peter12 Posted January 22, 2017 Posted January 22, 2017 Hello, when I turn on my orangepi with armbian, it automatically logs me in and shows desktop. How can I please disable autologin and auto desktop? For example, on raspberry pi after boot I see just terminal with username and password, when I type these it logs me in and stays in terminal, and when I want dekstop environment I type startx and then I am in desktop. I would like to have the same behaviour on the orangepi (first headless after boot, I juust after then I should be able to login and choose to display desktop). Many thanks.
Igor Posted January 22, 2017 Posted January 22, 2017 Just install - replace current nodm with one of the display managers: http://www.makeuseof.com/tag/choose-switch-linux-display-managers/
peter12 Posted January 22, 2017 Author Posted January 22, 2017 thanks @Igor! If I understand functionality of display managers good, It let's me to choose which desktop environment I want to see after login. But is there a way how to disable it temporarily, so I will be able to "recover" the same behaviour later as I have now (directly logs me in and shows desktop)?
zador.blood.stained Posted January 22, 2017 Posted January 22, 2017 thanks @Igor! If I understand functionality of display managers good, It let's me to choose which desktop environment I want to see after login. But is there a way how to disable it temporarily, so I will be able to "recover" the same behaviour later as I have now (directly logs me in and shows desktop)? Then just disable nodm and start it manually when you need the desktop - this scenario was discussed too many times on this forum.
