maxspoto Posted January 1 Posted January 1 Armbianmonitor: https://paste.armbian.com/utaruhokuc Hello everyone, and Happy New Year. One question about Orange Pi 5 Plus: i have installed a wifi module (supported than what the official Orange documentation reports) AX210NGW in my Orange Pi 5 Plus main board with Operating System: Armbian 23.11.1 bookworm and Kernel: Linux 5.10.160-legacy-rk35xx. I copied in /lib/firmware the firmware of the module (https://intel.ly/3S0QZrA). if from the terminal I run: lspci I see the device but in "Armbian-config" in hardware section don't see the wifi module, and I can't activate the module to surf the Internet or the local network in wifi. The question is: am I forgetting any steps to setup the wifi module correctly? 0 Quote
Werner Posted January 1 Posted January 1 Hm dtbo might be missing. Try rk3588-wifi-ap6275p.dts or rk3588-wifi-pcie.dts from here: https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-5.10-rk35xx/arch/arm64/boot/dts/rockchip/overlay 0 Quote
maxspoto Posted January 1 Author Posted January 1 Hello @Werner thanks for your suggestion. I have enabled (via armbian-config) the orangepi-5-ap6275p module (listed), see attached image (orangepi-5-ap6275p.jpg) I restarted the pi5plus board, but the wifi still isn't working. The wifi module is visible with lspci (see attached imagem - lspci.jpg) The Manage wireless networking section (on armbian-config) only displays the two Ethernet network cards, as the network cables have been disconnected. (see attached image wired_connection.jpg). Important some question: you suggested "Try rk3588-wifi-ap6275p.dts or rk3588-wifi-pcie.dts from here: https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-5.10-rk35xx/arch/arm64/boot/dts/rockchip/overlay" 1) OK, but Where should I copy the two files (rk3588-wifi-ap6275p.dts or rk3588-wifi-pcie.dts) you suggested? 2) Will I see the copied items in the list under the 'Toggle hardware configuration' section in armbian-config? 3) Do I need to enable both items (rk3588-wifi-ap6275p.dts or rk3588-wifi-pcie.dts)? Thanks 0 Quote
Werner Posted January 1 Posted January 1 Here's some info about overlays: https://docs.armbian.com/User-Guide_Allwinner_overlays/ 0 Quote
maxspoto Posted January 1 Author Posted January 1 Thank you @Werner, but I have read the documentation on overlays and do not have enough experience to make the changes myself. I also don't know how to create the dtbo file to put in the /boot/overlay/ folder. Anyway, thanks for the help. 0 Quote
Infinity Q Posted January 1 Posted January 1 check dmesg for errors pertaining to iwlwifi or intel, and make sure /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm does not exist 0 Quote
Solution Werner Posted January 2 Solution Posted January 2 Overlay might not even be necessary. Try installing armbian-firmware-full via apt. 0 Quote
Antimtr Posted April 12 Posted April 12 (edited) Please help me with the exact same problem with the exact same board, distro, and wifi card. I am very inexperienced with Linux and am having the same problem. Tried installing the firmware manually, tried running apt install armbian-full-firmware, and it ran through the whole rigamarole, but I'm still having trouble. Wifi module isn't in armbian-config, but it is in device list, wifi options are in the GUI, but doesn't find any networks. usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm DOES exist but I don't know how to delete it. Dmesg results in image https://ibb.co/17K58zJ Edited April 12 by Antimtr 0 Quote
royk Posted April 12 Posted April 12 @Antimtr Learn some basic commands first: https://ubuntu.com/tutorials/command-line-for-beginners#5-moving-and-manipulating-files sudo rm /usr/lib/firmware/iwlwifi-ty-a0-gf-a0.pnvm 0 Quote
Antimtr Posted April 12 Posted April 12 (edited) Thank you Royk! I've been learning a lot of commands--googled for an hour and couldn't find that remove command. I'll try it and update after. *Update* tried it and still getting wifi unavailable. Bizarrely, the Bluetooth is working fine. Smh. *Update 2* I threw the kitchen sink at it so I don't know which solution posted here finally worked, but after trying everything--i put the wifi into airplane mode then turned airplane mode off and the module activated! Signal strength is only 3 bars right next to my router though. I've turned power management off. Any easy way in armbian to give the card maximum voltage? Edited April 12 by Antimtr 0 Quote
