Tony3 Posted January 6, 2024 Posted January 6, 2024 Just wondering if having profile-sync-daemon (psd) is causing troubles to you. After installing Armbian, I noticed that whenever I was restarting Chromium and accessing youtube, the system was asking me a login. The authentication cookies were simply disappearing after each restart of chromium. To avoid that I removed a link of my .profile directory pointing to a tmpfs filesystem (you see the tmpfs file system, use the df command). I read that it is used to avoid read/write on storage, as all I/O are done in Ram, but obviously in my case it was not really working, as I was loosing my cookies. Does anyone else uses that feature? Is this useful nowadays when using SSD's? 0 Quote
Igor Posted January 7, 2024 Posted January 7, 2024 15 hours ago, Tony3 said: After installing Armbian, Armbian comes in many different variants. This could be a bug in Debian SID package base or the one you are using. Where do you observe this? (armbianmonitor -u) I am running Armbian desktop (running Chrome / Firefox) on two machines without any issues. PSD is active. 0 Quote
Tony3 Posted January 7, 2024 Author Posted January 7, 2024 I got the issue on chromium Anyway is psd useful nowadays with ssds? I removed the link some time ago so i cannot really reproduce the problem anymore. What was the softlink please ? 0 Quote
Igor Posted January 15, 2024 Posted January 15, 2024 On 1/7/2024 at 5:58 PM, Tony3 said: Anyway is psd useful nowadays with ssds? We also have plenty of memory nowadays and memory is still significantly faster then ssds and does not wear out. On 1/7/2024 at 5:58 PM, Tony3 said: I removed the link some time ago so i cannot really reproduce the problem anymore. sudo apt install --reinstall profile-sync-daemon This is probably all we do here: https://github.com/armbian/build/blob/main/packages/bsp/common/usr/lib/armbian/armbian-firstlogin#L215-L237 0 Quote
