petaspam Posted March 1, 2017 Posted March 1, 2017 Hi.I am new to the MiniPC world and thank you for your help beforehand.I have managed to install ARMBian on my Orange Pi PC + and it occurred to me to use it as a STEAM Link with MOONLIGHT software that gives such good results in its version for Android. The linux version runs from an independent one here. The problem is that it does not let me install the dependencies, I leave them an image. I have tried it from XTerminal as from 'Synaptic Package Mannager'As I say I am new to this, if someone who knows how to operate explained it I would be very grateful.Thank you very much. //------------------------------------------\\ Spoiler Original en ESP: Hola. Soy nuevo en el mundillo de los MiniPC y les agradezco su ayuda de ante mano. He conseguido instalar ARMBian en mi Orange Pi PC+ y se me ocurrió usarla como una STEAM Link con el software MOONLIGHT que tan buenos resultados da en su versión para Android. La versión para linux corre de parte de un independiente aquí. El problema reside en que no me deja instalar las dependencias, les dejo una imagen. lo he probado desde XTerminal como desde 'Synaptic Package Mannager' Como digo soy nuevo en esto, si alguien que lo sepa hacer funcionar lo explicara le estaría muy agradecido. Muchas gracias.
Igor Posted March 2, 2017 Posted March 2, 2017 Try adding this packages list: https://github.com/irtimmer/moonlight-embedded/wiki/Packages I am not sure you can run this on Orange Pi. Under supported hardware you can find: ## Select the audio and video decoder to use ## default - autodetect ## aml - hardware video decoder for ODROID-C1/C2 ## omx - hardware video decoder for Raspberry Pi ## imx - hardware video decoder for i.MX6 devices ## sdl - software decoder In theory it should go with "software decoder" but in this case it probably won't be usable.
