KBytes
[  5]   1.00-2.00   sec   384 KBytes  3.15 Mbits/sec    2   11.4 KBytes
[  5]   2.00-3.00   sec  0.00 Bytes  0.00 bits/sec    1   10.4 KBytes
[  5]   3.00-4.00   sec   256 KBytes  2.10 Mbits/sec    0   19.9 KBytes
100 Mbps link:
root@odroidm1 ~# ethtool -s eth0 speed 100 duplex full autoneg off
root@odroidm1 ~# iperf3 -c 10.0.3.3
[  5] local 10.0.3.2 port 38436 connected to 10.0.3.3 port 5201
[  5]   0.00-1.00   sec  6.00 MBytes  50.3 Mbits/sec    0   2.38 MBytes
[  5]   1.00-2.00   sec  8.38 MBytes  70.3 Mbits/sec    0   7.87 MBytes
[  5]   2.00-3.00   sec  9.25 MBytes  77.6 Mbits/sec    0   7.87 MBytes
# grep -a --null-data U-Boot /dev/mtd0ro
U-Boot SPL 2026.01_armbian-2026.01-S127a-P2477-H8652-Vab81-Bd0d2-R448a (May 15 2026 - 06:45:08 +0000)
Edited by aleksandriusz
Since I haven't restarted the M1 for some time, I am currently still at:
# uptime
 12:56:23 up 115 days,  1:51,  5 users,  load average: 1.76, 1.26, 0.92
# uname -a
Linux micro-015 6.18.0-65.fc44.aarch64 #1 SMP PREEMPT_DYNAMIC Sun Dec  7 20:40:45 CET 2025 aarch64 GNU/Linux
I still get:
Spoiler
[  5] local odroid-m2 port 38866 connected to odroid-m1 port 5201
[  5]   0.00-1.00   sec   114 MBytes   959 Mbits/sec    0    553 KBytes
[  5]   1.00-2.00   sec   113 MBytes   946 Mbits/sec    0    648 KBytes
[  5]   2.00-3.00   sec   112 MBytes   941 Mbits/sec    0    684 KBytes
[  5]   3.00-4.00   sec   111 MBytes   930 Mbits/sec    0    809 KBytes
[  5]   4.00-5.00   sec   113 MBytes   949 Mbits/sec    0    809 KBytes
[  5]   5.00-6.00   sec   112 MBytes   943 Mbits/sec    0    809 KBytes
[  5]   6.00-7.00   sec   112 MBytes   940 Mbits/sec    0    809 KBytes
[  5]   7.00-8.00   sec   112 MBytes   940 Mbits/sec    0    809 KBytes
[  5]   8.00-9.00   sec   112 MBytes   935 Mbits/sec    0    850 KBytes
[  5]   9.00-10.00  sec   112 MBytes   942 Mbits/sec    0    850 KBytes
[  5]   0.00-10.01  sec  1.09 GBytes   940 Mbits/sec                  receiver
iperf Done.
[  5] local odroid-m2 port 50806 connected to odroid-m1 port 5201
[  5]   0.00-1.00   sec  92.2 MBytes   773 Mbits/sec
[  5]   1.00-2.00   sec  89.0 MBytes   746 Mbits/sec
[  5]   2.00-3.00   sec  88.1 MBytes   739 Mbits/sec
[  5]   3.00-4.00   sec  73.6 MBytes   618 Mbits/sec
[  5]   4.00-5.00   sec  89.5 MBytes   751 Mbits/sec
[  5]   5.00-6.00   sec  89.9 MBytes   754 Mbits/sec
[  5]   6.00-7.00   sec  77.5 MBytes   650 Mbits/sec
[  5]   7.00-8.00   sec  83.5 MBytes   701 Mbits/sec
[  5]   8.00-9.00   sec  84.6 MBytes   709 Mbits/sec
[  5]   9.00-10.00  sec  84.0 MBytes   705 Mbits/sec
[  5]   0.00-10.00  sec   853 MBytes   715 Mbits/sec  214            sender
[  5]   0.00-10.00  sec   852 MBytes   715 Mbits/sec                  receiver
iperf Done.
So nothing to complain about.
yes, it still exists unfortunately....
armbian-release: 26.2.1
# uname -r
# ethtool end0
Settings for end0:
                                1000baseT/Full
                                1000baseT/Full
        Speed: 1000Mb/s
        Duplex: Full
u-boot included in armbian 26.2.1
# dpkg -l linux-u-boot-odroidm1-current
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                          Version      Architecture Description
ii  linux-u-boot-odroidm1-current 26.2.1       arm64        Das U-Boot for odroidm1
U-Boot SPL 2026.01_armbian-2026.01-S127a-Pc2e6-H706e-Vab81-B2eb2-R448a (Feb 10 2026 - 04:37:42 +0000)
# iperf3 -R -c odroidm1.lan
Connecting to host odroidm1.lan, port 5201
Reverse mode, remote host odroidm1.lan is sending
[  5] local 192.168.1.192 port 48096 connected to 192.168.1.195 port 5201
[  5]   0.00-1.00   sec   128 KBytes  1.05 Mbits/sec
[  5]   1.00-2.00   sec   128 KBytes  1.05 Mbits/sec
[  5]   2.00-3.00   sec   128 KBytes  1.05 Mbits/sec
[  5]   3.00-4.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   4.00-5.00   sec   128 KBytes  1.05 Mbits/sec
[  5]   5.00-6.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   6.00-7.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   7.00-8.00   sec   256 KBytes  2.10 Mbits/sec
[  5]   8.00-9.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   9.00-10.00  sec  0.00 Bytes  0.00 bits/sec
[  5]   0.00-10.00  sec   896 KBytes   734 Kbits/sec  157             sender
[  5]   0.00-10.00  sec   768 KBytes   629 Kbits/sec                  receiver
u-boot from https://github.com/inindev/odroid-m1/releases/download/v12.0
[  5] local 192.168.1.192 port 43054 connected to 192.168.1.195 port 5201
[  5]   0.00-1.00   sec   110 MBytes   926 Mbits/sec
[  5]   1.00-2.00   sec   111 MBytes   929 Mbits/sec
[  5]   2.00-3.00   sec   110 MBytes   923 Mbits/sec
[  5]   3.00-4.00   sec   110 MBytes   920 Mbits/sec
[  5]   5.00-6.00   sec   110 MBytes   923 Mbits/sec
[  5]   6.00-7.00   sec   110 MBytes   926 Mbits/sec
^C[  5]   7.00-7.52   sec  58.1 MBytes   929 Mbits/sec
[  5]   0.00-7.52   sec  0.00 Bytes  0.00 bits/sec                  sender
[  5]   0.00-7.52   sec   830 MBytes   925 Mbits/sec                  receiver
latest u-boot still suffers...
latest u-boot from https://github.com/inindev/uboot-rockchip/releases
image: https://github.com/inindev/uboot-rockchip/releases/download/v2026.04/rk3568-odroid-m1.zip
[  5] local 192.168.1.192 port 51070 connected to 192.168.1.195 port 5201
[  5]   0.00-1.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   1.00-2.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   4.00-5.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   6.00-7.00   sec   256 KBytes  2.10 Mbits/sec
[  5]   7.00-8.00   sec  0.00 Bytes  0.00 bits/sec
[  5]   8.00-9.00   sec   128 KBytes  1.05 Mbits/sec
[  5]   9.00-10.00  sec   128 KBytes  1.05 Mbits/sec
[  5]   0.00-10.00  sec  1.00 MBytes   839 Kbits/sec  197             sender
[  5]   0.00-10.00  sec   896 KBytes   734 Kbits/sec                  receiver
iperf Done.
root@odroidm1:~# grep -a --null-data U-Boot /dev/mtd0ro
U-Boot SPL 2026.04 (Apr 16 2026 - 23:02:37 +0000)
the issue is fixed with edge kernel, with armbian u-boot included in 26.2.1
speed is now at gigabit level
# uname -r
6.19.0-edge-rockchip64
[  5] local 192.168.1.192 port 45834 connected to 192.168.1.195 port 5201
[  5]   0.00-1.00   sec   110 MBytes   919 Mbits/sec
[  5]   1.00-2.00   sec   110 MBytes   919 Mbits/sec
[  5]   2.00-3.00   sec   111 MBytes   928 Mbits/sec
[  5]   3.00-4.00   sec   110 MBytes   927 Mbits/sec
[  5]   4.00-5.00   sec   110 MBytes   922 Mbits/sec
[  5]   5.00-6.00   sec   110 MBytes   919 Mbits/sec
[  5]   6.00-7.00   sec   111 MBytes   928 Mbits/sec
[  5]   7.00-8.00   sec   110 MBytes   925 Mbits/sec
[  5]   8.00-9.00   sec   110 MBytes   925 Mbits/sec
[  5]   9.00-10.00  sec   110 MBytes   921 Mbits/sec
[  5]   0.00-10.00  sec  1.08 GBytes   926 Mbits/sec  110             sender
[  5]   0.00-10.00  sec  1.08 GBytes   923 Mbits/sec                  receiver
Posted (edited)
Can't confirm, still the same thing. U-boot built 7 days ago (linux-u-boot-odroidm1-edge/sid,now 26.8.0-trunk.105 arm64)
# uname -r
7.0.11-edge-rockchip64
U-Boot SPL 2026.01_armbian-2026.01-S127a-Pb401-H8652-Vab81-Bd0d2-R448a (May 31 2026 - 05:41:25 +0000)
# grep -a --null-data U-Boot /dev/mmcblk1
100 Mbps link still performs much better by some unknown reason. Hmm.
(I've already tested the cable, any other computer/laptop transmits the data just fine at full Gigabit speed)
