hi
I've been using the flag
compile.sh PREFER_DOCKER=no
while building in a systemd-nspawn  container:
Building Armbian using Ubuntu (jammy) in a systemd-nspawn container
This time I managed to make a complete successful build with my work arounds for loop devices in systemd nspawn.
However, the flag PREFER_DOCKER=no
Didn't seem to be documented in the build options
https://docs.armbian.com/Developer-Guide_Build-Options/
can the documentation be updated to add PREFER_DOCKER=no flag (at least under 'advanced users') ?
note that it isn't possible to run docker normally within systemd-nspawn or that it'd require all those workarounds such as patching and using the host docker server which defeats the purpose of using docker.
rather systemd-nspawn is the container to at least decouple the build environment from the host os environment (which can be a different linux distribution, I'm doing so from OpenSuse https://www.opensuse.org/), with the unfortunate caveat that loop devices still requires a workaround.
Whole documentation is needs updates. Like all the build switches  (kernel, kernel-config, uboot,...) are missing...
