paul75 Posted February 4, 2017 Posted February 4, 2017 Hello, I test to prepare a sd with the fresh install with the last image in the website 5.25. I installed Apache2 php5 mariadb and it works but when I reboot the system apache don't start it tell that /var/log/apache2 not found. The I created the directory apache2 and restart apache manually => ok it start. I reboot the system and again it failed withe the same message !*I go to /var/log/ and not see the apache2 created .... Thanks for help
paul75 Posted February 4, 2017 Author Posted February 4, 2017 Sorry it is Armbien 5.25 image not 2.15 ....
Igor Posted February 4, 2017 Posted February 4, 2017 Perhaps logram size is too small for your scenario ... disable or debug the ram logging service. systemctl disable log2ram.service
paul75 Posted February 4, 2017 Author Posted February 4, 2017 On 2/4/2017 at 9:31 AM, Igor said: Perhaps logram size is too small for your scenario ... disable or debug the ram logging service. systemctl disable log2ram.service Hello, Thanks not works without do : apt-get -o DPkg::Options::="--force-confmiss" --reinstall install apache2 after it works. Strange because in my other than have 5.23 and upgrade to 5.25 (apt-get upgrade) it not do this ..... Thanks
txumino Posted February 20, 2017 Posted February 20, 2017 On 2/4/2017 at 9:31 AM, Igor said: Perhaps logram size is too small for your scenario ... disable or debug the ram logging service. systemctl disable log2ram.service On 2/4/2017 at 9:21 AM, paul75 said: Hello, I test to prepare a sd with the fresh install with the last image in the website 5.25. I installed Apache2 php5 mariadb and it works but when I reboot the system apache don't start it tell that /var/log/apache2 not found. The I created the directory apache2 and restart apache manually => ok it start. I reboot the system and again it failed withe the same message !*I go to /var/log/ and not see the apache2 created .... Thanks for help I have the same problem. In this web: https://github.com/azlux/log2ram I see this, but doesn't work: Quote Customize services : If you open the file /etc/systemd/system/log2ram.service , you will see a line starting by Before=, you can list here the services who need to start after log2ram. You will need to change this line when a service start too fast and stop running because log2ram mount a ram folder where it has start to write log. For example, If you use apache instead of nginx, add apache2.service into this line.
pfeerick Posted March 6, 2017 Posted March 6, 2017 I had this exact same issue, but on an ubuntu image (Armbian 5.25, Ubuntu 16.04, pine64) and checked the service status of apache2, and saw the following two errors - sorry, ends were trimmed by SSH scrollback history (2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for main (2)No such file or directory: AH02291: Cannot access directory '/var/log/apache2/' for error I decided to take it on face value, and created the directory, and what do you know... it worked! This was fresh after installing a new (l)amp stack via sudo apt-get install lamp-server^ on a fresh pressed and updated Armbian image. Stupid apache2! sudo mkdir /var/log/apache2
WarEnd Posted March 17, 2017 Posted March 17, 2017 Same Problem Armbian uses log2ram for /var/log. And log2ram writes logs to storage every 1 hour. Basically if you install services and reboot computer before write all changes including new folders be missing most easy option is for example: sudo apt-get install apache2 sudo log2ram write sudo reboot and all works fine for confirmation after restart run: ls /var/log and look for "apache2" folder for chaking if system use log2ram type: df -h 1
