k405 Posted May 9, 2025 Posted May 9, 2025 @atleta I've been seeing that it's a bad idea, it has 8g and I didn't want to completely waste its use, I wanted to help the system's processing or speed in some way but I think it's difficult lol 0 Quote
RaptorSDS Posted May 9, 2025 Posted May 9, 2025 vor 4 Stunden schrieb Benedito Portela: sdcard boot yes put armbian image like multiboot on a sdcard and than boot maybe you have to put another boot partionion on emmc but not more , you dont need to remove emmc for this 1 Quote
RaptorSDS Posted May 9, 2025 Posted May 9, 2025 vor 15 Stunden schrieb k405: How do I get the serial log? you have to log at the bord direct for the pins or soldering point , than solder wire and connect to uart usb adapter , than you can get a log, you say yyou can boot from emmc but its not stable ? or complete dead emmc this are cheap box , there is not many to speed up maybe use one box for one task is the goal than 0 Quote
k405 Posted May 9, 2025 Posted May 9, 2025 updating so far, i installed arch linux on tv box @RaptorSDS I really want to learn how to do this, where are these pins? What adapter is this? Is this adapter the common one for reading electronic chips? I will love to help you with the information, in return I receive the knowledge Also, eMMC is unstable, I install and configure armbian normally, but when trying to update armbian, every now and then it freezes during the update and after restarting it no longer enters the system. After reporting the system crash here on the forum recently, I found myself on a mission to install a system that I feel comfortable with, Archlinux. With the idea of using the sdcard, with the command dd if=armbian-blabla.img of=device bs=1M oflag=direct status=progress I installed Armbian on the sdcard. With that, I already installed U-Boot and the Armbian boot, I just had to download the armv7 rootfs from archlinuxarm.org I had problems with the root password and file permissions. After copying the arch rootfs to the card, I discovered after trial and error that the files were corrupted. The solution was to redo the entire process. Now the system starts correctly, however, ssh would not start with the boot, and my board is an R29, I do not have HDMI access (and I suspect that not even the USB gadgets work, but I have not tested it yet). The solution was simple. With Armbian on the internal eMMC, I mounted the sdcard along with the dev, proc, sys and run partitions, and in chroot with the sdcard I configured ssh, pacman with pacman-key --init and pacman-key --populate archlinuxarm, and installed sudo to be able to do the basics. In addition, it was necessary to manually configure fstab and copy network settings (to make things easier) from armbian to arch. 0 Quote
k405 Posted May 9, 2025 Posted May 9, 2025 With this, I will use the box to run a simple file synchronization service. I want to use the internal eMMc, what is the best way to use it? 0 Quote
Benedito Portela Posted May 9, 2025 Posted May 9, 2025 @RaptorSDS, it do not boot from sdcard or flash usb, i think this box is die, only enter in Mask mode, but do not working any rkdeveloptool commands to rescue it! I rememeber now, to be a emcp so the ram memory is the same chip, i do not remove it, this go to junk! Thank you by help-me! 0 Quote
k405 Posted May 10, 2025 Posted May 10, 2025 I went back to the default Armbian rootfs. The Arch rootfs broke the boot, probably due to the use of the latest systemd. It is possible to mitigate this but it is not worth it. Now I am running normally from the sdcard, I just wanted help with the armbian-config options. I know that led-conf7 and uart2 are correct for my board, right? I'm still looking for the others in the thread And what do I have to do to make the wifi work? 0 Quote
Vinicius Guastala Posted May 12, 2025 Posted May 12, 2025 Hello Guys, This will be a long post, so I already apologize for that! I am trying to install armbian in the most generic MXQ PRO 5G 4K ever. No joking when I say it’s generic, because I have some proof that this Frankenstein monster is actually a MX9 and a MXQ 4K PRO merged together. Here are some board Details: MoBo: MXQ-EP-2-V1.0 CPU: Rockchip RK3228A Wifi: SV6256P Storage: Samsung KMQ7X000SA – B315 (Is this a ECMP 8GB+8GB or a emmc?) I call it a MXQ Frankenstein, for the following reasons: According to the info and the picture from this source, the “MX9 4K 5G” has the exactly same MoBo “MXQ-EP-2-V1.0”, but with the SV6152P wifi instead. According to this other forum post, the OP has posted pics from his "TXC2-MXQ-EP-V10” MoBo, which looks basically identical to my “MXQ-EP-2-V1.0”, but it has the SV6152p wifi like the MX9 4K 5G, but with a RK3229 CPU instead. This post was very useful for me because of the Short Pad for Mask Mode for this version is the same as mine. In this other post, we see the same “MXQ-EP-2-V1.0” Mobo, but with with a SanDisk storage chip instead. And in the same post, in the last comment we see another user with a 8GB/128GB variant with the same SV6152p wifi from the above “TXC2-MXQ-EP-V10” So including my version, it seems we have at least 5 different versions of this horrendous Frankenstein device, for the “lowering cost reasons” we already know…. Despite many tentatives, I am not able to make the “multitool” (or amrbian directly) to boot, from any method. Tried many times from SD, from USB and even after it is copied directly to the eMMC, all following the guides from the 1st page from this post, but also from other internet sources. Simply I’ve got a black screen output whenever the SD Card with multitool or armbian in inserted, with no leds turned at all. Unfortunately I have not done the backup from my original ROM before I have tried to write armbian directly to the emmc, because I did not know that was possible back then, and now I’m also not able to find my original ROM. I have tried many (10+) different ROMs, flashing from Linux and Windows, but I ending up having the same behavior as booting armbian, with no Video and no LEDs, until I finally came across to the ROM called “MXQ-EP-2-V1.0_SV6152P_OK By: (Zer013)” from this site. With said ROM, I was able at least to get the HDMI video and LED’s blinking, but I got stuck at a boot animation loop forever. For some reason, only when I flash it from Windows using BatchTool or RKDevTools it works. At least I was able to test different Loaders, and with this ROM, I have tested successfully all the loaders below, either flashing by Linux or Windows. (Remember: The device gave video and LEDs, but I still got stucked at ROM’s boot screen): RK322XMiniLoaderAll_V2.47_spectek_en_ddr2_rd_odt_171209.bin – This was extracted from the above ROM image that give me workin LEDS and HDMI Video rk322x_loader_v1.10.238_256 from a 2020 comment on this thread from a guy trying to overclock his ddr memory. rk322x_loader_v1.10.238_256.bin from first page, from the “Installation (without SD card, board with eMMC)” section I was trying to flash different loaders in hope that some of them would make my armbian to boot from the SD card, but without any luck unfortunately. I have also tried to erase the flash completely to force the SD Card boot, but I have got the same no-screen / no-leds behavior. If anybody has any ideas on how to go further to install armbian in this board, I would appreciate a lot! I don’t need the wifi for the purpose I intend to use it, so minimal installation is more than enough for me. I’ve been turning it on mostly with just the USB cable in the OTG port, so at least I can check the device status with lsusb in linux. Sometimes I do some tests with the power cable turned on, and I have noticed the same behavior as well. Does it make any different to turn it on by USB or Power Connector? I’m still not able to find the Serial UART pins, even after I have tried soldering my USB-TTL in different points of the Board as there is no printed info, so this also adds to the overall complexity. Despite my efforts with the multimeter, I was not able to identify them yet. Since I’m afraid to burn another USB-TLS adapter, I’m being cautious and only using the GND and RX pins from the adapter. So far, I have found 2 interesting pins, but they only give me gibberish text, despite trying different baud rates (I have tried them all). Most promissing PIN for now is the pin labeled “K” in the pic below, as it is the one that gives me more output when the device is booting, almost in the same time as a normal system boot… So my “guess” is that the Pink K is the board TX pin… Attached there are all the photos of the mentioned components from my board. 1 Quote
fabiobassa Posted May 12, 2025 Posted May 12, 2025 (edited) @Vinicius Guastala first of all thank you for so much detailled infos and your efforts to find any relevant pin on your board. Yes china manufacturers are well known to use the first avaible chip they have unused on desk so I am not at all surprised to have this frankstein model of a 322x Unfortunately I don't own such board, so really at the moment I have few clues to point you on the right direction. Mine are generic considerations: 1) no separate chips apart from cpu, just one big big chip = ECMP usually 8 giga rom, 1 giga ram ( good for you if it is 16/2 but i doubt) 2) to me looks more interesting the FGHI part for uart, REMEMBER that uart speed is 1500000 ( yes!!!!! one million 500000) but follow the tracks for any missing resistor/missing short that stop the uart signal from CPU to pads 3) if you have a radio-aficionado or a tv technician that owns an oscilloscope finding the uart pads will be easier Sorry if I am not any further useful for your case, cannot buy every single new board that comes out on market, but if for you is important feel free to send me one sample for study and development EDIT : I just remebered that if you are lucky because not all boards have enabled. you'll find a uart on the sd card reader, starting from most right pins and counting 4 . Let me be more clear : two small and two big, from right....on the 4 you will have a uart at 1.500.000 Of course if you put the sd in you will lose this signal, but at least confirm you have any readable character on that pin ) Edited May 12, 2025 by fabiobassa 0 Quote
jock Posted May 12, 2025 Author Posted May 12, 2025 @Vinicius Guastala I agree with @fabiobassa, thanks for the very detailed post of your board and broad description of the behaviour. I would suggest you to erase the internal flash and try to boot from sdcard with this armbian image. It is an "experimental" image with opensource Trust OS; many recent boards are having issues with proprietary trust os, possibly yours has similar issues, so you could give a shot to this. By the way, the serial log output would be indeed very handy if you have the chance to find the serial port. Beware also that armbian (and multitool) use 115200bps baud rate for the serial, while proprietary software uses 1.5Mbps baud rate! 3 Quote
Vinicius Guastala Posted May 12, 2025 Posted May 12, 2025 @fabiobassa and @jock, thanks for your quick responses! You are true heroes for this community. The suggested experimental image have not worked for me unfortunately. Same behavior, no Video and no Leds. However, a little progress on the UART search... Connecting my RX adapter pin to the SD Card 4th pin gave me the biggest console output so far, even though its just garbage, I see it as a little progress... Please see the attachment. Also, I think I was able to identify that the Samsung chip is a 1gb/8GB one from the "rkdeveloptool rfi" command... see it below with some more output from the rkdeveloptooll... [2025-05-12 18:49:03] viny182@desktop-mint ~> sudo rkdeveloptool list DevNo=1 Vid=0x2207,Pid=0x320b,LocationID=302 Loader [2025-05-12 18:49:17] viny182@desktop-mint ~> sudo rkdeveloptool list-partitions Not found any partition table! [2025-05-12 18:49:46] viny182@desktop-mint ~ [1]> sudo rkdeveloptool test-device Test Device OK. [2025-05-12 18:49:58] viny182@desktop-mint ~> sudo rkdeveloptool rfi Flash Info: Manufacturer: SAMSUNG, value=00 Flash Size: 7456 MB Flash Size: 15269888 Sectors Block Size: 512 KB Page Size: 2 KB ECC Bits: 0 Access Time: 40 Flash CS: Flash<0> [2025-05-12 18:50:19] viny182@desktop-mint ~> sudo rkdeveloptool read-flash-id Flash ID: 45 4D 4D 43 20 [2025-05-12 18:50:26] viny182@desktop-mint ~> sudo rkdeveloptool read-chip-info Chip Info: 41 32 32 33 0 0 0 0 0 0 0 0 0 0 0 0 [2025-05-12 18:50:41] viny182@desktop-mint ~> sudo rkdeveloptool read-capability Reading capabilities failed 0 Quote
Vinicius Guastala Posted May 12, 2025 Posted May 12, 2025 please ignore my previous comment. THE EXPERIMENTAL IMAGE DID BOOTED FROM SD CARD! IT WORKED I have forgotten to erase the flash on the first time... After I erased, it booted from the SD Card. I cannot thank you guys enough!!!! <3 <3 <3 2 Quote
fabiobassa Posted May 12, 2025 Posted May 12, 2025 @Vinicius Guastala @jock indeed is a semi-god on those boxes 😅 ✋ 0 Quote
Vinicius Guastala Posted May 12, 2025 Posted May 12, 2025 @fabiobassa @jock you both are master-gods with the power of every god from all the mythologies known by the human kind! Next step for me now is to install it to the eMMC (if that's not possible, I will stick with SD boot only, no problem). I heard that there is the armbian-install command, so I will try it since the provided image is a XFCE Desktop one and I want a minimum image to free up resources since I just need a headless machine... Any suggestions for guides/documentations to install a minimal enviroment to emmc from the SD desktop enviroment? 0 Quote
remlei Posted May 16, 2025 Posted May 16, 2025 (edited) Anyone managed to get the OTG port do USB peripheral stuff (gadgets)? I installed the latest armbian for rk322x on github armbian community. Looking at the kernel config, it looks like all the OTG stuff are set to Y by default now, execute armbian-config and set the dtb to rk322x-usb-otg-peripheral and reboot the system but alas, it still doesnt work with dmesg output pertaining that "Can't find any UCD" when executing "modprobe g_mass_storage file=/test.img luns=1 stall=0 ro=0 cdrom=0 removable=1". A little bit googling someone managed to get it working, I tried to follow what he did (but in more recent build of armbian instead of the legacy one), alas didnt managed to get it working. Using the provided rk322x-4.4 dtb file result of bricking my armbian install. My main goal here is to get that kvmd (pi-kvm port for armbian) working with rk322x. Edited May 16, 2025 by remlei 0 Quote
jock Posted May 17, 2025 Author Posted May 17, 2025 @remlei last time I checked, the usb gadget overlay was working fine and the UCD device was correctly spawning up. Some things work with rk322x (mass storage), some others don't (UAC1, UAC2), so your mileage may vary. Verify you have usb-otg-peripheral in /boot/armbianEnv.txt in the overlays= line 0 Quote
remlei Posted May 17, 2025 Posted May 17, 2025 (edited) 14 hours ago, jock said: Verify you have usb-otg-peripheral in /boot/armbianEnv.txt in the overlays= line Yes I verified that its there. But im suspecting something though. I have a NAND rk322x and using jumpstart to boot armbian using sd card, can that possibly causing this issue? edit: nah scratch that, I snag my on emmc model and tried it there but this time uboot did throw some useful stuff it relates that it cannot load the dtbo file? I cd to the directory and it was there. edit2: managed to partially get the OTG port working, just have to edit the dtb file on my own instead of relying on armbian-config now the otg functionality kinda works? I ended with this error and basically clueless at this point [ 76.310374] dwc2 30040000.usb: new device is high-speed [ 76.310458] dwc2 30040000.usb: dwc2_hsotg_enqueue_setup: failed queue (-11) pi-kvm is partially working, the usb capture and everything works except for the USB OTG so no remote keyboard/mouse functionality. Edited May 18, 2025 by remlei 0 Quote
jock Posted May 18, 2025 Author Posted May 18, 2025 @remlei you can see from the u-boot log that the overlay is not applied because there is the rk322x prefix two times. The overlay must be set literally as usb-otg-peripheral as I wrote above, and not rk322x-usb-otg-peripheral: the rk322x prefix is added automatically. About the OTG functionality, as said your mileage may vary. Unforturnately the rk322x OTG port or driver does not seem to be very collaborative or totally standard compliant. 0 Quote
remlei Posted May 19, 2025 Posted May 19, 2025 15 hours ago, jock said: The overlay must be set literally as usb-otg-peripheral I assume thats the proper format because armbian-config is the one put that there so I never questioned about it. so far all of the NAND models seems to have USB OTG working but not all my eMCP boards, it always throw that error I posted earlier. also for some reason, in NAND models with jumpstart installed on NAND, overlay option on /boot/armbianEnv.txt for some reason do not work and have to resort editing the dtb file manually, all of it from led config to wifi stuff, also enabling the peripheral mode as well. I guess those overlay stuff only works when that u-boot bootscreen on emcp boards I had only have those overlay stuff working but not on the NAND models with jumpstart. After all those dtb shenanigans, I went ahead and install https://github.com/srepac/kvmd-armbian skipping all the way to step 3, a hour and 2 reboots later, yep its all working now. with 256GB USB flash drive mount on /var/lib/kvmd/msd and running that msd fix sh script to get that USB storage stuff working. sheesh, this box sure is really hell of a work. if I dont have extra time, id probably not doing this and just buy a cheap orange pi instead. 0 Quote
fabiobassa Posted May 19, 2025 Posted May 19, 2025 @remlei Quote sheesh, this box sure is really hell of a work. if I dont have extra time, id probably not doing this and just buy a cheap orange pi instead Yes indeed, sometimes I ask to myself ( and to my friends @jock @ilmich ) who the hell give us so much entusiasm, patience ( and frustration) to deal AGAINST not the box itself, but against the lack of good documentation and support , but when finally a stuff is working after thousands of trials and errors, well then I go sleep like a child with it's christmas gift. This is the pagic called PASSION !!! 0 Quote
Vinicius Guastala Posted May 19, 2025 Posted May 19, 2025 and I must say that not only your passion, but also your dedication and commitment are truly inspiring for the whole community! One just cannot thank you guys for everything you have done! @fabiobassa @jock @ilmich Since @jock provided the experimental image on May 12th, i've been playing non-stop with this device, doing numerous flashing attempts and testing things out, just for fun... I must have spent 30+ hours on this ever since, mostly trying to compile things myself to run in the box, playing with the different overlays to test what works and what doesn't and learning about Tee, trust, op-tee,... You know those kids that when get their toys, they tear it apart instead? well... same feeling... the discovery passion thing... I'm preparing a report on my findings for my specific "MXQ-EP-2-V1.0" MoBo model, specially around on the working overlays, perhaps I can post it in the weekend.... And responding to my own question earlier about armbian minimal, in the armbian-config tool from the experimental image, there is an option to disable desktop... it gives you a system with only 25 tasks running and lower RAM usage than a DietPi. Now I begin to become interested on (re)assembling ROM images... I've been trying to replace some internet roms with the Trust Partitions and u-boot from the ROM I know it works... No successful test yet, but not sure if I'm repacking them correctly... Anyway, I'm learning a lot and that's great thanks to this community! 0 Quote
Defalt36 Posted May 26, 2025 Posted May 26, 2025 I'm dealing with a very annoying problem. Every iso I seem to get for bookworm minimal have the same problem that everytime I try to run nano the screen goes black. How to fix this? 0 Quote
Defalt36 Posted May 26, 2025 Posted May 26, 2025 Video recording of my problem. Can someone help me solve it? 0 Quote
Almero Ramadhan Insan wibowo Posted May 31, 2025 Posted May 31, 2025 (edited) does anyone know how to get maskrom and uart on this rk3228a board from mxq pro 4k 5G since pushing the little button shows up as armlogic devices on device manager but the actual chip is rockchip and sorry for bad quality images Edited May 31, 2025 by Almero Ramadhan Insan wibowo edit the description 0 Quote
jeffbzrr Posted June 2, 2025 Posted June 2, 2025 First of all, I would like to thank the developers for making this possible. I have two MXQs, one with OMV and the other running raspotify with a DAC. Thank you very much, it was a great addition to my homelab. I noticed that docker container support for armhf has been discontinued over time. Does anyone have a list of docker images for armhf? 0 Quote
Tavares R Posted June 16, 2025 Posted June 16, 2025 Hello everyone, I'm working on repurposing an MX9 5G TV Box (RK3229) for educational use and I'm looking for a lightweight Armbian image that already includes a working desktop environment (XFCE or similar) with GPU acceleration enabled (Mali drivers, no llvmpipe). I’ve tried minimal builds and installed XFCE manually, but I’m still getting software rendering (llvmpipe) instead of hardware acceleration. I'd really appreciate it if anyone could recommend a tested image (preferably based on Bookworm or Bullseye) that: Boots successfully on the MX9 5G (RK3229) Has Mali GPU acceleration enabled by default Includes or supports installing a lightweight DE (XFCE preferred) Bonus if it includes support for video playback or has a browser that runs decently. Thanks in advance for any suggestions or links! 0 Quote
Lucas Gomes Posted June 16, 2025 Posted June 16, 2025 (edited) Hello, first of all, I’d like to thank everyone for the post and your contributions! My problem is simple: I have an H96 Mini 4K Ultra HD, with CPU RK3228A, OS: Android 9.0, RAM: 2.0 GB, and ROM: 16 GB. I installed the ArmBian system on it; but then I decided to reinstall the original ROM. However, during the step sudo rkdeveloptool db rk322x_loader_v1.10.238_256.bin, I mistakenly flashed the original system image instead. Now, the device shows no sign of life — it's not recognized by either Linux or Windows. What should I do? Edited June 16, 2025 by Lucas Gomes 0 Quote
fabiobassa Posted June 21, 2025 Posted June 21, 2025 @Tavares R if you read the 1st post you will see that this box is a half-miracle, in the meaning that it work under some intergalactic forces 🤣😎 since it's harware is quite limited For use such as headless server is fantastic but when it comes to net browsing it shows all it's limits In the first post also is detaiiled a way to install full hw acceleration I tested many many many rootfs and many combinations but with XORG almost any browser is quite unusable. I dont have experience with wayland thought Different approach with playing video and music under libreelec with a reasonable frame rate and hw acceleration , but on this side @ilmich could be more specific 1 Quote
fabiobassa Posted June 21, 2025 Posted June 21, 2025 @Lucas Gomes you should force it go in maskrom ( if no phisical damage occurred) finding the appropriate pins on the board 0 Quote
cheaplinuxbox Posted June 21, 2025 Posted June 21, 2025 Hi there, just created an account to say thanks ! I randomly bought a clearance media player on tuesday thinking "there must be something I can do with this and need a project" https://www.jaycar.co.nz/4k-android-media-player/p/XC6012 A bit of DuckDuckgoing later and found this forum, and well, it's all been done! Good work guys, this device has nand flash and rk3228a so after a few nand reflashes and general messing about etc I decided to flash the latest image to SD card and well, it runs really well. As previously noted this board has horrible thermal design so active cooling is basically mandatory - anyone experiencing "freezes" or crashes during system updates, note the board temp, it heats rapidly and appears to thermal shutdown at around 80 degrees C. Have since added a USB wifi dongle which works fine as the onboard wifi isn't driver compat (as previously noted) So this board appears to have comparable performance to a Raspberry Pi 2b, so as long as you temper your expectations this is a fun system to mess around with. Thanks ! 1 Quote
