On 11/21/2018 at 3:59 AM, Fenn said:
I ended up working this out with the help of this post - specifically, if you add the following to /boot/armbianEnv.txt, you can force the video mode.
Some examples:
640x480
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/640x480.bin video=HDMI-A-1:640x480-24@60
1080p
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/1920x1080.bin video=HDMI-A-1:1920x1080@60
I didn't have to install any extra packages or anything using Armbian Debian Stretch / 4.14.78-sunxi, it just worked out of the box (edid files already installed/etc).
Thx mate..this is the right answer on question!
In Armbian-Config you can set the Boot-Env, there was :
disp_mode="1920x1080p60"
I've changed that to "1280x1024p50" but still get the 1024x768.
The TV-DVI-Input I use is a little bad so EDID does not work, but forced 1280x1024 works with my raspberry pi.
Is 1920x1080p60 wrong syntax may be, may be something with -24@50 is needed?
15 minutes ago, yushuiqiang said:
20.08.17 Buster with Linux 5.9.1-sunxi
Outdated packages and
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
Does someone solved the problem with wrong resolution on boot?
I have Waveshare touchscreen LCD(B) with resolution 800x480. Sometimes it detects as expected and after boot my GUI application run well with correct touchscreen coordintaes.
If I run
DISPLAY=:0 xrandr -q
I got output
Screen 0: minimum 320 x 200, current 800 x 480, maximum 8192 x 8192
HDMI-1 connected primary 800x480+0+0 (normal left inverted right x axis y axis) 150mm x 100mm
   800x480       65.68*+
The screen detects default resolution and even screen physical size.
However sometimes it detects wrong and touchscreen coordinates doesn't match to physical position.
If run
I got output
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192
HDMI-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768      60.00*
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
The resolution is wrongs as well as the physical coordinates isn't detected.
I've tried to put this row to armbianEnv.txt
extraargs=drm_kms_helper.edid_firmware=HDMI-A-1:edid/800x480.bin video=HDMI-A-1:800x480-24@60
This solved correct position of bootlogo during boot, but does't solve wrong touchscreen coordinates after boot. Moreover it causes very long boot time (more than 1 minute)
I've tried to put U-boot env and save it
setenv video-mode sunxi:800x480-24@60,monitor=hdmi,hpd=0,edid=0
saveenv
It doesn't work at all.
I've tried to set U-Boot variable
CONFIG_INITIAL_USB_SCAN_DELAY=2000
I was thinking the wrong detection of screen dimension may lay in surface of screen initialization time. However it doesn't help too. The screen initialized before that delay.
I've tried to put conf file to xorg conf according to this topic. It give correct resolution and touchscreen coordinates after boot, but form time to time wrong position of bootlogo.
Does someone find the best solution?
ok so it seems fen's solution would work, but I'm in a pickle here as my monitor resolution is 480x800. I got this screen for KlipperScreen, and it doesn't display anything despite having only an HDMI cable to send the display signal. It's a waveshare display from softpear.
Never messed with U-boot btw so if Fenn's solution works with this display that'd be great
The armbian server 23.05 5.15 is installed on the tv box. Automatically set 4k resolution on hdmi boot konsole.  I tried everything you wrote but it didn't work. always the same. I would like to set the hd resolution...
