A20 use of gpio
Go to solution Solved by zador.blood.stained,
I export a range of GPIOs and then  when i see the list of available GPIOs i see this
root@micro:~# ls /sys/class/gpio/
export  gpio16  gpio23  gpio30  gpio38  gpio45  gpio52  gpio6
gpio1   gpio17  gpio24  gpio31  gpio39  gpio46  gpio53  gpio60
gpio10  gpio18  gpio25  gpio32  gpio4   gpio47  gpio54  gpio61
gpio11  gpio19  gpio26  gpio33  gpio40  gpio48  gpio55  gpio7
gpio12  gpio2   gpio27  gpio34  gpio41  gpio49  gpio56  gpio8
gpio13  gpio20  gpio28  gpio35  gpio42  gpio5   gpio57  gpio9
gpio14  gpio21  gpio29  gpio36  gpio43  gpio50  gpio58  gpiochip1
gpio15  gpio22  gpio3   gpio37  gpio44  gpio51  gpio59  unexport
root@micro:~#
Instead i should see something like this :
 root@A20:~# ls /sys/class/gpio/
   export       gpio21_pc3/  gpio33_pb8/  gpio45_ph27/ gpio57_ph17/ gpio69_pg5/
   gpio10_pe9/  gpio22_pc7/  gpio34_pb10/ gpio46_ph0/  gpio58_ph18/ gpio6_pe5/
   gpio11_pe10/ gpio23_pc16/ gpio35_pb11/ gpio47_ph2/  gpio59_ph19/ gpio70_pg6/
   gpio12_pe11/ gpio24_pc17/ gpio36_pb12/ gpio48_ph7/  gpio5_pe4/   gpio71_pg7/
   gpio13_pi14/ gpio25_pc18/ gpio37_pb13/ gpio49_ph9/  gpio60_ph20/ gpio72_pg8/
   gpio14_pi15/ gpio26_pc23/ gpio38_pb14/ gpio4_pe3/   gpio61_ph21/ gpio73_pg9/
   gpio15_pi0/  gpio27_pc24/ gpio39_pb15/ gpio50_ph10/ gpio62_ph22/ gpio74_pg10/
   gpio16_pi1/  gpio28_pb3/  gpio3_pe2/   gpio51_ph11/ gpio63_ph23/ gpio75_pg11/
   gpio17_pi2/  gpio29_pb4/  gpio40_pb16/ gpio52_ph12/ gpio64_pg0/  gpio7_pe6/
   gpio18_pi3/  gpio2_pe1/   gpio41_pb17/ gpio53_ph13/ gpio65_pg1/  gpio8_pe7/
   gpio19_pi10/ gpio30_pb5/  gpio42_ph24/ gpio54_ph14/ gpio66_pg2/  gpio9_pe8/
   gpio1_pe0/   gpio31_pb6/  gpio43_ph25/ gpio55_ph15/ gpio67_pg3/  gpiochip1/
   gpio20_pi11/ gpio32_pb7/  gpio44_ph26/ gpio56_ph16/ gpio68_pg4/  unexport
This was changed for the compatibility with different libraries that use GPIO sysfs interface, and can be changed back to display native port bank and pin number by compiling a modified kernel.
The pins tha are available  are the same pins with the pin name removed for example gpio10_pe9 is the same as gpio10?
Or in  gpio10 the 10 is computed from the type :    (  position of letter in alphabet-1)*32 + pin number           ??
