Andrea Posted March 13, 2024 Posted March 13, 2024 Hi all, is it possible to flash the a board's eMMC via USB from another PC? I already checked this but could not figure out exactly how. Thanks in advance, kind regards 0 Quote
Andrea Posted March 24, 2024 Author Posted March 24, 2024 A custom designed board around H616. 0 Quote
Solution Werner Posted March 24, 2024 Solution Posted March 24, 2024 On 3/13/2024 at 4:58 PM, Andrea said: I already checked this but could not figure out exactly how. armbian-install is meant to be used inside the running Armbian system from microSD card. It copies itself to NVMe or eMMC or whatever options are available and can be utilized. This tool does not work "offline". Anyway. I never did something like that by myself but maybe you find some hints when you google for keywords like "h616 fel sunxi-fel emmc". fel mode seems something like Rockchips maskrom to utilized the rkdevtool. Maybe Allwinner has something similar 0 Quote
usual user Posted March 24, 2024 Posted March 24, 2024 If there is already firmware with U-Boot as a payload on the device, the UMS functionality is a possibility. In the meantime, all my firmware builds have easy access to this functionality, as long as the support requirements are met. I don't know the support status of the Allwinner H616 SoC, hence YMMV. 0 Quote
Michael Robinson Posted March 25, 2024 Posted March 25, 2024 if the emmc module is removable search for ubs emmc tool. then write emmc from desktop and reinstall on pcb. 0 Quote
