Liutas4x4 Posted January 6 Posted January 6 Not at the time of generation, but Armbian is stuck on reboot, not going to heartbeat led nor getting IP, and does nothing. I have no idea how it is related and what I should do to: - restore boot; - apply a key without ruining the installation. OMV 6.9.11-4 (Shaitan) on Armbian 23.8.1 Bullseye SBC RockPi-4A 4GB RAM with Penta SATA HAT (PCIe to SATA 4-channel for RAID + 1 eSATA). Eugenijus. 0 Quote
Werner Posted January 6 Posted January 6 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 4 minutes ago, Liutas4x4 said: 23.8.1 Outdated. 4 minutes ago, Liutas4x4 said: OMV Does plain Armbian work as expected. 0 Quote
Liutas4x4 Posted January 6 Author Posted January 6 - to run "armbianmonitor -u" I need to boot SBC, you see. - as for 23.8.1 - it is not supported anymore? Tell me which last bullseye minimal is current, please. - "Does plain Armbian work as expected." - I do not understand what you are saying. 0 Quote
Werner Posted January 6 Posted January 6 10 minutes ago, Liutas4x4 said: - as for 23.8.1 - it is not supported anymore? Tell me which last bullseye minimal is current, please. We can only afford to support the most recent version which is 23.11. Check https://www.armbian.com/rockpi4/ If there is none with Bullseye (old-stable btw.) userspace you can build your own image: https://github.com/armbian/build/ 11 minutes ago, Liutas4x4 said: I do not understand what you are saying. OMV heavily messes with the system and is known to cause all sorts of trouble. 0 Quote
Liutas4x4 Posted January 6 Author Posted January 6 Ok. If apt-get upgrade was not upgraded on my system by installation (I did not check that), I will go to find 23.11. OMV was working flawlessly for 2.5 years until I went to upgrade. 0 Quote
Liutas4x4 Posted January 6 Author Posted January 6 Created. Armbian-unofficial_23.11.0-trunk_Rockpi-4a_bullseye_current_6.1.63_minimal.img One day I will continue, but don't know when. Armbian-unofficial_23.11.0-trunk_Rockpi-4a_bullseye_current_6.1.63_minimal.img.txt 0 Quote
