Nanopi M4v1 no HDMI output
Go to solution Solved by frauseo,
Posted (edited)
Hi folks,
I had an old install of armbian which worked. I wanted a new install to start fresh all over.
My problem is that i don't het any HDMI signal form the board.
What i've done so far:
- Downloaded ISO from armbian (nanopim4 with DE)
- flashed iso to sd 8GB SD card
- ssh to the board and did the first install
- with `armbian-install` installed to 32GB emmc
- enabled RDP for remote access but i was not able to get this to work either -.-'
System:
 _   _ ____  _   __  __ _  _
| \ | |  _ \(_) |  \/  | || |
|  \| | |_) | | | |\/| | || |_
| |\  |  __/| | | |  | |__   _|
|_| \_|_|   |_| |_|  |_|  |_|
Welcome to Armbian 23.8.1 Bookworm with Linux 6.1.50-current-rockchip64
No end-user support: community creations
System load:   2%               Up time:       4 min
Memory usage:  6% of 3.77G      IP:            192.168.0.102
CPU temp:      33°C             Usage of /:    28% of 29G
RX today:      4.3 GiB
Board starts with no issue, ssh works perfectly but i dont have any HDMI output.
this is the `armbianmonitor - u` output: https://paste.armbian.com/akovewakud
If you need log from the old installation i can provide the logs also.
Thanks for your help!
Edited by frauseo
  • Solution
I have found a viable workaround.
After trying the latest version of Bookworm and Jammy without success, I downloaded the latest version of Focal from the archive and then updated to Jammy from there.
Now I have an up to date system.
I hope this helps others who stumble upon the same problem.
Cheers
