The latest desktop image has as much "HW decoding" support as was available in that beta image.
Currently only limited HW accelerated video decoding is possible, that's all. There are no plans to integrate the Mali driver.
I recently acquired an A64+ 2GB model with the optional WiFi.  I created an SD card with the latest nightly image.  Logging in I get the following:
Welcome to ARMBIAN 5.27.170410 nightly Ubuntu 16.04.2 LTS 4.10.0-pine64
So far it appears to be functioning well except it doesn't appear to recognize the wifi.   ifconfig shows only eth0 and lo interfaces.  iwconfig also shows only eth0 and lo.  lsmod shows no modules loaded.  Running dmesg I noticed the following WARNINGs:
<cut>
[    0.000000] psci: Trusted OS migration not required
[    0.000000] WARNING: x1-x3 nonzero in violation of boot protocol:
                x1: 0000000000000000
                x2: 0000000000000000
                x3: 0000000040080000
               This indicates a broken bootloader or old kernel
[    0.000000] percpu: Embedded 23 pages/cpu @ffff80007e794000 s56216 r8192 d29800 u94208
<cut>
[    1.666020] ------------[ cut here ]------------
[    1.666039] WARNING: CPU: 1 PID: 36 at drivers/base/dd.c:349 driver_probe_device+0x258/0x2c0
[    1.666041] Modules linked in:
[    1.666054] CPU: 1 PID: 36 Comm: kworker/1:1 Not tainted 4.10.0-pine64 #42
[    1.666057] Hardware name: Pine64+ (DT)
[    1.666066] Workqueue: events deferred_probe_work_func
[    1.666072] task: ffff80007c1e3200 task.stack: ffff80007c1d4000
[    1.666076] PC is at driver_probe_device+0x258/0x2c0
[    1.666081] LR is at driver_probe_device+0x60/0x2c0
[    1.666085] pc : [<ffff00000857c6b8>] lr : [<ffff00000857c4c0>] pstate: 20000145
[    1.666087] sp : ffff80007c1d7c60
[    1.666090] x29: ffff80007c1d7c60 x28: 0000000000000000
[    1.666096] x27: ffff80007c0d7d20 x26: ffff80007c1df3b8
[    1.666102] x25: ffff000008b37cbb x24: 0000000000000003
[    1.666108] x23: ffff000008b5cc40 x22: 0000000000000001
[    1.666114] x21: 0000000000000000 x20: ffff000008bd6000
[    1.666120] x19: ffff80007c216c10 x18: 0000000000000000
[    1.666126] x17: 00000000fd541423 x16: 00000000768beda0
[    1.666132] x15: ffffffffffffffff x14: ffff80007af1b91c
[    1.666139] x13: ffff80007af1b1e8 x12: 0000000000000020
[    1.666145] x11: 0000000000000020 x10: 0101010101010101
[    1.666151] x9 : 0000000000000008 x8 : 0000000000000008
[    1.666157] x7 : ffff000008864a80 x6 : 0000000000000020
[    1.666163] x5 : ffff80007c216da0 x4 : 0000000000000000
[    1.666168] x3 : ffff80007c1e3200 x2 : ffff000008bd6200
[    1.666174] x1 : ffff80007c216e80 x0 : ffff80007ad7e980
[    1.666183] ---[ end trace 7854786610e49d0e ]---
[    1.666186] Call trace:
[    1.666192] Exception stack(0xffff80007c1d7a90 to 0xffff80007c1d7bc0)
[    1.666197] 7a80:                                   ffff80007c216c10 0001000000000000
[    1.666203] 7aa0: ffff80007c1d7c60 ffff00000857c6b8 ffff80007af2a010 ffff80007af2a000
[    1.666209] 7ac0: ffff80007ad5a068 ffff80007af2a000 ffff80007c1d7b40 ffff0000084f0a04
[    1.666215] 7ae0: ffff80007af2a000 0000000000000001 ffff80007c1d7b10 ffff0000086b6274
[    1.666220] 7b00: ffff80007e7f53e8 ffff0000084f0cf0 ffff80007c1d7b30 ffff0000084f0c8c
[    1.666226] 7b20: ffff80007c3cd680 ffff80007e7f53e8 ffff80007ad7e980 ffff80007c216e80
[    1.666232] 7b40: ffff000008bd6200 ffff80007c1e3200 0000000000000000 ffff80007c216da0
[    1.666237] 7b60: 0000000000000020 ffff000008864a80 0000000000000008 0000000000000008
[    1.666242] 7b80: 0101010101010101 0000000000000020 0000000000000020 ffff80007af1b1e8
[    1.666248] 7ba0: ffff80007af1b91c ffffffffffffffff 00000000768beda0 00000000fd541423
[    1.666253] [<ffff00000857c6b8>] driver_probe_device+0x258/0x2c0
[    1.666259] [<ffff00000857c86c>] __device_attach_driver+0x9c/0xf8
[    1.666268] [<ffff00000857a8b4>] bus_for_each_drv+0x5c/0x98
[    1.666273] [<ffff00000857c33c>] __device_attach+0xc4/0x138
[    1.666278] [<ffff00000857c928>] device_initial_probe+0x10/0x18
[    1.666282] [<ffff00000857b8ac>] bus_probe_device+0x94/0xa0
[    1.666287] [<ffff00000857bd2c>] deferred_probe_work_func+0x74/0xa8
[    1.666296] [<ffff0000080bf8f4>] process_one_work+0x1c4/0x378
[    1.666301] [<ffff0000080bfcec>] worker_thread+0x244/0x498
[    1.666309] [<ffff0000080c5968>] kthread+0xf0/0x120
[    1.666316] [<ffff0000080826c0>] ret_from_fork+0x10/0x50
[    1.669020] sun50i-a64-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
I didn't notice anything else in that would indicate the recognition or initialization of any WiFi.
Thanks for any assistance.
RTL8723BS Wi-Fi driver is not present in those (dev kernel based) images and needs to be compiled manually.
