jock Posted January 8 Author Posted January 8 Yes, ffmpeg needs some patches (borrowed from LibreELEC project) to add support for v4l2request, which is in turn the interface for the kernel to use the hardware decoders on allwinner and rockchip platforms. 0 Quote
Дмитрий Батин Posted March 31 Posted March 31 (edited) Hello everyone, comrades! Please tell me, has anyone had success with opi 4 lts? If so, can you share the success scenario or the system image? My small success story is using a factory image. Orangepi4-lts_3.0.6_ubuntu_jammy_server_linux5.18.5 Then apt update && apt install mpv then i use this command line mpv --vo=gpu --drm-device=/dev/dri/card0 --hwdec=drm --cache=yes --loop-playlist --fs --input-ipc-server=/tmp/mpvsocket --audio-device=alsa/plughw:CARD=HDMI,DEV=0 /some_path_to_video 4 k 30 fps \ 4k 60fps \ h264 \ hevc decode by vpu vithout using CPU and do not have any freeze Скрытый текст Edited March 31 by Дмитрий Батин 0 Quote
jock Posted March 31 Author Posted March 31 UPDATE! Hello everyone, I'm glad to give a fresh update. After a couple of weeks and more or hard work, I finished the complete overhaul of the repository. It is now handled in a much tidier way. The result of this is a much easier support for new distributions as soon as they are published! I have just updated the instructions, since the old repository is no longer active; I suggest you to remove the old repository from you apt sources and install the new repository as described in first page. Packages for Noble Numbat are already available! Enjoy!💪 1 Quote
jock Posted April 1 Author Posted April 1 19 hours ago, Дмитрий Батин said: My small success story is using a factory image. Orangepi4-lts_3.0.6_ubuntu_jammy_server_linux5.18.5 No factory images here; I just tried an Armbian image with Ubuntu Noble and it worked flawlessy with XFCE, just need to disable the XFCE compositor to have full framerate. 0 Quote
Дмитрий Батин Posted April 1 Posted April 1 3 часа назад, jock сказал: Ubuntu Noble and it worked flawlessy with XFCE, just need to disable the XFCE compositor to have full framerate. how we can solve the problem with broken hdmi in 6.x releases ? Can we solve that using overlay ? 0 Quote
going Posted April 1 Posted April 1 4 часа назад, Дмитрий Батин сказал: how we can solve the problem with broken hdmi in 6.x releases ? Дмитрий, пожалуйста предоставьте дополнительную информацию. uname -r dmesg | grep -E 'hdmi|gpu|drm|codec' What brand of monitor and its resolution are used? My samsung 2k monitor cannot be detected by some linux kernels, for example. Although other users noted good performance at 1920x1080 resolution. 0 Quote
Дмитрий Батин Posted April 4 Posted April 4 (edited) 01.04.2025 в 20:25, going сказал: Дмитрий, пожалуйста предоставьте дополнительную информацию. orange pi 4 lts 4gb ram, 16gb emmc. TV - 4k LG Скрытый текст - there is terminal for 5.18-rk3399 (bsp) Скрытый текст root@bsVcore:~# uname -r 5.18.5-rk3399 root@bsVcore:~# dmesg | grep -E 'hdmi|gpu|drm|codec' [ 0.112287] platform ff940000.hdmi: Fixing up cyclic dependency with ff900000.vop [ 2.854491] vcca3v0_codec: supplied by vcc3v3_sys [ 2.861154] vcca1v8_codec: supplied by vcc3v3_sys [ 2.887793] vdd_gpu: supplied by vcc3v3_sys [ 6.625347] systemd[1]: Starting Load Kernel Module drm... [ 6.663773] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.664589] systemd[1]: Finished Load Kernel Module drm. [ 7.586926] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) [ 7.587072] [drm] unsupported AFBC format[3231564e] [ 7.588590] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) [ 7.589216] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) [ 7.589523] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 7.595687] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 7.602303] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops) [ 7.627249] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 7.669403] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 7.731546] panfrost ff9a0000.gpu: clock rate = 500000000 [ 7.762136] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 7.762147] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 7.762153] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 7.762158] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 7.793029] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 7.882366] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 7.892273] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 7.892957] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2 [ 7.899410] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 [ 8.089480] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device - there is edid-decode - Скрытый текст root@bsVcore:~# cat /sys/class/drm/card0-HDMI-A-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 1e 6d 01 00 01 01 01 01 01 1f 01 03 80 a0 5a 78 0a ee 91 a3 54 4c 99 26 0f 50 54 a1 08 00 31 40 45 40 61 40 71 40 81 80 d1 c0 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58 8a 00 40 84 63 00 00 1e 56 5e 00 a0 a0 a0 29 50 30 20 35 00 40 84 63 00 00 1e 00 00 00 fd 00 18 78 1e 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 47 20 54 56 20 53 53 43 52 32 0a 20 01 48 02 03 4f f1 5a 61 60 10 1f 66 65 04 13 05 14 03 02 12 20 21 22 15 01 5d 5e 5f 62 63 64 3f 40 29 09 57 07 15 07 50 55 07 00 6e 03 0c 00 20 00 b8 3c 2c 00 80 01 02 03 04 68 d8 5d c4 01 78 80 0b 02 e2 00 cf e3 05 c0 00 e3 06 0d 01 e2 0f 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 aa ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: GSM Model: 1 Serial Number: 16843009 Made in: week 1 of 2021 Basic Display Parameters & Features: Digital display Maximum image size: 160 cm x 90 cm Gamma: 2.20 RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6396, 0.3300 Green: 0.2998, 0.5996 Blue : 0.1503, 0.0595 White: 0.3125, 0.3291 Established Timings I & II: IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz Standard Timings: DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz GTF : 1152x864 60.000 Hz 4:3 53.700 kHz 81.624 MHz DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz DMT 0x52: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz Detailed Timing Descriptors: DTD 1: 3840x2160 60.000 Hz 16:9 135.000 kHz 594.000 MHz (1600 mm x 900 mm) Hfront 176 Hsync 88 Hback 296 Hpol P Vfront 8 Vsync 10 Vback 72 Vpol P DTD 2: 2560x1440 59.951 Hz 16:9 88.787 kHz 241.500 MHz (1600 mm x 900 mm) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 5 Vback 33 Vpol P Display Range Limits: Monitor ranges (GTF): 24-120 Hz V, 30-135 kHz H, max dotclock 600 MHz Display Product Name: 'LG TV SSCR2' Extension blocks: 1 Checksum: 0x48 ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 97: 3840x2160 60.000 Hz 16:9 135.000 kHz 594.000 MHz VIC 96: 3840x2160 50.000 Hz 16:9 112.500 kHz 594.000 MHz VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz VIC 31: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz VIC 102: 4096x2160 60.000 Hz 256:135 135.000 kHz 594.000 MHz VIC 101: 4096x2160 50.000 Hz 256:135 112.500 kHz 594.000 MHz VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz VIC 19: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz VIC 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 20: 1920x1080i 50.000 Hz 16:9 28.125 kHz 74.250 MHz VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz VIC 2: 720x480 59.940 Hz 4:3 31.469 kHz 27.000 MHz VIC 18: 720x576 50.000 Hz 16:9 31.250 kHz 27.000 MHz VIC 32: 1920x1080 24.000 Hz 16:9 27.000 kHz 74.250 MHz VIC 33: 1920x1080 25.000 Hz 16:9 28.125 kHz 74.250 MHz VIC 34: 1920x1080 30.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 21: 1440x576i 50.000 Hz 4:3 15.625 kHz 27.000 MHz VIC 1: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz VIC 93: 3840x2160 24.000 Hz 16:9 54.000 kHz 297.000 MHz VIC 94: 3840x2160 25.000 Hz 16:9 56.250 kHz 297.000 MHz VIC 95: 3840x2160 30.000 Hz 16:9 67.500 kHz 297.000 MHz VIC 98: 4096x2160 24.000 Hz 256:135 54.000 kHz 297.000 MHz VIC 99: 4096x2160 25.000 Hz 256:135 56.250 kHz 297.000 MHz VIC 100: 4096x2160 30.000 Hz 256:135 67.500 kHz 297.000 MHz VIC 63: 1920x1080 120.000 Hz 16:9 135.000 kHz 297.000 MHz VIC 64: 1920x1080 100.000 Hz 16:9 112.500 kHz 297.000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 192 96 48 44.1 32 Supported sample sizes (bits): 24 20 16 AC-3: Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Maximum bit rate: 640 kb/s Enhanced AC-3 (DD+): Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 2.0.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 300 MHz Supported Content Types: Cinema Game Extended HDMI video details: HDMI VICs: HDMI VIC 1: 3840x2160 30.000 Hz 16:9 67.500 kHz 297.000 MHz HDMI VIC 2: 3840x2160 25.000 Hz 16:9 56.250 kHz 297.000 MHz HDMI VIC 3: 3840x2160 24.000 Hz 16:9 54.000 kHz 297.000 MHz HDMI VIC 4: 4096x2160 24.000 Hz 256:135 54.000 kHz 297.000 MHz Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8: Version: 1 Maximum TMDS Character Rate: 600 MHz SCDC Present Supports UHD VIC Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding Supports Auto Low-Latency Mode Video Capability Data Block: YCbCr quantization: Selectable (via AVI YQ) RGB quantization: Selectable (via AVI Q) PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Colorimetry Data Block: BT2020YCC BT2020RGB HDR Static Metadata Data Block: Electro optical transfer functions: Traditional gamma - SDR luminance range SMPTE ST2084 Hybrid Log-Gamma Supported static metadata descriptors: Static metadata type 1 YCbCr 4:2:0 Capability Map Data Block: VIC 97: 3840x2160 60.000 Hz 16:9 67.500 kHz 297.000 MHz VIC 96: 3840x2160 50.000 Hz 16:9 56.250 kHz 297.000 MHz VIC 102: 4096x2160 60.000 Hz 256:135 67.500 kHz 297.000 MHz VIC 101: 4096x2160 50.000 Hz 256:135 56.250 kHz 297.000 MHz Checksum: 0xaa Edited April 4 by Дмитрий Батин 0 Quote
going Posted April 5 Posted April 5 23 часа назад, Дмитрий Батин сказал: ~# uname -r 5.18.5-rk3399 Unfortunately, there's nothing I can do to help you with this core. 23 часа назад, Дмитрий Батин сказал: TV - 4k LG I suspect that for other monitors the HDMI output will work. Just try to change the monitor, change the OS image to understand where the problem is. Пожалуйста попробуйте работу любого образа Armbian с этой страницы загрузки. https://www.armbian.com/orange-pi-4-lts/ If working on this image will have problems, please create a new theme with a name reflecting the essence of the problem. 0 Quote
Дмитрий Батин Posted April 7 Posted April 7 (edited) 05.04.2025 в 11:20, going сказал: Unfortunately, there's nothing I can do to help you with this core. There is new information - Armbian_23.5.1_Orangepi4-lts_jammy_current_6.1.30_minimal.img Armbian_23.8.1_Orangepi4-lts_bookworm_current_6.1.50_cinnamon_desktop.img - Скрытый текст root@orangepi4-lts:~# uname -r 6.1.30-rockchip64 root@orangepi4-lts:~# dmesg | grep -E 'hdmi|gpu|drm|codec' [ 0.091462] platform ff900000.vop: Fixed dependency cycle(s) with /hdmi@ff940000 [ 4.120782] panfrost ff9a0000.gpu: clock rate = 500000000 [ 4.125810] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 4.125836] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 4.125853] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 4.125872] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 4.131102] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 0 [ 10.280931] systemd[1]: Starting Load Kernel Module drm... [ 10.382296] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 10.384114] systemd[1]: Finished Load Kernel Module drm. [ 11.782891] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 11.785714] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 11.803394] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [ 11.803875] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 [ 11.864575] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) [ 11.864796] [drm] unsupported AFBC format[3231564e] [ 11.866571] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) [ 11.867230] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) [ 11.867445] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator [ 11.868407] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator [ 11.868743] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 11.870065] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops) [ 11.871573] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 11.872560] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1 [ 12.362246] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 12.927392] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 13.251842] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 14.219120] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn - there is edid-decode: - Скрытый текст root@orangepi4-lts:~# cat /sys/class/drm/card1-HDMI-A-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 1e 6d 01 00 01 01 01 01 01 1f 01 03 80 a0 5a 78 0a ee 91 a3 54 4c 99 26 0f 50 54 a1 08 00 31 40 45 40 61 40 71 40 81 80 d1 c0 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58 8a 00 40 84 63 00 00 1e 56 5e 00 a0 a0 a0 29 50 30 20 35 00 40 84 63 00 00 1e 00 00 00 fd 00 18 78 1e 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 47 20 54 56 20 53 53 43 52 32 0a 20 01 48 02 03 4f f1 5a 61 60 10 1f 66 65 04 13 05 14 03 02 12 20 21 22 15 01 5d 5e 5f 62 63 64 3f 40 29 09 57 07 15 07 50 55 07 00 6e 03 0c 00 20 00 b8 3c 2c 00 80 01 02 03 04 68 d8 5d c4 01 78 80 0b 02 e2 00 cf e3 05 c0 00 e3 06 0d 01 e2 0f 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 aa ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: GSM Model: 1 Serial Number: 16843009 Made in: week 1 of 2021 Basic Display Parameters & Features: Digital display Maximum image size: 160 cm x 90 cm Gamma: 2.20 RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6396, 0.3300 Green: 0.2998, 0.5996 Blue : 0.1503, 0.0595 White: 0.3125, 0.3291 Established Timings I & II: IBM : 720x400 70.082 Hz 9:5 31.467 kHz 28.320 MHz DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz Standard Timings: DMT 0x04: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz DMT 0x09: 800x600 60.317 Hz 4:3 37.879 kHz 40.000 MHz DMT 0x10: 1024x768 60.004 Hz 4:3 48.363 kHz 65.000 MHz GTF : 1152x864 60.000 Hz 4:3 53.700 kHz 81.624 MHz DMT 0x23: 1280x1024 60.020 Hz 5:4 63.981 kHz 108.000 MHz DMT 0x52: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz Detailed Timing Descriptors: DTD 1: 3840x2160 60.000 Hz 16:9 135.000 kHz 594.000 MHz (1600 mm x 900 mm) Hfront 176 Hsync 88 Hback 296 Hpol P Vfront 8 Vsync 10 Vback 72 Vpol P DTD 2: 2560x1440 59.951 Hz 16:9 88.787 kHz 241.500 MHz (1600 mm x 900 mm) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 5 Vback 33 Vpol P Display Range Limits: Monitor ranges (GTF): 24-120 Hz V, 30-135 kHz H, max dotclock 600 MHz Display Product Name: 'LG TV SSCR2' Extension blocks: 1 Checksum: 0x48 ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 97: 3840x2160 60.000 Hz 16:9 135.000 kHz 594.000 MHz VIC 96: 3840x2160 50.000 Hz 16:9 112.500 kHz 594.000 MHz VIC 16: 1920x1080 60.000 Hz 16:9 67.500 kHz 148.500 MHz VIC 31: 1920x1080 50.000 Hz 16:9 56.250 kHz 148.500 MHz VIC 102: 4096x2160 60.000 Hz 256:135 135.000 kHz 594.000 MHz VIC 101: 4096x2160 50.000 Hz 256:135 112.500 kHz 594.000 MHz VIC 4: 1280x720 60.000 Hz 16:9 45.000 kHz 74.250 MHz VIC 19: 1280x720 50.000 Hz 16:9 37.500 kHz 74.250 MHz VIC 5: 1920x1080i 60.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 20: 1920x1080i 50.000 Hz 16:9 28.125 kHz 74.250 MHz VIC 3: 720x480 59.940 Hz 16:9 31.469 kHz 27.000 MHz VIC 2: 720x480 59.940 Hz 4:3 31.469 kHz 27.000 MHz VIC 18: 720x576 50.000 Hz 16:9 31.250 kHz 27.000 MHz VIC 32: 1920x1080 24.000 Hz 16:9 27.000 kHz 74.250 MHz VIC 33: 1920x1080 25.000 Hz 16:9 28.125 kHz 74.250 MHz VIC 34: 1920x1080 30.000 Hz 16:9 33.750 kHz 74.250 MHz VIC 21: 1440x576i 50.000 Hz 4:3 15.625 kHz 27.000 MHz VIC 1: 640x480 59.940 Hz 4:3 31.469 kHz 25.175 MHz VIC 93: 3840x2160 24.000 Hz 16:9 54.000 kHz 297.000 MHz VIC 94: 3840x2160 25.000 Hz 16:9 56.250 kHz 297.000 MHz VIC 95: 3840x2160 30.000 Hz 16:9 67.500 kHz 297.000 MHz VIC 98: 4096x2160 24.000 Hz 256:135 54.000 kHz 297.000 MHz VIC 99: 4096x2160 25.000 Hz 256:135 56.250 kHz 297.000 MHz VIC 100: 4096x2160 30.000 Hz 256:135 67.500 kHz 297.000 MHz VIC 63: 1920x1080 120.000 Hz 16:9 135.000 kHz 297.000 MHz VIC 64: 1920x1080 100.000 Hz 16:9 112.500 kHz 297.000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 192 96 48 44.1 32 Supported sample sizes (bits): 24 20 16 AC-3: Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Maximum bit rate: 640 kb/s Enhanced AC-3 (DD+): Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 2.0.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 300 MHz Supported Content Types: Cinema Game Extended HDMI video details: HDMI VICs: HDMI VIC 1: 3840x2160 30.000 Hz 16:9 67.500 kHz 297.000 MHz HDMI VIC 2: 3840x2160 25.000 Hz 16:9 56.250 kHz 297.000 MHz HDMI VIC 3: 3840x2160 24.000 Hz 16:9 54.000 kHz 297.000 MHz HDMI VIC 4: 4096x2160 24.000 Hz 256:135 54.000 kHz 297.000 MHz Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8: Version: 1 Maximum TMDS Character Rate: 600 MHz SCDC Present Supports UHD VIC Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding Supports Auto Low-Latency Mode Video Capability Data Block: YCbCr quantization: Selectable (via AVI YQ) RGB quantization: Selectable (via AVI Q) PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Colorimetry Data Block: BT2020YCC BT2020RGB HDR Static Metadata Data Block: Electro optical transfer functions: Traditional gamma - SDR luminance range SMPTE ST2084 Hybrid Log-Gamma Supported static metadata descriptors: Static metadata type 1 YCbCr 4:2:0 Capability Map Data Block: VIC 97: 3840x2160 60.000 Hz 16:9 67.500 kHz 297.000 MHz VIC 96: 3840x2160 50.000 Hz 16:9 56.250 kHz 297.000 MHz VIC 102: 4096x2160 60.000 Hz 256:135 67.500 kHz 297.000 MHz VIC 101: 4096x2160 50.000 Hz 256:135 56.250 kHz 297.000 MHz Checksum: 0xaa Check this picture Скрытый текст Edited April 7 by Дмитрий Батин 0 Quote
Дмитрий Батин Posted April 7 Posted April 7 (edited) there is no display image in Armbian_24.2.1_Orangepi4-lts_bookworm_current_6.6.16_gnome_desktop.img Скрытый текст root@orangepi4-lts:~# uname -a Linux orangepi4-lts 6.6.16-current-rockchip64 #1 SMP PREEMPT Mon Feb 5 20:14:39 UTC 2024 aarch64 GNU/Linux root@orangepi4-lts:~# dmesg | grep -E 'hdmi|gpu|drm|codec' [ 0.097474] platform ff940000.hdmi: Fixed dependency cycle(s) with /vop@ff900000/port/endpoint@2 [ 1.464082] vcca3v0_codec: Bringing 1800000uV into 3000000-3000000uV [ 1.468678] vcca1v8_codec: Bringing 800000uV into 1800000-1800000uV [ 3.732837] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops) [ 3.734678] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops) [ 3.735179] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops) [ 3.735480] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator [ 3.735914] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator [ 3.736424] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.738238] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 3.744305] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops) [ 3.746166] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 3.914067] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 3.933701] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 4.236278] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 5.212004] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 7.149036] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 7.243113] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 7.244251] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 9.418902] panfrost ff9a0000.gpu: clock rate = 500000000 [ 9.493696] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 9.498186] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 9.498676] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video1 [ 9.498987] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video2 [ 9.502828] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 9.502867] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 9.502877] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 9.502888] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 9.630034] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 129.677038] hdmi-audio-codec hdmi-audio-codec.7.auto: Only one simultaneous stream supported! [ 129.677059] hdmi-audio-codec hdmi-audio-codec.7.auto: ASoC: error at snd_soc_dai_startup on i2s-hifi: -22 - edid decode - Скрытый текст root@orangepi4-lts:~# cat /sys/class/drm/card0-HDMI-A-1/edid | edid-decode edid-decode (hex): 00 ff ff ff ff ff ff 00 1e 6d 01 00 01 01 01 01 01 1f 01 03 80 a0 5a 78 0a ee 91 a3 54 4c 99 26 0f 50 54 a1 08 00 31 40 45 40 61 40 71 40 81 80 d1 c0 01 01 01 01 08 e8 00 30 f2 70 5a 80 b0 58 8a 00 40 84 63 00 00 1e 56 5e 00 a0 a0 a0 29 50 30 20 35 00 40 84 63 00 00 1e 00 00 00 fd 00 18 78 1e 87 3c 00 0a 20 20 20 20 20 20 00 00 00 fc 00 4c 47 20 54 56 20 53 53 43 52 32 0a 20 01 48 02 03 4f f1 5a 61 60 10 1f 66 65 04 13 05 14 03 02 12 20 21 22 15 01 5d 5e 5f 62 63 64 3f 40 29 09 57 07 15 07 50 55 07 00 6e 03 0c 00 20 00 b8 3c 2c 00 80 01 02 03 04 68 d8 5d c4 01 78 80 0b 02 e2 00 cf e3 05 c0 00 e3 06 0d 01 e2 0f 33 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 aa ---------------- Block 0, Base EDID: EDID Structure Version & Revision: 1.3 Vendor & Product Identification: Manufacturer: GSM Model: 1 Serial Number: 16843009 Made in: week 1 of 2021 Basic Display Parameters & Features: Digital display Maximum image size: 160 cm x 90 cm Gamma: 2.20 RGB color display First detailed timing is the preferred timing Color Characteristics: Red : 0.6396, 0.3300 Green: 0.2998, 0.5996 Blue : 0.1503, 0.0595 White: 0.3125, 0.3291 Established Timings I & II: IBM : 720x400 70.081663 Hz 9:5 31.467 kHz 28.320000 MHz DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz Standard Timings: DMT 0x04: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz DMT 0x09: 800x600 60.316541 Hz 4:3 37.879 kHz 40.000000 MHz DMT 0x10: 1024x768 60.003840 Hz 4:3 48.363 kHz 65.000000 MHz GTF : 1152x864 60.000000 Hz 4:3 53.700 kHz 81.624000 MHz DMT 0x23: 1280x1024 60.019740 Hz 5:4 63.981 kHz 108.000000 MHz DMT 0x52: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz Detailed Timing Descriptors: DTD 1: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz (1600 mm x 900 mm) Hfront 176 Hsync 88 Hback 296 Hpol P Vfront 8 Vsync 10 Vback 72 Vpol P DTD 2: 2560x1440 59.950550 Hz 16:9 88.787 kHz 241.500000 MHz (1600 mm x 900 mm) Hfront 48 Hsync 32 Hback 80 Hpol P Vfront 3 Vsync 5 Vback 33 Vpol P Display Range Limits: Monitor ranges (GTF): 24-120 Hz V, 30-135 kHz H, max dotclock 600 MHz Display Product Name: 'LG TV SSCR2' Extension blocks: 1 Checksum: 0x48 ---------------- Block 1, CTA-861 Extension Block: Revision: 3 Underscans IT Video Formats by default Basic audio support Supports YCbCr 4:4:4 Supports YCbCr 4:2:2 Native detailed modes: 1 Video Data Block: VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz VIC 16: 1920x1080 60.000000 Hz 16:9 67.500 kHz 148.500000 MHz VIC 31: 1920x1080 50.000000 Hz 16:9 56.250 kHz 148.500000 MHz VIC 102: 4096x2160 60.000000 Hz 256:135 135.000 kHz 594.000000 MHz VIC 101: 4096x2160 50.000000 Hz 256:135 112.500 kHz 594.000000 MHz VIC 4: 1280x720 60.000000 Hz 16:9 45.000 kHz 74.250000 MHz VIC 19: 1280x720 50.000000 Hz 16:9 37.500 kHz 74.250000 MHz VIC 5: 1920x1080i 60.000000 Hz 16:9 33.750 kHz 74.250000 MHz VIC 20: 1920x1080i 50.000000 Hz 16:9 28.125 kHz 74.250000 MHz VIC 3: 720x480 59.940060 Hz 16:9 31.469 kHz 27.000000 MHz VIC 2: 720x480 59.940060 Hz 4:3 31.469 kHz 27.000000 MHz VIC 18: 720x576 50.000000 Hz 16:9 31.250 kHz 27.000000 MHz VIC 32: 1920x1080 24.000000 Hz 16:9 27.000 kHz 74.250000 MHz VIC 33: 1920x1080 25.000000 Hz 16:9 28.125 kHz 74.250000 MHz VIC 34: 1920x1080 30.000000 Hz 16:9 33.750 kHz 74.250000 MHz VIC 21: 1440x576i 50.000000 Hz 4:3 15.625 kHz 27.000000 MHz VIC 1: 640x480 59.940476 Hz 4:3 31.469 kHz 25.175000 MHz VIC 93: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz VIC 94: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz VIC 95: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz VIC 98: 4096x2160 24.000000 Hz 256:135 54.000 kHz 297.000000 MHz VIC 99: 4096x2160 25.000000 Hz 256:135 56.250 kHz 297.000000 MHz VIC 100: 4096x2160 30.000000 Hz 256:135 67.500 kHz 297.000000 MHz VIC 63: 1920x1080 120.000000 Hz 16:9 135.000 kHz 297.000000 MHz VIC 64: 1920x1080 100.000000 Hz 16:9 112.500 kHz 297.000000 MHz Audio Data Block: Linear PCM: Max channels: 2 Supported sample rates (kHz): 192 96 48 44.1 32 Supported sample sizes (bits): 24 20 16 AC-3: Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Maximum bit rate: 640 kb/s Enhanced AC-3 (DD+): Max channels: 6 Supported sample rates (kHz): 48 44.1 32 Vendor-Specific Data Block (HDMI), OUI 00-0C-03: Source physical address: 2.0.0.0 Supports_AI DC_36bit DC_30bit DC_Y444 Maximum TMDS clock: 300 MHz Supported Content Types: Cinema Game Extended HDMI video details: HDMI VICs: HDMI VIC 1: 3840x2160 30.000000 Hz 16:9 67.500 kHz 297.000000 MHz HDMI VIC 2: 3840x2160 25.000000 Hz 16:9 56.250 kHz 297.000000 MHz HDMI VIC 3: 3840x2160 24.000000 Hz 16:9 54.000 kHz 297.000000 MHz HDMI VIC 4: 4096x2160 24.000000 Hz 256:135 54.000 kHz 297.000000 MHz Vendor-Specific Data Block (HDMI Forum), OUI C4-5D-D8: Version: 1 Maximum TMDS Character Rate: 600 MHz SCDC Present Supports UHD VIC Supports 12-bits/component Deep Color 4:2:0 Pixel Encoding Supports 10-bits/component Deep Color 4:2:0 Pixel Encoding Supports Auto Low-Latency Mode Video Capability Data Block: YCbCr quantization: Selectable (via AVI YQ) RGB quantization: Selectable (via AVI Q) PT scan behavior: No Data IT scan behavior: Supports both over- and underscan CE scan behavior: Supports both over- and underscan Colorimetry Data Block: BT2020YCC BT2020RGB HDR Static Metadata Data Block: Electro optical transfer functions: Traditional gamma - SDR luminance range SMPTE ST2084 Hybrid Log-Gamma Supported static metadata descriptors: Static metadata type 1 YCbCr 4:2:0 Capability Map Data Block: VIC 97: 3840x2160 60.000000 Hz 16:9 135.000 kHz 594.000000 MHz VIC 96: 3840x2160 50.000000 Hz 16:9 112.500 kHz 594.000000 MHz VIC 102: 4096x2160 60.000000 Hz 256:135 135.000 kHz 594.000000 MHz VIC 101: 4096x2160 50.000000 Hz 256:135 112.500 kHz 594.000000 MHz Checksum: 0xaa the latest noble Armbian_24.11.1_Orangepi4-lts_noble_current_6.6.62-kisak - Скрытый текст root@orangepi4-lts:~# root@orangepi4-lts:~# cat /sys/class/drm/card0-HDMI-A-1/modes 3840x2160 3840x2160 3840x2160 3840x2160 3840x2160 3840x2160 3840x2160 2560x1440 1920x1080 1920x1080 1920x1080 1920x1080 1920x1080 1920x1080i 1920x1080i 1920x1080 1920x1080i 1920x1080 1920x1080 1920x1080 1920x1080 1920x1080 1280x1024 1280x720 1280x720 1280x720 1024x768 800x600 720x576 720x480 720x480 720x480 720x480 root@orangepi4-lts:~# cat /sys/class/drm/card0-HDMI-A-1/ connector_id ddc/ device/ dpms edid enabled modes power/ status subsystem/ uevent root@orangepi4-lts:~# cat /sys/class/drm/card0-HDMI-A-1/status connected root@orangepi4-lts:~# cat /sys/class/drm/card0-HDMI-A-1/enabled disabled ^C root@orangepi4-lts:~# dmesg | grep -E 'hdmi|gpu|drm|codec' [ 0.080380] platform ff900000.vop: Fixed dependency cycle(s) with /hdmi@ff940000 [ 0.080488] platform ff8f0000.vop: Fixed dependency cycle(s) with /hdmi@ff940000 [ 0.080589] platform ff940000.hdmi: Fixed dependency cycle(s) with /vop@ff900000 [ 1.421271] vcca3v0_codec: Bringing 1800000uV into 3000000-3000000uV [ 1.425700] vcca1v8_codec: Bringing 800000uV into 1800000-1800000uV [ 3.431508] rockchip-drm display-subsystem: bound ff8f0000.vop (ops 0xffff8000811d6f68) [ 3.434836] rockchip-drm display-subsystem: bound ff900000.vop (ops 0xffff8000811d6f68) [ 3.435874] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 3.435974] rockchip-drm display-subsystem: bound fec00000.dp (ops 0xffff8000811dae90) [ 3.436237] dwhdmi-rockchip ff940000.hdmi: supply avdd-0v9 not found, using dummy regulator [ 3.436502] dwhdmi-rockchip ff940000.hdmi: supply avdd-1v8 not found, using dummy regulator [ 3.436797] dwhdmi-rockchip ff940000.hdmi: Detected HDMI TX controller v2.11a with HDCP (DWC HDMI 2.0 TX PHY) [ 3.440253] rockchip-drm display-subsystem: bound ff940000.hdmi (ops 0xffff8000811db1a8) [ 3.442269] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 0 [ 3.633228] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 3.640946] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device [ 3.951723] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 4.922516] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work] Not connected. Disabling cdn [ 6.314874] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 6.426707] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.427774] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 8.575319] panfrost ff9a0000.gpu: clock rate = 500000000 [ 8.625380] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0 [ 8.625395] panfrost ff9a0000.gpu: features: 00000000,00000407, issues: 00000000,24040400 [ 8.625401] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7 [ 8.625407] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1 [ 8.651957] [drm] Initialized panfrost 1.2.0 20180908 for ff9a0000.gpu on minor 1 [ 8.690945] rkvdec ff660000.video-codec: Adding to iommu group 1 [ 8.747445] hantro-vpu ff650000.video-codec: Adding to iommu group 0 [ 8.765480] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2 [ 8.791468] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3 root@orangepi4-lts:~# uname -a Linux orangepi4-lts 6.6.62-current-rockchip64 #2 SMP PREEMPT Sun Nov 17 14:08:59 UTC 2024 aarch64 aarch64 aarch64 GNU/Linux Edited April 7 by Дмитрий Батин 0 Quote
going Posted April 7 Posted April 7 2 часа назад, Дмитрий Батин сказал: Check this picture I wrote it in a private message. 0 Quote
going Posted April 15 Posted April 15 Allwinner h616-h618: After this pull request pull/8086 the 6.13 EDGE core supports hardware decoding. You can use the instructions: repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner Enjoy your viewing. 0 Quote
robertoj Posted April 18 Posted April 18 (edited) I tested NickA's armbian build, so I could get the cedrus+v4l2 improvements that would allow me to get h264 acceleration... but in my ili9488 I got these playback errors and 100% CPU usage with a 720p video in a 480x320 screen Spoiler roberto@orangepizero3:~$ DISPLAY=:0.0 mpv donde\ venderan\ buen\ trago\ 720p.mp4 (+) Video --vid=1 (*) (h264 1280x720 29.970fps) (+) Audio --aid=1 --alang=eng (*) (aac 2ch 44100Hz) libEGL warning: DRI2: failed to authenticate [vo/gpu/opengl] Suspected software renderer or indirect context. [vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device [vo/gpu/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. [vo/gpu/opengl/kms] No connected connectors found [vo/gpu/opengl] Failed to create KMS. libEGL warning: DRI2: failed to authenticate [vo/gpu-next/opengl] Suspected software renderer or indirect context. [vo/gpu-next] Can't handle VT release - signal already used [vo/gpu-next/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. [vo/gpu-next/opengl/kms] No connected connectors found [vo/gpu-next/opengl] Failed to create KMS. Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory [vo/vdpau] Error when calling vdp_device_create_x11: 1 [vo/xv] No Xvideo support found. [vo/sdl] Using opengl [vo/sdl] Warning: this legacy VO has bad performance. Consider fixing your graphics drivers, or not forcing the sdl VO. [W][01554.919773] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][01554.921633] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory AO: [alsa] 44100Hz stereo 2ch float VO: [sdl] 1280x720 yuv420p I will try with an HDMI LCD now: Spoiler DISPLAY=:0.0 mpv donde\ venderan\ buen\ trago\ 720p.mp4 (+) Video --vid=1 (*) (h264 1280x720 29.970fps) (+) Audio --aid=1 --alang=eng (*) (aac 2ch 44100Hz) libEGL warning: DRI2: failed to authenticate [vo/gpu/opengl] Suspected software renderer or indirect context. [vo/gpu] VT_GETMODE failed: Inappropriate ioctl for device [vo/gpu/opengl] Failed to set up VT switcher. Terminal switching will be unavailable. Using hardware decoding (drm). [W][00226.803020] pw.conf | [ conf.c: 939 try_load_conf()] can't load config client.conf: No such file or directory [E][00226.803389] pw.conf | [ conf.c: 963 pw_conf_load_conf_for_context()] can't load default config client.conf: No such file or directory AO: [alsa] 44100Hz stereo 2ch float VO: [gpu] 1280x720 drm_prime[nv12] [vo/gpu] Using HW-overlay mode. No GL filtering is performed on the video! [vo/gpu] Failed to commit atomic request (-22) AV: 00:00:00 / 00:04:18 (0%) A-V: -0.000 [vo/gpu] Failed to commit atomic request (-22) AV: 00:00:00 / 00:04:18 (0%) A-V: -0.000 [vo/gpu] Failed to commit atomic request (-22) AV: 00:00:00 / 00:04:18 (0%) A-V: -0.000 [vo/gpu] Failed to commit atomic request (-22) ... (typed command from an SSH session) The HDMI LCD just turns black. But I think this may be because I am using openbox... I think everyone else is using xfce UPDATE: I installed the xfce environment, selected it, and I still get a black LCD screen... I will try with the armbian official... does it now offer linux 6.13 with the edge kernel option? Edited April 18 by robertoj 0 Quote
robertoj Posted April 20 Posted April 20 (edited) I confirm I got my Orange Pi Zero 3 playing hardware decoded videos: * armbian official, built with the EDGE kernel 6.13.11, xfce environment * followed all the instructions in the first post of this thread * connected to a 1080p LCD monitor with HDMI * MPV plays a 1080p video with frame "tearing" with a window 800 pixels height. CPU usage 25% in all 4 cores * 720p video can be resized to almost full screen, but then it suffers tearing when resized larger. 10% to 15% CPU usage. * with all videos, when I try to play full screen, MPV plays the video every other frame, and shows a static frame (the frame that was showing when I double-clicked for full screen) UPDATE: without X11, to play videos on tty1, with an ili9488 LCD * check what drm connections are available: Spoiler $ mpv --drm-connector=help Available connectors for card 0 (/dev/dri/card1): SPI-1 (connected) Available connectors for card 1 (/dev/dri/card2): Cannot retrieve DRM resources: Operation not supported Available connectors for card 2 (/dev/dri/card0): HDMI-A-1 (disconnected) * find your connected DRM device, and run mpv from SSH $mpv --vo=drm --gpu-context=drm --drm-connector=SPI-1 myvideo.mp4 (+) Video --vid=1 (*) (h264 1920x1080 60.000fps) [vo/drm] VT_GETMODE failed: Inappropriate ioctl for device [vo/drm] Failed to set up VT switcher. Terminal switching will be unavailable. VO: [drm] 1920x1080 yuv420p {plays video in tty1 } A 360p video uses 15% in all cpus. 720p video->25% in all cpus. 1080p video->100% in all cpus It might be related to the fact that the SPI port is not hardware accelerated for video, like HDMI... but I will keep trying to get results similar to 720p... like scaling and changing framerate from the mpv command Press ctrl-c and mpv will exit Edited April 21 by robertoj 0 Quote
JFL Posted June 14 Posted June 14 Hi, Tried this Opi5-Plus with kernel-6.15.2-edge-rockchip64 but mpv doesn't seems to have vpu hardware acceleration Quote mpv https://www.youtube.com/watch?v=aqz-KE-bpKQ ● Video --vid=1 (h264 1920x1080 60 fps) [default] ● Audio --aid=1 (aac 6ch 48000 Hz 387 kbps) [default] File tags: Date: 20141110 Uploader: Blender Channel_URL: https://www.youtube.com/channel/UCSMOQeBJ2RAnuFungnQOxLg MESA: error: DRM_IOCTL_VIRTGPU_GET_CAPS failed with Bad file descriptor MESA: error: DRM_IOCTL_VIRTGPU_CONTEXT_INIT failed with Bad file descriptor, continuing without context... MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream [vo/gpu/libplacebo] Found no suitable device, giving up. [vo/gpu/libplacebo] Failed initializing vulkan device MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream MESA: error: DRM_VIRTGPU_RESOURCE_CREATE_BLOB failed with Bad file descriptor MESA: error: Failed to create virtgpu AddressSpaceStream [vo/gpu/libplacebo] Found no suitable device, giving up. [vo/gpu/libplacebo] Failed initializing vulkan device AO: [pipewire] 48000Hz 5.1 6ch floatp VO: [gpu] 1920x1080 yuv420p AV: 00:00:35 / 00:10:34 (6%) A-V: 0.000 Dropped: 6 Cache: 15s/7MB Exiting... (Quit) Does this repository works on RK3588 - Orange Pi 5 Plus Debian Trixie with mainline kernel 6.15.2-edge-rockchip64? 0 Quote
robertoj Posted July 4 Posted July 4 (edited) I haven't been able to use hardware acceleration ffmpeg in: * Orange Pi Zero 3 * self built image with Debian Trixie and Xfce desktop * Linux Edge 6.15.0 * Login in Xfce X11 mode * follow all the instructions in original post * mpv plays most mp4s VERY SMOOTHLY BUT WITH 100% CPU * The "Using hardware decoding (drm)" does not show * Instead, I get "hwdec unsupported=drm" * some resolutions will crash mpv with "Segmentation Fault" Edited July 13 by robertoj 0 Quote
robertoj Posted July 12 Posted July 12 (edited) Can someone tell me if Linux 6.14.8 or 6.15.4 supports this hardware acceleration? I can play 1080p H264, but with 100% CPU, with 6.14.8... and I get "unsuppoerted hwdec: drm" everytime I start mpv Edited July 12 by robertoj 0 Quote
robertoj Posted July 12 Posted July 12 (edited) On 4/15/2025 at 1:55 AM, going said: Allwinner h616-h618: After this pull request pull/8086 the 6.13 EDGE core supports hardware decoding. You can use the instructions: repository-for-v4l2request-hardware-video-decoding-rockchip-allwinner Enjoy your viewing. Are there any linux build config options needed to get the v4l2 functions? Can I assume that the improvements in 6.13.11 would be also in 6.15.4? No, the patches in pull/8086 are not in 6.14, 6.15 build/patch/kernel/archive/sunxi-6.13/patches.media vs the 6.14,6.15 folders Right now, linux-current is 6.12 and linux-edge is 6.15... I want to compile a Linux 6.13 Armbian OS... what specific linux version would I need to enter inside userpatches/lib.config ? KERNELBRANCH="tag:v6.13.xx" I tried building armbian 25.5.1 so I could get linux 6.14.x... but in the image file, there aren't the ko files mentioned in the pull/8086. For example: roberto@orangepizero3:~$ ls /lib/modules/6.14.5-edge-sunxi64/kernel/drivers/media/v4l2-core/ tuner.ko v4l2-cci.ko v4l2-fwnode.ko v4l2-jpeg.ko v4l2-vp9.ko v4l2-async.ko v4l2-dv-timings.ko v4l2-h264.ko v4l2-mem2mem.ko videodev.ko roberto@orangepizero3:~$ ls /lib/modules/6.14.5-edge-sunxi64/kernel/drivers/media/v4l2-core/v4l2-io* ls: cannot access '/lib/modules/6.14.5-edge-sunxi64/kernel/drivers/media/v4l2-core/v4l2-io*': No such file or directory Edited July 13 by robertoj 0 Quote
robertoj Posted July 13 Posted July 13 On 11/8/2024 at 6:56 AM, jock said: I may guess there are some missing pieces in the armbian kernel for allwinner: for rockchip, there are some patches borrowed from libreelec to make it work correctly with all formats. I don't know what is the status for allwinner and if there are similar patches and fixes that are not include right now, you won't be able to get anything. ffmpeg with v4l2request patches applied should work with any device which has a working v4l2request compliant drivers in the kernel, plus it also requires a properly working presentation framework for the DRM/DRMPrime and EGL parts, so there are several players involved: ffmpeg has to talk via v4l2-request to the kernel, the hardware decoding happens in the V4L2 drivers, but the presentation on screen happens within the kernel (DRM) and/or Mesa (EGL/OpenGL), bridged by DRMPRIME buffer sharing. I guess Mesa is pretty ok, since both Lima and Panfrost have the necessary bits in place to present things on screen, yet the Cedrus hardware decoder driver has to properly support hardware decoding and buffer sharing via drmprime with the GPU driver. I made some simplifications here and omitted details, but as you see it is already a fairly complex communication setup, of which ffmpeg is just the "user" of all those other services. Hello Jock, thank you for all the work bringing this video acceleration to our boards. Can you give an updated comment about what to download or how to build Armbian OS, and get the needed requirements, before we apply the ffmpeg repository? I haven't been able to get video acceleration for many months. Can you tell us what new kernel modules are needed also? 0 Quote
usual user Posted July 14 Posted July 14 FWIW rkvdec will be out of staging in 6.17 Be prepared to forward-port existing out-of-tree patches. cedrus has not seen much movement since a long time It can therefore be assumed that all necessary out-of-tree modifications from the past must be applied even with the latest kernel version. Since no mainline developments have taken place, no forward porting should be necessary. 0 Quote
robertoj Posted Tuesday at 05:10 PM Posted Tuesday at 05:10 PM (edited) On 7/13/2025 at 1:35 AM, robertoj said: Can you give an updated comment about what to download or how to build Armbian OS, and get the needed requirements, before we apply the ffmpeg repository? I haven't been able to get video acceleration for many months. Can you tell us what new kernel modules are needed also? Ok, I finally built armbian 25.5.1, to get Linux-edge 14.7 Bookworm + XFCE for my opiz3... and this time copy/pasted the whole build log to verify that: * the new patches mentioned in Pull Request 8086 were applied * the affected C files are compiled to .o files And then I tried the new ffmpeg-v4l2request with Bookworm's MPV, following the instructions in the original post.... I got the same result: 1080P plays smoothly, but with 100% CPU in all 4 cores. There's no error message of "unsupported hwdec=drm"... but there isn't any confirmation message from MPV either. (same behavior as with plain ffmpeg, from previous experiments) Edited Tuesday at 05:11 PM by robertoj 0 Quote
jaum20 Posted Tuesday at 10:59 PM Posted Tuesday at 10:59 PM Any way to use this to set up HW-ACC in jellyfin? I would like ti be able to perform audio transcode/remux 0 Quote
robertoj Posted Wednesday at 05:13 PM Posted Wednesday at 05:13 PM 18 hours ago, jaum20 said: Any way to use this to set up HW-ACC in jellyfin? I would like ti be able to perform audio transcode/remux Which arm board are you using? Do you have success with hardware acceleration with armbian? 0 Quote
Ryzer Posted Wednesday at 06:01 PM Posted Wednesday at 06:01 PM (edited) Interested in giving this a go again, a slight challenge is that the connection appears to timeout when using my home network: I did find that if instead use my phone for internet I can connect to the repo fine. If I where to manually download and install the debs, what is the correct order to do so? Are there any other dependencies which need to be installed? Edited Wednesday at 09:29 PM by Ryzer 0 Quote
robertoj Posted Wednesday at 07:44 PM Posted Wednesday at 07:44 PM (edited) Ryzer, you can navigate to the http link http://apt.undo.it:7242 click “pool” and all the other links until you see all the debs for download check you distribution recommended ffmpeg version with “apt list ffmpeg” download the matching deb versions: ffmpeg-x.x.x-v4l2request.deb, lib…x.x.x Sudo apt install ./lib…Deb (one by one) Sudo apt install./ffmpeg….deb sudo apt install mpv (from the original Armbian-configured repository) Edited Wednesday at 07:46 PM by robertoj 0 Quote
jaum20 Posted Thursday at 12:27 PM Posted Thursday at 12:27 PM 19 hours ago, robertoj said: Which arm board are you using? Do you have success with hardware acceleration with armbian? Orange Pi Zero 3. I followed the instrutions of the first post, but I can't test HA using mpv beacuse I am running a headless server 0 Quote
Ryzer Posted Thursday at 08:26 PM Posted Thursday at 08:26 PM I believe I have installed all the components as mpv seems to detect ffmpeg-v4l2-request. Unless adding --no-audio I get complaints about hdmi audio failing. From what I can tell mpv is at least trying to run on the video engine but something is not right:mpv-log.txt From when I tested this once before I got errors relating not being able to reserve enough memory (-12). I guess I need to hunt for cedrus patches as well as lowering CMA buffer size which conversely in the past allowed me to run a desktop image without crashing at boot. In truth the A10 is so old now that it is likely the video engine on will ever be fully supported. 0 Quote
