swaan Posted December 4, 2023 Posted December 4, 2023 I wanted to upgrade from the previous release to the current one. apt update & apt upgrade and reboot worked fine but I noticed it was still on the 5.10 kernel so I used the config utility to switch to 6.7 and now I can't get a display output on HDMI 1 or 2 and its not getting an IP address either. I'm booting from M.2 NVME. Is there any way to fix my setup? 0 Quote
swaan Posted December 4, 2023 Author Posted December 4, 2023 I think the new release just doesn't work for me as it won't boot of the sd card either with 6.7 but does with the previous Armbian_23.8.1_Rock-5b_bookworm_legacy_5.10.160.img 0 Quote
Werner Posted December 4, 2023 Posted December 4, 2023 5.10.y sources are based on rockchip bsp while 6.7 is bleeding edge mainline. Issues are to be expected. 0 Quote
Solution swaan Posted December 4, 2023 Author Solution Posted December 4, 2023 (edited) I think the armbian config tool upgraded to 6.1 and not 6.7 as I thought. Anyway I got it working again by getting the 5.10 kernel from the sd. Edited December 4, 2023 by swaan 0 Quote
l080 Posted January 3, 2024 Posted January 3, 2024 I was installing today armbian on my rock5b. It looks like kernel 6.7.. doesn't load /dev/mtdblock0 . I guess this is why you could not boot from nvme. 0 Quote
scolbeck Posted January 27, 2024 Posted January 27, 2024 I also had a problem with the 6.7 kernel not creating /dev/mtdblock0. Switching to the nightly 6.8 kernel fixed it for me. 0 Quote
chandlerkc Posted March 11, 2024 Posted March 11, 2024 On 1/27/2024 at 10:07 PM, scolbeck said: I also had a problem with the 6.7 kernel not creating /dev/mtdblock0. Switching to the nightly 6.8 kernel fixed it for me. Expand Same thing happening to me, I can only boot from microSD card. But in my case switching to 6.8 kernel is not solving the issue 0 Quote
scolbeck Posted March 12, 2024 Posted March 12, 2024 Try 6.8-rc1. That one worked for me but I also had problems with other ones like 6.8-rc5 so reverted back to 6.8-rc1. 0 Quote
