Timo12357 Posted April 9, 2024 Posted April 9, 2024 I disabled Armbian kernel upgrades to stay at Armbian 23.11.1 until Armbian 24 stabilizes. Yesterday I unfroze the kernel upgrades to upgrade to 24.2.1. I run: apt update apt upgrade apt dist-upgrade Apt update says All packages are up to date. Quote apt-mark showhold shows nothing. What did I miss? 0 Quote
SteeMan Posted April 9, 2024 Posted April 9, 2024 Providing logs with armbianmonitor -u helps with troubleshooting and significantly raises chances that issue gets addressed. 0 Quote
Timo12357 Posted April 11, 2024 Author Posted April 11, 2024 Here you go: https://paste.armbian.com/dodovukexe 0 Quote
SteeMan Posted April 11, 2024 Posted April 11, 2024 I can't explain what you are seeing. Are the contents of /etc/apt/sources.list.d/armbian.list correct? Have you tried to use armbian-config to upgrade the kernel? 0 Quote
Timo12357 Posted April 12, 2024 Author Posted April 12, 2024 armbian.list: deb http://mirrors.dotsrc.org/armbian-apt/ bullseye main bullseye-utils bullseye-desktop armbian-config says "No other kernels available" 0 Quote
SteeMan Posted April 12, 2024 Posted April 12, 2024 I can't explain what you are seeing, as everything appears in order. The only thing I'm going to suggest as a long shot, is that you are getting pointed to a mirror that for some reason isn't up to date (which shouldn't be the case). Since I don't know where you are located in the world, you could try to update your armbian.list file to point explicitly to a different mirror (list is available here: https://github.com/armbian/mirror) When I look at the mirror I get resolved to, I see the 24.2.1 packages in the bullseye repository. I don't understand why apt isn't finding them for you. 0 Quote
Timo12357 Posted April 24, 2024 Author Posted April 24, 2024 So 24.2.1 does not require Bookworm to upgrade? 0 Quote
Solution Igor Posted April 24, 2024 Solution Posted April 24, 2024 47 minutes ago, Timo12357 said: So 24.2.1 does not require Bookworm to upgrade? Bookworm is latest stable. You can only upgrade to unstable ... which is not recommended for production. You could upgrade kernels, but we don't provide them anymore for bullseye. On 4/12/2024 at 10:35 PM, Timo12357 said: armbian-config says "No other kernels available" That is correct. This is the list of packages per distribution: https://fi.mirror.armbian.de/apt/content.html Bullseye only has some files, probably by mistake. It should be just empty as its not supported anymore. Change tags in armbian.list from bullseye to bookworm and update. Should be fine .... at least as far as from Armbian perspective. We can't vouch for packages that are coming from Debian repository as they might come into some conflicts between each other. This is the problem we observe on older releases and have no capacity nor wish to address. 1 Quote
Timo12357 Posted April 30, 2024 Author Posted April 30, 2024 On 4/24/2024 at 10:12 AM, Igor said: Change tags in armbian.list from bullseye to bookworm and update. Did just that and now I have armbian 24.2.1 Thank you ! 1 Quote
