Virgus Posted November 1, 2015 Posted November 1, 2015 Hello, I just received a replacement unit of my Lamobo-R1 board and I'd like to test it with an SD card I've currently running on a BananaPro with the latest Armbian release. Is there a way to use it on the Lamobo-R1 without having to reinstall & reconfigure everything? Thanks, V.
Igor Posted November 2, 2015 Posted November 2, 2015 Upgrade to latest and move card to R1. It should work out of the box / both kernels. If you need to boot from SATA drive than change a u-boot loader to lamobo-r1. Remove the banana's at that time to avoid problems. Check here: http://www.armbian.com/kernel/
