Posted (edited)
1 hour ago, jock said:
I compiled mpv 0.40.0 on Debian Trixie with the patches for v4l2request, but the outcome is messy at best. There is a new hwdec v4l2request, but also two new gpu-hwdec-interop v4l2request and v4l2request-overlay. It works with acceleration when launched from a terminal, but in wayland/weston v4l2request refuses to work. I don't know what happened, but it looks like a big regression from 0.39. Better use the old mpv version IMHO.
I thought that v4l2request was exclusively in this github project and branch: https://github.com/philipl/mpv/tree/v4l2request
Which github project and branch/release are you trying?
I successfully compiled and installed the mpv from https://github.com/philipl/mpv/tree/v4l2request
I made the /etc/mpv.conf as per the original post
Result: 50% cpu in 4 cores, about half dropped frames:
Spoiler
roberto@orangepizero3:~/mpv-philippl-v4l2request/mpv$ DISPLAY=:0.0 mpv -v ~/donde\ venderan\ buen\ trago\ 720p.mp4
[cplayer] Command line options: '-v' '/home/roberto/donde venderan buen trago 720p.mp4'
[cplayer] mpv v0.1.0-18356-g17a8ef7e8 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects
[cplayer]  built on Oct  5 2025 18:48:33
[cplayer] libplacebo version: v7.349.0
[cplayer] FFmpeg version: 7.1.1-1
[cplayer] FFmpeg library versions:
[cplayer]    libavcodec      61.19.101
[cplayer]    libavdevice     61.3.100
[cplayer]    libavfilter     10.4.100
[cplayer]    libavformat     61.7.100
[cplayer]    libavutil       59.39.100
[cplayer]    libswresample   5.3.100
[cplayer]    libswscale      8.3.100
[cplayer] Configuration:
[cplayer] List of enabled features: alsa build-date caca cdda cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 wayland-protocols-1-44 x11 xv zlib
[cplayer] Setting option 'v' = '' (flags = 😎
[clipboard] Initialized vo clipboard backend.
[cplayer] Waiting for scripts...
[cplayer] Set property: user-data/osc/visibility="auto" -> 1
[cplayer] Set property: user-data/osc/margins={"l":0,"b":0,"r":0,"t":0} -> 1
[cplayer] Done loading scripts.
[cplayer] Running hook: auto_profiles/on_before_start_file
[cplayer] Failed sending hook command auto_profiles/on_before_start_file. Removing hook.
[cplayer] Running hook: auto_profiles/on_load
[cplayer] Failed sending hook command auto_profiles/on_load. Removing hook.
[cplayer] Running hook: ytdl_hook/on_load
[ytdl_hook] playlist hook
[ifo_dvdnav] Opening /home/roberto/donde venderan buen trago 720p.mp4
[bdmv/bluray] Opening /home/roberto/donde venderan buen trago 720p.mp4
[file] Opening /home/roberto/donde venderan buen trago 720p.mp4
[demux] Trying demuxers for level=normal.
[osd/libass] libass API version: 0x1703000
[osd/libass] libass source: tarball: 0.17.3
[osd/libass] Shaper: FriBidi 1.0.15 (SIMPLE) HarfBuzz-ng 10.2.0 (COMPLEX)
[osd/libass] Setting up fonts...
[lavf] Found 'mov,mp4,m4a,3gp,3g2,mj2' at score=100 size=2048.
[demux] Detected file format: mov,mp4,m4a,3gp,3g2,mj2 (libavformat)
[cplayer] Opening done: /home/roberto/donde venderan buen trago 720p.mp4
[osd/libass] Using font provider fontconfig
[osd/libass] Done.
[find_files] Loading external files in /home/roberto/
[cplayer] Running hook: auto_profiles/on_preloaded
[cplayer] Failed sending hook command auto_profiles/on_preloaded. Removing hook.
[cplayer] Running hook: ytdl_hook/on_preloaded
[lavf] select track 0
[lavf] select track 1
[cplayer] ● Video  --vid=1               (h264 1280x720 29.97 fps) [default]
[cplayer] ● Audio  --aid=1  --alang=eng  (aac 2ch 44100 Hz 128 kbps) [default]
[vo/gpu-next] Probing for best GPU context.
[vo/gpu-next/auto] Initializing GPU context 'auto'
[vo/gpu-next/vulkan] Initializing GPU context 'waylandvk'
[vo/gpu-next/libplacebo] Initialized libplacebo v7.349.0 (API v349)
[vo/gpu-next/libplacebo] Creating vulkan instance with extensions:
[vo/gpu-next/libplacebo]     VK_KHR_get_physical_device_properties2
[vo/gpu-next/libplacebo]     VK_KHR_portability_enumeration
[vo/gpu-next/libplacebo]     VK_KHR_surface
[vo/gpu-next/libplacebo]     VK_KHR_wayland_surface
[vo/gpu-next/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER
[vo/gpu-next/libplacebo] Failed initializing vulkan instance
[vo/gpu-next/vulkan] Initializing GPU context 'x11vk'
[vo/gpu-next/libplacebo]     VK_KHR_xlib_surface
[vo/gpu-next/opengl] Initializing GPU context 'wayland'
[vo/gpu-next/opengl] Initializing GPU context 'x11egl'
[vo/gpu-next/x11] X11 opening display: :0.0
[vo/gpu-next/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS
[vo/gpu-next/x11] Current display FPS: 60.000000
[vo/gpu-next/opengl] EGL_VERSION=1.5
[vo/gpu-next/opengl] EGL_VENDOR=Mesa Project
[vo/gpu-next/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[vo/gpu-next/opengl] Trying to create Desktop OpenGL context.
[vo/gpu-next/opengl] Choosing visual EGL config 0x9, visual ID 0x21
[vo/gpu-next/x11] The XPresent extension was found.
[vo/gpu-next/x11] XPresent enabled.
[vo/gpu-next/opengl] GL_VERSION='3.1 Mesa 25.0.7-2'
[vo/gpu-next/opengl] Detected desktop OpenGL 3.1.
[vo/gpu-next/opengl] GL_VENDOR='Mesa'
[vo/gpu-next/opengl] GL_RENDERER='Mali-G31 (Panfrost)'
[vo/gpu-next/opengl] GL_SHADING_LANGUAGE_VERSION='1.40'
[vo/gpu-next/opengl] Loaded extension GL_ARB_sync.
[vo/gpu-next/opengl] Loaded extension GL_ARB_timer_query.
[vo/gpu-next/opengl] Loaded extension GL_ARB_invalidate_subdata.
[vo/gpu-next/opengl] Loaded extension GL_ARB_get_program_binary.
[vo/gpu-next/opengl] Loaded extension GL_ARB_buffer_storage.
[vo/gpu-next/opengl] Loaded extension GL_ARB_shader_image_load_store.
[vo/gpu-next/opengl] Loaded extension GL_ARB_shader_storage_buffer_object.
[vo/gpu-next/opengl] Loaded extension GL_ARB_arrays_of_arrays.
[vo/gpu-next/opengl] Loaded extension GL_ARB_debug_output.
[vo/gpu-next/opengl] Loaded extension GL_KHR_debug.
[vo/gpu-next/libplacebo] Detected OpenGL version strings:
[vo/gpu-next/libplacebo]     GL_VERSION:  3.1 Mesa 25.0.7-2
[vo/gpu-next/libplacebo]     GL_VENDOR:   Mesa
[vo/gpu-next/libplacebo]     GL_RENDERER: Mali-G31 (Panfrost)
[vo/gpu-next/libplacebo]     GL_SHADING_LANGUAGE_VERSION: 1.40
[vo/gpu-next/libplacebo] GPU information:
[vo/gpu-next/libplacebo]     GLSL version: 140
[vo/gpu-next/libplacebo]       subgroup_size:             0
[vo/gpu-next/libplacebo]       min_gather_offset:         0
[vo/gpu-next/libplacebo]       max_gather_offset:         0
[vo/gpu-next/libplacebo]     Limits:
[vo/gpu-next/libplacebo]       thread_safe:               0
[vo/gpu-next/libplacebo]       callbacks:                 1
[vo/gpu-next/libplacebo]       max_buf_size:              18446744073709551615
[vo/gpu-next/libplacebo]       max_ubo_size:              65536
[vo/gpu-next/libplacebo]       max_ssbo_size:             134217728
[vo/gpu-next/libplacebo]       max_vbo_size:              18446744073709551615
[vo/gpu-next/libplacebo]       max_mapped_size:           18446744073709551615
[vo/gpu-next/libplacebo]       max_buffer_texels:         0
[vo/gpu-next/libplacebo]       align_host_ptr:            0
[vo/gpu-next/libplacebo]       host_cached:               0
[vo/gpu-next/libplacebo]       max_tex_1d_dim:            16384
[vo/gpu-next/libplacebo]       max_tex_2d_dim:            16384
[vo/gpu-next/libplacebo]       max_tex_3d_dim:            16384
[vo/gpu-next/libplacebo]       blittable_1d_3d:           0
[vo/gpu-next/libplacebo]       buf_transfer:              1
[vo/gpu-next/libplacebo]       align_tex_xfer_pitch:      4
[vo/gpu-next/libplacebo]       align_tex_xfer_offset:     32
[vo/gpu-next/libplacebo]       max_variable_comps:        16380
[vo/gpu-next/libplacebo]       max_constants:             0
[vo/gpu-next/libplacebo]       max_pushc_size:            0
[vo/gpu-next/libplacebo]       align_vertex_stride:       1
[vo/gpu-next/libplacebo]       fragment_queues:           1
[vo/gpu-next/libplacebo]       compute_queues:            0
[vo/gpu-next/libplacebo]     External API interop:
[vo/gpu-next/libplacebo]       UUID: 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
[vo/gpu-next/libplacebo]       PCI: 0000:00:00:0
[vo/gpu-next/libplacebo]       buf export caps: 0x0
[vo/gpu-next/libplacebo]       buf import caps: 0x0
[vo/gpu-next/libplacebo]       tex export caps: 0x8
[vo/gpu-next/libplacebo]       tex import caps: 0x8
[vo/gpu-next/libplacebo]       sync export caps: 0x0
[vo/gpu-next/libplacebo]       sync import caps: 0x0
[vo/gpu-next] Assuming 60.000000 FPS for display sync.
[vd] Container reported FPS: 29.970030
[vd] Codec list:
[vd]     h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vd]     h264_v4l2m2m (h264) - V4L2 mem2mem H.264 decoder wrapper
[vd]     h264_cuvid (h264) - Nvidia CUVID H264 decoder
[vd] Opening decoder h264
[vd] No hardware decoding requested.
[vd] Using software decoding.
[vd] Detected 4 logical cores.
[vd] Requesting 5 threads for decoding.
[vd] Selected decoder: h264 - H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
[vf] User filter list:
[vf]   (empty)
[ad] Codec list:
[ad]     aac - AAC (Advanced Audio Coding)
[ad]     aac_fixed (aac) - AAC (Advanced Audio Coding)
[ad] Opening decoder aac
[ad] Requesting 1 threads for decoding.
[ad] Selected decoder: aac - AAC (Advanced Audio Coding)
[af] User filter list:
[af]   (empty)
[cplayer] Starting playback...
[af] [in] 44100Hz stereo 2ch floatp
[af] [userspeed] 44100Hz stereo 2ch floatp
[af] [userspeed] (disabled)
[af] [convert] 44100Hz stereo 2ch floatp
[vd] DR failed - disabling.
[vd] Decoder format: 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vd] Using container aspect ratio.
[vf] [in] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vf] [userdeint] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vf] [userdeint] (disabled)
[vf] [autovflip] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vf] [autovflip] (disabled)
[vf] [autorotate] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vf] [autorotate] (disabled)
[vf] [convert] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vf] [convert] (disabled)
[vf] [out] 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[osd/libass] Done.
[ao] Trying audio driver 'pipewire'
[ao/pipewire] requested format: 44100 Hz, stereo channels, floatp
[ao/pipewire] Headers version: 1.4.2
[ao/pipewire] Library version: 1.4.2
[W][19:21:30.962233] pw.conf      | [          conf.c: 1182 try_load_conf()] can't load config client.conf: No such file or directory
[E][19:21:30.962448] pw.conf      | [          conf.c: 1215 pw_conf_load_conf_for_context()] can't load config client.conf: No such file or directory
[ao] Trying audio driver 'pulse'
[ao/pulse] requested format: 44100 Hz, stereo channels, floatp
[ao/pulse] Library version: 17.0.0
[ao/pulse] Proto: 35
[ao/pulse] Server proto: 35
[ao/pulse] Channel layouts:
[ao/pulse]  - #fl
[ao/pulse]  - #fr
[ao/pulse]  - #fc
[ao/pulse]  - #lfe
[ao/pulse]  - #bl
[ao/pulse]  - #br
[ao/pulse]  - #flc
[ao/pulse]  - #frc
[ao/pulse]  - #bc
[ao/pulse]  - #sl
[ao/pulse]  - #sr
[ao/pulse]  - #tc
[ao/pulse]  - #tfl
[ao/pulse]  - #tfc
[ao/pulse]  - #tfr
[ao/pulse]  - #tbl
[ao/pulse]  - #tbc
[ao/pulse]  - #tbr
[ao/pulse] result: stereo
[ao/pulse] device buffer: 6172 samples.
[ao/pulse] using soft-buffer of 8820 samples.
[cplayer] AO: [pulse] 44100Hz stereo 2ch float
[cplayer] AO: Description: PulseAudio audio output
[autoconvert] inserting resampler
[swresample] format change, reinitializing resampler
[swresample] 44100Hz stereo floatp -> 44100Hz stereo float
[af] [out] 44100Hz stereo 2ch float
[cplayer] VO: [gpu-next] 1280x720 yuv420p
[cplayer] VO: Description: Video output based on libplacebo
[vo/gpu-next] reconfig to 1280x720 yuv420p bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0 A=none
[vo/gpu-next] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu-next] Video source: 1280x720 (1:1)
[vo/gpu-next] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720
[vo/gpu-next] Video scale: 1.000000/1.000000
[vo/gpu-next] OSD borders: l=0 t=0 r=0 b=0
[vo/gpu-next] Video borders: l=0 t=0 r=0 b=0
[vo/gpu-next/libplacebo] Dithering to 8 bit depth
[cplayer] first video frame after restart shown
[cplayer] audio ready
[cplayer] starting audio playback
[vo/gpu-next/x11] Disabling screensaver.
[cplayer] playback restart complete @ 0.000000, audio=playing, video=playing
[ao/pulse] starting AO
[vo/gpu-next/libplacebo] Detected fps ratio 0.0000 below threshold 0.0100, disabling interpolation
[vo/gpu-next/libplacebo] Detected fps ratio 0.5000 exceeds threshold 0.0100, re-enabling interpolation
[vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 9.990
[vo/gpu-next/libplacebo] Estimated source FPS: 29.970, display FPS: 14.985
[cplayer] EOF code: 5
[statusline] AV: 00:00:15 / 00:04:18 (6%) A-V:  0.000 Dropped: 283
[cplayer] finished playback, success (reason 3)
[cplayer] Running hook: ytdl_hook/on_after_end_file
[vo/gpu-next/x11] Enabling screensaver.
[cplayer] Exiting... (Quit)
I don't see any mention of hwdec=drm in the mpv log
I used the libplacebo from Trixie, not compiled on my own... I can try that next. <- final update for this post: libplacebo downloaded and built by myself did not help... but now I will try mpv 0.3.9
Edited by robertoj
mpv official github repo. v4l2request commits are in a pull request.
Posted (edited)
I am not sure if I am using the git command correctly to get mpv-0.3.9 with PR14690.. Please help
roberto@orangepizero3:~$ mkdir mpv-official
roberto@orangepizero3:~$ cd mpv-official/
roberto@orangepizero3:~/mpv-official$ git clone https://github.com/mpv-player/mpv
roberto@orangepizero3:~/mpv-official$ cd mpv
roberto@orangepizero3:~/mpv-official/mpv$ git checkout -b release/0.39
roberto@orangepizero3:~/mpv-official/mpv$ gh pr checkout 14690  <- downloads and applies the v4l2request changes :)
roberto@orangepizero3:~/mpv-official/mpv$ nano video/out/gpu/hwdec.c  <-- I see the added changes in the hwdec.c file
roberto@orangepizero3:~/mpv-official/mpv$ meson setup build  <-- everything configures ok, but at the end, it shows that I got mpv-0.40 :(
I asked in the mpv github and a contributor said they are waiting for ffmpeg first incorporate v4l2request, then they will add the feature in mpv
Ref: https://github.com/mpv-player/mpv/pull/14690#issuecomment-3369829206
Applying the pr14690 manually on top of mpv 0.3.9 is something that i could do, if there’s no choice
For later:
Use something like https://github.com/foo/bar/commit/${SHA}.patch , to try to get the PR14690
https://stackoverflow.com/questions/21903805/how-to-download-a-single-commit-diff-from-github
Patches to apply:
https://github.com/mpv-player/mpv/commit/d9bb7241bbc8dfdf1c76293d28cb162c2688e2b6.patch
https://github.com/mpv-player/mpv/commit/17a8ef7e8752e39f8c5284127b5d7ba1cce64f48.patch
Previous discussions and ffmpeg too:
https://github.com/mpv-player/mpv/pull/14511
https://ffmpeg.org/pipermail/ffmpeg-devel/2024-August/332034.html
https://ffmpeg.org/pipermail/ffmpeg-devel/2024-August/332035.html
How to patch.
Spoiler
* download the 2 patch files above
$ cd mpv
$ patch -p1 < 17a8ef7e8752e39f8c5284127b5d7ba1cce64f48.patch
patching file video/hwdec.c
patching file video/hwdec.h
Hunk #1 succeeded at 108 (offset -13 lines).
patching file video/out/gpu/hwdec.c
patching file video/out/hwdec/hwdec_drmprime.c
patching file video/out/hwdec/hwdec_drmprime_overlay.c
patching file video/out/vo_dmabuf_wayland.c
Hunk #1 FAILED at 857.
1 out of 1 hunk FAILED -- saving rejects to file video/out/vo_dmabuf_wayland.c.rej
patching file video/v4l2request.c
$ patch -p1 < d9bb7241bbc8dfdf1c76293d28cb162c2688e2b6.patch
patching file meson.build
Hunk #1 succeeded at 1406 (offset 1 line).
Hunk #2 succeeded at 1865 (offset -4 lines).
can't find file to patch at input line 44
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/meson.options b/meson.options
|index dae0a333ef71b..3dba7a1451dab 100644
|--- a/meson.options
|+++ b/meson.options
File to patch: meson_options.txt
patching file meson_options.txt
Hunk #1 succeeded at 101 (offset 2 lines).
Finally, I got this error since the first linking action
[307/310] Linking target mpv
FAILED: mpv
cc  -o mpv libmpv.so.2.3.0.p/aud...
(and over a thousand linking errors)
Edited by robertoj
Posted (edited)
Anyone trying to compile mpv 0.3.9, is it possible to do it with Linux 6.15? With the libraries in Debian Trixie?
(considering mpv 0.3.9 is from sept 2024, and Trixie came with mpv-0.4.0)
https://github.com/mpv-player/mpv/releases
I think I am failing the compilation's linking stage, because I had a different mpv and its libraries already installed. Probably I need to format my microSD and re-image.
Edited by robertoj
Posted (edited)
I was successful in compiling mpv-0.3.9 + the 2 patches from PR14690.
I downloaded the release mpv as a tar.gz, expanded it, and applied the 2 patches. One hunk failed but it wasnt needed
A 720p h264 video played with 10% CPU: (note that the options are --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v
Spoiler
roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ DISPLAY=:0.0 ./build/mpv --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v ~/donde\ venderan\ buen\ trago\ 720p.mp4
[cplayer] Command line options: '--hwdec=v4l2request' '--drm-drmprime-video-plane=primary' '--drm-draw-plane=overlay' '-v' '/home/roberto/donde venderan buen trago 720p.mp4'
[cplayer] mpv 0.39.0 Copyright © 2000-2024 mpv/MPlayer/mplayer2 projects
[cplayer]  built on Oct 10 2025 10:05:25
[cplayer] FFmpeg version: 7.1.2-0+deb13u1
[cplayer] List of enabled features: alsa build-date caca cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 x11 xv zlib
[cplayer] Setting option 'hwdec' = 'v4l2request' (flags = 😎
[cplayer] Setting option 'drm-drmprime-video-plane' = 'primary' (flags = 😎
[cplayer] Setting option 'drm-draw-plane' = 'overlay' (flags = 😎
[cplayer] Set property: user-data/osc/margins={"b":0,"l":0,"t":0,"r":0} -> 1
[osd/libass] Done.
[vo/gpu] Probing for best GPU context.
[vo/gpu/auto] Initializing GPU context 'auto'
[vo/gpu/opengl] Initializing GPU context 'wayland'
[vo/gpu/opengl] Initializing GPU context 'x11egl'
[vo/gpu/x11] X11 opening display: :0.0
[vo/gpu/x11] Display 0 (HDMI-1): [0, 0, 1920, 1080] @ 60.000000 FPS
[vo/gpu/x11] Current display FPS: 60.000000
[vo/gpu/opengl] EGL_VERSION=1.5
[vo/gpu/opengl] EGL_VENDOR=Mesa Project
[vo/gpu/opengl] EGL_CLIENT_APIS=OpenGL OpenGL_ES
[vo/gpu/opengl] Trying to create Desktop OpenGL context.
[vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x21
[vo/gpu/x11] The XPresent extension was found.
[vo/gpu/x11] XPresent enabled.
[vo/gpu/opengl] GL_VERSION='3.1 Mesa 25.0.7-2'
[vo/gpu/opengl] Detected desktop OpenGL 3.1.
[vo/gpu/opengl] GL_VENDOR='Mesa'
[vo/gpu/opengl] GL_RENDERER='Mali-G31 (Panfrost)'
[vo/gpu/opengl] GL_SHADING_LANGUAGE_VERSION='1.40'
[vo/gpu/opengl] Loaded extension GL_ARB_sync.
[vo/gpu/opengl] Loaded extension GL_ARB_timer_query.
[vo/gpu/opengl] Loaded extension GL_ARB_invalidate_subdata.
[vo/gpu/opengl] Loaded extension GL_ARB_get_program_binary.
[vo/gpu/opengl] Loaded extension GL_ARB_buffer_storage.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_image_load_store.
[vo/gpu/opengl] Loaded extension GL_ARB_shader_storage_buffer_object.
[vo/gpu/opengl] Loaded extension GL_ARB_arrays_of_arrays.
[vo/gpu/opengl] Loaded extension GL_ARB_debug_output.
[vo/gpu/opengl] Loaded extension GL_KHR_debug.
[vo/gpu] Testing FBO format rgba16f
[vo/gpu] Using FBO format rgba16f.
[vo/gpu] Disabling HDR peak computation (one or more of the following is not supported: compute shaders=0, SSBO=1).
[vo/gpu] Assuming 60.000000 FPS for display sync.
[vd] Codec list:
[vd] Looking at hwdec h264-v4l2request...
[vo/gpu] Loading hwdec drivers for format: 'drm_prime'
[vo/gpu] Loading hwdec driver 'drmprime'
[vo/gpu/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage
[vo/gpu/drmprime] Using DRM device: /dev/dri/renderD128
[vo/gpu] Loading hwdec driver 'drmprime-overlay'
[vo/gpu/drmprime-overlay] Failed to retrieve DRM fd from native display.
[vo/gpu] Loading failed.
[vo/gpu] Loading hwdec driver 'v4l2request'
[vo/gpu/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage
[vo/gpu] Loading hwdec driver 'v4l2request-overlay'
[vo/gpu/v4l2request-overlay] Failed to retrieve DRM fd from native display.
[vd] Trying hardware decoding via h264-v4l2request.
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
[vd] Pixel formats supported by decoder: vdpau vulkan cuda drm_prime vaapi yuv420p
[vd] Codec profile: Main (0x4d)
[vd] Requesting pixfmt 'drm_prime' from decoder.
[ffmpeg/video] h264: Using V4L2 media driver cedrus (6.15.4) for S264
[vd] Using hardware decoding (v4l2request).
[vd] Decoder format: 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1280x720+0+0
[vf] [in] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[vf] [userdeint] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[vf] [autorotate] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[vf] [convert] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[hwupload] hwdec 'drmprime' does not report hwframe constraints. Using static metadata.
[vf] [out] 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[W][10:19:43.740112] pw.conf      | [          conf.c: 1204 pw_conf_load_conf_for_context()] setting config.name to client-rt.conf is deprecated, using client.conf
[W][10:19:43.740371] pw.conf      | [          conf.c: 1182 try_load_conf()] can't load config client.conf: No such file or directory
[E][10:19:43.740422] pw.conf      | [          conf.c: 1215 pw_conf_load_conf_for_context()] can't load config client.conf: No such file or directory
[ao/pulse] Server proto: 4294967295
[ao/pulse]  - #fl
[ao/pulse]  - #fr
[ao/pulse]  - #fc
[ao/pulse]  - #lfe
[ao/pulse]  - #bl
[ao/pulse]  - #br
[ao/pulse]  - #flc
[ao/pulse]  - #frc
[ao/pulse]  - #bc
[ao/pulse]  - #sl
[ao/pulse]  - #sr
[ao/pulse]  - #tc
[ao/pulse]  - #tfl
[ao/pulse]  - #tfc
[ao/pulse]  - #tfr
[ao/pulse]  - #tbl
[ao/pulse]  - #tbc
[ao/pulse]  - #tbr
[cplayer] VO: [gpu] 1280x720 drm_prime[nv12]
[cplayer] VO: Description: Shader-based GPU Renderer
[vo/gpu] reconfig to 1280x720 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1280x720+0+0
[vo/gpu] Resize: 1280x720
[vo/gpu] Window size: 1280x720 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 1280x720 (1:1)
[vo/gpu] Video display: (0, 0) 1280x720 -> (0, 0) 1280x720
[vo/gpu] Video scale: 1.000000/1.000000
[vo/gpu] OSD borders: l=0 t=0 r=0 b=0
[vo/gpu] Video borders: l=0 t=0 r=0 b=0
[vo/gpu] Reported display depth: 8
[vo/gpu] Dither to 8.
[osd/libass] Done.
[vo/gpu/x11] Disabling screensaver.
[vo/gpu/x11] Enabling screensaver.
[statusline] AV: 00:00:29 / 00:04:18 (11%) A-V:  0.000
Next, I tried with a 1080p h264... in this case, I needed the extraargs=cma=256M line in armbianEnv.txt.
Result, low CPU usage, but dropped frames (choppy video)
I didn't need to install mpv, because I ran it from within the build directory
Removing the --drm-drmprime-video-plane=primary --drm-draw-plane=overlay from the options didn't make any positive or negative difference
Spoiler
roberto@orangepizero3:~/mpv-official/mpv-0.39.0$ DISPLAY=:0.0 ./build/mpv --hwdec=v4l2request --drm-drmprime-video-plane=primary --drm-draw-plane=overlay -v ~/concert.mp4
[cplayer] Command line options: '--hwdec=v4l2request' '--drm-drmprime-video-plane=primary' '--drm-draw-plane=overlay' '-v' '/home/roberto/concert.mp4'
[bdmv/bluray] Opening /home/roberto/concert.mp4
[file] Opening /home/roberto/concert.mp4
[cplayer] Opening done: /home/roberto/concert.mp4
[osd/libass] Done.
[cplayer] ● Video  --vid=1  (h264 1920x1080 30 fps) [default]
[vd] Container reported FPS: 30.000000
[vd] Codec list:
[vf]   (empty)
[vd] Codec profile: High (0x64)
[vd] Decoder format: 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/auto CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [in] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [userdeint] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [autorotate] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [convert] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vf] [out] 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[osd/libass] Done.
[cplayer] VO: [gpu] 1920x1080 drm_prime[nv12]
[vo/gpu] reconfig to 1920x1080 drm_prime[nv12] bt.709/bt.709/bt.1886/limited/display CL=mpeg2/4/h264 crop=1920x1080+0+0
[vo/gpu/x11] not waiting for MapNotify
[vo/gpu] Resize: 1920x1025
[vo/gpu] Window size: 1920x1025 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video source: 1920x1080 (1:1)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (49, 0) 1822x1025
[vo/gpu] Video scale: 0.948958/0.949074
[vo/gpu] OSD borders: l=49 t=0 r=49 b=0
[vo/gpu] Video borders: l=49 t=0 r=49 b=0
[cplayer] playback restart complete @ 0.000000, audio=eof, video=playing
[statusline] V: 00:00:20 / 00:04:49 (7%) Dropped: 415
I repeated the test with mpv-0.4.0 and the result was the same.
I am using linux 6.15.4... tomorrow I will re-test with linux 6.16.8 and again with labwc (wayland)
UPDATE: with labwc-0.8.3-1 (from Trixie repo), 720p playback is fine, and 1080p playback drops 220 frames over 10 seconds.
However it seems that it activates an X11 renderer, and XWayland appears in the htop list. <-- only if started from SSH session, with "DISPLAY=:0"
How can I ensure that pure wayland is used? <-- answer: start mpv from within a terminal in labwc, like foot
mpv log:
Spoiler
roberto@orangepizero3:~/mpv-official/mpv-0.40.0$ DISPLAY=:0 ./build/mpv --hwdec=v4l2request --loop -v ~/concert.mp4
[cplayer] Command line options: '--hwdec=v4l2request' '--loop' '-v' '/home/roberto/concert.mp4'
[cplayer] mpv v0.40.0 Copyright © 2000-2025 mpv/MPlayer/mplayer2 projects
[cplayer]  built on Oct 10 2025 10:50:55
[cplayer] List of enabled features: alsa build-date caca cdda cplugins debug dmabuf-interop-gl dmabuf-wayland drm dvbin dvdnav egl egl-drm egl-wayland egl-x11 ffmpeg gbm gl glibc-thread-name glob glob-posix gpl iconv jack javascript jpeg lcms2 libarchive libass libavdevice libbluray libdl libplacebo linux-fstatfs lua52 memfd-create memrchr pipewire posix posix-shm ppoll pthread-condattr-setclock pulse rubberband rubberband-3 sixel sndio sndio-1-9 uchardet v4l2request vaapi vaapi-drm vaapi-wayland vaapi-x11 vdpau vector vk-khr-display vt.h vulkan wayland wayland-protocols-1-32 wayland-protocols-1-38 wayland-protocols-1-39 wayland-protocols-1-41 x11 xv zlib
[cplayer] Setting option 'loop' = '' (flags = 😎
[ifo_dvdnav] Opening /home/roberto/concert.mp4
[osd/libass] Done.
[vo/gpu/vulkan] Initializing GPU context 'waylandvk'
[vo/gpu/libplacebo] Initialized libplacebo v7.349.0 (API v349)
[vo/gpu/libplacebo] Creating vulkan instance with extensions:
[vo/gpu/libplacebo]     VK_KHR_get_physical_device_properties2
[vo/gpu/libplacebo]     VK_KHR_portability_enumeration
[vo/gpu/libplacebo]     VK_KHR_surface
[vo/gpu/libplacebo]     VK_KHR_wayland_surface
[vo/gpu/libplacebo] Failed creating instance: VK_ERROR_INCOMPATIBLE_DRIVER
[vo/gpu/libplacebo] Failed initializing vulkan instance
[vo/gpu/vulkan] Initializing GPU context 'x11vk'
[vo/gpu/libplacebo]     VK_KHR_xlib_surface
[vo/gpu/x11] Display 0 (HDMI-A-1): [0, 0, 1920, 1080] @ 59.962844 FPS
[vo/gpu/x11] Current display FPS: 59.962844
[vo/gpu/opengl] Choosing visual EGL config 0x9, visual ID 0x40
[vo/gpu/x11] XPresent disabled.
[vo/gpu] Assuming 59.962844 FPS for display sync.
[vd] Codec list:
[vf]   (empty)
[osd/libass] Done.
[vo/gpu] Resize: 1920x1080
[vo/gpu] Window size: 1920x1080 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (0, 0) 1920x1080
[vo/gpu] Resize: 1918x1052
[vo/gpu] Window size: 1918x1052 (Borders: l=0 t=0 r=0 b=0)
[vo/gpu] Video display: (0, 0) 1920x1080 -> (24, 0) 1870x1052
[vo/gpu] Video scale: 0.973958/0.974074
[vo/gpu] OSD borders: l=24 t=0 r=24 b=0
[vo/gpu] Video borders: l=24 t=0 r=24 b=0
[statusline] V: 00:00:10 / 00:04:49 (4%) Dropped: 220
When I try mpv-0.3.9 (from the source folder, so I dont need to install it), I get the same result: v4l2request works perfectly in 720p, but choppy in 1080p
Edited by robertoj
Posted (edited)
Hello Jock,
Can you confirm that you use the patch in mpv PR1460, or something else?
--vo=gpu or -vo=gpu-next?
I installed mesa-vulkan-drivers today, with some difference in the mpv log, but same performance
I also get:
[vo/gpu-next/libplacebo] Found no suitable device, giving up.
[vo/gpu-next/libplacebo] Failed initializing vulkan device
and ...
Spoiler
[vo/gpu-next] Assuming 59.962844 FPS for display sync.
[vd] Codec list:
[vo/gpu-next] Loading hwdec drivers for format: 'drm_prime'
[vo/gpu-next] Loading hwdec driver 'drmprime'
[vo/gpu-next/drmprime] Using EGL dmabuf interop via GL_EXT_EGL_image_storage
[vo/gpu-next/drmprime] Using DRM device: /dev/dri/renderD128
[vo/gpu-next] Loading hwdec driver 'drmprime-overlay'
[vo/gpu-next/drmprime-overlay] Failed to retrieve DRM fd from native display.
[vo/gpu-next] Loading failed.
[vo/gpu-next] Loading hwdec driver 'v4l2request'
[vo/gpu-next/v4l2request] Using EGL dmabuf interop via GL_EXT_EGL_image_storage
[vo/gpu-next] Loading hwdec driver 'v4l2request-overlay'
[vo/gpu-next/v4l2request-overlay] Failed to retrieve DRM fd from native display.
[vd] Requesting 4 threads for decoding.
[vf]   (empty)
[ad] Codec list:
[af]   (empty)
Does it matter?
If I want to test the latest libplacebo route (with git clone https://code.videolan.org/videolan/libplacebo.git...) do I need to uninstall libplacebo and libplacebo-dev?
Edited by robertoj
I compiled mpv 0.40.0 and the commits from this PR. Results are mixed and situation is messier than before, so if you need hardware acceleration, it is better to go gstreamer or revert to debian bookworm for now.
Thank you. I meant to ask about that PR14690 :)
I would rather stay with trixie and low fps, because it seems easier to solve my other problem: need 100% wayland and 0% X11 due to a LCD driver problem.
AFAIK bookworm is fine with wayland (weston, kde, ...)
Posted (edited)
Has anybody tried compiling mpv-0.35 + PR14690 within Trixie and ffmpeg 7.x.x?
If anyone is curious... mpv-0.37 fails in the compilation step in ad-spdif.c due to an incompatible pointer
But mpv-0.38 (without patches) compiles successfully
Edited by robertoj
Posted (edited)
There's a new version of the kwiboo ffmpeg+v4l2request function
https://code.ffmpeg.org/Kwiboo/FFmpeg/src/branch/v4l2request-v3
And it was shown as a work in progress in the ffmpeg community
https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847
Then, it was noticed in the mpv community
https://github.com/mpv-player/mpv/pull/14690#issuecomment-3500141427
They previously said that v4l2request first needs to be integrated in ffmpeg officially, then mpv would start working on v4l2request
This is needed, to have mpv+v4l2request compiling successfully and working under Debian Trixie (my experience)
Edited by robertoj
You managed to build mpv with v4l2request for Debian Trixie that has vpu hardware acceleration? Care to share?
FWIW, HEVC support is queued for 6.19.
With WIP patches on top, rkvdec2 is also available to me. With the gstreamer framework, this works for me out-of-the-box, as the necessary support has been available in mainline for quite some time. See video-pipeline.pdffor reference.
I have already rebuilt the Huffman package with the patches mentioned above, but currently the developers of the distribution of my choice are busy rebuilding all packages that depend on it. As soon as the Huffman package is rolled out, I will start to see how HEVC performs with the FFMPEG framework.
Posted (edited)
No. I haven't tried anything new. My previous attempts compiling mpv in Trixie were unsuccessful.
I want to try it again by compiling and installing this new ffmpeg+v4l2 first, then trying compiling mpv again.
You should try it too :)
Edited by robertoj
Posted (edited)
The ffmpeg discussion posted a way to test the code (at the bottom of https://code.ffmpeg.org/FFmpeg/FFmpeg/pulls/20847 )
*install all the ffmpeg dependencies, then:
$ git fetch -u https://code.ffmpeg.org/Kwiboo/FFmpeg v4l2request-v3:Kwiboo-v4l2request-v3
$ git switch Kwiboo-v4l2request-v3
* compile and install
Then rebuild mpv+PR14690 (https://forum.armbian.com/topic/32449-repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner/page/5/#findComment-226567)
Edited by robertoj
Just out of curiosity, why are you trying to backport the v4l2request support?
Why not build the pull request tree directly:
git clone --branch v4l2request https://github.com/philipl/mpv.git mpv-player-v4l2request
I thought this was the best way: official latest mpv + pull request
i am not trying to backport it. I want to make it work in trixie.
