Following the guide https://docs.armbian.com/Developer-Guide_Build-Preparation/  I compiled a kernel 4.10 and I get:
[*]  Only appears one CPU.
                          CPU1, CPU2, CPU3 show disabled as lshw result.   Anybody know how to enable the other cores?
[*] In kernel config I enabled staging drivers for sun8i crypto engine. It seems that
                          after loading the module,  cat /proc/crypto does't appears to be using the crypto engine.
                          openssl speed seems to be the same than legacy kernel.
                          In dtb I can see that there is some stuff about crypto with status: disabled
                          Anyone can help in getting the crypto engine enabled?
[*]  wifi: The iface wlan0 doesn't exists in kernel 4.10. but after compiling
                        git clone https://github.com/jwrdegoede/rtl8189ES_linux.gitfrom from http://linux-sunxi.org/Wifi
                        the wlan0 appears and I am able to scan wifi... but there is a error when trying to associate with WPA-PSK CCMP
                        so no wireless connection.
                        Anyone can point how to make it work?
Greetings
Did you make a full image or only the kernel? Installing dev kernel on a system which previously had legacy kernel without replacing u-boot and boot environment file will produce this issue.
sun8i-ce is WIP and last time I checked there were some problems with it, so it was disabled for a reason.
only the kernel... do you recommend full image?
Yes ... in case you don't know exactly what you are doing. Read Zador's post again - he wrote you what to do instead.
Full image solves for me:
-Quad core fully enabled
-Wifi works (compiling from git rtl8189ES_linux)
but... regarding crypto engine... I am not able to make it work properly... anybody can help with this?
root@orangepiplus:~# uname -a
Linux orangepiplus 4.10.0-sun8i #1 SMP Thu Feb 23 20:39:42 CET 2017 armv7l GNU/Linux
I've built the armbian image with mainline kernel 4.10 following the documentation
changing in the file lib/patch/kernel/sun8i-dev/add-sun8i-ce-crypto-engine-dt.patch
the line  for crypto@1c15000:   from status="disabled"   to status= "okay"
I enabled it in kernel config and I get the following:
root@orangepiplus:~# cat /proc/crypto | head -n 100
driver       : rsa-sun8i-ce
module       : sun8i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : akcipher
driver       : cbc-aes-sun8i-ss
module       : sun8i_ss
priority     : 300
refcnt       : 1
selftest     : passed
internal     : no
type         : ablkcipher
async        : yes
blocksize    : 16
min keysize  : 16
max keysize  : 32
ivsize       : 16
geniv        : <default>
I've installed cryptodev from git too...
root@orangepiplus:~# ls -lrt /dev/crypto
crw-rw-rw- 1 root root 10, 58 Feb 23 22:29 /dev/crypto
dmesg
[    6.159486] cryptodev: loading out-of-tree module taints kernel.
[    6.160711] cryptodev: driver 1.8 loaded.
[    7.212338] sun8i-ss 1c15000.crypto: CE_S Die ID 0
[    7.212353] sun8i-ss 1c15000.crypto: CE_NS Die ID 1
[    7.213395] sun8i-ss 1c15000.crypto: will run requests pump with realtime priority
[    7.213575] sun8i-ss 1c15000.crypto: will run requests pump with realtime priority
[    7.213662] sun8i-ss 1c15000.crypto: will run requests pump with realtime priority
[    7.213766] sun8i-ss 1c15000.crypto: will run requests pump with realtime priority
[    7.215742] sun8i-ss 1c15000.crypto: Registered Sun8i-ce PRNG
[    7.215767] sun8i-ss 1c15000.crypto: sun8i_ce_hwrng_init
[    7.215772] sun8i-ss 1c15000.crypto: sun8i_ce_hwrng_init rready=-114
[    7.215777] sun8i-ss 1c15000.crypto: sun8i_ce_seed
[  180.912998] sun8i-ss 1c15000.crypto: ERROR: Cannot allocate fallback
[  190.649388] sun8i-ss 1c15000.crypto: ERROR: Cannot allocate fallback
and test tools
root@orangepiplus:~/cryptodev-linux/tests# ./cipher
ioctl(CIOCGSESSION): Invalid argument
root@orangepiplus:~/cryptotest/cryptodev# ./cryptodev_test test aes
INFO: Mode test
ERROR: ioctl(CIOCGSESSION) Invalid argumentERROR: aes_encrypt ioctl(CIOCCRYPT) Invalid argumentError at encrypt request 0 pos=0 of len=16
71 00
73 00
5a 00
bd 00
53 00
30 00
11 00
05 00
5d 00
8f 00
16 00
ac 00
c0 00
28 00
7b 00
8d 00
I use same methodology as you tried and cryptodev test has been successfully worked for AES128, AES192 and AES256 algorithms. Also, I compiled openssl by enabling crypto engine support. After that, when I try to compile openssh, it works without using openssl's crypto engine libraries by default. In this case, I got data transmission speed about 14 MB/sec on openssh and my cpu usage is 94%. When I export openssl's crypto engine libraries, then data transmission speed descreases to 4 MB/sec. as the maximum speed. Also, cpu usage descreases to 9%. I use gigabit ethernet connection between my devices which are orange pi plus and banana pi M2. So, the performance is very bad as a result.
Note: This method only does not work on orange pi plus. It works on banana pi M2 as expected.
Could anyone help me with this performance problem? What do I need to do?
Regards.
On 29/04/2017 at 2:57 PM, ozdemirkulaoglu said:
Regards.
@ozdemirkulaoglu what output does running this command give with and without crypto engine libraries
time openssl speed -evp aes-128-cbc -engine cryptodev
what crypto module you using "sun8i-ce" ?
