TDCroPower Posted February 26 Posted February 26 (edited) I tried to install OMV 7 RC1 on the Bookworm image, but I get a lot of "Segmentation fault" and "free(): invalid pointer" error messages. My Installation for the Bookworm image... Is the problem due to the Bookworm image or the 6.6.8 kernel or should I contact the OMV team? Here is the complete log of the OMV 7 RC1 installation... Spoiler root@helios64:~# sudo curl -sSL https://github.com/OpenMediaVault-Plugin-Developers/installScript/raw/master/install | sudo bash [2024-02-22 13:32:50+0100] [omvinstall] script version :: 2.3.9 [2024-02-22 13:32:50+0100] [omvinstall] Armbian [2024-02-22 13:32:50+0100] [omvinstall] Starting ... [2024-02-22 13:32:50+0100] [omvinstall] Current / permissions = 755 mode of '/' retained as 0755 (rwxr-xr-x) [2024-02-22 13:32:50+0100] [omvinstall] New / permissions = 755 [2024-02-22 13:32:50+0100] [omvinstall] Forcing IPv4 only for apt... [2024-02-22 13:32:50+0100] [omvinstall] Updating repos before installing... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Hit:6 http://security.debian.org bookworm-security InRelease Hit:7 http://deb.debian.org/debian bookworm InRelease Hit:8 http://deb.debian.org/debian bookworm-updates InRelease Hit:9 http://deb.debian.org/debian bookworm-backports InRelease Hit:10 http://packages.openmediavault.org/public sandworm InRelease Reading package lists... [2024-02-22 13:33:02+0100] [omvinstall] Installing lsb_release... Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded. 1 not fully installed or removed. Need to get 6416 B of archives. After this operation, 0 B of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 lsb-release all 12.0-1 [6416 B] Fetched 6416 B in 0s (139 kB/s) (Reading database ... 84545 files and directories currently installed.) Preparing to unpack .../lsb-release_12.0-1_all.deb ... Unpacking lsb-release (12.0-1) over (12.0-1) ... Setting up lsb-release (12.0-1) ... Setting up openmediavault (7.0-32) ... Creating users/groups ... Updating local package archive ... Updating service units ... sshd.service is a disabled or a static unit, not starting it. Failed to preset unit, unit /etc/systemd/system/systemd-networkd.service is masked. /usr/bin/deb-systemd-helper: error: systemctl preset failed on systemd-networkd.service: No such file or directory dpkg: error processing package openmediavault (--configure): installed openmediavault package post-installation script subprocess returned error exit status 1 Processing triggers for man-db (2.11.2-2) ... Errors were encountered while processing: openmediavault Segmentation fault E: Sub-process /usr/bin/dpkg returned an error code (1) [2024-02-22 13:33:21+0100] [omvinstall] Arch :: arm64 [2024-02-22 13:33:21+0100] [omvinstall] Supported architecture [2024-02-22 13:33:21+0100] [omvinstall] Codename :: bookworm [2024-02-22 13:33:21+0100] [omvinstall] Copying /etc/resolv.conf to /root/resolv.conf ... '/etc/resolv.conf' -> '/root/resolv.conf' [2024-02-22 13:33:21+0100] [omvinstall] # This is /run/systemd/resolve/stub-resolv.conf managed by man:systemd-resolved(8). # Do not edit. # # This file might be symlinked as /etc/resolv.conf. If you're looking at # /etc/resolv.conf and seeing this text, you have followed the symlink. # # This is a dynamic resolv.conf file for connecting local clients to the # internal DNS stub resolver of systemd-resolved. This file lists all # configured search domains. # # Run "resolvectl status" to see details about the uplink DNS servers # currently in use. # # Third party programs should typically not access this file directly, but only # through the symlink at /etc/resolv.conf. To manage man:resolv.conf(5) in a # different way, replace this symlink by a static file or a different symlink. # # See man:systemd-resolved.service(8) for details about the supported modes of # operation for /etc/resolv.conf. nameserver 127.0.0.53 options edns0 trust-ad search fritz.box [2024-02-22 13:33:21+0100] [omvinstall] Debian :: bookworm [2024-02-22 13:33:21+0100] [omvinstall] sandworm :: 7 [2024-02-22 13:33:21+0100] [omvinstall] Hostname :: helios64 [2024-02-22 13:33:21+0100] [omvinstall] Domain name :: [2024-02-22 13:33:21+0100] [omvinstall] timezone :: Europe/Berlin [2024-02-22 13:33:21+0100] [omvinstall] Removing Armbian netplan file... removed '/etc/netplan/armbian-default.yaml' dpkg: warning: ignoring request to remove udisks2 which isn't installed [2024-02-22 13:33:22+0100] [omvinstall] Install prerequisites... Reading package lists... Building dependency tree... Reading state information... gnupg is already the newest version (2.2.40-1.1). wget is already the newest version (1.21.3-1+b1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up openmediavault (7.0-32) ... Creating users/groups ... Updating local package archive ... Updating service units ... sshd.service is a disabled or a static unit, not starting it. Failed to preset unit, unit /etc/systemd/system/systemd-networkd.service is masked. /usr/bin/deb-systemd-helper: error: systemctl preset failed on systemd-networkd.service: No such file or directory dpkg: error processing package openmediavault (--configure): installed openmediavault package post-installation script subprocess returned error exit status 1 Errors were encountered while processing: openmediavault E: Sub-process /usr/bin/dpkg returned an error code (1) Removed "/etc/systemd/system/systemd-networkd.service". [2024-02-22 13:33:42+0100] [omvinstall] Installing openmediavault required packages... Reading package lists... Building dependency tree... Reading state information... postfix is already the newest version (3.7.10-0+deb12u1). postfix set to manually installed. 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 1 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up openmediavault (7.0-32) ... Creating users/groups ... Updating local package archive ... Updating service units ... sshd.service is a disabled or a static unit, not starting it. Created symlink /etc/systemd/system/dbus-org.freedesktop.network1.service → /lib/systemd/system/systemd-networkd.service. Created symlink /etc/systemd/system/multi-user.target.wants/systemd-networkd.service → /lib/systemd/system/systemd-networkd.service. Created symlink /etc/systemd/system/sockets.target.wants/systemd-networkd.socket → /lib/systemd/system/systemd-networkd.socket. Created symlink /etc/systemd/system/sysinit.target.wants/systemd-network-generator.service → /lib/systemd/system/systemd-network-generator.service. Created symlink /etc/systemd/system/network-online.target.wants/systemd-networkd-wait-online.service → /lib/systemd/system/systemd-networkd-wait-online.service. systemd-journald.service is a disabled or a static unit, not starting it. Generating public/private rsa key pair. Your identification has been saved in /root/.ssh/id_rsa Your public key has been saved in /root/.ssh/id_rsa.pub The key fingerprint is: SHA256:tc+B1N/Qz4ayCcgLfXy/2d8SDC0gEIXzLW3kcIrvzd8 root@helios64 The key's randomart image is: +---[RSA 3072]----+ | o=. | | o o +. . | | + Xo.... .| | .o+==oo..=.| | ..So* ++o =| | ..o = *o. | | ..o = .. | | . o ..+.| | .. E.=| +----[SHA256]-----+ Failed to stop ntp.service: Unit ntp.service not loaded. Unit ntp.service does not exist, proceeding anyway. Created symlink /etc/systemd/system/ntp.service → /dev/null. Failed to stop systemd-timesyncd.service: Unit systemd-timesyncd.service not loaded. Unit systemd-timesyncd.service does not exist, proceeding anyway. Created symlink /etc/systemd/system/systemd-timesyncd.service → /dev/null. Created symlink /etc/systemd/system/nfs-blkmap.service → /dev/null. Created symlink /etc/systemd/system/multi-user.target.wants/smartctl-hdparm.service → /etc/systemd/system/smartctl-hdparm.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-beep-up.service → /lib/systemd/system/openmediavault-beep-up.service. Created symlink /etc/systemd/system/reboot.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/halt.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/poweroff.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-cleanup-monit.service → /lib/systemd/system/openmediavault-cleanup-monit.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-cleanup-php.service → /lib/systemd/system/openmediavault-cleanup-php.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-engined.service → /lib/systemd/system/openmediavault-engined.service. Created symlink /etc/systemd/system/getty.target.wants/openmediavault-issue.service → /lib/systemd/system/openmediavault-issue.service. Creating configuration database ... Setting up Salt environment ... /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() Setting up system ... /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/utils/pycrypto.py:26: DeprecationWarning: 'crypt' is deprecated and slated for removal in Python 3.13 import crypt /usr/lib/python3/dist-packages/salt/modules/linux_shadow.py:21: DeprecationWarning: 'spwd' is deprecated and slated for removal in Python 3.13 import spwd Deploying service configurations ... free(): invalid pointer Aborted Processing system modifications ... Processing triggers for openmediavault (7.0-32) ... Restarting engine daemon ... Monit: the monit HTTP interface is not enabled, please add the 'set httpd' statement and use the 'allow' option to allow monit to connect Updating workbench configuration files ... Processing triggers for initramfs-tools (0.142) ... update-initramfs: Generating /boot/initrd.img-6.6.8-edge-rockchip64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.8-edge-rockchip64 Image Name: uInitrd Created: Thu Feb 22 13:36:25 2024 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 29399711 Bytes = 28710.66 KiB = 28.04 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.8-edge-rockchip64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.8-edge-rockchip64' update-initramfs: Armbian: done. [2024-02-22 13:36:34+0100] [omvinstall] Adding openmediavault repo and key... deb [signed-by=/usr/share/keyrings/openmediavault-archive-keyring.gpg] http://packages.openmediavault.org/public sandworm main [2024-02-22 13:36:34+0100] [omvinstall] Updating repos... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Hit:6 http://deb.debian.org/debian bookworm InRelease Hit:7 http://deb.debian.org/debian bookworm-updates InRelease Hit:8 http://deb.debian.org/debian bookworm-backports InRelease Hit:9 http://security.debian.org bookworm-security InRelease Hit:10 http://packages.openmediavault.org/public sandworm InRelease Reading package lists... [2024-02-22 13:36:45+0100] [omvinstall] Install openmediavault-keyring... Reading package lists... Building dependency tree... Reading state information... openmediavault-keyring is already the newest version (1.0.2-2). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [2024-02-22 13:36:47+0100] [omvinstall] Installing openmediavault... Reading package lists... Building dependency tree... Reading state information... openmediavault is already the newest version (7.0-32). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() helios64: ---------- ID: configure_hosts_header Function: file.managed Name: /etc/hosts Result: True Comment: File /etc/hosts updated Started: 13:37:06.585729 Duration: 172.87 ms Changes: ---------- diff: --- +++ @@ -1,7 +1,2 @@ -127.0.0.1 localhost -127.0.1.1 helios64 -::1 localhost helios64 ip6-localhost ip6-loopback -fe00::0 ip6-localnet -ff00::0 ip6-mcastprefix -ff02::1 ip6-allnodes -ff02::2 ip6-allrouters +# This file is auto-generated by openmediavault (https://www.openmediavault.org) +# WARNING: Do not edit this file, your changes will get lost. ---------- ID: configure_hosts_localhost_ipv4 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 13:37:06.758960 Duration: 4.886 ms Changes: ---------- diff: --- +++ @@ -1,2 +1,3 @@ # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. +127.0.0.1 localhost.localdomain localhost ---------- ID: configure_hosts_localhost_fqdn_ipv4 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 13:37:06.764182 Duration: 4.653 ms Changes: ---------- diff: --- +++ @@ -1,3 +1,4 @@ # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. 127.0.0.1 localhost.localdomain localhost +127.0.1.1 helios64 ---------- ID: configure_hosts_comment_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 13:37:06.769172 Duration: 6.799 ms Changes: ---------- diff: --- +++ @@ -2,3 +2,4 @@ # WARNING: Do not edit this file, your changes will get lost. 127.0.0.1 localhost.localdomain localhost 127.0.1.1 helios64 +# The following lines are desirable for IPv6 capable hosts. ---------- ID: configure_hosts_localhost_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 13:37:06.776423 Duration: 4.767 ms Changes: ---------- diff: --- +++ @@ -3,3 +3,4 @@ 127.0.0.1 localhost.localdomain localhost 127.0.1.1 helios64 # The following lines are desirable for IPv6 capable hosts. +::1 localhost ip6-localhost ip6-loopback helios64 ---------- ID: configure_hosts_various_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 5 lines Started: 13:37:06.781519 Duration: 5.755 ms Changes: ---------- diff: --- +++ @@ -4,3 +4,8 @@ 127.0.1.1 helios64 # The following lines are desirable for IPv6 capable hosts. ::1 localhost ip6-localhost ip6-loopback helios64 +fe00::0 ip6-localnet +ff00::0 ip6-mcastprefix +ff02::1 ip6-allnodes +ff02::2 ip6-allrouters +ff02::3 ip6-allhosts Summary for helios64 ------------ Succeeded: 6 (changed=6) Failed: 0 ------------ Total states run: 6 Total run time: 199.730 ms [2024-02-22 13:37:07+0100] [omvinstall] Testing DNS... [2024-02-22 13:37:07+0100] [omvinstall] DNS failing to resolve. Fixing ... [2024-02-22 13:37:07+0100] [omvinstall] Reverting /etc/resolv.conf to saved copy ... removed '/etc/resolv.conf' '/root/resolv.conf' -> '/etc/resolv.conf' [2024-02-22 13:37:07+0100] [omvinstall] Downloading omv-extras.org plugin for openmediavault 7.x ... --2024-02-22 13:37:07-- https://github.com/OpenMediaVault-Plugin-Developers/packages/raw/master/openmediavault-omvextrasorg_latest_all7.deb Resolving github.com (github.com)... 140.82.121.4 Connecting to github.com (github.com)|140.82.121.4|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://raw.githubusercontent.com/OpenMediaVault-Plugin-Developers/packages/master/openmediavault-omvextrasorg_latest_all7.deb [following] --2024-02-22 13:37:07-- https://raw.githubusercontent.com/OpenMediaVault-Plugin-Developers/packages/master/openmediavault-omvextrasorg_latest_all7.deb Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 2606:50c0:8002::154, 2606:50c0:8003::154, 2606:50c0:8001::154, ... Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|2606:50c0:8002::154|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 40672 (40K) [application/octet-stream] Saving to: ‘openmediavault-omvextrasorg_latest_all7.deb’ openmediavault-omvextrasorg_latest_all7.deb 100%[==========================================================================================>] 39.72K --.-KB/s in 0.004s 2024-02-22 13:37:07 (8.72 MB/s) - ‘openmediavault-omvextrasorg_latest_all7.deb’ saved [40672/40672] Selecting previously unselected package openmediavault-omvextrasorg. (Reading database ... 84545 files and directories currently installed.) Preparing to unpack openmediavault-omvextrasorg_latest_all7.deb ... Unpacking openmediavault-omvextrasorg (7.0) ... Setting up openmediavault-omvextrasorg (7.0) ... Updating configuration database ... 1. Cleaning apt cache files... 2. Clearing available dpkg packages... dpkg: error: dpkg frontend lock was locked by another process with pid 9892 Note: removing the lock file is always wrong, can damage the locked area and the entire system. See <https://wiki.debian.org/Teams/Dpkg/FAQ#db-lock>. 3. Removing apt lists... removed '/var/lib/apt/lists/_var_cache_openmediavault_archives_Packages' removed directory '/var/lib/apt/lists/auxfiles' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/lock' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_InRelease' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_main_binary-arm64_Packages' removed directory '/var/lib/apt/lists/partial' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_InRelease' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_main_binary-arm64_Packages' 4. Removing OpenMediaVault cache packages... removed '/var/cache/openmediavault/archives/Packages' 5. Creating new OpenMediaVault packages file... 6. Remove old omv-extras apt list files... 7. Adding omv-extras repo and key... 8. Updating apt... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Get:6 http://deb.debian.org/debian bookworm InRelease [151 kB] Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:7 http://packages.openmediavault.org/public sandworm InRelease [12.8 kB] Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:8 http://security.debian.org bookworm-security InRelease [48.0 kB] Get:9 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:10 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:11 http://packages.openmediavault.org/public sandworm/main arm64 Packages [7669 B] Get:12 http://deb.debian.org/debian bookworm/main arm64 Packages [11.9 MB] Get:13 http://deb.debian.org/debian bookworm/main arm64 Contents (deb) [11.2 MB] Get:14 http://security.debian.org bookworm-security/main arm64 Packages [137 kB] Get:15 http://deb.debian.org/debian bookworm/main all Contents (deb) [33.0 MB] Get:16 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease [3936 B] Get:17 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 Packages [8546 B] Get:18 http://deb.debian.org/debian bookworm/contrib arm64 Packages [54.7 kB] Get:19 http://deb.debian.org/debian bookworm/contrib arm64 Contents (deb) [37.7 kB] Get:20 http://deb.debian.org/debian bookworm/contrib all Contents (deb) [98.6 kB] Get:21 http://deb.debian.org/debian bookworm/non-free arm64 Packages [94.4 kB] Get:22 http://deb.debian.org/debian bookworm/non-free arm64 Contents (deb) [43.4 kB] Get:23 http://deb.debian.org/debian bookworm/non-free all Contents (deb) [839 kB] Get:24 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [6401 B] Get:25 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Contents (deb) [243 B] Get:26 http://deb.debian.org/debian bookworm/non-free-firmware all Contents (deb) [16.9 kB] Get:27 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [12.5 kB] Get:28 http://deb.debian.org/debian bookworm-updates/main all Contents (deb) [222 kB] Get:29 http://deb.debian.org/debian bookworm-updates/main arm64 Contents (deb) [253 kB] Get:30 http://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B] Get:31 http://deb.debian.org/debian bookworm-updates/contrib arm64 Contents (deb) [222 B] Get:32 http://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB] Get:33 http://deb.debian.org/debian bookworm-updates/non-free arm64 Contents (deb) [14.9 kB] Get:34 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Packages [616 B] Get:35 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Contents (deb) [243 B] Get:36 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [172 kB] Get:37 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) [524 kB] Get:38 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) [3584 kB] Get:39 http://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:40 http://deb.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:41 http://deb.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:42 http://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:43 http://deb.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Fetched 62.7 MB in 12s (5394 kB/s) free(): invalid pointer Aborted Reading package lists... Done 9. Saving current package list... 10. Updating plugin index... Creating index of upgradeable packages ... Creating index of plugins ... free(): invalid pointer /usr/sbin/omv-aptclean: line 118: 10456 Aborted /usr/sbin/omv-mkaptidx Processing triggers for openmediavault (7.0-32) ... Updating workbench configuration files ... Restarting engine daemon ... Monit: the monit HTTP interface is not enabled, please add the 'set httpd' statement and use the 'allow' option to allow monit to connect [2024-02-22 13:37:51+0100] [omvinstall] Updating repos ... 1. Cleaning apt cache files... 2. Clearing available dpkg packages... 3. Removing apt lists... removed '/var/lib/apt/lists/_var_cache_openmediavault_archives_Packages' removed directory '/var/lib/apt/lists/auxfiles' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/lock' removed '/var/lib/apt/lists/openmediavault-plugin-developers.github.io_packages_debian_dists_sandworm_InRelease' removed '/var/lib/apt/lists/openmediavault-plugin-developers.github.io_packages_debian_dists_sandworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_InRelease' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_main_binary-arm64_Packages' removed directory '/var/lib/apt/lists/partial' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_InRelease' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_main_binary-arm64_Packages' 4. Removing OpenMediaVault cache packages... removed '/var/cache/openmediavault/archives/Packages' 5. Creating new OpenMediaVault packages file... 6. Remove old omv-extras apt list files... removed '/etc/apt/sources.list.d/omvextras.list' 7. Adding omv-extras repo and key... 8. Updating apt... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:6 http://deb.debian.org/debian bookworm InRelease [151 kB] Get:7 http://security.debian.org bookworm-security InRelease [48.0 kB] Get:8 http://packages.openmediavault.org/public sandworm InRelease [12.8 kB] Get:9 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:10 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:11 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease [3936 B] Get:12 http://packages.openmediavault.org/public sandworm/main arm64 Packages [7669 B] Get:13 http://deb.debian.org/debian bookworm/main arm64 Packages [11.9 MB] Get:14 http://deb.debian.org/debian bookworm/main arm64 Contents (deb) [11.2 MB] Get:15 http://security.debian.org bookworm-security/main arm64 Packages [137 kB] Get:16 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 Packages [8546 B] Get:17 http://deb.debian.org/debian bookworm/main all Contents (deb) [33.0 MB] Get:18 http://deb.debian.org/debian bookworm/contrib arm64 Packages [54.7 kB] Get:19 http://deb.debian.org/debian bookworm/contrib all Contents (deb) [98.6 kB] Get:20 http://deb.debian.org/debian bookworm/contrib arm64 Contents (deb) [37.7 kB] Get:21 http://deb.debian.org/debian bookworm/non-free arm64 Packages [94.4 kB] Get:22 http://deb.debian.org/debian bookworm/non-free arm64 Contents (deb) [43.4 kB] Get:23 http://deb.debian.org/debian bookworm/non-free all Contents (deb) [839 kB] Get:24 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [6401 B] Get:25 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Contents (deb) [243 B] Get:26 http://deb.debian.org/debian bookworm/non-free-firmware all Contents (deb) [16.9 kB] Get:27 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [12.5 kB] Get:28 http://deb.debian.org/debian bookworm-updates/main arm64 Contents (deb) [253 kB] Get:29 http://deb.debian.org/debian bookworm-updates/main all Contents (deb) [222 kB] Get:30 http://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B] Get:31 http://deb.debian.org/debian bookworm-updates/contrib arm64 Contents (deb) [222 B] Get:32 http://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB] Get:33 http://deb.debian.org/debian bookworm-updates/non-free arm64 Contents (deb) [14.9 kB] Get:34 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Packages [616 B] Get:35 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Contents (deb) [243 B] Get:36 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [172 kB] Get:37 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) [3584 kB] Get:38 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) [524 kB] Get:39 http://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:40 http://deb.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:41 http://deb.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:42 http://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:43 http://deb.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Fetched 62.7 MB in 12s (5405 kB/s) Reading package lists... 9. Saving current package list... 10. Updating plugin index... Creating index of upgradeable packages ... Creating index of plugins ... free(): invalid pointer /usr/sbin/omv-aptclean: line 118: 11001 Aborted /usr/sbin/omv-mkaptidx armbian-ramlog.service loaded active exited Armbian memory supported logging ● armbian-ramlog.target not-found inactive dead armbian-ramlog.target Removed "/etc/systemd/system/sysinit.target.wants/armbian-ramlog.service". armbian-zram-config.service loaded active exited Armbian ZRAM config Removed "/etc/systemd/system/sysinit.target.wants/armbian-zram-config.service". [2024-02-22 13:38:36+0100] [omvinstall] Install folder2ram... Reading package lists... Building dependency tree... Reading state information... The following additional packages will be installed: gawk libsigsegv2 Suggested packages: gawk-doc The following NEW packages will be installed: folder2ram gawk libsigsegv2 0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded. Need to get 691 kB of archives. After this operation, 3837 kB of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1 [37.0 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640 kB] Get:3 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 folder2ram all 0.3.5 [14.0 kB] Segmentation fault Fetched 691 kB in 0s (4133 kB/s) E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1) E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10 [2024-02-22 13:38:39+0100] [omvinstall] Failed to install folder2ram. [2024-02-22 13:38:39+0100] [omvinstall] Install flashmemory plugin... Reading package lists... Building dependency tree... Reading state information... The following additional packages will be installed: folder2ram gawk libsigsegv2 Suggested packages: gawk-doc The following NEW packages will be installed: folder2ram gawk libsigsegv2 openmediavault-flashmemory 0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded. Need to get 5156 B/696 kB of archives. After this operation, 3874 kB of additional disk space will be used. Get:1 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 openmediavault-flashmemory all 7.0 [5156 B] free(): invalid size Aborted Fetched 5156 B in 0s (54.7 kB/s) E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1) E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10 [2024-02-22 13:38:41+0100] [omvinstall] Failed to install flashmemory plugin. ERROR: The state 'flashmemory' does not exist Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. [2024-02-22 13:38:44+0100] [omvinstall] Disabling data collection ... {"enable":false} null bash: line 491: warning: command substitution: ignored null byte in input helios64: ---------- ID: run_state_patch Function: salt.state Result: True Comment: States ran successfully. No changes made to helios64. Started: 13:40:03.747407 Duration: 480.248 ms Changes: ---------- ID: sync_runners Function: salt.runner Name: saltutil.sync_runners Result: True Comment: Runner function 'saltutil.sync_runners' executed. Started: 13:40:04.228009 Duration: 4295.848 ms Changes: ---------- return: ---------- ID: sync_modules Function: salt.runner Name: saltutil.sync_modules Result: True Comment: Runner function 'saltutil.sync_modules' executed. Started: 13:40:08.524208 Duration: 11346.957 ms Changes: ---------- return: ---------- ID: sync_states Function: salt.runner Name: saltutil.sync_states Result: True Comment: Runner function 'saltutil.sync_states' executed. Started: 13:40:19.871529 Duration: 4096.686 ms Changes: ---------- return: ---------- ID: populate_pillar Function: salt.runner Name: omv.populate_pillar Result: True Comment: Runner function 'omv.populate_pillar' executed. Started: 13:40:23.970157 Duration: 12043.436 ms Changes: ---------- return: True ---------- ID: run_state_sync Function: salt.state Result: True Comment: States ran successfully. Updating helios64. Started: 13:40:36.014068 Duration: 4530.697 ms Changes: helios64: ---------- ID: clear_cache Function: module.run Result: True Comment: saltutil.clear_cache: True Started: 13:40:36.736226 Duration: 35.232 ms Changes: ---------- saltutil.clear_cache: True ---------- ID: sync_grains Function: saltutil.sync_grains Result: True Comment: Updated grains. Started: 13:40:36.773569 Duration: 1424.323 ms Changes: ---------- grains: - grains.omv ---------- ID: sync_states Function: saltutil.sync_states Result: True Comment: Updated states. Started: 13:40:38.198172 Duration: 1116.433 ms Changes: ---------- states: - states.omv_dpkg ---------- ID: sync_modules Function: saltutil.sync_modules Result: True Comment: Updated modules. Started: 13:40:39.315184 Duration: 1227.788 ms Changes: ---------- modules: - modules.omv_conf - modules.omv_utils Summary for helios64 ------------ Succeeded: 4 (changed=4) Failed: 0 ------------ Total states run: 4 Total run time: 3.804 s Summary for helios64 ------------ Succeeded: 6 (changed=5) Failed: 0 ------------ Total states run: 6 Total run time: 36.794 s ERROR: The state 'flashmemory' does not exist [2024-02-22 13:40:42+0100] [omvinstall] Add a cron job to make NAS processes more snappy and silence rsyslog [2024-02-22 13:40:42+0100] [omvinstall] Removing network-manager and dhcpcd5 ... Reading package lists... Building dependency tree... Reading state information... Package 'dhcpcd5' is not installed, so not removed The following packages will be REMOVED: libbluetooth3* libmm-glib0* libndp0* libnm0* libteamdctl0* network-manager* network-manager-openvpn* Segmentation fault 0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded. After this operation, 21.0 MB disk space will be freed. E: Sub-process /usr/bin/apt-listchanges --apt || test $? -lt 10 returned an error code (1) E: Failure running script /usr/bin/apt-listchanges --apt || test $? -lt 10 [2024-02-22 13:40:44+0100] [omvinstall] Enable and start systemd-resolved ... [2024-02-22 13:40:45+0100] [omvinstall] Unblocking wifi with rfkill ... [2024-02-22 13:40:45+0100] [omvinstall] Adding end0 to openmedivault database ... [2024-02-22 13:40:46+0100] [omvinstall] Adding enx646266d00975 to openmedivault database ... [2024-02-22 13:40:47+0100] [omvinstall] IP address may change and you could lose connection if running this script via ssh. client_loop: send disconnect: Broken pipe Edited February 28 by TDCroPower 0 Quote
TDCroPower Posted February 28 Author Posted February 28 (edited) Solved in this thread... Here the installation success output... Spoiler root@helios64:~# curl -sSL https://github.com/OpenMediaVault-Plugin-Developers/installScript/raw/master/install | sudo bash [2024-02-28 11:13:00+0100] [omvinstall] script version :: 2.3.9 [2024-02-28 11:13:00+0100] [omvinstall] Armbian [2024-02-28 11:13:00+0100] [omvinstall] Starting ... [2024-02-28 11:13:00+0100] [omvinstall] Current / permissions = 755 mode of '/' retained as 0755 (rwxr-xr-x) [2024-02-28 11:13:00+0100] [omvinstall] New / permissions = 755 [2024-02-28 11:13:00+0100] [omvinstall] Forcing IPv4 only for apt... [2024-02-28 11:13:00+0100] [omvinstall] Updating repos before installing... Hit:1 http://security.debian.org bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 http://deb.debian.org/debian bookworm-backports InRelease Reading package lists... [2024-02-28 11:13:05+0100] [omvinstall] Installing lsb_release... Reading package lists... Building dependency tree... Reading state information... 0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded. Need to get 6416 B of archives. After this operation, 0 B of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 lsb-release all 12.0-1 [6416 B] Fetched 6416 B in 0s (144 kB/s) (Reading database ... 76636 files and directories currently installed.) Preparing to unpack .../lsb-release_12.0-1_all.deb ... Unpacking lsb-release (12.0-1) over (12.0-1) ... Setting up lsb-release (12.0-1) ... Processing triggers for man-db (2.11.2-2) ... [2024-02-28 11:13:14+0100] [omvinstall] Arch :: arm64 [2024-02-28 11:13:14+0100] [omvinstall] Supported architecture [2024-02-28 11:13:14+0100] [omvinstall] Codename :: bookworm [2024-02-28 11:13:14+0100] [omvinstall] Copying /etc/resolv.conf to /root/resolv.conf ... '/etc/resolv.conf' -> '/root/resolv.conf' [2024-02-28 11:13:14+0100] [omvinstall] # Generated by NetworkManager search fritz.box nameserver 192.168.180.1 nameserver fd00::6b4:feff:fe96:b8b7 nameserver 2001:16b8:b59a:5800:6b4:feff:fe96:b8b7 [2024-02-28 11:13:14+0100] [omvinstall] Debian :: bookworm [2024-02-28 11:13:14+0100] [omvinstall] sandworm :: 7 [2024-02-28 11:13:14+0100] [omvinstall] Hostname :: helios64 [2024-02-28 11:13:14+0100] [omvinstall] Domain name :: [2024-02-28 11:13:14+0100] [omvinstall] timezone :: Europe/Berlin [2024-02-28 11:13:14+0100] [omvinstall] Removing Armbian netplan file... removed '/etc/netplan/armbian-default.yaml' dpkg: warning: ignoring request to remove udisks2 which isn't installed [2024-02-28 11:13:14+0100] [omvinstall] Install prerequisites... Reading package lists... Building dependency tree... Reading state information... gnupg is already the newest version (2.2.40-1.1). wget is already the newest version (1.21.3-1+b1). 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Removed "/etc/systemd/system/systemd-networkd.service". [2024-02-28 11:13:18+0100] [omvinstall] Installing openmediavault required packages... Reading package lists... Building dependency tree... Reading state information... The following additional packages will be installed: ssl-cert Suggested packages: procmail postfix-mysql postfix-pgsql postfix-ldap postfix-pcre postfix-lmdb postfix-sqlite sasl2-bin | dovecot-common libsasl2-modules | dovecot-common resolvconf postfix-cdb mail-reader postfix-mta-sts-resolver ufw postfix-doc The following NEW packages will be installed: postfix ssl-cert 0 upgraded, 2 newly installed, 0 to remove and 0 not upgraded. Need to get 1472 kB of archives. After this operation, 6094 kB of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 ssl-cert all 1.1.2 [21.1 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 postfix arm64 3.7.10-0+deb12u1 [1451 kB] Preconfiguring packages ... Fetched 1472 kB in 0s (8010 kB/s) Selecting previously unselected package ssl-cert. (Reading database ... 76636 files and directories currently installed.) Preparing to unpack .../ssl-cert_1.1.2_all.deb ... Unpacking ssl-cert (1.1.2) ... Selecting previously unselected package postfix. Preparing to unpack .../postfix_3.7.10-0+deb12u1_arm64.deb ... Unpacking postfix (3.7.10-0+deb12u1) ... Setting up ssl-cert (1.1.2) ... Setting up postfix (3.7.10-0+deb12u1) ... Adding group `postfix' (GID 116) ... Done. Adding system user `postfix' (UID 109) ... Adding new user `postfix' (UID 109) with group `postfix' ... Not creating home directory `/var/spool/postfix'. Creating /etc/postfix/dynamicmaps.cf Adding group `postdrop' (GID 117) ... Done. setting myhostname: helios64.fritz.box setting alias maps setting alias database mailname is not a fully qualified domain name. Not changing /etc/mailname. setting destinations: $myhostname, helios64, localhost.localdomain, , localhost setting relayhost: setting mynetworks: 127.0.0.0/8 [::ffff:127.0.0.0]/104 [::1]/128 setting mailbox_size_limit: 0 setting recipient_delimiter: + setting inet_interfaces: all setting inet_protocols: all /etc/aliases does not exist, creating it. WARNING: /etc/aliases exists, but does not have a root alias. Postfix (main.cf) is now set up with a default configuration. If you need to make changes, edit /etc/postfix/main.cf (and others) as needed. To view Postfix configuration values, see postconf(1). After modifying main.cf, be sure to run 'systemctl reload postfix'. Running newaliases Created symlink /etc/systemd/system/multi-user.target.wants/postfix.service → /lib/systemd/system/postfix.service. Processing triggers for man-db (2.11.2-2) ... Processing triggers for rsyslog (8.2302.0-1) ... [2024-02-28 11:13:44+0100] [omvinstall] Adding openmediavault repo and key... deb [signed-by=/usr/share/keyrings/openmediavault-archive-keyring.gpg] http://packages.openmediavault.org/public sandworm main [2024-02-28 11:13:44+0100] [omvinstall] Updating repos... Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://deb.debian.org/debian bookworm-updates InRelease Hit:3 http://deb.debian.org/debian bookworm-backports InRelease Hit:4 http://security.debian.org bookworm-security InRelease Get:5 http://packages.openmediavault.org/public sandworm InRelease [12.8 kB] Get:6 http://packages.openmediavault.org/public sandworm/main arm64 Packages [7669 B] Fetched 20.4 kB in 2s (8499 B/s) Reading package lists... [2024-02-28 11:13:49+0100] [omvinstall] Install openmediavault-keyring... Reading package lists... Building dependency tree... Reading state information... The following NEW packages will be installed: openmediavault-keyring 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 6036 B of archives. After this operation, 25.6 kB of additional disk space will be used. Get:1 http://packages.openmediavault.org/public sandworm/main arm64 openmediavault-keyring all 1.0.2-2 [6036 B] Fetched 6036 B in 0s (132 kB/s) Selecting previously unselected package openmediavault-keyring. (Reading database ... 76843 files and directories currently installed.) Preparing to unpack .../openmediavault-keyring_1.0.2-2_all.deb ... Unpacking openmediavault-keyring (1.0.2-2) ... Setting up openmediavault-keyring (1.0.2-2) ... Reading package lists... Building dependency tree... Reading state information... Suggested packages: sysvinit-core The following NEW packages will be installed: monit 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 337 kB of archives. After this operation, 1105 kB of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 monit arm64 1:5.33.0-1 [337 kB] Fetched 337 kB in 0s (4228 kB/s) Selecting previously unselected package monit. (Reading database ... 76850 files and directories currently installed.) Preparing to unpack .../monit_1%3a5.33.0-1_arm64.deb ... Unpacking monit (1:5.33.0-1) ... Setting up monit (1:5.33.0-1) ... Processing triggers for man-db (2.11.2-2) ... [2024-02-28 11:14:07+0100] [omvinstall] Installing openmediavault... Reading package lists... Building dependency tree... Reading state information... The following additional packages will be installed: acl anacron apt-listchanges apticron avahi-daemon beep bsd-mailx bsdmainutils collectd collectd-core dctrl-tools dmeventd gdisk jfsutils libaio1 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-core7 libcups2 libdbi1 libdevmapper-event1.02.1 libinih1 libjs-jquery libjs-sphinxdoc libjs-underscore libldb2 liblmdb0 liblockfile-bin liblockfile1 liblvm2cmd2.03 libncurses6 libnorm1 libnss-mdns libnss-resolve libnss-systemd libossp-uuid16 libpgm-5.3-0 libpython3.11 librrd8 libsasl2-modules libtalloc2 libtdb1 libtevent0 liburcu8 liburing2 libwbclient0 libxslt1.1 libzmq5 lvm2 ncal nfs-kernel-server nginx nginx-common php-bcmath php-cgi php-common php-fpm php-mbstring php-pam php-xml php-yaml php8.2-bcmath php8.2-cgi php8.2-cli php8.2-common php8.2-fpm php8.2-mbstring php8.2-opcache php8.2-readline php8.2-xml php8.2-yaml python3-cached-property python3-certifi python3-chardet python3-charset-normalizer python3-click python3-colorama python3-dateutil python3-debconf python3-dialog python3-dnspython python3-gnupg python3-idna python3-jinja2 python3-jmespath python3-ldb python3-looseversion python3-lxml python3-markupsafe python3-msgpack python3-natsort python3-packaging python3-polib python3-psutil python3-py python3-pycryptodome python3-pyudev python3-requests python3-samba python3-systemd python3-talloc python3-tdb python3-urllib3 python3-zmq quota quotatool rrdcached rrdtool salt-common salt-minion samba samba-common samba-common-bin samba-libs samba-vfs-modules sdparm sshpass systemd-resolved tdb-tools uuid whiptail wsdd xfsprogs xmlstarlet zstd Suggested packages: powermgmt-base x-terminal-emulator calendar whois vacation mailutils collectd-dev librrds-perl liburi-perl libhtml-parser-perl libregexp-common-perl libconfig-general-perl apache2 apcupsd bind9 ceph default-mysql-server gpsd ipvsadm mbmon memcached notification-daemon nut olsrd pdns-server postgresql redis-server slapd varnish zookeeper libabsl20220623 libatasmart4 libbson-1.0-0 libesmtp6 libgps28 libgrpc++1.51 libgrpc29 libhiredis0.14 liblua5.3-0 libmariadb3 libmemcached11 libmicrohttpd12 libmodbus5 libmongoc-1.0-0 libmosquitto1 libnotify4 libopenipmi0 liboping0 libpcap0.8 libpq5 libprotobuf-c1 libprotobuf32 libqpid-proton11 librabbitmq4 librdkafka1 libriemann-client0 libsnmp40 libupsclient6 libvarnishapi3 libvirt0 libxenmisc4.17 libyajl2 default-jre-headless debtags cups-common libsasl2-modules-gssapi-mit | libsasl2-modules-gssapi-heimdal libsasl2-modules-ldap libsasl2-modules-otp libsasl2-modules-sql fcgiwrap nginx-doc php-pear python3-doc python3-sniffio python3-trio python3-aioquic python-jinja2-doc python-lxml-doc python-natsort-doc python-polib-doc python-psutil-doc subversion python3-pytest python3-wxgtk4.0 python3-pyqt5 python3-openssl python3-socks python-requests-doc python3-brotli libnet-ldap-perl python3-pycurl python3-twisted python3-augeas bind9utils ctdb ldb-tools ufw winbind heimdal-clients python3-markdown xfsdump attr Recommended packages: libabsl20220623 libatasmart4 libbson-1.0-0 libesmtp6 libgps28 libgrpc++1.51 libgrpc29 libhiredis0.14 liblua5.3-0 libmariadb3 libmemcached11 libmicrohttpd12 libmodbus5 libmongoc-1.0-0 libmosquitto1 libnotify4 libopenipmi0 liboping0 libpcap0.8 libpq5 libprotobuf-c1 libprotobuf32 libqpid-proton11 librabbitmq4 librdkafka1 libriemann-client0 libsnmp40 libupsclient6 libvarnishapi3 libvirt0 libxenmisc4.17 libyajl2 default-jre-headless javascript-common thin-provisioning-tools python3-h2 python3-httpx python3-requests-toolbelt python3-babel python3-bs4 python3-html5lib python3-gpg python3-contextvars python3-croniter net-tools attr python3-markdown samba-dsdb-modules samba-ad-provision libcephfs2 libgfapi0 The following NEW packages will be installed: acl anacron apt-listchanges apticron avahi-daemon beep bsd-mailx bsdmainutils collectd collectd-core dctrl-tools dmeventd gdisk jfsutils libaio1 libavahi-client3 libavahi-common-data libavahi-common3 libavahi-core7 libcups2 libdbi1 libdevmapper-event1.02.1 libinih1 libjs-jquery libjs-sphinxdoc libjs-underscore libldb2 liblmdb0 liblockfile-bin liblockfile1 liblvm2cmd2.03 libncurses6 libnorm1 libnss-mdns libnss-resolve libnss-systemd libossp-uuid16 libpgm-5.3-0 libpython3.11 librrd8 libsasl2-modules libtalloc2 libtdb1 libtevent0 liburcu8 liburing2 libwbclient0 libxslt1.1 libzmq5 lvm2 ncal nfs-kernel-server nginx nginx-common openmediavault php-bcmath php-cgi php-common php-fpm php-mbstring php-pam php-xml php-yaml php8.2-bcmath php8.2-cgi php8.2-cli php8.2-common php8.2-fpm php8.2-mbstring php8.2-opcache php8.2-readline php8.2-xml php8.2-yaml python3-cached-property python3-certifi python3-chardet python3-charset-normalizer python3-click python3-colorama python3-dateutil python3-debconf python3-dialog python3-dnspython python3-gnupg python3-idna python3-jinja2 python3-jmespath python3-ldb python3-looseversion python3-lxml python3-markupsafe python3-msgpack python3-natsort python3-packaging python3-polib python3-psutil python3-py python3-pycryptodome python3-pyudev python3-requests python3-samba python3-systemd python3-talloc python3-tdb python3-urllib3 python3-zmq quota quotatool rrdcached rrdtool salt-common salt-minion samba samba-common samba-common-bin samba-libs samba-vfs-modules sdparm sshpass systemd-resolved tdb-tools uuid whiptail wsdd xfsprogs xmlstarlet zstd 0 upgraded, 127 newly installed, 0 to remove and 0 not upgraded. Need to get 45.8 MB of archives. After this operation, 234 MB of additional disk space will be used. Get:1 http://packages.openmediavault.org/public sandworm/main arm64 php-pam arm64 2.2.4-1+deb12u1 [8308 B] Get:2 http://deb.debian.org/debian bookworm/main arm64 liblockfile-bin arm64 1.17-1+b1 [20.4 kB] Get:3 http://packages.openmediavault.org/public sandworm/main arm64 python3-looseversion all 1.0.2-2 [6900 B] Get:4 http://packages.openmediavault.org/public sandworm/main arm64 salt-common all 3006.0+ds-1+197.1 [7509 kB] Get:5 http://deb.debian.org/debian bookworm/main arm64 liblockfile1 arm64 1.17-1+b1 [16.8 kB] Get:6 http://deb.debian.org/debian bookworm/main arm64 bsd-mailx arm64 8.1.2-0.20220412cvs-1 [89.0 kB] Get:7 http://deb.debian.org/debian bookworm/main arm64 apticron all 1.2.5+nmu1 [11.5 kB] Get:8 http://deb.debian.org/debian bookworm/main arm64 php-common all 2:93 [13.1 kB] Get:9 http://deb.debian.org/debian bookworm/main arm64 php8.2-common arm64 8.2.7-1~deb12u1 [642 kB] Get:10 http://deb.debian.org/debian bookworm/main arm64 php8.2-opcache arm64 8.2.7-1~deb12u1 [492 kB] Get:11 http://deb.debian.org/debian bookworm/main arm64 php8.2-readline arm64 8.2.7-1~deb12u1 [11.9 kB] Get:12 http://deb.debian.org/debian bookworm/main arm64 php8.2-cli arm64 8.2.7-1~deb12u1 [1562 kB] Get:13 http://deb.debian.org/debian bookworm/main arm64 php8.2-fpm arm64 8.2.7-1~deb12u1 [1573 kB] Get:14 http://deb.debian.org/debian bookworm/main arm64 php8.2-cgi arm64 8.2.7-1~deb12u1 [1521 kB] Get:15 http://packages.openmediavault.org/public sandworm/main arm64 salt-minion all 3006.0+ds-1+197.1 [126 kB] Get:16 http://deb.debian.org/debian bookworm/main arm64 php8.2-yaml arm64 2.2.2+2.1.0+2.0.4+1.3.2-6 [19.4 kB] Get:17 http://packages.openmediavault.org/public sandworm/main arm64 openmediavault all 7.0-32 [3009 kB] Get:18 http://deb.debian.org/debian bookworm/main arm64 php-yaml arm64 2.2.2+2.1.0+2.0.4+1.3.2-6 [3096 B] Get:19 http://deb.debian.org/debian bookworm/main arm64 quota arm64 4.06-1+b2 [246 kB] Get:20 http://deb.debian.org/debian bookworm/main arm64 libdbi1 arm64 0.9.0-6 [27.8 kB] Get:21 http://deb.debian.org/debian bookworm/main arm64 librrd8 arm64 1.7.2-4+b8 [228 kB] Get:22 http://deb.debian.org/debian bookworm/main arm64 rrdcached arm64 1.7.2-4+b8 [153 kB] Get:23 http://deb.debian.org/debian bookworm/main arm64 python3-dnspython all 2.3.0-1 [152 kB] Get:24 http://deb.debian.org/debian bookworm/main arm64 liblmdb0 arm64 0.9.24-1 [43.7 kB] Get:25 http://deb.debian.org/debian bookworm/main arm64 libtalloc2 arm64 2.4.0-f2 [24.3 kB] Get:26 http://deb.debian.org/debian bookworm/main arm64 libtdb1 arm64 1.4.8-2 [43.6 kB] Get:27 http://deb.debian.org/debian bookworm/main arm64 libtevent0 arm64 0.14.1-1 [35.6 kB] Get:28 http://deb.debian.org/debian bookworm/main arm64 libldb2 arm64 2:2.6.2+samba4.17.12+dfsg-0+deb12u1 [154 kB] Get:29 http://deb.debian.org/debian bookworm/main arm64 libpython3.11 arm64 3.11.2-6 [1841 kB] Get:30 http://deb.debian.org/debian bookworm/main arm64 python3-ldb arm64 2:2.6.2+samba4.17.12+dfsg-0+deb12u1 [60.0 kB] Get:31 http://deb.debian.org/debian bookworm/main arm64 python3-tdb arm64 1.4.8-2 [16.2 kB] Get:32 http://deb.debian.org/debian bookworm/main arm64 libavahi-common-data arm64 0.8-10 [107 kB] Get:33 http://deb.debian.org/debian bookworm/main arm64 libavahi-common3 arm64 0.8-10 [40.6 kB] Get:34 http://deb.debian.org/debian bookworm/main arm64 libavahi-client3 arm64 0.8-10 [43.8 kB] Get:35 http://deb.debian.org/debian bookworm/main arm64 libwbclient0 arm64 2:4.17.12+dfsg-0+deb12u1 [52.8 kB] Get:36 http://deb.debian.org/debian bookworm/main arm64 samba-libs arm64 2:4.17.12+dfsg-0+deb12u1 [5265 kB] Get:37 http://deb.debian.org/debian bookworm/main arm64 python3-talloc arm64 2.4.0-f2 [14.6 kB] Get:38 http://deb.debian.org/debian bookworm/main arm64 python3-samba arm64 2:4.17.12+dfsg-0+deb12u1 [2625 kB] Get:39 http://deb.debian.org/debian bookworm/main arm64 samba-common all 2:4.17.12+dfsg-0+deb12u1 [87.9 kB] Get:40 http://deb.debian.org/debian bookworm/main arm64 libcups2 arm64 2.4.2-3+deb12u5 [229 kB] Get:41 http://deb.debian.org/debian bookworm/main arm64 libncurses6 arm64 6.4-4 [93.9 kB] Get:42 http://deb.debian.org/debian bookworm/main arm64 samba-common-bin arm64 2:4.17.12+dfsg-0+deb12u1 [1094 kB] Get:43 http://deb.debian.org/debian bookworm/main arm64 tdb-tools arm64 1.4.8-2 [26.6 kB] Get:44 http://deb.debian.org/debian bookworm/main arm64 samba arm64 2:4.17.12+dfsg-0+deb12u1 [888 kB] Get:45 http://deb.debian.org/debian bookworm/main arm64 whiptail arm64 0.52.23-1+b1 [23.8 kB] Get:46 http://deb.debian.org/debian bookworm/main arm64 python3-debconf all 1.5.82 [3980 B] Get:47 http://deb.debian.org/debian bookworm/main arm64 apt-listchanges all 3.24 [133 kB] Get:48 http://deb.debian.org/debian bookworm/main arm64 libnss-systemd arm64 252.22-1~deb12u1 [150 kB] Get:49 http://deb.debian.org/debian bookworm/main arm64 acl arm64 2.3.1-3 [60.1 kB] Get:50 http://deb.debian.org/debian bookworm/main arm64 anacron arm64 2.3-36 [26.3 kB] Get:51 http://deb.debian.org/debian bookworm/main arm64 libavahi-core7 arm64 0.8-10 [95.6 kB] Get:52 http://deb.debian.org/debian bookworm/main arm64 avahi-daemon arm64 0.8-10 [79.7 kB] Get:53 http://deb.debian.org/debian bookworm/main arm64 beep arm64 1.4.9-1 [31.9 kB] Get:54 http://deb.debian.org/debian bookworm/main arm64 ncal arm64 12.1.8 [19.2 kB] Get:55 http://deb.debian.org/debian bookworm/main arm64 bsdmainutils all 12.1.8 [5952 B] Get:56 http://deb.debian.org/debian bookworm/main arm64 collectd-core arm64 5.12.0-14 [1218 kB] Get:57 http://deb.debian.org/debian bookworm/main arm64 collectd arm64 5.12.0-14 [90.9 kB] Get:58 http://deb.debian.org/debian bookworm/main arm64 dctrl-tools arm64 2.24-3 [101 kB] Get:59 http://deb.debian.org/debian bookworm/main arm64 libdevmapper-event1.02.1 arm64 2:1.02.185-2 [12.2 kB] Get:60 http://deb.debian.org/debian bookworm/main arm64 libaio1 arm64 0.3.113-4 [13.3 kB] Get:61 http://deb.debian.org/debian bookworm/main arm64 liblvm2cmd2.03 arm64 2.03.16-2 [632 kB] Get:62 http://deb.debian.org/debian bookworm/main arm64 dmeventd arm64 2:1.02.185-2 [56.7 kB] Get:63 http://deb.debian.org/debian bookworm/main arm64 gdisk arm64 1.0.9-2.1 [209 kB] Get:64 http://deb.debian.org/debian bookworm/main arm64 jfsutils arm64 1.1.15-5 [196 kB] Get:65 http://deb.debian.org/debian bookworm/main arm64 libinih1 arm64 55-1 [6604 B] Get:66 http://deb.debian.org/debian bookworm/main arm64 libjs-jquery all 3.6.1+dfsg+~3.5.14-1 [326 kB] Get:67 http://deb.debian.org/debian bookworm/main arm64 libjs-underscore all 1.13.4~dfsg+~1.11.4-3 [116 kB] Get:68 http://deb.debian.org/debian bookworm/main arm64 libjs-sphinxdoc all 5.3.0-4 [130 kB] Get:69 http://deb.debian.org/debian bookworm/main arm64 libnorm1 arm64 1.5.9+dfsg-2 [202 kB] Get:70 http://deb.debian.org/debian bookworm/main arm64 libnss-mdns arm64 0.15.1-3 [21.3 kB] Get:71 http://deb.debian.org/debian bookworm/main arm64 systemd-resolved arm64 252.22-1~deb12u1 [279 kB] Get:72 http://deb.debian.org/debian bookworm/main arm64 libnss-resolve arm64 252.22-1~deb12u1 [92.5 kB] Get:73 http://deb.debian.org/debian bookworm/main arm64 libossp-uuid16 arm64 1.6.2-1.5+b11 [39.9 kB] Get:74 http://deb.debian.org/debian bookworm/main arm64 libpgm-5.3-0 arm64 5.3.128~dfsg-2 [152 kB] Get:75 http://deb.debian.org/debian bookworm/main arm64 libsasl2-modules arm64 2.1.28+dfsg-10 [63.1 kB] Get:76 http://deb.debian.org/debian bookworm/main arm64 liburcu8 arm64 0.13.2-1 [69.5 kB] Get:77 http://deb.debian.org/debian bookworm/main arm64 liburing2 arm64 2.3-3 [12.6 kB] Get:78 http://deb.debian.org/debian bookworm/main arm64 libxslt1.1 arm64 1.1.35-1 [231 kB] Get:79 http://deb.debian.org/debian bookworm/main arm64 libzmq5 arm64 4.3.4-6 [244 kB] Get:80 http://deb.debian.org/debian bookworm/main arm64 lvm2 arm64 2.03.16-2 [1114 kB] Get:81 http://deb.debian.org/debian bookworm/main arm64 nfs-kernel-server arm64 1:2.6.2-4 [147 kB] Get:82 http://deb.debian.org/debian bookworm/main arm64 nginx-common all 1.22.1-9 [112 kB] Get:83 http://deb.debian.org/debian bookworm/main arm64 nginx arm64 1.22.1-9 [494 kB] Get:84 http://deb.debian.org/debian bookworm/main arm64 php-fpm all 2:8.2+93 [3712 B] Get:85 http://deb.debian.org/debian bookworm/main arm64 php-cgi all 2:8.2+93 [4164 B] Get:86 http://deb.debian.org/debian bookworm/main arm64 php8.2-mbstring arm64 8.2.7-1~deb12u1 [430 kB] Get:87 http://deb.debian.org/debian bookworm/main arm64 php-mbstring all 2:8.2+93 [3664 B] Get:88 http://deb.debian.org/debian bookworm/main arm64 python3-dialog all 3.5.1-3 [1393 kB] Get:89 http://deb.debian.org/debian bookworm/main arm64 xfsprogs arm64 6.1.0-1 [929 kB] Get:90 http://deb.debian.org/debian bookworm/main arm64 wsdd all 2:0.7.0-2.1 [33.6 kB] Get:91 http://deb.debian.org/debian bookworm/main arm64 sdparm arm64 1.12-1 [156 kB] Get:92 http://deb.debian.org/debian bookworm/main arm64 uuid arm64 1.6.2-1.5+b11 [19.3 kB] Get:93 http://deb.debian.org/debian bookworm/main arm64 sshpass arm64 1.09-1 [12.5 kB] Get:94 http://deb.debian.org/debian bookworm/main arm64 zstd arm64 1.5.4+dfsg2-5 [584 kB] Get:95 http://deb.debian.org/debian bookworm/main arm64 php8.2-bcmath arm64 8.2.7-1~deb12u1 [14.3 kB] Get:96 http://deb.debian.org/debian bookworm/main arm64 php-bcmath all 2:8.2+93 [3664 B] Get:97 http://deb.debian.org/debian bookworm/main arm64 rrdtool arm64 1.7.2-4+b8 [466 kB] Get:98 http://deb.debian.org/debian bookworm/main arm64 php8.2-xml arm64 8.2.7-1~deb12u1 [97.6 kB] Get:99 http://deb.debian.org/debian bookworm/main arm64 php-xml all 2:8.2+93 [3672 B] Get:100 http://deb.debian.org/debian bookworm/main arm64 quotatool arm64 1:1.6.2-6 [21.2 kB] Get:101 http://deb.debian.org/debian bookworm/main arm64 xmlstarlet arm64 1.6.1-3 [210 kB] Get:102 http://deb.debian.org/debian bookworm/main arm64 samba-vfs-modules arm64 2:4.17.12+dfsg-0+deb12u1 [406 kB] Get:103 http://deb.debian.org/debian bookworm/main arm64 python3-pyudev all 0.24.0-1 [36.5 kB] Get:104 http://deb.debian.org/debian bookworm/main arm64 python3-natsort all 8.0.2-2 [39.0 kB] Get:105 http://deb.debian.org/debian bookworm/main arm64 python3-lxml arm64 4.9.2-1+b1 [1074 kB] Get:106 http://deb.debian.org/debian bookworm/main arm64 python3-dateutil all 2.8.2-2 [78.3 kB] Get:107 http://deb.debian.org/debian bookworm/main arm64 python3-markupsafe arm64 2.1.2-1+b1 [13.3 kB] Get:108 http://deb.debian.org/debian bookworm/main arm64 python3-jinja2 all 3.1.2-1 [119 kB] Get:109 http://deb.debian.org/debian bookworm/main arm64 python3-msgpack arm64 1.0.3-2+b1 [62.6 kB] Get:110 http://deb.debian.org/debian bookworm/main arm64 python3-certifi all 2022.9.24-1 [153 kB] Get:111 http://deb.debian.org/debian bookworm/main arm64 python3-charset-normalizer all 3.0.1-2 [49.3 kB] Get:112 http://deb.debian.org/debian bookworm/main arm64 python3-idna all 3.3-1 [39.4 kB] Get:113 http://deb.debian.org/debian bookworm/main arm64 python3-urllib3 all 1.26.12-1 [117 kB] Get:114 http://deb.debian.org/debian bookworm/main arm64 python3-chardet all 5.1.0+dfsg-2 [110 kB] Get:115 http://deb.debian.org/debian bookworm/main arm64 python3-requests all 2.28.1+dfsg-1 [67.9 kB] Get:116 http://deb.debian.org/debian bookworm/main arm64 python3-systemd arm64 235-1+b2 [39.1 kB] Get:117 http://deb.debian.org/debian bookworm/main arm64 python3-psutil arm64 5.9.4-1+b1 [189 kB] Get:118 http://deb.debian.org/debian bookworm/main arm64 python3-pycryptodome arm64 3.11.0+dfsg1-4 [1010 kB] Get:119 http://deb.debian.org/debian bookworm/main arm64 python3-gnupg all 0.4.9-1 [20.9 kB] Get:120 http://deb.debian.org/debian bookworm/main arm64 python3-py all 1.11.0-1 [89.2 kB] Get:121 http://deb.debian.org/debian bookworm/main arm64 python3-zmq arm64 24.0.1-4+b1 [249 kB] Get:122 http://deb.debian.org/debian bookworm/main arm64 python3-jmespath all 1.0.1-1 [21.1 kB] Get:123 http://deb.debian.org/debian bookworm/main arm64 python3-packaging all 23.0-1 [32.5 kB] Get:124 http://deb.debian.org/debian bookworm/main arm64 python3-colorama all 0.4.6-2 [36.8 kB] Get:125 http://deb.debian.org/debian bookworm/main arm64 python3-click all 8.1.3-2 [92.2 kB] Get:126 http://deb.debian.org/debian bookworm/main arm64 python3-cached-property all 1.5.2-1 [12.5 kB] Get:127 http://deb.debian.org/debian bookworm/main arm64 python3-polib all 1.1.1-1 [25.8 kB] Preconfiguring packages ... Deferring configuration of apt-listchanges until /usr/bin/python3 and python's debconf module are available Fetched 45.8 MB in 4s (11.2 MB/s) Selecting previously unselected package liblockfile-bin. (Reading database ... 76894 files and directories currently installed.) Preparing to unpack .../00-liblockfile-bin_1.17-1+b1_arm64.deb ... Unpacking liblockfile-bin (1.17-1+b1) ... Selecting previously unselected package liblockfile1:arm64. Preparing to unpack .../01-liblockfile1_1.17-1+b1_arm64.deb ... Unpacking liblockfile1:arm64 (1.17-1+b1) ... Selecting previously unselected package bsd-mailx. Preparing to unpack .../02-bsd-mailx_8.1.2-0.20220412cvs-1_arm64.deb ... Unpacking bsd-mailx (8.1.2-0.20220412cvs-1) ... Selecting previously unselected package apticron. Preparing to unpack .../03-apticron_1.2.5+nmu1_all.deb ... Unpacking apticron (1.2.5+nmu1) ... Selecting previously unselected package php-common. Preparing to unpack .../04-php-common_2%3a93_all.deb ... Unpacking php-common (2:93) ... Selecting previously unselected package php8.2-common. Preparing to unpack .../05-php8.2-common_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-common (8.2.7-1~deb12u1) ... Selecting previously unselected package php8.2-opcache. Preparing to unpack .../06-php8.2-opcache_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-opcache (8.2.7-1~deb12u1) ... Selecting previously unselected package php8.2-readline. Preparing to unpack .../07-php8.2-readline_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-readline (8.2.7-1~deb12u1) ... Selecting previously unselected package php8.2-cli. Preparing to unpack .../08-php8.2-cli_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-cli (8.2.7-1~deb12u1) ... Selecting previously unselected package php8.2-fpm. Preparing to unpack .../09-php8.2-fpm_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-fpm (8.2.7-1~deb12u1) ... Selecting previously unselected package php8.2-cgi. Preparing to unpack .../10-php8.2-cgi_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-cgi (8.2.7-1~deb12u1) ... Setting up php-common (2:93) ... Created symlink /etc/systemd/system/timers.target.wants/phpsessionclean.timer → /lib/systemd/system/phpsessionclean.timer. Selecting previously unselected package php8.2-yaml. (Reading database ... 77084 files and directories currently installed.) Preparing to unpack .../000-php8.2-yaml_2.2.2+2.1.0+2.0.4+1.3.2-6_arm64.deb ... Unpacking php8.2-yaml (2.2.2+2.1.0+2.0.4+1.3.2-6) ... Selecting previously unselected package php-yaml. Preparing to unpack .../001-php-yaml_2.2.2+2.1.0+2.0.4+1.3.2-6_arm64.deb ... Unpacking php-yaml (2.2.2+2.1.0+2.0.4+1.3.2-6) ... Selecting previously unselected package quota. Preparing to unpack .../002-quota_4.06-1+b2_arm64.deb ... Unpacking quota (4.06-1+b2) ... Selecting previously unselected package libdbi1:arm64. Preparing to unpack .../003-libdbi1_0.9.0-6_arm64.deb ... Unpacking libdbi1:arm64 (0.9.0-6) ... Selecting previously unselected package librrd8:arm64. Preparing to unpack .../004-librrd8_1.7.2-4+b8_arm64.deb ... Unpacking librrd8:arm64 (1.7.2-4+b8) ... Selecting previously unselected package rrdcached. Preparing to unpack .../005-rrdcached_1.7.2-4+b8_arm64.deb ... Unpacking rrdcached (1.7.2-4+b8) ... Selecting previously unselected package python3-dnspython. Preparing to unpack .../006-python3-dnspython_2.3.0-1_all.deb ... Unpacking python3-dnspython (2.3.0-1) ... Selecting previously unselected package liblmdb0:arm64. Preparing to unpack .../007-liblmdb0_0.9.24-1_arm64.deb ... Unpacking liblmdb0:arm64 (0.9.24-1) ... Selecting previously unselected package libtalloc2:arm64. Preparing to unpack .../008-libtalloc2_2.4.0-f2_arm64.deb ... Unpacking libtalloc2:arm64 (2.4.0-f2) ... Selecting previously unselected package libtdb1:arm64. Preparing to unpack .../009-libtdb1_1.4.8-2_arm64.deb ... Unpacking libtdb1:arm64 (1.4.8-2) ... Selecting previously unselected package libtevent0:arm64. Preparing to unpack .../010-libtevent0_0.14.1-1_arm64.deb ... Unpacking libtevent0:arm64 (0.14.1-1) ... Selecting previously unselected package libldb2:arm64. Preparing to unpack .../011-libldb2_2%3a2.6.2+samba4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking libldb2:arm64 (2:2.6.2+samba4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package libpython3.11:arm64. Preparing to unpack .../012-libpython3.11_3.11.2-6_arm64.deb ... Unpacking libpython3.11:arm64 (3.11.2-6) ... Selecting previously unselected package python3-ldb. Preparing to unpack .../013-python3-ldb_2%3a2.6.2+samba4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking python3-ldb (2:2.6.2+samba4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package python3-tdb. Preparing to unpack .../014-python3-tdb_1.4.8-2_arm64.deb ... Unpacking python3-tdb (1.4.8-2) ... Selecting previously unselected package libavahi-common-data:arm64. Preparing to unpack .../015-libavahi-common-data_0.8-10_arm64.deb ... Unpacking libavahi-common-data:arm64 (0.8-10) ... Selecting previously unselected package libavahi-common3:arm64. Preparing to unpack .../016-libavahi-common3_0.8-10_arm64.deb ... Unpacking libavahi-common3:arm64 (0.8-10) ... Selecting previously unselected package libavahi-client3:arm64. Preparing to unpack .../017-libavahi-client3_0.8-10_arm64.deb ... Unpacking libavahi-client3:arm64 (0.8-10) ... Selecting previously unselected package libwbclient0:arm64. Preparing to unpack .../018-libwbclient0_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package samba-libs:arm64. Preparing to unpack .../019-samba-libs_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking samba-libs:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package python3-talloc:arm64. Preparing to unpack .../020-python3-talloc_2.4.0-f2_arm64.deb ... Unpacking python3-talloc:arm64 (2.4.0-f2) ... Selecting previously unselected package python3-samba. Preparing to unpack .../021-python3-samba_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking python3-samba (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package samba-common. Preparing to unpack .../022-samba-common_2%3a4.17.12+dfsg-0+deb12u1_all.deb ... Unpacking samba-common (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package libcups2:arm64. Preparing to unpack .../023-libcups2_2.4.2-3+deb12u5_arm64.deb ... Unpacking libcups2:arm64 (2.4.2-3+deb12u5) ... Selecting previously unselected package libncurses6:arm64. Preparing to unpack .../024-libncurses6_6.4-4_arm64.deb ... Unpacking libncurses6:arm64 (6.4-4) ... Selecting previously unselected package samba-common-bin. Preparing to unpack .../025-samba-common-bin_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking samba-common-bin (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package tdb-tools. Preparing to unpack .../026-tdb-tools_1.4.8-2_arm64.deb ... Unpacking tdb-tools (1.4.8-2) ... Selecting previously unselected package samba. Preparing to unpack .../027-samba_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking samba (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package whiptail. Preparing to unpack .../028-whiptail_0.52.23-1+b1_arm64.deb ... Unpacking whiptail (0.52.23-1+b1) ... Selecting previously unselected package python3-debconf. Preparing to unpack .../029-python3-debconf_1.5.82_all.deb ... Unpacking python3-debconf (1.5.82) ... Selecting previously unselected package apt-listchanges. Preparing to unpack .../030-apt-listchanges_3.24_all.deb ... Unpacking apt-listchanges (3.24) ... Selecting previously unselected package libnss-systemd:arm64. Preparing to unpack .../031-libnss-systemd_252.22-1~deb12u1_arm64.deb ... Unpacking libnss-systemd:arm64 (252.22-1~deb12u1) ... Selecting previously unselected package acl. Preparing to unpack .../032-acl_2.3.1-3_arm64.deb ... Unpacking acl (2.3.1-3) ... Selecting previously unselected package anacron. Preparing to unpack .../033-anacron_2.3-36_arm64.deb ... Unpacking anacron (2.3-36) ... Selecting previously unselected package libavahi-core7:arm64. Preparing to unpack .../034-libavahi-core7_0.8-10_arm64.deb ... Unpacking libavahi-core7:arm64 (0.8-10) ... Selecting previously unselected package avahi-daemon. Preparing to unpack .../035-avahi-daemon_0.8-10_arm64.deb ... Unpacking avahi-daemon (0.8-10) ... Selecting previously unselected package beep. Preparing to unpack .../036-beep_1.4.9-1_arm64.deb ... Unpacking beep (1.4.9-1) ... Selecting previously unselected package ncal. Preparing to unpack .../037-ncal_12.1.8_arm64.deb ... Unpacking ncal (12.1.8) ... Selecting previously unselected package bsdmainutils. Preparing to unpack .../038-bsdmainutils_12.1.8_all.deb ... Unpacking bsdmainutils (12.1.8) ... Selecting previously unselected package collectd-core. Preparing to unpack .../039-collectd-core_5.12.0-14_arm64.deb ... Unpacking collectd-core (5.12.0-14) ... Selecting previously unselected package collectd. Preparing to unpack .../040-collectd_5.12.0-14_arm64.deb ... Unpacking collectd (5.12.0-14) ... Selecting previously unselected package dctrl-tools. Preparing to unpack .../041-dctrl-tools_2.24-3_arm64.deb ... Unpacking dctrl-tools (2.24-3) ... Selecting previously unselected package libdevmapper-event1.02.1:arm64. Preparing to unpack .../042-libdevmapper-event1.02.1_2%3a1.02.185-2_arm64.deb ... Unpacking libdevmapper-event1.02.1:arm64 (2:1.02.185-2) ... Selecting previously unselected package libaio1:arm64. Preparing to unpack .../043-libaio1_0.3.113-4_arm64.deb ... Unpacking libaio1:arm64 (0.3.113-4) ... Selecting previously unselected package liblvm2cmd2.03:arm64. Preparing to unpack .../044-liblvm2cmd2.03_2.03.16-2_arm64.deb ... Unpacking liblvm2cmd2.03:arm64 (2.03.16-2) ... Selecting previously unselected package dmeventd. Preparing to unpack .../045-dmeventd_2%3a1.02.185-2_arm64.deb ... Unpacking dmeventd (2:1.02.185-2) ... Selecting previously unselected package gdisk. Preparing to unpack .../046-gdisk_1.0.9-2.1_arm64.deb ... Unpacking gdisk (1.0.9-2.1) ... Selecting previously unselected package jfsutils. Preparing to unpack .../047-jfsutils_1.1.15-5_arm64.deb ... Unpacking jfsutils (1.1.15-5) ... Selecting previously unselected package libinih1:arm64. Preparing to unpack .../048-libinih1_55-1_arm64.deb ... Unpacking libinih1:arm64 (55-1) ... Selecting previously unselected package libjs-jquery. Preparing to unpack .../049-libjs-jquery_3.6.1+dfsg+~3.5.14-1_all.deb ... Unpacking libjs-jquery (3.6.1+dfsg+~3.5.14-1) ... Selecting previously unselected package libjs-underscore. Preparing to unpack .../050-libjs-underscore_1.13.4~dfsg+~1.11.4-3_all.deb ... Unpacking libjs-underscore (1.13.4~dfsg+~1.11.4-3) ... Selecting previously unselected package libjs-sphinxdoc. Preparing to unpack .../051-libjs-sphinxdoc_5.3.0-4_all.deb ... Unpacking libjs-sphinxdoc (5.3.0-4) ... Selecting previously unselected package libnorm1:arm64. Preparing to unpack .../052-libnorm1_1.5.9+dfsg-2_arm64.deb ... Unpacking libnorm1:arm64 (1.5.9+dfsg-2) ... Selecting previously unselected package libnss-mdns:arm64. Preparing to unpack .../053-libnss-mdns_0.15.1-3_arm64.deb ... Unpacking libnss-mdns:arm64 (0.15.1-3) ... Selecting previously unselected package systemd-resolved. Preparing to unpack .../054-systemd-resolved_252.22-1~deb12u1_arm64.deb ... Unpacking systemd-resolved (252.22-1~deb12u1) ... Selecting previously unselected package libnss-resolve:arm64. Preparing to unpack .../055-libnss-resolve_252.22-1~deb12u1_arm64.deb ... Unpacking libnss-resolve:arm64 (252.22-1~deb12u1) ... Selecting previously unselected package libossp-uuid16:arm64. Preparing to unpack .../056-libossp-uuid16_1.6.2-1.5+b11_arm64.deb ... Unpacking libossp-uuid16:arm64 (1.6.2-1.5+b11) ... Selecting previously unselected package libpgm-5.3-0:arm64. Preparing to unpack .../057-libpgm-5.3-0_5.3.128~dfsg-2_arm64.deb ... Unpacking libpgm-5.3-0:arm64 (5.3.128~dfsg-2) ... Selecting previously unselected package libsasl2-modules:arm64. Preparing to unpack .../058-libsasl2-modules_2.1.28+dfsg-10_arm64.deb ... Unpacking libsasl2-modules:arm64 (2.1.28+dfsg-10) ... Selecting previously unselected package liburcu8:arm64. Preparing to unpack .../059-liburcu8_0.13.2-1_arm64.deb ... Unpacking liburcu8:arm64 (0.13.2-1) ... Selecting previously unselected package liburing2:arm64. Preparing to unpack .../060-liburing2_2.3-3_arm64.deb ... Unpacking liburing2:arm64 (2.3-3) ... Selecting previously unselected package libxslt1.1:arm64. Preparing to unpack .../061-libxslt1.1_1.1.35-1_arm64.deb ... Unpacking libxslt1.1:arm64 (1.1.35-1) ... Selecting previously unselected package libzmq5:arm64. Preparing to unpack .../062-libzmq5_4.3.4-6_arm64.deb ... Unpacking libzmq5:arm64 (4.3.4-6) ... Selecting previously unselected package lvm2. Preparing to unpack .../063-lvm2_2.03.16-2_arm64.deb ... Unpacking lvm2 (2.03.16-2) ... Selecting previously unselected package nfs-kernel-server. Preparing to unpack .../064-nfs-kernel-server_1%3a2.6.2-4_arm64.deb ... Unpacking nfs-kernel-server (1:2.6.2-4) ... Selecting previously unselected package nginx-common. Preparing to unpack .../065-nginx-common_1.22.1-9_all.deb ... Unpacking nginx-common (1.22.1-9) ... Selecting previously unselected package nginx. Preparing to unpack .../066-nginx_1.22.1-9_arm64.deb ... Unpacking nginx (1.22.1-9) ... Selecting previously unselected package php-fpm. Preparing to unpack .../067-php-fpm_2%3a8.2+93_all.deb ... Unpacking php-fpm (2:8.2+93) ... Selecting previously unselected package php-cgi. Preparing to unpack .../068-php-cgi_2%3a8.2+93_all.deb ... Unpacking php-cgi (2:8.2+93) ... Selecting previously unselected package php8.2-mbstring. Preparing to unpack .../069-php8.2-mbstring_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-mbstring (8.2.7-1~deb12u1) ... Selecting previously unselected package php-mbstring. Preparing to unpack .../070-php-mbstring_2%3a8.2+93_all.deb ... Unpacking php-mbstring (2:8.2+93) ... Selecting previously unselected package php-pam. Preparing to unpack .../071-php-pam_2.2.4-1+deb12u1_arm64.deb ... Unpacking php-pam (2.2.4-1+deb12u1) ... Selecting previously unselected package python3-dialog. Preparing to unpack .../072-python3-dialog_3.5.1-3_all.deb ... Unpacking python3-dialog (3.5.1-3) ... Selecting previously unselected package xfsprogs. Preparing to unpack .../073-xfsprogs_6.1.0-1_arm64.deb ... Unpacking xfsprogs (6.1.0-1) ... Selecting previously unselected package wsdd. Preparing to unpack .../074-wsdd_2%3a0.7.0-2.1_all.deb ... Unpacking wsdd (2:0.7.0-2.1) ... Selecting previously unselected package sdparm. Preparing to unpack .../075-sdparm_1.12-1_arm64.deb ... Unpacking sdparm (1.12-1) ... Selecting previously unselected package uuid. Preparing to unpack .../076-uuid_1.6.2-1.5+b11_arm64.deb ... Unpacking uuid (1.6.2-1.5+b11) ... Selecting previously unselected package sshpass. Preparing to unpack .../077-sshpass_1.09-1_arm64.deb ... Unpacking sshpass (1.09-1) ... Selecting previously unselected package zstd. Preparing to unpack .../078-zstd_1.5.4+dfsg2-5_arm64.deb ... Unpacking zstd (1.5.4+dfsg2-5) ... Selecting previously unselected package php8.2-bcmath. Preparing to unpack .../079-php8.2-bcmath_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-bcmath (8.2.7-1~deb12u1) ... Selecting previously unselected package php-bcmath. Preparing to unpack .../080-php-bcmath_2%3a8.2+93_all.deb ... Unpacking php-bcmath (2:8.2+93) ... Selecting previously unselected package rrdtool. Preparing to unpack .../081-rrdtool_1.7.2-4+b8_arm64.deb ... Unpacking rrdtool (1.7.2-4+b8) ... Selecting previously unselected package php8.2-xml. Preparing to unpack .../082-php8.2-xml_8.2.7-1~deb12u1_arm64.deb ... Unpacking php8.2-xml (8.2.7-1~deb12u1) ... Selecting previously unselected package php-xml. Preparing to unpack .../083-php-xml_2%3a8.2+93_all.deb ... Unpacking php-xml (2:8.2+93) ... Selecting previously unselected package quotatool. Preparing to unpack .../084-quotatool_1%3a1.6.2-6_arm64.deb ... Unpacking quotatool (1:1.6.2-6) ... Selecting previously unselected package xmlstarlet. Preparing to unpack .../085-xmlstarlet_1.6.1-3_arm64.deb ... Unpacking xmlstarlet (1.6.1-3) ... Selecting previously unselected package samba-vfs-modules:arm64. Preparing to unpack .../086-samba-vfs-modules_2%3a4.17.12+dfsg-0+deb12u1_arm64.deb ... Unpacking samba-vfs-modules:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Selecting previously unselected package python3-pyudev. Preparing to unpack .../087-python3-pyudev_0.24.0-1_all.deb ... Unpacking python3-pyudev (0.24.0-1) ... Selecting previously unselected package python3-natsort. Preparing to unpack .../088-python3-natsort_8.0.2-2_all.deb ... Unpacking python3-natsort (8.0.2-2) ... Selecting previously unselected package python3-lxml:arm64. Preparing to unpack .../089-python3-lxml_4.9.2-1+b1_arm64.deb ... Unpacking python3-lxml:arm64 (4.9.2-1+b1) ... Selecting previously unselected package python3-dateutil. Preparing to unpack .../090-python3-dateutil_2.8.2-2_all.deb ... Unpacking python3-dateutil (2.8.2-2) ... Selecting previously unselected package python3-looseversion. Preparing to unpack .../091-python3-looseversion_1.0.2-2_all.deb ... Unpacking python3-looseversion (1.0.2-2) ... Selecting previously unselected package python3-markupsafe. Preparing to unpack .../092-python3-markupsafe_2.1.2-1+b1_arm64.deb ... Unpacking python3-markupsafe (2.1.2-1+b1) ... Selecting previously unselected package python3-jinja2. Preparing to unpack .../093-python3-jinja2_3.1.2-1_all.deb ... Unpacking python3-jinja2 (3.1.2-1) ... Selecting previously unselected package python3-msgpack. Preparing to unpack .../094-python3-msgpack_1.0.3-2+b1_arm64.deb ... Unpacking python3-msgpack (1.0.3-2+b1) ... Selecting previously unselected package python3-certifi. Preparing to unpack .../095-python3-certifi_2022.9.24-1_all.deb ... Unpacking python3-certifi (2022.9.24-1) ... Selecting previously unselected package python3-charset-normalizer. Preparing to unpack .../096-python3-charset-normalizer_3.0.1-2_all.deb ... Unpacking python3-charset-normalizer (3.0.1-2) ... Selecting previously unselected package python3-idna. Preparing to unpack .../097-python3-idna_3.3-1_all.deb ... Unpacking python3-idna (3.3-1) ... Selecting previously unselected package python3-urllib3. Preparing to unpack .../098-python3-urllib3_1.26.12-1_all.deb ... Unpacking python3-urllib3 (1.26.12-1) ... Selecting previously unselected package python3-chardet. Preparing to unpack .../099-python3-chardet_5.1.0+dfsg-2_all.deb ... Unpacking python3-chardet (5.1.0+dfsg-2) ... Selecting previously unselected package python3-requests. Preparing to unpack .../100-python3-requests_2.28.1+dfsg-1_all.deb ... Unpacking python3-requests (2.28.1+dfsg-1) ... Selecting previously unselected package python3-systemd. Preparing to unpack .../101-python3-systemd_235-1+b2_arm64.deb ... Unpacking python3-systemd (235-1+b2) ... Selecting previously unselected package python3-psutil. Preparing to unpack .../102-python3-psutil_5.9.4-1+b1_arm64.deb ... Unpacking python3-psutil (5.9.4-1+b1) ... Selecting previously unselected package python3-pycryptodome. Preparing to unpack .../103-python3-pycryptodome_3.11.0+dfsg1-4_arm64.deb ... Unpacking python3-pycryptodome (3.11.0+dfsg1-4) ... Selecting previously unselected package python3-gnupg. Preparing to unpack .../104-python3-gnupg_0.4.9-1_all.deb ... Unpacking python3-gnupg (0.4.9-1) ... Selecting previously unselected package python3-py. Preparing to unpack .../105-python3-py_1.11.0-1_all.deb ... Unpacking python3-py (1.11.0-1) ... Selecting previously unselected package python3-zmq. Preparing to unpack .../106-python3-zmq_24.0.1-4+b1_arm64.deb ... Unpacking python3-zmq (24.0.1-4+b1) ... Selecting previously unselected package python3-jmespath. Preparing to unpack .../107-python3-jmespath_1.0.1-1_all.deb ... Unpacking python3-jmespath (1.0.1-1) ... Selecting previously unselected package python3-packaging. Preparing to unpack .../108-python3-packaging_23.0-1_all.deb ... Unpacking python3-packaging (23.0-1) ... Selecting previously unselected package salt-common. Preparing to unpack .../109-salt-common_3006.0+ds-1+197.1_all.deb ... Unpacking salt-common (3006.0+ds-1+197.1) ... Selecting previously unselected package salt-minion. Preparing to unpack .../110-salt-minion_3006.0+ds-1+197.1_all.deb ... Unpacking salt-minion (3006.0+ds-1+197.1) ... Selecting previously unselected package python3-colorama. Preparing to unpack .../111-python3-colorama_0.4.6-2_all.deb ... Unpacking python3-colorama (0.4.6-2) ... Selecting previously unselected package python3-click. Preparing to unpack .../112-python3-click_8.1.3-2_all.deb ... Unpacking python3-click (8.1.3-2) ... Selecting previously unselected package python3-cached-property. Preparing to unpack .../113-python3-cached-property_1.5.2-1_all.deb ... Unpacking python3-cached-property (1.5.2-1) ... Selecting previously unselected package python3-polib. Preparing to unpack .../114-python3-polib_1.1.1-1_all.deb ... Unpacking python3-polib (1.1.1-1) ... Selecting previously unselected package openmediavault. Preparing to unpack .../115-openmediavault_7.0-32_all.deb ... Unpacking openmediavault (7.0-32) ... Setting up python3-cached-property (1.5.2-1) ... Setting up liblmdb0:arm64 (0.9.24-1) ... Setting up nfs-kernel-server (1:2.6.2-4) ... Created symlink /etc/systemd/system/nfs-client.target.wants/nfs-blkmap.service → /lib/systemd/system/nfs-blkmap.service. Created symlink /etc/systemd/system/multi-user.target.wants/nfs-server.service → /lib/systemd/system/nfs-server.service. nfs-mountd.service is a disabled or a static unit, not starting it. nfsdcld.service is a disabled or a static unit, not starting it. Creating config file /etc/exports with new version Creating config file /etc/default/nfs-kernel-server with new version Setting up php8.2-common (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/calendar.ini with new version Creating config file /etc/php/8.2/mods-available/ctype.ini with new version Creating config file /etc/php/8.2/mods-available/exif.ini with new version Creating config file /etc/php/8.2/mods-available/fileinfo.ini with new version Creating config file /etc/php/8.2/mods-available/ffi.ini with new version Creating config file /etc/php/8.2/mods-available/ftp.ini with new version Creating config file /etc/php/8.2/mods-available/gettext.ini with new version Creating config file /etc/php/8.2/mods-available/iconv.ini with new version Creating config file /etc/php/8.2/mods-available/pdo.ini with new version Creating config file /etc/php/8.2/mods-available/phar.ini with new version Creating config file /etc/php/8.2/mods-available/posix.ini with new version Creating config file /etc/php/8.2/mods-available/shmop.ini with new version Creating config file /etc/php/8.2/mods-available/sockets.ini with new version Creating config file /etc/php/8.2/mods-available/sysvmsg.ini with new version Creating config file /etc/php/8.2/mods-available/sysvsem.ini with new version Creating config file /etc/php/8.2/mods-available/sysvshm.ini with new version Creating config file /etc/php/8.2/mods-available/tokenizer.ini with new version Setting up beep (1.4.9-1) ... Setting up python3-gnupg (0.4.9-1) ... Setting up liblockfile-bin (1.17-1+b1) ... Setting up libdbi1:arm64 (0.9.0-6) ... Setting up libdevmapper-event1.02.1:arm64 (2:1.02.185-2) ... Setting up libpython3.11:arm64 (3.11.2-6) ... Setting up collectd-core (5.12.0-14) ... Created symlink /etc/systemd/system/multi-user.target.wants/collectd.service → /lib/systemd/system/collectd.service. Setting up python3-py (1.11.0-1) ... Setting up php8.2-bcmath (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/bcmath.ini with new version Setting up ncal (12.1.8) ... Setting up python3-colorama (0.4.6-2) ... Setting up anacron (2.3-36) ... Created symlink /etc/systemd/system/multi-user.target.wants/anacron.service → /lib/systemd/system/anacron.service. Created symlink /etc/systemd/system/timers.target.wants/anacron.timer → /lib/systemd/system/anacron.timer. Setting up python3-charset-normalizer (3.0.1-2) ... Setting up python3-polib (1.1.1-1) ... Setting up php8.2-opcache (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/opcache.ini with new version Setting up libinih1:arm64 (55-1) ... Setting up libtdb1:arm64 (1.4.8-2) ... Setting up libpgm-5.3-0:arm64 (5.3.128~dfsg-2) ... Setting up python3-pycryptodome (3.11.0+dfsg1-4) ... Setting up jfsutils (1.1.15-5) ... update-initramfs: deferring update (trigger activated) Setting up php8.2-readline (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/readline.ini with new version Setting up php8.2-mbstring (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/mbstring.ini with new version Setting up python3-debconf (1.5.82) ... Setting up libsasl2-modules:arm64 (2.1.28+dfsg-10) ... Setting up libnorm1:arm64 (1.5.9+dfsg-2) ... Setting up nginx-common (1.22.1-9) ... Created symlink /etc/systemd/system/multi-user.target.wants/nginx.service → /lib/systemd/system/nginx.service. Setting up libnss-systemd:arm64 (252.22-1~deb12u1) ... Setting up libossp-uuid16:arm64 (1.6.2-1.5+b11) ... Setting up samba-common (2:4.17.12+dfsg-0+deb12u1) ... Creating config file /etc/samba/smb.conf with new version Setting up python3-click (8.1.3-2) ... Setting up php-mbstring (2:8.2+93) ... Setting up python3-markupsafe (2.1.2-1+b1) ... Setting up sshpass (1.09-1) ... Setting up libwbclient0:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Setting up python3-psutil (5.9.4-1+b1) ... Setting up python3-natsort (8.0.2-2) ... Setting up acl (2.3.1-3) ... Setting up wsdd (2:0.7.0-2.1) ... Created symlink /etc/systemd/system/multi-user.target.wants/wsdd.service → /lib/systemd/system/wsdd.service. Setting up libtalloc2:arm64 (2.4.0-f2) ... Setting up gdisk (1.0.9-2.1) ... Setting up python3-tdb (1.4.8-2) ... Setting up python3-jinja2 (3.1.2-1) ... Setting up sdparm (1.12-1) ... Setting up python3-packaging (23.0-1) ... Setting up python3-chardet (5.1.0+dfsg-2) ... Setting up libtevent0:arm64 (0.14.1-1) ... Setting up python3-certifi (2022.9.24-1) ... Setting up python3-jmespath (1.0.1-1) ... Setting up libavahi-common-data:arm64 (0.8-10) ... Setting up libncurses6:arm64 (6.4-4) ... Setting up tdb-tools (1.4.8-2) ... update-alternatives: using /usr/bin/tdbbackup.tdbtools to provide /usr/bin/tdbbackup (tdbbackup) in auto mode Setting up quotatool (1:1.6.2-6) ... Setting up bsdmainutils (12.1.8) ... Setting up python3-idna (3.3-1) ... Setting up uuid (1.6.2-1.5+b11) ... Setting up liburcu8:arm64 (0.13.2-1) ... Setting up quota (4.06-1+b2) ... Setting up python3-urllib3 (1.26.12-1) ... Setting up whiptail (0.52.23-1+b1) ... Setting up python3-looseversion (1.0.2-2) ... Setting up python3-dnspython (2.3.0-1) ... Setting up libxslt1.1:arm64 (1.1.35-1) ... Setting up python3-dateutil (2.8.2-2) ... Setting up python3-msgpack (1.0.3-2+b1) ... Setting up liblockfile1:arm64 (1.17-1+b1) ... Setting up apt-listchanges (3.24) ... Creating config file /etc/apt/listchanges.conf with new version Setting up libjs-jquery (3.6.1+dfsg+~3.5.14-1) ... Setting up liburing2:arm64 (2.3-3) ... Setting up python3-pyudev (0.24.0-1) ... Setting up libaio1:arm64 (0.3.113-4) ... Setting up php8.2-cli (8.2.7-1~deb12u1) ... update-alternatives: using /usr/bin/php8.2 to provide /usr/bin/php (php) in auto mode update-alternatives: using /usr/bin/phar8.2 to provide /usr/bin/phar (phar) in auto mode update-alternatives: using /usr/bin/phar.phar8.2 to provide /usr/bin/phar.phar (phar.phar) in auto mode Creating config file /etc/php/8.2/cli/php.ini with new version Setting up libldb2:arm64 (2:2.6.2+samba4.17.12+dfsg-0+deb12u1) ... Setting up libnss-mdns:arm64 (0.15.1-3) ... Setting up zstd (1.5.4+dfsg2-5) ... Setting up dctrl-tools (2.24-3) ... Setting up python3-systemd (235-1+b2) ... Setting up libjs-underscore (1.13.4~dfsg+~1.11.4-3) ... Setting up systemd-resolved (252.22-1~deb12u1) ... Converting /etc/resolv.conf to a symlink to /run/systemd/resolve/stub-resolv.conf... Creating group 'systemd-resolve' with GID 996. Creating user 'systemd-resolve' (systemd Resolver) with UID 996 and GID 996. Created symlink /etc/systemd/system/dbus-org.freedesktop.resolve1.service → /lib/systemd/system/systemd-resolved.service. Created symlink /etc/systemd/system/sysinit.target.wants/systemd-resolved.service → /lib/systemd/system/systemd-resolved.service. Setting up librrd8:arm64 (1.7.2-4+b8) ... Setting up libzmq5:arm64 (4.3.4-6) ... Setting up php-bcmath (2:8.2+93) ... Setting up php-pam (2.2.4-1+deb12u1) ... Setting up nginx (1.22.1-9) ... Upgrading binary: nginx. Setting up python3-talloc:arm64 (2.4.0-f2) ... Setting up collectd (5.12.0-14) ... Setting up rrdcached (1.7.2-4+b8) ... Setting up libavahi-common3:arm64 (0.8-10) ... Setting up php8.2-fpm (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/fpm/php.ini with new version Created symlink /etc/systemd/system/multi-user.target.wants/php8.2-fpm.service → /lib/systemd/system/php8.2-fpm.service. Setting up php8.2-xml (8.2.7-1~deb12u1) ... Creating config file /etc/php/8.2/mods-available/dom.ini with new version Creating config file /etc/php/8.2/mods-available/simplexml.ini with new version Creating config file /etc/php/8.2/mods-available/xml.ini with new version Creating config file /etc/php/8.2/mods-available/xmlreader.ini with new version Creating config file /etc/php/8.2/mods-available/xmlwriter.ini with new version Creating config file /etc/php/8.2/mods-available/xsl.ini with new version Setting up python3-zmq (24.0.1-4+b1) ... Setting up bsd-mailx (8.1.2-0.20220412cvs-1) ... update-alternatives: using /usr/bin/bsd-mailx to provide /usr/bin/mailx (mailx) in auto mode Setting up python3-requests (2.28.1+dfsg-1) ... Setting up python3-ldb (2:2.6.2+samba4.17.12+dfsg-0+deb12u1) ... Setting up xfsprogs (6.1.0-1) ... update-initramfs: deferring update (trigger activated) Setting up libjs-sphinxdoc (5.3.0-4) ... Setting up xmlstarlet (1.6.1-3) ... Setting up php-fpm (2:8.2+93) ... Setting up php8.2-cgi (8.2.7-1~deb12u1) ... update-alternatives: using /usr/bin/php-cgi8.2 to provide /usr/bin/php-cgi (php-cgi) in auto mode update-alternatives: using /usr/lib/cgi-bin/php8.2 to provide /usr/lib/cgi-bin/php (php-cgi-bin) in auto mode Creating config file /etc/php/8.2/cgi/php.ini with new version Setting up python3-lxml:arm64 (4.9.2-1+b1) ... Setting up php8.2-yaml (2.2.2+2.1.0+2.0.4+1.3.2-6) ... Setting up rrdtool (1.7.2-4+b8) ... Setting up libavahi-core7:arm64 (0.8-10) ... Setting up libnss-resolve:arm64 (252.22-1~deb12u1) ... Setting up libavahi-client3:arm64 (0.8-10) ... Setting up php-cgi (2:8.2+93) ... update-alternatives: using /usr/bin/php-cgi.default to provide /usr/bin/php-cgi (php-cgi) in auto mode update-alternatives: using /usr/lib/cgi-bin/php.default to provide /usr/lib/cgi-bin/php (php-cgi-bin) in auto mode Setting up php-xml (2:8.2+93) ... Setting up python3-dialog (3.5.1-3) ... Setting up apticron (1.2.5+nmu1) ... Creating config file /etc/cron.d/apticron with new version Setting up samba-libs:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Setting up php-yaml (2.2.2+2.1.0+2.0.4+1.3.2-6) ... Setting up salt-common (3006.0+ds-1+197.1) ... Setting up libcups2:arm64 (2.4.2-3+deb12u5) ... Setting up avahi-daemon (0.8-10) ... Created symlink /etc/systemd/system/dbus-org.freedesktop.Avahi.service → /lib/systemd/system/avahi-daemon.service. Created symlink /etc/systemd/system/multi-user.target.wants/avahi-daemon.service → /lib/systemd/system/avahi-daemon.service. Created symlink /etc/systemd/system/sockets.target.wants/avahi-daemon.socket → /lib/systemd/system/avahi-daemon.socket. Setting up python3-samba (2:4.17.12+dfsg-0+deb12u1) ... Setting up samba-vfs-modules:arm64 (2:4.17.12+dfsg-0+deb12u1) ... Setting up salt-minion (3006.0+ds-1+197.1) ... Created symlink /etc/systemd/system/multi-user.target.wants/salt-minion.service → /lib/systemd/system/salt-minion.service. Setting up samba-common-bin (2:4.17.12+dfsg-0+deb12u1) ... Setting up samba (2:4.17.12+dfsg-0+deb12u1) ... Created symlink /etc/systemd/system/multi-user.target.wants/nmbd.service → /lib/systemd/system/nmbd.service. Created symlink /etc/systemd/system/multi-user.target.wants/samba-ad-dc.service → /lib/systemd/system/samba-ad-dc.service. Created symlink /etc/systemd/system/multi-user.target.wants/smbd.service → /lib/systemd/system/smbd.service. Setting up liblvm2cmd2.03:arm64 (2.03.16-2) ... Setting up dmeventd (2:1.02.185-2) ... Created symlink /etc/systemd/system/sockets.target.wants/dm-event.socket → /lib/systemd/system/dm-event.socket. dm-event.service is a disabled or a static unit, not starting it. Setting up lvm2 (2.03.16-2) ... Created symlink /etc/systemd/system/sysinit.target.wants/blk-availability.service → /lib/systemd/system/blk-availability.service. Created symlink /etc/systemd/system/sysinit.target.wants/lvm2-monitor.service → /lib/systemd/system/lvm2-monitor.service. Created symlink /etc/systemd/system/sysinit.target.wants/lvm2-lvmpolld.socket → /lib/systemd/system/lvm2-lvmpolld.socket. Setting up openmediavault (7.0-32) ... Creating users/groups ... Updating local package archive ... Updating service units ... sshd.service is a disabled or a static unit, not starting it. Created symlink /etc/systemd/system/dbus-org.freedesktop.network1.service → /lib/systemd/system/systemd-networkd.service. Created symlink /etc/systemd/system/multi-user.target.wants/systemd-networkd.service → /lib/systemd/system/systemd-networkd.service. Created symlink /etc/systemd/system/sockets.target.wants/systemd-networkd.socket → /lib/systemd/system/systemd-networkd.socket. Created symlink /etc/systemd/system/sysinit.target.wants/systemd-network-generator.service → /lib/systemd/system/systemd-network-generator.service. Created symlink /etc/systemd/system/network-online.target.wants/systemd-networkd-wait-online.service → /lib/systemd/system/systemd-networkd-wait-online.service. systemd-journald.service is a disabled or a static unit, not starting it. Generating public/private rsa key pair. Your identification has been saved in /root/.ssh/id_rsa Your public key has been saved in /root/.ssh/id_rsa.pub The key fingerprint is: SHA256:sScYFw9dNVZeVAoOeEtVZZlXv5mwxc28zOyPJcZJjYE root@helios64 The key's randomart image is: +---[RSA 3072]----+ | oo.o+o=+&| | .++o +.X=| | . oo..E.ooB| | + o. B+=| | . S . .oO.| | o o.. | | =..| | . +.| | . .| +----[SHA256]-----+ Failed to stop ntp.service: Unit ntp.service not loaded. Unit ntp.service does not exist, proceeding anyway. Created symlink /etc/systemd/system/ntp.service → /dev/null. Failed to stop systemd-timesyncd.service: Unit systemd-timesyncd.service not loaded. Unit systemd-timesyncd.service does not exist, proceeding anyway. Created symlink /etc/systemd/system/systemd-timesyncd.service → /dev/null. Created symlink /etc/systemd/system/nfs-blkmap.service → /dev/null. Created symlink /etc/systemd/system/multi-user.target.wants/smartctl-hdparm.service → /etc/systemd/system/smartctl-hdparm.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-beep-up.service → /lib/systemd/system/openmediavault-beep-up.service. Created symlink /etc/systemd/system/reboot.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/halt.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/poweroff.target.wants/openmediavault-beep-down.service → /lib/systemd/system/openmediavault-beep-down.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-cleanup-monit.service → /lib/systemd/system/openmediavault-cleanup-monit.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-cleanup-php.service → /lib/systemd/system/openmediavault-cleanup-php.service. Created symlink /etc/systemd/system/multi-user.target.wants/openmediavault-engined.service → /lib/systemd/system/openmediavault-engined.service. Created symlink /etc/systemd/system/getty.target.wants/openmediavault-issue.service → /lib/systemd/system/openmediavault-issue.service. Creating configuration database ... Setting up Salt environment ... /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() Setting up system ... /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/utils/pycrypto.py:26: DeprecationWarning: 'crypt' is deprecated and slated for removal in Python 3.13 import crypt /usr/lib/python3/dist-packages/salt/modules/linux_shadow.py:21: DeprecationWarning: 'spwd' is deprecated and slated for removal in Python 3.13 import spwd Deploying service configurations ... Processing system modifications ... Processing triggers for libc-bin (2.36-9+deb12u4) ... Processing triggers for rsyslog (8.2302.0-1) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for dbus (1.14.10-1~deb12u1) ... Processing triggers for initramfs-tools (0.142) ... update-initramfs: Generating /boot/initrd.img-6.6.8-edge-rockchip64 update-initramfs: Armbian: Converting to u-boot format: /boot/uInitrd-6.6.8-edge-rockchip64 Image Name: uInitrd Created: Wed Feb 28 11:20:56 2024 Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 29401991 Bytes = 28712.88 KiB = 28.04 MiB Load Address: 00000000 Entry Point: 00000000 update-initramfs: Armbian: Symlinking /boot/uInitrd-6.6.8-edge-rockchip64 to /boot/uInitrd '/boot/uInitrd' -> 'uInitrd-6.6.8-edge-rockchip64' update-initramfs: Armbian: done. Processing triggers for php8.2-cli (8.2.7-1~deb12u1) ... Processing triggers for php8.2-fpm (8.2.7-1~deb12u1) ... Processing triggers for php8.2-cgi (8.2.7-1~deb12u1) ... Processing triggers for openmediavault (7.0-32) ... Restarting engine daemon ... Updating workbench configuration files ... /usr/lib/python3/dist-packages/salt/utils/http.py:8: DeprecationWarning: 'cgi' is deprecated and slated for removal in Python 3.13 import cgi /usr/lib/python3/dist-packages/salt/utils/jinja.py:9: DeprecationWarning: 'pipes' is deprecated and slated for removal in Python 3.13 import pipes /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() helios64: ---------- ID: configure_hosts_header Function: file.managed Name: /etc/hosts Result: True Comment: File /etc/hosts updated Started: 11:21:26.501620 Duration: 173.77 ms Changes: ---------- diff: --- +++ @@ -1,7 +1,2 @@ -127.0.0.1 localhost -127.0.1.1 helios64 -::1 localhost helios64 ip6-localhost ip6-loopback -fe00::0 ip6-localnet -ff00::0 ip6-mcastprefix -ff02::1 ip6-allnodes -ff02::2 ip6-allrouters +# This file is auto-generated by openmediavault (https://www.openmediavault.org) +# WARNING: Do not edit this file, your changes will get lost. ---------- ID: configure_hosts_localhost_ipv4 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 11:21:26.675759 Duration: 4.875 ms Changes: ---------- diff: --- +++ @@ -1,2 +1,3 @@ # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. +127.0.0.1 localhost.localdomain localhost ---------- ID: configure_hosts_localhost_fqdn_ipv4 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 11:21:26.680975 Duration: 4.636 ms Changes: ---------- diff: --- +++ @@ -1,3 +1,4 @@ # This file is auto-generated by openmediavault (https://www.openmediavault.org) # WARNING: Do not edit this file, your changes will get lost. 127.0.0.1 localhost.localdomain localhost +127.0.1.1 helios64 ---------- ID: configure_hosts_comment_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 11:21:26.685950 Duration: 7.095 ms Changes: ---------- diff: --- +++ @@ -2,3 +2,4 @@ # WARNING: Do not edit this file, your changes will get lost. 127.0.0.1 localhost.localdomain localhost 127.0.1.1 helios64 +# The following lines are desirable for IPv6 capable hosts. ---------- ID: configure_hosts_localhost_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 1 lines Started: 11:21:26.693376 Duration: 4.806 ms Changes: ---------- diff: --- +++ @@ -3,3 +3,4 @@ 127.0.0.1 localhost.localdomain localhost 127.0.1.1 helios64 # The following lines are desirable for IPv6 capable hosts. +::1 localhost ip6-localhost ip6-loopback helios64 ---------- ID: configure_hosts_various_ipv6 Function: file.append Name: /etc/hosts Result: True Comment: Appended 5 lines Started: 11:21:26.698510 Duration: 5.931 ms Changes: ---------- diff: --- +++ @@ -4,3 +4,8 @@ 127.0.1.1 helios64 # The following lines are desirable for IPv6 capable hosts. ::1 localhost ip6-localhost ip6-loopback helios64 +fe00::0 ip6-localnet +ff00::0 ip6-mcastprefix +ff02::1 ip6-allnodes +ff02::2 ip6-allrouters +ff02::3 ip6-allhosts Summary for helios64 ------------ Succeeded: 6 (changed=6) Failed: 0 ------------ Total states run: 6 Total run time: 201.113 ms [2024-02-28 11:21:27+0100] [omvinstall] Testing DNS... [2024-02-28 11:21:27+0100] [omvinstall] DNS failing to resolve. Fixing ... [2024-02-28 11:21:27+0100] [omvinstall] Reverting /etc/resolv.conf to saved copy ... removed '/etc/resolv.conf' '/root/resolv.conf' -> '/etc/resolv.conf' [2024-02-28 11:21:27+0100] [omvinstall] Downloading omv-extras.org plugin for openmediavault 7.x ... --2024-02-28 11:21:27-- https://github.com/OpenMediaVault-Plugin-Developers/packages/raw/master/openmediavault-omvextrasorg_latest_all7.deb Resolving github.com (github.com)... 140.82.121.3 Connecting to github.com (github.com)|140.82.121.3|:443... connected. HTTP request sent, awaiting response... 302 Found Location: https://raw.githubusercontent.com/OpenMediaVault-Plugin-Developers/packages/master/openmediavault-omvextrasorg_latest_all7.deb [following] --2024-02-28 11:21:28-- https://raw.githubusercontent.com/OpenMediaVault-Plugin-Developers/packages/master/openmediavault-omvextrasorg_latest_all7.deb Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 2606:50c0:8002::154, 2606:50c0:8003::154, 2606:50c0:8000::154, ... Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|2606:50c0:8002::154|:443... connected. HTTP request sent, awaiting response... 200 OK Length: 40672 (40K) [application/octet-stream] Saving to: ‘openmediavault-omvextrasorg_latest_all7.deb’ openmediavault-omvextrasorg_latest_all7.deb 100%[=================================================================================================>] 39.72K --.-KB/s in 0.005s 2024-02-28 11:21:28 (7.51 MB/s) - ‘openmediavault-omvextrasorg_latest_all7.deb’ saved [40672/40672] Selecting previously unselected package openmediavault-omvextrasorg. (Reading database ... 84555 files and directories currently installed.) Preparing to unpack openmediavault-omvextrasorg_latest_all7.deb ... Unpacking openmediavault-omvextrasorg (7.0) ... Setting up openmediavault-omvextrasorg (7.0) ... Updating configuration database ... 1. Cleaning apt cache files... 2. Clearing available dpkg packages... dpkg: error: dpkg frontend lock was locked by another process with pid 26246 Note: removing the lock file is always wrong, can damage the locked area and the entire system. See <https://wiki.debian.org/Teams/Dpkg/FAQ#db-lock>. 3. Removing apt lists... removed directory '/var/lib/apt/lists/auxfiles' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-all.diff_Index' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.diff_Index' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages.diff_Index' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-all.lz4' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/lock' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_InRelease' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_main_binary-arm64_Packages' removed directory '/var/lib/apt/lists/partial' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_InRelease' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_main_binary-arm64_Packages' 4. Removing OpenMediaVault cache packages... removed '/var/cache/openmediavault/archives/Packages' 5. Creating new OpenMediaVault packages file... 6. Remove old omv-extras apt list files... 7. Adding omv-extras repo and key... 8. Updating apt... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:6 http://packages.openmediavault.org/public sandworm InRelease [12.8 kB] Get:7 http://deb.debian.org/debian bookworm InRelease [151 kB] Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:8 http://security.debian.org bookworm-security InRelease [48.0 kB] Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:9 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB] Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:10 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:11 http://httpredir.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:12 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:13 https://openmediavault.github.io/packages sandworm InRelease [12.8 kB] Get:14 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease [3936 B] Get:15 http://packages.openmediavault.org/public sandworm/main arm64 Packages [7669 B] Get:16 http://deb.debian.org/debian bookworm/main arm64 Packages [11.9 MB] Get:17 http://security.debian.org bookworm-security/main arm64 Packages [141 kB] Get:18 http://security.debian.org/debian-security bookworm-security/non-free-firmware Sources [796 B] Get:19 http://security.debian.org/debian-security bookworm-security/contrib Sources [856 B] Get:20 http://security.debian.org/debian-security bookworm-security/main Sources [82.8 kB] Get:21 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [141 kB] Get:22 http://deb.debian.org/debian bookworm/main all Contents (deb) [33.0 MB] Get:23 http://httpredir.debian.org/debian bookworm-backports/main arm64 Packages [178 kB] Get:24 http://httpredir.debian.org/debian bookworm-backports/main all Contents (deb) [3830 kB] Get:25 http://httpredir.debian.org/debian bookworm-backports/main arm64 Contents (deb) [771 kB] Get:26 https://openmediavault.github.io/packages sandworm/main arm64 Packages [7669 B] Get:27 http://httpredir.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:28 http://httpredir.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:29 http://httpredir.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:30 http://httpredir.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:31 http://httpredir.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Get:32 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 Packages [8689 B] Get:33 http://deb.debian.org/debian bookworm/main arm64 Contents (deb) [11.2 MB] Get:34 http://deb.debian.org/debian bookworm/contrib arm64 Packages [54.7 kB] Get:35 http://deb.debian.org/debian bookworm/contrib all Contents (deb) [98.6 kB] Get:36 http://deb.debian.org/debian bookworm/contrib arm64 Contents (deb) [37.7 kB] Get:37 http://deb.debian.org/debian bookworm/non-free arm64 Packages [94.4 kB] Get:38 http://deb.debian.org/debian bookworm/non-free arm64 Contents (deb) [43.4 kB] Get:39 http://deb.debian.org/debian bookworm/non-free all Contents (deb) [839 kB] Get:40 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [6401 B] Get:41 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Contents (deb) [243 B] Get:42 http://deb.debian.org/debian bookworm/non-free-firmware all Contents (deb) [16.9 kB] Get:43 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [12.5 kB] Get:44 http://deb.debian.org/debian bookworm-updates/main arm64 Contents (deb) [253 kB] Get:45 http://deb.debian.org/debian bookworm-updates/main all Contents (deb) [222 kB] Get:46 http://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B] Get:47 http://deb.debian.org/debian bookworm-updates/contrib arm64 Contents (deb) [222 B] Get:48 http://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB] Get:49 http://deb.debian.org/debian bookworm-updates/non-free arm64 Contents (deb) [14.9 kB] Get:50 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Packages [616 B] Get:51 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Contents (deb) [243 B] Get:52 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [178 kB] Get:53 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) [3830 kB] Get:54 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) [771 kB] Get:55 http://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:56 http://deb.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:57 http://deb.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:58 http://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:59 http://deb.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Fetched 68.4 MB in 12s (5491 kB/s) Reading package lists... Done 9. Saving current package list... 10. Updating plugin index... Creating index of upgradeable packages ... Creating index of plugins ... Processing triggers for openmediavault (7.0-32) ... Updating workbench configuration files ... Restarting engine daemon ... [2024-02-28 11:22:17+0100] [omvinstall] Updating repos ... 1. Cleaning apt cache files... 2. Clearing available dpkg packages... 3. Removing apt lists... removed '/var/lib/apt/lists/_var_cache_openmediavault_archives_Packages' removed directory '/var/lib/apt/lists/auxfiles' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-backports_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm-updates_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_InRelease' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free-firmware_binary-arm64_Packages' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-all.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_Contents-arm64.gz' removed '/var/lib/apt/lists/deb.debian.org_debian_dists_bookworm_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_InRelease' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_contrib_Contents-all.gz' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_contrib_Contents-arm64.gz' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_contrib_binary-arm64_Packages' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_main_Contents-all.gz' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_main_Contents-arm64.gz' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_main_binary-arm64_Packages' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_non-free_Contents-all.gz' removed '/var/lib/apt/lists/httpredir.debian.org_debian_dists_bookworm-backports_non-free_binary-arm64_Packages' removed '/var/lib/apt/lists/lock' removed '/var/lib/apt/lists/openmediavault-plugin-developers.github.io_packages_debian_dists_sandworm_InRelease' removed '/var/lib/apt/lists/openmediavault-plugin-developers.github.io_packages_debian_dists_sandworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/openmediavault.github.io_packages_dists_sandworm_InRelease' removed '/var/lib/apt/lists/openmediavault.github.io_packages_dists_sandworm_main_binary-arm64_Packages' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_InRelease' removed '/var/lib/apt/lists/packages.openmediavault.org_public_dists_sandworm_main_binary-arm64_Packages' removed directory '/var/lib/apt/lists/partial' removed '/var/lib/apt/lists/security.debian.org_debian-security_dists_bookworm-security_InRelease' removed '/var/lib/apt/lists/security.debian.org_debian-security_dists_bookworm-security_contrib_source_Sources' removed '/var/lib/apt/lists/security.debian.org_debian-security_dists_bookworm-security_main_binary-arm64_Packages' removed '/var/lib/apt/lists/security.debian.org_debian-security_dists_bookworm-security_main_source_Sources' removed '/var/lib/apt/lists/security.debian.org_debian-security_dists_bookworm-security_non-free-firmware_source_Sources' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_InRelease' removed '/var/lib/apt/lists/security.debian.org_dists_bookworm-security_main_binary-arm64_Packages' 4. Removing OpenMediaVault cache packages... removed '/var/cache/openmediavault/archives/Packages' 5. Creating new OpenMediaVault packages file... 6. Remove old omv-extras apt list files... removed '/etc/apt/sources.list.d/omvextras.list' 7. Adding omv-extras repo and key... 8. Updating apt... Get:1 file:/var/cache/openmediavault/archives InRelease Ign:1 file:/var/cache/openmediavault/archives InRelease Get:2 file:/var/cache/openmediavault/archives Release Ign:2 file:/var/cache/openmediavault/archives Release Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:6 http://httpredir.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:7 http://deb.debian.org/debian bookworm InRelease [151 kB] Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:8 http://security.debian.org bookworm-security InRelease [48.0 kB] Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:9 http://packages.openmediavault.org/public sandworm InRelease [12.8 kB] Get:3 file:/var/cache/openmediavault/archives Packages Ign:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:3 file:/var/cache/openmediavault/archives Packages Get:4 file:/var/cache/openmediavault/archives Contents (deb) Ign:4 file:/var/cache/openmediavault/archives Contents (deb) Get:5 file:/var/cache/openmediavault/archives Contents (deb) Ign:5 file:/var/cache/openmediavault/archives Contents (deb) Get:10 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB] Get:11 http://deb.debian.org/debian bookworm-backports InRelease [56.5 kB] Get:12 http://security.debian.org/debian-security bookworm-security InRelease [48.0 kB] Get:13 https://openmediavault.github.io/packages sandworm InRelease [12.8 kB] Get:14 https://openmediavault-plugin-developers.github.io/packages/debian sandworm InRelease [3936 B] Get:15 http://security.debian.org bookworm-security/main arm64 Packages [141 kB] Get:16 http://deb.debian.org/debian bookworm/main arm64 Packages [11.9 MB] Get:17 http://deb.debian.org/debian bookworm/main all Contents (deb) [33.0 MB] Get:18 http://security.debian.org/debian-security bookworm-security/contrib Sources [856 B] Get:19 http://security.debian.org/debian-security bookworm-security/main Sources [82.8 kB] Get:20 http://security.debian.org/debian-security bookworm-security/non-free-firmware Sources [796 B] Get:21 http://security.debian.org/debian-security bookworm-security/main arm64 Packages [141 kB] Get:22 http://httpredir.debian.org/debian bookworm-backports/main arm64 Packages [178 kB] Get:23 http://httpredir.debian.org/debian bookworm-backports/main arm64 Contents (deb) [771 kB] Get:24 http://httpredir.debian.org/debian bookworm-backports/main all Contents (deb) [3830 kB] Get:25 https://openmediavault.github.io/packages sandworm/main arm64 Packages [7669 B] Get:26 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 Packages [8689 B] Get:27 http://httpredir.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:28 http://httpredir.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:29 http://httpredir.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:30 http://httpredir.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:31 http://httpredir.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Get:32 http://packages.openmediavault.org/public sandworm/main arm64 Packages [7669 B] Get:33 http://deb.debian.org/debian bookworm/main arm64 Contents (deb) [11.2 MB] Get:34 http://deb.debian.org/debian bookworm/contrib arm64 Packages [54.7 kB] Get:35 http://deb.debian.org/debian bookworm/contrib all Contents (deb) [98.6 kB] Get:36 http://deb.debian.org/debian bookworm/contrib arm64 Contents (deb) [37.7 kB] Get:37 http://deb.debian.org/debian bookworm/non-free arm64 Packages [94.4 kB] Get:38 http://deb.debian.org/debian bookworm/non-free all Contents (deb) [839 kB] Get:39 http://deb.debian.org/debian bookworm/non-free arm64 Contents (deb) [43.4 kB] Get:40 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Packages [6401 B] Get:41 http://deb.debian.org/debian bookworm/non-free-firmware arm64 Contents (deb) [243 B] Get:42 http://deb.debian.org/debian bookworm/non-free-firmware all Contents (deb) [16.9 kB] Get:43 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [12.5 kB] Get:44 http://deb.debian.org/debian bookworm-updates/main all Contents (deb) [222 kB] Get:45 http://deb.debian.org/debian bookworm-updates/main arm64 Contents (deb) [253 kB] Get:46 http://deb.debian.org/debian bookworm-updates/contrib arm64 Packages [768 B] Get:47 http://deb.debian.org/debian bookworm-updates/contrib arm64 Contents (deb) [222 B] Get:48 http://deb.debian.org/debian bookworm-updates/non-free arm64 Packages [12.0 kB] Get:49 http://deb.debian.org/debian bookworm-updates/non-free arm64 Contents (deb) [14.9 kB] Get:50 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Packages [616 B] Get:51 http://deb.debian.org/debian bookworm-updates/non-free-firmware arm64 Contents (deb) [243 B] Get:52 http://deb.debian.org/debian bookworm-backports/main arm64 Packages [178 kB] Get:53 http://deb.debian.org/debian bookworm-backports/main arm64 Contents (deb) [771 kB] Get:54 http://deb.debian.org/debian bookworm-backports/main all Contents (deb) [3830 kB] Get:55 http://deb.debian.org/debian bookworm-backports/contrib arm64 Packages [4704 B] Get:56 http://deb.debian.org/debian bookworm-backports/contrib all Contents (deb) [20.0 kB] Get:57 http://deb.debian.org/debian bookworm-backports/contrib arm64 Contents (deb) [17.0 kB] Get:58 http://deb.debian.org/debian bookworm-backports/non-free arm64 Packages [1288 B] Get:59 http://deb.debian.org/debian bookworm-backports/non-free all Contents (deb) [31.8 kB] Fetched 68.4 MB in 13s (5306 kB/s) Reading package lists... 9. Saving current package list... 10. Updating plugin index... Creating index of upgradeable packages ... Creating index of plugins ... armbian-ramlog.service loaded active exited Armbian memory supported logging ● armbian-ramlog.target not-found inactive dead armbian-ramlog.target Removed "/etc/systemd/system/sysinit.target.wants/armbian-ramlog.service". armbian-zram-config.service loaded active exited Armbian ZRAM config Removed "/etc/systemd/system/sysinit.target.wants/armbian-zram-config.service". [2024-02-28 11:23:07+0100] [omvinstall] Install folder2ram... Reading package lists... Building dependency tree... Reading state information... The following additional packages will be installed: gawk libsigsegv2 Suggested packages: gawk-doc The following NEW packages will be installed: folder2ram gawk libsigsegv2 0 upgraded, 3 newly installed, 0 to remove and 0 not upgraded. Need to get 691 kB of archives. After this operation, 3837 kB of additional disk space will be used. Get:1 http://deb.debian.org/debian bookworm/main arm64 libsigsegv2 arm64 2.14-1 [37.0 kB] Get:2 http://deb.debian.org/debian bookworm/main arm64 gawk arm64 1:5.2.1-2 [640 kB] Get:3 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 folder2ram all 0.3.5 [14.0 kB] Fetched 691 kB in 0s (3669 kB/s) Selecting previously unselected package libsigsegv2:arm64. (Reading database ... 84627 files and directories currently installed.) Preparing to unpack .../libsigsegv2_2.14-1_arm64.deb ... Unpacking libsigsegv2:arm64 (2.14-1) ... Setting up libsigsegv2:arm64 (2.14-1) ... Selecting previously unselected package gawk. (Reading database ... 84636 files and directories currently installed.) Preparing to unpack .../gawk_1%3a5.2.1-2_arm64.deb ... Unpacking gawk (1:5.2.1-2) ... Selecting previously unselected package folder2ram. Preparing to unpack .../folder2ram_0.3.5_all.deb ... Unpacking folder2ram (0.3.5) ... Setting up gawk (1:5.2.1-2) ... Setting up folder2ram (0.3.5) ... Processing triggers for libc-bin (2.36-9+deb12u4) ... Processing triggers for man-db (2.11.2-2) ... [2024-02-28 11:23:24+0100] [omvinstall] Installed folder2ram. [2024-02-28 11:23:24+0100] [omvinstall] Install flashmemory plugin... Reading package lists... Building dependency tree... Reading state information... The following NEW packages will be installed: openmediavault-flashmemory 0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. Need to get 5156 B of archives. After this operation, 36.9 kB of additional disk space will be used. Get:1 https://openmediavault-plugin-developers.github.io/packages/debian sandworm/main arm64 openmediavault-flashmemory all 7.0 [5156 B] Fetched 5156 B in 0s (22.7 kB/s) Selecting previously unselected package openmediavault-flashmemory. (Reading database ... 84831 files and directories currently installed.) Preparing to unpack .../openmediavault-flashmemory_7.0_all.deb ... Unpacking openmediavault-flashmemory (7.0) ... Setting up openmediavault-flashmemory (7.0) ... helios64: ---------- ID: configure_rrd_dir Function: file.directory Name: /var/lib/openmediavault/rrd Result: True Comment: The directory /var/lib/openmediavault/rrd is in the correct state Started: 11:23:43.297413 Duration: 16.127 ms Changes: ---------- ID: configure_samba_dir Function: file.directory Name: /var/cache/samba Result: True Comment: The directory /var/cache/samba is in the correct state Started: 11:23:43.313888 Duration: 2.739 ms Changes: ---------- ID: configure_folder2ram_dir Function: file.directory Name: /etc/folder2ram Result: True Comment: The directory /etc/folder2ram is in the correct state Started: 11:23:43.316940 Duration: 2.536 ms Changes: ---------- ID: configure_flashmemory Function: file.managed Name: /etc/folder2ram/folder2ram.conf Result: True Comment: File /etc/folder2ram/folder2ram.conf updated Started: 11:23:43.319798 Duration: 7.675 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: folder2ram_enable_systemd Function: cmd.run Name: /sbin/folder2ram -enablesystemd Result: True Comment: Command "/sbin/folder2ram -enablesystemd" run Started: 11:23:43.329620 Duration: 2343.757 ms Changes: ---------- pid: 27917 retcode: 0 stderr: Created symlink /etc/systemd/system/basic.target.wants/folder2ram_startup.service → /usr/lib/systemd/system/folder2ram_startup.service. Created symlink /etc/systemd/system/multi-user.target.wants/folder2ram_shutdown.service → /usr/lib/systemd/system/folder2ram_shutdown.service. stdout: systemd services enabled but not started, it is recommended to reboot for a cleaner transition to tmpfs folders otherwise you can start them now (both services are needed) with systemctl start folder2ram_startup.service systemctl start folder2ram_shutdown.service ---------- ID: folder2ram_mountall Function: cmd.run Name: /sbin/folder2ram -mountall Result: True Comment: Command "/sbin/folder2ram -mountall" run Started: 11:23:45.673748 Duration: 1066.144 ms Changes: ---------- pid: 27975 retcode: 0 stderr: stdout: will now start all mountpoints start /var/log start /var/tmp start /var/lib/openmediavault/rrd start /var/spool start /var/lib/rrdcached start /var/lib/monit start /var/cache/samba ---------- ID: systemd-reload Function: cmd.run Name: systemctl daemon-reload Result: True Comment: Command "systemctl daemon-reload" run Started: 11:23:46.740666 Duration: 1170.715 ms Changes: ---------- pid: 28252 retcode: 0 stderr: stdout: Summary for helios64 ------------ Succeeded: 7 (changed=4) Failed: 0 ------------ Total states run: 7 Total run time: 4.610 s Processing triggers for openmediavault (7.0-32) ... Updating workbench configuration files ... Restarting engine daemon ... [2024-02-28 11:24:02+0100] [omvinstall] Installed flashmemory plugin. [2024-02-28 11:24:02+0100] [omvinstall] Disabling data collection ... {"enable":false} null bash: line 491: warning: command substitution: ignored null byte in input helios64: ---------- ID: run_state_patch Function: salt.state Result: True Comment: States ran successfully. No changes made to helios64. Started: 11:25:19.122578 Duration: 489.563 ms Changes: ---------- ID: sync_runners Function: salt.runner Name: saltutil.sync_runners Result: True Comment: Runner function 'saltutil.sync_runners' executed. Started: 11:25:19.612501 Duration: 4281.82 ms Changes: ---------- return: ---------- ID: sync_modules Function: salt.runner Name: saltutil.sync_modules Result: True Comment: Runner function 'saltutil.sync_modules' executed. Started: 11:25:23.894954 Duration: 11165.586 ms Changes: ---------- return: ---------- ID: sync_states Function: salt.runner Name: saltutil.sync_states Result: True Comment: Runner function 'saltutil.sync_states' executed. Started: 11:25:35.061473 Duration: 4159.561 ms Changes: ---------- return: ---------- ID: populate_pillar Function: salt.runner Name: omv.populate_pillar Result: True Comment: Runner function 'omv.populate_pillar' executed. Started: 11:25:39.222756 Duration: 12217.2 ms Changes: ---------- return: True ---------- ID: run_state_sync Function: salt.state Result: True Comment: States ran successfully. Updating helios64. Started: 11:25:51.440435 Duration: 4431.883 ms Changes: helios64: ---------- ID: clear_cache Function: module.run Result: True Comment: saltutil.clear_cache: True Started: 11:25:52.165999 Duration: 40.076 ms Changes: ---------- saltutil.clear_cache: True ---------- ID: sync_grains Function: saltutil.sync_grains Result: True Comment: Updated grains. Started: 11:25:52.208218 Duration: 1426.132 ms Changes: ---------- grains: - grains.omv ---------- ID: sync_states Function: saltutil.sync_states Result: True Comment: Updated states. Started: 11:25:53.635051 Duration: 1114.974 ms Changes: ---------- states: - states.omv_dpkg ---------- ID: sync_modules Function: saltutil.sync_modules Result: True Comment: Updated modules. Started: 11:25:54.750308 Duration: 1119.855 ms Changes: ---------- modules: - modules.omv_conf - modules.omv_utils Summary for helios64 ------------ Succeeded: 4 (changed=4) Failed: 0 ------------ Total states run: 4 Total run time: 3.701 s Summary for helios64 ------------ Succeeded: 6 (changed=5) Failed: 0 ------------ Total states run: 6 Total run time: 36.746 s helios64: ---------- ID: cleanup_monit_conf_dir Function: module.run Result: True Comment: file.find: ['/etc/monit/conf.d/openmediavault-engined.conf', '/etc/monit/conf.d/openmediavault-filesystem.conf', '/etc/monit/conf.d/openmediavault-nginx.conf', '/etc/monit/conf.d/openmediavault-phpfpm.conf', '/etc/monit/conf.d/openmediavault-system.conf'] Started: 11:26:09.507876 Duration: 4.192 ms Changes: ---------- file.find: - /etc/monit/conf.d/openmediavault-engined.conf - /etc/monit/conf.d/openmediavault-filesystem.conf - /etc/monit/conf.d/openmediavault-nginx.conf - /etc/monit/conf.d/openmediavault-phpfpm.conf - /etc/monit/conf.d/openmediavault-system.conf ---------- ID: configure_default_monit Function: file.managed Name: /etc/default/monit Result: True Comment: File /etc/default/monit is in the correct state Started: 11:26:09.517143 Duration: 164.601 ms Changes: ---------- ID: divert_default_monit Function: omv_dpkg.divert_add Name: /etc/default/monit Result: True Comment: Leaving 'local diversion of /etc/default/monit to /etc/default/monit.distrib' Started: 11:26:09.684492 Duration: 38.801 ms Changes: ---------- ID: configure_monit_monitrc Function: file.managed Name: /etc/monit/monitrc Result: True Comment: File /etc/monit/monitrc is in the correct state Started: 11:26:09.723695 Duration: 359.038 ms Changes: ---------- ID: divert_monit_monitrc Function: omv_dpkg.divert_add Name: /etc/monit/monitrc Result: True Comment: Leaving 'local diversion of /etc/monit/monitrc to /etc/monit/monitrc.distrib' Started: 11:26:10.083180 Duration: 41.799 ms Changes: ---------- ID: configure_monit_filesystem_service Function: file.managed Name: /etc/monit/conf.d/openmediavault-filesystem.conf Result: True Comment: File /etc/monit/conf.d/openmediavault-filesystem.conf updated Started: 11:26:10.125429 Duration: 375.194 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_monit_nginx_service Function: file.managed Name: /etc/monit/conf.d/openmediavault-nginx.conf Result: True Comment: File /etc/monit/conf.d/openmediavault-nginx.conf updated Started: 11:26:10.500977 Duration: 371.953 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_monit_omv-engined_service Function: file.managed Name: /etc/monit/conf.d/openmediavault-engined.conf Result: True Comment: File /etc/monit/conf.d/openmediavault-engined.conf updated Started: 11:26:10.873361 Duration: 366.445 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_monit_php-fpm_service Function: file.managed Name: /etc/monit/conf.d/openmediavault-phpfpm.conf Result: True Comment: File /etc/monit/conf.d/openmediavault-phpfpm.conf updated Started: 11:26:11.240159 Duration: 340.76 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_monit_system_service Function: file.managed Name: /etc/monit/conf.d/openmediavault-system.conf Result: True Comment: File /etc/monit/conf.d/openmediavault-system.conf updated Started: 11:26:11.581247 Duration: 387.687 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: test_monit_config Function: cmd.run Name: monit -t Result: True Comment: Command "monit -t" run Started: 11:26:11.971136 Duration: 44.27 ms Changes: ---------- pid: 29180 retcode: 0 stderr: stdout: Control file syntax OK ---------- ID: reload_monit_service Function: service.running Name: monit Result: True Comment: Service reloaded Started: 11:26:15.116783 Duration: 503.381 ms Changes: ---------- monit: True ---------- ID: configure_phpfpm_webgui Function: file.managed Name: /etc/php/8.2/fpm/pool.d/openmediavault-webgui.conf Result: True Comment: File /etc/php/8.2/fpm/pool.d/openmediavault-webgui.conf is in the correct state Started: 11:26:15.620601 Duration: 179.96 ms Changes: ---------- ID: test_phpfpm_service_config Function: cmd.run Name: php-fpm8.2 --test Result: True Comment: Command "php-fpm8.2 --test" run Started: 11:26:15.800909 Duration: 110.826 ms Changes: ---------- pid: 29199 retcode: 0 stderr: [28-Feb-2024 11:26:15] NOTICE: configuration file /etc/php/8.2/fpm/php-fpm.conf test is successful stdout: ---------- ID: restart_phpfpm_service Function: service.running Name: php8.2-fpm Result: True Comment: The service php8.2-fpm is already running Started: 11:26:15.913888 Duration: 128.991 ms Changes: ---------- ID: monitor_phpfpm_service Function: module.run Result: True Comment: monit.monitor: True Started: 11:26:16.046823 Duration: 39.92 ms Changes: ---------- monit.monitor: True ---------- ID: configure_samba_global Function: file.managed Name: /etc/samba/smb.conf Result: True Comment: File /etc/samba/smb.conf updated Started: 11:26:16.087491 Duration: 714.697 ms Changes: ---------- diff: --- +++ @@ -1,236 +1,40 @@ -# -# Sample configuration file for the Samba suite for Debian GNU/Linux. -# -# -# This is the main Samba configuration file. You should read the -# smb.conf(5) manual page in order to understand the options listed -# here. Samba has a huge number of configurable options most of which -# are not shown in this example -# -# Some options that are often worth tuning have been included as -# commented-out examples in this file. -# - When such options are commented with ";", the proposed setting -# differs from the default Samba behaviour -# - When commented with "#", the proposed setting is the default -# behaviour of Samba but the option is considered important -# enough to be mentioned here -# -# NOTE: Whenever you modify this file you should run the command -# "testparm" to check that you have not made any basic syntactic -# errors. - +# This file is auto-generated by openmediavault (https://www.openmediavault.org) +# WARNING: Do not edit this file, your changes will get lost. #======================= Global Settings ======================= - [global] - -## Browsing/Identification ### - -# Change this to the workgroup/NT-domain name your Samba server will part of - workgroup = WORKGROUP - -#### Networking #### - -# The specific set of interfaces / networks to bind to -# This can be either the interface name or an IP address/netmask; -# interface names are normally preferred -; interfaces = 127.0.0.0/8 eth0 - -# Only bind to the named interfaces and/or networks; you must use the -# 'interfaces' option above to use this. -# It is recommended that you enable this feature if your Samba machine is -# not protected by a firewall or is a firewall itself. However, this -# option cannot handle dynamic or non-broadcast interfaces correctly. -; bind interfaces only = yes - - - -#### Debugging/Accounting #### - -# This tells Samba to use a separate log file for each machine -# that connects - log file = /var/log/samba/log.%m - -# Cap the size of the individual log files (in KiB). - max log size = 1000 - -# We want Samba to only log to /var/log/samba/log.{smbd,nmbd}. -# Append syslog@1 if you want important messages to be sent to syslog too. - logging = file - -# Do something sensible when Samba crashes: mail the admin a backtrace - panic action = /usr/share/samba/panic-action %d - - -####### Authentication ####### - -# Server role. Defines in which mode Samba will operate. Possible -# values are "standalone server", "member server", "classic primary -# domain controller", "classic backup domain controller", "active -# directory domain controller". -# -# Most people will want "standalone server" or "member server". -# Running as "active directory domain controller" will require first -# running "samba-tool domain provision" to wipe databases and create a -# new domain. - server role = standalone server - - obey pam restrictions = yes - -# This boolean parameter controls whether Samba attempts to sync the Unix -# password with the SMB password when the encrypted SMB password in the -# passdb is changed. - unix password sync = yes - -# For Unix password sync to work on a Debian GNU/Linux system, the following -# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for -# sending the correct chat script for the passwd program in Debian Sarge). - passwd program = /usr/bin/passwd %u - passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* . - -# This boolean controls whether PAM will be used for password changes -# when requested by an SMB client instead of the program listed in -# 'passwd program'. The default is 'no'. - pam password change = yes - -# This option controls how unsuccessful authentication attempts are mapped -# to anonymous connections - map to guest = bad user - -########## Domains ########### - -# -# The following settings only takes effect if 'server role = classic -# primary domain controller', 'server role = classic backup domain controller' -# or 'domain logons' is set -# - -# It specifies the location of the user's -# profile directory from the client point of view) The following -# required a [profiles] share to be setup on the samba server (see -# below) -; logon path = \\%N\profiles\%U -# Another common choice is storing the profile in the user's home directory -# (this is Samba's default) -# logon path = \\%N\%U\profile - -# The following setting only takes effect if 'domain logons' is set -# It specifies the location of a user's home directory (from the client -# point of view) -; logon drive = H: -# logon home = \\%N\%U - -# The following setting only takes effect if 'domain logons' is set -# It specifies the script to run during logon. The script must be stored -# in the [netlogon] share -# NOTE: Must be store in 'DOS' file format convention -; logon script = logon.cmd - -# This allows Unix users to be created on the domain controller via the SAMR -# RPC pipe. The example command creates a user account with a disabled Unix -# password; please adapt to your needs -; add user script = /usr/sbin/useradd --create-home %u - -# This allows machine accounts to be created on the domain controller via the -# SAMR RPC pipe. -# The following assumes a "machines" group exists on the system -; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u - -# This allows Unix groups to be created on the domain controller via the SAMR -# RPC pipe. -; add group script = /usr/sbin/addgroup --force-badname %g - -############ Misc ############ - -# Using the following line enables you to customise your configuration -# on a per machine basis. The %m gets replaced with the netbios name -# of the machine that is connecting -; include = /home/samba/etc/smb.conf.%m - -# Some defaults for winbind (make sure you're not using the ranges -# for something else.) -; idmap config * : backend = tdb -; idmap config * : range = 3000-7999 -; idmap config YOURDOMAINHERE : backend = tdb -; idmap config YOURDOMAINHERE : range = 100000-999999 -; template shell = /bin/bash - -# Setup usershare options to enable non-root users to share folders -# with the net usershare command. - -# Maximum number of usershare. 0 means that usershare is disabled. -# usershare max shares = 100 - -# Allow users who've been granted usershare privileges to create -# public shares, not just authenticated ones - usershare allow guests = yes - -#======================= Share Definitions ======================= - -[homes] - comment = Home Directories - browseable = no - -# By default, the home directories are exported read-only. Change the -# next parameter to 'no' if you want to be able to write to them. - read only = yes - -# File creation mask is set to 0700 for security reasons. If you want to -# create files with group=rw permissions, set next parameter to 0775. - create mask = 0700 - -# Directory creation mask is set to 0700 for security reasons. If you want to -# create dirs. with group=rw permissions, set next parameter to 0775. - directory mask = 0700 - -# By default, \\server\username shares can be connected to by anyone -# with access to the samba server. -# The following parameter makes sure that only "username" can connect -# to \\server\username -# This might need tweaking when using external authentication schemes - valid users = %S - -# Un-comment the following and create the netlogon directory for Domain Logons -# (you need to configure Samba to act as a domain controller too.) -;[netlogon] -; comment = Network Logon Service -; path = /home/samba/netlogon -; guest ok = yes -; read only = yes - -# Un-comment the following and create the profiles directory to store -# users profiles (see the "logon path" option above) -# (you need to configure Samba to act as a domain controller too.) -# The path below should be writable by all users so that their -# profile directory may be created the first time they log on -;[profiles] -; comment = Users profiles -; path = /home/samba/profiles -; guest ok = no -; browseable = no -; create mask = 0600 -; directory mask = 0700 - -[printers] - comment = All Printers - browseable = no - path = /var/tmp - printable = yes - guest ok = no - read only = yes - create mask = 0700 - -# Windows clients look for this share name as a source of downloadable -# printer drivers -[print$] - comment = Printer Drivers - path = /var/lib/samba/printers - browseable = yes - read only = yes - guest ok = no -# Uncomment to allow remote administration of Windows print drivers. -# You may need to replace 'lpadmin' with the name of the group your -# admin users are members of. -# Please note that you also need to set appropriate Unix permissions -# to the drivers directory for these users to have write rights in it -; write list = root, @lpadmin - +workgroup = WORKGROUP +server string = %h server +dns proxy = no +log level = 0 +log file = /var/log/samba/log.%m +max log size = 1000 +logging = syslog +panic action = /usr/share/samba/panic-action %d +passdb backend = tdbsam +obey pam restrictions = no +unix password sync = no +passwd program = /usr/bin/passwd %u +passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* . +pam password change = yes +socket options = TCP_NODELAY IPTOS_LOWDELAY +guest account = nobody +load printers = no +disable spoolss = yes +printing = bsd +printcap name = /dev/null +unix extensions = yes +wide links = no +create mask = 0777 +directory mask = 0777 +use sendfile = yes +aio read size = 1 +aio write size = 1 +time server = no +wins support = no +disable netbios = yes +multicast dns register = no +server min protocol = SMB2_02 +# Special configuration for Apple's Time Machine +fruit:aapl = yes +fruit:copyfile = yes +fruit:nfs_aces = no ---------- ID: configure_samba_shares Function: file.append Name: /etc/samba/smb.conf Result: True Comment: Appended 1 lines Started: 11:26:16.802525 Duration: 193.36 ms Changes: ---------- diff: --- +++ @@ -38,3 +38,4 @@ fruit:aapl = yes fruit:copyfile = yes fruit:nfs_aces = no +#======================= Share Definitions ======================= ---------- ID: configure_samba_recyclebin_cron Function: file.managed Name: /etc/cron.daily/openmediavault-samba-recycle Result: True Comment: File /etc/cron.daily/openmediavault-samba-recycle updated Started: 11:26:16.996209 Duration: 6.317 ms Changes: ---------- diff: New file mode: 0750 ---------- ID: remove_samba_recyclebin_cron_scripts Function: module.run Result: True Comment: file.find: [] Started: 11:26:17.002862 Duration: 3.145 ms Changes: ---------- file.find: ---------- ID: configure_default_wsdd Function: file.managed Name: /etc/default/wsdd Result: True Comment: File /etc/default/wsdd updated Started: 11:26:17.006330 Duration: 159.897 ms Changes: ---------- diff: --- +++ @@ -1,6 +1,3 @@ -# -# Defaults file for wsdd -# -# Useful args here are -i eth0 -6 etc -# Consult wsdd(8) man page -WSDD_PARAMS="" +# This file is auto-generated by openmediavault (https://www.openmediavault.org) +# WARNING: Do not edit this file, your changes will get lost. +WSDD_PARAMS="--workgroup='WORKGROUP' " ---------- ID: divert_default_wsdd Function: omv_dpkg.divert_add Name: /etc/default/wsdd Result: True Comment: Adding 'local diversion of /etc/default/wsdd to /etc/default/wsdd.distrib' Started: 11:26:17.166562 Duration: 71.92 ms Changes: ---------- ID: divert_samba_smb_config Function: omv_dpkg.divert_add Name: /etc/samba/smb.conf Result: True Comment: Adding 'local diversion of /etc/samba/smb.conf to /etc/samba/smb.conf.distrib' Started: 11:26:17.239056 Duration: 52.366 ms Changes: ---------- ID: stop_samba_service_smbd Function: service.dead Name: smbd Result: True Comment: The service smbd is already dead Started: 11:26:17.292024 Duration: 165.826 ms Changes: ---------- ID: stop_samba_service_nmbd Function: service.dead Name: nmbd Result: True Comment: The service nmbd is already dead Started: 11:26:17.458554 Duration: 177.863 ms Changes: ---------- ID: stop_wsdd_service Function: service.dead Name: wsdd Result: True Comment: Service wsdd has been disabled, and is in the desired state Started: 11:26:17.637134 Duration: 1662.031 ms Changes: ---------- wsdd: True ---------- ID: configure_default_rrdcached Function: file.managed Name: /etc/default/rrdcached Result: True Comment: File /etc/default/rrdcached is in the correct state Started: 11:26:19.300221 Duration: 213.702 ms Changes: ---------- ID: divert_default_rrdcached Function: omv_dpkg.divert_add Name: /etc/default/rrdcached Result: True Comment: Leaving 'local diversion of /etc/default/rrdcached to /etc/default/rrdcached.distrib' Started: 11:26:19.514267 Duration: 43.62 ms Changes: ---------- ID: unmonitor_rrdcached_service Function: cmd.run Name: monit unmonitor rrdcached || true Result: True Comment: Command "monit unmonitor rrdcached || true" run Started: 11:26:19.559704 Duration: 49.418 ms Changes: ---------- pid: 29244 retcode: 0 stderr: There is no service named "rrdcached" stdout: ---------- ID: stop_rrdcached_service Function: service.dead Name: rrdcached Result: True Comment: The service rrdcached is already dead Started: 11:26:19.609705 Duration: 178.704 ms Changes: ---------- ID: configure_timezone Function: file.managed Name: /etc/timezone Result: True Comment: File /etc/timezone is in the correct state Started: 11:26:19.789469 Duration: 221.277 ms Changes: ---------- ID: set_timezone Function: timezone.system Name: Europe/Berlin Result: True Comment: Timezone Europe/Berlin already set, UTC already set to Europe/Berlin Started: 11:26:20.012537 Duration: 272.195 ms Changes: ---------- ID: configure_rrd_dir Function: file.directory Name: /var/lib/openmediavault/rrd Result: True Comment: The directory /var/lib/openmediavault/rrd is in the correct state Started: 11:26:20.285066 Duration: 2.6 ms Changes: ---------- ID: configure_samba_dir Function: file.directory Name: /var/cache/samba Result: True Comment: The directory /var/cache/samba is in the correct state Started: 11:26:20.287964 Duration: 2.384 ms Changes: ---------- ID: configure_folder2ram_dir Function: file.directory Name: /etc/folder2ram Result: True Comment: The directory /etc/folder2ram is in the correct state Started: 11:26:20.290628 Duration: 2.492 ms Changes: ---------- ID: configure_flashmemory Function: file.managed Name: /etc/folder2ram/folder2ram.conf Result: True Comment: File /etc/folder2ram/folder2ram.conf is in the correct state Started: 11:26:20.293408 Duration: 134.092 ms Changes: ---------- ID: folder2ram_enable_systemd Function: cmd.run Name: /sbin/folder2ram -enablesystemd Result: True Comment: Command "/sbin/folder2ram -enablesystemd" run Started: 11:26:20.427843 Duration: 2420.376 ms Changes: ---------- pid: 29255 retcode: 0 stderr: stdout: systemd services enabled but not started, it is recommended to reboot for a cleaner transition to tmpfs folders otherwise you can start them now (both services are needed) with systemctl start folder2ram_startup.service systemctl start folder2ram_shutdown.service ---------- ID: folder2ram_mountall Function: cmd.run Name: /sbin/folder2ram -mountall Result: True Comment: Command "/sbin/folder2ram -mountall" run Started: 11:26:22.848560 Duration: 560.82 ms Changes: ---------- pid: 29313 retcode: 0 stderr: stdout: will now start all mountpoints start /var/log /var/log already mounted start /var/tmp /var/tmp already mounted start /var/lib/openmediavault/rrd /var/lib/openmediavault/rrd already mounted start /var/spool /var/spool already mounted start /var/lib/rrdcached /var/lib/rrdcached already mounted start /var/lib/monit /var/lib/monit already mounted start /var/cache/samba /var/cache/samba already mounted ---------- ID: systemd-reload Function: cmd.run Name: systemctl daemon-reload Result: True Comment: Command "systemctl daemon-reload" run Started: 11:26:23.410753 Duration: 1154.378 ms Changes: ---------- pid: 29540 retcode: 0 stderr: stdout: ---------- ID: configure_default_cpufrequtils Function: file.managed Name: /etc/default/cpufrequtils Result: True Comment: File /etc/default/cpufrequtils updated Started: 11:26:24.566516 Duration: 596.544 ms Changes: ---------- diff: --- +++ @@ -1,4 +1,4 @@ ENABLE="true" -GOVERNOR="schedutil" -MAX_SPEED="0" -MIN_SPEED="0" +GOVERNOR="ondemand" +MAX_SPEED="1200000" +MIN_SPEED="408000" ---------- ID: configure_default_loadcpufreq Function: file.managed Name: /etc/default/loadcpufreq Result: True Comment: File /etc/default/loadcpufreq is in the correct state Started: 11:26:25.163413 Duration: 363.532 ms Changes: ---------- ID: start_cpufrequtils_service Function: service.running Name: cpufrequtils Result: True Comment: Service restarted Started: 11:26:25.659688 Duration: 544.297 ms Changes: ---------- cpufrequtils: True ---------- ID: start_loadcpufreq_service Function: service.running Name: loadcpufreq Result: True Comment: The service loadcpufreq is already running Started: 11:26:26.207535 Duration: 148.741 ms Changes: ---------- ID: configure_apt_sources_list_openmediavault Function: file.managed Name: /etc/apt/sources.list.d/openmediavault.list Result: True Comment: File /etc/apt/sources.list.d/openmediavault.list is in the correct state Started: 11:26:26.357082 Duration: 587.623 ms Changes: ---------- ID: remove_apt_proxy Function: file.absent Name: /etc/apt/apt.conf.d/99openmediavault-proxy Result: True Comment: File /etc/apt/apt.conf.d/99openmediavault-proxy is not present Started: 11:26:26.945135 Duration: 2.071 ms Changes: ---------- ID: configure_apt_pref_kernel_backports Function: file.managed Name: /etc/apt/preferences.d/openmediavault-kernel-backports.pref Result: True Comment: File /etc/apt/preferences.d/openmediavault-kernel-backports.pref is in the correct state Started: 11:26:26.947585 Duration: 522.876 ms Changes: ---------- ID: configure_apt_sources_list_kernel_backports Function: file.managed Name: /etc/apt/sources.list.d/openmediavault-kernel-backports.list Result: True Comment: File /etc/apt/sources.list.d/openmediavault-kernel-backports.list is in the correct state Started: 11:26:27.470948 Duration: 530.545 ms Changes: ---------- ID: remove_apt_sources_list_omv_security_obsolete Function: file.absent Name: /etc/apt/sources.list.d/openmediavault-debian-security.list Result: True Comment: File /etc/apt/sources.list.d/openmediavault-debian-security.list is not present Started: 11:26:28.001925 Duration: 2.207 ms Changes: ---------- ID: remove_apt_sources_list_security_0 Function: file.line Name: /etc/apt/sources.list.d/openmediavault-os-security.list Result: True Comment: Changes were made Started: 11:26:28.004496 Duration: 7.241 ms Changes: ---------- diff: --- +++ @@ -1,2 +1 @@ -deb [signed-by=/usr/share/keyrings/debian-archive-bookworm-security-automatic.gpg] http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware deb-src [signed-by=/usr/share/keyrings/debian-archive-bookworm-security-automatic.gpg] http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware ---------- ID: remove_apt_sources_list_security_1 Function: file.line Name: /etc/apt/sources.list.d/openmediavault-os-security.list Result: True Comment: Changes were made Started: 11:26:28.012175 Duration: 6.528 ms Changes: ---------- diff: --- +++ @@ -1 +0,0 @@ -deb-src [signed-by=/usr/share/keyrings/debian-archive-bookworm-security-automatic.gpg] http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware ---------- ID: configure_apt_sources_list_os_security Function: file.managed Name: /etc/apt/sources.list.d/openmediavault-os-security.list Result: True Comment: File /etc/apt/sources.list.d/openmediavault-os-security.list updated Started: 11:26:28.019216 Duration: 757.317 ms Changes: ---------- diff: --- +++ @@ -0,0 +1,2 @@ +deb [signed-by=/usr/share/keyrings/debian-archive-bookworm-security-automatic.gpg] http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware +deb-src [signed-by=/usr/share/keyrings/debian-archive-bookworm-security-automatic.gpg] http://security.debian.org/debian-security bookworm-security main contrib non-free non-free-firmware ---------- ID: remove_cdrom_apt_sources_list Function: file.line Name: /etc/apt/sources.list Result: True Comment: No changes needed to be made Started: 11:26:28.776965 Duration: 4.588 ms Changes: ---------- ID: configure_watchdog_systemd Function: file.managed Name: /etc/systemd/system.conf.d/openmediavault-watchdog.conf Result: True Comment: File /etc/systemd/system.conf.d/openmediavault-watchdog.conf is in the correct state Started: 11:26:28.781967 Duration: 187.784 ms Changes: ---------- ID: configure_watchdog_module Function: file.managed Name: /etc/modules-load.d/openmediavault-watchdog.conf Result: True Comment: File /etc/modules-load.d/openmediavault-watchdog.conf is in the correct state Started: 11:26:28.970188 Duration: 224.184 ms Changes: ---------- ID: restart_systemd_modules_load_service Function: service.running Name: systemd-modules-load Result: True Comment: The service systemd-modules-load is already running Started: 11:26:29.196235 Duration: 155.062 ms Changes: ---------- ID: watchdog_systemctl_daemon_reload Function: module.run Result: True Comment: service.systemctl_reload: True Started: 11:26:29.352027 Duration: 1483.649 ms Changes: ---------- service.systemctl_reload: True ---------- ID: configure_nginx_site_webgui Function: file.managed Name: /etc/nginx/sites-available/openmediavault-webgui Result: True Comment: File /etc/nginx/sites-available/openmediavault-webgui is in the correct state Started: 11:26:30.836491 Duration: 608.756 ms Changes: ---------- ID: configure_nginx_security Function: file.managed Name: /etc/nginx/openmediavault-webgui.d/security.conf Result: True Comment: File /etc/nginx/openmediavault-webgui.d/security.conf is in the correct state Started: 11:26:31.445681 Duration: 548.616 ms Changes: ---------- ID: execute_nginx_ensite Function: cmd.run Name: nginx_ensite openmediavault-webgui Result: True Comment: Command "nginx_ensite openmediavault-webgui" run Started: 11:26:31.994726 Duration: 28.575 ms Changes: ---------- pid: 29629 retcode: 0 stderr: stdout: Site configuration file 'openmediavault-webgui' is already enabled. ---------- ID: test_nginx_service_config Function: cmd.run Name: nginx -t Result: True Comment: Command "nginx -t" run Started: 11:26:32.024032 Duration: 42.044 ms Changes: ---------- pid: 29630 retcode: 0 stderr: nginx: the configuration file /etc/nginx/nginx.conf syntax is ok nginx: configuration file /etc/nginx/nginx.conf test is successful stdout: ---------- ID: restart_nginx_service Function: service.running Name: nginx Result: True Comment: The service nginx is already running Started: 11:26:32.071600 Duration: 161.724 ms Changes: ---------- ID: monitor_nginx_service Function: module.run Result: True Comment: monit.monitor: True Started: 11:26:32.240237 Duration: 41.652 ms Changes: ---------- monit.monitor: True ---------- ID: configure_chrony Function: file.managed Name: /etc/chrony/chrony.conf Result: True Comment: File /etc/chrony/chrony.conf is in the correct state Started: 11:26:32.282548 Duration: 572.864 ms Changes: ---------- ID: start_chrony_service Function: service.running Name: chrony Result: True Comment: The service chrony is already running Started: 11:26:32.857154 Duration: 147.742 ms Changes: ---------- ID: disable_ssh_socket_activation Function: service.dead Name: ssh.socket Result: True Comment: The service ssh.socket is already dead Started: 11:26:33.005332 Duration: 183.744 ms Changes: ---------- ID: remove_ssh_authorized_keys Function: file.directory Name: /var/lib/openmediavault/ssh/authorized_keys Result: True Comment: The directory /var/lib/openmediavault/ssh/authorized_keys is in the correct state Started: 11:26:33.189716 Duration: 6.714 ms Changes: ---------- ID: configure_sshd_config Function: file.managed Name: /etc/ssh/sshd_config Result: True Comment: File /etc/ssh/sshd_config is in the correct state Started: 11:26:33.197039 Duration: 614.181 ms Changes: ---------- ID: divert_sshd_config Function: omv_dpkg.divert_add Name: /etc/ssh/sshd_config Result: True Comment: Leaving 'local diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.distrib' Started: 11:26:33.811677 Duration: 56.594 ms Changes: ---------- ID: create_sshd_runtime_dir Function: file.directory Name: /run/sshd Result: True Comment: The directory /run/sshd is in the correct state Started: 11:26:33.869004 Duration: 6.285 ms Changes: ---------- ID: test_sshd_config Function: cmd.run Name: sshd -t Result: True Comment: Command "sshd -t" run Started: 11:26:33.875976 Duration: 77.709 ms Changes: ---------- pid: 29644 retcode: 0 stderr: stdout: ---------- ID: start_ssh_service Function: service.running Name: ssh Result: True Comment: The service ssh is already running Started: 11:26:33.955578 Duration: 140.655 ms Changes: ---------- ID: remove_mkrrdgraph_cron_job Function: file.absent Name: /etc/cron.d/openmediavault-mkrrdgraph Result: True Comment: File /etc/cron.d/openmediavault-mkrrdgraph is not present Started: 11:26:34.096678 Duration: 1.906 ms Changes: ---------- ID: unmonitor_collectd_service Function: cmd.run Name: monit unmonitor collectd || true Result: True Comment: Command "monit unmonitor collectd || true" run Started: 11:26:34.098988 Duration: 49.769 ms Changes: ---------- pid: 29648 retcode: 0 stderr: There is no service named "collectd" stdout: ---------- ID: stop_collectd_service Function: service.dead Name: collectd Result: True Comment: The service collectd is already dead Started: 11:26:34.149466 Duration: 195.755 ms Changes: ---------- ID: cleanup_collectd_conf_dir Function: module.run Result: True Comment: file.find: ['/etc/collectd/collectd.conf.d/cpu.conf', '/etc/collectd/collectd.conf.d/df.conf', '/etc/collectd/collectd.conf.d/interface.conf', '/etc/collectd/collectd.conf.d/load.conf', '/etc/collectd/collectd.conf.d/memory.conf', '/etc/collectd/collectd.conf.d/rrdcached.conf', '/etc/collectd/collectd.conf.d/syslog.conf', '/etc/collectd/collectd.conf.d/unixsock.conf', '/etc/collectd/collectd.conf.d/uptime.conf'] Started: 11:26:34.345847 Duration: 9.425 ms Changes: ---------- file.find: - /etc/collectd/collectd.conf.d/cpu.conf - /etc/collectd/collectd.conf.d/df.conf - /etc/collectd/collectd.conf.d/interface.conf - /etc/collectd/collectd.conf.d/load.conf - /etc/collectd/collectd.conf.d/memory.conf - /etc/collectd/collectd.conf.d/rrdcached.conf - /etc/collectd/collectd.conf.d/syslog.conf - /etc/collectd/collectd.conf.d/unixsock.conf - /etc/collectd/collectd.conf.d/uptime.conf ---------- ID: configure_collectd_conf Function: file.managed Name: /etc/collectd/collectd.conf Result: True Comment: File /etc/collectd/collectd.conf is in the correct state Started: 11:26:34.355956 Duration: 547.712 ms Changes: ---------- ID: divert_collectd_conf Function: omv_dpkg.divert_add Name: /etc/collectd/collectd.conf Result: True Comment: Leaving 'local diversion of /etc/collectd/collectd.conf to /etc/collectd/collectd.conf.distrib' Started: 11:26:34.904103 Duration: 54.101 ms Changes: ---------- ID: configure_collectd_conf_cpu_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/cpu.conf Result: True Comment: File /etc/collectd/collectd.conf.d/cpu.conf updated Started: 11:26:34.958660 Duration: 7.946 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_df_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/df.conf Result: True Comment: File /etc/collectd/collectd.conf.d/df.conf updated Started: 11:26:34.967092 Duration: 520.512 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_collectd_conf_interface_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/interface.conf Result: True Comment: File /etc/collectd/collectd.conf.d/interface.conf updated Started: 11:26:35.488023 Duration: 519.624 ms Changes: ---------- diff: New file mode: 0644 ---------- ID: configure_collectd_conf_load_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/load.conf Result: True Comment: File /etc/collectd/collectd.conf.d/load.conf updated Started: 11:26:36.008069 Duration: 7.679 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_memory_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/memory.conf Result: True Comment: File /etc/collectd/collectd.conf.d/memory.conf updated Started: 11:26:36.016170 Duration: 7.713 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_rrdcached_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/rrdcached.conf Result: True Comment: File /etc/collectd/collectd.conf.d/rrdcached.conf updated Started: 11:26:36.024307 Duration: 7.707 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_syslog_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/syslog.conf Result: True Comment: File /etc/collectd/collectd.conf.d/syslog.conf updated Started: 11:26:36.032438 Duration: 7.584 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_unixsock_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/unixsock.conf Result: True Comment: File /etc/collectd/collectd.conf.d/unixsock.conf updated Started: 11:26:36.040439 Duration: 7.64 ms Changes: ---------- diff: New file ---------- ID: configure_collectd_conf_uptime_plugin Function: file.managed Name: /etc/collectd/collectd.conf.d/uptime.conf Result: True Comment: File /etc/collectd/collectd.conf.d/uptime.conf updated Started: 11:26:36.048507 Duration: 7.676 ms Changes: ---------- diff: New file Summary for helios64 ------------- Succeeded: 86 (changed=41) Failed: 0 ------------- Total states run: 86 Total run time: 23.237 s [2024-02-28 11:26:37+0100] [omvinstall] Add a cron job to make NAS processes more snappy and silence rsyslog [2024-02-28 11:26:37+0100] [omvinstall] Removing network-manager and dhcpcd5 ... Reading package lists... Building dependency tree... Reading state information... Package 'dhcpcd5' is not installed, so not removed The following packages will be REMOVED: libbluetooth3* libmm-glib0* libndp0* libnm0* libteamdctl0* network-manager* network-manager-openvpn* 0 upgraded, 0 newly installed, 7 to remove and 0 not upgraded. After this operation, 21.0 MB disk space will be freed. (Reading database ... 84842 files and directories currently installed.) Removing network-manager-openvpn (1.10.2-2) ... Removing network-manager (1.42.4-1) ... Removing libbluetooth3:arm64 (5.66-1+deb12u1) ... Removing libmm-glib0:arm64 (1.20.4-1) ... Removing libndp0:arm64 (1.8-1) ... Removing libnm0:arm64 (1.42.4-1) ... Removing libteamdctl0:arm64 (1.31-1) ... Processing triggers for man-db (2.11.2-2) ... Processing triggers for dbus (1.14.10-1~deb12u1) ... Processing triggers for libc-bin (2.36-9+deb12u4) ... (Reading database ... 84585 files and directories currently installed.) Purging configuration files for network-manager (1.42.4-1) ... Purging configuration files for network-manager-openvpn (1.10.2-2) ... [2024-02-28 11:27:08+0100] [omvinstall] Enable and start systemd-resolved ... [2024-02-28 11:27:09+0100] [omvinstall] Unblocking wifi with rfkill ... [2024-02-28 11:27:09+0100] [omvinstall] Adding end0 to openmedivault database ... [2024-02-28 11:27:10+0100] [omvinstall] Adding enx646266d00975 to openmedivault database ... [2024-02-28 11:27:11+0100] [omvinstall] IP address may change and you could lose connection if running this script via ssh. Edited February 28 by TDCroPower 0 Quote
Trillien Posted April 5 Posted April 5 Openmediavault 7 (sandworm) is now released. Using my Helios64 with Linux 6.6.8, I followed the instructions on https://github.com/OpenMediaVault-Plugin-Developers/installScript to install OMV7. First attempt failed during the update of linux image by initramfs. The device rebooted by itself. This was due to CPUfrequency parameters that were changed in between, probably by one of OMV necessary package. Previously were : $ cat /etc/default/cpufrequtils ENABLE="true" GOVERNOR="ondemand" MAX_SPEED="1800000" MIN_SPEED="408000" And were updated to : $ cat /etc/default/cpufrequtils ENABLE="true" GOVERNOR="schedutil" MAX_SPEED="0" MIN_SPEED="0" I changed back the governor to "ondemand" using armbian-config > System > CPU. $ sudo armbian-config Needed to clean the install with : $ sudo dpkg-reconfigure -a And lauch again the install script : $ sudo curl -sSL https://github.com/OpenMediaVault-Plugin-Developers/installScript/raw/master/install | sudo bash To be sure OMV is aligned with my CPUfrequency parameters, I checked : $ cat /etc/default/openmediavault ... OMV_CPUFREQUTILS_GOVERNOR="ondemand" OMV_CPUFREQUTILS_MINSPEED="408000" OMV_CPUFREQUTILS_MAXSPEED="1800000" Those parameters were collected by the install script from /etc/default/cpufrequtils : https://github.com/OpenMediaVault-Plugin-Developers/installScript/blob/master/install Be aware OMV remove ssh-users group from /etc/ssh/sshd_config. It still possible to ssh using root. $cat /etc/ssh/sshd_config ... AllowGroups root _ssh ... As sshd_config is now controlled by OMV and may be replaced unexpectedly, you should include your user in _ssh group $ sudo usermod -a -G _ssh youruser 0 Quote
TDCroPower Posted April 5 Author Posted April 5 @Trillien I recommend that you do not set the max frequency to 1800000, set it only to max 1200000. Only 2 of the 6 cores can reach this high frequency and this often leads to problems. It is unpleasant but so far there is no solution. But it is not so tragic with a NAS. But thank you for the instructions/tips, I'll give it a try. 0 Quote
TDCroPower Posted April 6 Author Posted April 6 @Trillien you can also see the CPU frequencies in the sbc check... CPU 1: Microarchitecture: Cortex-A53 Max Frequency: 1.416 GHz Cores: 4 cores Features: NEON,SHA1,SHA2,AES,CRC32 CPU 2: Microarchitecture: Cortex-A72 Max Frequency: 1.800 GHz Cores: 2 cores Features: NEON,SHA1,SHA2,AES,CRC32 0 Quote
TDCroPower Posted April 6 Author Posted April 6 (edited) @Trillien I have monitored the installation with the following command to see when the frequency is changed and then when it crashes. Command to monitor the cpufrequtil file... while [ 1 ]; do sleep 1; clear; tail /etc/default/cpufrequtils; done at this point the cpufrequtils file is changed to the 0 values... /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/grains/core.py:2711: DeprecationWarning: Use setlocale(), getencoding() and getlocale() instead ) = locale.getdefaultlocale() /usr/lib/python3/dist-packages/salt/utils/pycrypto.py:26: DeprecationWarning: 'crypt' is deprecated and slated for removal in Python 3.13 import crypt /usr/lib/python3/dist-packages/salt/modules/linux_shadow.py:21: DeprecationWarning: 'spwd' is deprecated and slated for removal in Python 3.13 import spwd Deploying service configurations ... <<<<< here !!! Processing system modifications ... <<<<< or here !!! and at this point the cpufrequtils file is changed back to its own values... - modules.omv_conf - modules.omv_utils Summary for helios64 ------------ Succeeded: 4 (changed=4) Failed: 0 ------------ Total states run: 4 Total run time: 3.700 s Summary for helios64 ------------ Succeeded: 6 (changed=5) Failed: 0 ------------ Total states run: 6 Total run time: 22.648 s and exactly then the helios64 crashes/reboots directly. I'll take a look at the script that is executed at this point and see if it can be deactivated. edit: ok the installation of omv changes the cpufrequtils file at this point of the script... line 337 - 343... _log "Installing openmediavault..." aptFlags="--yes --auto-remove --show-upgraded --allow-downgrades --allow-change-held-packages --no-install-recommends" apt-get ${aptFlags} install openmediavault 2>&1 | tee -a ${logfile} if [ ${PIPESTATUS[0]} -gt 0 ]; then _log "failed to install openmediavault package." exit 2 fi ... I'll go to the OMV forum and ask why this is done and whether it is really necessary, because changing the cpufrequtils without reboot kills the Helios! Here my OMV forum post: https://forum.openmediavault.org/index.php?thread/52156-omv-7-install-on-helios64-fails/ Edited April 6 by TDCroPower 0 Quote
TDCroPower Posted April 6 Author Posted April 6 (edited) @Trillien your command to clean up the install doesn't work... root@helios64:~# dpkg-reconfigure -a Unknown option: a Usage: dpkg-reconfigure [options] packages -u, --unseen-only Show only not yet seen questions. --default-priority Use default priority instead of low. --force Force reconfiguration of broken packages. --no-reload Do not reload templates. (Use with caution.) -f, --frontend Specify debconf frontend to use. -p, --priority Specify minimum priority question to show. --terse Enable terse mode. edit: The following command worked and then the script ran through without any problems... finally I have OMV 7 on the eMMC (boot) + SSD installation! dpkg-reconfigure openmediavault or do you perhaps mean the following command, which has at least the -a option... dpkg --configure -a Edited April 7 by TDCroPower 0 Quote
Trillien Posted April 7 Posted April 7 (edited) Sorry, I meant dpkg --configure -a I've got a theory on /etc/default/cpufrequtils change. Searching within openmediavault github repository for "Deploying Service Configurations ...", there is only one result : deb/openmediavault/debian/openmediavault.postinst According to openmediavault.postinst, the script echoes this message and runs omv-salt deploy run cpufrequtils 237 ######################################################################## 238 # Deploy various services when the package is installed the first time. 239 ######################################################################## 240 if [ -z "$2" ]; then 241 # Disable default nginx site. 242 nginx_dissite default || : 243 244 # Deploy the configuration for various services. 245 echo "Deploying service configurations ..." 246 LANG=C.UTF-8 omv-salt deploy run --no-color --quiet \ 247 apt cpufrequtils chrony rsyslog \ 248 watchdog monit rrdcached avahi ssh nginx collectd \ 249 phpfpm issue sysctl systemd systemd-logind || : 250 fi Thanks to https://docs.openmediavault.org/en/stable/various/advset.html#environmental-variables, I learn the configuration files used by omv-salt is stored at /srv/salt/omv Looking at the deploy stage in /srv/salt/omv I find a cpufrequtils folder kobol@helios64:~$ ls -al /srv/salt/omv/deploy/cpufrequtils/ total 20 drwxr-xr-x 3 root root 4096 Apr 5 15:58 . drwxr-xr-x 39 root root 4096 Apr 5 17:04 .. -rw-r--r-- 1 root root 2387 Mar 9 12:58 default.sls drwxr-xr-x 2 root root 4096 Apr 5 15:58 files -rw-r--r-- 1 root root 916 Mar 9 12:58 init.sls default.sls tells us the source file used by salt to configure /etc/default/cpufrequtils is files/cpufrequtils.j2 $ nano /srv/salt/omv/deploy/cpufrequtils/default.sls ... configure_default_cpufrequtils: file.managed: - name: "/etc/default/cpufrequtils" - source: - salt://{{ tpldir }}/files/cpufrequtils.j2 - template: jinja - context: cpufreq: {{ config.cpufreq }} - user: root - group: root - mode: 644 ... Finally, files/cpufrequtils.j2 calls for OMV_CPUFREQUTILS_MAXSPEED, OMV_CPUFREQUTILS_MINSPEED and OMV_CPUFREQUTILS_GOVERNOR $ nano /srv/salt/omv/deploy/cpufrequtils/files/cpufrequtils.j2 {%- set max_speed = salt['pillar.get']('default:OMV_CPUFREQUTILS_MAXSPEED', '0') -%} {%- set min_speed = salt['pillar.get']('default:OMV_CPUFREQUTILS_MINSPEED', '0') -%} {%- set governor = salt['pillar.get']('default:OMV_CPUFREQUTILS_GOVERNOR', salt['grains.filter_by']({ "default": "ondemand", "amd64": "conservative", "i386": "conservative", "armhf": "schedutil", "arm64": "schedutil", "armel": "schedutil" }, grain="osarch")) -%} {%- if cpufreq -%} ENABLE="true" {%- else -%} ENABLE="false" {%- endif %} GOVERNOR="{{ governor }}" MAX_SPEED="{{ max_speed }}" MIN_SPEED="{{ min_speed }}" The point is these values are first defined in the install script at line 543... after omv-salt is called on cpufrequtils at line 337 543 # set defaults in /etc/default/openmediavault 544 omv_set_default "OMV_CPUFREQUTILS_GOVERNOR" "${GOVERNOR}" 545 omv_set_default "OMV_CPUFREQUTILS_MINSPEED" "${MIN_SPEED}" 546 omv_set_default "OMV_CPUFREQUTILS_MAXSPEED" "${MAX_SPEED}" As per /srv/salt/omv/deploy/cpufrequtils/files/cpufrequtils.j2, there isn't any values defined yet in /etc/default/openmediavault. Thus : governor takes "schedutil" max_speed is 0 min_speed is 0 Edited April 7 by Trillien 1 Quote
TDCroPower Posted April 7 Author Posted April 7 @Trillien could be due to the commands after the installation... line 345-347 omv-confdbadm populate 2>&1 | tee -a ${logfile} omv-salt deploy run hosts 2>&1 | tee -a ${logfile} fi also explains why your "workaround" probably works, since the part is skipped if OMV has already been installed... line 295-297, end with fi on line 347 # install openmediavault if not installed already omvInstall=$(dpkg -l | awk '$2 == "openmediavault" { print $1 }') if [[ ! "${omvInstall}" == "ii" ]]; then ... the DEV ryecoaaron from the script is currently looking at the script fortunately and will hopefully fix the problem in the next version. Do you use Docker? For me, Helios crashes when I try to start a container, even with the hello-world test image from Docker... docker run hello-world 0 Quote
Trillien Posted April 7 Posted April 7 I plan to use OMV Photoprism extension that's managed as a container by OMV. As I remember, OMV doesn't manage containers with Docker but Podman. Not tested yet. Did you have a look at? 0 Quote
Trillien Posted April 7 Posted April 7 Quote could be due to the commands after the installation... line 345-347 omv-confdbadm populate 2>&1 | tee -a ${logfile} omv-salt deploy run hosts 2>&1 | tee -a ${logfile} fi Nop, I didn't get a chance to reach these steps at the first install. It reboot during update-initramfs, part of apt install openmediavault substep. However, /etc/default/cpufrequtils were already changed to "schedutil" 0 Quote
TDCroPower Posted April 7 Author Posted April 7 @Trillien comment out the ledtrig-netdev line fixed the docker run problem... root@helios64:~# cat /etc/modules-load.d/modules.conf lm75 #ledtrig-netdev 0 Quote
Trillien Posted April 19 Posted April 19 Hi @TDCroPower Have you got any issue with systemd-networkd service ? I systematically have a timeout as it seems waiting for all network interface to be ready. $ systemctl status systemd-networkd-wait-online.service × systemd-networkd-wait-online.service - Wait for Network to be Configured Loaded: loaded (/lib/systemd/system/systemd-networkd-wait-online.service; enabled; preset: disabled) Drop-In: /etc/systemd/system/systemd-networkd-wait-online.service.d └─override.conf Active: failed (Result: exit-code) since Fri 2024-04-19 16:33:57 CEST; 18min ago Docs: man:systemd-networkd-wait-online.service(8) Process: 1188 ExecStart=/lib/systemd/systemd-networkd-wait-online (code=exited, status=1/FAILURE) Main PID: 1188 (code=exited, status=1/FAILURE) CPU: 48ms I use end0 network interface. The other enx646266d00b79 isn't connected I've got a bridge br0 with a virtual tap0 interface (OpenVPN) podman runs a container and enable the interface veth7198de08 and the bridge cni-podman. $ networkctl IDX LINK TYPE OPERATIONAL SETUP 1 lo loopback carrier unmanaged 2 end0 ether enslaved configuring 4 enx646266d00b79 ether no-carrier configured 5 br0 bridge routable configured 6 tap0 ether enslaved configuring 7 cni-podman0 bridge routable unmanaged 8 veth7198de08 ether enslaved unmanaged 7 links listed. 0 Quote
