I just installed latest Jammy on XU-4 and it was running fine off SD. Then I did nand-sata-install and you can see below what happened. This used to work fine with older versions.
sudo hdparm -Tt /dev/sda
/dev/sda:
 Timing cached reads:     2 MB in  5.54 seconds = 369.48 kB/sec
 Timing buffered disk reads:   2 MB in 10.33 seconds = 198.19 kB/sec
OK, tried this:
lsusb
Bus 004 Device 003: ID 174c:55aa ASMedia Technology Inc. ASM1051E SATA 6Gb/s bridge, ASM1053E SATA 6Gb/s bridge, ASM1153 SATA 3Gb/s bridge, ASM1153E SATA 6Gb/s bridge
sudo nano /etc/modprobe.d/disable-uas.conf
options usb-storage quirks=174c:55aa:u
/dev/sda:
 Timing cached reads:   656 MB in  2.00 seconds = 327.95 MB/sec
 Timing buffered disk reads:  62 MB in 35.03 seconds =   1.77 MB/sec
 lsusb -t
 /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/2p, 5000M
        |__ Port 1: Dev 3, If 0, Class=Mass Storage, Driver=uas, 5000M
        |__ Port 2: Dev 4, If 0, Class=Vendor Specific Class, Driver=r8152, 5000M
Still in UAS mode. Do you really need to recompile the kernel?
armbianEnv.txt doesn't exist on Armbian_23.11.1_Odroidxu4_jammy_current_6.1.63.img or Armbian_23.11.1_Odroidxu4_bookworm_current_6.1.63.img.
I built image from dev branch and same deal. Stable branch (23.11) dies and doesn't build.
Oh crap I just read on the download page
Run armbian-config utility and go to section system -> DTB and select optimized board configuration for Odroid HC1. The same config is valid for HC2 and MC1.
That creates the armbianEnv.txt file. I don't remember having to do that before. It's been a while since I've installed on XU4. OK that was it:
/dev/sda:
 Timing cached reads:   2042 MB in  2.00 seconds = 1022.35 MB/sec
 Timing buffered disk reads: 136 MB in  4.29 seconds =  31.68 MB/sec
