Hi people!
I'm trying to use Armbian 23.8.1 CLI with the Rock 4 SE board without success.
I write the eMMC in the classic way: xzcat Armbian_23.8.1_Rockpi-4b_bookworm_current_6.1.50.img.xz | sudo dd of=/dev/sdb bs=4M status=progress; sync
but nothing seems to happens, i have only the green led on, the blue led is not blinking and the display says "no hdmi signal".
No problems with the image from radxa.
Do you have any idea what's going wrong?
Hi, thank for the answer, the serial is really useful!
The problem was the screen, i had used an HDMI/DP converter.
I changed the monitor with one with HDMI and now it works perfectly.
Thank you very much, you saved me a lot of hours!
Well probably was just a lucky shot.
I checked the image with hexdump and at least first MBs are identical, so data should be ok.
The power comes from a fast charger with a proper cable, both of a known brand.
Trying with other 2 devices (still rock4 se) problems are back:
U-Boot TPL 2022.07-armbian (Aug 22 2023 - 15:14:34)
Channel 0: col error
Cap error!
Channel 1: col error
Cap error!
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...                      <--------[OFTEN IS STUCK HERE]
trying again and again (with other power supply, with or without devices....), get stuck in different positions:
Cap error!
Cap error!
256B stride
Channel 0: row errorCap error!
Cap error!
no stride
Returning to boot ROM...                             <--------[SOMETIMES GOES FURTHER]
U-Boot SPL 2022.07-armbian (Aug 22 2023 - 15:14:34 +0000)
Trying to boot from MMC2
Card did not respond to voltage select! : -110
spl: mmc init failed with error: -95
Trying to boot from MMC1
NOTICE:  BL31: v1.3(release):845ee93
NOTICE:  BL31: Built : 15:51:11, Jul 22 2020
NOTICE:  BL31: Rockchip release version: v1. detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:   INFO:    If lpddr4 need support multi frequency,
INFO:    please update loader!
INFO:    Currectl index[0] freq=400MHz
INFO:  freq=800MHz
INFO:    plat_rockchip_pmu_init(1196): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE inin SMC_UNK
ERROR:   Error initializing runtime service opteed_fa    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9                                        <--------[CAUGHT ALSO HERE]
U-Boot 2022.07-armbian (Aug 22 2023 - 15:14:34 +0000)
SoC: Rockchip rk3399
Reset cause: POR
Model: Radxa ROCK Pi 4B
DRAM:  1.5 GiB                                                   <--------[CAUGHT ALSO HERE]
By insisting, everything starts working properly. It behaves like a diesel engine... :D
Some hints:
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=4 CS0 Row=16/15 CS=1 Die BW=16 Size=768MB
Channel 1: LPDDR4, 50MHz
BW=32 Col=9 Bk=4 5 CS=1 Die BW=16 Size=384MB
Reset cause: POR
DRAM:
My impression is that it doesn't take the right RAM size, so it only works when it
luckily addresses enough space...
Same here:
U-Boot TPL 2022.07-armbian (Nov 26 2023 - 16:22:55)
Cap error!
Cap error!
256B stride
I'm not able to get past that whatever I do. It boots Radxa own debian image, but it's old and bulky with gui which I don't need. Happens on both CLI and Desktop image:
Armbian_23.11.1_Rockpi-4c_bookworm_current_6.1.63.img.xz
Armbian_23.11.1_Rockpi-4c_jammy_current_6.1.63_xfce_desktop.img.xz
We found the same issue. It does boot with the dedicated rock-4se target, hence pretty surely an issue with the updated DDR blob. The Armbian repo ships functional U-Boot packages already: https://apt.armbian.com/pool/main/l/linux-u-boot-rock-4se-current/
But WiFi does not work. We tried with rk3399-rock-4se.dtb as well as rk3399-rock-pi-4b.dtb (as used in armbianEnv.txt with rock-4se target). Still trying to figure out what is missing: The correct brcmfmac driver loads. With ROCK 4 SE device tree, it tries to load the brcm/brcmfmac43455-sdio.radxa,rock-4se.bin, else brcm/brcmfmac43455-sdio.radxa,rockpi4b.bin, but actually it uses brcm/brcmfmac43455-sdio without the device-specific appendix anyway. Also creating symlinks for the device-specific suffix mutes the warning, but does not fix WiFi: The adapter is just not showing up in e.g. `ip link`.
Does someone know why the ROCK 4B device tree is explicitly used for the ROCK 4 SE target? For the U-Boot config, there is a note that upstream U-Boot ROCK 4 SE target is/was broken, but no hint why the 4B device tree is used. I thought that some patches might patch the 4B device tree only, but as far as we tested, both device trees generally work, but with none of them onboard WiFi is working on the ROCK 4 SE.
Edited by MichaIng
