I have a question ...is it possible to run : Medion X10 (WiFi) remote control ?
Unfortunately, after the command irw
I do not get any information  ...... I'm not too good at linux :-(
Armbian system detects this as a pilot !
lsusb
Bus 006 Device 003: ID 0bc7:0006 X10 Wireless Technology, Inc. Wireless Transceiver (ACPI-compliant)
cat /proc/bus/input/devices
I: Bus=0003 Vendor=0bc7 Product=0006 Version=0100
N: Name="X10 WTI RF receiver"
P: Phys=usb-sunxi-ohci-1.2/input0
S: Sysfs=/devices/platform/sunxi-ohci.2/usb6/6-1/6-1.2/6-1.2:1.0/rc/rc1/input9
U: Uniq=
H: Handlers=kbd event9
B: PROP=0
B: EV=100013
B: KEY=108fcf32 ac10043 0 0 0 8 2008000 10180 80002801 9e9680 0 0 ffc
B: MSC=10
N: Name="X10 WTI RF receiver mouse"
P: Phys=usb-sunxi-ohci-1.2/input1
S: Sysfs=/devices/platform/sunxi-ohci.2/usb6/6-1/6-1.2/6-1.2:1.0/input/input10
U: Uniq=
H: Handlers=mouse3 event10
B: PROP=0
B: EV=7
B: KEY=1b0000 0 0 0 0 0 0 0 0
B: REL=3
lsmod
rfcomm                 32863  4
bnep                    9617  2
bluetooth             174065  8 bnep,rfcomm
mali_drm                2732  1
drm                   178255  2 mali_drm
snd_usb_audio          80300  2
snd_hwdep               5250  1 snd_usb_audio
snd_usbmidi_lib        17198  1 snd_usb_audio
snd_rawmidi            16402  1 snd_usbmidi_lib
ati_remote              7117  0
pcf8591                 3363  0
bmp085                  3487  0
mali                  123208  0
ump                    29379  3 mali
g_serial               27617  2
sunxi_cir               1601  0
8189fs               1050451  0
hid_logitech_dj        10040  0
This remote is not Infra Red but radio so there is no relation to "irw" which is a part of LIRC.
Did you try to use it under Armbian desktop?
Yes :-) ......
This pilot work on Linux ...
but on the router ..... and after the command irw showing the appropriate entries ! ?
This pilot work on Linux ...but on the router with alternative firmware Tomato ..... and after the command irw
I read somewhere that the standard drivers are bad: ati_remote ?
You can read more ... but in the Polish forum    :  https://openlinksys.info/forum/viewthread.php?thread_id=11511#post_103125
So you are saying this is a combo device, wireless and IR and you want to communicate with an Orane PI Lite on board IR sensor?
Check this:
http://linux-sunxi.org/LIRC
and other general how-to's regarding LIRC.
@kris777
Since this device is detected as an input device, you have to create a devinput based LIRC config for it.
Default config shipped with Armbian is designed to work with onboard IR receiver (or receiver connected to a dedicated pin on the pin header), so irw won't give you any output with your device.
Unfortunately this
will be your main problem, since in order to get ti to work, you need to create
  • An udev rule to create a permanent symlink for your device
  • a LIRC hardware config to point at your input device and to use the devinput node
  • a LIRC remote config defining button codes
Thank you for... any information
probably, unfortunately, I can not do
but I will try .... if I can let you know
sorry for my English :-(
Regards!
Not the pilot has its own sensor
Unfortunately, unless you have to compile drivers :-(
It's fun because you can control through the wall
armbian system does not work even command: sudo dpkg-reconfigure lirc  ( I can not install : lirc-modules-source )
rather, I have to use another remote control
Ps. remote control works with a dedicated sensor !... but
on another system ( beta ).....Armbian-5.25-Orangepilite-Ubuntu-xenial-3.4.113-desktop
start-up procedure is simple:
apt-get install lirc
# reconfigure lirc
Remote control configuration: ATI/NVidia/X10 RF Remote (userspace)
IR transmitter, if present: None !!!
configuration file lircd.conf here :
I ran up to two remotes simultaneously with the program mpc mpd ( internetradio )
regards!
I use now : ARMBIAN Debian GNU / Linux 8 (jessie) 3.4.112-sun8i ... It works a little better than xenial 3.4.113
I question whether you can in the future to add
lirc with properly working option : dpkg-reconfigure lirc
with a choice of drivers ?
