alr Posted February 14, 2017 Posted February 14, 2017 Hi! I look for this topic in every place at the internet but all of the topics are not related with my problem. I have a custom board based on the Lime2-emmc. It can boot from SD, but when I tried to copy the same u-boot-sunxi-with-spl.bin to the emmc and try to boot, nothing happends, the screen is empty. dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8 boot from SDhttp://imgur.com/a/OHxzm When it boots from SD the u-boot shows both (SD on MMC0 and EMMC on MMC1) I´m using the A20-OLinuXino-Lime2-eMMC_defconfig with some mods to my board. My emmc is unit is KLM8G1GEME-B041 and is connected to the board like the emmc unit is connected to A20-OLinuXino-Lime2_Rev_Ghttp://imgur.com/a/GIY3W I did a hexdump on the SD and MMC and it looks the same with the "eGON.BT0" tag in the right position. SDhttp://imgur.com/a/AL6lv MMChttp://imgur.com/a/bM5v3 Thanks!
alr Posted February 16, 2017 Author Posted February 16, 2017 Hi again,A funny thing. :-[When it boots from the SD card, and the u-boot prompt appears, if I remove the SD card and send the reset command, the board starts from the EMMC without problems. U-Boot SPL 2017.03-rc2-dirty (Feb 15 2017 - 10:37:04) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC1 U-Boot 2017.03-rc2-dirty (Feb 15 2017 - 10:37:04 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Olimex A20-OLinuXino-LIME2-eMMC I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1 In: serial Out: serial Err: serial SCSI: AHCI PHY power up failed. Net: No ethernet found. starting USB... USB0: USB EHCI 1.00 USB1: USB OHCI 1.0 USB2: USB EHCI 1.00 USB3: USB OHCI 1.0 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 2 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Hit any key to stop autoboot: 0 => reset resetting ... U-Boot SPL 2017.01-armbian (Feb 09 2017 - 14:44:38) DRAM: 1024 MiB CPU: 912000000Hz, AXI/AHB/APB: 3/2/2 Trying to boot from MMC2 U-Boot 2017.01-armbian (Feb 09 2017 - 14:44:38 +0100) Allwinner Technology CPU: Allwinner A20 (SUN7I) Model: Olimex A20-OLinuXino-LIME2-eMMC I2C: ready DRAM: 1 GiB MMC: SUNXI SD/MMC: 1, SUNXI SD/MMC: 0 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial SCSI: AHCI PHY power up failed. Net: No ethernet found. Hit any key to stop autoboot: 0 6944 bytes read in 150 ms (44.9 KiB/s) switch to partitions #0, OK mmc0(part 0) is current device Any hints?
martinayotte Posted February 16, 2017 Posted February 16, 2017 From the log above, we can see that both u-boot are not the same version. Are you sure that when you did "dd if=u-boot-sunxi-with-spl.bin of=/dev/mmcblk1 bs=1024 seek=8" it was the proper u-boot file ?
alr Posted March 3, 2017 Author Posted March 3, 2017 Hi Martinayotte. Yes the versions are different, because the first one is the one loaded into the EMMC card with armbian and the one into the SD is only the uboot. Yes, I am sure about that was the file. As you can see in my previous message is booting from the EMMC only when it reboots, so that says that the Uboot is working properly only when the board is already started.
alr Posted March 13, 2017 Author Posted March 13, 2017 With the SD loaded with U-Boot 2017.01-armbian I can boot and manage the board. I did a nand-sata-install and now the content of the SD and MMC is the same (checked with hexdump) but the board is not booting from the EMMC. The config is one based on A20-OLinuXino-Lime2-eMMC_defconfig, but modified for my board: CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=360 CONFIG_DRAM_MBUS_CLK=400 CONFIG_DRAM_ZQ=91 CONFIG_DRAM_ODT_EN=y CONFIG_DRAM_TPR3=0x041111 CONFIG_DRAM_DQS_GATING_DELAY=0x04040404 # CONFIG_DRAM_TIMINGS_VENDOR_MAGIC is not set CONFIG_DRAM_TIMINGS_DDR3_1066F_1333H=y CONFIG_USB0_VBUS_PIN="" CONFIG_USB0_VBUS_DET="" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2-emmc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y CONFIG_MMC0_CD_PIN="PH15" CONFIG_MMC_SUNXI_SLOT = 2 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_DFU_RAM=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 this is my fdisk -l output Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 2048 15213343 15211296 7.3G 83 Linux Disk /dev/mmcblk1: 7.3 GiB, 7818182656 bytes, 15269888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x8a6be3e2 Device Boot Start End Sectors Size Id Type /dev/mmcblk1p1 2048 15117183 15115136 7.2G 83 Linux Disk /dev/mmcblk1boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xeb695f6b Device Boot Start End Sectors Size Id Type /dev/mmcblk1boot1p1 1 8191 8191 4M 83 Linux Disk /dev/mmcblk1boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0xaf98e9b7 Any hints?
zador.blood.stained Posted March 13, 2017 Posted March 13, 2017 2 hours ago, alr said: CONFIG_MMC_SUNXI_SLOT = 2 I don't think this is a correct option or even a correct syntax (with spaces). I think this is the option you need to use: CONFIG_MMC_SUNXI_SLOT_EXTRA=2
alr Posted March 13, 2017 Author Posted March 13, 2017 4 minutes ago, zador.blood.stained said: I don't think this is a correct option or even a correct syntax (with spaces). I think this is the option you need to use: CONFIG_MMC_SUNXI_SLOT_EXTRA=2 Yeah, that´s was copy/paste from another file. Thanks. I meant: CONFIG_ARM=y CONFIG_ARCH_SUNXI=y CONFIG_SPL_I2C_SUPPORT=y CONFIG_MACH_SUN7I=y CONFIG_DRAM_CLK=360 CONFIG_DRAM_MBUS_CLK=400 CONFIG_DRAM_ZQ=91 CONFIG_DRAM_ODT_EN=y CONFIG_DRAM_TPR3=0x041111 CONFIG_DRAM_DQS_GATING_DELAY=0x04040404 # CONFIG_DRAM_TIMINGS_VENDOR_MAGIC is not set CONFIG_DRAM_TIMINGS_DDR3_1066F_1333H=y CONFIG_USB0_VBUS_PIN="" CONFIG_USB0_VBUS_DET="" CONFIG_DEFAULT_DEVICE_TREE="sun7i-a20-olinuxino-lime2-emmc" # CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set CONFIG_SYS_EXTRA_OPTIONS="SUNXI_GMAC,RGMII,AHCI,SATAPWR=SUNXI_GPC(3)" CONFIG_SPL=y CONFIG_MMC0_CD_PIN="PH15" CONFIG_MMC_SUNXI_SLOT_EXTRA=2 # CONFIG_CMD_IMLS is not set # CONFIG_CMD_FLASH is not set CONFIG_CMD_DFU=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_FPGA is not set CONFIG_DFU_RAM=y CONFIG_RTL8211X_PHY_FORCE_MASTER=y CONFIG_ETH_DESIGNWARE=y CONFIG_AXP_ALDO3_VOLT=2800 CONFIG_AXP_ALDO4_VOLT=2800 CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_GADGET=y CONFIG_USB_GADGET=y CONFIG_USB_GADGET_DOWNLOAD=y CONFIG_G_DNL_MANUFACTURER="Allwinner Technology" CONFIG_G_DNL_VENDOR_NUM=0x1f3a CONFIG_G_DNL_PRODUCT_NUM=0x1010 But still doesn´t boot
zador.blood.stained Posted March 13, 2017 Posted March 13, 2017 14 minutes ago, alr said: But still doesn´t boot Serial console logs? "Doesn't boot" may mean a lot of different things.
alr Posted March 13, 2017 Author Posted March 13, 2017 26 minutes ago, zador.blood.stained said: Serial console logs? "Doesn't boot" may mean a lot of different things. As I told in earlier posts, nothings appears in the Serial console, is completely empty, like nothings happends.
zador.blood.stained Posted March 13, 2017 Posted March 13, 2017 Just now, alr said: As I told tin earlier post, nothings appears in the Serial console, is completely empty, like nothings happends. This means that SPL is not loaded (even if u-boot is misconfigured it would print something like "unknown boot source"). On 16.02.2017 at 11:37 AM, alr said: if I remove the SD card and send the reset command, the board starts from the EMMC without problems. Is this still true? Is the eMMC accessible if you load u-boot using FEL mode (and does the board fall back to FEL without SD inserted or not)? Maybe eMMC doesn't have enough time to reset properly on cold start, or 3.3V power (according to Lime2 rev. G schematic it is enabled with EXTEN pin) doesn't turn on fast enough. Did you try to press the reset button multiple times without SD inserted?
alr Posted March 14, 2017 Author Posted March 14, 2017 21 hours ago, zador.blood.stained said: This means that SPL is not loaded (even if u-boot is misconfigured it would print something like "unknown boot source"). Is this still true? Is the eMMC accessible if you load u-boot using FEL mode (and does the board fall back to FEL without SD inserted or not)? Yes. I load a u-boot via FEL mode and then type reset without SD card and it boots from the eMMC. I lost the version I compiled to this board. How I can get this boot info to put in another board. 21 hours ago, zador.blood.stained said: Maybe eMMC doesn't have enough time to reset properly on cold start, or 3.3V power (according to Lime2 rev. G schematic it is enabled with EXTEN pin) doesn't turn on fast enough. I have to check that. 21 hours ago, zador.blood.stained said: Did you try to press the reset button multiple times without SD inserted? Yes, and it isn´t working
alr Posted March 27, 2017 Author Posted March 27, 2017 I just realized that the boot and boot1 sectors of the emmc on the LIme2-emmc board are 16Mb each. And the boot sectors on my EMMC of my custom board are 4MB each. is this related with the SPL? Can I configure armbian u-boot to change this? Thanks again.
zador.blood.stained Posted March 27, 2017 Posted March 27, 2017 1 minute ago, alr said: I just realized that the boot and boot1 sectors of the emmc on the LIme2-emmc board are 16Mb each. And the boot sectors on my EMMC of my custom board are 4MB each. is this related with the SPL? Can I configure armbian u-boot to change this? AFAIK A20 BROM boots fine from u-boot located in the "main" eMMC partition, I don't think anybody investigated what offsets and configuration should be used with boot partitions and whether BROM checks them.
