crazyquark Posted April 20, 2024 Posted April 20, 2024 (edited) Hello, I would like to add support for Milk-V Mars in the Armbian build system. Right now I am building for visionfive2(build boots fine with u-boot in spi) and intend to see if I can reuse the DTBs produced by the Milk-V Mars official SDK build(https://github.com/milkv-mars/mars-buildroot-sdk/releases/). I am looking for guidance on how to proceed. The board has the same SoC as the Visionfive2 but different peripherals (USB, m.2). L.E. I realized that the bootloader from the image cannot boot the image, the “official “ u-boot from SPI flash is used instead. Possibly due to some incompatible config. Edited April 20, 2024 by crazyquark 0 Quote
crazyquark Posted April 20, 2024 Author Posted April 20, 2024 Started work here: https://github.com/crazyquark/armbian-buildI forked the kernel source from the official Mars repo(split off only kernel sources). Will be building an image and testing it in my Mars board. 0 Quote
Platima Cooks Posted June 29, 2024 Posted June 29, 2024 Armbian Lichee Pi 4A image has Meles DTB in the boot partition :) 0 Quote
Igor Posted June 29, 2024 Posted June 29, 2024 10 hours ago, Platima Cooks said: Armbian Lichee Pi 4A image has Meles DTB in the boot partition This is common. Sometimes other (similar or identical) board's DT is used and we always bundle more DTs in the package. 0 Quote
crazyquark Posted April 9 Author Posted April 9 (edited) FYI, I've updated the fork, now I am using `starfive-linux` for the kernel(currently 6.14) instead of the old one provided by MilkV. There is also some (maybe minimal) support for Mars in the mainline kernel. I need to look into the GPU driver. The board boots, I do not know yet about HDMI output and other features but I am testing. `uname -a` says: `Linux mars 6.14.0-rc3-edge-milkv-mars #1 SMP Mon Feb 17 09:04:34 UTC 2025 riscv64 GNU/Linux` Edited April 9 by crazyquark 0 Quote
crazyquark Posted April 17 Author Posted April 17 HDMI is sadly not working. Everything else seems fine. No GPU driver, of course. 0 Quote
