Hi Igor,
while trying to reproduce/fixing my boot problem, I stumbled across some weird things regarding your new update script.
I've put a complete new image on sd-card only (Armbian_4.5_Cubietruck_Ubuntu_trusty_4.2.3) which works fine, boots and reboots.
Then I've tried to use your update script which I called via:
wget -q -O - http://upgrade.armbian.com | bash
with the letter O and a blank between the minus and http, is this correct?
First strange thing I noticed is, that it starts but doesn't run through completely. It ends with this output:
Don't think that this should be the normal behaviour!? And remember that this wasn't the case when I tried this some time ago. What could have happened?
Second strange thing is, that when I call it again, it runs through completely, removes the old kerne-stuff:
but tells me that nothing was upgraded / removed nor installed.....????:
Could this be because everything was already up to date? But then it either shouldn't remove 'old' kernel or should populate /boot again with the latest stuff!?
Looking in /boot, all the new stuff is missing:
So no wonder that it doesn't boot anymore.
Does this make any sense to you? Can you imagine what has happened and whether this is a common thing or something went wrong just at my side?
[Edit:] There's another user that reports similar problem: http://forum.armbian.com/index.php/topic/211-kernel-update-procedure-has-been-changed/?p=2173
Thanks in advance and best regards,
Jochen
Thanks. I'll take a closer look.
Do a manual packages install before reboot.
Thank you.
While downloading the packages I retrieve errors from 213.168.13.97. Trying again, 213.168.13.40 answers and works. Is this some round-robin and could this be related to the above problem?
Ok, I ran the script again with system up&running again.
Now it doesn't delete kernel but also doesn't upgrade anything.
Maybe that's because running
apt-get update
results in
Ign http://apt.armbian.com trusty/main Translation-en
Armbian.key was added...
Ign is when there is no change. That's ok.
The problem might be, that your package base is corrupted ... or simply it does not update because there are no packages to update. In this case you need to install them manually / with this script.
Without (install) log I hard to tell what went wrong.
apt-get update && apt-get upgrade
ran through smoothly and yesterday some other packages where updated successfully (...libc...), so I assume that the package base shouldn't be corrupted. Otherwise this wouldn't have worked?
But running:
root@seafile:/# wget -qO - http://upgrade.armbian.com | bash
Image Name:
Created:      Tue Oct 20 12:03:57 2015
Image Type:   ARM Linux Script (uncompressed)
Data Size:    1753 Bytes = 1.71 kB = 0.00 MB
Load Address: 00000000
Entry Point:  00000000
Contents:
   Image 0: 1745 Bytes = 1.70 kB = 0.00 MB
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
All done. Check boot scripts and reboot for changes to take effect!
Visit: forum.armbian.com in case of troubles or just for fun
root@seafile:/#
results in no kernel update, although I'm still on 4.1.6.
Which log could I check / do you need to further investigate?
With "install them manually" do you mean the steps described in 'how to unbrick the system'? So just download and dpkg -x these files?
Thanks and best regards,
Jochen
If you still have a running system, than you don't need to use that procedure but directly:
apt-get install linux-image-next-sunxi linux-headers-next-sunxi linux-firmware-image-next-sunxi
apt-get install linux-trusty-root-cubietruck
apt-get install linux-u-boot-next-cubietruck
Ha? :(  :angry: You cut the power or you did a proper shutdown?
I don't understand what are you doing wrong. SD card / hardware problem?
This is a proper boot procedure ...
Did a powercycle after proper shutdown. Didn't come up afterwards.
Pretty sure now, that it's a hardware issue (sd card or cubietruck).
