Timur Timaev Posted December 12, 2023 Posted December 12, 2023 Hello everyone! I was struggling to make wiring work on OrangePi 5 Plus armbian. Tried everything and came up with a solution that worked for me. I was constantly getting these errors: wiringPiSetup: mmap (PWM) failed: Operation not permitted wiringPiSetup: mmap (GPIO) failed: Operation not permitted I'm on 23.8.2. 1. Install armbian and update apt sudo apt update 2. As stated in OrangePi5Plus wiki page I got .deb installer for wiringPi on OrangePi Quote Note that wiringOP has been pre-installed in the linux image released by Orange Pi. Unless the code of wiringOP is updated, there is no need to re-download, compile and install, just use it directly. The storage path of the compiled wiringOP deb package in orangepi-build is: orangepi-build/external/cache/debs/arm64/wiringpi_x.xx.deb Now here's the link to this file: https://github.com/orangepi-xunlong/orangepi-build/blob/next/external/cache/debs/arm64/wiringpi_2.51.deb 3. The most important step was described here: https://github.com/Joshua-Riek/ubuntu-rockchip/issues/273 echo "BOARD=orangepi5plus" | sudo tee /etc/orangepi-release Somehow this solves the issue. No idea how these things work tbh... 4. Check if pins are detected via gpio readall or add sudo sudo gpio readall You should get a table with all the pins and numbers like this: 5. Install wiringop-python just as stated in the manual: http://www.orangepi.org/orangepiwiki/index.php/Orange_Pi_5_Plus#How_to_install_wiringOP-Python # get the dependencies sudo apt-get update sudo apt-get -y install git swig python3-dev python3-setuptools # clone wiringOP-python repo, the branch should be "next" and NOT "main" or "master" git clone --recursive https://github.com/orangepi-xunlong/wiringOP-Python -b next cd wiringOP-Python git submodule update --init --remote python3 generate-bindings.py > bindings.i sudo python3 setup.py install The wiringOP-Python should be working now. 2 Quote
armbianer123 Posted March 7, 2024 Posted March 7, 2024 (edited) I had some issues with "wiring" and getting the I2C and SPI interfaces on orange pi 5 plus working with armbian and wanted to link the source that had everything I needed. I just copy pasted the commands and got my BME280 sensor working nicely: guide on howto setup i2c and SPI on orange pi 5 plus with armbian Edited March 7, 2024 by armbianer123 0 Quote
OlegEnot Posted August 6, 2024 Posted August 6, 2024 I confirm on Armbian bookworm v24.5.5 stable, wiringOP expects a line in /etc/orangepi-release indicating the board name BOARD=orangepi5plus Maybe the build maintainer will include the change by default in the image for Orange Pi 5 Plus boards? 😊 0 Quote
Werner Posted August 6, 2024 Posted August 6, 2024 Would make more sense if the wiringop maintainers change to /etc/armbian-release since orangepi images are based on Armbian. They forked the framework years ago, did "sed s/armbian/orangepi/g" across the whole code and added hacks to make their boards somehow work. 0 Quote
OlegEnot Posted August 6, 2024 Posted August 6, 2024 Please tell me. I find it difficult to answer the question myself: Has Armbian always had BOARD=orangepi5-plus for the Orange Pi 5 Plus board and similarly in orangepi images? For the current Armbian cat /etc/armbian-release -> BOARD=orangepi5-plus, in turn wiringOP expects orangepi5plus. Don't judge strictly, 🙂 it would be interesting to come to some adequate solution, maybe create a request for inclusion in wiringop with the addition of the line else if (strncmp(revision, "orangepi5-plus.", 14) == 0) { *model = PI_MODEL_5_PLUS; } as an option. Thanks! 0 Quote
z28z34man Posted 16 hours ago Posted 16 hours ago (edited) I know I am bringing this back from the dead but i am having issued getting wiringop-python installed. with the fallowing i was able to do a gpio readall echo "BOARD=orangepi5plus" | sudo tee /etc/orangepi-release but when i get errors from the sudo python3 setup.py install. (wiringpi_warp.c:3901:29: error: implicit declaration of function 'getGpioNum' [-Wimplicit-function-declaration]) # get the dependencies sudo apt-get update sudo apt-get -y install git swig python3-dev python3-setuptools # clone wiringOP-python repo, the branch should be "next" and NOT "main" or "master" git clone --recursive https://github.com/orangepi-xunlong/wiringOP-Python -b next cd wiringOP-Python git submodule update --init --remote python3 generate-bindings.py > bindings.i sudo python3 setup.py install is there a fix for this? Edited 16 hours ago by z28z34man 0 Quote
z28z34man Posted 13 hours ago Posted 13 hours ago Just an FYI i just tried it with a different armbian version and it works fine. it works with Armbian_25.5.1_Orangepi5-plus_bookworm_current_6.12.28_xfce_desktop.img it doesn't work with Armbian_25.8.1_Orangepi5-plus_trixie_current_6.12.43_xfce_desktop.img 0 Quote
Werner Posted 7 hours ago Posted 7 hours ago Just a wild guess: The code from orangepi wiringpi is old and no longer compatible with newer python which is shipped in Trixie. 0 Quote
eselarm Posted 2 hours ago Posted 2 hours ago 13 hours ago, z28z34man said: I know I am bringing this back from the dead but i am having issued getting wiringop-python installed. Simple GPIO toggling has been a long term issue and it is clear to me that it need continued attention. I only use pin toggle on RPi1 and NanoPi-NEO, so BCM2735 and AllwinnerH3. I use generic Linux gpiod, still a bit a workaround for really proper handling, but it is OK for non-critical tasks at home. I used orignal WiringPi on RPi before (from Gordon), but many forks now. See also: https://forums.raspberrypi.com/viewtopic.php?t=369361 'latest' seems to be here: https://github.com/WiringPi/WiringPi?tab=readme-ov-file Note what is written under Ports w.r.t. Python. I guess Werner's guess is correct. I am not good at Python so prepared a bit for own C-code implementation, also w.r.t. high speed PWM. On AllwinnerH3 running Armbian Trixie, using the lgpio examples was easy to toggle a pin. I currently have Domoticz doing it, so also easy MQTT messaging, but it is overkill and also Domoticz build for ARMv6 is not available anymore (needed for RPi0/1), so already replaced that. 0 Quote
