Hello
I try to connect to a nfs drive on boot by using fstab
my fstab entry is
xxx.xxx.xxx.xxx:/MP3   /home/MP3   nfs   nouser,atime,auto,rw,dev,exec,suid 0   0
mount -a work properly and I have access to the drive after mounting it.
the problem apear after reboot  my OP , on the display I see the attached picture. ofcours ssh connection is also dead. if is remove the fstab input the OP bot rpoperly again
I use the armbian 5.25 debian jessie version, I also try wit 5.24.
do you have an idea how to solve this issue
let me know if I should provide somme logs.
thank you for your help
It's a quirk with systemd... I had the same problem...  _netdev doesn't work either..    Switch to systemd automounter and it'll magically work when you access it..
diskstation:/volume6/linuxmirror /mnt/linuxmirror nfs defaults,x-systemd.automount 0 0
Hello @lanefu
thank you for your answer but unfortunaly thids tip also doe'nt work for me.
hello
I solved my problem with
XXX.XXX.XXX.XXX:/MP3 /home/MP3 nfs noauto,x-systemd.automount 0 0
