MarkA007 Posted May 27, 2024 Posted May 27, 2024 G'day Has anyone managed to get our fave OS booting on this device. ? Wyse 3040 (N10D) I've created UEFI boot media, with both Rufus and Etcher, but it dosne't see it as bootable. To prove settings are ok on the device, it boots the deb bookworm usb image I made. Unfortunatly, Deb won't install as this device only has 8GB of flash... hence why I returned again to Armbain Many thanks MarkA 0 Quote
wukongdaily Posted July 20, 2024 Posted July 20, 2024 You can create a PE system using a USB flash drive. Store a software called "DiskImage" in the remaining space of the PE system, which is only 64KB by the way. After booting into the PE system, use "DiskImage" to write the unzipped Armbian image (armbian.img) into it. Note that the detail here is to write the image to "Physical Disk 0". It's an option similar to such physical disk options, not the drive letter. DiskImage_1.6 (Stand_Alone_Version): https://roadkil.net/program.php?ProgramID=12&Action=NewOSID&DownloadVersion=4&Installer=NO 0 Quote
Sonikku Posted Sunday at 06:07 PM Posted Sunday at 06:07 PM I have managed to successfully install Armbian onto the DELL Wyse3040 As mentioned above, the way to do this is to use a PE environment that works on these devices. I used an old version of Hiren's BootCD and booted from it. Then I used a NTFS formatted flash drive with the unzipped image and used Roadkill's Disk Image to write it to the eMMC And it works, beautifully 0 Quote
