foxx1337 Posted February 18, 2024 Posted February 18, 2024 I was getting kernel panics and discovered that my 32 GB Rock 5B Blue Edition just crashes when I try to malloc 8-9 gigabtes of memory. Is there a way to specify that this board has 32 GB ram? 5.10 works fine. 0 Quote
Werner Posted February 18, 2024 Posted February 18, 2024 For now using 5.10 vendor bsp is the way to go. 6.8 is - as the name implies - bleeding edge and problems are to be expected. This will most likely be addressed upstream sooner or later. MAY take a while since there seems to be a general shortage in 32G boards due to the lack of available memory chips. 0 Quote
foxx1337 Posted February 18, 2024 Author Posted February 18, 2024 (edited) Thanks! I was wrong with the kernel - same panic happens also on the old 23.11.1-legacy Armbian with the vendor's 5.10.160 kernel. The one that works is Joshua Riek's Ubuntu build (still 5.10.160). Maybe DTB related? Edited February 18, 2024 by foxx1337 0 Quote
Werner Posted February 18, 2024 Posted February 18, 2024 Hm this is odd. Joshua's and our kernel sources are very close. He did some adjustments for packaging and directly integrated some wifi stuff but that's it... 0 Quote
