Liutas4x4 Posted January 6, 2024 Posted January 6, 2024 Not at the time of generation, but Armbian is stuck on reboot, not going to heartbeat led nor getting IP, and does nothing. I have no idea how it is related and what I should do to: - restore boot; - apply a key without ruining the installation. OMV 6.9.11-4 (Shaitan) on Armbian 23.8.1 Bullseye SBC RockPi-4A 4GB RAM with Penta SATA HAT (PCIe to SATA 4-channel for RAID + 1 eSATA). Eugenijus. 0 Quote
Werner Posted January 6, 2024 Posted January 6, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 4 minutes ago, Liutas4x4 said: 23.8.1 Outdated. 4 minutes ago, Liutas4x4 said: OMV Does plain Armbian work as expected. 0 Quote
Liutas4x4 Posted January 6, 2024 Author Posted January 6, 2024 - to run "armbianmonitor -u" I need to boot SBC, you see. - as for 23.8.1 - it is not supported anymore? Tell me which last bullseye minimal is current, please. - "Does plain Armbian work as expected." - I do not understand what you are saying. 0 Quote
Werner Posted January 6, 2024 Posted January 6, 2024 10 minutes ago, Liutas4x4 said: - as for 23.8.1 - it is not supported anymore? Tell me which last bullseye minimal is current, please. We can only afford to support the most recent version which is 23.11. Check https://www.armbian.com/rockpi4/ If there is none with Bullseye (old-stable btw.) userspace you can build your own image: https://github.com/armbian/build/ 11 minutes ago, Liutas4x4 said: I do not understand what you are saying. OMV heavily messes with the system and is known to cause all sorts of trouble. 0 Quote
Liutas4x4 Posted January 6, 2024 Author Posted January 6, 2024 Ok. If apt-get upgrade was not upgraded on my system by installation (I did not check that), I will go to find 23.11. OMV was working flawlessly for 2.5 years until I went to upgrade. 0 Quote
Liutas4x4 Posted January 6, 2024 Author Posted January 6, 2024 Created. Armbian-unofficial_23.11.0-trunk_Rockpi-4a_bullseye_current_6.1.63_minimal.img One day I will continue, but don't know when. Armbian-unofficial_23.11.0-trunk_Rockpi-4a_bullseye_current_6.1.63_minimal.img.txt 0 Quote
