robertoj Posted July 18 Posted July 18 (edited) I have tried again with orange pi zero 3, debian trixie linux edge, xfce desktop. This time, I tried without compositor. I ran this from SSH, as my user: killall xfwm4 && xfwm4 --compositor=off & I got: (xfwm4:7880): Gtk-WARNING **: 10:45:56.629: cannot open display: Then I tried "killall xfwm4 && xfwm4 --compositor=off --display :0.0 &" and there were no errors. The orange transparent effect when moving windows is now a white line rectangle Then, mpv played my 1080p mp4 with low framerate (slow motion, 75% of speed)... sometimes with 100% CPU and sometimes with 25% CPU I noticed this in the log (both high and low CPU cases) [vd] Unsupported hwdec: drm [vd] Using software decoding. With high CPU: [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 With 25% CPU: [cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1 Whole log (low CPU case): (Mpv.conf at the bottom) Spoiler LOW CPU roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v videofile.mp4 [cplayer] Command line options: '-v' 'videofile.mp4' [cplayer] mpv v0.40.0 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.1-1+b1 (runtime 7.1.1-1) [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: -Dpython.bytecompile=-1 -Dlibmpv=true -Dbuild-date=false -Dcdda=enabled -Ddvdnav=enabled -Dsdl2=enabled -Ddvbin=enabled -Dprefix=/usr -Dlibdir=lib/aarch64-linux-gnu -Dlocalstatedir=/var -Dsysconfdir=/etc -Dbuildtype=plain -Dwrap_mode=nodownload [cplayer] List of enabled features: alsa caca cdda cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg ffnvcodec gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel sndio sndio-1-9 uchardet vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 x11 xv zimg zimg-st428 zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [ifo_dvdnav] Opening /etc/mpv/encoding-profiles.conf [bdmv/bluray] Opening /etc/mpv/encoding-profiles.conf [file] Opening /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [ifo_dvdnav] Opening /etc/mpv/mpv.conf [bdmv/bluray] Opening /etc/mpv/mpv.conf [file] Opening /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [clipboard] Initialized vo clipboard backend. [cplayer] Waiting for scripts... [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook. [cplayer] Running hook: auto_profiles/on_load [cplayer] Failed sending hook command auto_profiles/on_load. Removing hook. [cplayer] Running hook: ytdl_hook/on_load [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] playlist hook [ifo_dvdnav] Opening videofile.mp4 [bdmv/bluray] Opening videofile.mp4 [file] Opening videofile.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: videofile.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Running hook: auto_profiles/on_preloaded [cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook. [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] ● Video --vid=1 (av1 1920x1080 30 fps) [default] [vo/gpu] Probing for best GPU context. [vo/gpu/auto] Initializing GPU context 'auto' [vo/gpu/vulkan] Initializing GPU context 'waylandvk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_wayland_surface [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/vulkan] Initializing GPU context 'x11vk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_xlib_surface [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.5 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent enabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.5-2' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Mesa' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 30.000000 [vd] Codec list: [vd] libdav1d (av1) - dav1d AV1 decoder by VideoLAN [vd] libaom-av1 (av1) - libaom AV1 [vd] av1 - Alliance for Open Media AV1 [vd] av1_cuvid (av1) - Nvidia CUVID AV1 decoder [vd] Opening decoder libdav1d [vd] Unsupported hwdec: drm [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected decoder: libdav1d - dav1d AV1 decoder by VideoLAN [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=unknown crop=1920x1080+0+0 [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Dither to 8. [cplayer] first video frame after restart shown [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu/x11] Disabling screensaver. [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 [cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1 ... roberto@orangepizero3:~$ cat /etc/mpv/mpv.conf hwdec=drm drm-drmprime-video-plane=primary drm-draw-plane=overlay Another sanity check: Spoiler roberto@orangepizero3:~$ uname -a Linux orangepizero3 6.15.4-edge-sunxi64 #2 SMP Fri Jun 27 10:13:43 UTC 2025 aarch64 GNU/Linux roberto@orangepizero3:~$ apt list libav*|grep v4l2 WARNING: apt does not have a stable CLI interface. Use with caution in scripts. libavcodec-dev/trixie 7:7.1.1-1-v4l2request1 arm64 libavcodec-extra61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavcodec-extra61/trixie 7:7.1.1-1-v4l2request1 arm64 libavcodec-extra/trixie 7:7.1.1-1-v4l2request1 arm64 libavcodec61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavcodec61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic] libavdevice-dev/trixie 7:7.1.1-1-v4l2request1 arm64 libavdevice61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavdevice61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic] libavfilter-dev/trixie 7:7.1.1-1-v4l2request1 arm64 libavfilter-extra10-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavfilter-extra10/trixie 7:7.1.1-1-v4l2request1 arm64 libavfilter-extra/trixie 7:7.1.1-1-v4l2request1 arm64 libavfilter10-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavfilter10/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic] libavformat-dev/trixie 7:7.1.1-1-v4l2request1 arm64 libavformat-extra61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavformat-extra61/trixie 7:7.1.1-1-v4l2request1 arm64 libavformat-extra/trixie 7:7.1.1-1-v4l2request1 arm64 libavformat61-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavformat61/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic] libavutil-dev/trixie 7:7.1.1-1-v4l2request1 arm64 libavutil59-dbgsym/trixie 7:7.1.1-1-v4l2request1 arm64 libavutil59/trixie,now 7:7.1.1-1-v4l2request1 arm64 [installed,automatic] Ryzer, did you turn the compositor off? Are you using an armbian-downloaded OS, or self built? What kernel version? DId you change anything in the linux menuconfig? I am recompiling again, having checked again that the new linux patches are taken.... how could I check that my current Linux kernel has the new v4l2, cedrus functions? Then I will try again with Bookworm Edited July 19 by robertoj 0 Quote
robertoj Posted July 19 Posted July 19 (edited) I have tried again with trixie, ensuring that the kernel patches were taken... no difference. Then I build a Bookworm Armbian image, with linux 6.15.4. It wasn't visible wether the kernel was downloaded from armbian, or the last one was included in my OS image. Just for fun, I tried it with Bookworm's default ffmpeg-5.1.6, with xfce with compositor off... and I got a 1080p MP4 playing with 100% mpv log: Spoiler bookworm without compositor, linux 6.15.4, default ffmpeg roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v videofile.mp4 [cplayer] Command line options: '-v' 'videofile.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening videofile.mp4 [bdmv/bluray] Opening videofile.mp4 [file] Opening videofile.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: videofile.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Set property: shared-script-properties -> 1 [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (av1 1920x1080 30.000fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 30.000000 [vd] Codec list: [vd] libdav1d (av1) - dav1d AV1 decoder by VideoLAN [vd] libaom-av1 (av1) - libaom AV1 [vd] av1 - Alliance for Open Media AV1 [vd] av1_cuvid (av1) - Nvidia CUVID AV1 decoder [vd] Opening decoder libdav1d [vd] Unsupported hwdec: drm [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [ffmpeg/video] libdav1d: libdav1d 1.0.0 [vd] Selected codec: libdav1d (dav1d AV1 decoder by VideoLAN) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=unknown [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] Set property: shared-script-properties -> 1 [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu/x11] not waiting for MapNotify [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [cplayer] first video frame after restart shown [vo/gpu/x11] Disabling screensaver. [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [statusline] V: 00:00:00 / 00:04:49 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:08 / 00:04:49 (3%) Dropped: 47 [cplayer] Set property: fullscreen -> 1 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [statusline] V: 00:00:08 / 00:04:49 (3%) Dropped: 47 [vo/gpu] Resize: 1920x1080 [vo/gpu] Window size: 1920x1080 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080 [vo/gpu] Video scale: 1.000000/1.000000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:08 / 00:04:49 (3%) Dropped: 47 [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:08 / 00:04:49 (3%) Dropped: 47 [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:26 / 00:04:49 (9%) Dropped: 150 [cplayer] EOF code: 5 [vo/gpu/x11] Enabling screensaver. [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 ... roberto@orangepizero3:~$ apt list ffmpeg Listing... Done ffmpeg/stable,stable-security,now 7:5.1.6-0+deb12u1 arm64 [installed] roberto@orangepizero3:~$ apt list libavcodec59 Listing... Done libavcodec59/stable,stable-security,now 7:5.1.6-0+deb12u1 arm64 [installed,automatic] Note that mpv still complains about unsupported hwdec: drm I repeated the test with compositor ON: killall xfwm4 && xfwm4 --compositor=on --display :0.0 & Same result: CPU 100%, but nice full FPS video Then I tried with the ffmpeg-x.x.x-v4l2 request Adding the repo, updating, and checking the update: Spoiler roberto@orangepizero3:~$ apt list --upgradable Listing... Done ffmpeg/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libavcodec59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libavdevice59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libavfilter8/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libavformat59/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libavutil57/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libpostproc56/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libswresample4/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] libswscale6/bookworm 7:5.1.6-0+deb12u1-v4l2request1 arm64 [upgradable from: 7:5.1.6-0+deb12u1] roberto@orangepizero3:~$ sudo apt upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: ffmpeg libavcodec59 libavdevice59 libavfilter8 libavformat59 libavutil57 libpostproc56 libswresample4 libswscale6 9 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 11.8 MB of archives. After this operation, 66.6 kB of additional disk space will be used. Do you want to continue? [Y/n] Y ... the 9 ffmpeg packages get installed with no problem Then I tried playing the mp4, I got no complaint about "unsupported hwdec: drm", but the CPU was still 100% For the first time, I get some video glitches when I resize, and repeated messages: Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory compositor=on or off doesn't make a difference for me. mpv log: Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v videofile.mp4 [cplayer] Command line options: '-v' 'videofile.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening videofile.mp4 [bdmv/bluray] Opening videofile.mp4 [file] Opening videofile.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: videofile.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (av1 1920x1080 30.000fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 30.000000 [vd] Codec list: [vd] libdav1d (av1) - dav1d AV1 decoder by VideoLAN [vd] libaom-av1 (av1) - libaom AV1 [vd] av1 - Alliance for Open Media AV1 [vd] av1_cuvid (av1) - Nvidia CUVID AV1 decoder [vd] Opening decoder libdav1d [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [ffmpeg/video] libdav1d: libdav1d 1.0.0 [vd] Selected codec: libdav1d (dav1d AV1 decoder by VideoLAN) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [cplayer] Set property: shared-script-properties -> 1 [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=unknown [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] Set property: shared-script-properties -> 1 [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu/x11] not waiting for MapNotify [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [cplayer] first video frame after restart shown [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [statusline] V: 00:00:00 / 00:04:49 (0%) [vo/gpu/x11] Disabling screensaver. [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:00 / 00:04:49 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:16 / 00:04:49 (6%) Dropped: 216 [cplayer] EOF code: 5 [vo/gpu/x11] Enabling screensaver. [vf] dropping frame due to pin disconnect [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 Summary: Armbian Trixie (and the correspoinding ffmpeg 7.1.1) will always result in "unsupported hwdec: drm", with default ffmpeg, or ffmpeg-v4l2 request Armbian Bookworm (ffmpeg 5.1.6) will never complain about "unsupported hwdec: drm", with default ffmpeg or ffmpeg-v4l2request. Still 100% CPU Edited July 19 by robertoj 0 Quote
usual user Posted July 19 Posted July 19 4 hours ago, robertoj said: [vd] Codec list: [vd] libdav1d (av1) - dav1d AV1 decoder by VideoLAN [vd] libaom-av1 (av1) - libaom AV1 [vd] av1 - Alliance for Open Media AV1 [vd] av1_cuvid (av1) - Nvidia CUVID AV1 decoder [vd] Opening decoder libdav1d [vd] No hardware decoding available for this codec. Just out of curiosity, you are trying to play content that is encoded in AV1. Are you sure that your device is equipped with an AV1 decoder IP and that the kernel has the appropriate driver? 0 Quote
robertoj Posted July 19 Posted July 19 (edited) 12 hours ago, usual user said: Just out of curiosity, you are trying to play content that is encoded in AV1. Are you sure that your device is equipped with an AV1 decoder IP and that the kernel has the appropriate driver? You are right. I just downloaded something from youtube and assumed it was H264. When I checked it in VLC in my PC, the codec is: AOMedia's AV1 video (av01) I picked another mp4, which I verified in VLC as H264-MPEG4, 720p, and it played with 10% CPU This test below is with Bookworm XFCE, compositor ON, Linux 6.15.4 with default configuration Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v donde\ venderan\ buen\ trago\ 720p.mp4 [cplayer] Command line options: '-v' 'donde venderan buen trago 720p.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening donde venderan buen trago 720p.mp4 [bdmv/bluray] Opening donde venderan buen trago 720p.mp4 [file] Opening donde venderan buen trago 720p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: donde venderan buen trago 720p.mp4 [find_files] Loading external files in . [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [lavf] select track 1 [cplayer] (+) Video --vid=1 (*) (h264 1280x720 29.970fps) [cplayer] (+) Audio --aid=1 --alang=eng (*) (aac 2ch 44100Hz) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-drm... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] using EGL dmabuf interop [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [vd] Trying hardware decoding via h264-drm. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [ad] Codec list: [ad] aac - AAC (Advanced Audio Coding) [ad] aac_fixed (aac) - AAC (Advanced Audio Coding) [ad] Opening decoder aac [ad] Requesting 1 threads for decoding. [ad] Selected codec: aac (AAC (Advanced Audio Coding)) [af] User filter list: [af] (empty) [cplayer] Starting playback... [af] [in] 44100Hz stereo 2ch floatp [af] [userspeed] 44100Hz stereo 2ch floatp [af] [userspeed] (disabled) [af] [convert] 44100Hz stereo 2ch floatp [vd] Pixel formats supported by decoder: vdpau cuda vaapi drm_prime yuv420p [vd] Codec profile: Main (0x4d) [vd] Requesting pixfmt 'drm_prime' from decoder. [vd] Using hardware decoding (drm). [vd] Decoder format: 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vd] Using container aspect ratio. [vf] [in] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [ao] Trying audio driver 'pipewire' [ao/pipewire] requested format: 44100 Hz, stereo channels, floatp [ao/pipewire] Headers version: 0.3.65 [ao/pipewire] Library version: 0.3.65 [W][00618.325296] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][00618.325551] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory [ao] Trying audio driver 'pulse' [ao/pulse] requested format: 44100 Hz, stereo channels, floatp [ao/pulse] Library version: 16.1.0 [ao/pulse] Proto: 35 [ao/pulse] Server proto: 4294967295 [ao/pulse] Channel layouts: [ao/pulse] - #fl [ao/pulse] - #fr [ao/pulse] - #fc [ao/pulse] - #lfe [ao/pulse] - #bl [ao/pulse] - #br [ao/pulse] - #flc [ao/pulse] - #frc [ao/pulse] - #bc [ao/pulse] - #sl [ao/pulse] - #sr [ao/pulse] - #tc [ao/pulse] - #tfl [ao/pulse] - #tfc [ao/pulse] - #tfr [ao/pulse] - #tbl [ao/pulse] - #tbc [ao/pulse] - #tbr [ao/pulse] result: stereo [ao/pulse] device buffer: 6172 samples. [ao/pulse] using soft-buffer of 8820 samples. [cplayer] AO: [pulse] 44100Hz stereo 2ch float [cplayer] AO: Description: PulseAudio audio output [autoconvert] inserting resampler [swresample] format change, reinitializing resampler [swresample] 44100Hz stereo floatp -> 44100Hz stereo float [af] [out] 44100Hz stereo 2ch float [cplayer] VO: [gpu] 1280x720 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1280x720 [vo/gpu] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1280x720 (1:1) [vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720 [vo/gpu] Video scale: 1.000000/1.000000 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [cplayer] first video frame after restart shown [cplayer] Set property: shared-script-properties -> 1 [cplayer] audio ready [cplayer] starting audio playback [cplayer] playback restart complete @ 0.000000, audio=playing, video=playing [vo/gpu/x11] Disabling screensaver. [ao/pulse] starting AO DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource [cplayer] Set property: shared-script-properties -> 1 DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource [statusline] AV: 00:00:04 / 00:04:18 (2%) A-V: 0.000 [cplayer] Set property: shared-script-properties -> 1 [statusline] AV: 00:00:04 / 00:04:18 (2%) A-V: 0.000 [osd/libass] fontselect: (sans-serif, 400, 0) -> /usr/share/fonts/truetype/dejavu/DejaVuSans.ttf, 0, DejaVuSans [osd/libass] fontselect: (mpv-osd-symbols, 400, 0) -> mpv-osd-symbols-Regular, 0, mpv-osd-symbols-Regular [vo/gpu] Reallocating OSD texture to 2048x256. [statusline] AV: 00:00:05 / 00:04:18 (2%) A-V: 0.000 [cplayer] Set property: shared-script-properties -> 1 [statusline] AV: 00:00:08 / 00:04:18 (3%) A-V: 0.000 Dropped: 2 [vo/gpu] Resize: 1093x615 [vo/gpu] Window size: 1093x615 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1280x720 (1:1) [vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1093x615 [vo/gpu] Video scale: 0.853906/0.854167 [vo/gpu] OSD borders: l=0 t=0 r=0 b=0 [vo/gpu] Video borders: l=0 t=0 r=0 b=0 [vo/gpu] Reported display depth: 8 [statusline] AV: 00:00:08 / 00:04:18 (3%) A-V: 0.000 Dropped: 2 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [statusline] AV: 00:00:19 / 00:04:18 (7%) A-V: 0.000 Dropped: 2 [cplayer] EOF code: 5 [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 [vo/gpu/x11] Enabling screensaver Then I repeat the test with a 1080p H264 mp4. mpv tries to use hardware acceleration, but the mpv is black and there's continuous DRM_IOCTL errors: Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v windwaker1080p.mp4 [cplayer] Command line options: '-v' 'windwaker1080p.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening windwaker1080p.mp4 [bdmv/bluray] Opening windwaker1080p.mp4 [file] Opening windwaker1080p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: windwaker1080p.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (h264 1920x1080 29.970fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-drm... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] using EGL dmabuf interop [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [vd] Trying hardware decoding via h264-drm. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [cplayer] Set property: shared-script-properties -> 1 [vd] Pixel formats supported by decoder: vdpau cuda vaapi drm_prime yuv420p [vd] Codec profile: High (0x64) [vd] Requesting pixfmt 'drm_prime' from decoder. [vd] Using hardware decoding (drm). [vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1920x1080 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [cplayer] first video frame after restart shown [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu] Reported display depth: 8 [vo/gpu/x11] Disabling screensaver. DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource [cplayer] Set property: shared-script-properties -> 1 DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource [cplayer] Set property: shared-script-properties -> 1 DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource DRM_IOCTL_MODE_CREATE_DUMB failed: Cannot allocate memory Failed to create scanout resource Then I tried this inside /etc/mpv/mpv.conf hwdec=drm-prime drm-drmprime-video-plane=primary drm-draw-plane=overlay and the 1080p H264 starts playing fluidly with just 40% CPU (compositor off) Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v windwaker1080p.mp4 [cplayer] Command line options: '-v' 'windwaker1080p.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm-prime' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [cplayer] Set property: shared-script-properties -> 1 [ifo_dvdnav] Opening windwaker1080p.mp4 [bdmv/bluray] Opening windwaker1080p.mp4 [file] Opening windwaker1080p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: windwaker1080p.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (h264 1920x1080 29.970fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Unsupported hwdec: drm-prime [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] DR path suspected slow/uncached, disabling..reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [cplayer] first video frame after restart shown [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu] Reported display depth: 8 [vo/gpu/x11] Disabling screensaver. [statusline] V: 00:00:00 / 00:04:31 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:00 / 00:04:31 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:09 / 00:04:31 (3%) [cplayer] EOF code: 5 [vo/gpu/x11] Enabling screensaver. [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 With compositor on, I get same 40% CPU Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v windwaker1080p.mp4 [cplayer] Command line options: '-v' 'windwaker1080p.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm-prime' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Waiting for scripts... [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Set property: shared-script-properties -> 1 [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [ifo_dvdnav] Opening windwaker1080p.mp4 [bdmv/bluray] Opening windwaker1080p.mp4 [file] Opening windwaker1080p.mp4 [demux] Trying demuxers for level=normal. [cplayer] Set property: shared-script-properties -> 1 [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: windwaker1080p.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [cplayer] Set property: shared-script-properties -> 1 [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (h264 1920x1080 29.970fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 29.970030 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Unsupported hwdec: drm-prime [vd] No hardware decoding available for this codec. [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] DR path suspected slow/uncached, disabling..reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [cplayer] first video frame after restart shown [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu] Reported display depth: 8 [vo/gpu/x11] Disabling screensaver. [statusline] V: 00:00:00 / 00:04:31 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:00 / 00:04:31 (0%) [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:16 / 00:04:31 (6%) Dropped: 2 [cplayer] EOF code: 5 [vo/gpu/x11] Enabling screensaver. [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [cplayer] Set property: shared-script-properties -> 1 Same video glitches, with or without compositor, but I am getting hardware acceleration (although there's the hwdec unsupported message) Update: Thank you to all who helped me. I have hardware acceleration again with my opiz3 hwdec=drm is more efficient extraargs=cma=256 is needed to avoid memory allocation problems and video glitches. https://forum.armbian.com/topic/29202-orange-pi-zero-3/page/26/#findComment-222596 Edited July 20 by robertoj 1 Quote
Ryzer Posted July 20 Posted July 20 First test was in a CLI environment so running fullscreen. Self built with no media related changes to the configuration. Edge build around kernel 6.15.0 and running on Pcduino2 For the second test I used the build scripts to create a desktop image which came to be less of a headache because less dependencies had to resolved than working purely with CLI only. This was built around kernel 6.15.4 and running on Pcduino3. This time got a blue screen within the window and lots of errors relating to dmabuf. test2.txt I currently have CMA set to 64mb, although this is overridden by the shared-dma-pool within the sun7i-a20.dtsi 0 Quote
robertoj Posted July 21 Posted July 21 20 hours ago, Ryzer said: First test was in a CLI environment so running fullscreen. Self built with no media related changes to the configuration. Edge build around kernel 6.15.0 and running on Pcduino2 For the second test I used the build scripts to create a desktop image which came to be less of a headache because less dependencies had to resolved than working purely with CLI only. This was built around kernel 6.15.4 and running on Pcduino3. This time got a blue screen within the window and lots of errors relating to dmabuf. test2.txt I currently have CMA set to 64mb, although this is overridden by the shared-dma-pool within the sun7i-a20.dtsi I would try the cma=256M argument anyway... this kernel argument eliminated my video glitches and dma errors. I don't know how a dtsi or dtbo parameter (loaded after linux is started) would override a kernel argument (given before the linux kernel is started). 0 Quote
robertoj Posted July 22 Posted July 22 Has anybody had success with Armbian Trixie? I repeated the steps I did for Bookworm, to have HW accelerated H264 1080p in XFCE, X11, with Linux 6.15.4... and I get "Unsupported hwdec: drm" in Trixie: ffmpeg 7.1.1, mpv 0.4.0 mpv log in trixie (with double verbose): Spoiler trixie test, 50% CPU, drops 50% of frames roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v -v pedro\ pe\ 1080p\ 25fps\ h264.mp4 [cplayer] Command line options: '-v' '-v' 'pedro pe 1080p 25fps h264.mp4' [cplayer] mpv v0.40.0 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects [cplayer] libplacebo version: v7.349.0 [cplayer] FFmpeg version: 7.1.1-1+b1 (runtime 7.1.1-1) [cplayer] FFmpeg library versions: [cplayer] libavcodec 61.19.101 [cplayer] libavdevice 61.3.100 [cplayer] libavfilter 10.4.100 [cplayer] libavformat 61.7.100 [cplayer] libavutil 59.39.100 [cplayer] libswresample 5.3.100 [cplayer] libswscale 8.3.100 [cplayer] Configuration: -Dpython.bytecompile=-1 -Dlibmpv=true -Dbuild-date=false -Dcdda=enabled -Ddvdnav=enabled -Dsdl2=enabled -Ddvbin=enabled -Dprefix=/usr -Dlibdir=lib/aarch64-linux-gnu -Dlocalstatedir=/var -Dsysconfdir=/etc -Dbuildtype=plain -Dwrap_mode=nodownload [cplayer] List of enabled features: alsa caca cdda cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg ffnvcodec gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel sndio sndio-1-9 uchardet vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 x11 xv zimg zimg-st428 zlib [global] home path: '' -> '/home/roberto/.config/mpv' [global] user path: '~~home/' -> '/home/roberto/.config/mpv' [global] user path: '~~old_home/' -> '/home/roberto/.mpv' [global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.config/mpv/encoding-profiles.conf' [global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.mpv/encoding-profiles.conf' [global] config path: 'encoding-profiles.conf' -> '/etc/mpv/encoding-profiles.conf' [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [ifo_dvdnav] Opening /etc/mpv/encoding-profiles.conf [bdmv/bluray] Opening /etc/mpv/encoding-profiles.conf [file] Opening /etc/mpv/encoding-profiles.conf [file] resize stream to 131072 bytes, drop 0 bytes [file] Stream opened successfully. [cplayer] Applying profile 'default'... [global] config path: 'mpv.conf' -/-> '/home/roberto/.config/mpv/mpv.conf' [global] config path: 'config' -/-> '/home/roberto/.config/mpv/config' [global] config path: 'mpv.conf' -/-> '/home/roberto/.mpv/mpv.conf' [global] config path: 'config' -/-> '/home/roberto/.mpv/config' [global] config path: 'mpv.conf' -> '/etc/mpv/mpv.conf' [global] config path: 'config' -/-> '/etc/mpv/config' [cplayer] Reading config file /etc/mpv/mpv.conf [ifo_dvdnav] Opening /etc/mpv/mpv.conf [bdmv/bluray] Opening /etc/mpv/mpv.conf [file] Opening /etc/mpv/mpv.conf [file] resize stream to 131072 bytes, drop 0 bytes [file] Stream opened successfully. [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Setting option 'v' = '' (flags = 😎 [global] config path: 'input.conf' -/-> '/home/roberto/.config/mpv/input.conf' [global] config path: 'input.conf' -/-> '/home/roberto/.mpv/input.conf' [global] config path: 'input.conf' -/-> '/etc/mpv/input.conf' [osc] Loading lua script @osc.lua... [ytdl_hook] Loading lua script @ytdl_hook.lua... [stats] Loading lua script @stats.lua... [console] Loading lua script @console.lua... [auto_profiles] Loading lua script @auto_profiles.lua... [select] Loading lua script @select.lua... [positioning] Loading lua script @positioning.lua... [stats] loading mp.defaults [commands] Loading lua script @commands.lua... [console] loading mp.defaults [clipboard] Initialized vo clipboard backend. [auto_profiles] loading mp.defaults [positioning] loading mp.defaults [ytdl_hook] loading mp.defaults [select] loading mp.defaults [stats] loading @stats.lua [positioning] loading @positioning.lua [global] config path: 'scripts' -/-> '/home/roberto/.config/mpv/scripts' [global] config path: 'scripts' -/-> '/home/roberto/.mpv/scripts' [global] config path: 'scripts' -/-> '/etc/mpv/scripts' [cplayer] Waiting for scripts... [osc] loading mp.defaults [positioning] reading options for positioning [global] config path: 'script-opts/positioning.conf' -/-> '/home/roberto/.config/mpv/script-opts/positioning.conf' [global] config path: 'script-opts/positioning.conf' -/-> '/home/roberto/.mpv/script-opts/positioning.conf' [global] config path: 'script-opts/positioning.conf' -/-> '/etc/mpv/script-opts/positioning.conf' [positioning] script-opts/positioning.conf not found. [global] config path: 'lua-settings/positioning.conf' -/-> '/home/roberto/.config/mpv/lua-settings/positioning.conf' [global] config path: 'lua-settings/positioning.conf' -/-> '/home/roberto/.mpv/lua-settings/positioning.conf' [global] config path: 'lua-settings/positioning.conf' -/-> '/etc/mpv/lua-settings/positioning.conf' [positioning] lua-settings/positioning.conf not found. [ytdl_hook] loading @ytdl_hook.lua [commands] loading mp.defaults [cplayer] Run command: define-section, flags=64, args=[name="input_positioning", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_positioning", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_positioning", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_positioning", flags="allow-hide-cursor+allow-vo-dragging"] [select] loading @select.lua [osc] loading @osc.lua [commands] loading @commands.lua [auto_profiles] loading @auto_profiles.lua [console] loading @console.lua [select] reading options for select [global] config path: 'script-opts/select.conf' -/-> '/home/roberto/.config/mpv/script-opts/select.conf' [global] config path: 'script-opts/select.conf' -/-> '/home/roberto/.mpv/script-opts/select.conf' [global] config path: 'script-opts/select.conf' -/-> '/etc/mpv/script-opts/select.conf' [select] script-opts/select.conf not found. [global] config path: 'lua-settings/select.conf' -/-> '/home/roberto/.config/mpv/lua-settings/select.conf' [global] config path: 'lua-settings/select.conf' -/-> '/home/roberto/.mpv/lua-settings/select.conf' [global] config path: 'lua-settings/select.conf' -/-> '/etc/mpv/lua-settings/select.conf' [select] lua-settings/select.conf not found. [stats] reading options for stats [global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.config/mpv/script-opts/stats.conf' [global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.mpv/script-opts/stats.conf' [global] config path: 'script-opts/stats.conf' -/-> '/etc/mpv/script-opts/stats.conf' [stats] script-opts/stats.conf not found. [global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.config/mpv/lua-settings/stats.conf' [global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.mpv/lua-settings/stats.conf' [global] config path: 'lua-settings/stats.conf' -/-> '/etc/mpv/lua-settings/stats.conf' [stats] lua-settings/stats.conf not found. [commands] reading options for commands [cplayer] Run command: define-section, flags=64, args=[name="input_select", contents="", flags="default"] [console] reading options for console [ytdl_hook] reading options for ytdl_hook [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/script-opts/ytdl_hook.conf' [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.mpv/script-opts/ytdl_hook.conf' [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/etc/mpv/script-opts/ytdl_hook.conf' [ytdl_hook] script-opts/ytdl_hook.conf not found. [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/lua-settings/ytdl_hook.conf' [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.mpv/lua-settings/ytdl_hook.conf' [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/etc/mpv/lua-settings/ytdl_hook.conf' [global] config path: 'script-opts/commands.conf' -/-> '/home/roberto/.config/mpv/script-opts/commands.conf' [global] config path: 'script-opts/commands.conf' -/-> '/home/roberto/.mpv/script-opts/commands.conf' [global] config path: 'script-opts/commands.conf' -/-> '/etc/mpv/script-opts/commands.conf' [commands] script-opts/commands.conf not found. [global] config path: 'lua-settings/commands.conf' -/-> '/home/roberto/.config/mpv/lua-settings/commands.conf' [global] config path: 'lua-settings/commands.conf' -/-> '/home/roberto/.mpv/lua-settings/commands.conf' [global] config path: 'lua-settings/commands.conf' -/-> '/etc/mpv/lua-settings/commands.conf' [commands] lua-settings/commands.conf not found. [global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.config/mpv/script-opts/console.conf' [global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.mpv/script-opts/console.conf' [ytdl_hook] lua-settings/ytdl_hook.conf not found. [global] config path: 'script-opts/console.conf' -/-> '/etc/mpv/script-opts/console.conf' [console] script-opts/console.conf not found. [global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.config/mpv/lua-settings/console.conf' [global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.mpv/lua-settings/console.conf' [global] config path: 'lua-settings/console.conf' -/-> '/etc/mpv/lua-settings/console.conf' [console] lua-settings/console.conf not found. [cplayer] Run command: enable-section, flags=64, args=[name="input_select", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_select", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_select", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_commands", contents="", flags="default"] [cplayer] Run command: define-section, flags=64, args=[name="input_stats", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_stats", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: enable-section, flags=64, args=[name="input_commands", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_stats", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_stats", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_commands", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_commands", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_console", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_console", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_console", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_console", flags="allow-hide-cursor+allow-vo-dragging"] [auto_profiles] Destroying client handle... [cplayer] Run command: define-section, flags=64, args=[name="showhide", contents="mouse_move script-binding osc/__keybinding1\nmouse_leave script-binding osc/__keybinding2\n", flags="force"] [cplayer] Run command: define-section, flags=64, args=[name="showhide_wc", contents="mouse_move script-binding osc/__keybinding3\nmouse_leave script-binding osc/__keybinding4\n", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="showhide", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: enable-section, flags=64, args=[name="showhide_wc", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input", contents="mbtn_left script-binding osc/__keybinding5\nmbtn_mid script-binding osc/__keybinding6\nmbtn_right script-binding osc/__keybinding7\nshift+mbtn_left script-binding osc/__keybinding8\nwheel_up script-binding osc/__keybinding9\nwheel_down script-binding osc/__keybinding10\nmbtn_left_dbl ignore\nshift+mbtn_left_dbl ignore\nmbtn_right_dbl ignore\n", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input", flags=""] [cplayer] Run command: define-section, flags=64, args=[name="window-controls", contents="mbtn_left script-binding osc/__keybinding11\n", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""] [osc] reading options for osc [global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.config/mpv/script-opts/osc.conf' [global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.mpv/script-opts/osc.conf' [global] config path: 'script-opts/osc.conf' -/-> '/etc/mpv/script-opts/osc.conf' [osc] script-opts/osc.conf not found. [global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.config/mpv/lua-settings/osc.conf' [global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.mpv/lua-settings/osc.conf' [global] config path: 'lua-settings/osc.conf' -/-> '/etc/mpv/lua-settings/osc.conf' [osc] lua-settings/osc.conf not found. [cplayer] Set property: user-data/osc/visibility="auto" -> 1 [cplayer] Run command: disable-section, flags=64, args=[name="input"] [cplayer] Run command: disable-section, flags=64, args=[name="window-controls"] [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [cplayer] Done loading scripts. [global] state path: 'watch_later' -> '/home/roberto/.local/state/mpv/watch_later' [cplayer] Running hook: auto_profiles/on_before_start_file [cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook. [global] state path: 'watch_later' -> '/home/roberto/.local/state/mpv/watch_later' [cplayer] Running hook: auto_profiles/on_load [cplayer] Failed sending hook command auto_profiles/on_load. Removing hook. [cplayer] Running hook: ytdl_hook/on_load [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [cplayer] Running hook: ytdl_hook/on_load [osc] osc_init [ytdl_hook] playlist hook [ifo_dvdnav] Opening pedro pe 1080p 25fps h264.mp4 [bdmv/bluray] Opening pedro pe 1080p 25fps h264.mp4 [file] Opening pedro pe 1080p 25fps h264.mp4 [file] resize stream to 131072 bytes, drop 0 bytes [file] Stream opened successfully. [demux] Trying demuxers for level=normal. [demux] Trying demuxer: directory (force-level: normal) [demux] Trying demuxer: disc (force-level: normal) [demux] Trying demuxer: edl (force-level: normal) [demux] Trying demuxer: cue (force-level: normal) [demux] Trying demuxer: rawaudio (force-level: normal) [demux] Trying demuxer: rawvideo (force-level: normal) [demux] Trying demuxer: mkv (force-level: normal) [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [demux] Trying demuxer: libarchive (force-level: normal) [global] config path: 'fonts' -/-> '/home/roberto/.config/mpv/fonts' [global] config path: 'fonts' -/-> '/home/roberto/.mpv/fonts' [global] config path: 'fonts' -/-> '/etc/mpv/fonts' [osd/libass] ASS library version: 0x1703000 (runtime 0x1703000) [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [demux] Trying demuxer: lavf (force-level: normal) [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [global] config path: 'subfont.ttf' -/-> '/home/roberto/.config/mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/home/roberto/.mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.config/mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [osd/libass] Setting up fonts... [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [ffmpeg/demuxer] mov,mp4,m4a,3gp,3g2,mj2: advanced_editlist does not work with fragmented MP4. disabling. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: pedro pe 1080p 25fps h264.mp4 [osd/libass] Using font provider fontconfig [osd/libass] Done. [find_files] Loading external files in . [global] config path: 'sub' -/-> '/home/roberto/.config/mpv/sub' [global] config path: 'sub' -/-> '/home/roberto/.mpv/sub' [global] config path: 'sub' -/-> '/etc/mpv/sub' [cplayer] Running hook: auto_profiles/on_preloaded [cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook. [cplayer] Running hook: ytdl_hook/on_preloaded [lavf] select track 0 [cplayer] ● Video --vid=1 (h264 1920x1080 25 fps) [default] [vo/gpu] Probing for best GPU context. [vo/gpu/auto] Initializing GPU context 'auto' [vo/gpu/vulkan] Initializing GPU context 'waylandvk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Available instance version: 1.4.309 [vo/gpu/libplacebo] Spent 0.482 ms enumerating instance layers [vo/gpu/libplacebo] Available layers: [vo/gpu/libplacebo] Spent 0.574 ms enumerating instance extensions [vo/gpu/libplacebo] Available instance extensions: [vo/gpu/libplacebo] VK_EXT_debug_report [vo/gpu/libplacebo] VK_EXT_debug_utils [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_LUNARG_direct_driver_loading [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_wayland_surface [vo/gpu/libplacebo] Spent 0.232 ms creating vulkan instance [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/vulkan] Initializing GPU context 'x11vk' [vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349) [vo/gpu/libplacebo] Available instance version: 1.4.309 [vo/gpu/libplacebo] Spent 0.435 ms enumerating instance layers [vo/gpu/libplacebo] Available layers: [vo/gpu/libplacebo] Spent 0.503 ms enumerating instance extensions [vo/gpu/libplacebo] Available instance extensions: [vo/gpu/libplacebo] VK_EXT_debug_report [vo/gpu/libplacebo] VK_EXT_debug_utils [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_LUNARG_direct_driver_loading [vo/gpu/libplacebo] Creating vulkan instance with extensions: [vo/gpu/libplacebo] VK_KHR_get_physical_device_properties2 [vo/gpu/libplacebo] VK_KHR_portability_enumeration [vo/gpu/libplacebo] VK_KHR_surface [vo/gpu/libplacebo] VK_KHR_xlib_surface [vo/gpu/libplacebo] Spent 0.227 ms creating vulkan instance [vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER [vo/gpu/libplacebo] Failed initializing vulkan instance [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] X11 running at 1920x1080 (":0.0" => local display) [vo/gpu/x11] Detected wm supports NetWM. [vo/gpu/x11] Detected wm supports ABOVE state. [vo/gpu/x11] Detected wm supports BELOW state. [vo/gpu/x11] Detected wm supports FULLSCREEN state. [vo/gpu/x11] Detected wm supports SKIP_TASKBAR state. [vo/gpu/x11] Detected wm supports STICKY state. [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.5 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Chosen EGLConfig: [vo/gpu/opengl] EGL_CONFIG_ID=0x9 [vo/gpu/opengl] EGL_RED_SIZE=0x8 [vo/gpu/opengl] EGL_GREEN_SIZE=0x8 [vo/gpu/opengl] EGL_BLUE_SIZE=0x8 [vo/gpu/opengl] EGL_ALPHA_SIZE=0x0 [vo/gpu/opengl] EGL_COLOR_BUFFER_TYPE=0x308e [vo/gpu/opengl] EGL_CONFIG_CAVEAT=0x3038 [vo/gpu/opengl] EGL_CONFORMANT=0x4d [vo/gpu/opengl] EGL_NATIVE_VISUAL_ID=0x21 [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent enabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Mesa' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Combined OpenGL extensions string: [vo/gpu/opengl] EGL_ANDROID_blob_cache EGL_ANDROID_native_fence_sync EGL_CHROMIUM_sync_control EGL_ANGLE_sync_control_rate EGL_EXT_buffer_age EGL_EXT_config_select_group EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_surface_compression EGL_EXT_swap_buffers_with_damage EGL_IMG_context_priority EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_partial_update EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_gl_interop EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_MESA_x11_native_visual_id EGL_NOK_texture_from_pixmap EGL_WL_bind_wayland_display GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_polygon_offset_clamp GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_EGL_image_storage GL_EXT_EGL_image_storage_compression GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_debug_label GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_image_load_formatted GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_RG8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_INTEL_blackhole_render GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_image GL_NV_depth_clamp GL_NV_fog_distance GL_NV_half_float GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_timer_query. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu/opengl] Texture formats: [vo/gpu/opengl] NAME COMP*TYPE SIZE DEPTH PER COMP. [vo/gpu/opengl] r8 1*unorm 1B LF CR ST {8} [vo/gpu/opengl] rg8 2*unorm 2B LF CR ST {8 8} [vo/gpu/opengl] rgb8 3*unorm 3B LF CR ST {8 8 8} [vo/gpu/opengl] rgba8 4*unorm 4B LF CR ST {8 8 8 8} [vo/gpu/opengl] r16 1*unorm 2B LF CR ST {16} [vo/gpu/opengl] rg16 2*unorm 4B LF CR ST {16 16} [vo/gpu/opengl] rgb16 3*unorm 6B LF CR ST {16 16 16} [vo/gpu/opengl] rgba16 4*unorm 8B LF CR ST {16 16 16 16} [vo/gpu/opengl] r8ui 1*uint 1B CR ST {8} [vo/gpu/opengl] rg8ui 2*uint 2B CR ST {8 8} [vo/gpu/opengl] rgb8ui 3*uint 3B ST {8 8 8} [vo/gpu/opengl] rgba8ui 4*uint 4B CR ST {8 8 8 8} [vo/gpu/opengl] r16ui 1*uint 2B CR ST {16} [vo/gpu/opengl] rg16ui 2*uint 4B CR ST {16 16} [vo/gpu/opengl] rgb16ui 3*uint 6B ST {16 16 16} [vo/gpu/opengl] rgba16ui 4*uint 8B CR ST {16 16 16 16} [vo/gpu/opengl] r16f 1*float 4B LF CR ST {32/16} [vo/gpu/opengl] rg16f 2*float 8B LF CR ST {32/16 32/16} [vo/gpu/opengl] rgb16f 3*float 12B LF CR ST {32/16 32/16 32/16} [vo/gpu/opengl] rgba16f 4*float 16B LF CR ST {32/16 32/16 32/16 32/16} [vo/gpu/opengl] r32f 1*float 4B LF CR ST {32} [vo/gpu/opengl] rg32f 2*float 8B LF CR ST {32 32} [vo/gpu/opengl] rgb32f 3*float 12B LF CR ST {32 32 32} [vo/gpu/opengl] rgba32f 4*float 16B LF CR ST {32 32 32 32} [vo/gpu/opengl] rgb10_a2 4*unorm 4B LF CR ST {0/10 0/10 0/10 0/2} [vo/gpu/opengl] rgba12 4*unorm 8B LF CR ST {16 16 16 16} [vo/gpu/opengl] rgb10 3*unorm 6B LF CR ST {16/10 16/10 16/10} [vo/gpu/opengl] rgb565 3*unorm 2B LF ST {0/8 0/8 0/8} [vo/gpu/opengl] LA = LUMINANCE_ALPHA hack format [vo/gpu/opengl] LF = linear filterable [vo/gpu/opengl] CR = can be used for render targets [vo/gpu/opengl] ST = can be used for storable images [vo/gpu/opengl] Image formats: [vo/gpu/opengl] yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] gray => 1 planes 1x1 8/0 [r8] (r) [unorm] [vo/gpu/opengl] gray16 => 1 planes 1x1 16/0 [r16] (r) [unorm] [vo/gpu/opengl] uyvy422 [vo/gpu/opengl] nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] argb => 1 planes 1x1 8/0 [rgba8] (argb) [unorm] [vo/gpu/opengl] bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm] [vo/gpu/opengl] abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [unorm] [vo/gpu/opengl] rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [unorm] [vo/gpu/opengl] bgr24 => 1 planes 1x1 8/0 [rgb8] (bgr) [unorm] [vo/gpu/opengl] rgb24 => 1 planes 1x1 8/0 [rgb8] (rgb) [unorm] [vo/gpu/opengl] 0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [unorm] [vo/gpu/opengl] bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm] [vo/gpu/opengl] 0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [unorm] [vo/gpu/opengl] rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [unorm] [vo/gpu/opengl] rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [unorm] [vo/gpu/opengl] rgb565 => 1 planes 1x1 0/0 [rgb565] (rgb) [unknown] [vo/gpu/opengl] pal8 [vo/gpu/opengl] vdpau [vo/gpu/opengl] d3d11 [vo/gpu/opengl] dxva2_vld [vo/gpu/opengl] mmal [vo/gpu/opengl] mediacodec [vo/gpu/opengl] cuda [vo/gpu/opengl] yap8 => 2 planes 1x1 8/0 [r8/r8] (r/a) [unorm] [vo/gpu/opengl] yap16 => 2 planes 1x1 16/0 [r16/r16] (r/a) [unorm] [vo/gpu/opengl] grayaf32 => 2 planes 1x1 32/0 [r16f/r16f] (r/a) [float] [vo/gpu/opengl] yuv444pf => 3 planes 1x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva444pf => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv420pf => 3 planes 2x2 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva420pf => 4 planes 2x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv422pf => 3 planes 2x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva422pf => 4 planes 2x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv440pf => 3 planes 1x2 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva440pf => 4 planes 1x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv410pf => 3 planes 4x4 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva410pf => 4 planes 4x4 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv411pf => 3 planes 4x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva411pf => 4 planes 4x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] rgb30 => 1 planes 1x1 10/0 [rgb10_a2] (bgr) [unknown] [vo/gpu/opengl] y1 => 1 planes 1x1 8/-7 [r8] (r) [unorm] [vo/gpu/opengl] gbrp1 => 3 planes 1x1 8/-7 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp2 => 3 planes 1x1 8/-6 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp3 => 3 planes 1x1 8/-5 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp4 => 3 planes 1x1 8/-4 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp5 => 3 planes 1x1 8/-3 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp6 => 3 planes 1x1 8/-2 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] vdpau_output [vo/gpu/opengl] vaapi [vo/gpu/opengl] videotoolbox [vo/gpu/opengl] vulkan [vo/gpu/opengl] drm_prime [vo/gpu/opengl] yuyv422 [vo/gpu/opengl] yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] monow [vo/gpu/opengl] monob [vo/gpu/opengl] yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] uyyvyy411 [vo/gpu/opengl] bgr8 [vo/gpu/opengl] bgr4 [vo/gpu/opengl] bgr4_byte [vo/gpu/opengl] rgb8 [vo/gpu/opengl] rgb4 [vo/gpu/opengl] rgb4_byte [vo/gpu/opengl] nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [unorm] [vo/gpu/opengl] gray16be [vo/gpu/opengl] yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] rgb48be [vo/gpu/opengl] rgb48 => 1 planes 1x1 16/0 [rgb16] (rgb) [unorm] [vo/gpu/opengl] rgb565be [vo/gpu/opengl] rgb555be [vo/gpu/opengl] rgb555 [vo/gpu/opengl] bgr565be [vo/gpu/opengl] bgr565 [vo/gpu/opengl] bgr555be [vo/gpu/opengl] bgr555 [vo/gpu/opengl] yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p16be [vo/gpu/opengl] yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p16be [vo/gpu/opengl] yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p16be [vo/gpu/opengl] rgb444 [vo/gpu/opengl] rgb444be [vo/gpu/opengl] bgr444 [vo/gpu/opengl] bgr444be [vo/gpu/opengl] ya8 => 1 planes 1x1 8/0 [rg8] (ra) [unorm] [vo/gpu/opengl] bgr48be [vo/gpu/opengl] bgr48 => 1 planes 1x1 16/0 [rgb16] (bgr) [unorm] [vo/gpu/opengl] yuv420p9be [vo/gpu/opengl] yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p10be [vo/gpu/opengl] yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p10be [vo/gpu/opengl] yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p9be [vo/gpu/opengl] yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p10be [vo/gpu/opengl] yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p9be [vo/gpu/opengl] yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp9be [vo/gpu/opengl] gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp10be [vo/gpu/opengl] gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp16be [vo/gpu/opengl] gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p9be [vo/gpu/opengl] yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p9be [vo/gpu/opengl] yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p9be [vo/gpu/opengl] yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p10be [vo/gpu/opengl] yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p10be [vo/gpu/opengl] yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p10be [vo/gpu/opengl] yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p16be [vo/gpu/opengl] yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p16be [vo/gpu/opengl] yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p16be [vo/gpu/opengl] yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] xyz12 => 1 planes 1x1 16/4 [rgb16] (rgb) [unorm] [vo/gpu/opengl] xyz12be [vo/gpu/opengl] nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] nv20be [vo/gpu/opengl] rgba64be [vo/gpu/opengl] bgra64be [vo/gpu/opengl] bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [unorm] [vo/gpu/opengl] yvyu422 [vo/gpu/opengl] ya16be [vo/gpu/opengl] ya16 => 1 planes 1x1 16/0 [rg16] (ra) [unorm] [vo/gpu/opengl] gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [unorm] [vo/gpu/opengl] gbrap16be [vo/gpu/opengl] gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] qsv [vo/gpu/opengl] d3d11va_vld [vo/gpu/opengl] yuv420p12be [vo/gpu/opengl] yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p14be [vo/gpu/opengl] yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p12be [vo/gpu/opengl] yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p14be [vo/gpu/opengl] yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p12be [vo/gpu/opengl] yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p14be [vo/gpu/opengl] yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] gbrp12be [vo/gpu/opengl] gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp14be [vo/gpu/opengl] gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] bayer_bggr8 [vo/gpu/opengl] bayer_rggb8 [vo/gpu/opengl] bayer_gbrg8 [vo/gpu/opengl] bayer_grbg8 [vo/gpu/opengl] bayer_bggr16 [vo/gpu/opengl] bayer_bggr16be [vo/gpu/opengl] bayer_rggb16 [vo/gpu/opengl] bayer_rggb16be [vo/gpu/opengl] bayer_gbrg16 [vo/gpu/opengl] bayer_gbrg16be [vo/gpu/opengl] bayer_grbg16 [vo/gpu/opengl] bayer_grbg16be [vo/gpu/opengl] yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv440p10be [vo/gpu/opengl] yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv440p12be [vo/gpu/opengl] ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [unorm] [vo/gpu/opengl] ayuv64be [vo/gpu/opengl] p010be [vo/gpu/opengl] gbrap12be [vo/gpu/opengl] gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] gbrap10be [vo/gpu/opengl] gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] gray12be [vo/gpu/opengl] gray12 => 1 planes 1x1 16/-4 [r16] (r) [unorm] [vo/gpu/opengl] gray10be [vo/gpu/opengl] gray10 => 1 planes 1x1 16/-6 [r16] (r) [unorm] [vo/gpu/opengl] p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p016be [vo/gpu/opengl] gray9be [vo/gpu/opengl] gray9 => 1 planes 1x1 16/-7 [r16] (r) [unorm] [vo/gpu/opengl] gbrpf32be [vo/gpu/opengl] gbrpf32 => 3 planes 1x1 32/0 [r16f/r16f/r16f] (g/b/r) [float] [vo/gpu/opengl] gbrapf32be [vo/gpu/opengl] gbrapf32 => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (g/b/r/a) [float] [vo/gpu/opengl] opencl [vo/gpu/opengl] gray14be [vo/gpu/opengl] gray14 => 1 planes 1x1 16/-2 [r16] (r) [unorm] [vo/gpu/opengl] grayf32be [vo/gpu/opengl] grayf32 => 1 planes 1x1 32/0 [r16f] (r) [float] [vo/gpu/opengl] yuva422p12be [vo/gpu/opengl] yuva422p12 => 4 planes 2x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p12be [vo/gpu/opengl] yuva444p12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] nv24 => 2 planes 1x1 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] nv42 => 2 planes 1x1 8/0 [r8/rg8] (r/bg) [unorm] [vo/gpu/opengl] y210be [vo/gpu/opengl] y210 [vo/gpu/opengl] x2rgb10be [vo/gpu/opengl] x2bgr10 [vo/gpu/opengl] x2bgr10be [vo/gpu/opengl] p210be [vo/gpu/opengl] p210 => 2 planes 2x1 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p410be [vo/gpu/opengl] p410 => 2 planes 1x1 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p216be [vo/gpu/opengl] p216 => 2 planes 2x1 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p416be [vo/gpu/opengl] p416 => 2 planes 1x1 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] vuya => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm] [vo/gpu/opengl] rgbaf16be [vo/gpu/opengl] rgbaf16 [vo/gpu/opengl] vuyx => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm] [vo/gpu/opengl] p012 => 2 planes 2x2 16/4 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p012be [vo/gpu/opengl] y212be [vo/gpu/opengl] y212 [vo/gpu/opengl] xv30be [vo/gpu/opengl] xv30 [vo/gpu/opengl] xv36be [vo/gpu/opengl] xv36 => 1 planes 1x1 16/4 [rgba16] (grb) [unorm] [vo/gpu/opengl] rgbf32be [vo/gpu/opengl] rgbf32 [vo/gpu/opengl] rgbaf32be [vo/gpu/opengl] rgbaf32 [vo/gpu/opengl] p212be [vo/gpu/opengl] p212 => 2 planes 2x1 16/4 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p412be [vo/gpu/opengl] p412 => 2 planes 1x1 16/4 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] gbrap14be [vo/gpu/opengl] gbrap14 => 4 planes 1x1 16/-2 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] d3d12 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Resizing texture: 16x16 [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [global] cache path: '' -> '/home/roberto/.cache/mpv' [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 25.000000 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Unsupported hwdec: drm [vd] Using software decoding. [vd] Detected 4 logical cores. [vd] Requesting 5 threads for decoding. [vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [cplayer] Run command: define-section, flags=64, args=[name="input_osc", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_osc", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_osc", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_osc", flags="allow-hide-cursor+allow-vo-dragging"] [global] config path: 'fonts' -/-> '/home/roberto/.config/mpv/fonts' [global] config path: 'fonts' -/-> '/home/roberto/.mpv/fonts' [global] config path: 'fonts' -/-> '/etc/mpv/fonts' [osd/libass] ASS library version: 0x1703000 (runtime 0x1703000) [osd/libass] libass API version: 0x1703000 [osd/libass] libass source: tarball: 0.17.3 [osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX) [global] config path: 'subfont.ttf' -/-> '/home/roberto/.config/mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/home/roberto/.mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.config/mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [osd/libass] Setting up fonts... [osd/libass] Using font provider fontconfig [osd/libass] Done. [osc] osc_init [ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: yuv420p [vd] DR parameter change to 1920x1090 yuv420p align=64 [vd] Allocating new (host-cached) DR image... [vo/gpu] DR path suspected slow/uncached, disabling. [vd] ...failed.. [vd] DR failed - disabling. [vd] Using software decoding. [vd] Decoder format: 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [in] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vf] [convert] (disabled) [vf] [out] 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [cplayer] VO: [gpu] 1920x1080 yuv420p [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0 [vo/gpu] max content size: 1920x1080 [vo/gpu] monitor size: 1920x1080 [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Texture for plane 0: 1920x1080 [vo/gpu] Texture for plane 1: 960x540 [vo/gpu] Texture for plane 2: 960x540 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Resizing texture: 16x16 [vo/gpu] Using FBO format rgba16f. [vo/gpu] Resizing texture: 960x540 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [vo/gpu] Resizing texture: 960x1080 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [vo/gpu] Resizing texture: 1920x1080 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [vo/gpu] Resizing texture: 1920x1080 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [vo/gpu] Resizing texture: 1920x1025 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [vo/gpu] Dither to 8. [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [cplayer] first video frame after restart shown [cplayer] starting video playback [vo/gpu] Resize: 1920x1025 [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu/x11] Disabling screensaver. [vo/gpu] Resizing texture: 1920x1025 [vo/gpu] Trying to load shader from disk... [vo/gpu/opengl] Loading binary program succeeded. [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [osc] osc_init [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [cplayer] Run command: quit, flags=73, args=[code="0"] [cplayer] EOF code: 5 [vd] Uninit decoder. [cplayer] Terminating demuxers... [cplayer] Done terminating demuxers. [statusline] V: 00:00:01 / 00:02:24 (1%) Dropped: 28 [cplayer] finished playback, success (reason 3) [cplayer] Running hook: ytdl_hook/on_after_end_file [vo/gpu/x11] Enabling screensaver. [cplayer] Run command: del, flags=64, args=[name="user-data/mpv/ytdl/json-subprocess-result"] [osc] osc_init [cplayer] Exiting... (Quit) [cplayer] Run command: del, flags=64, args=[name="user-data/mpv/console"] [ytdl_hook] Destroying client handle... [commands] Destroying client handle... [positioning] Destroying client handle... [stats] Destroying client handle... [select] Destroying client handle... [console] Destroying client handle... [cplayer] Set property: user-data/osc/margins={"b":0,"r":0,"t":0,"l":0} -> 1 [cplayer] Run command: del, flags=64, args=[name="user-data/osc"] [osc] Destroying client handle... [vo/gpu] flushing shader cache [vo/gpu/x11] uninit ... For reference, mpv log in Bookworm: Spoiler bookworm, fluid full fps, almost no dropped frames roberto@orangepizero3:~$ DISPLAY=:0.0 mpv -v -v pedro\ pe\ 1080p\ 25fps\ h264.mp4 [cplayer] Command line options: '-v' '-v' 'pedro pe 1080p 25fps h264.mp4' [cplayer] mpv 0.35.1 Copyright © 2000-2023 mpv/MPlayer/mplayer2 projects [cplayer] built on UNKNOWN [cplayer] FFmpeg library versions: [cplayer] libavutil 57.28.100 [cplayer] libavcodec 59.37.100 [cplayer] libavformat 59.27.100 [cplayer] libswscale 6.7.100 [cplayer] libavfilter 8.44.100 [cplayer] libswresample 4.7.100 [cplayer] FFmpeg version: 5.1.6-0+deb12u1 [cplayer] [cplayer] Configuration: meson configure build -Dprefix=/usr -Dbuildtype=plain -Doptimization=plain [cplayer] List of enabled features: alsa av-channel-layout caca cdda cplayer cplugins cuda-hwaccel cuda-interop dmabuf-interop-gl dmabuf-interop-pl dmabuf-wayland drm drm-is-kms dvbin dvdnav egl egl-drm egl-helpers egl-x11 ffmpeg ffnvcodec gbm gl gl-wayland glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg jpegxl lcms2 libarchive libass libavdevice libbluray libdl libm libmpv-shared libplacebo libplacebo-next librt linux-fstatfs lua52 manpage-build memfd_create noexecstack pipewire plain-gl posix pulse rubberband rubberband-3 sdl2 sdl2-audio sdl2-gamepad sdl2-video sixel spirv-cross stdatomic threads uchardet vaapi vaapi-drm vaapi-egl vaapi-libplacebo vaapi-wayland vaapi-x-egl vaapi-x11 vdpau vector vt.h vulkan wayland wayland_protocols_1_24 x11 xv zimg zlib [global] config path: '' -> '/home/roberto/.config/mpv' [global] user path: '~~home/' -> '/home/roberto/.config/mpv' [global] user path: '~~old_home/' -> '/home/roberto/.mpv' [global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.config/mpv/encoding-profiles.conf' [global] config path: 'encoding-profiles.conf' -/-> '/home/roberto/.mpv/encoding-profiles.conf' [global] config path: 'encoding-profiles.conf' -> '/etc/mpv/encoding-profiles.conf' [cplayer] Reading config file /etc/mpv/encoding-profiles.conf [cplayer] Applying profile 'default'... [global] config path: 'mpv.conf' -/-> '/home/roberto/.config/mpv/mpv.conf' [global] config path: 'config' -/-> '/home/roberto/.config/mpv/config' [global] config path: 'mpv.conf' -/-> '/home/roberto/.mpv/mpv.conf' [global] config path: 'config' -/-> '/home/roberto/.mpv/config' [global] config path: 'mpv.conf' -> '/etc/mpv/mpv.conf' [global] config path: 'config' -/-> '/etc/mpv/config' [cplayer] Reading config file /etc/mpv/mpv.conf [cplayer] Applying profile 'default'... [cplayer] Setting option 'hwdec' = 'drm' (flags = 4) [cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 4) [cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 4) [cplayer] Setting option 'v' = '' (flags = 😎 [cplayer] Setting option 'v' = '' (flags = 😎 [global] config path: 'input.conf' -/-> '/home/roberto/.config/mpv/input.conf' [global] config path: 'input.conf' -/-> '/home/roberto/.mpv/input.conf' [global] config path: 'input.conf' -/-> '/etc/mpv/input.conf' [osc] Loading lua script @osc.lua... [ytdl_hook] Loading lua script @ytdl_hook.lua... [stats] Loading lua script @stats.lua... [console] Loading lua script @console.lua... [auto_profiles] Loading lua script @auto_profiles.lua... [global] config path: 'scripts' -/-> '/home/roberto/.config/mpv/scripts' [global] config path: 'scripts' -/-> '/home/roberto/.mpv/scripts' [global] config path: 'scripts' -/-> '/etc/mpv/scripts' [cplayer] Waiting for scripts... [ytdl_hook] loading mp.defaults [console] loading mp.defaults [stats] loading mp.defaults [auto_profiles] loading mp.defaults [osc] loading mp.defaults [stats] loading @stats.lua [console] loading @console.lua [ytdl_hook] loading @ytdl_hook.lua [auto_profiles] loading @auto_profiles.lua [osc] loading @osc.lua [console] reading options for console [global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.config/mpv/script-opts/console.conf' [global] config path: 'script-opts/console.conf' -/-> '/home/roberto/.mpv/script-opts/console.conf' [global] config path: 'script-opts/console.conf' -/-> '/etc/mpv/script-opts/console.conf' [console] script-opts/console.conf not found. [global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.config/mpv/lua-settings/console.conf' [ytdl_hook] reading options for ytdl_hook [auto_profiles] Exiting... [global] config path: 'lua-settings/console.conf' -/-> '/home/roberto/.mpv/lua-settings/console.conf' [global] config path: 'lua-settings/console.conf' -/-> '/etc/mpv/lua-settings/console.conf' [console] lua-settings/console.conf not found. [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/script-opts/ytdl_hook.conf' [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/home/roberto/.mpv/script-opts/ytdl_hook.conf' [global] config path: 'script-opts/ytdl_hook.conf' -/-> '/etc/mpv/script-opts/ytdl_hook.conf' [ytdl_hook] script-opts/ytdl_hook.conf not found. [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.config/mpv/lua-settings/ytdl_hook.conf' [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/home/roberto/.mpv/lua-settings/ytdl_hook.conf' [global] config path: 'lua-settings/ytdl_hook.conf' -/-> '/etc/mpv/lua-settings/ytdl_hook.conf' [ytdl_hook] lua-settings/ytdl_hook.conf not found. [stats] reading options for stats [global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.config/mpv/script-opts/stats.conf' [global] config path: 'script-opts/stats.conf' -/-> '/home/roberto/.mpv/script-opts/stats.conf' [global] config path: 'script-opts/stats.conf' -/-> '/etc/mpv/script-opts/stats.conf' [stats] script-opts/stats.conf not found. [global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.config/mpv/lua-settings/stats.conf' [global] config path: 'lua-settings/stats.conf' -/-> '/home/roberto/.mpv/lua-settings/stats.conf' [global] config path: 'lua-settings/stats.conf' -/-> '/etc/mpv/lua-settings/stats.conf' [stats] lua-settings/stats.conf not found. [global] config path: 'fonts' -/-> '/home/roberto/.config/mpv/fonts' [global] config path: 'fonts' -/-> '/home/roberto/.mpv/fonts' [global] config path: 'fonts' -/-> '/etc/mpv/fonts' [osd/libass] ASS library version: 0x1701000 (runtime 0x1701000) [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [global] config path: 'subfont.ttf' -/-> '/home/roberto/.config/mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/home/roberto/.mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.config/mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [osd/libass] Setting up fonts... [osc] reading options for osc [global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.config/mpv/script-opts/osc.conf' [global] config path: 'script-opts/osc.conf' -/-> '/home/roberto/.mpv/script-opts/osc.conf' [global] config path: 'script-opts/osc.conf' -/-> '/etc/mpv/script-opts/osc.conf' [osc] script-opts/osc.conf not found. [global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.config/mpv/lua-settings/osc.conf' [global] config path: 'lua-settings/osc.conf' -/-> '/home/roberto/.mpv/lua-settings/osc.conf' [global] config path: 'lua-settings/osc.conf' -/-> '/etc/mpv/lua-settings/osc.conf' [osc] lua-settings/osc.conf not found. [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Run command: define-section, flags=64, args=[name="input_console", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_console", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_console", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_console", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="showhide", contents="mouse_move script-binding osc/__keybinding1\nmouse_leave script-binding osc/__keybinding2\n", flags="force"] [cplayer] Run command: define-section, flags=64, args=[name="showhide_wc", contents="mouse_move script-binding osc/__keybinding3\nmouse_leave script-binding osc/__keybinding4\n", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="showhide", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: enable-section, flags=64, args=[name="showhide_wc", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input", contents="mbtn_left script-binding osc/__keybinding5\nshift+mbtn_left script-binding osc/__keybinding6\nmbtn_right script-binding osc/__keybinding7\nmbtn_mid script-binding osc/__keybinding8\nwheel_up script-binding osc/__keybinding9\nwheel_down script-binding osc/__keybinding10\nmbtn_left_dbl ignore\nshift+mbtn_left_dbl ignore\nmbtn_right_dbl ignore\n", flags="force"] [cplayer] Run command: define-section, flags=64, args=[name="input_stats", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input", flags=""] [cplayer] Run command: enable-section, flags=64, args=[name="input_stats", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="window-controls", contents="mbtn_left script-binding osc/__keybinding11\n", flags="force"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_stats", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="window-controls", flags=""] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_stats", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-visibility=auto"] [cplayer] Set property: shared-script-properties -> 1 [cplayer] Run command: disable-section, flags=64, args=[name="input"] [cplayer] Run command: disable-section, flags=64, args=[name="window-controls"] [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [cplayer] Set property: shared-script-properties -> 1 [cplayer] Done loading scripts. [global] config path: 'watch_later' -> '/home/roberto/.config/mpv/watch_later' [cplayer] Running hook: ytdl_hook/on_load [ytdl_hook] ytdl:// hook [ytdl_hook] not a ytdl:// url [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [cplayer] Set property: shared-script-properties -> 1 [osc] osc_init [ifo_dvdnav] Opening pedro pe 1080p 25fps h264.mp4 [bdmv/bluray] Opening pedro pe 1080p 25fps h264.mp4 [file] Opening pedro pe 1080p 25fps h264.mp4 [file] resize stream to 131072 bytes, drop 0 bytes [file] Stream opened successfully. [demux] Trying demuxers for level=normal. [demux] Trying demuxer: disc (force-level: normal) [demux] Trying demuxer: edl (force-level: normal) [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [cplayer] Set property: shared-script-properties -> 1 [global] config path: 'fonts' -/-> '/home/roberto/.config/mpv/fonts' [global] config path: 'fonts' -/-> '/home/roberto/.mpv/fonts' [global] config path: 'fonts' -/-> '/etc/mpv/fonts' [osd/libass] ASS library version: 0x1701000 (runtime 0x1701000) [osd/libass] libass API version: 0x1701000 [osd/libass] libass source: tarball: 0.17.1 [osd/libass] Shaper: FriBidi 1.0.8 (SIMPLE) HarfBuzz-ng 6.0.0 (COMPLEX) [global] config path: 'subfont.ttf' -/-> '/home/roberto/.config/mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/home/roberto/.mpv/subfont.ttf' [global] config path: 'subfont.ttf' -/-> '/etc/mpv/subfont.ttf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.config/mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/home/roberto/.mpv/fonts.conf' [global] config path: 'fonts.conf' -/-> '/etc/mpv/fonts.conf' [osd/libass] Setting up fonts... [demux] Trying demuxer: cue (force-level: normal) [demux] Trying demuxer: rawaudio (force-level: normal) [demux] Trying demuxer: rawvideo (force-level: normal) [demux] Trying demuxer: mkv (force-level: normal) [demux] Trying demuxer: libarchive (force-level: normal) [demux] Trying demuxer: lavf (force-level: normal) [osd/libass] Using font provider fontconfig [osd/libass] Done. [cplayer] Run command: define-section, flags=64, args=[name="input_osc", contents="", flags="default"] [cplayer] Run command: enable-section, flags=64, args=[name="input_osc", flags="allow-hide-cursor+allow-vo-dragging"] [cplayer] Run command: define-section, flags=64, args=[name="input_forced_osc", contents="", flags="force"] [cplayer] Run command: enable-section, flags=64, args=[name="input_forced_osc", flags="allow-hide-cursor+allow-vo-dragging"] [lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048. [demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat) [cplayer] Opening done: pedro pe 1080p 25fps h264.mp4 [find_files] Loading external files in . [global] config path: 'sub' -/-> '/home/roberto/.config/mpv/sub' [global] config path: 'sub' -/-> '/home/roberto/.mpv/sub' [global] config path: 'sub' -/-> '/etc/mpv/sub' [cplayer] Running hook: ytdl_hook/on_preloaded [osc] osc_init [lavf] select track 0 [cplayer] (+) Video --vid=1 (*) (h264 1920x1080 25.000fps) [vo/gpu] Probing for best GPU context. [vo/gpu/opengl] Initializing GPU context 'wayland' [vo/gpu/opengl] Initializing GPU context 'x11egl' [vo/gpu/x11] X11 opening display: :0.0 [vo/gpu/x11] X11 running at 1920x1080 (":0.0" => local display) [vo/gpu/x11] Detected wm supports NetWM. [vo/gpu/x11] Detected wm supports ABOVE state. [vo/gpu/x11] Detected wm supports BELOW state. [vo/gpu/x11] Detected wm supports FULLSCREEN state. [vo/gpu/x11] Detected wm supports STICKY state. [vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS [vo/gpu/x11] Current display FPS: 60.000000 [vo/gpu/opengl] EGL_VERSION=1.4 [vo/gpu/opengl] EGL_VENDOR=Mesa Project [vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES [vo/gpu/opengl] Trying to create Desktop OpenGL context. [vo/gpu/opengl] Chosen EGLConfig: [vo/gpu/opengl] EGL_CONFIG_ID=0x9 [vo/gpu/opengl] EGL_RED_SIZE=0x8 [vo/gpu/opengl] EGL_GREEN_SIZE=0x8 [vo/gpu/opengl] EGL_BLUE_SIZE=0x8 [vo/gpu/opengl] EGL_ALPHA_SIZE=0x0 [vo/gpu/opengl] EGL_COLOR_BUFFER_TYPE=0x308e [vo/gpu/opengl] EGL_CONFIG_CAVEAT=0x3038 [vo/gpu/opengl] EGL_CONFORMANT=0x4d [vo/gpu/opengl] EGL_NATIVE_VISUAL_ID=0x21 [vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21 [vo/gpu/x11] The XPresent extension was found. [vo/gpu/x11] XPresent disabled. [vo/gpu/opengl] GL_VERSION='3.1 Mesa 22.3.6' [vo/gpu/opengl] Detected desktop OpenGL 3.1. [vo/gpu/opengl] GL_VENDOR='Panfrost' [vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)' [vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40' [vo/gpu/opengl] Combined OpenGL extensions string: [vo/gpu/opengl] EGL_ANDROID_blob_cache EGL_CHROMIUM_sync_control EGL_ANGLE_sync_control_rate EGL_EXT_buffer_age EGL_EXT_image_dma_buf_import EGL_EXT_image_dma_buf_import_modifiers EGL_EXT_swap_buffers_with_damage EGL_KHR_cl_event2 EGL_KHR_config_attribs EGL_KHR_context_flush_control EGL_KHR_create_context EGL_KHR_create_context_no_error EGL_KHR_fence_sync EGL_KHR_get_all_proc_addresses EGL_KHR_gl_colorspace EGL_KHR_gl_renderbuffer_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_3D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_no_config_context EGL_KHR_partial_update EGL_KHR_reusable_sync EGL_KHR_surfaceless_context EGL_KHR_swap_buffers_with_damage EGL_EXT_pixel_format_float EGL_KHR_wait_sync EGL_MESA_configless_context EGL_MESA_drm_image EGL_MESA_image_dma_buf_export EGL_MESA_query_driver EGL_NOK_texture_from_pixmap GL_AMD_conservative_depth GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_multi_draw_indirect GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_stencil_export GL_AMD_shader_trinary_minmax GL_AMD_texture_texture4 GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_APPLE_packed_pixels GL_ARB_ES2_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_parallel_shader_compile GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counter_ops GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_draw_parameters GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_filter_anisotropic GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_window_pos GL_ATI_blend_equation_separate GL_ATI_draw_buffers GL_ATI_fragment_shader GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_EGL_image_storage GL_EXT_EGL_sync GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_texture GL_EXT_debug_label GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_framebuffer_fetch GL_EXT_shader_framebuffer_fetch_non_coherent GL_EXT_shader_image_load_formatted GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_R8 GL_EXT_texture_sRGB_RG8 GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_swizzle GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_INTEL_blackhole_render GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent GL_KHR_context_flush_control GL_KHR_debug GL_KHR_no_error GL_KHR_parallel_shader_compile GL_KHR_texture_compression_astc_ldr GL_KHR_texture_compression_astc_sliced_3d GL_MESA_pack_invert GL_MESA_shader_integer_functions GL_MESA_texture_signed_rgba GL_MESA_window_pos GL_NV_ES1_1_compatibility GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_image GL_NV_depth_clamp GL_NV_fog_distance GL_NV_half_float GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_OES_EGL_image GL_OES_read_format GL_S3_s3tc GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays [vo/gpu/opengl] Loaded extension GL_ARB_sync. [vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata. [vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary. [vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage. [vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store. [vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object. [vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays. [vo/gpu/opengl] Loaded extension GL_ARB_debug_output. [vo/gpu/opengl] Loaded extension GL_KHR_debug. [vo/gpu/opengl] Texture formats: [vo/gpu/opengl] NAME COMP*TYPE SIZE DEPTH PER COMP. [vo/gpu/opengl] r8 1*unorm 1B LF CR ST {8} [vo/gpu/opengl] rg8 2*unorm 2B LF CR ST {8 8} [vo/gpu/opengl] rgb8 3*unorm 3B LF CR ST {8 8 8} [vo/gpu/opengl] rgba8 4*unorm 4B LF CR ST {8 8 8 8} [vo/gpu/opengl] r16 1*unorm 2B LF CR ST {16} [vo/gpu/opengl] rg16 2*unorm 4B LF CR ST {16 16} [vo/gpu/opengl] rgb16 3*unorm 6B LF CR ST {16 16 16} [vo/gpu/opengl] rgba16 4*unorm 8B LF CR ST {16 16 16 16} [vo/gpu/opengl] r8ui 1*uint 1B CR ST {8} [vo/gpu/opengl] rg8ui 2*uint 2B CR ST {8 8} [vo/gpu/opengl] rgb8ui 3*uint 3B ST {8 8 8} [vo/gpu/opengl] rgba8ui 4*uint 4B CR ST {8 8 8 8} [vo/gpu/opengl] r16ui 1*uint 2B CR ST {16} [vo/gpu/opengl] rg16ui 2*uint 4B CR ST {16 16} [vo/gpu/opengl] rgb16ui 3*uint 6B ST {16 16 16} [vo/gpu/opengl] rgba16ui 4*uint 8B CR ST {16 16 16 16} [vo/gpu/opengl] r16f 1*float 4B LF CR ST {32/16} [vo/gpu/opengl] rg16f 2*float 8B LF CR ST {32/16 32/16} [vo/gpu/opengl] rgb16f 3*float 12B LF CR ST {32/16 32/16 32/16} [vo/gpu/opengl] rgba16f 4*float 16B LF CR ST {32/16 32/16 32/16 32/16} [vo/gpu/opengl] r32f 1*float 4B LF CR ST {32} [vo/gpu/opengl] rg32f 2*float 8B LF CR ST {32 32} [vo/gpu/opengl] rgb32f 3*float 12B LF CR ST {32 32 32} [vo/gpu/opengl] rgba32f 4*float 16B LF CR ST {32 32 32 32} [vo/gpu/opengl] rgb10_a2 4*unorm 4B LF CR ST {0/10 0/10 0/10 0/2} [vo/gpu/opengl] rgba12 4*unorm 8B LF CR ST {16 16 16 16} [vo/gpu/opengl] rgb10 3*unorm 6B LF CR ST {16/10 16/10 16/10} [vo/gpu/opengl] rgb565 3*unorm 2B LF ST {0/8 0/8 0/8} [vo/gpu/opengl] LA = LUMINANCE_ALPHA hack format [vo/gpu/opengl] LF = linear filterable [vo/gpu/opengl] CR = can be used for render targets [vo/gpu/opengl] ST = can be used for storable images [vo/gpu/opengl] Image formats: [vo/gpu/opengl] yuv444p => 3 planes 1x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p => 3 planes 2x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] gray => 1 planes 1x1 8/0 [r8] (r) [unorm] [vo/gpu/opengl] gray16 => 1 planes 1x1 16/0 [r16] (r) [unorm] [vo/gpu/opengl] uyvy422 [vo/gpu/opengl] nv12 => 2 planes 2x2 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] p010 => 2 planes 2x2 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] argb => 1 planes 1x1 8/0 [rgba8] (argb) [unorm] [vo/gpu/opengl] bgra => 1 planes 1x1 8/0 [rgba8] (bgra) [unorm] [vo/gpu/opengl] abgr => 1 planes 1x1 8/0 [rgba8] (abgr) [unorm] [vo/gpu/opengl] rgba => 1 planes 1x1 8/0 [rgba8] (rgba) [unorm] [vo/gpu/opengl] bgr24 => 1 planes 1x1 8/0 [rgb8] (bgr) [unorm] [vo/gpu/opengl] rgb24 => 1 planes 1x1 8/0 [rgb8] (rgb) [unorm] [vo/gpu/opengl] 0rgb => 1 planes 1x1 8/0 [rgba8] (_rgb) [unorm] [vo/gpu/opengl] bgr0 => 1 planes 1x1 8/0 [rgba8] (bgr) [unorm] [vo/gpu/opengl] 0bgr => 1 planes 1x1 8/0 [rgba8] (_bgr) [unorm] [vo/gpu/opengl] rgb0 => 1 planes 1x1 8/0 [rgba8] (rgb) [unorm] [vo/gpu/opengl] rgba64 => 1 planes 1x1 16/0 [rgba16] (rgba) [unorm] [vo/gpu/opengl] rgb565 => 1 planes 1x1 0/0 [rgb565] (rgb) [unknown] [vo/gpu/opengl] pal8 [vo/gpu/opengl] vdpau [vo/gpu/opengl] d3d11 [vo/gpu/opengl] dxva2_vld [vo/gpu/opengl] mmal [vo/gpu/opengl] mediacodec [vo/gpu/opengl] cuda [vo/gpu/opengl] yap8 => 2 planes 1x1 8/0 [r8/r8] (r/a) [unorm] [vo/gpu/opengl] yap16 => 2 planes 1x1 16/0 [r16/r16] (r/a) [unorm] [vo/gpu/opengl] grayaf32 => 2 planes 1x1 32/0 [r16f/r16f] (r/a) [float] [vo/gpu/opengl] yuv444pf => 3 planes 1x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva444pf => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv420pf => 3 planes 2x2 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva420pf => 4 planes 2x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv422pf => 3 planes 2x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva422pf => 4 planes 2x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv440pf => 3 planes 1x2 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva440pf => 4 planes 1x2 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv410pf => 3 planes 4x4 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva410pf => 4 planes 4x4 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] yuv411pf => 3 planes 4x1 32/0 [r16f/r16f/r16f] (r/g/b) [float] [vo/gpu/opengl] yuva411pf => 4 planes 4x1 32/0 [r16f/r16f/r16f/r16f] (r/g/b/a) [float] [vo/gpu/opengl] rgb30 => 1 planes 1x1 10/0 [rgb10_a2] (bgr) [unknown] [vo/gpu/opengl] y1 => 1 planes 1x1 8/-7 [r8] (r) [unorm] [vo/gpu/opengl] gbrp1 => 3 planes 1x1 8/-7 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp2 => 3 planes 1x1 8/-6 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp3 => 3 planes 1x1 8/-5 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp4 => 3 planes 1x1 8/-4 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp5 => 3 planes 1x1 8/-3 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp6 => 3 planes 1x1 8/-2 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] vdpau_output [vo/gpu/opengl] vaapi [vo/gpu/opengl] videotoolbox [vo/gpu/opengl] drm_prime [vo/gpu/opengl] yuyv422 [vo/gpu/opengl] yuv422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv410p => 3 planes 4x4 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuv411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] monow [vo/gpu/opengl] monob [vo/gpu/opengl] yuvj422p => 3 planes 2x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] uyyvyy411 [vo/gpu/opengl] bgr8 [vo/gpu/opengl] bgr4 [vo/gpu/opengl] bgr4_byte [vo/gpu/opengl] rgb8 [vo/gpu/opengl] rgb4 [vo/gpu/opengl] rgb4_byte [vo/gpu/opengl] nv21 => 2 planes 2x2 8/0 [r8/rg8] (r/bg) [unorm] [vo/gpu/opengl] gray16be [vo/gpu/opengl] yuv440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuvj440p => 3 planes 1x2 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] yuva420p => 4 planes 2x2 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] rgb48be [vo/gpu/opengl] rgb48 => 1 planes 1x1 16/0 [rgb16] (rgb) [unorm] [vo/gpu/opengl] rgb565be [vo/gpu/opengl] rgb555be [vo/gpu/opengl] rgb555 [vo/gpu/opengl] bgr565be [vo/gpu/opengl] bgr565 [vo/gpu/opengl] bgr555be [vo/gpu/opengl] bgr555 [vo/gpu/opengl] yuv420p16 => 3 planes 2x2 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p16be [vo/gpu/opengl] yuv422p16 => 3 planes 2x1 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p16be [vo/gpu/opengl] yuv444p16 => 3 planes 1x1 16/0 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p16be [vo/gpu/opengl] rgb444 [vo/gpu/opengl] rgb444be [vo/gpu/opengl] bgr444 [vo/gpu/opengl] bgr444be [vo/gpu/opengl] ya8 => 1 planes 1x1 8/0 [rg8] (ra) [unorm] [vo/gpu/opengl] bgr48be [vo/gpu/opengl] bgr48 => 1 planes 1x1 16/0 [rgb16] (bgr) [unorm] [vo/gpu/opengl] yuv420p9be [vo/gpu/opengl] yuv420p9 => 3 planes 2x2 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p10be [vo/gpu/opengl] yuv420p10 => 3 planes 2x2 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p10be [vo/gpu/opengl] yuv422p10 => 3 planes 2x1 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p9be [vo/gpu/opengl] yuv444p9 => 3 planes 1x1 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p10be [vo/gpu/opengl] yuv444p10 => 3 planes 1x1 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p9be [vo/gpu/opengl] yuv422p9 => 3 planes 2x1 16/-7 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] gbrp => 3 planes 1x1 8/0 [r8/r8/r8] (g/b/r) [unorm] [vo/gpu/opengl] gbrp9be [vo/gpu/opengl] gbrp9 => 3 planes 1x1 16/-7 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp10be [vo/gpu/opengl] gbrp10 => 3 planes 1x1 16/-6 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp16be [vo/gpu/opengl] gbrp16 => 3 planes 1x1 16/0 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] yuva422p => 4 planes 2x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p => 4 planes 1x1 8/0 [r8/r8/r8/r8] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p9be [vo/gpu/opengl] yuva420p9 => 4 planes 2x2 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p9be [vo/gpu/opengl] yuva422p9 => 4 planes 2x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p9be [vo/gpu/opengl] yuva444p9 => 4 planes 1x1 16/-7 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p10be [vo/gpu/opengl] yuva420p10 => 4 planes 2x2 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p10be [vo/gpu/opengl] yuva422p10 => 4 planes 2x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p10be [vo/gpu/opengl] yuva444p10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva420p16be [vo/gpu/opengl] yuva420p16 => 4 planes 2x2 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva422p16be [vo/gpu/opengl] yuva422p16 => 4 planes 2x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p16be [vo/gpu/opengl] yuva444p16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] xyz12 => 1 planes 1x1 16/4 [rgb16] (rgb) [unorm] [vo/gpu/opengl] xyz12be [vo/gpu/opengl] nv16 => 2 planes 2x1 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] nv20 => 2 planes 2x1 16/-6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] nv20be [vo/gpu/opengl] rgba64be [vo/gpu/opengl] bgra64be [vo/gpu/opengl] bgra64 => 1 planes 1x1 16/0 [rgba16] (bgra) [unorm] [vo/gpu/opengl] yvyu422 [vo/gpu/opengl] ya16be [vo/gpu/opengl] ya16 => 1 planes 1x1 16/0 [rg16] (ra) [unorm] [vo/gpu/opengl] gbrap => 4 planes 1x1 8/0 [r8/r8/r8/r8] (g/b/r/a) [unorm] [vo/gpu/opengl] gbrap16be [vo/gpu/opengl] gbrap16 => 4 planes 1x1 16/0 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] qsv [vo/gpu/opengl] d3d11va_vld [vo/gpu/opengl] yuv420p12be [vo/gpu/opengl] yuv420p12 => 3 planes 2x2 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv420p14be [vo/gpu/opengl] yuv420p14 => 3 planes 2x2 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p12be [vo/gpu/opengl] yuv422p12 => 3 planes 2x1 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv422p14be [vo/gpu/opengl] yuv422p14 => 3 planes 2x1 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p12be [vo/gpu/opengl] yuv444p12 => 3 planes 1x1 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv444p14be [vo/gpu/opengl] yuv444p14 => 3 planes 1x1 16/-2 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] gbrp12be [vo/gpu/opengl] gbrp12 => 3 planes 1x1 16/-4 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] gbrp14be [vo/gpu/opengl] gbrp14 => 3 planes 1x1 16/-2 [r16/r16/r16] (g/b/r) [unorm] [vo/gpu/opengl] yuvj411p => 3 planes 4x1 8/0 [r8/r8/r8] (r/g/b) [unorm] [vo/gpu/opengl] bayer_bggr8 [vo/gpu/opengl] bayer_rggb8 [vo/gpu/opengl] bayer_gbrg8 [vo/gpu/opengl] bayer_grbg8 [vo/gpu/opengl] bayer_bggr16 [vo/gpu/opengl] bayer_bggr16be [vo/gpu/opengl] bayer_rggb16 [vo/gpu/opengl] bayer_rggb16be [vo/gpu/opengl] bayer_gbrg16 [vo/gpu/opengl] bayer_gbrg16be [vo/gpu/opengl] bayer_grbg16 [vo/gpu/opengl] bayer_grbg16be [vo/gpu/opengl] xvmc [vo/gpu/opengl] yuv440p10 => 3 planes 1x2 16/-6 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv440p10be [vo/gpu/opengl] yuv440p12 => 3 planes 1x2 16/-4 [r16/r16/r16] (r/g/b) [unorm] [vo/gpu/opengl] yuv440p12be [vo/gpu/opengl] ayuv64 => 1 planes 1x1 16/0 [rgba16] (argb) [unorm] [vo/gpu/opengl] ayuv64be [vo/gpu/opengl] p010be [vo/gpu/opengl] gbrap12be [vo/gpu/opengl] gbrap12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] gbrap10be [vo/gpu/opengl] gbrap10 => 4 planes 1x1 16/-6 [r16/r16/r16/r16] (g/b/r/a) [unorm] [vo/gpu/opengl] gray12be [vo/gpu/opengl] gray12 => 1 planes 1x1 16/-4 [r16] (r) [unorm] [vo/gpu/opengl] gray10be [vo/gpu/opengl] gray10 => 1 planes 1x1 16/-6 [r16] (r) [unorm] [vo/gpu/opengl] p016 => 2 planes 2x2 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p016be [vo/gpu/opengl] gray9be [vo/gpu/opengl] gray9 => 1 planes 1x1 16/-7 [r16] (r) [unorm] [vo/gpu/opengl] gbrpf32be [vo/gpu/opengl] gbrpf32 => 3 planes 1x1 32/0 [r16f/r16f/r16f] (g/b/r) [float] [vo/gpu/opengl] gbrapf32be [vo/gpu/opengl] gbrapf32 => 4 planes 1x1 32/0 [r16f/r16f/r16f/r16f] (g/b/r/a) [float] [vo/gpu/opengl] opencl [vo/gpu/opengl] gray14be [vo/gpu/opengl] gray14 => 1 planes 1x1 16/-2 [r16] (r) [unorm] [vo/gpu/opengl] grayf32be [vo/gpu/opengl] grayf32 => 1 planes 1x1 32/0 [r16f] (r) [float] [vo/gpu/opengl] yuva422p12be [vo/gpu/opengl] yuva422p12 => 4 planes 2x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] yuva444p12be [vo/gpu/opengl] yuva444p12 => 4 planes 1x1 16/-4 [r16/r16/r16/r16] (r/g/b/a) [unorm] [vo/gpu/opengl] nv24 => 2 planes 1x1 8/0 [r8/rg8] (r/gb) [unorm] [vo/gpu/opengl] nv42 => 2 planes 1x1 8/0 [r8/rg8] (r/bg) [unorm] [vo/gpu/opengl] vulkan [vo/gpu/opengl] y210be [vo/gpu/opengl] y210 [vo/gpu/opengl] x2rgb10be [vo/gpu/opengl] x2bgr10 [vo/gpu/opengl] x2bgr10be [vo/gpu/opengl] p210be [vo/gpu/opengl] p210 => 2 planes 2x1 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p410be [vo/gpu/opengl] p410 => 2 planes 1x1 16/6 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p216be [vo/gpu/opengl] p216 => 2 planes 2x1 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu/opengl] p416be [vo/gpu/opengl] p416 => 2 planes 1x1 16/0 [r16/rg16] (r/gb) [unorm] [vo/gpu] Testing FBO format rgba16f [vo/gpu] Resizing texture: 16x16 [vo/gpu] Using FBO format rgba16f. [vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1). [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Assuming 60.000000 FPS for display sync. [vd] Container reported FPS: 25.000000 [vd] Codec list: [vd] h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 [vd] h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper [vd] h264_cuvid (h264) - Nvidia CUVID H264 decoder [vd] Opening decoder h264 [vd] Looking at hwdec h264-drm... [vo/gpu] Loading hwdec drivers for format: 'drm_prime' [vo/gpu] Loading hwdec driver 'drmprime-overlay' [vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display. [vo/gpu] Loading failed. [vo/gpu] Loading hwdec driver 'drmprime' [vo/gpu/drmprime] using EGL dmabuf interop [vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128 [ffmpeg] AVHWDeviceContext: Opened DRM device /dev/dri/renderD128: driver panfrost version 1.3.0. [vd] Trying hardware decoding via h264-drm. [vd] Selected codec: h264 (H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10) [vf] User filter list: [vf] (empty) [cplayer] Starting playback... [vd] Pixel formats supported by decoder: vdpau cuda vaapi drm_prime yuv420p [vd] Codec profile: High (0x64) [vd] Requesting pixfmt 'drm_prime' from decoder. [ffmpeg/video] h264: Reinit context to 1920x1088, pix_fmt: drm_prime [vd] Using hardware decoding (drm). [vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 [vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [userdeint] (disabled) [vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [autorotate] (disabled) [vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vf] [convert] (disabled) [vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [cplayer] VO: [gpu] 1920x1080 drm_prime[nv12] [cplayer] VO: Description: Shader-based GPU Renderer [vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display SP=1.000000 CL=mpeg2/4/h264 [vo/gpu] max content size: 1920x1080 [vo/gpu] monitor size: 1920x1080 [vo/gpu/x11] not waiting for MapNotify [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu] Testing FBO format rgba16f [vo/gpu] Resizing texture: 16x16 [vo/gpu] Using FBO format rgba16f. [vo/gpu] No advanced processing required. Enabling dumb mode. [vo/gpu] Resize: 1920x1025 [vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0) [vo/gpu] Video source: 1920x1080 (1:1) [vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025 [vo/gpu] Video scale: 0.948958/0.949074 [vo/gpu] OSD borders: l=49 t=0 r=49 b=0 [vo/gpu] Video borders: l=49 t=0 r=49 b=0 [vo/gpu] Reported display depth: 8 [vo/gpu/opengl] vertex shader source: [vo/gpu/opengl] [ 1] #version 140 [vo/gpu/opengl] [ 2] #define tex1D texture [vo/gpu/opengl] [ 3] #define tex3D texture [vo/gpu/opengl] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [vo/gpu/opengl] [ 5] in vec2 vertex_position; [vo/gpu/opengl] [ 6] in vec2 vertex_texcoord0; [vo/gpu/opengl] [ 7] out vec2 texcoord0; [vo/gpu/opengl] [ 8] in vec2 vertex_texcoord1; [vo/gpu/opengl] [ 9] out vec2 texcoord1; [vo/gpu/opengl] [ 10] void main() { [vo/gpu/opengl] [ 11] gl_Position = vec4(vertex_position, 1.0, 1.0); [vo/gpu/opengl] [ 12] texcoord0 = vertex_texcoord0; [vo/gpu/opengl] [ 13] texcoord1 = vertex_texcoord1; [vo/gpu/opengl] [ 14] } [vo/gpu/opengl] fragment shader source: [vo/gpu/opengl] [ 1] #version 140 [vo/gpu/opengl] [ 2] #define tex1D texture [vo/gpu/opengl] [ 3] #define tex3D texture [vo/gpu/opengl] [ 4] #define LUT_POS(x, lut_size) mix(0.5 / (lut_size), 1.0 - 0.5 / (lut_size), (x)) [vo/gpu/opengl] [ 5] out vec4 out_color; [vo/gpu/opengl] [ 6] in vec2 texcoord0; [vo/gpu/opengl] [ 7] in vec2 texcoord1; [vo/gpu/opengl] [ 8] uniform mat3 colormatrix; [vo/gpu/opengl] [ 9] uniform vec3 colormatrix_c; [vo/gpu/opengl] [ 10] uniform vec3 src_luma; [vo/gpu/opengl] [ 11] uniform vec3 dst_luma; [vo/gpu/opengl] [ 12] uniform sampler2D texture0; [vo/gpu/opengl] [ 13] uniform vec2 texture_size0; [vo/gpu/opengl] [ 14] uniform mat2 texture_rot0; [vo/gpu/opengl] [ 15] uniform vec2 texture_off0; [vo/gpu/opengl] [ 16] uniform vec2 pixel_size0; [vo/gpu/opengl] [ 17] uniform sampler2D texture1; [vo/gpu/opengl] [ 18] uniform vec2 texture_size1; [vo/gpu/opengl] [ 19] uniform mat2 texture_rot1; [vo/gpu/opengl] [ 20] uniform vec2 texture_off1; [vo/gpu/opengl] [ 21] uniform vec2 pixel_size1; [vo/gpu/opengl] [ 22] void main() { [vo/gpu/opengl] [ 23] vec4 color = vec4(0.0, 0.0, 0.0, 1.0); [vo/gpu/opengl] [ 24] color.r = 1.000000 * vec4(texture(texture0, texcoord0)).r; [vo/gpu/opengl] [ 25] color.gb = 1.000000 * vec4(texture(texture1, texcoord1)).rg; [vo/gpu/opengl] [ 26] color = color.rgbr; [vo/gpu/opengl] [ 27] color.rgb = mat3(colormatrix) * color.rgb + colormatrix_c; [vo/gpu/opengl] [ 28] color.a = 1.0; [vo/gpu/opengl] [ 29] // color mapping [vo/gpu/opengl] [ 30] color.rgb *= vec3(1.000000); [vo/gpu/opengl] [ 31] color.rgb *= vec3(1.000000); [vo/gpu/opengl] [ 32] out_color = color; [vo/gpu/opengl] [ 33] } [vo/gpu/opengl] shader link log (status=1): [cplayer] first video frame after restart shown [cplayer] starting video playback [cplayer] playback restart complete @ 0.000000, audio=eof, video=playing [vo/gpu/x11] Disabling screensaver. [statusline] V: 00:00:00 / 00:02:24 (0%) [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:00 / 00:02:24 (0%) [osc] osc_init [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="append", value="osc-margins=0.000000,0.000000,0.000000,0.000000"] [cplayer] Set property: shared-script-properties -> 1 [statusline] V: 00:00:06 / 00:02:24 (4%) [cplayer] Run command: quit, flags=73, args=[code="0"] [cplayer] EOF code: 5 [vd] Uninit decoder. [cplayer] Terminating demuxers... [cplayer] Done terminating demuxers. [cplayer] finished playback, success (reason 3) [cplayer] [cplayer] Exiting... (Quit) [console] Exiting... [cplayer] Run command: change-list, flags=64, args=[name="shared-script-properties", operation="remove", value="osc-margins"] [ytdl_hook] Exiting... [cplayer] Set property: shared-script-properties -> 1 [stats] Exiting... [osc] Exiting... [vo/gpu/x11] Enabling screensaver. [vo/gpu] flushing shader cache [vo/gpu/x11] uninit . I inspected ffmpeg build configuration, and I see that ffmpeg 7.1.1 doesn't have "--enable-libv4l2", while ffmpeg 5.1.6 has that option. I checked with "ffmpeg -codecs|grep h264" In bookworm: Spoiler bookworm roberto@orangepizero3:~$ ffmpeg -codecs|grep h264 ffmpeg version 5.1.6-0+deb12u1 Copyright (c) 2000-2024 the FFmpeg developers built with gcc 12 (Debian 12.2.0-14) configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libv4l2 --enable-v4l2-request --enable-v4l2-m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared libavutil 57. 28.100 / 57. 28.100 libavcodec 59. 37.100 / 59. 37.100 libavformat 59. 27.100 / 59. 27.100 libavdevice 59. 7.100 / 59. 7.100 libavfilter 8. 44.100 / 8. 44.100 libswscale 6. 7.100 / 6. 7.100 libswresample 4. 7.100 / 4. 7.100 libpostproc 56. 6.100 / 56. 6.100 DEV.LS h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_cuvid ) (encoders: libx264 libx264rgb h264_nvenc h264_omx h264_v4l2m2m h264_vaapi ) In trixie Spoiler trixie roberto@orangepizero3:~$ ffmpeg -codecs|grep h264 ffmpeg version 7.1.1-1 Copyright (c) 2000-2025 the FFmpeg developers built with gcc 14 (Debian 14.2.0-19) configuration: --prefix=/usr --extra-version=1 --toolchain=hardened --libdir=/usr/lib/aarch64-linux-gnu --incdir=/usr/include/aarch64-linux-gnu --arch=arm64 --enable-gpl --disable-stripping --disable-libmfx --disable-omx --enable-gnutls --enable-libaom --enable-libass --enable-libbs2b --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libharfbuzz --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-v4l2-request --enable-v4l2_m2m --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libudev --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-openal --enable-opencl --enable-opengl --disable-sndio --disable-libvpl --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-ladspa --enable-libbluray --enable-libcaca --enable-libdvdnav --enable-libdvdread --enable-libjack --enable-libpulse --enable-librabbitmq --enable-librist --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libx264 --enable-libzmq --enable-libzvbi --enable-lv2 --enable-sdl2 --enable-libplacebo --enable-librav1e --enable-pocketsphinx --enable-librsvg --enable-libjxl --enable-shared libavutil 59. 39.100 / 59. 39.100 libavcodec 61. 19.101 / 61. 19.101 libavformat 61. 7.100 / 61. 7.100 libavdevice 61. 3.100 / 61. 3.100 libavfilter 10. 4.100 / 10. 4.100 libswscale 8. 3.100 / 8. 3.100 libswresample 5. 3.100 / 5. 3.100 libpostproc 58. 3.100 / 58. 3.100 DEV.LS h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 (decoders: h264 h264_v4l2m2m h264_cuvid) (encoders: libx264 libx264rgb h264_nvenc h264_v4l2m2m h264_vaapi h264_vulkan) Although, here the ffmpeg manual reads that this is option is only for webcams and videocapture https://www.ffmpeg.org/ffmpeg-devices.html#video4linux2_002c-v4l2 0 Quote
Ryzer Posted July 22 Posted July 22 On 7/21/2025 at 5:32 PM, robertoj said: I would try the cma=256M argument anyway... this kernel argument eliminated my video glitches and dma errors. Unfortunately an added challenge of the older SOC (A10, A13 & A20) generation is a limitation of the video engine which can only access the first 256MB of DRAM. I have tested this and found that the system becomes unresponsive as soon as we attempt media playback which confirms this is true. On 7/21/2025 at 5:32 PM, robertoj said: I don't know how a dtsi or dtbo parameter (loaded after linux is started) would override a kernel argument (given before the linux kernel is started). I dont yet know how it works under the hood but probably a similiar mechanism to how the kernel parses the dts in order to know what modules to load during the boot process. Allocation and ranges are set within the memory reserved node. reserved-memory { #address-cells = <1>; #size-cells = <1>; ranges; /* Address must be kept in the lower 256 MiBs of DRAM for VE. */ default-pool { compatible = "shared-dma-pool"; size = <0x6000000>; alloc-ranges = <0x40000000 0x10000000>; reusable; linux,cma-default; }; }; I have also tried increasing via overlay but it seems anything larger than 96MB gets disassociated from the dma pool. The first address that gets allocated is 0x4a000000. Trying via the extraargs method to specify a lower start address fails. Looks like the display buffers take a chunk out of CMA as well. Monitor disconnected: ryan@pcduino2-2:~$ cat /proc/meminfo | grep Cma CmaTotal: 98304 kB CmaFree: 98008 kB Monitor connected: CmaTotal: 98304 kB CmaFree: 89780 kB If I attempt to fast forward, playback falls back to software decoding and I get these errors in the log: [ 596.444060] cma: __cma_alloc: reserved: alloc failed, req-size: 1024 pages, ret: -16 [ 596.444103] cma: number of available pages: [ 596.444110] cma: range 0: 3@109+56@128+64@192+23@2281+8@4344+162@5726+162@7262+162@8798+162@10334+162@11870+162@ 13406+8@15608+8@17656+8@19704+162@21086+162@22622+418@24158 [ 596.444254] cma: [ 596.454008] cma: __cma_alloc: reserved: alloc failed, req-size: 350 pages, ret: -16 [ 596.454045] cma: number of available pages: l: [ 596.454052] cma: range 0: 3@109+56@128+64@192+23@2281+8@4344+162@5726+162@7262+162@8798+162@10334+162@11870+162@ 13406+8@15608+8@17656+8@19704+162@21086+162@22622+418@24158 0 Quote
robertoj Posted July 31 Posted July 31 I got hardware acceleration working in wayland+labwc, in Bookworm, Linux 6.15.4, self built armbian With a self-compiled labwc (instructions: https://forum.armbian.com/topic/53797-labwc-wayland-crashes-on-exit/#findComment-223267 ) And the ffmpeg instructions in the original post were used with no changes... plus the extraargs=cma=256M in armbianEnv.txt Side question: can anybody make hardware acceleration work in Trixie? 0 Quote
jock Posted July 31 Author Posted July 31 4 hours ago, robertoj said: Side question: can anybody make hardware acceleration work in Trixie? Unfortunately, lxc containers are not supplied anymore for armhf targets (see https://github.com/lxc/lxc-ci/commit/8d7326930f824a0aeedb6be3598c64e9e9a6ce36, I read somewhere the build machine has no 32bit compatibility anymore), hence building ffmpeg on Debian Trixie for armhf (32 bits) requires some more trickery. 0 Quote
robertoj Posted July 31 Posted July 31 Thank you but my use case is orange pi zero 3 and orange pi zero 2w… they are 64 bit H618 0 Quote
jock Posted July 31 Author Posted July 31 50 minutes ago, robertoj said: but my use case is orange pi zero 3 and orange pi zero 2w… they are 64 bit H618 Then Trixie arm64 is already supported BTW: just managed to use a trixie armhf armbian rootfs as a rootfs container for lxc... it just works, so packages are coming for trixie armhf too 😁 edit: trixie armhf packages added! 0 Quote
jock Posted August 9 Author Posted August 9 On 7/31/2025 at 11:56 PM, robertoj said: Thank you... I will try with trixie again some time It looks like mpv does not work anymore with v4l2request on trixie. Benchmarking with ffmpeg reports very high framerate on a 1080p h.265 video, but mpv refuses to work when --hwdec=v4l2request is chosen. It says a generic [vd] Could not create device. message in the log and switches to software rendering. Parameter --hwdec=v4l2request-copy works though, despite being slow because it involves framebuffer copy. 0 Quote
robertoj Posted August 10 Posted August 10 What is the difference between --hwdec=v4l2request and --hwdec=drm ? And drmprime, drmprime_overlay, and auto? Is the v4l2request absent from Trixie's mpv, due to a pre-compile configuration, or was it removed from the mpv source code? 0 Quote
jock Posted August 10 Author Posted August 10 @robertoj --hwdec=v4l2request seems present on mpv v0.40, which is the one in trixie. Older mpv versions have --hwdec=drm; I don't know the differences, but I guess drm become v4l2request at some point. --gpu-hwdec-interop=drmprime-overlay directly presents the frames using an hardware overlay. It is very useful if you want to go fullscreen (like on a virtual terminal), but if you are running a desktop environment, everything behind the video overlay will be hidden. --gpu-hwdec-interop=drmprime instead uses the linux facilities (dmabuf) to transfer the decoded frames from the hardware decoder buffer to the EGL/OpenGL (or whatever) presentation layer without actually copying the buffer data, but just passing a file handler. It is more complex and has more overhead, but it is suitable to be used within a desktop environment because the frames are drawn in regular windows. --gpu-hwdec-interop=auto don't know, I guess mpv does some guessing to decide which one is the best. 0 Quote
robertoj Posted September 26 Posted September 26 Has anybody had success with ffmpeg-v4l2request under Debian TRIXIE? I have seen successful reports from Jammy and Noble users... are they still having success? 0 Quote
jock Posted September 26 Author Posted September 26 2 hours ago, robertoj said: Has anybody had success with ffmpeg-v4l2request under Debian TRIXIE? From my tests, ffmpeg works fine with hardware acceleration under Debian Trixie, but packaged mpv (AFAIR it is v0.4.0) does always fails hardware decoding. 0 Quote
robertoj Posted September 26 Posted September 26 (edited) Instructions to build mpv, for anyone trying it with trixie... I don't see any pre-compilation options related to v4l2request https://forums.raspberrypi.com/viewtopic.php?t=360902#p2172777 https://github.com/mpv-player/mpv-build https://www.youtube.com/watch?v=KdyX3k8vOhw Edited September 26 by robertoj 0 Quote
JFL Posted September 27 Posted September 27 Device: Opi5-Plus. Have the same issue on Debian-Trixie kernel-6.16.8-edge-rockchip64 mpv (0.40.0_ deos not support vpu hardware acceleration. mpv --hwdec=v4l2request-copy is too slow to decode 4K/60 video, very high dropped frames. mpv --hwdec=v4l2request '/media/jfl/writable/home/jfl/Videos/Two Steps From Hell - Unleashed-15ZqpVOjZEc.mp4' ● Video --vid=1 (h264 1920x1080 60 fps) [default] ● Audio --aid=1 --alang=eng (aac 2ch 44100 Hz 128 kbps) [default] AO: [pipewire] 44100Hz stereo 2ch floatp VO: [gpu] 1920x1080 yuv420p AV: 00:00:04 / 00:05:41 (1%) A-V: 0.000 Exiting... (Quit) The is a mpv-full-git version @junari had build for arch linux which support v4l2request. The PKGBUILD https://github.com/iuncuim/manjaro-h616/blob/main/mpv-v4l2request/PKGBUILD Don't have experience to compile or build packages for Linux. Experience Armbian users and developers might be able to build the mpv-full-git for Debian Trixie. 0 Quote
Werner Posted September 27 Posted September 27 mainline support for rk3588 is still incomplete. If you need vpu stuff mostly work you need to use vendor kernel which is based on rockchip bsp. 0 Quote
jock Posted September 27 Author Posted September 27 7 hours ago, JFL said: Don't have experience to compile or build packages for Linux. Experience Armbian users and developers might be able to build the mpv-full-git for Debian Trixie. "Regular" mpv coming in Debian Bookworm works perfectly fine, as Bullseye did also. There should be no need for custom mpv builds, unless some features have been removed. 0 Quote
JFL Posted September 27 Posted September 27 Not sure whether is specific to Opi5-Plus, on Arch Linux mpv-0.40.0 somehow also did not support --hwdec=v4l2request as such had to resort to the mpv-full-git which supports --hwdec=v4l2request. Debian-Trixie's repo mpv-0.40.0 also doesn't seems to support --hwdec=v4l2request. 0 Quote
robertoj Posted Monday at 06:33 PM Posted Monday at 06:33 PM (edited) quoting JPL: Quote The is a mpv-full-git version @junari had build for arch linux which support v4l2request. The PKGBUILD https://github.com/iuncuim/manjaro-h616/blob/main/mpv-v4l2request/PKGBUILD Don't have experience to compile or build packages for Linux. Experience Armbian users and developers might be able to build the mpv-full-git for Debian Trixie. Did you see any announcement by the github's owner, about what we can expect from her/his source code? Looking at the content of the file, it seems like we need to download the code from: https://github.com/philipl/mpv#branch=v4l2request or https://github.com/philipl/mpv/tree/v4l2request And include this build-time configuration -Dv4l2request='enabled' I have posted instructions to build MPV on Sept 26 in this thread Warning: if you try compiling this MPV source package, don't try it in bookworm. You need Trixie to get the required libavcodec60+ dependency (and maybe others). Edited 11 hours ago by robertoj 0 Quote
robertoj Posted 11 hours ago Posted 11 hours ago On 9/27/2025 at 9:15 AM, JFL said: Not sure whether is specific to Opi5-Plus, on Arch Linux mpv-0.40.0 somehow also did not support --hwdec=v4l2request as such had to resort to the mpv-full-git which supports --hwdec=v4l2request. Debian-Trixie's repo mpv-0.40.0 also doesn't seems to support --hwdec=v4l2request. Did you mean that you had success getting HW acceleration in Arch Linux+mpv-0.40.0? Which github page did you use, and did you use the standard official instructions in that github page, to build? 0 Quote
JFL Posted 7 hours ago Posted 7 hours ago Hi @robertoj Quote Did you mean that you had success getting HW acceleration in Arch Linux+mpv-0.40.0? The stock mpv-0.40.0 from alarm-repo does not seem to support v4l2request so downloaded mpv-full-git with v4l2request from @junari (manjaro-arm user) https://drive.google.com/drive/folders/1hAr_PB52fIBcZOgtx2WoGghv63H1-JzB. Also downloaded the ffmpeg-v4l2request. Wtih the ffmpeg-v4l2request and mpv-full-git from @junari mpv vpu hardware acceleration works. Quote Which github page did you use, and did you use the standard official instructions in that github page, to build? Did not build/compile mpv-full-git (no experience in compliling/build packages in Linux) downloaded mpv-full-git. According to @jnuari, the mpv-full-git PKGBUILD: https://github.com/iuncuim/manjaro-h616/blob/main/mpv-v4l2request/PKGBUILD Hopefully you can modified this PKGBUILD to compile on Debian Trixie. 0 Quote
robertoj Posted 3 hours ago Posted 3 hours ago Yep... that looks like the method I had thought about: get the source from https://github.com/philipl/mpv.git#branch=v4l2request and compile it with the v4l2request option I have old experience making redhat rpms, but I need to learn how to make debian debs 0 Quote
