sovking Posted February 4, 2017 Posted February 4, 2017 I experencing the following error upgrading orangePI-PC with connected a WiFi ralink key: # apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-firmware 1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 1,617 kB of archives. After this operation, 0 B of additional disk space will be used. Do you want to continue? [Y/n] Y Get:1 http://apt.armbian.com/ jessie/main armbian-firmware armhf 5.25 [1,617 kB] Fetched 1,617 kB in 11s (138 kB/s) (Reading database ... 44676 files and directories currently installed.) Preparing to unpack .../armbian-firmware_5.25_armhf.deb ... Unpacking armbian-firmware (5.25) over (5.22) ... dpkg: error processing archive /var/cache/apt/archives/armbian-firmware_5.25_armhf.deb (--unpack): trying to overwrite '/lib/firmware/rt2870.bin', which is also in package firmware-ralink 0.43 dpkg-deb: error: subprocess paste was killed by signal (Broken pipe) Errors were encountered while processing: /var/cache/apt/archives/armbian-firmware_5.25_armhf.deb E: Sub-process /usr/bin/dpkg returned an error code (1) Now my system is with: # dpkg-query -l | grep 5.25 ii armbian-tools-jessie 5.25 armhf Armbian tools, temper, Cubie bt utils ii hostapd 1:2.5~armbian5.25+1 armhf IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator ii linux-headers-sun8i 5.25 armhf Linux kernel headers for 3.4.113-sun8i on armhf ii linux-image-sun8i 5.25 armhf Linux kernel, version 3.4.113-sun8i ii linux-jessie-root-orangepipc 5.25 armhf Armbian tweaks for jessie on orangepipc (default branch) ii linux-u-boot-orangepipc-default 5.25 armhf Uboot loader 2017.01 ii sunxi-tools 1.4.2-1~armbian5.25+1 armhf tools for working with Allwinner (sunxi) ARM processors root@genka-h3:/# dpkg-query -l | grep 5.22 ii armbian-firmware 5.22 armhf Linux firmware dmesg stays that the device is: rt2800usb It will boot with this one packages which is still at 5.22 and the other at 5.25 ? And it will connect to wifi with the armbian-firmware not upgraded by firmware-ralink present ? Should I uninstall armbian-firwmare leaving firmware-ralink only ? Any suggestion to solve this ?
sovking Posted February 5, 2017 Author Posted February 5, 2017 Probably I should ask this question in debian/ubuntu because is not specific to H3/H2 devices... Unfortunaly this board is in remote location and is connected trhough Wi-Fi, so if I make a mistake I will lost the connection
Igor Posted February 5, 2017 Posted February 5, 2017 Should I uninstall armbian-firwmare leaving firmware-ralink only Remove armbian-firmware or firmware-ralink and double check if needed file exists before reboot. Make sure that apt update finished properly, without error code.
sovking Posted February 8, 2017 Author Posted February 8, 2017 Done! I removed armbian-firmware and the library was still there: good! Then I checked no update was pending before reboot. Now everithing work fine. I could be nice if in future when a new armbian package release can overwrite another package (fowrwhatever reason) report how to deal with this situation, if it cannot be resolved automatically: for example warning about different files revision, sizes, benefits, drawback and so on. Of course this could be done just per armbian packages which you can control and manage, for other packages I think could be too much work or not reasonable. Thank you very much for your help!
