CSC Armbian for RK322x TV box boards
jock
On 4/16/2022 at 9:55 PM, Charles Bauer said:
Now I am here again with another box that I bought to validade the project but I think it came with an emcp module again.
Hello!
If you don't see the DRAM chips (usually two or four) but only a single big chip other than the SoC, then your board has an eMCP chip.
And I am trying to boot this box with an SD with multitool and that does not boot. It stays on black screen. (I have tested the sd on another box and it works fine and this box is booting android fine too.)
If you have an R29 board, then you are unlucky: there is an issue which prevents the HDMI to work with these boards. This issue won't be solved until some developer gets its hands on such a board.
I will never stress enough the fact that these tv boxes are not a good choice for serious projects.
Link to comment
Share on other sites
Hy Group
another topic maybe someone can point in the right direction my box has a SCL 9082 Wifi chip , this chip is bad supported .
i got hands on an SV6030P wifi modul , pinout is idientical --> how good is this chip supportet at linux ?
Link to comment
Never heard about sv6030P and never saw any driver for it. It looks very similar so ssv6051p, but can't say what kind of support it has.
Link to comment
vor 1 Stunde schrieb jock:
ok thank you , looks also bad supported --> ssv6051p is maybe a big brother of 6030p i found some coreElec information and some datasheet from icomm  (iottech)
Zitat
CoreELEC 9.2.14 changelog
Updated Wifi driver ssv6xxx-aml
Implemented Wifi driver SSV6030P
they force ssv6051p driver for 6030p
Question is the SSV6051p and the patch also inside the rk322x images
ssv6xxx-aml-003-force-SSV6051P-when-SSV6030P-is-detected.patch
Link to comment
i tried installing an old armbian image to see if it would be faster since the most recent one felt a little slower than an older one i tried before and now the tvbox wont boot anymore. my board is r329Q_V3.1.
Link to comment
Hi everyone,
Can anyone help me? I'm not so technical guy so please bear with me.
I decided to use bullseye image because I have a hard time using jammy in remote session. It really really slow.
I just want a system running adguard home. So I think I need aguard home installation and a browser to configure it.
My problem is that I cannot launch the browser (chromium) in SSH for the obvious reason.
What do I need to install to be able run and configure adguard home. I really appreciate if anyone guide me for the command that I need to use.
Thank you so much.
EDIT: Silly me, I figure it out. I just need to install aguard home and configure it in my local computer (laptop) 😅
Link to comment
Please, anyone could provide a full dump from the default android (any android) of a mxq-4k, made with multiboot tool? I did not made the backup, and now I can't restore original firmware, probably because of the partitions been mess-up or whatever.. I can install and remove and install Armbian many times as I want, but I just can't go back to android without the full dump, a least is what I think.
Edited by Felipe Triana
typo
Link to comment
@Felipe Triana
Felipe armbian uses gpt , android uses a organization of partitions called rkparameters . rk parameters are written into sector 0X02000 of the nand, just after the loader address space
is a bit as you modified the master boot record to use mbr or uefi. This just to explain the difference between android and armbian and also this is an annoing alert repeating from the beginning of this post, saying  mxq-4k means NOTHING !!!!!!!
Neither is possible ask a backup from a mxq-4k from other users for the reasons explained  later in this post
Please open the bow ( 4 little screws under rubber pads) and give more info ( mx4v ? mz4vr? r329q ??) or better attach photos of the box
If you really want go back to android ( but .. why ???   🙂  )  and if you are also a windows user or you can use windows in some way , you can use the attached windows tool and,  instead of using the backup obtained by multitool,  look for an android suitable for you board ( that despite of being called mxq-4k could be a 3228. 3228a, 3229, ddr2, ddr3 and all the hell the china market does ) !!!
For the future, backup before any experiment !
AndroidTool_Release_v2.69.zip
Link to comment
@fabiobassa
Hi, I'm only replying now, because the forum limts one post per day for me, for now a least. Ok. Back to the topic.
Yesterday, I was trying to go back to the android because I was thinking in use the TV BOX as a temporary replacemant to my father's notebook, that stopped working and I already resoldered almost everything changed the SIO, SB etc.. Anyway, today I just boght another box, with android and installed for him, and worked fine... but would be nice to have a full backup of the nand anyway, if one day I wish to go back to original firmware, I should have done the backup.
The box is a MXQ-4K, as i said, but now I will give details:
It features a RK3228A, with 2GB of Micron DDR3 (2 chips on top, 2 on the back of board), a 8GB BGA NAND, and a SV6051 wireless chip and R329Q_V3.0 board revision. I took some photos for more details, right below here:
WhatsApp_Image_2022-05-27_at_9.39.42_PM.
Here a close up of the rockchip on this board, before I changed the heatsink
WhatsApp_Image_2022-05-27_at_9.38.44_PM.
Here is 2 of the 4 DDR3 ram chips, its HTTC4G83BGR (4 gigabites, or 512MB per module)
WhatsApp_Image_2022-05-27_at_9.39.14_PM.
The wireless chip, SV6051P, nothing special..
WhatsApp_Image_2022-05-27_at_9.38.58_PM.
An overview of the back of the board, showing the nand and pcb shape
WhatsApp_Image_2022-05-27_at_9.40.24_PM.
And finely a overview of the board powered on, running main build from SD Card...
Ok, things that I noticed, that can ou cannot be bugs:
- It only finds 1GB of ram, instead of 2GB (maybe need some aditional configuration?) - tested with both builds, main and legacy, same.
- I can only connect to SSH, or anyother service, even apache, if I connect the RJ45 cable, tried diferent router, tried ufw open, tried remove iptables and fw completely, nothing - tested with both builds, main and legacy, same.
- on GUI interface, on main build, audio does not detect HDMI audio, only onboard audio, on legacy works fine.
- Minor issue, but nice to metion, the multimedia script for legacy devices, has a variable like $USERNAME or something near this, that is suppost to copy a XML file I think for home/user folder, but the variable is broken, it just returns empty. I had to open the script and write my username manually. I think that it is responsable for make window composing work(?) - anyway, even with this, the desktop arrow and select tool works faster, but that's it. When you drag a window across the screen, it looks like I finished solitary game.
So far is what I noticed...
I would be already happy if a least I could recognize the full 2GB of ram on board and wireless worked on inbound connections, a least I could use the box as a home server, for files, websites, etc.
I found other issues that I think is maybe the hardware itself that cant cope with todays demands: main or legacy, even with multimedia tools installed, Youtube can't even play at 144p without dropping 20 to 40% of the frames, tested windowd, and fullscreen, same. Youtube keep rendering on CPU mode, with firefox or chromium, even if I run the browser with glrun command.
So far thats it, I'm afraid that I will be able only to reply after 24 hours, because of forum limitation, so in this case, until tomorrow! Thank you for the attention,
Link to comment
@Felipe Triana Hello, I don't understand if you did or didn't backup the original firmware and how many boxes you have.
Anyway, replacing a notebook with the cheapest of the cheapest hardware around is not a wise idea; such tv boxes are much more suited for light server usage and they are definitely not suitable as desktop replacement.
If the amount of detected ram is 1gb, then you have 1gb, no matter what the manufacturer says about. There are plenty of reports of fake specs just in this thread, so this is no surprise.
For the other issues you mention, never experienced anything like that: network services are working perfectly fine and HDMI audio device is showing up for me.
About youtube, it is worth mention that there is no video acceleration in browsers nowadays. Videos are accelerated when used with proper software, but surely can't be accelerated in browsers and you can't expect anything more than a 10-years old budget-class smartphone CPU.
One thing that helps is disabling desktop composition (is a general recommendation as per Armbian documentation).
Legacy flavour is receiving little to no attention due to recent advancements of mainline kernels, so you'd better switch to mainline kernel, but surely these cheap tvboxes are not suitable for desktop replacement.
Link to comment
@jock
I bought another yesterday, brand new, left with stock android and workds for my father for now. On android at least he can see emails and youtube. 😅 about the backup, no I did not make it, I should have... I had this box laying arrond, and had the ideia for desktop replacement, but then I saw the limitations that you said, but I didnt made the backup of the NAND, and that's is why I made the first post..
I know my box have 2GB, because I installed it 😂 I'm work with GPU, bga etc, and was very easy to me find DDR3 laying around, I just swap the original samsung 256MB chips for the 512MB micron ones. Maybe I need to make other steps to unlock the memory. I already reflashed it from maskrom, still 1GB. Maybe you can help.I know the hardware stuff, but no so much about the software. 🤣
Yes, this issue about wireless exists, I could not access any inbound port from wireless. I noticed that if I just plug my etherned cable, and instantly try to access SSH using the wireless ip, works fine, but if I disconnect the cable, stop working.  I "fixed" apparently by disabling the eth0 with ifconfig, but I dont know if it is a proper fix 😅
About the HDMI I tested it again and worked, but show as "built in audio" instead HDMI audio, like on the legacy one does show, differentiating built in, from HDMI.
Yes, I noticed that, but its the only option if you dont want to use a SD card as system drive if you have NAND, right? Anyway, the problem that I mentioned on the media script existis, you can replicate if you want.
But for me, about the box, no matter, I plan now to use this box as a home server as you said. I'm running main from SD card, mininal install without desktop. I already installed apache2, mariadb, php, working fine, very responsive, I liked. If I can make 2GB work, would be awesome.
Link to comment
Ah, I did not understand you soldered bga chips directly on the board! Congrats, that's quite a skill!
Anyway, DDR amount is detected automatically and there is no software switch to change the amount of memory the system will detect. The right amount is purely a hardware matter, so I don't know if there is a resistor or something more complex to let the hardware being detected 🤷‍♂️
ssv6051p driver suffers from an ARP request problem, so even if the wireless is connected, the device does not actually respond to requests from external hosts, even pings, until you let the wireless exchange a packet with the network, doing like a ping from the box to the router for example. This is just a hypothesis though, no one really dug into; that could be or not be related to your isssue.
To use the NAND as system drive you need to use the legacy kernel, that's right. At the moment the NAND driver is not available for mainline kernels.
Link to comment
Hmm, do you know when the software do the detection? Maybe I just need to upgrade the bootloader on NAND for other (?) ... Don't know.. I'm not using nand right now, because I'm usind SD card to use mainline, but I think the multiboot tool flashed something to bypass NAND, if I remember correctly... 🤔
But if the detection is made during the system boot process, maybe its some resistor configuration or the kernel just "dont like" my modules. They are 8 bit instead 4 bit, and double the original density, but thats the only diferrence.
unknown.png?width=923&height=671unknown.png?width=879&height=671
Original was Samsung, K4B2G0446C, and the replacemant is from Micron, HTTC4G83BFR:
K4B: just Samsung marking.
2G:   2 Gigabites module (256 Megabytes)
04:   4 bit module
4:     8 internal banks *(3 = 4 banks, 4 = 8 banks, 5 = 16 banks)
6:     Voltage *(6 = 1.5v)
I took this data from Samsung datasheet... Micron is a little more dificult to find the right datasheet, but its fair to assume that this module has 4 Gigabites, 8 bytes, and for 4 internal banks, since its 4G83
The letters after that is just revision type, speed, power, etc, doesn't matter in this case.
Anyway, if you know where its detected the DRAM, and where the profiles for then (assuming that is some kind of profiling table) maybe just need to edit this, a big maybe on that, because I dont know s**t about the software compared to you guys.
Thanks @jock and @fabiobassa for the support until now 😃 Have a nice weekend.
Link to comment
@Felipe Triana DDR memory detection is made by a rockchip proprietary code that is called ddrbin as the very first binary code.
It's a closed source binary, so whatever it does and how it does is not known. It produces some debug messages that may be useful to you (memory arrangement, density, bus width) when the serial adapter is connected to the board.
There is a tool, ddrbin_tool, that can be used to alter ddr speed, ddr command rate timing and uart debug speed, but nothing more.
If you totally erased the NAND, then the ddrbin in use is the one from the sdcard, if you installed "jump start" with multitool, then the ddrbin in use is from NAND.
Multitool can't completely erase the NAND because the kernel driver has some limitations and cannot access the first sectors of the NAND, thus multitool can't neither write or read the installed ddrbin  in NAND.
Link to comment
Hey guys,
First thx to @jock and @fabiobassa for their amazing work!!
Im running docker-emby on my RK3229 box Armbian 21.08.1 Buster kernel legacy 4.4.194-rk322x and works fine...
If you need to test docker on your system try this as root:
cd /root
curl https://raw.githubusercontent.com/docker/docker/master/contrib/check-config.sh > check-config.sh
chmod +x check-config.sh
bash ./check-config.sh
Let me know if you wanna know how to run docker-emby ...🤓
Edited by primoitt
Link to comment
On 2/17/2022 at 4:09 PM, jock said:
@vhick @cnupy
Sorry for the issue, I discovered that the images I built were strangely missing the bootloader.
I'm rebuilding and will upload the images in a few minutes, hopefully these new images will be ok: I just tested the bullseye current minimal and it works fine, I guess the others will be fine too...
Good afternoon, My name is Marcio and I am part of an NGO where we have a computer project for inclusion here in Brazil. At first I apologize for the bad English (I'm using google translator). The IRS seized many of these devices mostly RK3229, RK322x, and we want to use these devices to supply the demand for donations that we need. I've tried several images but none works, multitool works, but when I burn the image in mmcblk2, it doesn't start and even if I burn it directly to the memory card it doesn't start either, I would really like some help. Thank you so much
Link to comment
@Poleto69
bom dia marcio, if you search on this same forum there was another brasilian man, he also was struggling with this honorable project  to bring computers and/or low power devices into favelas
Contact him so you can share infos on those box and achieve your goal
Edited by fabiobassa
Link to comment
Hello!
I would like to ask for help.
I have the following TV box:
MXQ-4k 5G
MXQ_RK3229
Wifi Chip: ESP8089-522014-P22G43
RK3229_MXQ_EMCP_V.4.0
Rockchip
4GB ram + 64GB storage
I want an SD card running Armbian for this box, but so far I haven't found a suitable Armbian image for this box.
From here I tried Armbian images: https://armbian.systemonachip.net/archive/rk322x-box/archive/
Do not write an image to the EMCP chip because it will be brick out of the box. So it stays in the box with the original firmware.
SD boot system may work, "Boot from sdcard" may be good.
These images work well when written to an SD card (starting from an SD card):
- Boot from SD card and works fine: Multitool (multitool.img)
- Starts and works well from SD card: LibreElec (LibreELEC-RK322x.arm-9.2-devel-20200427213119-b7186bc-rk3228a-mxq4kpro.img)
and this is also good (LibreELEC-RK322x.arm-9.2-devel-20220112105523-3ce5dd4-rk3228a-mxq4kpro.img)
Is there an Armbian that can boot from an SD card and work with it to install APT GET programs?
I would need an image file that can do this and work with my TV box.
I want to install Octoprint on linux to control a 3D printer via USB.
I would reach the box with a Wi-Fi connection. That would be the mission of the box.
Maybe this TV box is not suitable for this because there is no system for it.
The following may help something about my system.
Multitool log: (dmesg.multitool.log)
[    0.000000] Booting Linux on physical CPU 0xf00
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.194-rk322x (root@armbianbuild) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) ) #47 SMP Thu Apr 9 17:37:46 UTC 2020
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Generic RK322x TV Box board
[    0.000000] cma: Reserved 128 MiB at 0x98000000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 258560
[    0.000000] free_area_init_node: node 0, pgdat b1236b40, node_mem_map e76b9000
[    0.000000]   Normal zone: 2304 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 258560 pages, LIFO batch:31
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv65535.65535 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 14 pages/cpu @e7659000 s24856 r8192 d24296 u57344
[    0.000000] pcpu-alloc: s24856 r8192 d24296 u57344 alloc=14*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 256256
[    0.000000] Kernel command line: boot=PARTUUID=00628e24-01 root=PARTUUID=00628e24-02 rootwait console=ttyS2,115200 verbose=1 consoleblank=0
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 871700K/1034240K available (12820K kernel code, 875K rwdata, 3224K rodata, 796K init, 1219K bss, 31468K reserved, 131072K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
                   lowmem  : 0xb0000000 - 0xf0000000   (1024 MB)
                   pkmap   : 0xafe00000 - 0xb0000000   (   2 MB)
                   modules : 0xaf000000 - 0xafe00000   (  14 MB)
                     .text : 0xb0008000 - 0xb0c8d53c   (12822 kB)
                     .init : 0xb10a1000 - 0xb1168000   ( 796 kB)
                     .data : 0xb1168000 - 0xb1242e94   ( 876 kB)
                      .bss : 0xb1244000 - 0xb1374ee4   (1220 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]     Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[    0.000009] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[    0.000024] Switching to timer-based delay loop, resolution 41ns
[    0.001760] Console: colour dummy device 80x30
[    0.001804] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
[    0.001825] pid_max: default: 32768 minimum: 301
[    0.001976] Security Framework initialized
[    0.001992] Yama: becoming mindful.
[    0.002082] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002099] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.003127] Initializing cgroup subsys io
[    0.003170] Initializing cgroup subsys memory
[    0.003221] Initializing cgroup subsys devices
[    0.003243] Initializing cgroup subsys freezer
[    0.003261] Initializing cgroup subsys net_cls
[    0.003279] Initializing cgroup subsys perf_event
[    0.003298] Initializing cgroup subsys net_prio
[    0.003332] Initializing cgroup subsys pids
[    0.003411] CPU: Testing write buffer coherency: ok
[    0.003471] ftrace: allocating 41720 entries in 123 pages
[    0.086889] /cpus/cpu@f00 missing clock-frequency property
[    0.086932] /cpus/cpu@f01 missing clock-frequency property
[    0.086951] /cpus/cpu@f02 missing clock-frequency property
[    0.086972] /cpus/cpu@f03 missing clock-frequency property
[    0.086986] CPU0: update cpu_capacity 430
[    0.086998] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[    0.087100] Setting up static identity map for 0x60008280 - 0x600082d8
[    0.090503] CPU1: update cpu_capacity 430
[    0.090513] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[    0.091797] CPU2: update cpu_capacity 430
[    0.091806] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[    0.093063] CPU3: update cpu_capacity 430
[    0.093072] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[    0.093236] Brought up 4 CPUs
[    0.093278] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[    0.093287] CPU: All CPU(s) started in SVC mode.
[    0.095146] devtmpfs: initialized
[    0.113402] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.114017] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.114062] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.120812] xor: measuring software checksum speed
[    0.158888]    arm4regs  :  1011.000 MB/sec
[    0.198997]    8regs     :   705.000 MB/sec
[    0.239099]    32regs    :   684.000 MB/sec
[    0.279201]    neon      :  1018.000 MB/sec
[    0.279212] xor: using function: neon (1018.000 MB/sec)
[    0.279257] pinctrl core: initialized pinctrl subsystem
[    0.281074] NET: Registered protocol family 16
[    0.283509] DMA: preallocated 2048 KiB pool for atomic coherent allocations
[    0.295404] cpuidle: using governor ladder
[    0.307410] cpuidle: using governor menu
[    0.324343] gpiochip_add_data: registered GPIOs 0 to 31 on device: gpio0
[    0.324515] gpiochip_add_data: registered GPIOs 32 to 63 on device: gpio1
[    0.324663] gpiochip_add_data: registered GPIOs 64 to 95 on device: gpio2
[    0.324824] gpiochip_add_data: registered GPIOs 96 to 127 on device: gpio3
[    0.331182] console [pstore-1] enabled
[    0.331196] pstore: Registered ramoops as persistent store backend
[    0.331209] ramoops: attached 0xf0000@0x62e00000, ecc: 0/0
[    0.334287] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.334312] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.432570] raid6: int32x1  gen()   133 MB/s
[    0.500584] raid6: int32x1  xor()   131 MB/s
[    0.568809] raid6: int32x2  gen()   166 MB/s
[    0.637100] raid6: int32x2  xor()   137 MB/s
[    0.705242] raid6: int32x4  gen()   163 MB/s
[    0.773482] raid6: int32x4  xor()   137 MB/s
[    0.841655] raid6: int32x8  gen()   166 MB/s
[    0.909920] raid6: int32x8  xor()   113 MB/s
[    0.977906] raid6: neonx1   gen()   381 MB/s
[    1.046207] raid6: neonx1   xor()   290 MB/s
[    1.114410] raid6: neonx2   gen()   519 MB/s
[    1.182568] raid6: neonx2   xor()   376 MB/s
[    1.250841] raid6: neonx4   gen()   581 MB/s
[    1.318999] raid6: neonx4   xor()   400 MB/s
[    1.387270] raid6: neonx8   gen()   559 MB/s
[    1.455486] raid6: neonx8   xor()   391 MB/s
[    1.455499] raid6: using algorithm neonx4 gen() 581 MB/s
[    1.455510] raid6: .... xor() 400 MB/s, rmw enabled
[    1.455521] raid6: using intx1 recovery algorithm
[    1.456656] rockchip-pm rockchip-suspend: not set wakeup-config
[    1.456681] rockchip-pm rockchip-suspend: not set pwm-regulator-config
[    1.457065] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@0[0]'
[    1.457631] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/regulators/regulator@1[0]'
[    1.458335] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc-host-regulator[0]' - status (0)
[    1.459029] of_get_named_gpiod_flags: parsed 'gpio' property of node '/otg-vbus-regulator[0]' - status (0)
[    1.459667] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/vcc-phy-regulator[0]'
[    1.460615] iommu: Adding device 20020000.vpu-service to group 0
[    1.460731] iommu: Adding device 20030000.rkvdec to group 1
[    1.460830] iommu: Adding device 20050000.vop to group 2
[    1.460925] iommu: Adding device 20070000.iep to group 3
[    1.461551] rk_iommu 20020800.iommu: can't get sclk
[    1.462295] rk_iommu 20030480.iommu: can't get sclk
[    1.462560] rk_iommu 20053f00.iommu: can't get sclk
[    1.462708] rk_iommu 20070800.iommu: can't get aclk
[    1.462728] rk_iommu 20070800.iommu: can't get hclk
[    1.462744] rk_iommu 20070800.iommu: can't get sclk
[    1.463723] SCSI subsystem initialized
[    1.464170] usbcore: registered new interface driver usbfs
[    1.464273] usbcore: registered new interface driver hub
[    1.464417] usbcore: registered new device driver usb
[    1.464658] media: Linux media interface: v0.10
[    1.464743] Linux video capture interface: v2.00
[    1.464968] pps_core: LinuxPPS API ver. 1 registered
[    1.464984] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.465026] PTP clock support registered
[    1.467212] Advanced Linux Sound Architecture Driver Initialized.
[    1.468477] Bluetooth: Core ver 2.21
[    1.468562] NET: Registered protocol family 31
[    1.468575] Bluetooth: HCI device and connection manager initialized
[    1.468598] Bluetooth: HCI socket layer initialized
[    1.468617] Bluetooth: L2CAP socket layer initialized
[    1.468681] Bluetooth: SCO socket layer initialized
[    1.469604] NetLabel: Initializing
[    1.469629] NetLabel:  domain hash size = 128
[    1.469639] NetLabel:  protocols = UNLABELED CIPSOv4
[    1.469725] NetLabel:  unlabeled traffic allowed by default
[    1.470932] clocksource: Switched to clocksource arch_sys_counter
[    1.574247] NET: Registered protocol family 2
[    1.575382] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    1.575506] TCP bind hash table entries: 8192 (order: 5, 163840 bytes)
[    1.575864] TCP: Hash tables configured (established 8192 bind 8192)
[    1.575983] UDP hash table entries: 512 (order: 2, 24576 bytes)
[    1.576056] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes)
[    1.576448] NET: Registered protocol family 1
[    1.577328] RPC: Registered named UNIX socket transport module.
[    1.577358] RPC: Registered udp transport module.
[    1.577368] RPC: Registered tcp transport module.
[    1.577379] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.578417] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[    1.581682] Initialise system trusted keyring
[    1.596629] VFS: Disk quotas dquot_6.6.0
[    1.596973] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.599977] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.603727] NFS: Registering the id_resolver key type
[    1.603823] Key type id_resolver registered
[    1.603837] Key type id_legacy registered
[    1.603874] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.603973] ntfs: driver 2.1.32 [Flags: R/W].
[    1.604934] JFS: nTxBlock = 7834, nTxLock = 62673
[    1.617945] SGI XFS with security attributes, no debug enabled
[    1.627919] NET: Registered protocol family 38
[    1.627985] Key type asymmetric registered
[    1.628008] Asymmetric key parser 'x509' registered
[    1.628469] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[    1.628802] io scheduler noop registered
[    1.628838] io scheduler deadline registered
[    1.628933] io scheduler cfq registered (default)
[    1.632620] phy phy-11000000.syscon:usb2-phy@800.2: Failed to get VBUS supply regulator
[    1.638207] rk-vcodec 20020000.vpu-service: no regulator for vcodec
[    1.638789] rk-vcodec 20020000.vpu-service: probe device
[    1.639398] rk-vcodec 20020000.vpu-service: drm allocator with mmu enabled
[    1.640965] rk-vcodec 20020000.vpu-service: could not find power_model node
[    1.640998] rk-vcodec 20020000.vpu-service: init success
[    1.641393] rk-vcodec 20030000.rkvdec: vcodec regulator not ready, retry
[    1.645956] dma-pl330 110f0000.pdma: Loaded driver for PL330 DMAC-241330
[    1.645991] dma-pl330 110f0000.pdma:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
[    1.647339] rockchip-system-monitor rockchip-system-monitor: system monitor probe
[    1.647857] pwm-regulator vdd-arm-regulator: GPIO lookup for consumer enable
[    1.647879] pwm-regulator vdd-arm-regulator: using device tree for GPIO lookup
[    1.647899] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-arm-regulator[0]'
[    1.647913] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-arm-regulator[0]'
[    1.647927] pwm-regulator vdd-arm-regulator: using lookup tables for GPIO lookup
[    1.647942] pwm-regulator vdd-arm-regulator: lookup for GPIO enable failed
[    1.648694] pwm-regulator vdd-log-regulator: GPIO lookup for consumer enable
[    1.648719] pwm-regulator vdd-log-regulator: using device tree for GPIO lookup
[    1.648736] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/vdd-log-regulator[0]'
[    1.648751] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/vdd-log-regulator[0]'
[    1.648764] pwm-regulator vdd-log-regulator: using lookup tables for GPIO lookup
[    1.648778] pwm-regulator vdd-log-regulator: lookup for GPIO enable failed
[    1.649917] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.650870] 11030000.serial: ttyS2 at MMIO 0x11030000 (irq = 30, base_baud = 1500000) is a 16550A
[    2.682824] console [ttyS2] enabled
[    2.688385] [drm] Initialized drm 1.1.0 20060810
[    2.695698] [drm] Rockchip DRM driver version: v1.0.1
[    2.701101] rockchip-drm display-subsystem: devfreq is not set
[    2.707861] rockchip-drm display-subsystem: bound 20050000.vop (ops 0xb0d111b0)
[    2.715699] i2c i2c-0: of_i2c: modalias failure on /hdmi@200a0000/ports
[    2.722382] dwhdmi-rockchip 200a0000.hdmi: registered DesignWare HDMI I2C bus driver
[    2.730259] dwhdmi-rockchip 200a0000.hdmi: Detected HDMI TX controller v2.01a with HDCP (inno_dw_hdmi_phy)
[    2.741523] rockchip-drm display-subsystem: bound 200a0000.hdmi (ops 0xb0d09708)
[    2.749036] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    2.755682] [drm] No driver support for vblank timestamp query.
[    2.761780] rockchip-drm display-subsystem: failed to parse display resources
[    3.392773] rockchip-vop 20050000.vop: [drm:vop_crtc_enable] Update mode to 1920x1080p60, type: 11
[    3.393479] dwhdmi-rockchip 200a0000.hdmi: HDMI infoframe: Auxiliary Video Information (AVI), version 2, length 13
[    3.393487] dwhdmi-rockchip 200a0000.hdmi:     colorspace: RGB
[    3.393495] dwhdmi-rockchip 200a0000.hdmi:     scan mode: Underscan
[    3.393501] dwhdmi-rockchip 200a0000.hdmi:     colorimetry: No Data
[    3.393509] dwhdmi-rockchip 200a0000.hdmi:     picture aspect: 16:9
[    3.393516] dwhdmi-rockchip 200a0000.hdmi:     active aspect: Same as Picture
[    3.393522] dwhdmi-rockchip 200a0000.hdmi:     itc: IT Content
[    3.393529] dwhdmi-rockchip 200a0000.hdmi:     extended colorimetry: xvYCC 601
[    3.393536] dwhdmi-rockchip 200a0000.hdmi:     quantization range: Full
[    3.393543] dwhdmi-rockchip 200a0000.hdmi:     nups: Unknown Non-uniform Scaling
[    3.393549] dwhdmi-rockchip 200a0000.hdmi:     video code: 16
[    3.393556] dwhdmi-rockchip 200a0000.hdmi:     ycc quantization range: Full
[    3.393563] dwhdmi-rockchip 200a0000.hdmi:     hdmi content type: Graphics
[    3.393569] dwhdmi-rockchip 200a0000.hdmi:     pixel repeat: 0
[    3.393577] dwhdmi-rockchip 200a0000.hdmi:     bar top 0, bottom 0, left 0, right 0
[    3.473466] Console: switching to colour frame buffer device 240x67
[    3.641271] rockchip-drm display-subsystem: fb0:  frame buffer device
[    3.667964] brd: module loaded
[    3.686306] loop: module loaded
[    3.689640] lkdtm: No crash points registered, enable through debugfs
[    3.699750] libphy: Fixed MDIO Bus: probed
[    3.703969] tun: Universal TUN/TAP device driver, 1.6
[    3.709063] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    3.715845] CAN device driver interface
[    3.721662] rk_gmac-dwmac 30200000.ethernet: clock input or output? (output).
[    3.728932] rk_gmac-dwmac 30200000.ethernet: TX delay(0x30).
[    3.734632] rk_gmac-dwmac 30200000.ethernet: RX delay(0x10).
[    3.740378] rk_gmac-dwmac 30200000.ethernet: integrated PHY? (yes).
[    3.746876] rk_gmac-dwmac 30200000.ethernet: cannot get clock clk_mac_speed
[    3.758949] rk_gmac-dwmac 30200000.ethernet: init for RMII
[    3.799183] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.804296]  Ring mode enabled
[    3.807386]  DMA HW capability register supported
[    3.811963]  Normal descriptors
[    3.815315]  RX Checksum Offload Engine supported (type 2)
[    3.820816]  TX Checksum insertion supported
[    3.825104]  Wake-Up On Lan supported
[    3.828941] rk_gmac-dwmac 30200000.ethernet: rk_get_eth_addr: mac address: 9e:69:55:b9:b8:30
[    3.837423] eth%d: device MAC address 9e:69:55:b9:b8:30
[    3.842676]  Enable RX Mitigation via HW Watchdog Timer
[    3.848249] of_get_named_gpiod_flags: parsed 'snps,reset-gpio' property of node '/ethernet@30200000[0]' - status (0)
[    3.870593] libphy: stmmac: probed
[    3.874310] eth%d: PHY ID 1234d400 at 0 IRQ POLL (stmmac-0:00) active
[    3.880866] eth%d: PHY ID 00000000 at 1 IRQ POLL (stmmac-0:01)
[    3.886737] eth%d: PHY ID 00000000 at 2 IRQ POLL (stmmac-0:02)
[    3.892601] eth%d: PHY ID 00000000 at 3 IRQ POLL (stmmac-0:03)
[    3.898477] eth%d: PHY ID 00000000 at 4 IRQ POLL (stmmac-0:04)
[    3.904341] eth%d: PHY ID 00000000 at 5 IRQ POLL (stmmac-0:05)
[    3.910204] eth%d: PHY ID 00000000 at 6 IRQ POLL (stmmac-0:06)
[    3.916068] eth%d: PHY ID 00000000 at 7 IRQ POLL (stmmac-0:07)
[    3.921925] eth%d: PHY ID 00000000 at 8 IRQ POLL (stmmac-0:08)
[    3.927800] eth%d: PHY ID 00000000 at 9 IRQ POLL (stmmac-0:09)
[    3.933659] eth%d: PHY ID 00000000 at 10 IRQ POLL (stmmac-0:0a)
[    3.939600] eth%d: PHY ID 00000000 at 11 IRQ POLL (stmmac-0:0b)
[    3.945562] eth%d: PHY ID 00000000 at 12 IRQ POLL (stmmac-0:0c)
[    3.951503] eth%d: PHY ID 00000000 at 13 IRQ POLL (stmmac-0:0d)
[    3.957445] eth%d: PHY ID 00000000 at 14 IRQ POLL (stmmac-0:0e)
[    3.963394] eth%d: PHY ID 00000000 at 15 IRQ POLL (stmmac-0:0f)
[    3.969334] eth%d: PHY ID 00000000 at 16 IRQ POLL (stmmac-0:10)
[    3.975276] eth%d: PHY ID 00000000 at 17 IRQ POLL (stmmac-0:11)
[    3.981230] eth%d: PHY ID 00000000 at 18 IRQ POLL (stmmac-0:12)
[    3.987171] eth%d: PHY ID 00000000 at 19 IRQ POLL (stmmac-0:13)
[    3.993112] eth%d: PHY ID 00000000 at 20 IRQ POLL (stmmac-0:14)
[    3.999095] eth%d: PHY ID 00000000 at 21 IRQ POLL (stmmac-0:15)
[    4.005059] eth%d: PHY ID 00000000 at 22 IRQ POLL (stmmac-0:16)
[    4.011024] eth%d: PHY ID 00000000 at 23 IRQ POLL (stmmac-0:17)
[    4.016979] eth%d: PHY ID 00000000 at 24 IRQ POLL (stmmac-0:18)
[    4.022940] eth%d: PHY ID 00000000 at 25 IRQ POLL (stmmac-0:19)
[    4.028903] eth%d: PHY ID 00000000 at 26 IRQ POLL (stmmac-0:1a)
[    4.034851] eth%d: PHY ID 00000000 at 27 IRQ POLL (stmmac-0:1b)
[    4.040800] eth%d: PHY ID 00000000 at 28 IRQ POLL (stmmac-0:1c)
[    4.046758] eth%d: PHY ID 00000000 at 29 IRQ POLL (stmmac-0:1d)
[    4.052709] eth%d: PHY ID 00000000 at 30 IRQ POLL (stmmac-0:1e)
[    4.058660] eth%d: PHY ID 00000000 at 31 IRQ POLL (stmmac-0:1f)
[    4.066666] PPP generic driver version 2.4.2
[    4.071656] Atmel at76x USB Wireless LAN Driver 0.17 loading
[    4.077567] usbcore: registered new interface driver at76c50x-usb
[    4.083884] usbcore: registered new interface driver rtl8187
[    4.089716] usbcore: registered new interface driver rndis_wlan
[    4.095821] usbcore: registered new interface driver zd1201
[    4.102073] usbcore: registered new interface driver rt2800usb
[    4.108235] Rockchip WiFi SYS interface (V1.00) ...
[    4.113349] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[    4.120917] usbcore: registered new interface driver pegasus
[    4.126734] usbcore: registered new interface driver rtl8150
[    4.132530] usbcore: registered new interface driver r8152
[    4.138171] usbcore: registered new interface driver asix
[    4.143696] usbcore: registered new interface driver ax88179_178a
[    4.149922] usbcore: registered new interface driver cdc_ether
[    4.155901] usbcore: registered new interface driver dm9601
[    4.161626] usbcore: registered new interface driver smsc75xx
[    4.167553] usbcore: registered new interface driver smsc95xx
[    4.173430] usbcore: registered new interface driver net1080
[    4.179207] usbcore: registered new interface driver rndis_host
[    4.185253] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[    4.192860] usbcore: registered new interface driver cdc_ncm
[    4.198645] usbcore: registered new interface driver cdc_mbim
[    4.205158] 30040000.usb supply vusb_d not found, using dummy regulator
[    4.211982] 30040000.usb supply vusb_a not found, using dummy regulator
[    4.232398] dwc2 30040000.usb: DWC OTG Controller
[    4.237303] dwc2 30040000.usb: new USB bus registered, assigned bus number 1
[    4.244483] dwc2 30040000.usb: irq 49, io mem 0x30040000
[    4.250277] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.257125] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.264380] usb usb1: Product: DWC OTG Controller
[    4.269111] usb usb1: Manufacturer: Linux 4.4.194-rk322x dwc2_hsotg
[    4.275402] usb usb1: SerialNumber: 30040000.usb
[    4.281459] hub 1-0:1.0: USB hub found
[    4.285371] hub 1-0:1.0: 1 port detected
[    4.291597] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.298207] ehci-platform: EHCI generic platform driver
[    4.306312] ehci-platform 30080000.usb: EHCI Host Controller
[    4.312618] ehci-platform 30080000.usb: new USB bus registered, assigned bus number 2
[    4.320984] ehci-platform 30080000.usb: irq 50, io mem 0x30080000
[    4.339032] ehci-platform 30080000.usb: USB 2.0 started, EHCI 1.00
[    4.345670] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.352529] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.359777] usb usb2: Product: EHCI Host Controller
[    4.364682] usb usb2: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.370801] usb usb2: SerialNumber: 30080000.usb
[    4.376684] hub 2-0:1.0: USB hub found
[    4.380591] hub 2-0:1.0: 1 port detected
[    4.387806] ehci-platform 300c0000.usb: EHCI Host Controller
[    4.394096] ehci-platform 300c0000.usb: new USB bus registered, assigned bus number 3
[    4.402441] ehci-platform 300c0000.usb: irq 52, io mem 0x300c0000
[    4.419020] ehci-platform 300c0000.usb: USB 2.0 started, EHCI 1.00
[    4.425643] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    4.432499] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.439755] usb usb3: Product: EHCI Host Controller
[    4.444659] usb usb3: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.450777] usb usb3: SerialNumber: 300c0000.usb
[    4.456718] hub 3-0:1.0: USB hub found
[    4.460606] hub 3-0:1.0: 1 port detected
[    4.467820] ehci-platform 30100000.usb: EHCI Host Controller
[    4.474120] ehci-platform 30100000.usb: new USB bus registered, assigned bus number 4
[    4.482471] ehci-platform 30100000.usb: irq 54, io mem 0x30100000
[    4.499021] ehci-platform 30100000.usb: USB 2.0 started, EHCI 1.00
[    4.505618] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    4.512476] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.519728] usb usb4: Product: EHCI Host Controller
[    4.524631] usb usb4: Manufacturer: Linux 4.4.194-rk322x ehci_hcd
[    4.530749] usb usb4: SerialNumber: 30100000.usb
[    4.536704] hub 4-0:1.0: USB hub found
[    4.540615] hub 4-0:1.0: 1 port detected
[    4.545597] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    4.551895] ohci-platform: OHCI generic platform driver
[    4.557800] ohci-platform 300a0000.usb: Generic Platform OHCI controller
[    4.566210] ohci-platform 300a0000.usb: new USB bus registered, assigned bus number 5
[    4.574562] ohci-platform 300a0000.usb: irq 51, io mem 0x300a0000
[    4.639360] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[    4.646229] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.653496] usb usb5: Product: Generic Platform OHCI controller
[    4.659453] usb usb5: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.665577] usb usb5: SerialNumber: 300a0000.usb
[    4.671750] hub 5-0:1.0: USB hub found
[    4.675670] hub 5-0:1.0: 1 port detected
[    4.680808] ohci-platform 300e0000.usb: Generic Platform OHCI controller
[    4.688126] ohci-platform 300e0000.usb: new USB bus registered, assigned bus number 6
[    4.696425] ohci-platform 300e0000.usb: irq 53, io mem 0x300e0000
[    4.759399] usb usb6: New USB device found, idVendor=1d6b, idProduct=0001
[    4.766263] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.773547] usb usb6: Product: Generic Platform OHCI controller
[    4.779511] usb usb6: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.785636] usb usb6: SerialNumber: 300e0000.usb
[    4.792458] hub 6-0:1.0: USB hub found
[    4.796394] hub 6-0:1.0: 1 port detected
[    4.801503] ohci-platform 30120000.usb: Generic Platform OHCI controller
[    4.808842] ohci-platform 30120000.usb: new USB bus registered, assigned bus number 7
[    4.817149] ohci-platform 30120000.usb: irq 55, io mem 0x30120000
[    4.883314] usb usb7: New USB device found, idVendor=1d6b, idProduct=0001
[    4.890175] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.897433] usb usb7: Product: Generic Platform OHCI controller
[    4.903400] usb usb7: Manufacturer: Linux 4.4.194-rk322x ohci_hcd
[    4.909527] usb usb7: SerialNumber: 30120000.usb
[    4.915933] hub 7-0:1.0: USB hub found
[    4.919847] hub 7-0:1.0: 1 port detected
[    4.925080] usbcore: registered new interface driver cdc_acm
[    4.930813] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    4.939050] usbcore: registered new interface driver cdc_wdm
[    4.945068] usbcore: registered new interface driver usb-storage
[    4.951376] usbcore: registered new interface driver usbserial
[    4.957364] usbcore: registered new interface driver usbserial_generic
[    4.964003] usbserial: USB Serial support registered for generic
[    4.970171] usbcore: registered new interface driver keyspan
[    4.975922] usbserial: USB Serial support registered for Keyspan - (without firmware)
[    4.983854] usbserial: USB Serial support registered for Keyspan 1 port adapter
[    4.991277] usbserial: USB Serial support registered for Keyspan 2 port adapter
[    4.998675] usbserial: USB Serial support registered for Keyspan 4 port adapter
[    5.006158] usbcore: registered new interface driver option
[    5.011842] usbserial: USB Serial support registered for GSM modem (1-port)
[    5.019627] usbcore: registered new interface driver oti6858
[    5.025668] usbserial: USB Serial support registered for oti6858
[    5.031883] usbcore: registered new interface driver qcserial
[    5.037746] usbserial: USB Serial support registered for Qualcomm USB modem
[    5.044921] usbcore: registered new interface driver sierra
[    5.050592] usbserial: USB Serial support registered for Sierra USB modem
[    5.058736] usbcore: registered new interface driver iforce
[    5.064609] usbcore: registered new interface driver xpad
[    5.070368] usbcore: registered new interface driver usbtouchscreen
[    5.078071] i2c /dev entries driver
[    5.085152] usbcore: registered new interface driver uvcvideo
[    5.090980] USB Video Class driver (1.1.1)
[    5.097522] Boot mode: normal
[    5.102335] rockchip-thermal 11150000.tsadc: tsadc is probed successfully!
[    5.111409] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[    5.120601] Bluetooth: Virtual HCI driver ver 1.5
[    5.126103] Bluetooth: HCI UART driver ver 2.3
[    5.130647] Bluetooth: HCI UART protocol H4 registered
[    5.135823] Bluetooth: HCI UART protocol LL registered
[    5.141035] Bluetooth: HCI UART protocol ATH3K registered
[    5.146474] Bluetooth: HCI UART protocol Three-wire (H5) registered
[    5.153349] Bluetooth: HCI UART protocol BCM registered
[    5.158888] usbcore: registered new interface driver bfusb
[    5.164650] usbcore: registered new interface driver btusb
[    5.170251] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[    5.176781] cpu cpu0: leakage=4
[    5.180055] cpu cpu0: leakage-volt-sel=0
[    5.184481] cpu cpu0: Failed to get pvtm
[    5.190441] cpu cpu0: avs=0
[    5.193486] cpu cpu0: l=-2147483648 h=2147483647 hyst=0 l_limit=0 h_limit=0
[    5.200517] cpu cpu0: failed to read out thermal zone (-22)
[    5.207167] cpu cpu0: failed to find power_model node
[    5.213405] Synopsys Designware Multimedia Card Interface Driver
[    5.220547] dwmmc_rockchip 30000000.dwmmc: IDMAC supports 32-bit address mode.
[    5.228076] dwmmc_rockchip 30000000.dwmmc: Using internal DMA controller.
[    5.234941] dwmmc_rockchip 30000000.dwmmc: Version ID is 270a
[    5.241020] dwmmc_rockchip 30000000.dwmmc: DW MMC controller at irq 45,32 bit host data width,256 deep fifo
[    5.250965] dwmmc_rockchip 30000000.dwmmc: No vmmc regulator found
[    5.257183] dwmmc_rockchip 30000000.dwmmc: No vqmmc regulator found
[    5.263493] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer cd
[    5.263509] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.263569] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/dwmmc@30000000[0]' - status (0)
[    5.263641] gpio-49 (cd): gpiod_set_debounce: missing set() or set_debounce() operations
[    5.263656] dwmmc_rockchip 30000000.dwmmc: Got CD GPIO
[    5.268837] dwmmc_rockchip 30000000.dwmmc: GPIO lookup for consumer wp
[    5.268851] dwmmc_rockchip 30000000.dwmmc: using device tree for GPIO lookup
[    5.268866] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30000000[0]'
[    5.268876] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30000000[0]'
[    5.268886] dwmmc_rockchip 30000000.dwmmc: using lookup tables for GPIO lookup
[    5.268902] dwmmc_rockchip 30000000.dwmmc: lookup for GPIO wp failed
[    5.281963] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
[    5.295005] usb 7-1: new low-speed USB device number 2 using ohci-platform
[    5.304461] dwmmc_rockchip 30000000.dwmmc: 1 slots initialized
[    5.311091] dwmmc_rockchip 30010000.dwmmc: num-slots property not found, assuming 1 slot is available
[    5.320585] dwmmc_rockchip 30010000.dwmmc: IDMAC supports 32-bit address mode.
[    5.328195] dwmmc_rockchip 30010000.dwmmc: Using internal DMA controller.
[    5.335106] dwmmc_rockchip 30010000.dwmmc: Version ID is 270a
[    5.341060] dwmmc_rockchip 30010000.dwmmc: DW MMC controller at irq 46,32 bit host data width,256 deep fifo
[    5.351009] dwmmc_rockchip 30010000.dwmmc: No vmmc regulator found
[    5.357265] dwmmc_rockchip 30010000.dwmmc: No vqmmc regulator found
[    5.363791] dwmmc_rockchip 30010000.dwmmc: GPIO lookup for consumer wp
[    5.363816] dwmmc_rockchip 30010000.dwmmc: using device tree for GPIO lookup
[    5.363838] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30010000[0]'
[    5.363853] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30010000[0]'
[    5.363867] dwmmc_rockchip 30010000.dwmmc: using lookup tables for GPIO lookup
[    5.363883] dwmmc_rockchip 30010000.dwmmc: lookup for GPIO wp failed
[    5.377210] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 400000Hz, actual 244140HZ div = 2)
[    5.395838] mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.405804] dwmmc_rockchip 30010000.dwmmc: 1 slots initialized
[    5.412122] dwmmc_rockchip 30020000.dwmmc: IDMAC supports 32-bit address mode.
[    5.419727] dwmmc_rockchip 30020000.dwmmc: Using internal DMA controller.
[    5.419817] mmc0: new high speed SDHC card at address 1234
[    5.421092] mmcblk0: mmc0:1234 SA04G 3.71 GiB
[    5.423268]  mmcblk0: p1 p2
[    5.439451] dwmmc_rockchip 30020000.dwmmc: Version ID is 270a
[    5.445400] dwmmc_rockchip 30020000.dwmmc: DW MMC controller at irq 47,32 bit host data width,256 deep fifo
[    5.455286] dwmmc_rockchip 30020000.dwmmc: 'clock-freq-min-max' property was deprecated.
[    5.459010] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 300000Hz, actual 244140HZ div = 2)
[    5.472727] dwmmc_rockchip 30020000.dwmmc: No vmmc regulator found
[    5.478957] dwmmc_rockchip 30020000.dwmmc: No vqmmc regulator found
[    5.485284] dwmmc_rockchip 30020000.dwmmc: GPIO lookup for consumer wp
[    5.485307] dwmmc_rockchip 30020000.dwmmc: using device tree for GPIO lookup
[    5.485331] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/dwmmc@30020000[0]'
[    5.485349] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/dwmmc@30020000[0]'
[    5.485363] dwmmc_rockchip 30020000.dwmmc: using lookup tables for GPIO lookup
[    5.485380] dwmmc_rockchip 30020000.dwmmc: lookup for GPIO wp failed
[    5.498502] mmc_host mmc2: Bus speed (slot 0) = 2343750Hz (slot req 400000Hz, actual 390625HZ div = 3)
[    5.511141] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 200000Hz, actual 162760HZ div = 3)
[    5.520632] dwmmc_rockchip 30020000.dwmmc: 1 slots initialized
[    5.526038] usb 7-1: New USB device found, idVendor=03f0, idProduct=0024
[    5.526046] usb 7-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.526054] usb 7-1: Product: HP Basic USB Keyboard
[    5.526059] usb 7-1: Manufacturer: CHICONY
[    5.550676] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio-leds/mmc[0]' - status (0)
[    5.551355] ledtrig-cpu: registered to indicate activity on CPUs
[    5.557777] hidraw: raw HID events driver (C) Jiri Kosina
[    5.573237] input: CHICONY HP Basic USB Keyboard as /devices/platform/30120000.usb/usb7/7-1/7-1:1.0/0003:03F0:0024.0001/input/input0
[    5.576133] mmc_host mmc1: Bus speed (slot 0) = 976562Hz (slot req 100000Hz, actual 97656HZ div = 5)
[    5.609542] mmc_host mmc2: Bus speed (slot 0) = 50000000Hz (slot req 50000000Hz, actual 50000000HZ div = 0)
[    5.621362] mmc2: new high speed MMC card at address 0001
[    5.628051] mmcblk2: mmc2:0001 V10008 7.05 GiB
[    5.633366] mmcblk2boot0: mmc2:0001 V10008 partition 1 4.00 MiB
[    5.640042] mmcblk2boot1: mmc2:0001 V10008 partition 2 4.00 MiB
[    5.646697] mmcblk2rpmb: mmc2:0001 V10008 partition 3 4.00 MiB
[    5.654016] hid-generic 0003:03F0:0024.0001: input,hidraw0: USB HID v1.10 Keyboard [CHICONY HP Basic USB Keyboard] on usb-30120000.usb-1/input0
[    5.667636] usbcore: registered new interface driver usbhid
[    5.673344] usbhid: USB HID core driver
[    5.677938] ashmem: initialized
[    5.683655] rknandbase v1.2 2018-05-08
[    5.687982] rknand 30030000.nandc: rknand_probe clk rate = 150000000
[    5.694734] ftl_init fffffffe
[    5.697748] rk_ftl_init fail
[    5.702067] usbcore: registered new interface driver snd-usb-audio
[    5.708520] usbcore: registered new interface driver snd-ua101
[    5.714545] usbcore: registered new interface driver snd-usb-caiaq
[    5.720898] usbcore: registered new interface driver snd-usb-6fire
[    5.727211] usbcore: registered new interface driver snd-usb-hiface
[    5.733622] usbcore: registered new interface driver snd-bcd2000
[    5.739762] usbcore: registered new interface driver snd_usb_pod
[    5.745953] usbcore: registered new interface driver snd_usb_podhd
[    5.752275] usbcore: registered new interface driver snd_usb_toneport
[    5.758843] usbcore: registered new interface driver snd_usb_variax
[    5.771372] u32 classifier
[    5.774112]     input device check on
[    5.777835]     Actions configured
[    5.781290] Netfilter messages via NETLINK v0.30.
[    5.786054] nfnl_acct: registering with nfnetlink.
[    5.791002] nf_conntrack version 0.5.0 (15668 buckets, 62672 max)
[    5.798186] Initializing XFRM netlink socket
[    5.803607] NET: Registered protocol family 10
[    5.809907] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    5.815834] sit: IPv6 over IPv4 tunneling driver
[    5.821630] NET: Registered protocol family 17
[    5.826224] NET: Registered protocol family 15
[    5.830797] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[    5.843508] Bridge firewalling registered
[    5.847562] can: controller area network core (rev 20120528 abi 9)
[    5.853861] NET: Registered protocol family 29
[    5.858354] can: raw protocol (rev 20120528)
[    5.862654] can: broadcast manager protocol (rev 20120528 t)
[    5.868350] can: netlink gateway (rev 20130117) max_hops=1
[    5.874573] Bluetooth: RFCOMM TTY layer initialized
[    5.879539] Bluetooth: RFCOMM socket layer initialized
[    5.884749] Bluetooth: RFCOMM ver 1.11
[    5.888554] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    5.894505] Bluetooth: HIDP socket layer initialized
[    5.899697] 8021q: 802.1Q VLAN Support v1.8
[    5.903973] lib80211: common routines for IEEE802.11 drivers
[    5.909662] lib80211_crypt: registered algorithm 'NULL'
[    5.909684] lib80211_crypt: registered algorithm 'WEP'
[    5.909699] lib80211_crypt: registered algorithm 'CCMP'
[    5.909713] lib80211_crypt: registered algorithm 'TKIP'
[    5.909730] [WLAN_RFKILL]: Enter rfkill_wlan_init
[    5.914881] [BT_RFKILL]: Enter rfkill_rk_init
[    5.919610] Key type dns_resolver registered
[    5.924534] flash vendor_init_thread!
[    5.924640] Error: Driver 'sc031gs' is already registered, aborting...
[    5.925291] Registering SWP/SWPB emulation handler
[    5.926718] registered taskstats version 1
[    5.926736] Loading compiled-in X.509 certificates
[    5.930355] Btrfs loaded
[    5.932156] rga2: Driver loaded successfully ver:4.01
[    5.932458] rga2: Module initialized.
[    5.932499] pvtm list NULL
[    5.934438] rk-vcodec 20030000.rkvdec: leakage=4
[    5.934499] rk-vcodec 20030000.rkvdec: leakage-volt-sel=0
[    5.934664] rk-vcodec 20030000.rkvdec: Failed to get pvtm
[    5.935496] rk-vcodec 20030000.rkvdec: avs=0
[    5.935970] rk-vcodec 20030000.rkvdec: probe device
[    5.936773] rk-vcodec 20030000.rkvdec: drm allocator with mmu enabled
[    5.939173] rk-vcodec 20030000.rkvdec: init success
[    5.940951] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/hdmi-sound[0]'
[    5.940960] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/hdmi-sound[0]'
[    5.944674] asoc-simple-card hdmi-sound: i2s-hifi <-> 100c0000.i2s0 mapping ok
[    5.947796] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/spdif-sound[0]'
[    5.947819] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/spdif-sound[0]'
[    5.949410] asoc-simple-card spdif-sound: dit-hifi <-> 100d0000.spdif mapping ok
[    5.952860] hctosys: unable to open rtc device (rtc0)
[    5.959298] vendor storage:20190527 ret = 0
[    5.969303] ALSA device list:
[    5.969316]   #0: DW-I2S-HDMI
[    5.969319]   #1: SPDIF
[    6.031506] flash vendor storage:20170308 ret = -1
[    6.036749] ttyS2 - failed to request DMA, use interrupt mode
[    6.051091] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
[    6.058639] squashfs: SQUASHFS error: unable to read xattr id index table
[    6.070175] VFS: Mounted root (squashfs filesystem) readonly on device 179:2.
[    6.082126] devtmpfs: mounted
[    6.086416] Freeing unused kernel memory: 796K
[    6.090945] This architecture does not have kernel memory protection.
[    7.398177] random: dropbear: uninitialized urandom read (32 bytes read, 30 bits of entropy available)
LibreElec's log: (kodi.log)
2022-06-06 07:57:38.599 T:3011133456  NOTICE: -----------------------------------------------------------------------
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Starting Kodi (18.6 Git:rockchip_18.6-Leia). Platform: Linux ARM 32-bit
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Using Release Kodi x32 build
2022-06-06 07:57:38.599 T:3011133456  NOTICE: Kodi compiled 2020-04-27 by GCC 8.3.0 for Linux ARM 32-bit version 4.4.194 (263362)
2022-06-06 07:57:38.600 T:3011133456  NOTICE: Running on LibreELEC (knaerzche): devel-20200427213119-b7186bc 9.2, kernel: Linux ARM 32-bit version 4.4.194
2022-06-06 07:57:38.600 T:3011133456  NOTICE: FFmpeg version/source: 4.0.4-Kodi
2022-06-06 07:57:38.600 T:3011133456  NOTICE: Host CPU: ARMv7 Processor rev 5 (v7l), 4 cores available
2022-06-06 07:57:38.600 T:3011133456  NOTICE: ARM Features: Neon enabled
2022-06-06 07:57:38.600 T:3011133456  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi/
2022-06-06 07:57:38.600 T:3011133456  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://masterprofile/ is mapped to: /storage/.kodi/userdata
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://envhome/ is mapped to: /storage
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://home/ is mapped to: /storage/.kodi
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://temp/ is mapped to: /storage/.kodi/temp
2022-06-06 07:57:38.601 T:3011133456  NOTICE: special://logpath/ is mapped to: /storage/.kodi/temp
2022-06-06 07:57:38.601 T:3011133456  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
2022-06-06 07:57:38.601 T:3011133456  NOTICE: Local hostname: LibreELEC
2022-06-06 07:57:38.601 T:3011133456  NOTICE: Log File is located: /storage/.kodi/temp/kodi.log
2022-06-06 07:57:38.601 T:3011133456  NOTICE: -----------------------------------------------------------------------
2022-06-06 07:57:38.627 T:3011133456    INFO: loading settings
2022-06-06 07:57:38.631 T:3011133456  NOTICE: special://profile/ is mapped to: special://masterprofile/
2022-06-06 07:57:38.689 T:3011133456   DEBUG: CSkinSettings: no <skinsettings> tag found
2022-06-06 07:57:38.692 T:3011133456  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2022-06-06 07:57:38.692 T:3011133456  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="utf-8" ?>
                                            <advancedsettings>
                                              <cputempcommand>/usr/bin/cputemp</cputempcommand>
                                              <gputempcommand>/usr/bin/gputemp</gputempcommand>
                                              <showexitbutton>false</showexitbutton>
                                              <remotedelay>1</remotedelay>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                            </advancedsettings>
2022-06-06 07:57:38.692 T:3011133456 WARNING: CSettingsManager: missing version attribute
2022-06-06 07:57:38.695 T:3011133456  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Default Video Player: VideoPlayer
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Default Audio Player: paplayer
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2022-06-06 07:57:38.696 T:3011133456  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2022-06-06 07:57:38.696 T:3011133456  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2022-06-06 07:57:39.040 T:3011133456  NOTICE: PulseAudio: Server found running - will try to use Pulse
2022-06-06 07:57:39.256 T:3011133456  NOTICE: Running database version Addons27
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: game.controller.default v1.0.19 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: game.controller.snes v1.0.18 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2022-06-06 07:57:39.857 T:3011133456  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: kodi.resource v1.0.0 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.album.universal v3.1.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.artists.universal v4.3.8 installed
2022-06-06 07:57:39.858 T:3011133456  NOTICE: ADDON: metadata.common.allmusic.com v3.2.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.fanart.tv v3.6.4 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.imdb.com v3.2.6 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.4 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.3 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.common.themoviedb.org v3.2.18 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.local v1.0.0 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.themoviedb.org v5.2.6 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.5.14 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: os.libreelec.tv v9.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: os.openelec.tv v9.2 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: peripheral.joystick v1.4.9 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: repository.kodi.game v1.0.0 installed
2022-06-06 07:57:39.859 T:3011133456  NOTICE: ADDON: repository.libreelec.tv v9.2.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: repository.xbmc.org v3.1.6 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.language.hu_hu v9.0.18 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.33 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.59 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.module.pil v1.1.7 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: script.program.driverselect v0.1.6 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: service.libreelec.settings v9.0.0 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: service.system.docker v9.2.0.127 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: skin.estuary v2.0.27 installed
2022-06-06 07:57:39.860 T:3011133456  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.addon v18.6.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.core v0.1.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.json v10.3.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.python v2.26.0 installed
2022-06-06 07:57:39.861 T:3011133456  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2022-06-06 07:57:39.954 T:3011133456   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2022-06-06 07:57:40.936 T:2988422016 WARNING: Pulseaudio module module-allow-passthrough not loaded - opening PT devices might fail
2022-06-06 07:57:40.939 T:2988422016  NOTICE: Found 2 Lists of Devices
2022-06-06 07:57:40.939 T:2988422016  NOTICE: Enumerated ALSA devices:
2022-06-06 07:57:40.939 T:2988422016  NOTICE:     Device 1
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceName      : @
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_displayName     : Default (ROCKCHIP,RK3229 Analog)
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_displayNameExtra:
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_sampleRates     : 8000,16000,32000,48000,64000,96000
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.940 T:2988422016  NOTICE:     Device 2
2022-06-06 07:57:40.940 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=ROCKCHIPRK3229
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayName     : ROCKCHIP,RK3229
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayNameExtra: Analog
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_sampleRates     : 8000,16000,32000,48000,64000,96000
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.941 T:2988422016  NOTICE:     Device 3
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=HDMI
2022-06-06 07:57:40.941 T:2988422016  NOTICE:         m_displayName     : HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.942 T:2988422016  NOTICE:     Device 4
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_deviceName      : hdmi:CARD=HDMI,DEV=0
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_displayName     : HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_displayNameExtra: VES 43FHD_LCD_TV on HDMI
2022-06-06 07:57:40.942 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_RAW,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2022-06-06 07:57:40.943 T:2988422016  NOTICE:     Device 5
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_deviceName      : sysdefault:CARD=ROCKCHIPSPDIF
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_displayName     : ROCKCHIP,SPDIF
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_displayNameExtra: Analog
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_sampleRates     : 32000,44100,48000,96000,192000
2022-06-06 07:57:40.943 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S16NE,AE_FMT_S16LE
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_streamTypes     : No passthrough capabilities
2022-06-06 07:57:40.944 T:2988422016  NOTICE: Enumerated PULSE devices:
2022-06-06 07:57:40.944 T:2988422016  NOTICE:     Device 1
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_deviceName      : Default
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_displayName     : Default
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_displayNameExtra: Bluetooth Audio (PULSEAUDIO)
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_channels        : FL, FR
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_sampleRates     : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2022-06-06 07:57:40.944 T:2988422016  NOTICE:         m_dataFormats     : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
2022-06-06 07:57:42.066 T:3011133456 WARNING: CDRMUtils::FindPlane - could not find plane
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 60.000000 Hz
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 60.000000 Hz
2022-06-06 07:57:42.073 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 50.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 50.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080i @ 48.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 30.000000 Hz
2022-06-06 07:57:42.074 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 25.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1920x1080 with 1920x1080 @ 24.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1600x1200 with 1600x1200 @ 60.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1680x1050 with 1680x1050 @ 60.000000 Hz
2022-06-06 07:57:42.075 T:3011133456  NOTICE: Found resolution 1400x1050 with 1400x1050 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x1024 with 1280x1024 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1440x900 with 1440x900 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x960 with 1280x960 @ 60.000000 Hz
2022-06-06 07:57:42.076 T:3011133456  NOTICE: Found resolution 1280x800 with 1280x800 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1280x720 with 1280x720 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1280x720 with 1280x720 @ 50.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 1024x768 with 1024x768 @ 60.000000 Hz
2022-06-06 07:57:42.077 T:3011133456  NOTICE: Found resolution 800x600 with 800x600 @ 60.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x576 with 720x576 @ 50.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x576 with 720x576i @ 50.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x480 with 720x480 @ 60.000000 Hz
2022-06-06 07:57:42.078 T:3011133456  NOTICE: Found resolution 720x480 with 720x480i @ 60.000000 Hz
2022-06-06 07:57:42.079 T:3011133456  NOTICE: Found resolution 640x480 with 640x480 @ 60.000000 Hz
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_VERSION = 1.4 Linux-r7p0-00rel0
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_VENDOR = ARM
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_EXT_image_dma_buf_import EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_reusable_sync EGL_KHR_fence_sync EGL_KHR_lock_surface EGL_KHR_lock_surface2 EGL_EXT_create_context_robustness EGL_ANDROID_blob_cache EGL_KHR_create_context EGL_KHR_partial_update EGL_KHR_create_context_no_error
2022-06-06 07:57:42.084 T:3011133456  NOTICE: EGL_CLIENT_EXTENSIONS = EGL_EXT_client_extensions EGL_EXT_platform_base EGL_KHR_platform_gbm
2022-06-06 07:57:42.090 T:3011133456  NOTICE: Checking resolution 25
2022-06-06 07:57:42.318 T:3011133456 WARNING: CGBMUtils::DestroySurface - surface already destroyed
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_VENDOR = ARM
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_RENDERER = Mali-400 MP
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_VERSION = OpenGL ES 2.0
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2022-06-06 07:57:42.785 T:3011133456  NOTICE: GL_EXTENSIONS = GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_compressed_ETC1_RGB8_texture GL_EXT_compressed_ETC1_RGB8_sub_texture GL_OES_standard_derivatives GL_OES_EGL_image GL_OES_depth24 GL_ARM_rgba8 GL_ARM_mali_shader_binary GL_OES_depth_texture GL_OES_packed_depth_stencil GL_EXT_texture_format_BGRA8888 GL_OES_vertex_half_float GL_EXT_blend_minmax GL_OES_EGL_image_external GL_OES_EGL_sync GL_OES_rgb8_rgba8 GL_EXT_multisampled_render_to_texture GL_EXT_discard_framebuffer GL_OES_get_program_binary GL_ARM_mali_program_binary GL_EXT_shader_texture_lod GL_EXT_robustness GL_OES_depth_texture_cube_map GL_KHR_debug GL_ARM_shader_framebuffer_fetch GL_ARM_shader_framebuffer_fetch_depth_stencil GL_OES_mapbuffer GL_KHR_no_error
2022-06-06 07:57:45.481 T:2923426688  NOTICE: Running database version Addons27
2022-06-06 07:57:45.489 T:2923426688  NOTICE: Running database version ViewModes6
2022-06-06 07:57:45.510 T:2923426688  NOTICE: Running database version Textures13
2022-06-06 07:57:45.555 T:2923426688  NOTICE: Running database version MyMusic72
2022-06-06 07:57:45.625 T:2923426688  NOTICE: Running database version MyVideos116
2022-06-06 07:57:45.638 T:2923426688  NOTICE: Running database version TV32
2022-06-06 07:57:45.649 T:2923426688  NOTICE: Running database version Epg12
2022-06-06 07:57:45.679 T:3011133456  NOTICE: start dvd mediatype detection
2022-06-06 07:57:45.869 T:3011133456  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.27)
2022-06-06 07:57:47.257 T:3011133456 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2022-06-06 07:57:47.397 T:3011133456  NOTICE: Register - new keyboard device registered on application->keyboard: Billentyűzet (0000:0000)
2022-06-06 07:57:47.399 T:3011133456  NOTICE: Register - new mouse device registered on application->mouse: Egér (0000:0000)
2022-06-06 07:57:47.413 T:3011133456  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2022-06-06 07:57:47.415 T:3011133456  NOTICE: Loaded playercorefactory configuration
2022-06-06 07:57:47.415 T:3011133456  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2022-06-06 07:57:47.416 T:3011133456  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2022-06-06 07:57:47.540 T:3011133456  NOTICE: initialize done
2022-06-06 07:57:47.545 T:3011133456  NOTICE: Running the application...
2022-06-06 07:57:47.567 T:3011133456  NOTICE: starting zeroconf publishing
2022-06-06 07:57:47.569 T:3011133456  NOTICE: CWebServer[8080]: Started
2022-06-06 07:57:47.575 T:2814321536  NOTICE: ES: Starting UDP Event server on port 9777
2022-06-06 07:57:47.576 T:2814321536  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2022-06-06 07:57:48.232 T:2898248576  NOTICE: Register - new cec device registered on cec->Linux: CEC Adapter (0000:0000)
2022-06-06 07:58:08.613 T:3011133456  NOTICE: Quitting due to POSIX signal
2022-06-06 07:58:08.679 T:3011133456  NOTICE: Stopping player
2022-06-06 07:58:08.680 T:3011133456  NOTICE: Storing total System Uptime
2022-06-06 07:58:08.680 T:3011133456  NOTICE: Saving settings
2022-06-06 07:58:08.713 T:3011133456  NOTICE: Saving skin settings
2022-06-06 07:58:08.720 T:3011133456  NOTICE: Stopping all
2022-06-06 07:58:08.721 T:3011133456  NOTICE: ES: Stopping event server
2022-06-06 07:58:08.753 T:3011133456  NOTICE: stopping zeroconf publishing
2022-06-06 07:58:08.777 T:3011133456  NOTICE: CWebServer[8080]: Stopped
2022-06-06 07:58:09.600 T:2814321536  NOTICE: ES: UDP Event server stopped
2022-06-06 07:58:09.625 T:3011133456  NOTICE: stop dvd detect media
2022-06-06 07:58:14.832 T:3011133456   ERROR: CPythonInvoker(1, /storage/.kodi/addons/service.system.docker/default.py): script didn't stop in 5 seconds - let's kill it
2022-06-06 07:58:15.071 T:3011133456  NOTICE: Application stopped
2022-06-06 07:58:15.272 T:3011133456  NOTICE: XBApplicationEx: destroying...
2022-06-06 07:58:29.877 T:3011133456  NOTICE: unload skin
2022-06-06 07:58:29.953 T:3011133456  NOTICE: unload sections
2022-06-06 07:58:30.174 T:3011133456  NOTICE: XBApplicationEx: application stopped!
Thanks
Edited by SteeMan
moved log to spoiler
Link to comment
Share on other sites
@Zoli I don't get what is your problem with armbian images, actually everything is described in the first page of this thread and you should not take the archived images (which are way older) but you should take the stable ones from https://users.armbian.com/jock/rk322x/armbian/stable/ and prefer the mainline/current kernel; legacy is not really maintained anymore.
Once you successfully test the image from sdcard (following the instructions on the first page), you may think to burn it on eMMC/eMCP using the multitool (or via armbian-config), but first be sure your armbian image boots from sdcard, otherwise you may risk to brick the board.
Link to comment
My box has served me well, unfortunately it got wet and finally gave up the ghost. i bought 3 other boxes, one is scishion v88 and the other two is tylex v88. installation with the scishion went well, everything works. the tylex box however could not detect the wifi chip. chip was marked sp6330, i removed the tin can on top of it and sure enough it was a bcm4330 chip. rk322x-config cannot detect the chip. attached are pics and armbian dmesg log. oh the scishion one is now serving as my print server very reliable.
dmesg.log
Link to comment
Hello @Seth, the TX3PRO board looks a nice one, with a clean design.
Probably your issue is due a low strength for the SDIO pins set by default device tree.
You may try to use the IPB900 (led-conf5) board configuration from rk322x-config, reboot and see if the wireless is detected. IPB900 is clearly not the board you have, so leds will probably not work, but that board has the same problem I think yours has, so it is useful to make a quick test.
If it works, we've just spotted the problem; anyway the original android image/backup (or, even better, just the dtb) is useful to make a better suited board configuration for TX3PRO
Link to comment
hello again
thanks for the reply @jock
sadly led-conf5 doesn't seem to work. the backup i made also seems to be corrupted because i used a dodgy microsd that came with an ender3 i bought. about 1GB is still readable though. i loaded it in binwalk and i have attached the log, i then used dd to extract the portion of the file that says flattened device tree, after that i converted the dtb to dts which is also attached here. i hope the files are readable enough. i got the trick from @hexdump at page 26 or 27 i think. and also the errors and warnings from the dtc command. i know the dts seems to say that it is rk3188 but it is a 3228A because i checked the processor physically. i'm guessing that this board originally used 3188 processor and that it just happened that 3228a was pin compatible and they repurposed their old boards, i am so confused right now...
edit:
i also forgot to mention that i did all this using the same box hooked up to my router lan. :D
I have also encountered the problem just like @Bandar but i just installed the legacy kernel, i found a small transistor at the power input of my tylex box which is way smaller than the intended footprint, i'm guessing it is used as a capacitance multiplier for cleaner dc since the dodgy power supplies that come with these boxes are noisy and severely underrated for the load. buster legacy and buster current with version 20.11.13 worked on mine though, but i just went with the bullseye legacy since it's newer.
binwalk.log devicetree.dtb devicetree.dts errors.log
Edited by Seth
Link to comment
@Seth I looked into the device tree you provided and it seems to be that the gpio pin to enable the wifi chip have reversed polarity. There seems to be several pins with reversed polarity (wifi, bluetooth, leds, ...) , so I need to craft a special device tree overlay to make tests.
Unfortunately I don't follow the legacy kernel anymore, everything is moving towards mainline since support is very good nowadays, so the overlay I will provide may or may not work on legacy kernel...
Link to comment
@jock
been playing with the tylex boxes last night and forgot to unplug it. woke up with 2 dead boxes probably power surge from thunderstorm killed it last night. might try to fix it when i find the time or i might transplant ram and emmc to the scishion box. i gotta unpack my hot air station from storage and go yolo this weekend. the scishion box has a lot of potential though just need to upgrade nand to emmc and add more ram. your rk3318/3328 project is starting to appeal to me too. lots of things to try out. :D
Link to comment
