How to switch to mainline kernel in Armbian 23.11 on Orange Pi 5 ?
adr3nal1n27
The release notes for Armbian 23.11 state, under Key Improvements in This Release, "Mainline Kernel for RK3588 with experimental HDMI support."
I am currently running the default 5.10.160-legacy-rk35xx kernel
If I wanted to switch to and try out the mainline kernel for RK3588 with experimental HDMI support, would I do something like this:
sudo apt install linux-image-collabora-rockchip-rk3588
After testing, If I want to rollback to the default legacy kernel, what are the steps involved?
Apologies if there are instructions elsewhere that cover this.
Thanks in advance for any guidance.
Edited by adr3nal1n27
Link to comment
Share on other sites
  • adr3nal1n27 changed the title to How to switch to mainline kernel in Armbian 23.11 on Orange Pi 5 ?
Just for the reference of others who are currently running the legacy 5.10.160 kernel and wanting to switch to kernel 6.7 (As this is not currently selectable in armbian-config >> System >> Other "Switch to other kernels"
Note that I tested this on a clean sd card install of Armbian Bookworm CLI with kernel 5.10
Here is what I did:
sudo apt install linux-image-edge-rockchip-rk3588 linux-dtb-edge-rockchip-rk3588 linux-u-boot-orangepi5-edge
sudo reboot
After reboot, uname -a now reports:
Linux orangepi5 6.7.0-rc1-edge-rockchip-rk3588 #1 SMP PREEMPT Mon Nov 13 00:19:07 UTC 2023 aarch64 GNU/Linux
Thanks very much armbian team for an excellent distribution.
Link to comment
