Posted (edited)
I have tried again with orange pi zero 3, debian trixie linux edge, xfce desktop.
This time, I tried without compositor. I ran this from SSH, as my user:
killall xfwm4 && xfwm4 --compositor=off &
I got:  (xfwm4:7880): Gtk-WARNING **: 10:45:56.629: cannot open display:
Then I tried "killall xfwm4 && xfwm4 --compositor=off --display :0.0 &" and there were no errors. The orange transparent effect when moving windows is now a white line rectangle
Then, mpv played my 1080p mp4 with low framerate (slow motion, 75% of speed)... sometimes with 100% CPU and sometimes with 25% CPU
I noticed this in the log (both high and low CPU cases)
[vd] Unsupported hwdec: drm
[vd] Using software decoding.
With high CPU:
[cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1
With 25% CPU:
[cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1
Whole log (low CPU case):
(Mpv.conf at the bottom)
Spoiler
LOW CPU
roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v videofile.mp4
[cplayer] Command line options: '-v' 'videofile.mp4'
[cplayer] mpv v0.40.0 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects
[cplayer] libplacebo version: v7.349.0
[cplayer] FFmpeg version: 7.1.1-1+b1 (runtime 7.1.1-1)
[cplayer] FFmpeg library versions:
[cplayer]    libavcodec      61.19.101
[cplayer]    libavdevice     61.3.100
[cplayer]    libavfilter     10.4.100
[cplayer]    libavformat     61.7.100
[cplayer]    libavutil       59.39.100
[cplayer]    libswresample   5.3.100
[cplayer]    libswscale      8.3.100
[cplayer] Configuration: -Dpython.bytecompile=-1 -Dlibmpv=true -Dbuild-date=false -Dcdda=enabled -Ddvdnav=enabled -Dsdl2=enabled -Ddvbin=enabled -Dprefix=/usr -Dlibdir=lib/aarch64-linux-gnu -Dlocalstatedir=/var -Dsysconfdir=/etc -Dbuildtype=plain -Dwrap_mode=nodownload
[cplayer] List of enabled features: alsa caca cdda cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg ffnvcodec gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel sndio sndio-1-9 uchardet vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 x11 xv zimg zimg-st428 zlib
[cplayer] Reading config file /etc/mpv/encoding-profiles.conf
[ifo_dvdnav] Opening /etc/mpv/encoding-profiles.conf
[bdmv/bluray] Opening /etc/mpv/encoding-profiles.conf
[file] Opening /etc/mpv/encoding-profiles.conf
[cplayer] Applying profile 'default'...
[cplayer] Reading config file /etc/mpv/mpv.conf
[ifo_dvdnav] Opening /etc/mpv/mpv.conf
[bdmv/bluray] Opening /etc/mpv/mpv.conf
[file] Opening /etc/mpv/mpv.conf
[cplayer] Setting option 'hwdec' = 'drm' (flags = 4)
[cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4)
[cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4)
[cplayer] Setting option 'v' = '' (flags = 😎
[clipboard] Initialized vo clipboard backend.
[cplayer] Waiting for scripts...
[cplayer] Set property: user-data/osc/visibility="auto" -> 1
[cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1
[cplayer] Done loading scripts.
[cplayer] Running hook: auto_profiles/on_before_start_file
[cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook.
[cplayer] Running hook: auto_profiles/on_load
[cplayer] Failed sending hook command auto_profiles/on_load. Removing hook.
[cplayer] Running hook: ytdl_hook/on_load
[ytdl_hook] playlist hook
[ifo_dvdnav] Opening videofile.mp4
[bdmv/bluray] Opening videofile.mp4
[file] Opening videofile.mp4
[demux] Trying demuxers for level=normal.
[osd/libass] libass API version: 0x1703000
[osd/libass] libass source: tarball: 0.17.3
[osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX)
[osd/libass] Setting up fonts...
[lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[cplayer] Opening done: videofile.mp4
[osd/libass] Using font provider fontconfig
[osd/libass] Done.
[find_files] Loading external files in .
[cplayer] Running hook: auto_profiles/on_preloaded
[cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook.
[cplayer] Running hook: ytdl_hook/on_preloaded
[lavf] select track 0
[cplayer] ● Video  --vid=1  (av1 1920x1080 30 fps) [default]
[vo/gpu] Probing for best GPU context.
[vo/gpu/auto] Initializing GPU context 'auto'
[vo/gpu/vulkan] Initializing GPU context 'waylandvk'
[vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349)
[vo/gpu/libplacebo] Creating vulkan instance with extensions:
[vo/gpu/libplacebo]     VK_KHR_get_physical_device_properties2
[vo/gpu/libplacebo]     VK_KHR_portability_enumeration
[vo/gpu/libplacebo]     VK_KHR_surface
[vo/gpu/libplacebo]     VK_KHR_wayland_surface
[vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER
[vo/gpu/libplacebo] Failed initializing vulkan instance
[vo/gpu/vulkan] Initializing GPU context 'x11vk'
[vo/gpu/libplacebo]     VK_KHR_xlib_surface
[vo/gpu/opengl] Initializing GPU context 'wayland'
[vo/gpu/opengl] Initializing GPU context 'x11egl'
[vo/gpu/x11] X11 opening display: :0.0
[vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS
[vo/gpu/x11] Current display FPS: 60.000000
[vo/gpu/opengl] EGL_VERSION=1.5
[vo/gpu/opengl] EGL_VENDOR=Mesa Project
[vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[vo/gpu/opengl] Trying to create Desktop OpenGL context.
[vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21
[vo/gpu/x11] The XPresent extension was found.
[vo/gpu/x11] XPresent enabled.
[vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.5-2'
[vo/gpu/opengl] Detected desktop OpenGL 3.1.
[vo/gpu/opengl] GL_VENDOR='Mesa'
[vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)'
[vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40'
[vo/gpu/opengl] Loaded extension GL_ARB_sync.
[vo/gpu/opengl] Loaded extension GL_ARB_timer_query.
[vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata.
[vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary.
[vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object.
[vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays.
[vo/gpu/opengl] Loaded extension GL_ARB_debug_output.
[vo/gpu/opengl] Loaded extension GL_KHR_debug.
[vo/gpu] Testing FBO format rgba16f
[vo/gpu] Using FBO format rgba16f.
[vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1).
[vo/gpu] Assuming 60.000000 FPS for display sync.
[vd] Container reported FPS: 30.000000
[vd] Codec list:
[vd]     libdav1d (av1) - dav1d AV1 decoder by VideoLAN
[vd]     libaom-av1 (av1) - libaom AV1
[vd]     av1 - Alliance for Open Media AV1
[vd]     av1_cuvid (av1) - Nvidia CUVID AV1 decoder
[vd] Opening decoder libdav1d
[vd] Detected 4 logical cores.
[vd] Requesting 5 threads for decoding.
[vd] Selected decoder: libdav1d - dav1d AV1 decoder by VideoLAN
[vf] User filter list:
[vf]   (empty)
[cplayer] Starting playback...
[vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=unknown crop=1920x1080+0+0
[vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [userdeint] (disabled)
[vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [autorotate] (disabled)
[vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [convert] (disabled)
[vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[osd/libass] Done.
[cplayer] VO: [gpu] 1920x1080 yuv420p
[cplayer] VO: Description: Shader-based GPU Renderer
[vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vo/gpu] Resize: 1920x1025
[vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 1920x1080 (1:1)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025
[vo/gpu] Video scale: 0.948958/0.949074
[vo/gpu] OSD borders: l=49 t=0 r=49 b=0
[vo/gpu] Video borders: l=49 t=0 r=49 b=0
[vo/gpu] Reported display depth: 8
[vo/gpu] Texture for plane 0: 1920x1080
[vo/gpu] Texture for plane 1: 960x540
[vo/gpu] Texture for plane 2: 960x540
[vo/gpu] Dither to 8.
[cplayer] first video frame after restart shown
[vo/gpu/x11] Disabling screensaver.
[cplayer] playback restart complete @ 0.000000, audio=eof, video=playing
roberto@orangepizero3:~$ cat /etc/mpv/mpv.conf
hwdec=drm
drm-drmprime-video-plane=primary
drm-draw-plane=overlay
Another sanity check:
Spoiler
roberto@orangepizero3:~$ uname -a
Linux orangepizero3 6.15.4-edge-sunxi64 #2 SMP Fri Jun 27 10:13:43 UTC 2025 aarch64 GNU/Linux
roberto@orangepizero3:~$ apt list libav*|grep v4l2
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libavcodec-dev/trixie 7:7.1.1-1-v4l2request1 arm64
libavcodec-extra61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavcodec-extra61/trixie 7:7.1.1-1-v4l2request1 arm64
libavcodec-extra/trixie 7:7.1.1-1-v4l2request1 arm64
libavcodec61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavcodec61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic]
libavdevice-dev/trixie 7:7.1.1-1-v4l2request1 arm64
libavdevice61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavdevice61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic]
libavfilter-dev/trixie 7:7.1.1-1-v4l2request1 arm64
libavfilter-extra10-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavfilter-extra10/trixie 7:7.1.1-1-v4l2request1 arm64
libavfilter-extra/trixie 7:7.1.1-1-v4l2request1 arm64
libavfilter10-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavfilter10/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic]
libavformat-dev/trixie 7:7.1.1-1-v4l2request1 arm64
libavformat-extra61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavformat-extra61/trixie 7:7.1.1-1-v4l2request1 arm64
libavformat-extra/trixie 7:7.1.1-1-v4l2request1 arm64
libavformat61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavformat61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic]
libavutil-dev/trixie 7:7.1.1-1-v4l2request1 arm64
libavutil59-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64
libavutil59/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic]
Ryzer, did you turn the compositor off? Are you using an armbian-downloaded OS, or self built? What kernel version?
DId you change anything in the linux menuconfig?
I am recompiling again, having checked again that the new linux patches are taken.... how could I check that my current Linux kernel has the new v4l2, cedrus functions?
Then I will try again with Bookworm
Edited by robertoj
Posted (edited)
I have tried again with trixie, ensuring that the kernel patches were taken... no difference.
Then I build a Bookworm Armbian image, with linux 6.15.4. It wasn't visible wether the kernel was downloaded from armbian, or the last one was included in my OS image.
Just for fun, I tried it with Bookworm's default ffmpeg-5.1.6, with xfce with compositor off... and I got a 1080p MP4 playing with 100%
mpv log:
Spoiler
bookworm without compositor, linux 6.15.4, default ffmpeg
[cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects
[cplayer]  built on UNKNOWN
[cplayer]    libavutil       57.28.100
[cplayer]    libavcodec      59.37.100
[cplayer]    libavformat     59.27.100
[cplayer]    libswscale      6.7.100
[cplayer]    libavfilter     8.44.100
[cplayer]    libswresample   4.7.100
[cplayer] FFmpeg version: 5.1.6-0+deb12u1
[cplayer]
[cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain
[cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib
[osd/libass] libass API version: 0x1701000
[osd/libass] libass source: tarball: 0.17.1
[osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX)
[osd/libass] Done.
[cplayer] Set property: shared-script-properties -> 1
[ytdl_hook] ytdl:// hook
[ytdl_hook] not a ytdl:// url
[osd/libass] Done.
[cplayer]  (+) Video --vid=1 (*) (av1 1920x1080 30.000fps)
[vo/gpu/opengl] EGL_VERSION=1.4
[vo/gpu/x11] XPresent disabled.
[vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6'
[vo/gpu/opengl] GL_VENDOR='Panfrost'
[vo/gpu] No advanced processing required. Enabling dumb mode.
[vd] Codec list:
[vd] No hardware decoding available for this codec.
[ffmpeg/video] libdav1d: libdav1d 1.0.0
[vd] Selected codec: libdav1d (dav1d AV1 decoder by VideoLAN)
[vf]   (empty)
[vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vo/gpu/x11] not waiting for MapNotify
[statusline] V: 00:00:00 / 00:04:49 (0%)
[statusline] V: 00:00:08 / 00:04:49 (3%) Dropped: 47
[cplayer] Set property: fullscreen -> 1
[vo/gpu] Resize: 1920x1080
[vo/gpu] Window size: 1920x1080 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080
[vo/gpu] Video scale: 1.000000/1.000000
[vo/gpu] OSD borders: l=0 t=0 r=0 b=0
[vo/gpu] Video borders: l=0 t=0 r=0 b=0
[statusline] V: 00:00:26 / 00:04:49 (9%) Dropped: 150
[cplayer] EOF code: 5
[vo/gpu/x11] Enabling screensaver.
[cplayer] finished playback, success (reason 3)
[cplayer]
[cplayer] Exiting... (Quit)
roberto@orangepizero3:~$ apt list ffmpeg
Listing... Done
ffmpeg/stable,stable-security,now 7:5.1.6-0+deb12u1 arm64 [installed]
roberto@orangepizero3:~$ apt list libavcodec59
Listing... Done
libavcodec59/stable,stable-security,now 7:5.1.6-0+deb12u1 arm64 [installed,automatic]
Note that mpv still complains about unsupported hwdec: drm
I repeated the test with compositor ON: killall xfwm4 && xfwm4 --compositor=on --display :0.0 &
Same result: CPU 100%, but nice full FPS video
Then I tried with the ffmpeg-x.x.x-v4l2 request
Adding the repo, updating, and checking the update:
Spoiler
roberto@orangepizero3:~$ apt list --upgradable
Listing... Done
ffmpeg/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libavcodec59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libavdevice59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libavfilter8/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libavformat59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libavutil57/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libpostproc56/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libswresample4/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
libswscale6/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1]
roberto@orangepizero3:~$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages will be upgraded:
  ffmpeg libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libpostproc56 libswresample4
  libswscale6
9 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 11.8 MB of archives.
After this operation, 66.6 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
... the 9 ffmpeg packages get installed with no problem
Then I tried playing the mp4, I got no complaint about "unsupported hwdec: drm", but the CPU was still 100%
For the first time, I get some video glitches when I resize, and repeated messages:
Failed to create scanout resource
DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory
compositor=on or off doesn't make a difference for me.
mpv log:
Spoiler
[cplayer]
[osd/libass] Done.
[osd/libass] Done.
[vd] Codec list:
[vf]   (empty)
[statusline] V: 00:00:16 / 00:04:49 (6%) Dropped: 216
[vf] dropping frame due to pin disconnect
[cplayer]
Summary:
Armbian Trixie (and the correspoinding ffmpeg 7.1.1) will always result in "unsupported hwdec: drm", with default ffmpeg, or ffmpeg-v4l2 request
Armbian Bookworm (ffmpeg 5.1.6) will never complain about "unsupported hwdec: drm", with default ffmpeg or ffmpeg-v4l2request. Still 100% CPU
Edited by robertoj
4 hours ago, robertoj said:
[vd] Codec list:
Just out of curiosity, you are trying to play content that is encoded in AV1.
Are you sure that your device is equipped with an AV1 decoder IP and that the kernel has the appropriate driver?
Posted (edited)
You are right.
I just downloaded something from youtube and assumed it was H264.
When I checked it in VLC in my PC, the codec is: AOMedia's AV1 video (av01)
I picked another mp4, which I verified in VLC as H264-MPEG4, 720p, and it played with 10% CPU :)
This test below is with Bookworm XFCE, compositor ON, Linux 6.15.4 with default configuration
Spoiler
roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v donde\ venderan\ buen\ trago\ 720p.mp4
[cplayer] Command line options: '-v' 'donde venderan buen trago 720p.mp4'
[cplayer]
[osd/libass] Done.
[ifo_dvdnav] Opening donde venderan buen trago 720p.mp4
[bdmv/bluray] Opening donde venderan buen trago 720p.mp4
[file] Opening donde venderan buen trago 720p.mp4
[osd/libass] Done.
[cplayer] Opening done: donde venderan buen trago 720p.mp4
[lavf] select track 1
[cplayer]  (+) Video --vid=1 (*) (h264 1280x720 29.970fps)
[cplayer]  (+) Audio --aid=1 --alang=eng (*) (aac 2ch 44100Hz)
[vd] Container reported FPS: 29.970030
[vd] Codec list:
[vd]     h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vd]     h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper
[vd]     h264_cuvid (h264) - Nvidia CUVID H264 decoder
[vd] Opening decoder h264
[vd] Looking at hwdec h264-drm...
[vo/gpu] Loading hwdec drivers for format: 'drm_prime'
[vo/gpu] Loading hwdec driver 'drmprime-overlay'
[vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display.
[vo/gpu] Loading failed.
[vo/gpu] Loading hwdec driver 'drmprime'
[vo/gpu/drmprime] using EGL dmabuf interop
[vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128
[vd] Trying hardware decoding via h264-drm.
[vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10)
[vf]   (empty)
[ad] Codec list:
[ad]     aac - AAC (Advanced Audio Coding)
[ad]     aac_fixed (aac) - AAC (Advanced Audio Coding)
[ad] Opening decoder aac
[ad] Requesting 1 threads for decoding.
[ad] Selected codec: aac (AAC (Advanced Audio Coding))
[af] User filter list:
[af]   (empty)
[af] [in] 44100Hz stereo 2ch floatp
[af] [userspeed] 44100Hz stereo 2ch floatp
[af] [userspeed] (disabled)
[af] [convert] 44100Hz stereo 2ch floatp
[vd] Pixel formats supported by decoder: vdpau cuda vaapi drm_prime yuv420p
[vd] Codec profile: Main (0x4d)
[vd] Requesting pixfmt 'drm_prime' from decoder.
[vd] Using hardware decoding (drm).
[vd] Decoder format: 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264
[vd] Using container aspect ratio.
[vf] [in] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [userdeint] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [autorotate] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [convert] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [out] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[ao] Trying audio driver 'pipewire'
[ao/pipewire] requested format: 44100 Hz, stereo channels, floatp
[ao/pipewire] Headers version: 0.3.65
[ao/pipewire] Library version: 0.3.65
[W][00618.325296] pw.conf      | [          conf.c:  939 try_load_conf()] can't load config client.conf: No such file or directory
[E][00618.325551] pw.conf      | [          conf.c:  963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory
[ao] Trying audio driver 'pulse'
[ao/pulse] requested format: 44100 Hz, stereo channels, floatp
[ao/pulse] Library version: 16.1.0
[ao/pulse] Proto: 35
[ao/pulse] Server proto: 4294967295
[ao/pulse] Channel layouts:
[ao/pulse]  - #fl
[ao/pulse]  - #fr
[ao/pulse]  - #fc
[ao/pulse]  - #lfe
[ao/pulse]  - #bl
[ao/pulse]  - #br
[ao/pulse]  - #flc
[ao/pulse]  - #frc
[ao/pulse]  - #bc
[ao/pulse]  - #sl
[ao/pulse]  - #sr
[ao/pulse]  - #tc
[ao/pulse]  - #tfl
[ao/pulse]  - #tfc
[ao/pulse]  - #tfr
[ao/pulse]  - #tbl
[ao/pulse]  - #tbc
[ao/pulse]  - #tbr
[ao/pulse] result: stereo
[ao/pulse] device buffer: 6172 samples.
[ao/pulse] using soft-buffer of 8820 samples.
[cplayer] AO: [pulse] 44100Hz stereo 2ch float
[cplayer] AO: Description: PulseAudio audio output
[autoconvert] inserting resampler
[swresample] format change, reinitializing resampler
[swresample] 44100Hz stereo floatp -> 44100Hz stereo float
[af] [out] 44100Hz stereo 2ch float
[cplayer] VO: [gpu] 1280x720 drm_prime[nv12]
[vo/gpu] reconfig to 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vo/gpu] Resize: 1280x720
[vo/gpu] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 1280x720 (1:1)
[vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720
[cplayer] audio ready
[cplayer] starting audio playback
[cplayer] playback restart complete @ 0.000000, audio=playing, video=playing
[ao/pulse] starting AO
[statusline] AV: 00:00:04 / 00:04:18 (2%) A-V:  0.000
[osd/libass] fontselect: (sans-serif, 400, 0) -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf, 0, DejaVuSans
[osd/libass] fontselect: (mpv-osd-symbols, 400, 0) -> mpv-osd-symbols-Regular, 0, mpv-osd-symbols-Regular
[vo/gpu] Reallocating OSD texture to 2048x256.
[statusline] AV: 00:00:05 / 00:04:18 (2%) A-V:  0.000
[statusline] AV: 00:00:08 / 00:04:18 (3%) A-V:  0.000 Dropped: 2
[vo/gpu] Resize: 1093x615
[vo/gpu] Window size: 1093x615 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1093x615
[vo/gpu] Video scale: 0.853906/0.854167
[statusline] AV: 00:00:19 / 00:04:18 (7%) A-V:  0.000 Dropped: 2
[cplayer]
Then I repeat the test with a 1080p H264 mp4. mpv tries to use hardware acceleration, but the mpv is black and there's continuous DRM_IOCTL errors:
Spoiler
roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v windwaker1080p.mp4
[cplayer] Command line options: '-v' 'windwaker1080p.mp4'
[cplayer]
[osd/libass] Done.
[ifo_dvdnav] Opening windwaker1080p.mp4
[bdmv/bluray] Opening windwaker1080p.mp4
[file] Opening windwaker1080p.mp4
[cplayer] Opening done: windwaker1080p.mp4
[osd/libass] Done.
[cplayer]  (+) Video --vid=1 (*) (h264 1920x1080 29.970fps)
[vd] Codec list:
[vf]   (empty)
[vd] Codec profile: High (0x64)
[vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264
[vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[cplayer] VO: [gpu] 1920x1080 drm_prime[nv12]
[vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
Then I tried this inside /etc/mpv/mpv.conf
hwdec=drm-prime
and the 1080p H264 starts playing fluidly with just 40% CPU (compositor off)
Spoiler
[cplayer]
[cplayer] Setting option 'hwdec' = 'drm-prime' (flags = 4)
[osd/libass] Done.
[osd/libass] Done.
[vd] Codec list:
[vd] Unsupported hwdec: drm-prime
[vf]   (empty)
[vd] DR failed - disabling.
[vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264
[vo/gpu] DR path suspected slow/uncached, disabling..reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264
[statusline] V: 00:00:00 / 00:04:31 (0%)
[statusline] V: 00:00:09 / 00:04:31 (3%)
[cplayer]
With compositor on, I get same 40% CPU
Spoiler
[cplayer]
[osd/libass] Done.
[osd/libass] Done.
[vd] Codec list:
[vf]   (empty)
[statusline] V: 00:00:16 / 00:04:31 (6%) Dropped: 2
[cplayer]
Same video glitches, with or without compositor, but I am getting hardware acceleration (although there's the hwdec unsupported message)
Update: Thank you to all who helped me. I have hardware acceleration again with my opiz3
hwdec=drm is more efficient
extraargs=cma=256 is needed to avoid memory allocation problems and video glitches.
https://forum.armbian.com/topic/29202-orange-pi-zero-3/page/26/#findComment-222596
Edited by robertoj
First test was in a CLI environment so running fullscreen. Self built with no media related changes to the configuration. Edge build around kernel 6.15.0 and running on Pcduino2
For the second test I used the build scripts to create a desktop image which came to be less of a headache because less dependencies had to resolved than working purely with CLI only. This was built around kernel 6.15.4 and running on Pcduino3. This time got a blue screen within the window and lots of errors relating to dmabuf. test2.txt I currently have CMA set to 64mb, although this is overridden by the shared-dma-pool within the sun7i-a20.dtsi
I would try the cma=256M argument anyway... this kernel argument eliminated my video glitches and dma errors.
I don't know how a dtsi or dtbo parameter (loaded after linux is started) would override a kernel argument (given before the linux kernel is started).
Has anybody had success with Armbian Trixie?
I repeated the steps I did for Bookworm, to have HW accelerated H264 1080p in XFCE, X11, with Linux 6.15.4... and I get "Unsupported hwdec: drm" in Trixie: ffmpeg 7.1.1, mpv 0.4.0
mpv log in trixie (with double verbose):
Spoiler
trixie test, 50% CPU, drops 50% of frames
roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v -v pedro\ pe\ 1080p\ 25fps\ h264.mp4
[cplayer] Command line options: '-v' '-v' 'pedro pe 1080p 25fps h264.mp4'
[global] home path: '' -> '/home/roberto/.config/mpv'
[global] user path: '~~home/' -> '/home/roberto/.config/mpv'
[global] user path: '~~old_home/' -> '/home/roberto/.mpv'
[global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.config/mpv/encoding-profiles.conf'
[global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.mpv/encoding-profiles.conf'
[global] config path: 'encoding-profiles.conf' -> '/etc/mpv/encoding-profiles.conf'
[file] resize stream to 131072 bytes, drop 0 bytes
[file] Stream opened successfully.
[global] config path: 'mpv.conf' -/-> '/home/roberto/.config/mpv/mpv.conf'
[global] config path: 'config' -/-> '/home/roberto/.config/mpv/config'
[global] config path: 'mpv.conf' -/-> '/home/roberto/.mpv/mpv.conf'
[global] config path: 'config' -/-> '/home/roberto/.mpv/config'
[global] config path: 'mpv.conf' -> '/etc/mpv/mpv.conf'
[global] config path: 'config' -/-> '/etc/mpv/config'
[global] config path: 'input.conf' -/-> '/home/roberto/.config/mpv/input.conf'
[global] config path: 'input.conf' -/-> '/home/roberto/.mpv/input.conf'
[global] config path: 'input.conf' -/-> '/etc/mpv/input.conf'
[osc] Loading lua script @osc.lua...
[ytdl_hook] Loading lua script @ytdl_hook.lua...
[stats] Loading lua script @stats.lua...
[console] Loading lua script @console.lua...
[auto_profiles] Loading lua script @auto_profiles.lua...
[select] Loading lua script @select.lua...
[positioning] Loading lua script @positioning.lua...
[stats] loading mp.defaults
[commands] Loading lua script @commands.lua...
[console] loading mp.defaults
[auto_profiles] loading mp.defaults
[positioning] loading mp.defaults
[ytdl_hook] loading mp.defaults
[select] loading mp.defaults
[stats] loading @stats.lua
[positioning] loading @positioning.lua
[global] config path: 'scripts' -/-> '/home/roberto/.config/mpv/scripts'
[global] config path: 'scripts' -/-> '/home/roberto/.mpv/scripts'
[global] config path: 'scripts' -/-> '/etc/mpv/scripts'
[osc] loading mp.defaults
[positioning] reading options for positioning
[global] config path: 'script-opts/positioning.conf' -/-> '/home/roberto/.config/mpv/script-opts/positioning.conf'
[global] config path: 'script-opts/positioning.conf' -/-> '/home/roberto/.mpv/script-opts/positioning.conf'
[global] config path: 'script-opts/positioning.conf' -/-> '/etc/mpv/script-opts/positioning.conf'
[positioning] script-opts/positioning.conf not found.
[global] config path: 'lua-settings/positioning.conf' -/-> '/home/roberto/.config/mpv/lua-settings/positioning.conf'
[global] config path: 'lua-settings/positioning.conf' -/-> '/home/roberto/.mpv/lua-settings/positioning.conf'
[global] config path: 'lua-settings/positioning.conf' -/-> '/etc/mpv/lua-settings/positioning.conf'
[positioning] lua-settings/positioning.conf not found.
[ytdl_hook] loading @ytdl_hook.lua
[commands] loading mp.defaults
[cplayer] Run command: define-section, flags=64, args=[name="input_positioning", contents="", flags="default"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_positioning", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_positioning", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_positioning", flags="allow-hide-cursor+allow-vo-dragging"]
[select] loading @select.lua
[osc] loading @osc.lua
[commands] loading @commands.lua
[auto_profiles] loading @auto_profiles.lua
[console] loading @console.lua
[select] reading options for select
[global] config path: 'script-opts/select.conf' -/-> '/home/roberto/.config/mpv/script-opts/select.conf'
[global] config path: 'script-opts/select.conf' -/-> '/home/roberto/.mpv/script-opts/select.conf'
[global] config path: 'script-opts/select.conf' -/-> '/etc/mpv/script-opts/select.conf'
[select] script-opts/select.conf not found.
[global] config path: 'lua-settings/select.conf' -/-> '/home/roberto/.config/mpv/lua-settings/select.conf'
[global] config path: 'lua-settings/select.conf' -/-> '/home/roberto/.mpv/lua-settings/select.conf'
[global] config path: 'lua-settings/select.conf' -/-> '/etc/mpv/lua-settings/select.conf'
[select] lua-settings/select.conf not found.
[stats] reading options for stats
[global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.config/mpv/script-opts/stats.conf'
[global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.mpv/script-opts/stats.conf'
[global] config path: 'script-opts/stats.conf' -/-> '/etc/mpv/script-opts/stats.conf'
[stats] script-opts/stats.conf not found.
[global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.config/mpv/lua-settings/stats.conf'
[global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.mpv/lua-settings/stats.conf'
[global] config path: 'lua-settings/stats.conf' -/-> '/etc/mpv/lua-settings/stats.conf'
[stats] lua-settings/stats.conf not found.
[commands] reading options for commands
[cplayer] Run command: define-section, flags=64, args=[name="input_select", contents="", flags="default"]
[console] reading options for console
[ytdl_hook] reading options for ytdl_hook
[global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/script-opts/ytdl_hook.conf'
[global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.mpv/script-opts/ytdl_hook.conf'
[global] config path: 'script-opts/ytdl_hook.conf' -/-> '/etc/mpv/script-opts/ytdl_hook.conf'
[ytdl_hook] script-opts/ytdl_hook.conf not found.
[global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/lua-settings/ytdl_hook.conf'
[global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.mpv/lua-settings/ytdl_hook.conf'
[global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/etc/mpv/lua-settings/ytdl_hook.conf'
[global] config path: 'script-opts/commands.conf' -/-> '/home/roberto/.config/mpv/script-opts/commands.conf'
[global] config path: 'script-opts/commands.conf' -/-> '/home/roberto/.mpv/script-opts/commands.conf'
[global] config path: 'script-opts/commands.conf' -/-> '/etc/mpv/script-opts/commands.conf'
[commands] script-opts/commands.conf not found.
[global] config path: 'lua-settings/commands.conf' -/-> '/home/roberto/.config/mpv/lua-settings/commands.conf'
[global] config path: 'lua-settings/commands.conf' -/-> '/home/roberto/.mpv/lua-settings/commands.conf'
[global] config path: 'lua-settings/commands.conf' -/-> '/etc/mpv/lua-settings/commands.conf'
[commands] lua-settings/commands.conf not found.
[global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.config/mpv/script-opts/console.conf'
[global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.mpv/script-opts/console.conf'
[ytdl_hook] lua-settings/ytdl_hook.conf not found.
[global] config path: 'script-opts/console.conf' -/-> '/etc/mpv/script-opts/console.conf'
[console] script-opts/console.conf not found.
[global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.config/mpv/lua-settings/console.conf'
[global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.mpv/lua-settings/console.conf'
[global] config path: 'lua-settings/console.conf' -/-> '/etc/mpv/lua-settings/console.conf'
[console] lua-settings/console.conf not found.
[cplayer] Run command: enable-section, flags=64, args=[name="input_select", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_select", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_select", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_commands", contents="", flags="default"]
[cplayer] Run command: define-section, flags=64, args=[name="input_stats", contents="", flags="default"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_stats", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_commands", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_stats", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_stats", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_commands", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_commands", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_console", contents="", flags="default"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_console", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_console", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_console", flags="allow-hide-cursor+allow-vo-dragging"]
[auto_profiles] Destroying client handle...
[cplayer] Run command: define-section, flags=64, args=[name="showhide", contents="mouse_move script-binding osc/__keybinding1\nmouse_leave script-binding osc/__keybinding2\n", flags="force"]
[cplayer] Run command: define-section, flags=64, args=[name="showhide_wc", contents="mouse_move script-binding osc/__keybinding3\nmouse_leave script-binding osc/__keybinding4\n", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="showhide", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: enable-section, flags=64, args=[name="showhide_wc", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input", contents="mbtn_left script-binding osc/__keybinding5\nmbtn_mid script-binding osc/__keybinding6\nmbtn_right script-binding osc/__keybinding7\nshift+mbtn_left script-binding osc/__keybinding8\nwheel_up script-binding osc/__keybinding9\nwheel_down script-binding osc/__keybinding10\nmbtn_left_dbl ignore\nshift+mbtn_left_dbl ignore\nmbtn_right_dbl ignore\n", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input", flags=""]
[cplayer] Run command: define-section, flags=64, args=[name="window-controls", contents="mbtn_left script-binding osc/__keybinding11\n", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""]
[osc] reading options for osc
[global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.config/mpv/script-opts/osc.conf'
[global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.mpv/script-opts/osc.conf'
[global] config path: 'script-opts/osc.conf' -/-> '/etc/mpv/script-opts/osc.conf'
[osc] script-opts/osc.conf not found.
[global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.config/mpv/lua-settings/osc.conf'
[global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.mpv/lua-settings/osc.conf'
[global] config path: 'lua-settings/osc.conf' -/-> '/etc/mpv/lua-settings/osc.conf'
[osc] lua-settings/osc.conf not found.
[cplayer] Run command: disable-section, flags=64, args=[name="input"]
[cplayer] Run command: disable-section, flags=64, args=[name="window-controls"]
[global] state path: 'watch_later' -> '/home/roberto/.local/state/mpv/watch_later'
[osc] osc_init
[ifo_dvdnav] Opening pedro pe 1080p 25fps h264.mp4
[bdmv/bluray] Opening pedro pe 1080p 25fps h264.mp4
[file] Opening pedro pe 1080p 25fps h264.mp4
[demux] Trying demuxer: directory (force-level: normal)
[demux] Trying demuxer: disc (force-level: normal)
[demux] Trying demuxer: edl (force-level: normal)
[demux] Trying demuxer: cue (force-level: normal)
[demux] Trying demuxer: rawaudio (force-level: normal)
[demux] Trying demuxer: rawvideo (force-level: normal)
[demux] Trying demuxer: mkv (force-level: normal)
[demux] Trying demuxer: libarchive (force-level: normal)
[global] config path: 'fonts' -/-> '/home/roberto/.config/mpv/fonts'
[global] config path: 'fonts' -/-> '/home/roberto/.mpv/fonts'
[global] config path: 'fonts' -/-> '/etc/mpv/fonts'
[osd/libass] ASS library version: 0x1703000 (runtime 0x1703000)
[demux] Trying demuxer: lavf (force-level: normal)
[global] config path: 'subfont.ttf' -/-> '/home/roberto/.config/mpv/subfont.ttf'
[global] config path: 'subfont.ttf' -/-> '/home/roberto/.mpv/subfont.ttf'
[global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf'
[global] config path: 'fonts.conf' -/-> '/home/roberto/.config/mpv/fonts.conf'
[global] config path: 'fonts.conf' -/-> '/home/roberto/.mpv/fonts.conf'
[global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf'
[ffmpeg/demuxer] mov,mp4,m4a,3gp,3g2,mj2: advanced_editlist does not work with fragmented MP4. disabling.
[cplayer] Opening done: pedro pe 1080p 25fps h264.mp4
[osd/libass] Done.
[global] config path: 'sub' -/-> '/home/roberto/.config/mpv/sub'
[global] config path: 'sub' -/-> '/home/roberto/.mpv/sub'
[global] config path: 'sub' -/-> '/etc/mpv/sub'
[cplayer] ● Video  --vid=1  (h264 1920x1080 25 fps) [default]
[vo/gpu/libplacebo] Available instance version: 1.4.309
[vo/gpu/libplacebo] Spent 0.482 ms enumerating instance layers
[vo/gpu/libplacebo] Available layers:
[vo/gpu/libplacebo] Spent 0.574 ms enumerating instance extensions
[vo/gpu/libplacebo] Available instance extensions:
[vo/gpu/libplacebo]     VK_EXT_debug_report
[vo/gpu/libplacebo]     VK_EXT_debug_utils
[vo/gpu/libplacebo]     VK_LUNARG_direct_driver_loading
[vo/gpu/libplacebo] Spent 0.232 ms creating vulkan instance
[vo/gpu/libplacebo] Spent 0.435 ms enumerating instance layers
[vo/gpu/libplacebo] Spent 0.503 ms enumerating instance extensions
[vo/gpu/libplacebo] Spent 0.227 ms creating vulkan instance
[vo/gpu/x11] X11 running at 1920x1080 (":0.0" => local display)
[vo/gpu/x11] Detected wm supports NetWM.
[vo/gpu/x11] Detected wm supports ABOVE state.
[vo/gpu/x11] Detected wm supports BELOW state.
[vo/gpu/x11] Detected wm supports FULLSCREEN state.
[vo/gpu/x11] Detected wm supports SKIP_TASKBAR state.
[vo/gpu/x11] Detected wm supports STICKY state.
[vo/gpu/opengl] Chosen EGLConfig:
[vo/gpu/opengl]   EGL_CONFIG_ID=0x9
[vo/gpu/opengl]   EGL_RED_SIZE=0x8
[vo/gpu/opengl]   EGL_GREEN_SIZE=0x8
[vo/gpu/opengl]   EGL_BLUE_SIZE=0x8
[vo/gpu/opengl]   EGL_ALPHA_SIZE=0x0
[vo/gpu/opengl]   EGL_COLOR_BUFFER_TYPE=0x308e
[vo/gpu/opengl]   EGL_CONFIG_CAVEAT=0x3038
[vo/gpu/opengl]   EGL_CONFORMANT=0x4d
[vo/gpu/opengl]   EGL_NATIVE_VISUAL_ID=0x21
[vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2'
[vo/gpu/opengl] Combined OpenGL extensions string:
[vo/gpu/opengl] EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_CHROMIUM_sync_control EGL_ANGLE_sync_control_rate EGL_EXT_buffer_age EGL_EXT_config_select_group EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_surface_compression EGL_EXT_swap_buffers_with_damage EGL_IMG_context_priority EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_partial_update EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_gl_interop EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_MESA_x11_native_visual_id EGL_NOK_texture_from_pixmap EGL_WL_bind_wayland_display  GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_EGL_image_storage GL_EXT_EGL_image_storage_compression GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_debug_label GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_image_load_formatted GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_RG8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_INTEL_blackhole_render GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_image GL_NV_depth_clamp GL_NV_fog_distance GL_NV_half_float GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
[vo/gpu/opengl] Texture formats:
[vo/gpu/opengl]   NAME       COMP*TYPE SIZE           DEPTH PER COMP.
[vo/gpu/opengl]   r8         1*unorm   1B    LF CR ST {8}
[vo/gpu/opengl]   rg8        2*unorm   2B    LF CR ST {8 8}
[vo/gpu/opengl]   rgb8       3*unorm   3B    LF CR ST {8 8 8}
[vo/gpu/opengl]   rgba8      4*unorm   4B    LF CR ST {8 8 8 8}
[vo/gpu/opengl]   r16        1*unorm   2B    LF CR ST {16}
[vo/gpu/opengl]   rg16       2*unorm   4B    LF CR ST {16 16}
[vo/gpu/opengl]   rgb16      3*unorm   6B    LF CR ST {16 16 16}
[vo/gpu/opengl]   rgba16     4*unorm   8B    LF CR ST {16 16 16 16}
[vo/gpu/opengl]   r8ui       1*uint    1B       CR ST {8}
[vo/gpu/opengl]   rg8ui      2*uint    2B       CR ST {8 8}
[vo/gpu/opengl]   rgb8ui     3*uint    3B          ST {8 8 8}
[vo/gpu/opengl]   rgba8ui    4*uint    4B       CR ST {8 8 8 8}
[vo/gpu/opengl]   r16ui      1*uint    2B       CR ST {16}
[vo/gpu/opengl]   rg16ui     2*uint    4B       CR ST {16 16}
[vo/gpu/opengl]   rgb16ui    3*uint    6B          ST {16 16 16}
[vo/gpu/opengl]   rgba16ui   4*uint    8B       CR ST {16 16 16 16}
[vo/gpu/opengl]   r16f       1*float   4B    LF CR ST {32/16}
[vo/gpu/opengl]   rg16f      2*float   8B    LF CR ST {32/16 32/16}
[vo/gpu/opengl]   rgb16f     3*float  12B    LF CR ST {32/16 32/16 32/16}
[vo/gpu/opengl]   rgba16f    4*float  16B    LF CR ST {32/16 32/16 32/16 32/16}
[vo/gpu/opengl]   r32f       1*float   4B    LF CR ST {32}
[vo/gpu/opengl]   rg32f      2*float   8B    LF CR ST {32 32}
[vo/gpu/opengl]   rgb32f     3*float  12B    LF CR ST {32 32 32}
[vo/gpu/opengl]   rgba32f    4*float  16B    LF CR ST {32 32 32 32}
[vo/gpu/opengl]   rgb10_a2   4*unorm   4B    LF CR ST {0/10 0/10 0/10 0/2}
[vo/gpu/opengl]   rgba12     4*unorm   8B    LF CR ST {16 16 16 16}
[vo/gpu/opengl]   rgb10      3*unorm   6B    LF CR ST {16/10 16/10 16/10}
[vo/gpu/opengl]   rgb565     3*unorm   2B    LF    ST {0/8 0/8 0/8}
[vo/gpu/opengl]  LA = LUMINANCE_ALPHA hack format
[vo/gpu/opengl]  LF = linear filterable
[vo/gpu/opengl]  CR = can be used for render targets
[vo/gpu/opengl]  ST = can be used for storable images
[vo/gpu/opengl] Image formats:
[vo/gpu/opengl]   yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   gray => 1 planes 1x1 8/0 [r8] (r) [unorm]
[vo/gpu/opengl]   gray16 => 1 planes 1x1 16/0 [r16] (r) [unorm]
[vo/gpu/opengl]   uyvy422
[vo/gpu/opengl]   nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [unorm]
[vo/gpu/opengl]   p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   argb => 1 planes 1x1 8/0 [rgba8] (argb) [unorm]
[vo/gpu/opengl]   bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm]
[vo/gpu/opengl]   abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [unorm]
[vo/gpu/opengl]   rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [unorm]
[vo/gpu/opengl]   bgr24 => 1 planes 1x1 8/0 [rgb8] (bgr) [unorm]
[vo/gpu/opengl]   rgb24 => 1 planes 1x1 8/0 [rgb8] (rgb) [unorm]
[vo/gpu/opengl]   0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [unorm]
[vo/gpu/opengl]   bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm]
[vo/gpu/opengl]   0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [unorm]
[vo/gpu/opengl]   rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [unorm]
[vo/gpu/opengl]   rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [unorm]
[vo/gpu/opengl]   rgb565 => 1 planes 1x1 0/0 [rgb565] (rgb) [unknown]
[vo/gpu/opengl]   pal8
[vo/gpu/opengl]   vdpau
[vo/gpu/opengl]   d3d11
[vo/gpu/opengl]   dxva2_vld
[vo/gpu/opengl]   mmal
[vo/gpu/opengl]   mediacodec
[vo/gpu/opengl]   cuda
[vo/gpu/opengl]   yap8 => 2 planes 1x1 8/0 [r8/r8] (r/a) [unorm]
[vo/gpu/opengl]   yap16 => 2 planes 1x1 16/0 [r16/r16] (r/a) [unorm]
[vo/gpu/opengl]   grayaf32 => 2 planes 1x1 32/0 [r16f/r16f] (r/a) [float]
[vo/gpu/opengl]   yuv444pf => 3 planes 1x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva444pf => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   yuv420pf => 3 planes 2x2 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva420pf => 4 planes 2x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   yuv422pf => 3 planes 2x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva422pf => 4 planes 2x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   yuv440pf => 3 planes 1x2 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva440pf => 4 planes 1x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   yuv410pf => 3 planes 4x4 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva410pf => 4 planes 4x4 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   yuv411pf => 3 planes 4x1 32/0 [r16f/r16f/r16f] (r/g/b) [float]
[vo/gpu/opengl]   yuva411pf => 4 planes 4x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float]
[vo/gpu/opengl]   rgb30 => 1 planes 1x1 10/0 [rgb10_a2] (bgr) [unknown]
[vo/gpu/opengl]   y1 => 1 planes 1x1 8/-7 [r8] (r) [unorm]
[vo/gpu/opengl]   gbrp1 => 3 planes 1x1 8/-7 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp2 => 3 planes 1x1 8/-6 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp3 => 3 planes 1x1 8/-5 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp4 => 3 planes 1x1 8/-4 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp5 => 3 planes 1x1 8/-3 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp6 => 3 planes 1x1 8/-2 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   vdpau_output
[vo/gpu/opengl]   vaapi
[vo/gpu/opengl]   videotoolbox
[vo/gpu/opengl]   vulkan
[vo/gpu/opengl]   drm_prime
[vo/gpu/opengl]   yuyv422
[vo/gpu/opengl]   yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   monow
[vo/gpu/opengl]   monob
[vo/gpu/opengl]   yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   uyyvyy411
[vo/gpu/opengl]   bgr8
[vo/gpu/opengl]   bgr4
[vo/gpu/opengl]   bgr4_byte
[vo/gpu/opengl]   rgb4
[vo/gpu/opengl]   rgb4_byte
[vo/gpu/opengl]   nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [unorm]
[vo/gpu/opengl]   gray16be
[vo/gpu/opengl]   yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[vo/gpu/opengl]   rgb48be
[vo/gpu/opengl]   rgb48 => 1 planes 1x1 16/0 [rgb16] (rgb) [unorm]
[vo/gpu/opengl]   rgb565be
[vo/gpu/opengl]   rgb555be
[vo/gpu/opengl]   bgr565be
[vo/gpu/opengl]   bgr555be
[vo/gpu/opengl]   yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv420p16be
[vo/gpu/opengl]   yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv422p16be
[vo/gpu/opengl]   yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv444p16be
[vo/gpu/opengl]   rgb444
[vo/gpu/opengl]   rgb444be
[vo/gpu/opengl]   bgr444
[vo/gpu/opengl]   bgr444be
[vo/gpu/opengl]   ya8 => 1 planes 1x1 8/0 [rg8] (ra) [unorm]
[vo/gpu/opengl]   bgr48be
[vo/gpu/opengl]   bgr48 => 1 planes 1x1 16/0 [rgb16] (bgr) [unorm]
[vo/gpu/opengl]   yuv420p9be
[vo/gpu/opengl]   yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv420p10be
[vo/gpu/opengl]   yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv422p10be
[vo/gpu/opengl]   yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv444p9be
[vo/gpu/opengl]   yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv444p10be
[vo/gpu/opengl]   yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv422p9be
[vo/gpu/opengl]   yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp9be
[vo/gpu/opengl]   gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp10be
[vo/gpu/opengl]   gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp16be
[vo/gpu/opengl]   gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [unorm]
[vo/gpu/opengl]   yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva420p9be
[vo/gpu/opengl]   yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva422p9be
[vo/gpu/opengl]   yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva444p9be
[vo/gpu/opengl]   yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva420p10be
[vo/gpu/opengl]   yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva422p10be
[vo/gpu/opengl]   yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva444p10be
[vo/gpu/opengl]   yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva420p16be
[vo/gpu/opengl]   yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva422p16be
[vo/gpu/opengl]   yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva444p16be
[vo/gpu/opengl]   yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   xyz12 => 1 planes 1x1 16/4 [rgb16] (rgb) [unorm]
[vo/gpu/opengl]   xyz12be
[vo/gpu/opengl]   nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [unorm]
[vo/gpu/opengl]   nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   nv20be
[vo/gpu/opengl]   rgba64be
[vo/gpu/opengl]   bgra64be
[vo/gpu/opengl]   bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [unorm]
[vo/gpu/opengl]   yvyu422
[vo/gpu/opengl]   ya16be
[vo/gpu/opengl]   ya16 => 1 planes 1x1 16/0 [rg16] (ra) [unorm]
[vo/gpu/opengl]   gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [unorm]
[vo/gpu/opengl]   gbrap16be
[vo/gpu/opengl]   gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[vo/gpu/opengl]   qsv
[vo/gpu/opengl]   d3d11va_vld
[vo/gpu/opengl]   yuv420p12be
[vo/gpu/opengl]   yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv420p14be
[vo/gpu/opengl]   yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv422p12be
[vo/gpu/opengl]   yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv422p14be
[vo/gpu/opengl]   yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv444p12be
[vo/gpu/opengl]   yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv444p14be
[vo/gpu/opengl]   yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   gbrp12be
[vo/gpu/opengl]   gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [unorm]
[vo/gpu/opengl]   gbrp14be
[vo/gpu/opengl]   gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [unorm]
[vo/gpu/opengl]   yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm]
[vo/gpu/opengl]   bayer_bggr8
[vo/gpu/opengl]   bayer_rggb8
[vo/gpu/opengl]   bayer_gbrg8
[vo/gpu/opengl]   bayer_grbg8
[vo/gpu/opengl]   bayer_bggr16
[vo/gpu/opengl]   bayer_bggr16be
[vo/gpu/opengl]   bayer_rggb16
[vo/gpu/opengl]   bayer_rggb16be
[vo/gpu/opengl]   bayer_gbrg16
[vo/gpu/opengl]   bayer_gbrg16be
[vo/gpu/opengl]   bayer_grbg16
[vo/gpu/opengl]   bayer_grbg16be
[vo/gpu/opengl]   yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv440p10be
[vo/gpu/opengl]   yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [unorm]
[vo/gpu/opengl]   yuv440p12be
[vo/gpu/opengl]   ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [unorm]
[vo/gpu/opengl]   ayuv64be
[vo/gpu/opengl]   p010be
[vo/gpu/opengl]   gbrap12be
[vo/gpu/opengl]   gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[vo/gpu/opengl]   gbrap10be
[vo/gpu/opengl]   gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[vo/gpu/opengl]   gray12be
[vo/gpu/opengl]   gray12 => 1 planes 1x1 16/-4 [r16] (r) [unorm]
[vo/gpu/opengl]   gray10be
[vo/gpu/opengl]   gray10 => 1 planes 1x1 16/-6 [r16] (r) [unorm]
[vo/gpu/opengl]   p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p016be
[vo/gpu/opengl]   gray9be
[vo/gpu/opengl]   gray9 => 1 planes 1x1 16/-7 [r16] (r) [unorm]
[vo/gpu/opengl]   gbrpf32be
[vo/gpu/opengl]   gbrpf32 => 3 planes 1x1 32/0 [r16f/r16f/r16f] (g/b/r) [float]
[vo/gpu/opengl]   gbrapf32be
[vo/gpu/opengl]   gbrapf32 => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (g/b/r/a) [float]
[vo/gpu/opengl]   opencl
[vo/gpu/opengl]   gray14be
[vo/gpu/opengl]   gray14 => 1 planes 1x1 16/-2 [r16] (r) [unorm]
[vo/gpu/opengl]   grayf32be
[vo/gpu/opengl]   grayf32 => 1 planes 1x1 32/0 [r16f] (r) [float]
[vo/gpu/opengl]   yuva422p12be
[vo/gpu/opengl]   yuva422p12 => 4 planes 2x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   yuva444p12be
[vo/gpu/opengl]   yuva444p12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm]
[vo/gpu/opengl]   nv24 => 2 planes 1x1 8/0 [r8/rg8] (r/gb) [unorm]
[vo/gpu/opengl]   nv42 => 2 planes 1x1 8/0 [r8/rg8] (r/bg) [unorm]
[vo/gpu/opengl]   y210be
[vo/gpu/opengl]   x2rgb10be
[vo/gpu/opengl]   x2bgr10
[vo/gpu/opengl]   x2bgr10be
[vo/gpu/opengl]   p210be
[vo/gpu/opengl]   p210 => 2 planes 2x1 16/6 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p410be
[vo/gpu/opengl]   p410 => 2 planes 1x1 16/6 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p216be
[vo/gpu/opengl]   p216 => 2 planes 2x1 16/0 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p416be
[vo/gpu/opengl]   p416 => 2 planes 1x1 16/0 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   vuya => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm]
[vo/gpu/opengl]   rgbaf16be
[vo/gpu/opengl]   vuyx => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm]
[vo/gpu/opengl]   p012 => 2 planes 2x2 16/4 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p012be
[vo/gpu/opengl]   y212be
[vo/gpu/opengl]   xv30be
[vo/gpu/opengl]   xv36be
[vo/gpu/opengl]   xv36 => 1 planes 1x1 16/4 [rgba16] (grb) [unorm]
[vo/gpu/opengl]   rgbf32be
[vo/gpu/opengl]   rgbaf32be
[vo/gpu/opengl]   p212be
[vo/gpu/opengl]   p212 => 2 planes 2x1 16/4 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   p412be
[vo/gpu/opengl]   p412 => 2 planes 1x1 16/4 [r16/rg16] (r/gb) [unorm]
[vo/gpu/opengl]   gbrap14be
[vo/gpu/opengl]   gbrap14 => 4 planes 1x1 16/-2 [r16/r16/r16/r16] (g/b/r/a) [unorm]
[vo/gpu/opengl]   d3d12
[vo/gpu] Resizing texture: 16x16
[global] cache path: '' -> '/home/roberto/.cache/mpv'
[vd] Container reported FPS: 25.000000
[vd] Codec list:
[vd] Using software decoding.
[vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vf]   (empty)
[cplayer] Run command: define-section, flags=64, args=[name="input_osc", contents="", flags="default"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_osc", flags="allow-hide-cursor+allow-vo-dragging"]
[cplayer] Run command: define-section, flags=64, args=[name="input_forced_osc", contents="", flags="force"]
[cplayer] Run command: enable-section, flags=64, args=[name="input_forced_osc", flags="allow-hide-cursor+allow-vo-dragging"]
[osd/libass] libass API version: 0x1703000
[osd/libass] libass source: tarball: 0.17.3
[osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX)
[osd/libass] Setting up fonts...
[osd/libass] Using font provider fontconfig
[osd/libass] Done.
[osc] osc_init
[ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: yuv420p
[vd] DR parameter change to 1920x1090 yuv420p align=64
[vd] Allocating new (host-cached) DR image...
[vd] ...failed..
[vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1920x1080+0+0
[vo/gpu] max content size: 1920x1080
[vo/gpu] monitor size: 1920x1080
[vo/gpu] Resizing texture: 960x540
[vo/gpu] Trying to load shader from disk...
[vo/gpu/opengl] Loading binary program succeeded.
[vo/gpu] Resizing texture: 960x1080
[vo/gpu] Resizing texture: 1920x1080
[vo/gpu] Resizing texture: 1920x1025
[cplayer] starting video playback
[cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1
[osc] osc_init
[cplayer] Run command: quit, flags=73, args=[code="0"]
[vd] Uninit decoder.
[cplayer] Terminating demuxers...
[cplayer] Done terminating demuxers.
[statusline] V: 00:00:01 / 00:02:24 (1%) Dropped: 28
[cplayer] Running hook: ytdl_hook/on_after_end_file
[cplayer] Run command: del, flags=64, args=[name="user-data/mpv/ytdl/json-subprocess-result"]
[osc] osc_init
[cplayer] Run command: del, flags=64, args=[name="user-data/mpv/console"]
[ytdl_hook] Destroying client handle...
[commands] Destroying client handle...
[positioning] Destroying client handle...
[stats] Destroying client handle...
[select] Destroying client handle...
[console] Destroying client handle...
[cplayer] Run command: del, flags=64, args=[name="user-data/osc"]
[osc] Destroying client handle...
[vo/gpu] flushing shader cache
[vo/gpu/x11] uninit ...
For reference, mpv log in Bookworm:
Spoiler
bookworm, fluid full fps, almost no dropped frames
[cplayer] FFmpeg library versions:
[cplayer]
[global] config path: '' -> '/home/roberto/.config/mpv'
[cplayer] Reading config file /etc/mpv/encoding-profiles.conf
[cplayer] Applying profile 'default'...
[cplayer] Reading config file /etc/mpv/mpv.conf
[cplayer] Setting option 'hwdec' = 'drm' (flags = 4)
[cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4)
[cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4)
[cplayer] Setting option 'v' = '' (flags = 😎
[cplayer] Waiting for scripts...
[auto_profiles] Exiting...
[osd/libass] ASS library version: 0x1701000 (runtime 0x1701000)
[osd/libass] Done.
[cplayer] Run command: define-section, flags=64, args=[name="input", contents="mbtn_left script-binding osc/__keybinding5\nshift+mbtn_left script-binding osc/__keybinding6\nmbtn_right script-binding osc/__keybinding7\nmbtn_mid script-binding osc/__keybinding8\nwheel_up script-binding osc/__keybinding9\nwheel_down script-binding osc/__keybinding10\nmbtn_left_dbl ignore\nshift+mbtn_left_dbl ignore\nmbtn_right_dbl ignore\n", flags="force"]
[cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-visibility=auto"]
[cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"]
[cplayer] Done loading scripts.
[global] config path: 'watch_later' -> '/home/roberto/.config/mpv/watch_later'
[cplayer] Running hook: ytdl_hook/on_load
[osc] osc_init
[demux] Trying demuxers for level=normal.
[osd/libass] Done.
[lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[find_files] Loading external files in .
[cplayer] Running hook: ytdl_hook/on_preloaded
[osc] osc_init
[lavf] select track 0
[cplayer]  (+) Video --vid=1 (*) (h264 1920x1080 25.000fps)
[vo/gpu] Probing for best GPU context.
[vo/gpu/opengl] Initializing GPU context 'wayland'
[vo/gpu/opengl] Initializing GPU context 'x11egl'
[vo/gpu/x11] X11 opening display: :0.0
[vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS
[vo/gpu/x11] Current display FPS: 60.000000
[vo/gpu/opengl] EGL_VENDOR=Mesa Project
[vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[vo/gpu/opengl] Trying to create Desktop OpenGL context.
[vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21
[vo/gpu/x11] The XPresent extension was found.
[vo/gpu/opengl] Detected desktop OpenGL 3.1.
[vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)'
[vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40'
[vo/gpu/opengl] EGL_ANDROID_blob_cache EGL_CHROMIUM_sync_control EGL_ANGLE_sync_control_rate EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_swap_buffers_with_damage EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_partial_update EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_NOK_texture_from_pixmap  GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_EGL_image_storage GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_debug_label GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_image_load_formatted GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_RG8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_INTEL_blackhole_render GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_image GL_NV_depth_clamp GL_NV_fog_distance GL_NV_half_float GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
[vo/gpu/opengl] Loaded extension GL_ARB_sync.
[vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata.
[vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary.
[vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object.
[vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays.
[vo/gpu/opengl] Loaded extension GL_ARB_debug_output.
[vo/gpu/opengl] Loaded extension GL_KHR_debug.
[vo/gpu/opengl]   qsv
[vo/gpu/opengl]   xvmc
[vo/gpu] Testing FBO format rgba16f
[vo/gpu] Using FBO format rgba16f.
[vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1).
[vo/gpu] No advanced processing required. Enabling dumb mode.
[vo/gpu] Assuming 60.000000 FPS for display sync.
[vd] Codec list:
[ffmpeg] AVHWDeviceContext: Opened DRM device /dev/dri/renderD128: driver panfrost version 1.3.0.
[vf] User filter list:
[vf]   (empty)
[cplayer] Starting playback...
[ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: drm_prime
[vf] [userdeint] (disabled)
[vf] [autorotate] (disabled)
[vf] [convert] (disabled)
[cplayer] VO: Description: Shader-based GPU Renderer
[vo/gpu/x11] not waiting for MapNotify
[vo/gpu] Resize: 1920x1025
[vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 1920x1080 (1:1)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025
[vo/gpu] Video scale: 0.948958/0.949074
[vo/gpu] OSD borders: l=49 t=0 r=49 b=0
[vo/gpu] Video borders: l=49 t=0 r=49 b=0
[vo/gpu] Reported display depth: 8
[vo/gpu/opengl] vertex shader source:
[vo/gpu/opengl] [  1] #version 140
[vo/gpu/opengl] [  2] #define tex1D texture
[vo/gpu/opengl] [  3] #define tex3D texture
[vo/gpu/opengl] [  4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x))
[vo/gpu/opengl] [  5] in vec2 vertex_position;
[vo/gpu/opengl] [  6] in vec2 vertex_texcoord0;
[vo/gpu/opengl] [  7] out vec2 texcoord0;
[vo/gpu/opengl] [  8] in vec2 vertex_texcoord1;
[vo/gpu/opengl] [  9] out vec2 texcoord1;
[vo/gpu/opengl] [ 10] void main() {
[vo/gpu/opengl] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0);
[vo/gpu/opengl] [ 12] texcoord0 = vertex_texcoord0;
[vo/gpu/opengl] [ 13] texcoord1 = vertex_texcoord1;
[vo/gpu/opengl] [ 14] }
[vo/gpu/opengl] fragment shader source:
[vo/gpu/opengl] [  5] out vec4 out_color;
[vo/gpu/opengl] [  6] in vec2 texcoord0;
[vo/gpu/opengl] [  7] in vec2 texcoord1;
[vo/gpu/opengl] [  8] uniform mat3 colormatrix;
[vo/gpu/opengl] [  9] uniform vec3 colormatrix_c;
[vo/gpu/opengl] [ 10] uniform vec3 src_luma;
[vo/gpu/opengl] [ 11] uniform vec3 dst_luma;
[vo/gpu/opengl] [ 12] uniform sampler2D texture0;
[vo/gpu/opengl] [ 13] uniform vec2 texture_size0;
[vo/gpu/opengl] [ 14] uniform mat2 texture_rot0;
[vo/gpu/opengl] [ 15] uniform vec2 texture_off0;
[vo/gpu/opengl] [ 16] uniform vec2 pixel_size0;
[vo/gpu/opengl] [ 17] uniform sampler2D texture1;
[vo/gpu/opengl] [ 18] uniform vec2 texture_size1;
[vo/gpu/opengl] [ 19] uniform mat2 texture_rot1;
[vo/gpu/opengl] [ 20] uniform vec2 texture_off1;
[vo/gpu/opengl] [ 21] uniform vec2 pixel_size1;
[vo/gpu/opengl] [ 22] void main() {
[vo/gpu/opengl] [ 23] vec4 color = vec4(0.0, 0.0, 0.0, 1.0);
[vo/gpu/opengl] [ 24] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r;
[vo/gpu/opengl] [ 25] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg;
[vo/gpu/opengl] [ 26] color = color.rgbr;
[vo/gpu/opengl] [ 27] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c;
[vo/gpu/opengl] [ 28] color.a = 1.0;
[vo/gpu/opengl] [ 29] // color mapping
[vo/gpu/opengl] [ 30] color.rgb *= vec3(1.000000);
[vo/gpu/opengl] [ 31] color.rgb *= vec3(1.000000);
[vo/gpu/opengl] [ 32] out_color = color;
[vo/gpu/opengl] [ 33] }
[vo/gpu/opengl] shader link log (status=1):
[cplayer] first video frame after restart shown
[cplayer] playback restart complete @ 0.000000, audio=eof, video=playing
[vo/gpu/x11] Disabling screensaver.
[statusline] V: 00:00:00 / 00:02:24 (0%)
[cplayer] Set property: shared-script-properties -> 1
[osc] osc_init
[statusline] V: 00:00:06 / 00:02:24 (4%)
[cplayer] EOF code: 5
[cplayer] finished playback, success (reason 3)
[cplayer]
[cplayer] Exiting... (Quit)
[console] Exiting...
[cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="remove", value="osc-margins"]
[ytdl_hook] Exiting...
[stats] Exiting...
[osc] Exiting...
[vo/gpu/x11] Enabling screensaver.
I inspected ffmpeg build configuration, and I see that ffmpeg 7.1.1 doesn't have "--enable-libv4l2", while ffmpeg 5.1.6 has that option.
I checked with "ffmpeg -codecs|grep h264"
In bookworm:
Spoiler
bookworm
roberto@orangepizero3:~$ ffmpeg -codecs|grep h264
ffmpeg version 5.1.6-0+deb12u1 Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 12 (Debian 12.2.0-14)
  configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-v4l2-request --enable-v4l2-m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
  libavutil      57. 28.100 / 57. 28.100
  libavcodec     59. 37.100 / 59. 37.100
  libavformat    59. 27.100 / 59. 27.100
  libavdevice    59.  7.100 / 59.  7.100
  libavfilter     8. 44.100 /  8. 44.100
  libswscale      6.  7.100 /  6.  7.100
  libswresample   4.  7.100 /  4.  7.100
  libpostproc    56.  6.100 / 56.  6.100
 DEV.LS h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_cuvid ) (encoders: libx264 libx264rgb h264_nvenc h264_omx h264_v4l2m2m h264_vaapi )
In trixie
Spoiler
trixie
ffmpeg version 7.1.1-1 Copyright (c) 2000-2025 the FFmpeg developers
  built with gcc 14 (Debian 14.2.0-19)
  configuration: --prefix=/usr --extra-version=1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --disable-libmfx --disable-omx --enable-gnutls --enable-libaom --enable-libass --enable-libbs2b --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libharfbuzz --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-v4l2-request --enable-v4l2_m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-openal --enable-opencl --enable-opengl --disable-sndio --disable-libvpl --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-ladspa --enable-libbluray --enable-libcaca --enable-libdvdnav --enable-libdvdread --enable-libjack --enable-libpulse --enable-librabbitmq --enable-librist --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libx264 --enable-libzmq --enable-libzvbi --enable-lv2 --enable-sdl2 --enable-libplacebo --enable-librav1e --enable-pocketsphinx --enable-librsvg --enable-libjxl --enable-shared
  libavutil      59. 39.100 / 59. 39.100
  libavcodec     61. 19.101 / 61. 19.101
  libavformat    61.  7.100 / 61.  7.100
  libavdevice    61.  3.100 / 61.  3.100
  libavfilter    10.  4.100 / 10.  4.100
  libswscale      8.  3.100 /  8.  3.100
  libswresample   5.  3.100 /  5.  3.100
  libpostproc    58.  3.100 / 58.  3.100
 DEV.LS h264                 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_cuvid) (encoders: libx264 libx264rgb h264_nvenc h264_v4l2m2m h264_vaapi h264_vulkan)
Although, here the ffmpeg manual reads that this is option is only for webcams and videocapture
https://www.ffmpeg.org/ffmpeg-devices.html#video4linux2_002c-v4l2
Unfortunately an added challenge of the older SOC (A10, A13 & A20) generation is a limitation of the video engine which can only access the first 256MB of DRAM. I have tested this and found that the system becomes unresponsive as soon as we attempt media playback which confirms this is true.
I dont yet know how it works under the hood but probably a similiar mechanism to how the kernel parses the dts in order to know what modules to load during the boot process. Allocation and ranges are set within the memory reserved node.
reserved-memory {
		#address-cells = <1>;
		#size-cells = <1>;
		ranges;
		/* Address must be kept in the lower 256 MiBs of DRAM for VE. */
		default-pool {
			compatible = "shared-dma-pool";
			size = <0x6000000>;
			alloc-ranges = <0x40000000 0x10000000>;
			reusable;
			linux,cma-default;
I have also tried increasing via overlay but it seems anything larger than 96MB gets disassociated from the dma pool. The first address that gets allocated is 0x4a000000. Trying via the extraargs method to specify a lower start address fails. Looks like the display buffers take a chunk out of CMA as well.
Monitor disconnected:
ryan@pcduino2-2:~$ cat /proc/meminfo | grep Cma
CmaTotal:          98304 kB
CmaFree:           98008 kB
Monitor connected:
CmaTotal:          98304 kB
CmaFree:           89780 kB
If I attempt to fast forward, playback falls back to software decoding and I get these errors in the log:
[  596.444060] cma: __cma_alloc: reserved: alloc failed, req-size: 1024 pages, ret: -16
[  596.444103] cma: number of available pages:
[  596.444110] cma: range 0: 3@109+56@128+64@192+23@2281+8@4344+162@5726+162@7262+162@8798+162@10334+162@11870+162@ 13406+8@15608+8@17656+8@19704+162@21086+162@22622+418@24158
[  596.444254] cma:
[  596.454008] cma: __cma_alloc: reserved: alloc failed, req-size: 350 pages, ret: -16
[  596.454045] cma: number of available pages:
l: [  596.454052] cma: range 0: 3@109+56@128+64@192+23@2281+8@4344+162@5726+162@7262+162@8798+162@10334+162@11870+162@
I got hardware acceleration working in wayland+labwc, in Bookworm, Linux 6.15.4, self built armbian
With a self-compiled labwc (instructions: https://forum.armbian.com/topic/53797-labwc-wayland-crashes-on-exit/#findComment-223267 )
And the ffmpeg instructions in the original post were used with no changes... plus the extraargs=cma=256M in armbianEnv.txt
Side question: can anybody make hardware acceleration work in Trixie?
Unfortunately, lxc containers are not supplied anymore for armhf targets (see https://github.com/lxc/lxc-ci/commit/8d7326930f824a0aeedb6be3598c64e9e9a6ce36, I read somewhere the build machine has no 32bit compatibility anymore), hence building ffmpeg on Debian Trixie for armhf (32 bits) requires some more trickery.
50 minutes ago, robertoj said:
but my use case is orange pi zero 3 and orange pi zero 2w… they are 64 bit H618
Then Trixie arm64 is already supported
BTW: just managed to use a trixie armhf armbian rootfs as a rootfs container for lxc... it just works, so packages are coming for trixie armhf too 😁
edit: trixie armhf packages added!
On 7/31/2025 at 11:56 PM, robertoj said:
Thank you... I will try with trixie again some time
It looks like mpv does not work anymore with v4l2request on trixie.
Benchmarking with ffmpeg reports very high framerate on a 1080p h.265 video, but mpv refuses to work when --hwdec=v4l2request is chosen. It says a generic [vd] Could not create device. message in the log and switches to software rendering.
Parameter --hwdec=v4l2request-copy works though, despite being slow because it involves framebuffer copy.
What is the difference between --hwdec=v4l2request and --hwdec=drm ? And drmprimedrmprime_overlay, and auto?
Is the v4l2request absent from Trixie's mpv, due to a pre-compile configuration, or was it removed from the mpv source code?
@robertoj --hwdec=v4l2request seems present on mpv v0.40, which is the one in trixie. Older mpv versions have --hwdec=drm; I don't know the differences, but I guess drm become v4l2request at some point.
--gpu-hwdec-interop=drmprime-overlay directly presents the frames using an hardware overlay. It is very useful if you want to go fullscreen (like on a virtual terminal), but if you are running a desktop environment, everything behind the video overlay will be hidden.
--gpu-hwdec-interop=drmprime instead uses the linux facilities (dmabuf) to transfer the decoded frames from the hardware decoder buffer to the EGL/OpenGL (or whatever) presentation layer without actually copying the buffer data, but just passing a file handler. It is more complex and has more overhead, but it is suitable to be used within a desktop environment because the frames are drawn in regular windows.
--gpu-hwdec-interop=auto don't know, I guess mpv does some guessing to decide which one is the best.
Has anybody had success with ffmpeg-v4l2request under Debian TRIXIE?
I have seen successful reports from Jammy and Noble users... are they still having success?
From my tests, ffmpeg works fine with hardware acceleration under Debian Trixie, but packaged mpv (AFAIR it is v0.4.0) does always fails hardware decoding.
Device: Opi5-Plus.  Have the same issue on Debian-Trixie kernel-6.16.8-edge-rockchip64 mpv (0.40.0_ deos not support vpu hardware acceleration.  mpv --hwdec=v4l2request-copy is too slow to decode 4K/60 video, very high dropped frames.
mpv --hwdec=v4l2request '/media/jfl/writable/home/jfl/Videos/Two Steps From Hell - Unleashed-15ZqpVOjZEc.mp4'
● Video  --vid=1               (h264 1920x1080 60 fps) [default]
● Audio  --aid=1  --alang=eng  (aac 2ch 44100 Hz 128 kbps) [default]
AO: [pipewire] 44100Hz stereo 2ch floatp
VO: [gpu] 1920x1080 yuv420p
AV: 00:00:04 / 00:05:41 (1%) A-V:  0.000
Exiting... (Quit)
The is a mpv-full-git version @junari had build for arch linux which support v4l2request.  The PKGBUILD
https://github.com/iuncuim/manjaro-h616/blob/main/mpv-v4l2request/PKGBUILD
Don't have experience to compile or build packages for Linux.  Experience Armbian users and developers might be able to build the mpv-full-git for Debian Trixie.
mainline support for rk3588 is still incomplete. If you need vpu stuff mostly work you need to use vendor kernel which is based on rockchip bsp.
