anon Posted March 15, 2017 Posted March 15, 2017 Hi! Banana pi m1, armbian Ubuntu Xenial Legacy 3.4.113, bluetooth usb dongle. I can find bananapi from other devices, but can`t pair whit any device. journalctl -u bluetooth ar 15 16:05:11 bananapi systemd[1]: Starting Bluetooth service... Mar 15 16:05:11 bananapi bluetoothd[646]: Bluetooth daemon 5.37 Mar 15 16:05:11 bananapi bluetoothd[646]: Starting SDP server Mar 15 16:05:11 bananapi systemd[1]: Started Bluetooth service. Mar 15 16:05:11 bananapi bluetoothd[646]: Bluetooth management interface 1.0 initialized Mar 15 16:05:11 bananapi bluetoothd[646]: Failed to obtain handles for "Service Changed" characteristic Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Error adding Link Loss service Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Current Time Service could not be registered Mar 15 16:05:11 bananapi bluetoothd[646]: gatt-time-server: Input/output error (5) Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Not enough free handles to register service Mar 15 16:05:11 bananapi bluetoothd[646]: Sap driver initialization failed. Mar 15 16:05:11 bananapi bluetoothd[646]: sap-server: Operation not permitted (1) Mar 15 16:13:07 bananapi bluetoothd[646]: Ignoring unsupported UUID for addition Any ideas?
Igor Posted March 15, 2017 Posted March 15, 2017 https://www.armbian.com/banana-pi ->"Known issues" I have two different USB BT keys and both work fine only on mainline kernel.
anon Posted March 15, 2017 Author Posted March 15, 2017 Yeh, I checked. Problem in kernel? Are there ways to solve the problem? Recompile the kernel? Patches? I need only legacy kernel for video acceleration.
arox Posted March 16, 2017 Posted March 16, 2017 Here a nanopi neo with a logilink bt0009 paired with a "chip" root@hub:~# lsusb | grep -i bluetooth Bus 008 Device 002: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode) root@hub:~# uname -a Linux hub 3.4.113-sun8i #20 SMP PREEMPT Fri Dec 30 14:37:10 CET 2016 armv7l armv7l armv7l GNU/Linux root@hub:~# echo "paired-devices" | bluetoothctl [NEW] Controller 00:15:83:54:9C:58 hub [default] [NEW] Device A0:2C:36:25:26:F3 btst [bluetooth]# paired-devices Device A0:2C:36:25:26:F3 btst [DEL] Controller 00:15:83:54:9C:58 hub [default] [bluetooth]# root@hub:~# bluetoothd -v 5.37 But I had a lot of trouble with the same dongle yesterday to connect through RFCOMM and used a BT0015 for that use With bluez never try to understand why or when it works or dont. So ... Same player shoot again : try not to be too close or too far, avoid interferences (usb, wifi, bt ...), reboot to clean kernel and user space daemon state, remove devices, clean /var/lib/bluetooth, stop scan as soon as you have discovered peer, increase delay in main.conf ...
