I don't know if this is something I have broken or not, but I have a \var\log and a \var\log.hdd both identical and both being updated.
Where should I be looking to rectify this duplication?
ARMBIAN 5.25 stable Debian GNU/Linux 8 (jessie) 3.4.113-sun8i
OrangePiZero
/var/log uses the "log2ram" filesystem, and /var/log.hdd is on your sd card.  This is done to minimize writes to the sd card.  So while they appear duplicated, I think only the most recent stuff is kept in ram.
Thank you.
Is there a place where all my questions are answered already? I don't want to annoy people on the forum with my n00bness.
Important data are at download page, more general in docs.armbian.com, the rest you can find by using search engine or Google powered site search
On my system /var/log appears to be in the sd card, yet log2ram is active (note: I didn't alter /etc/fstab, this is a system installed from the armbian server image for the orange pi pc, I also checked and /var/log is not a symbolic link to a tmpfs). Kinda defeats the purpose to reduce wear on the SD card.
Btw, the file /etc/cron.daily/log2ram is owned by a non existent user and group 1001
In fact I have a bunch of those, all coming from the linux-xenial-root-orangepipc package:
# find -uid 1001 2>/dev/null | sed 's/^\.//' | xargs dpkg -S
linux-xenial-root-orangepipc: /lib/systemd/system/systemd-modules-load.service.d
linux-xenial-root-orangepipc: /lib/systemd/system/systemd-modules-load.service.d/10-timeout.conf
linux-xenial-root-orangepipc: /lib/systemd/system/log2ram.service
linux-xenial-root-orangepipc: /lib/systemd/system/serial-getty@.service.d
linux-xenial-root-orangepipc: /lib/systemd/system/serial-getty@.service.d/10-term.conf
linux-xenial-root-orangepipc: /lib/systemd/system/firstrun.service
linux-xenial-root-orangepipc: /lib/systemd/system/resize2fs.service
linux-xenial-root-orangepipc: /lib/systemd/system/getty@tty1.service.d
linux-xenial-root-orangepipc: /lib/systemd/system/getty@tty1.service.d/10-noclear.conf
linux-xenial-root-orangepipc: /lib/udev/rules.d/71-axp-power-button.rules
linux-xenial-root-orangepipc: /etc/initramfs/post-update.d/99-uboot
linux-xenial-root-orangepipc: /etc/X11/xorg.conf.d/01-armbian-defaults.conf
linux-xenial-root-orangepipc: /etc/profile.d/ssh-title.sh
linux-xenial-root-orangepipc: /etc/profile.d/check_first_login_reboot.sh
linux-xenial-root-orangepipc: /etc/default/armbian-motd.dpkg-dist
linux-xenial-root-orangepipc: /etc/default/log2ram.dpkg-dist
linux-xenial-root-orangepipc: /etc/network/interfaces.bonding
linux-xenial-root-orangepipc: /etc/network/interfaces.default
linux-xenial-root-orangepipc: /etc/network/interfaces.r1switch
linux-xenial-root-orangepipc: /etc/network/interfaces.network-manager
linux-xenial-root-orangepipc: /etc/network/interfaces.espressobin
linux-xenial-root-orangepipc: /etc/network/interfaces.r1router
linux-xenial-root-orangepipc: /etc/network/interfaces.hostapd
linux-xenial-root-orangepipc: /etc/apt/apt.conf.d/71-no-recommends
linux-xenial-root-orangepipc: /etc/apt/apt.conf.d/02periodic
linux-xenial-root-orangepipc: /etc/cron.daily/log2ram
linux-xenial-root-orangepipc: /etc/kernel/preinst.d/initramfs-cleanup
linux-xenial-root-orangepipc: /var/lib/polkit-1/localauthority/backlight.pkla
linux-xenial-root-orangepipc: /var/lib/polkit-1/localauthority/power.pkla
linux-xenial-root-orangepipc: /var/lib/polkit-1/localauthority/networkmanager.pkla
linux-xenial-root-orangepipc: /var/lib/polkit-1/localauthority/plugdev.pkla
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a20/bootloader/linux/linux.ini
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a20/bootloader/linux/u-boot.bin
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a20/bootloader/boot.axf
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a20/bootloader/boot.ini
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/exclude.txt
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a10/bootloader/u-boot.bin
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a10/bootloader/linux/linux.ini
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a10/bootloader/boot.axf
linux-xenial-root-orangepipc: /usr/lib/nand-sata-install/a10/bootloader/boot.ini
linux-xenial-root-orangepipc: /usr/lib/armbian/apt-updates
linux-xenial-root-orangepipc: /usr/share/log2ram/LICENSE
linux-xenial-root-orangepipc: /usr/sbin/log2ram
root@citofono:/# dpkg -l linux-xenial-root-orangepipc
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                        Version            Architecture       Description
ii  linux-xenial-root-orangepip 5.32.170901        armhf              Armbian tweaks for xenial on orangepipc (default branch)
So far it was working without a problem. Can you provide full logs? armbianmonitor -u
No, I mean, if /var/log is already on the sd card, using the log2ram script to copy it to /var/log.hdd will at least double the wear on the sd card.
The real question is why /var/log is not in ram (and why there are files with the 1001 owner).
Something is malfunction but without logs, I am unable to guess what went wrong. I only see that you are using beta build, which is auto made and possible broken ... nobody test that.
Oops, I forgot I enabled the beta repository.
But I checked the original image and even there /var/log is on disk.
root@orangepiprime:~# df
Filesystem     1K-blocks    Used Available Use% Mounted on
udev              990260       0    990260   0% /dev
tmpfs             205140    5824    199316   3% /run
/dev/mmcblk0p1   7419364 2559408   4734400  36% /
tmpfs            1025692     140   1025552   1% /dev/shm
tmpfs               5120       4      5116   1% /run/lock
tmpfs            1025692       0   1025692   0% /sys/fs/cgroup
tmpfs            1025692       8   1025684   1% /tmp
log2ram            51200    1452     49748   3% /var/log
tmpfs             205140       0    205140   0% /run/user/0
tmpfs             205140       8    205132   1% /run/user/1000
Mount info:
log2ram on /var/log type tmpfs (rw,nosuid,nodev,noexec,relatime,size=51200k,mode=755)
Logs: http://sprunge.us/VQSd
In /var/log/armhwinfo.log I see that log2ram was initially enabled (or so it seems)
### partitions:
major minor  #blocks  name
 179        0    1954816 mmcblk0
 179        1    1445888 mmcblk0p1
### df:
Filesystem      Size  Used Avail Use% Mounted on
udev            370M     0  370M   0% /dev
tmpfs           101M  1.7M   99M   2% /run
/dev/mmcblk0p1  1.4G  975M  387M  72% /
tmpfs           501M     0  501M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           501M     0  501M   0% /sys/fs/cgroup
tmpfs           501M   28K  501M   1% /tmp
log2ram          50M  752K   50M   2% /var/log
So I guess some package removed the log2ram entry (I for sure didn't: I didn't even know what log2ram was until I setup nullmailer and saw the log message).
Now I see that log2ram is not a fs type but a service and it was disabled (not by me)
# systemctl status log2ram
● log2ram.service - Armbian enhanced Log2Ram
   Loaded: loaded (/lib/systemd/system/log2ram.service; disabled; vendor preset: enabled)
   Active: inactive (dead)
I enabled it, let's see if it lasts
I just ran apt-upgrade
Start-Date: 2017-09-11  12:44:53
Commandline: apt upgrade
Requested-By: luca (1000)
Upgrade: linux-image-sun8i:armhf (5.32.170901, 5.32.170911), linux-headers-sun8i:armhf (5.32.170901, 5.32.170911), linux-u-boot-orangepipc-default:armhf (5.32.170901, 5.32.170911), sunxi-tools:armhf (1.4.2-1~armbian5.32.170901+1, 1.4.2-1~armbian5.32.170911+1), hostapd:armhf (1:2.5~armbian5.32.170901+1, 1:2.5~armbian5.32.170911+1), linux-xenial-root-orangepipc:armhf (5.32.170901, 5.32.170911), linux-firmware:armhf (1.157.11, 1.157.12)
End-Date: 2017-09-11  12:52:25
and it disabled the log2ram service (I'll investigate which package did it).
BTW, I found out why I enabled the beta repository
There's this line in the postrm of linux-xenial-root-orangepipc
systemctl disable log2ram.service armhwinfo.service >/dev/null 2>&1
but I don't think the postrm is called on upgrade, is it?
Edit: yes it does
I'm not too familiar with deb packaging, but maybe just using the same condition as the line above it would be enough:
[ remove = "$1" ] || [ abort-install = "$1" ] &&
And file ownership should also be fixed
# dpkg -L linux-xenial-root-orangepipc | xargs ls -n | grep '1001 1001'
ls: cannot access '/etc/update-motd.d/99-point-to-faq': No such file or directory
ls: cannot access 'package': No such file or directory
ls: cannot access 'diverts': No such file or directory
ls: cannot access 'others': No such file or directory
ls: cannot access 'to:': No such file or directory
ls: cannot access '/etc/mpv/mpv-dist.conf': No such file or directory
-rw-r--r--   1 1001 1001     56 Aug  1 15:17 /etc/apt/apt.conf.d/71-no-recommends
-rwxr-xr-x   1 1001 1001     36 Aug  1 15:17 /etc/cron.daily/log2ram
-rw-r--r--   1 1001 1001     83 Aug  1 15:17 /etc/cron.d/armbian-updates
-rw-r--r--   1 1001 1001    156 Aug  1 15:17 /etc/default/armbian-motd.dpkg-dist
-rw-r--r--   1 1001 1001    280 Aug  1 15:17 /etc/default/log2ram.dpkg-dist
-rwxr-xr-x   1 1001 1001    308 Aug  1 15:17 /etc/initramfs/post-update.d/99-uboot
-rwxr-xr-x   1 1001 1001   1022 Aug  1 15:17 /etc/kernel/preinst.d/initramfs-cleanup
-rw-r--r--   1 1001 1001    525 Aug  1 15:17 /etc/network/interfaces.bonding
-rw-r--r--   1 1001 1001   1028 Sep 10 12:16 /etc/network/interfaces.default
-rw-r--r--   1 1001 1001    280 Aug  1 15:17 /etc/network/interfaces.espressobin
-rw-r--r--   1 1001 1001    197 Aug  1 15:17 /etc/network/interfaces.hostapd
-rw-r--r--   1 1001 1001    218 Aug  1 15:17 /etc/network/interfaces.network-manager
-rw-r--r--   1 1001 1001    495 Aug  1 15:17 /etc/network/interfaces.r1
-rw-r--r--   1 1001 1001    610 Aug  1 15:17 /etc/network/interfaces.r1router
-rw-r--r--   1 1001 1001    359 Aug  1 15:17 /etc/network/interfaces.r1switch
-rw-r--r--   1 1001 1001    212 Aug  1 15:17 /etc/profile.d/check_first_login_reboot.sh
-rw-r--r--   1 1001 1001    174 Aug  1 15:17 /etc/profile.d/ssh-title.sh
-rw-r--r--   1 1001 1001    217 Aug  1 15:17 /etc/X11/xorg.conf.d/01-armbian-defaults.conf
-rw-r--r--   1 1001 1001    384 Aug  1 15:17 /lib/systemd/system/firstrun.service
-rw-r--r--   1 1001 1001     30 Aug  1 15:17 /lib/systemd/system/getty@tty1.service.d/10-noclear.conf
-rw-r--r--   1 1001 1001    448 Aug  1 15:17 /lib/systemd/system/log2ram.service
-rw-r--r--   1 1001 1001    426 Aug  1 15:17 /lib/systemd/system/resize2fs.service
-rw-r--r--   1 1001 1001     33 Aug  1 15:17 /lib/systemd/system/serial-getty@.service.d/10-term.conf
-rw-r--r--   1 1001 1001     28 Aug  1 15:17 /lib/systemd/system/systemd-modules-load.service.d/10-timeout.conf
-rw-r--r--   1 1001 1001    287 Aug  1 15:17 /lib/udev/rules.d/71-axp-power-button.rules
-rwxr-xr-x   1 1001 1001   3783 Aug  1 15:17 /usr/lib/armbian/apt-updates
-rw-r--r--   1 1001 1001  84132 Aug  1 15:17 /usr/lib/nand-sata-install/a10/bootloader/boot.axf
-rw-r--r--   1 1001 1001    126 Aug  1 15:17 /usr/lib/nand-sata-install/a10/bootloader/boot.ini
-rw-r--r--   1 1001 1001    146 Aug  1 15:17 /usr/lib/nand-sata-install/a10/bootloader/linux/linux.ini
-rw-r--r--   1 1001 1001 321016 Aug  1 15:17 /usr/lib/nand-sata-install/a10/bootloader/u-boot.bin
-rw-r--r--   1 1001 1001 118912 Aug  1 15:17 /usr/lib/nand-sata-install/a20/bootloader/boot.axf
-rw-r--r--   1 1001 1001     91 Aug  1 15:17 /usr/lib/nand-sata-install/a20/bootloader/boot.ini
-rw-r--r--   1 1001 1001    152 Aug  1 15:17 /usr/lib/nand-sata-install/a20/bootloader/linux/linux.ini
-rw-r--r--   1 1001 1001 309228 Aug  1 15:17 /usr/lib/nand-sata-install/a20/bootloader/linux/u-boot.bin
-rw-r--r--   1 1001 1001     60 Aug  1 15:17 /usr/lib/nand-sata-install/exclude.txt
-rwxr-xr-x   1 1001 1001   1458 Aug  1 15:17 /usr/sbin/log2ram
-rw-r--r--   1 1001 1001   1067 Aug  1 15:17 /usr/share/log2ram/LICENSE
-rw-r--r-- 1 1001 1001   56 Aug  1 15:17 71-no-recommends
-rw-r--r-- 1 1001 1001  83 Aug  1 15:17 armbian-updates
-rwxr-xr-x 1 1001 1001   36 Aug  1 15:17 log2ram
-rw-r--r-- 1 1001 1001  156 Aug  1 15:17 armbian-motd.dpkg-dist
-rw-r--r-- 1 1001 1001  280 Aug  1 15:17 log2ram.dpkg-dist
-rwxr-xr-x 1 1001 1001 308 Aug  1 15:17 99-uboot
-rwxr-xr-x 1 1001 1001 1022 Aug  1 15:17 initramfs-cleanup
-rw-r--r-- 1 1001 1001  525 Aug  1 15:17 interfaces.bonding
-rw-r--r-- 1 1001 1001 1028 Sep 10 12:16 interfaces.default
-rw-r--r-- 1 1001 1001  280 Aug  1 15:17 interfaces.espressobin
-rw-r--r-- 1 1001 1001  197 Aug  1 15:17 interfaces.hostapd
-rw-r--r-- 1 1001 1001  218 Aug  1 15:17 interfaces.network-manager
-rw-r--r-- 1 1001 1001  495 Aug  1 15:17 interfaces.r1
-rw-r--r-- 1 1001 1001  610 Aug  1 15:17 interfaces.r1router
-rw-r--r-- 1 1001 1001  359 Aug  1 15:17 interfaces.r1switch
-rw-r--r-- 1 1001 1001  212 Aug  1 15:17 check_first_login_reboot.sh
-rw-r--r-- 1 1001 1001  174 Aug  1 15:17 ssh-title.sh
-rw-r--r-- 1 1001 1001 217 Aug  1 15:17 01-armbian-defaults.conf
-rw-r--r-- 1 1001 1001  384 Aug  1 15:17 firstrun.service
drwxr-xr-x 2 1001 1001 4096 Sep 11 12:49 getty@tty1.service.d
-rw-r--r-- 1 1001 1001  448 Aug  1 15:17 log2ram.service
-rw-r--r-- 1 1001 1001  426 Aug  1 15:17 resize2fs.service
drwxr-xr-x 2 1001 1001 4096 Sep 11 12:49 serial-getty@.service.d
drwxr-xr-x 2 1001 1001 4096 Sep 11 12:49 systemd-modules-load.service.d
-rw-r--r-- 1 1001 1001 30 Aug  1 15:17 10-noclear.conf
-rw-r--r-- 1 1001 1001 33 Aug  1 15:17 10-term.conf
-rw-r--r-- 1 1001 1001 28 Aug  1 15:17 10-timeout.conf
-rw-r--r-- 1 1001 1001  287 Aug  1 15:17 71-axp-power-button.rules
-rwxr-xr-x 1 1001 1001 3783 Aug  1 15:17 apt-updates
-rw-r--r-- 1 1001 1001   60 Aug  1 15:17 exclude.txt
-rw-r--r-- 1 1001 1001  84132 Aug  1 15:17 boot.axf
-rw-r--r-- 1 1001 1001    126 Aug  1 15:17 boot.ini
-rw-r--r-- 1 1001 1001 321016 Aug  1 15:17 u-boot.bin
-rw-r--r-- 1 1001 1001 146 Aug  1 15:17 linux.ini
-rw-r--r-- 1 1001 1001 118912 Aug  1 15:17 boot.axf
-rw-r--r-- 1 1001 1001     91 Aug  1 15:17 boot.ini
-rw-r--r-- 1 1001 1001    152 Aug  1 15:17 linux.ini
-rw-r--r-- 1 1001 1001 309228 Aug  1 15:17 u-boot.bin
-rwxr-xr-x 1 1001 1001    1458 Aug  1 15:17 log2ram
-rw-r--r-- 1 1001 1001 1067 Aug  1 15:17 LICENSE
Hello, I'm new to Armbian, but I just booted by CuboxTV with Armbian_5.30_Cubox-i_Debian_jessie_next_4.11.4.img,
and log2ram was looking fine:
# mount
. etc etc
/dev/mmcblk0p1 on /var/log.hdd type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
upon upgrading via 'apt update' and 'apt upgrade' + reboot, I also see that log2ram is disabled:
   Loaded: loaded (/lib/systemd/system/log2ram.service; disabled)
enable + start via systemctl restored log2ram.
